    4. Apple Homekit Siri
    Apple Homekit Siri
    • Alex1808
      Alex1808 last edited by
      @venni:
      OK, ist die gleiche Version 4.4.7.
      Aber es funktioniert dann tadellos. :shock:
      Vielen Dank für den Tipp! `
      ich freue mich dass es funktioniert hat 🙂
        chka last edited by
        Ich bekomme es einfach nicht mit Eve gekoppelt, er bricht immer wieder ab. Des Weiteren kann ich es auch nur auf dem master iobroker installieren (Multihost)
        • eric2905
          eric2905 last edited by
          bei mir schmiert der Adapter leider ab:
          host-iobroker 2016-07-17 17:22:49.995 info Restart adapter system.adapter.homekit.0 because enabled
          host-iobroker 2016-07-17 17:22:49.994 error instance system.adapter.homekit.0 terminated with code 0 (OK)
          Error: 2016-07-17 17:22:49.973 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          Error: 2016-07-17 17:22:49.973 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
          Error: 2016-07-17 17:22:49.973 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
          Error: 2016-07-17 17:22:49.973 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
          Error: 2016-07-17 17:22:49.973 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
          Error: 2016-07-17 17:22:49.973 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
          Error: 2016-07-17 17:22:49.973 error at require (internal/module.js:12:17)
          Error: 2016-07-17 17:22:49.973 error at Module.require (module.js:353:17)
          Error: 2016-07-17 17:22:49.973 error at Function.Module._load (module.js:276:25)
          Error: 2016-07-17 17:22:49.973 error at Function.Module._resolveFilename (module.js:325:15)
          Error: 2016-07-17 17:22:49.973 error Cannot find module 'hap-nodejs/node_modules/node-persist'
          uncaught 2016-07-17 17:22:49.972 error exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
          homekit-0 2016-07-17 17:22:49.940 info hap-nodejs starting...
          homekit-0 2016-07-17 17:22:49.938 debug received all objects
          homekit-0 2016-07-17 17:22:49.533 debug received all states
          homekit-0 2016-07-17 17:22:48.532 debug requesting all objects
          homekit-0 2016-07-17 17:22:48.528 debug requesting all states
          homekit-0 2016-07-17 17:22:48.524 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
          homekit-0 2016-07-17 17:22:48.424 debug statesDB connected
          homekit-0 2016-07-17 17:22:48.414 debug objectDB connected
          host-iobroker 2016-07-17 17:22:47.762 info instance system.adapter.homekit.0 started with pid 7095
          Jemand ne Idee?
          __Nachtrag 19.07.2016:
          Habe den Adapter jetzt komplett deaktiviert, gelöscht und neu eingebunden - leider ohne Erfolg.
          Werde heute Abend nochmal auf die Suche nach 'hap-nodejs/node_modules/node-persist" gehen, was ja anscheinend nicht gefunden wird.__
          Danke und Gruß,
          Eric
            Rookman last edited by
            Hallo zusammen, gibt es im HomeKit Adapter die Möglichkeit nur Geräte eines bestimmten Gewerk anzuzeigen?
            Auch versuche ich verzweifelt meine Dreh-Fenster-Kontakte mit einzubinden aber leider ohne Erfolg, kann mir hier jemand behilflich sein?
            Es werden auch meine ganzen Programme mit ausgegeben, was ich auch nicht möchte, da gibt es doch bestimmt einen Trick 😉
            Viele Grüße Rookman
              Michy last edited by
              Nabend,
              habe mir heute die Beta2 von IOS 10 für mein Iphone geladen und die beinhaltet auch die neue Apple "Home Smart Home" -App.
              Verbinden konnte ich die App mit dem HomeKit des IoBrokers ohne Probleme. Beim Einrichten der einzelnen Homematic-Geräte und meiner Hue-Lampen
              sind jedoch immer wieder die Meldungen "Die Verbindung des Gerätes wurde unterbrochen, überprüfen Sie die Internetverbindung" aufgetreten.
              Nachdem ich dann alle Meldungen immer wieder ignoriert hatte und alle Geräte eingebunden waren, kam ich dann auf die Hauptansicht.
              Und da ist es passiert. Der HomeKit Adapter stürzt ab- jedes mal wenn ich die App neu starte.
              Im Log des Iobrokers wird mir dazu folgendes angezeigt.
