    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
    • XxJooO
      XxJooO @dirkhe last edited by
      @dirkhe , bitte schön...
      true	true	lgtv.0	2020-07-29 12:07:55.874
      false	true	lgtv.0	2020-07-29 14:30:18.658
      true	true	lgtv.0	2020-07-29 14:53:05.074
      false	true	lgtv.0	2020-07-29 15:15:20.727
      true	true	lgtv.0	2020-07-29 17:10:45.873
      false	true	lgtv.0	2020-07-29 19:13:14.852
      true	true	lgtv.0	2020-07-29 20:38:27.763
      false	true	lgtv.0	2020-07-29 21:58:20.164
      true	true	lgtv.0	2020-07-29 22:00:55.765
      false	true	lgtv.0	2020-07-30 10:13:10.677
      true	true	lgtv.0	2020-07-30 10:36:00.946
      false	true	lgtv.0	2020-07-30 12:07:32.753
      true	true	lgtv.0	2020-07-30 12:11:25.597
      false	true	lgtv.0	2020-07-30 13:01:32.676
      true	true	lgtv.0	2020-07-30 15:05:51.057
      false	true	lgtv.0	2020-07-30 16:04:59.603
      true	true	lgtv.0	2020-07-30 16:12:52.545
      false	true	lgtv.0	2020-07-30 16:12:54.697
      true	true	lgtv.0	2020-07-30 18:35:13.491
      false	true	lgtv.0	2020-07-30 18:48:36.277
      true	true	lgtv.0	2020-07-30 18:50:18.088
      false	true	lgtv.0	2020-07-30 18:50:18.741
      true	true	lgtv.0	2020-07-30 19:13:28.994
      false	true	lgtv.0	2020-07-30 19:13:29.048
      true	true	lgtv.0	2020-07-30 19:17:33.233
      false	true	lgtv.0	2020-07-30 19:17:34.089
      true	true	lgtv.0	2020-07-30 20:08:03.876
      false	true	lgtv.0	2020-07-30 20:08:04.654
      true	true	lgtv.0	2020-07-30 21:40:47.101
      false	true	lgtv.0	2020-07-30 21:41:13.149
      true	true	lgtv.0	2020-07-30 21:41:24.865
      false	true	lgtv.0	2020-07-30 21:41:28.671
      true	true	lgtv.0	2020-07-30 21:41:50.303
      false	true	lgtv.0	2020-07-30 21:41:53.400
      true	true	lgtv.0	2020-08-03 18:29:47.445
      false	true	lgtv.0	2020-08-03 19:07:06.929
      true	true	lgtv.0	2020-08-03 19:19:48.598
      false	true	lgtv.0	2020-08-03 19:56:42.319
      true	true	lgtv.0	2020-08-03 20:05:26.257
      false	true	lgtv.0	2020-08-03 20:05:28.094
      true	true	lgtv.0	2020-08-03 21:28:42.841
      false	true	lgtv.0	2020-08-03 21:35:01.458
      true	true	lgtv.0	2020-08-04 21:48:39.513
      false	true	lgtv.0	2020-08-04 22:53:49.119
      true	true	lgtv.0	2020-08-05 19:43:40.679
      false	true	lgtv.0	2020-08-05 21:16:39.059
      true	true	lgtv.0	2020-08-05 21:28:17.563
      false	true	lgtv.0	2020-08-05 21:28:21.357
      Es sind genügend geloggte Ereignisse bei denen, an- und binnen einer Sekunde wieder ausgeschaltet geloggt wurde...
      usw.
      Und ich möchte betonen, dass die Corona-Kinder under der Rest der Familie im Ausland weilt. Ich bin alleine und veranschalte keine Schaltorgien...
        dirkhe Developer @XxJooO last edited by
        @XxJooO hattest du deine JavaScript bzw blocky abgeschaltet? Wie ich schon mal geschrieben habe, müsste im debug Log dann auch diese schaltvotgänge geloggt werden
        • Dalmatino
          Dalmatino @dirkhe last edited by
          @dirkhe
          Danke, mir hats geholfen
          Lg👍🏻
            blackeagle998 last edited by
            bei mir wird die aktuelle Lautstärke im Datenpunkt Volume nicht angezeigt (bleibt leer).
