    4. Test Adapter mihome-vacuum v2.0.x
      SchuetzeSchulz @dirkhe last edited by
      @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
      @SchuetzeSchulz am besten den adapter msl auf debug stellen und stsrt und stop testen
      Hallo Dirk,
      hier das Log (in Zeile 26 sieht man das ich den Saugvorgang über Objekte gestartet habe, in Zeile 9 habe ich auch wieder über Objekte clean_home auf false gesetzt nur scheint das beim Adapter nicht anzukommen?):
      2020-08-25 09:01:29.399  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":15,"method":"get_status"}
      2020-08-25 09:01:29.405  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":918,"state":8,"battery":100,"clean_time":209,"clean_area":5615000,"error_code":0,"map_present":0,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":15}
      2020-08-25 09:01:29.406  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":16,"method":"get_consumable"}
      2020-08-25 09:01:29.411  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"main_brush_work_time":126741,"side_brush_work_time":126741,"filter_work_time":126741,"sensor_dirty_time":126741}],"id":16}
      2020-08-25 09:01:29.907  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":17,"method":"get_clean_summary"}
      2020-08-25 09:01:29.913  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[3179394,46403550000,1387,[1598248800,1598162400,1598076000,1597989600,1597903200,1597816800,1597730400]],"id":17}
      2020-08-25 09:01:31.479  - debug: mihome-vacuum.1 (7951) system.adapter.admin.0: logging false
      2020-08-25 09:01:31.484  - debug: mihome-vacuum.0 (7940) system.adapter.admin.0: logging false
      2020-08-25 09:01:31.573  - debug: mihome-vacuum.0 (7940) stateChange mihome-vacuum.0.control.clean_home {"val":true,"ack":false,"ts":1598338891571,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598338891571}
      2020-08-25 09:01:31.573  - debug: mihome-vacuum.0 (7940) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      2020-08-25 09:01:31.574  - info: mihome-vacuum.0 (7940) trigger cleaning all
      2020-08-25 09:01:31.575  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":18,"method":"app_start"}
      2020-08-25 09:01:31.580  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":0,"id":18}
      2020-08-25 09:01:31.930  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":28,"method":"get_status"}
      2020-08-25 09:01:33.129  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[{"msg_ver":8,"msg_seq":979,"state":8,"battery":100,"clean_time":2945,"clean_area":41970000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":28}
      2020-08-25 09:01:33.130  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":29,"method":"get_consumable"}
      2020-08-25 09:01:33.135  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[{"main_brush_work_time":105388,"side_brush_work_time":105388,"filter_work_time":105388,"sensor_dirty_time":105388}],"id":29}
      2020-08-25 09:01:33.574  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":19,"method":"get_status"}
      2020-08-25 09:01:33.581  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":920,"state":5,"battery":100,"clean_time":209,"clean_area":5615000,"error_code":0,"map_present":0,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":19}
      2020-08-25 09:01:33.582  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":20,"method":"get_sound_volume"}
      2020-08-25 09:01:33.587  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[61],"id":20}
      2020-08-25 09:01:33.632  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":30,"method":"get_clean_summary"}
      2020-08-25 09:01:33.639  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[1409063,22058512500,630,[1920696483,1920672653,1598252409,1598247899,1598186699,1598180399,1598168709,1598088609,1597996539,1597927657,1597829053,1597647977,1597586410,1597475136,1597436999,1597411809,1597326301,1597301249,1597212506,1597132810]],"id":30}
      2020-08-25 09:01:35.430  - debug: mihome-vacuum.1 (7951) system.adapter.admin.0: logging true
      2020-08-25 09:01:35.430  - debug: mihome-vacuum.0 (7940) system.adapter.admin.0: logging true
      2020-08-25 09:01:45.212  - debug: mihome-vacuum.0 (7940) stateChange mihome-vacuum.0.control.clean_home {"val":false,"ack":false,"ts":1598338905212,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598338905212}
      2020-08-25 09:01:45.213  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":21,"method":"app_charge"}
      2020-08-25 09:01:45.219  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":0,"id":21}
      2020-08-25 09:01:47.214  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":22,"method":"get_status"}
      2020-08-25 09:01:47.221  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":921,"state":5,"battery":100,"clean_time":209,"clean_area":5615000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":22}
      2020-08-25 09:01:47.221  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":23,"method":"get_sound_volume"}
      2020-08-25 09:01:47.227  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[61],"id":23}
      2020-08-25 09:01:51.931  - debug: mihome-vacuum.1 (7951) sendMsg[1] >>> {"id":31,"method":"get_status"}
      2020-08-25 09:01:51.938  - debug: mihome-vacuum.1 (7951) Receive <<< {"result":[{"msg_ver":8,"msg_seq":980,"state":8,"battery":100,"clean_time":2945,"clean_area":41970000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":31}
      2020-08-25 09:02:07.216  - debug: mihome-vacuum.0 (7940) sendMsg[1] >>> {"id":24,"method":"get_status"}
      2020-08-25 09:02:07.228  - debug: mihome-vacuum.0 (7940) Receive <<< {"result":[{"msg_ver":6,"msg_seq":922,"state":5,"battery":100,"clean_time":33,"clean_area":615000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":100,"dnd_enabled":0}],"id":24}
        blackeagle998 last edited by
        @dirkhe
        Gibt die API irgendeine Möglichkeit her die aktuelle Position des Roboters als Koordinaten auszugeben?