              TypeError:	2016-07-26 18:38:32.897	error	at HAPServer._handleCharacteristics (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
              TypeError:	2016-07-26 18:38:32.897	error	at HAPServer.emit (events.js:175:7)
              TypeError:	2016-07-26 18:38:32.897	error	at emitThree (events.js:97:13)
              TypeError:	2016-07-26 18:38:32.897	error	at Bridge.Accessory._handleGetCharacteristics (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
              TypeError:	2016-07-26 18:38:32.897	error	at Array.forEach (native)
              TypeError:	2016-07-26 18:38:32.897	error	at Bridge. (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
              TypeError:	2016-07-26 18:38:32.897	error	at Characteristic.getValue (/root/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
              TypeError:	2016-07-26 18:38:32.897	error	at emit (events.js:172:7)
              TypeError:	2016-07-26 18:38:32.897	error	at emitTwo (events.js:87:13)
              TypeError:	2016-07-26 18:38:32.897	error	at null. (/root/node_modules/iobroker.homekit/main.js:759:37)
              TypeError:	2016-07-26 18:38:32.897	error	Cannot read property 'val' of undefined
              uncaught	2016-07-26 18:38:32.892	error	exception: Cannot read property 'val' of undefined
              Die Node/Nodejs Versionen habe ich mithilfe des vorherigen Posts aktualisiert.
              Wäre super wenn mir da wer weiterhelfen kann, würde gerne die Hauseigenen Systeme von Apple für die Steuerung der Geräte über den IOBroker
              nutzen.
              VG Michy
              • Bluefox
                Bluefox last edited by
                Kannst du die version probieren?
                cd /opt/iobroker
                npm install https://github.com/ioBroker/ioBroker.homekit/tarball/master --production
                  @Bluefox:
                  cd /opt/iobroker
                  die Version 0.1.4 habe ich vorher deinstalliert - die neue Version 0.1.5. einmal über SSH und per Terminal installiert. Lief alles sauber durch und habe auch jeweils neugestartet. Bei der Installation über SSH habe ich den IOBroker zusätzlich gestoppt.
                  Leider ist der Adapter nicht unter "Instanzen" aufgeführt und unter Objekte wird mir auch nichts angezeigt.
                  Nachtrag: HomeKit 0.1.4 installiert und per Terminal die von dir genannte Version installiert. Auch kein Erfolg.
                  Vielleicht mache ich was falsch?
                  VG Michy
                  • jens.maus
                    jens.maus last edited by
                    Also bei mir funktioniert leider auch mit der 0.1.5 version die Kopplung an mein iPhone immer noch nicht. ioBroker wird zwar als Gerät angezeigt und ich kann auch den Code eingeben, aber dann kommt immer "Gerät konnte nicht hinzugefügt werden". Habe schon verschiedenes probiert von Pincode ändern über Username ändern usw. Leider alles ohne Erfolg inkl. zich mal komplett neu installieren. Das problem hatte ich schon mit iOS 9 und der Eve App und nun mit iOS 10 und der von Apple nativen HomeKit app geht es leider immer noch nicht.
                    Hat irgendwer eine Idee wie man das Problem eingrenzen kann?
                      schnallibert last edited by
                      Hallo, danke für den Adapter!! Funktioniert super, Installation war einfach. Habe erst vor zwei tagen ioBroker mal testweise auf einer neu erstellten Debian Jessie VM installiert und dann den Homekit Adapter installiert.
                      Derzeit habe ich Testweise die CCU2 und die Hue's eingebunden.
                      Ich würde gerne die Temperatur des HM-TC-IT-WM-W-EU auslesen und in der Insteon+ App anzeigen lassen. (im Übrigen bringt die EVE App den Homekit Adapter zum crashen… passiert aber auch bei der nfarina variante)
                      Der HM-TC-IT-WM-W-EU wird in der App auch angezeigt. Jedoch nur dass das Gerät von Homematic seie und dessen Seriennummer.
                      Die Hues hat er lustigerweise auch gleich mit reingepackt, scheinbar weil es die Rolle level.dimmer benutzt....
                      Was genau muss bei Name und bei der Rolle definiert sein und von was wird ein "funktionierendes" Temperatur Accesorie abhängig gemacht?
                        @jens.maus:
                        Hat irgendwer eine Idee wie man das Problem eingrenzen kann? `
                        stürzt der HomeKit Adapter mit Version 0.1.5. ab? Wenn ja, dann wäre der Log mal interessant.
                        Wenn der Fehler mit Version 0.1.4. weg, ist könnte es sein, dass wir einen Schritt weiter sind. 8-)
                        Gruß Michy
                        • jens.maus
                          @Michy:
                          @jens.maus:
                          Wenn der Fehler mit Version 0.1.4. weg, ist könnte es sein, dass wir einen Schritt weiter sind. 8-) `
                          Also ich sehe hier nicht das irgendetwas abstürzt. Ich bin nur einfach nicht in der Lage ioBroker in der HomeKit App auf iOS hinzuzufügen. Habe hier schon alles mögliche probiert, ohne erfolg, leider… Ich wüsste jetzt auch nicht wie ich das problem Debuggen sollte.