            Die Steuerung lauter/leiser funktioniert.
            Das betrifft alle Eingänge, egal ob interne Antenne oder HDMI.
            Adapterversion: 1.1.9
            WebOS: 5.1.0-3304
            Hat noch jemand das Problem?
              dirkhe Developer @blackeagle998 last edited by
              @blackeagle998 kannst du mal den adapter auf debug stellen und dann die Lautstärke ändern und das dann hier Posten, bitte
                blackeagle998 @dirkhe last edited by blackeagle998
                @dirkhe
                lgtv.0	2020-08-21 00:04:30.573	debug	(22310) TV is off
                lgtv.0	2020-08-21 00:04:29.071	debug	(22310) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"","returnValue":true,"windowId":"","processId":""}
                lgtv.0	2020-08-21 00:04:28.703	debug	(22310) State change "remote.power" - VALUE: {"val":true,"ack":false,"ts":1597961068696,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1597961068696}
                lgtv.0	2020-08-21 00:04:28.702	debug	(22310) State change "remote.power" - VALUE: true
                lgtv.0	2020-08-21 00:04:15.197	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":4,"soundOutput":"tv_speaker","maxVolume":100},"retur
                lgtv.0	2020-08-21 00:04:15.191	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                lgtv.0	2020-08-21 00:04:15.191	debug	(22310) State change "states.volumeDown" - VALUE: true
                lgtv.0	2020-08-21 00:04:14.366	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":5,"soundOutput":"tv_speaker","maxVolume":100},"retur
                lgtv.0	2020-08-21 00:04:14.349	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                lgtv.0	2020-08-21 00:04:14.348	debug	(22310) State change "states.volumeDown" - VALUE: true
                lgtv.0	2020-08-21 00:04:13.101	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeUp","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":6,"soundOutput":"tv_speaker","maxVolume":100},"returnV
                lgtv.0	2020-08-21 00:04:13.086	debug	(22310) Sending volumeUp true command to WebOS TV: 192.xxx.xxx.xx
                lgtv.0	2020-08-21 00:04:13.085	debug	(22310) State change "states.volumeUp" - VALUE: true
                lgtv.0	2020-08-21 00:04:11.528	debug	(22310) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                lgtv.0	2020-08-21 00:04:11.506	debug	(22310) State change "states.soundOutput" - VALUE: tv_speaker
                lgtv.0	2020-08-21 00:04:09.639	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":5,"soundOutput":"tv_speaker","maxVolume":100},"retur
                lgtv.0	2020-08-21 00:04:09.633	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                lgtv.0	2020-08-21 00:04:09.632	debug	(22310) State change "states.volumeDown" - VALUE: true
                lgtv.0	2020-08-21 00:04:08.235	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":6,"soundOutput":"tv_speaker","maxVolume":100},"retur
                lgtv.0	2020-08-21 00:04:08.230	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                lgtv.0	2020-08-21 00:04:08.230	debug	(22310) State change "states.volumeDown" - VALUE: true
                lgtv.0	2020-08-21 00:04:07.088	debug	(22310) audio/getVolume: {"volumeStatus":{"cause":"volumeDown","mode":"normal","adjustVolume":true,"activeStatus":true,"muteStatus":false,"volume":7,"soundOutput":"tv_speaker","maxVolume":100},"retur
                lgtv.0	2020-08-21 00:04:07.082	debug	(22310) Sending volumeDown true command to WebOS TV: 192.xxx.xxx.xx
                lgtv.0	2020-08-21 00:04:07.081	debug	(22310) State change "states.volumeDown" - VALUE: true
                lgtv.0	2020-08-21 00:04:01.907	debug	(22310) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                lgtv.0	2020-08-21 00:04:01.863	debug	(22310) getCurrentSWInformation: {"returnValue":true,"product_name":"webOSTV 5.0","model_name":"HE_DTV_W20H_AFADABAA","sw_type":"FIRMWARE","major_ver":"03","minor_ver":"10.28","country":"DE","country
                lgtv.0	2020-08-21 00:04:01.555	debug	(22310) getSystemInfo: {"returnValue":true,"features":{"dvr":false},"receiverType":"DVB","modelName":"86UN85006LA","programMode":true}
                lgtv.0	2020-08-21 00:04:01.504	debug	(22310) renew connection in one minute for stable subscriptions...
