    4. CC 2538/2592 Netzwerkkarte im Zigbee Adapter defekt
      watcherkb @Mac_Schmeck last edited by
      @Mac_Schmeck zigbee Adapter auf debug stellen und wenigstens das Log hier einstellen. Sonst kann man schwer helfen
        raspberrypi 2020-08-20 12:36:56.481 info Do not restart adapter system.adapter.zigbee.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:56.481 error instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        zigbee.0 2020-08-20 12:36:55.968 info (4794) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0 2020-08-20 12:36:55.965 error (4794) zigbee.0 invalid process id scenario 4512 vs. own ID 4794. Stopping
        host.raspberrypi 2020-08-20 12:36:54.527 info instance system.adapter.zigbee.0 started with pid 4794
        host.raspberrypi 2020-08-20 12:36:52.219 info Do not restart adapter system.adapter.web.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:52.219 error instance system.adapter.web.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        web.0 2020-08-20 12:36:51.699 info (4783) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        web.0 2020-08-20 12:36:51.695 error (4783) web.0 invalid process id scenario 2103 vs. own ID 4783. Stopping
        host.raspberrypi 2020-08-20 12:36:50.529 info instance system.adapter.web.0 started with pid 4783
        host.raspberrypi 2020-08-20 12:36:48.362 info Do not restart adapter system.adapter.terminal.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:48.362 error instance system.adapter.terminal.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        terminal.0 2020-08-20 12:36:47.847 info (4772) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        terminal.0 2020-08-20 12:36:47.844 error (4772) terminal.0 invalid process id scenario 2088 vs. own ID 4772. Stopping
        host.raspberrypi 2020-08-20 12:36:46.528 info instance system.adapter.terminal.0 started with pid 4772
        host.raspberrypi 2020-08-20 12:36:44.048 info Do not restart adapter system.adapter.pushover.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:44.047 error instance system.adapter.pushover.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        pushover.0 2020-08-20 12:36:43.521 info (4761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        pushover.0 2020-08-20 12:36:43.518 error (4761) pushover.0 invalid process id scenario 2081 vs. own ID 4761. Stopping
        host.raspberrypi 2020-08-20 12:36:42.529 info instance system.adapter.pushover.0 started with pid 4761
        host.raspberrypi 2020-08-20 12:36:41.123 info Do not restart adapter system.adapter.javascript.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:41.123 error instance system.adapter.javascript.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        javascript.0 2020-08-20 12:36:40.597 info (4750) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        javascript.0 2020-08-20 12:36:40.594 error (4750) javascript.0 invalid process id scenario 2062 vs. own ID 4750. Stopping
        host.raspberrypi 2020-08-20 12:36:38.531 info instance system.adapter.javascript.0 started with pid 4750
        host.raspberrypi 2020-08-20 12:36:36.024 info Do not restart adapter system.adapter.iqontrol.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:36.023 error instance system.adapter.iqontrol.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        iqontrol.0 2020-08-20 12:36:35.505 info (4739) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        iqontrol.0 2020-08-20 12:36:35.502 error (4739) iqontrol.0 invalid process id scenario 2047 vs. own ID 4739. Stopping
        host.raspberrypi 2020-08-20 12:36:34.532 info instance system.adapter.iqontrol.0 started with pid 4739
        host.raspberrypi 2020-08-20 12:36:32.762 info Do not restart adapter system.adapter.info.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:32.761 error instance system.adapter.info.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        info.0 2020-08-20 12:36:32.225 info (4720) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        info.0 2020-08-20 12:36:32.222 error (4720) info.0 invalid process id scenario 2036 vs. own ID 4720. Stopping