                            chka last edited by
                            eben noch mal ausprobiert das gleiche wie bei Jens
                            • eric2905
                              bei mir schmiert der Adapter ab.
                              Hier das Log dazu:
                              host-iobroker 2016-07-28 21:21:14.848 info instance system.adapter.homekit.0 started with pid 1734
                              host-iobroker 2016-07-28 21:21:04.884 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
                              tankerkoenig-0 2016-07-28 21:21:04.371 info force terminating adapter after 1 minute
                              host-iobroker 2016-07-28 21:20:44.842 info Restart adapter system.adapter.homekit.0 because enabled
                              host-iobroker 2016-07-28 21:20:44.841 error instance system.adapter.homekit.0 terminated with code 0 (OK)
                              Error: 2016-07-28 21:20:44.822 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                              Error: 2016-07-28 21:20:44.822 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
                              Error: 2016-07-28 21:20:44.822 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
                              Error: 2016-07-28 21:20:44.822 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                              Error: 2016-07-28 21:20:44.822 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                              Error: 2016-07-28 21:20:44.822 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
                              Error: 2016-07-28 21:20:44.822 error at require (internal/module.js:12:17)
                              Error: 2016-07-28 21:20:44.822 error at Module.require (module.js:353:17)
                              Error: 2016-07-28 21:20:44.822 error at Function.Module._load (module.js:276:25)
                              Error: 2016-07-28 21:20:44.822 error at Function.Module._resolveFilename (module.js:325:15)
                              Error: 2016-07-28 21:20:44.822 error Cannot find module 'hap-nodejs/node_modules/node-persist'
                              uncaught 2016-07-28 21:20:44.821 error exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
                              homekit-0 2016-07-28 21:20:44.789 info hap-nodejs starting...
                              homekit-0 2016-07-28 21:20:44.787 debug received all objects
                              homekit-0 2016-07-28 21:20:44.394 debug received all states
                              homekit-0 2016-07-28 21:20:43.344 debug requesting all objects
                              homekit-0 2016-07-28 21:20:43.340 debug requesting all states
                              homekit-0 2016-07-28 21:20:43.336 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.homekit
                              homekit-0 2016-07-28 21:20:43.244 debug statesDB connected
                              homekit-0 2016-07-28 21:20:43.231 debug objectDB connected
                              host-iobroker 2016-07-28 21:20:42.559 info instance system.adapter.homekit.0 started with pid 1725
                              Die Installation des Adapters lief ohne Probleme durch (Errorcode 0).
                              Fehlt dem Adapter irgendwas an Installationsfiles?
                              Gruß,
                              Eric
                                Diese Fehler:
                                schließen für mich auf das Fehlen von Modul node-persist hin…
                                Die Version 0.1.5 bekomme ich übrigens nicht installiert.
                                Hat die schon jemand installiert und getestet?!
                                Gruß Michy
                                • Bluefox
                                  Es wird node 4.x.x gebraucht.
                                  • jens.maus
                                    @Bluefox:
                                    Es wird node 4.x.x gebraucht. `
                                    Vielleicht solltest du überlegen das minimum an nodejs version auf 4.x.x zu pumpen und beim start von ioBroker darauf zu prüfen?
                                    Ich habe hier aber node 4.4.7 und dort bekomme ich aber trotzdem nicht das homekit mit ioBroker verbunden - es schmiert aber auch nicht ab?!?!
                                    • eric2905
                                      Hi Mich,
                                      @Michy:
                                      schließen für mich auf das Fehlen von Modul node-persist hin… `
                                      nee, das war's leider nicht - die Fehlermeldung bleibt gleich.
                                      Noch jemand eine Idee?
                                      Gruß,
                                      Eric
                                        @eric2905:
                                        Hi Mich,
                                        @Michy:
                                        Gruß,
                                        Eric `
                                        Hi Eric,
                                        Danke für dein Feedback! Dann müssen wir weiter suchen..
                                        Habe die aktuellste Version also, 4.x.x installiert. Bei mir kommt trotzdem der gleiche Fehler.
                                        Gruß Michy
                                        • Bluefox
                                          Ich kann euch leider nicht helfen.
                                          Aber im August sollte mein Nachbarn mit viel Apple Geräten den ioBroker installieren und ich hoffe, das ich bei ihm das testen kann.
                                            @Bluefox:
                                            Aber im August sollte mein Nachbarn mit viel Apple Geräten den ioBroker installieren und ich hoffe, das ich bei ihm das testen kann. `
                                            Das wäre super. Mir fällt bisher erstmal kein möglicher Lösungsansatz ein.
                                            250
                                            52391