                lgtv.0	2020-08-21 00:04:01.491	debug	(22310) Service list: {"returnValue":true,"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"config","version":1},{"name":"externalpq","version":1},{"name":"media.controls",
                lgtv.0	2020-08-21 00:04:01.433	debug	(22310) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":8,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerI
                lgtv.0	2020-08-21 00:04:01.431	debug	(22310) cur app is com.webos.app.hdmi1
                lgtv.0	2020-08-21 00:04:01.430	debug	(22310) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi1","subscribed":true,"returnValue":true,"windowId":"","processId":""}
                lgtv.0	2020-08-21 00:04:01.218	debug	(22310) WebOS TV Connected
                lgtv.0	2020-08-21 00:04:00.707	debug	(22310) Connecting to WebOS TV: ws://192.xxx.xxx.xx:3000
                lgtv.0	2020-08-21 00:03:59.668	debug	(22310) Send WOL to MAC: {xx:xx:xx:xx:xx:xx} OK
                lgtv.0	2020-08-21 00:03:59.657	debug	(22310) GetState mac: {"val":"xx:xx:xx:xx:xx:xx","ack":true,"ts":1597957048597,"q":0,"from":"system.adapter.lgtv.0","user":"system.user.admin","lc":1597954699324}
                lgtv.0	2020-08-21 00:03:59.654	debug	(22310) State change "states.power" - VALUE: true
                  @blackeagle998 ok, anscheinend haben die das Antwort JSON geändert. Kannst du mir bitte nochmal den gefallen tun und mute drücken und das loggen? Ich würde das dann einbauen.
                  @SchuetzeSchulz ich denke, wir müssen hier nach cause suchen anstelle von changed. Soll ich das machen oder willst du das direkt machen?
                  B S 2 Replies Last reply Reply Quote 0
                    @dirkhe
                    Na aber sehr gerne doch, Mute geht zu schalten:
                    2020-08-21 21:38:50.176  - debug: lgtv.0 (19579) adapter.config = {"ip":"192.xxx.xxx.xx","mac":"xx:xx:xx:xx:xx:xx","timeout":"5000","reconnect":"5000","power":true,"healthIntervall":""}
                    2020-08-21 21:38:50.225  - debug: lgtv.0 (19579) Connecting to WebOS TV: ws://192.xxx.xxx.xx:3000
                    2020-08-21 21:38:50.331  - debug: lgtv.0 (19579) WebOS TV Connected
                    2020-08-21 21:38:50.349  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"secondscreen.client"}
                    2020-08-21 21:38:50.416  - debug: lgtv.0 (19579) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi1","subscribed":true,"returnValue":true,"windowId":"","processId":""}
                    2020-08-21 21:38:50.417  - debug: lgtv.0 (19579) cur app is com.webos.app.hdmi1
                    2020-08-21 21:38:50.424  - debug: lgtv.0 (19579) Service list: {"returnValue":true,"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"config","version":1},{"name":"externalpq","version":1},{"name":"media.controls","version":1},{"name":"media.viewer","version":1},{"name":"pairing","version":1},{"name":"settings","version":1},{"name":"system","version":1},{"name":"system.launcher","version":1},{"name":"system.notifications","version":1},{"name":"timer","version":1},{"name":"tv","version":1},{"name":"user","version":1},{"name":"webapp","version":2}]}
                    2020-08-21 21:38:50.434  - debug: lgtv.0 (19579) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                    2020-08-21 21:38:50.437  - debug: lgtv.0 (19579) renew connection in one minute for stable subscriptions...