        host.raspberrypi 2020-08-20 12:36:30.533 info instance system.adapter.info.0 started with pid 4720
        host.raspberrypi 2020-08-20 12:36:28.033 info Do not restart adapter system.adapter.discovery.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:28.032 error instance system.adapter.discovery.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        discovery.0 2020-08-20 12:36:27.509 info (4709) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        discovery.0 2020-08-20 12:36:27.506 error (4709) discovery.0 invalid process id scenario 2029 vs. own ID 4709. Stopping
        host.raspberrypi 2020-08-20 12:36:26.552 info instance system.adapter.discovery.0 started with pid 4709
        host.raspberrypi 2020-08-20 12:36:25.697 info Do not restart adapter system.adapter.backitup.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:25.696 error instance system.adapter.backitup.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        backitup.0 2020-08-20 12:36:25.179 info (4696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        backitup.0 2020-08-20 12:36:25.176 error (4696) backitup.0 invalid process id scenario 2006 vs. own ID 4696. Stopping
        host.raspberrypi 2020-08-20 12:36:22.527 info instance system.adapter.backitup.0 started with pid 4696
        host.raspberrypi 2020-08-20 12:36:20.455 info Do not restart adapter system.adapter.admin.0 because desired by instance
        host.raspberrypi 2020-08-20 12:36:20.454 error instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        admin.0 2020-08-20 12:36:19.937 info (4685) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        admin.0 2020-08-20 12:36:19.934 error (4685) admin.0 invalid process id scenario 1991 vs. own ID 4685. Stopping
        host.raspberrypi 2020-08-20 12:36:18.528 info instance system.adapter.admin.0 started with pid 4685
        host.raspberrypi 2020-08-20 12:36:18.506 info starting 10 instances
        host.raspberrypi 2020-08-20 12:36:18.479 info 10 instances found
        host.raspberrypi 2020-08-20 12:36:18.211 info connected to Objects and States
        host.raspberrypi 2020-08-20 12:36:18.100 info Error inMem-states listening on port 9000
        host.raspberrypi 2020-08-20 12:36:18.082 info Error inMem-objects listening on port 9001
          arteck Developer Most Active @Mac_Schmeck last edited by
          @Mac_Schmeck sagte in CC 2538/2592 Netzwerkkarte im Zigbee Adapter defekt:
          Meine persönliche Erfahrung zur Reichweite von oben genannten Stick zum alten cc2531 ist eher durchschnittlich. Ein bißchen höher ist die Reichweite aber ich hätte mir mehr erhofft.
          ein bisschen ist gut.. aber das ist deine Meinung.. die Tests sagen was anderes.. egal... ist ehh auf jeder Umgebung anders...
          was heisst die verbinden sich nicht.. mach die Karte auf und warte .. bei mir sind es 5 min.. je mehr Geräte desto lönger dauerts.. da diese alle angesprochen werden ob die da sind...
            Mac_Schmeck @arteck last edited by
            @arteck said in CC 2538/2592 Netzwerkkarte im Zigbee Adapter defekt:
            Die Netzwerkkarte hat sich bis gestern innerhalb von Sekunden aktualisiert und alle Geräte hingen am coordinator. Jetzt sind sie alle rot und sind nicht mehr mit Linien mit dem coordinator verbunden.
            Kann das sein daß es mit der Reichweite an dicken Wänden liegt? Ich glaube es sind 36cm dicke Wände. Kann ich mit dem WLAN Kanal vom Stick versuchen noch ein wenig mehr rauszukitzeln?
              was ??? welchen WLAN kanal vom Stick ?????? du musst die Kanäle so einstellen das sich diese nicht in die Quere kommen.. WLAN und Zigbee
                Ich bin mit dem zigbee Adapter auf Kanal 12 und mein wlan ist auf Kanal 2. Sollte dann wohl so in Ordnung sein. Ich habe hier Mal eine Übersicht gesehen mit den WLAN Kanälen in Verbindung mit der Reichweite oder durchsatz, hatte nur daran gedacht daß ich da noch was hätte machen können.
                • FredF
                  FredF Most Active Forum Testing @Mac_Schmeck last edited by
                  Ich glaube eher nicht:
                    Mac_Schmeck @FredF last edited by
                    @FredF said in CC 2538/2592 Netzwerkkarte im Zigbee Adapter defekt:
                    Sondern? Vorschlag?
