    4. [gelöst] Telegram produziert Fehler
    UNSOLVED [gelöst] Telegram produziert Fehler
    • Lumo74
      Lumo74 @MCU last edited by
      @MCU
      aktuell bekomme ich iot nicht "grün"... DNS Server auf google gesetzt und in der Fritzbox kein Einschränkungen.
      Telegram will auch nicht. springt zwischen gelb und grün. mit alter Fehlermeldung. Noch ideen wie ich das problem weiter einkreisen kann?
      iot.0	2020-08-21 15:20:22.933	warn	(2950) [GHOME] Invalid URL Pro key. Status auto-update is disabled you can set states but receive states only manually: Error: connect ECONNREFUSED 54.192.209.118:443
      iot.0	2020-08-21 15:20:22.932	error	(2950) [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: Error: connect ECONN
      iot.0	2020-08-21 15:20:22.886	warn	(2950) hm-rpc.0.BidCoS-RF.2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Dev
      iot.0	2020-08-21 15:20:22.885	warn	(2950) hm-rpc.0.BidCoS-RF.1 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Dev
      iot.0	2020-08-21 15:20:22.883	warn	(2950) hm-rpc.0.NAA0001422.2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google De
      iot.0	2020-08-21 15:20:22.883	warn	(2950) hm-rpc.0.NAA0001422.1 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google De
      • haselchen
        haselchen Most Active @Lumo74 last edited by
        @Lumo74
        Versuch im IOT Adapter nen neues Zertifikat zu laden. Gibt nen Button in den Einstellungen.
        Lumo74 1 Reply Last reply Reply Quote 0
        • Lumo74
          Lumo74 @haselchen last edited by
          @haselchen
          scheint auch nicht zu greifen.
          jetzt ist der alexa auch noch gelb. In den Einstellung ist das Warnschild zu sehen mit der Bitte, sich doch neu bei Amazon anzumelden. Klicke ich den Link kommt:
          Proxy-Error: Error: connect ECONNREFUSED 52.85.92.219:443
          • haselchen
            @Lumo74
            Benutzt du Pi Hole ?
            • Lumo74
              @haselchen
              nein aktuell nicht
              • haselchen
                haselchen Most Active @Lumo74 last edited by haselchen
                @Lumo74
                Das wäre noch ne Fehlerquelle sonst gewesen.
                Und wenn du in der Fritzbox den DNS Server vom Provider beziehen anhakst? (Standardeinstellung)
                Vermutlich dann die Fritzbox neu starten.
                • Lumo74
                  @haselchen
                  Ich glaube die DNS Auflösung läuft.
                  aber eure Ideen mit dem Netzwerk könnte passen. Ich hab jetzt mal alles neu gestartet.. und wenn ich dann das log auf Error filter sehe ich zwar IPs aber er erreicht die Services nicht:
                  yr.0	2020-08-21 16:36:02.896	error	(1473) Error: Unexpected close tag Line: 0 Column: 168 Char: >
                  dwd.0	2020-08-21 16:33:02.577	error	(30216) Empty or invalid JSON: Cannot read JSON file: null
                  info.0	2020-08-21 16:23:57.477	error	(940) Error: connect ECONNREFUSED 151.101.0.133:443
                  host.iobroker	2020-08-21 16:11:02.834	error	instance system.adapter.yr.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  yr.0	2020-08-21 16:11:02.789	error	(27916) force terminate
                  weatherunderground.0	2020-08-21 16:10:02.449	error	(855) No forecast data found in response
                  weatherunderground.0	2020-08-21 16:10:02.449	error	(855) No current observation data found in response
                  weatherunderground.0	2020-08-21 16:10:02.445	error	(855) Wunderground reported an error: --/Error: connect ECONNREFUSED 104.102.20.84:443
                  weatherunderground.0	2020-08-21 16:10:02.437	error	(855) Wunderground reported an error: --/Error: connect ECONNREFUSED 104.102.20.84:443
                  weatherunderground.0	2020-08-21 16:10:02.425	error	(855) Wunderground reported an error: --/Error: connect ECONNREFUSED 104.102.20.84:443
                  iot.0	2020-08-21 16:09:14.099	error	(32167) Cannot read keys: Error: connect ECONNREFUSED 54.230.183.129:443
                  iot.0	2020-08-21 16:09:05.155	error	(31931) Cannot read keys: Error: connect ECONNREFUSED 54.230.183.129:443
                  hatte das schon mal jemand? mir fehlt grade jeder Ansatz zum suchen..
                  • haselchen
                    @Lumo74
                    Mit alles neu gestartet auch iobroker?
                    Hab gerade gelesen du benutzt eine SSD.
                    Puh, ich glaube genau das Netzwerkthema hatten wir vor ein paar Tagen hier auch.
                    Ich meine da haben wir @Thomas-Braun ins Boot geholt.
                    • Lumo74
                      @haselchen
                      Ich habe das Problem für mich erkannt/gelöst und schreibe das mal kurz auf, damit das Thema einen Schluss bekommt.
                      Der Fehler trat aus nach dem Update auf FritzOS 7.20. Ein Rollback auf 7.12 hat alle Fehlermeldungen oben ohne Änderungen im IOBroker oder dem Raspberry gelöst.
                      Die Adapter laufen wieder einwandfrei.