                    2020-08-21 21:38:50.443  - debug: lgtv.0 (19579) getSystemInfo: {"returnValue":true,"features":{"dvr":false},"receiverType":"DVB","modelName":"xxx","programMode":true}
                    2020-08-21 21:38:50.499  - debug: lgtv.0 (19579) getCurrentSWInformation: {"returnValue":true,"product_name":"webOSTV 5.0","model_name":"xxx","sw_type":"FIRMWARE","major_ver":"03","minor_ver":"10.28","country":"DE","country_group":"EU","device_id":"xx:xx:xx:xx:xx:xx","auth_flag":"N","ignore_disable":"N","eco_info":"01","config_key":"00","language_code":"de-DE"}
                    2020-08-21 21:39:00.438  - debug: lgtv.0 (19579) State change "states.soundOutput" - VALUE: tv_speaker
                    2020-08-21 21:39:00.466  - debug: lgtv.0 (19579) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                    2020-08-21 21:39:25.476  - debug: lgtv.0 (19579) State change "states.mute" - VALUE: true
                    2020-08-21 21:39:25.477  - debug: lgtv.0 (19579) Sending mute true command to WebOS TV: 192.xxx.xxx.xx
                    2020-08-21 21:39:25.486  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":true,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"com.webos.service.apiadapter"}
                    2020-08-21 21:39:31.050  - debug: lgtv.0 (19579) State change "states.mute" - VALUE: false
                    2020-08-21 21:39:31.051  - debug: lgtv.0 (19579) Sending mute false command to WebOS TV: 192.xxx.xxx.xx
                    2020-08-21 21:39:31.061  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"com.webos.service.apiadapter"}
                    2020-08-21 21:39:35.216  - debug: lgtv.0 (19579) system.adapter.admin.0: logging true
                    2020-08-21 21:39:48.305  - debug: lgtv.0 (19579) system.adapter.admin.0: logging false
                    2020-08-21 21:39:50.443  - debug: lgtv.0 (19579) Connection closed: 1000
                    2020-08-21 21:39:50.941  - debug: lgtv.0 (19579) Connecting to WebOS TV: ws://192.xxx.xxx.xx:3000
                    2020-08-21 21:39:51.006  - debug: lgtv.0 (19579) WebOS TV Connected
                    2020-08-21 21:39:51.027  - debug: lgtv.0 (19579) audio/getVolume: {"volumeStatus":{"activeStatus":true,"adjustVolume":true,"maxVolume":100,"muteStatus":false,"volume":10,"mode":"normal","soundOutput":"tv_speaker"},"returnValue":true,"callerId":"secondscreen.client"}
                    2020-08-21 21:39:51.070  - debug: lgtv.0 (19579) DEBUGGING getForegroundAppInfo: {"appId":"com.webos.app.hdmi1","subscribed":true,"returnValue":true,"windowId":"","processId":""}
                    2020-08-21 21:39:51.071  - debug: lgtv.0 (19579) cur app is com.webos.app.hdmi1
                    2020-08-21 21:39:51.075  - debug: lgtv.0 (19579) Service list: {"returnValue":true,"services":[{"name":"api","version":1},{"name":"audio","version":1},{"name":"config","version":1},{"name":"externalpq","version":1},{"name":"media.controls","version":1},{"name":"media.viewer","version":1},{"name":"pairing","version":1},{"name":"settings","version":1},{"name":"system","version":1},{"name":"system.launcher","version":1},{"name":"system.notifications","version":1},{"name":"timer","version":1},{"name":"tv","version":1},{"name":"user","version":1},{"name":"webapp","version":2}]}
                    2020-08-21 21:39:51.083  - debug: lgtv.0 (19579) audio/getSoundOutput: {"soundOutput":"tv_speaker","subscribed":true}
                    2020-08-21 21:39:51.088  - debug: lgtv.0 (19579) getSystemInfo: {"returnValue":true,"features":{"dvr":false},"receiverType":"DVB","modelName":"xxx","programMode":true}
                    2020-08-21 21:39:51.155  - debug: lgtv.0 (19579) getCurrentSWInformation: {"returnValue":true,"product_name":"webOSTV 5.0","model_name":"xxx","sw_type":"FIRMWARE","major_ver":"03","minor_ver":"10.28","country":"DE","country_group":"EU","device_id":"xx:xx:xx:xx:xx:xx","auth_flag":"N","ignore_disable":"N","eco_info":"01","config_key":"00","language_code":"de-DE"}
                      SchuetzeSchulz @dirkhe last edited by
                      @dirkhe Kannst Du gern machen.
                      Machst Du dann einen Pull-Request?
                        @blackeagle998 Kannst du bitte mal von github (https://github.com/dirkhe/ioBroker.lgtv) installieren und schauen, ob es funktioniert? Ich habe jetzt mal zusätzlich die neue Struktur abgefragt. Wenn es klappt, würde ich den PR stellen
                          @dirkhe
                          Funktioniert, besten Dank für den schnellen Support!!!
