    4. Fehlermeldung Module js.550
    UNSOLVED Fehlermeldung Module js.550
      Franta last edited by
      Ich habe folgende wiederkehrende Fehlermeldung:
      throw err;
      2020-08-24 17:28:14 stdout module.js:550
      2020-08-24 17:27:58 stdout
      2020-08-24 17:27:58 stdout at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2020-08-24 17:27:58 stdout at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      2020-08-24 17:27:58 stdout at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      2020-08-24 17:27:58 stdout at Socket.adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
      2020-08-24 17:27:58 stdout at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
      2020-08-24 17:27:58 stdout at Array.forEach (<anonymous>)
      2020-08-24 17:27:58 stdout at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
      2020-08-24 17:27:58 stdout at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
      2020-08-24 17:27:58 stdout at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
      2020-08-24 17:27:58 stdout TypeError: Cannot read property 'split' of undefined
      2020-08-24 17:27:43 stdout
      2020-08-24 17:27:43 stdout at Function.Module._load (module.js:498:3)
      2020-08-24 17:27:43 stdout at tryModuleLoad (module.js:506:12)
      2020-08-24 17:27:43 stdout at Module.load (module.js:566:32)
      2020-08-24 17:27:43 stdout at Object.Module._extensions..js (module.js:664:10)
      2020-08-24 17:27:43 stdout at Module._compile (module.js:653:30)
      2020-08-24 17:27:43 stdout at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ping/node_modules/@iobroker/adapter-core/build/index.js:29:54)
      2020-08-24 17:27:43 stdout at require (internal/module.js:11:18)
      2020-08-24 17:27:43 stdout at Module.require (module.js:597:17)
      2020-08-24 17:27:43 stdout at Function.Module._load (module.js:475:25)
      2020-08-24 17:27:43 stdout at Function.Module._resolveFilename (module.js:548:15)
      2020-08-24 17:27:43 stdout Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/exitCodes'
      Ich bin Neuling. Vielleicht kann mir jemand helfen?
      |Hardwaresystem:| DS 411+II|
      |Arbeitsspeicher:| 8GB |
      |Festplattenart:| WD Red |
      |Betriebssystem:| Mac |
      |Node-Version:| 8.1 |
      |NPM-Version:| 6.x.x |
      Thomas Braun AlCalzone 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Franta last edited by
        @Franta
        nodejs -v && node -v && npm -v
        • AlCalzone
          AlCalzone Developer @Franta last edited by
          @Franta Dein JS-Controller ist zu alt für den ping-Adapter, bitte upgraden.
            Thomas Braun Most Active @AlCalzone last edited by
            @AlCalzone Der Rest scheint aber auch nicht frischer zu sein.
              Franta @Thomas Braun last edited by
              @Thomas-Braun ich kann leider im Terminal gar nichts mehr eingeben.... kommt immer nur diese Meldung
                Thomas Braun Most Active @Franta last edited by Thomas Braun
                @Franta Strg-C drücken.
                Ich sehe gerade, das ist so'n Synology-Kram...
                Da bin ich raus, das ist mir zu 'krumm'.
                • AlCalzone
                  @Franta Fang mal damit an, den Ping-Adapter zu stoppen.
                  F 1 Reply Last reply Reply Quote -1
                    Franta99 @AlCalzone last edited by
                    @AlCalzone wie komme ich denn dahin, wenn der Terminal nicht mehr auf die Eingaben reagiert?
                    Das ist ja mein größtes Problem...
                    • AlCalzone
                      AlCalzone Developer @Franta99 last edited by AlCalzone
                      @Franta99 Kannst du auf der Diskstation nicht einfach ein zusätzliches Terminal aufmachen? Ansonsten in der Admin UI stoppen.
                        @AlCalzone Vielen Dank! Werde es probieren!
                        js controller module
                        473