                      Ich hatte versucht ein paar der IPs der Traceroute aufzurufen das hatte aber nicht funktioniert. Irgendwann habe ich dann das WLAN vom Raspberry hoch gefahren und über dieses Interface konnte ich die IPs sauber erreichen. Ich gehe also davon aus, dass in der 7.20 eine Änderungen in den Firewall regeln ist die ich nicht sehen konnte.
                      • haselchen
                        @Lumo74
                        Die 7.20 habe ich auch und permanent DSL Abbrüche.
                        Geht es dir mit der Version auch so?
                        • Lumo74
                          @haselchen
                          hab ein Glasfaser Kabelmodem hinter der Fritz.
                          Aber wie gesagt, vor dem Update auf 7.20 soweit alles gut. Mit dem Update auf 7.20 kamen die Bugs, welche mit dem Downgrade auch sofort wieder weg waren.
                          Bin jetzt auf der 7.12 und geht alles und gefühlt auch flotter.
                          • haselchen
                            @Lumo74
                            Hast du das Downgrade über die AVM .exe gemacht?
                            Oder ne Firmware Datei, die Du über die GUI eingespielt hast?
                            • Lumo74
                              Lumo74 @haselchen last edited by Lumo74
                              @haselchen
                              ja gibt einen Download:
                              https://avm.de/service/fritzbox/fritzbox-7590/wissensdatenbank/publication/show/257_Alteres-FRITZ-OS-installieren-Downgrade/
                              über einen ethernetport verbinden und fritzbox neu starten ist easy und gut beschrieben.
                              aber Achtung das Backup der Einstellungen was man aus der 7.20 zieht lässt sich auf dem Downgrade nicht einspielen. d.h. ggf. Handarbeit beim Einrichten.
                              • haselchen
                                @Lumo74
                                😂😂😂😂😂 kommt 24 Stunden zu spät der Hinweis.......
                                Wenigstens läuft jetzt alles wieder.
                                Aber das nur Softwaregleiche Versions-Sicherungen eingespielt werden können ist der größte Witz des Jahres.
                                • Röstkartoffel
                                  Röstkartoffel last edited by Röstkartoffel
                                  Ich habe auf meiner Fritzbox die 07.12, die 07.20 wird noch nicht angeboten und trotzdem erhalte ich seit zwei Tagen immer zur gleichen Uhrzeit folgende Fehlermeldung im Log:
                                  2020-08-28 03:35:08.297 - warn: telegram.0 (30221) polling_error:EFATAL, EFATAL: Error: read ECONNRESET
                                  2020-08-28 03:35:08.326 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2020-08-28 03:35:08.327 - error: telegram.0 (30221) unhandled promise rejection: EFATAL: Error: read ECONNRESET
                                  2020-08-28 03:35:08.327 - error: telegram.0 (30221) RequestError: Error: read ECONNRESET
                                  at new RequestError (/opt/iobroker/node_modules/request-promise-core/lib/errors.js:14:15)
                                  at Request.plumbing.callback (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:87:29)
                                  at Request.RP$callback [as _callback] (/opt/iobroker/node_modules/request-promise-core/lib/plumbing.js:46:31)
                                  at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                                  at Request.emit (events.js:198:13)
                                  at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
                                  at ClientRequest.emit (events.js:198:13)
                                  at TLSSocket.socketErrorListener (_http_client.js:401:9)
                                  at TLSSocket.emit (events.js:198:13)
                                  at emitErrorNT (internal/streams/destroy.js:91:8)
                                  at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                                  at process._tickCallback (internal/process/next_tick.js:63:19)
                                  2020-08-28 03:35:08.830 - info: telegram.0 (30221) terminating
                                  2020-08-28 03:35:08.831 - info: telegram.0 (30221) Terminated (NO_ERROR): Without reason
                                  2020-08-28 03:35:09.343 - info: host.ioBroker instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
                                  2020-08-28 03:35:09.344 - info: host.ioBroker Restart adapter system.adapter.telegram.0 because enabled
                                  Es wurden keinerlei Updates kurz vor dem erstmalilgen Auftritt der Fehlermeldung durchgeführt.
                                  Das gesamte System läuft störungsfrei, alle Adapter default up to date, iot Adapter ist nicht installiert.
                                  Hat jemand einen Tip, was da los ist?
                                  • haselchen
                                    haselchen Most Active @Röstkartoffel last edited by
                                    @Röstkartoffel
                                    Im Log der Fritzbox mal geguckt, ob zu der Uhrzeit etwas passiert ist?
                                    Zwangstrennung oder dergleichen?
                                    Röstkartoffel 1 Reply Last reply Reply Quote 0
                                    • Röstkartoffel
                                      Röstkartoffel @haselchen last edited by
                                      @haselchen
                                      Hast recht, zu dem Zeitpunkt findet die Zwangstrennung statt.
                                      Aber dieser Fehler ist früher nie aufgetreten, vorgestern zum ersten Male, und die Zwangstrennung ist schon seit Jahren so eingestellt.
                                      • haselchen
                                        @Röstkartoffel
                                        Diese Fehlerzeilen habe ich auch, wenn was mit dem Internet im Argen ist.
                                        War auch für mich neu.
                                        Vielleicht kann ein Entwickler dazu was sagen.
                                        econnrefused fritzbox fritzos 7.20 telegram
                                        1554