                            SchuetzeSchulz last edited by
                            Pull request ist gemerged. 🙂
                            Danke Dirk!
                              A Former User @SchuetzeSchulz last edited by
                              @SchuetzeSchulz
                              vielen Dank, der Adapter läuft mit allen Funktionen mit einem 86UN85006LA ( WebOs 5 ).
                              Nur ist mir beim Installieren des Adapters LG aufgefallen, dass er keine Instanz 0 anlegt, sondern gleich eine Instanz 1.
                              Warum? Weil ich für meinen älteren 2011er LG TV den LG11-Adapter installiert habe, und da meint der LG Adapter anscheinend, dass schon eine Instanz vorhanden ist...
                              Vielleicht beim nächsten Update mal dran denken, ist ja kein Beinbruch, hat mich nur gewundert... 🙂
                              S B 2 Replies Last reply Reply Quote 0
                                SchuetzeSchulz @Guest last edited by
                                @ilovegym
                                Sorry, das kann ich hier nicht nachvollziehen. Bei mir korrekt eine 0er Instanz erzeugt:
                                  blackeagle998 @Guest last edited by blackeagle998
                                  @ilovegym
                                  da ich den gleichen TV habe, kurze Frage:
                                  Kannst du mit dem Switch lgtv.0.states.power den Fernseher an und ausschalten?
                                  An geht bei mir, für aus muss ich immer lgtv.0.remote.power nehmen.
                                  @SchuetzeSchulz
                                  Ist das aus Adapter Sicht korrekt oder muss hier wegen einem geänderten JSON noch was angepasst werden?
                                    @SchuetzeSchulz
                                    hmm hattest du den lgtv11 zuerst installiert?
                                    ich teste nochmal auf dem Testsystem..
                                    Hi, habs gerade auf dem Testsystem ausprobiert, da war der lg11 adapter installiert, und der lg-adapter wurde als Instanz 1 installiert. Mit der 0 bekomm ich das nicht hin.. :-()
                                      A Former User @blackeagle998 last edited by
                                      @blackeagle998 ja, ich schalte mit Power an und aus, ging aber erst, nachdem ich am TV "Wireless lan support" oder sowas aktiviert hatte.. hatte mir n Wolf gesucht.. da der TV per Kabel angeschlossen ist, und ich den eigentlich nicht im Wlan haben möchte.. geht aber nur so.. anscheinend wird dann der Energiesparmodus abgeschaltet für das Netzwerkmodul...
                                        @ilovegym
                                        Hmm das will bei mir einfach nicht funktionieren...
                                        Mein TV ist per Kabel dran und der einzige Menüpunkt wo sich die von dir erwähnte Einstellung noch verstecken kann, ist "Erweiterte Wi-Fi Einstellungen". Der Punkt ist bei mir aber ausgegraut, da der TV per LAN verbunden ist.
                                        Verstehe ich das richtig, dass du deinen TV nun doch per WLAN verbunden hast?
                                        Wenn ich lgtv.0.state.power auf false switche passiert nichts, der TV bleibt einfach an.
                                          A Former User @blackeagle998 last edited by A Former User
                                          @blackeagle998 das nennt sich TV ein mit Mobilgerät,
                                          Management der mobilinhalte...
                                            @ilovegym @SchuetzeSchulz @dirkhe
                                            Die genannte Option ist bei mir aktiviert, geht trotzdem nicht 🙁
                                            Ich habe die Instanz mal auf Debug gestellt, hier die relevanten LOG Zeilen:
                                            2020-08-24 21:39:54.671  - debug: lgtv.0 (26205) State change "states.power" - VALUE: false
                                            2020-08-24 21:39:54.672  - debug: lgtv.0 (26205) Sending turn OFF command to WebOS TV: 192.xxx.xxx.xx
                                            2020-08-24 21:40:00.265  - debug: lgtv.0 (26205) system.adapter.admin.0: logging true
                                            Laut LOG sendet er "turn OFF", der TV reagiert aber nicht darauf.
                                            Noch ne Idee dazu?
                                            lgtv
                                            113
                                            861
                                            312059