                    FredF P 2 Replies Last reply Reply Quote 0
                    • FredF
                      @Mac_Schmeck
                      z.B. zigbee Adapter auf Kanal 12 und wlan auf Kanal 11. Halt so das sie sich nicht in die Quere kommen
                        pk68 @Mac_Schmeck last edited by
                        @Mac_Schmeck Man sollte nicht nur dem eigenen WLAN, sondern auch dem der Nachbarn aus dem Wege gehen. Um die zu erkennen, gibt es Apps fürs Handy. Das nützt aber wenig, wenn das WLAN der Nachbarn auf auto steht, d.h. der Kanal wechselt je nach Auslastung. Außerdem tummeln sich gerne mal in den Lücken zwischen WLAN 1 und 6 bzw. 6 und 11 weitere WLAN's. Ich verwende Zigbee-Kanal 25. Kanal 11 oder 26 wäre sicher auch gut geeignet.
                          Mac_Schmeck @pk68 last edited by Mac_Schmeck
                          @pk68
                          Andere WLANs stellen hier keine Probleme da...
                          Ich bin jetzt auf WLAN Kanal 11 und zigbee Kanal 12.
                          So sieht übrigens meine Netzwerkkarte aus. Die Sensoren verbinden sich nur noch mit dem Osram Plug.
                            @Mac_Schmeck vergiss die KArte wenn alles geschaltet wird
                              Mac_Schmeck @arteck last edited by Mac_Schmeck
                              @arteck
                              Das ist leider nicht mehr so.
                              Den Plug hab ich gezogen.
                              Jetzt stehen alle Sensoren auf rot und ich hab keine aktuellen werte mehr.Screenshot_2020-08-23-17-48-32-361_com.android.chrome.jpg
                                Mac_Schmeck last edited by Mac_Schmeck
                                Hallo nochmals.
                                nachdem ich jetzt den zigbee adapter nochmal gelöscht habe und eine neue Instanz installiert habe und die geräte wieder gekoppelt habe war alles i.O.
                                Dann habe ich das Kabel samt stick gezogen und eine Verlängerung noch dazwischen gehangen, seitdem ist die netzwerkkarte wieder futsch und die geräte stehen zwar in der liste reagieren aber nicht. Bin der Meinung das jetzt in der Netzwerkkarte vom coordinator zum gerät die nwk Addr. (Network Adress?) fehlt.
                                Ausserdem habe ich mit Antenne am Stick immer noch die gleichen Empfangswerte wie ohne Antenne. Das kann doch auch nicht normal sein?!
                                  Hallo.
                                  Habt ihr noch eine Idee wenn die Netzwerkkarte futsch ist?
                                  Sobald der Strom zum pi4 samt Stick kurz weg ist ist danach die Netzwerkkarte futsch und der coordinator verbindet sich im Anschluss nur noch mit den repeatern/Steckdosen aber nicht mehr mit den Sensoren.
                                    @Mac_Schmeck vergiss die karte
                                      @arteck ja ich denn gar nichts versuchen das es wieder funktioniert?
                                      Die Link Qualität wird auf der Geräte Seite auch nicht mehr aktualisiert.
                                        ok das ist nicht korrekt...
                                        wie kurz weg.. ??
                                        und aktualisiere die version..oben steht du hast noch die 1.2
                                          Zigbee Adapter steht auf 1.2.1. soll ich auf eine GitHub version aktualisieren?
                                          Das Problem mit der Netzwerkkarte ist seitdem ich den cc2538/2592 Stick habe.
                                          Wenn der Strom kurz weg ist damit mein ich Stromausfall, das passiert alle paar Monate. Falls du noch weitere Infos brauchst lasse mich es wissen.
                                            Kann man hier noch was erkennen woran es liegen könnte?
                                            1.0k
                                            cc2538 cc2538 + cc2592
                                            1871
