    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    • Amnesia1211
      Amnesia1211 last edited by
      @Dutchman
      Hier ein Auszug aus dem Log, hoffe es Hilft dir bei der Fehlersuche.
      2020-08-14 04:53:25.465 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
      2020-08-14 04:53:25.511 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.consumed.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      2020-08-14 04:53:25.511 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
      2020-08-14 04:53:25.558 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.meterReadings.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      2020-08-14 04:53:25.558 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
      2020-08-14 04:53:25.603 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.costs.weeks.28 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      2020-08-14 04:53:25.604 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
      2020-08-14 04:53:25.650 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.consumed.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      2020-08-14 04:53:25.650 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
      2020-08-14 04:53:25.696 - warn: sourceanalytix.0 (29949) Object sonoff__0__NAS0__ENERGY_Power.2020.meterReadings.weeks.29 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
      2020-08-14 04:53:25.696 - warn: sourceanalytix.0 (29949) This object will not be created in future versions. Please report this to the developer.
      Das ganze ging noch so weiter aber dann wird das hier zu groß denke ich....
      Danke schon mal für deine Mühe und Hilfe.
        dtp @Amnesia1211 last edited by dtp
        @Amnesia1211 Diese Warnmeldungen hatte ich auch zuhauf. War mit ein Grund, weshalb ich den Adapter erst mal wieder deinstalliert habe.
          Malz1902 @Andy200877 last edited by
          @Andy200877
          Habe das als Cron, f täglich 23.59 Sonntags um 23.59 und am 31.12. um 23.59 klappt, aber wie mache ich das für am Ende des Monats?
          SourceAnalytix habe mir den Adapter gerade installiert. Habe eine Steckdose per Sonoff Adapter, haben die SourceAnalytix für den Datenpunkt Energy Total aktiviert ist das richtig so? Wo finde ich denn dann die Werte täglich, monatlich, jährlich?
          • X
            xbow42 @Malz1902 last edited by
            @Malz1902 Cron "0 0 1 * *" jeden 1. im Monat 00:00
            Atifan 1 Reply Last reply Reply Quote 0
            • Atifan
              Atifan @xbow42 last edited by
              Falls es jemand brauchen kann.
              Habe mir jetzt zwei Blockly Scripte erstellt, mit denen ich den Stromverbrauch und den Wasserverbrauch der letzten 7 Tage logge und mir in Grafana anzeigen lasse.
              Brauche also kein Sourceanalytics mehr. Einziger Nachteil ist, meine Anzeige ist <heute, gestern, vorgestern, vor 3 Tagen, vor 4 Tagen, vor 5 Tagen, vor 6 Tagen> statt wie bei Sourceanalytics <Montag, Dienstag, Mittwoch, Donnerstag, Freitag, Samstag, Sonntag>.
                <block type="schedule" id="D8b8A[Vu|6HiotAVpgf/" x="-1488" y="188">
                  <field name="SCHEDULE">{"time":{"exactTime":true,"start":"23:59"},"period":{"days":1}}</field>
                    <block type="update" id="):pA.YXuccNrThTR!:N,">
                      <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_00_Zählerstand_Tagesende</field>
                        <block type="get_value" id="7G`A!*:dx08%5B96elT]">
                          <field name="OID">parser.0.Wasseruhr</field>
                        <block type="update" id="6KoxJ{5#BCT=E)KF{Zr8">
                          <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_07_vor_6_Tagen</field>
                            <block type="get_value" id="iBYl1VhiXq6|z?;O(w/|">
                              <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_06_vor_5_Tagen</field>
                            <block type="update" id="*OGNM{DqDcaZu+6AC8Um">
                                <block type="get_value" id="5C5(HYu#,S_BSa66[@GQ">
                                  <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_05_vor_4_Tagen</field>
                                <block type="update" id="f^A-M[@es2H*}8,-$hK+">
                                    <block type="get_value" id="t?,5sT(3Y-yBo:[`^~%p">
                                      <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_04_vor_3_Tagen</field>
                                    <block type="update" id="y;x[:/!)QiA-b.8`]*D=">
                                        <block type="get_value" id="qG_mF^qIWz!M*wL3Ps?a">
                                          <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_03_vorgestern</field>
                                        <block type="update" id="H);_jP,CNUlYzpv^T0#X">
                                            <block type="get_value" id="2wx:gHJ,h=qqxUDn1l=G">
                                              <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_02_gestern</field>
                                            <block type="update" id=")@ujF(DE4(p9[OK*%:m}">
                                                <block type="get_value" id="jh[d9[qpG{6~pR@t^t5y">
                                                  <field name="OID">javascript.0.eigene_Datenpunkte.Wasserverbrauch_01_heute_aktuell</field>
                                                <block type="update" id="7Im|mD4[-Z.D:(U9F(x/">
                                                    <block type="math_number" id="M_;P6hIKRvX_b?QW*DJ2">
                                                      <field name="NUM">0</field>
                <block type="on_ext" id="f+pE0a@G*zU-by@6FUe(" x="-1488" y="638">
                  <value name="OID0">
                    <shadow type="field_oid" id="C,Ac-zm;SE@/roO8`H/+">
                      <field name="oid">parser.0.Wasseruhr</field>
                    <block type="update" id="C4J;CKp8]3C[X*9ZIz*v">
                        <block type="math_arithmetic" id="WW(1[CJW}{hk}w~P$kd#">
                            <shadow type="math_number" id="/tsl(y~_b6?I+crCT^i!">
                              <field name="NUM">1</field>
                            <block type="math_arithmetic" id="!d}dAx;/HL+a^8}z/BFL">
                                <shadow type="math_number" id="_b8?QPIY?$6*D;mVJFL-">
                                <block type="get_value" id="0vp2e}Gb^x1mjg#FiqJy">
                                <shadow type="math_number" id="BwEZeMiifVwZBCfG6yq(">
                                <block type="get_value" id="+jIc+6OgAA@abWq$L)@V">
                            <shadow type="math_number" id="86+t92VTmBO)X4eOtNG:">
                              <field name="NUM">1000</field>
              Strom Netzbezug der letzten 7 Tage
                      <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_00_Zählerstand_Tagesende</field>
                          <field name="OID">smartmeter.0.1-0:1_8_0__255.value</field>
                          <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_07_vor_6_Tagen</field>
                              <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_06_vor_5_Tagen</field>
                                  <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_05_vor_4_Tagen</field>
                                <block type="update" id="4+Yu3VFi-g]4or8^ljH%">
                                    <block type="get_value" id="c$3H$:n61`+:iYM+GG_j">
                                      <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_04_vor_3_Tagen</field>
                                    <block type="update" id="KNZk!f$11}lld2/U_|VE">
                                        <block type="get_value" id="i3i^9sbtjB3qr:Nb!T9R">
                                          <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_03_vorgestern</field>
                                        <block type="update" id="vZNud[nG`/c4G:s#!xLy">
                                            <block type="get_value" id="hfT!REZ9|yzwNXo@uUR)">
                                              <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_02_gestern</field>
                                            <block type="update" id="z::D,8y8HP:a];[?B3+F">
                                                <block type="get_value" id="I}jFb{rET+wP~rcw#[si">
                                                  <field name="OID">javascript.0.eigene_Datenpunkte.Strombezug_aus_Netz_01_heute_aktuell</field>
                <block type="on_ext" id="f+pE0a@G*zU-by@6FUe(" x="-1487" y="613">
                  <value name="OID0">
                      <field name="oid">smartmeter.0.1-0:1_8_0__255.value</field>
              • Atifan
                Atifan @Atifan last edited by
                Anbei noch ein Screenshot der Datenpunkte die man vorher manuell anlegen muss.
                • Atifan
                  Das Ergebnis in Grafana sieht bei mir dann so aus:
                  • hg6806
                    hg6806 Most Active @Atifan last edited by
                    Also bei mir läuft noch die Version 0.3.0. gut und fehlerfrei.
                    Einziges Problem, es fehlen halt die Werte letzte Tage, Wochen, Monate, Jahre.
                    Ich muss also jede Woche hier die Werte nachtragen, damit ich im folgenden Bar Chart die Wochen aktuell habe:
                    Ich bin allerdings mit dem Bar Chart nicht ganz zufrieden, da nur max. 8 erstellt werden können.
                    Gibt es andere Bar Charts ohne weitere Scripte nutzen zu müssen, die mehr darstellen können?
                    Mit Flot bin ich auch nicht weitergekommen.
                    • Dutchman
                      Dutchman Developer Most Active Administrators @hg6806 last edited by
                      @hg6806 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                      leider musste ich durch persönliche umstände die letzten wochen/monate ein bisschen abstand nemen, so wie man im forum sieht und auf git läuft aber alles allmalig wieder an und damit auch die weiter Entwicklung dieses adapters.
                      Nieste Wochen erst noch Prioritäten mit Adaptern richtig setzen dan gehts weiter.... sorry leute fürs lange warten aber manchmal muss man .... 😕
                      1 Reply Last reply Reply Quote 6
                        gerald123 last edited by
                        Leider will bei mir SourceAnalytix die Werte nicht Berechnen. Installiert ist bei mir die Version 0.4.5
                        Ich lese bei mir den Wasserzähler aus und schreibe den aktuellen wert in ein Objekt und SourceAnalytix aktiviert.
                        Die SourceAnalytix Objekte wurden auch alle automatisch angelegt, sie bleiben aber alle leer.
                        Kann mir jemand sagen woran das liegen kann?
                        crunchip Dutchman 2 Replies Last reply Reply Quote 0
                          crunchip Forum Testing Most Active @gerald123 last edited by
                          @gerald123 ich gehe mal davon aus, daß dein Datenpunkt keine Unit aufweißt und somit der Adapter nicht berechnen kann
                            gerald123 @crunchip last edited by
                            @crunchip Was meinst du mit Unit
                              crunchip Forum Testing Most Active @gerald123 last edited by crunchip
                              @gerald123 Dein DP Wasserverbrauch muss eine Unit haben, dein Zählerstand kann ja Apfel/Birne sein, der Adapter soll umwandeln auf Banane, also braucht er die Unit zum umrechnen
                                @crunchip Ich habe jetzt eine eingetragen, ändert leider auch nichts
                                crunchip 2 Replies Last reply Reply Quote 0
                                  @gerald123 Zählerstand bei Tagesbeginn noch richtig eintragen
                                    @crunchip da habe ich jetzt einfach mal 10 eingegeben
                                      @gerald123 Warum???
                                      wenn dein Zählerstand 11,301 ist, dann trag das auch so ein
                                        @crunchip ist jetzt auch so eingetragen, leider noch immer keine Änderung
                                          @gerald123 lass mal die Badewanne voll laufen, dann sollte sich auch was ändern☺
                                            @crunchip Dann gehe ich mal Duschen und dann sehe ich ob sich was ändert
                                            81.1k
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            351566