        Ich muss meine Ladestation versetzen und möchte neben Räumen auch Zonen nutzen.
        Nur sehe ich momentan keine Möglichkeit die neuen Koordinaten dafür zu ermitteln.
          moviehunter @BamBam89 last edited by moviehunter
          @haselchen @Meistertr @dirkhe
          ich habe das gleiche Problem allerdings mit Version 2.2.3
          Token sind bei mir beide identisch
          Hier ein Auszug meines logs...
          mihome-vacuum.0	2020-08-25 21:13:38.365	debug	(6318) sendMsg[1] >>> {"id":2,"method":"get_status"}
          mihome-vacuum.0	2020-08-25 21:13:38.360	debug	(6318) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2020-08-25 21:13:38.359	info	(6318) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2020-08-25 21:13:38.357	debug	(6318) Receive <<< Helo <<< 213100200000000013d62eac5f4562e2ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2020-08-25 21:13:33.412	debug	(6318) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2020-08-25 21:13:33.411	debug	(6318) no answer for id:1 received, giving up
          mihome-vacuum.0	2020-08-25 21:13:28.410	debug	(6318) sendMsg[3] >>> {"id":1,"method":"get_status"}
          mihome-vacuum.0	2020-08-25 21:13:23.408	debug	(6318) sendMsg[2] >>> {"id":1,"method":"get_status"}
          mihome-vacuum.0	2020-08-25 21:13:18.836	info	(6318) set nächster Timer: Nicht verfügbar
          mihome-vacuum.0	2020-08-25 21:13:18.407	debug	(6318) sendMsg[1] >>> {"id":1,"method":"get_status"}
          mihome-vacuum.0	2020-08-25 21:13:18.396	debug	(6318) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2020-08-25 21:13:18.395	info	(6318) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2020-08-25 21:13:18.393	debug	(6318) Receive <<< Helo <<< 213100200000000013d62eac5f4562ceffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2020-08-25 21:13:18.377	debug	(6318) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          mihome-vacuum.0	2020-08-25 21:13:18.341	debug	(6318) server started on 0.0.0.0:53421
          mihome-vacuum.0	2020-08-25 21:13:18.316	info	(6318) Cloud control disabled
          mihome-vacuum.0	2020-08-25 21:13:18.314	info	(6318) Expert mode disabled, states deleted
          mihome-vacuum.0	2020-08-25 21:13:18.258	info	(6318) starting. Version 2.2.3 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.21.0, js-controller: 3.1.6
          kannst du mir auch weiter helfen? Bekomme keine Verbindung zum Sauger...
          M 1 Reply Last reply Reply Quote -1
            dirkhe Developer @blackeagle998 last edited by
            @blackeagle998 über die API nicht. Ich hatte mal angefangen, die Map auszulesen und die Koordinaten entsprechend umzurechnen, ist aber mangels Zeit eingeschlafen.
              dirkhe Developer @SchuetzeSchulz last edited by
              @SchuetzeSchulz er gibt das an den Robbie weiter, nämlich den Befehl app_charge. Aber anscheinend mag er den Befehl bei dir nicht. Müssten wir mal schauen, was deiner mag, dann könnte man das ggf. Mal alternativ einbauen. Ich war mal angefangen, die Kommunikation zu abstrahieren, aber mittlerweile hat sich der Code schon wieder soweit verändern, dass ich praktisch von vorne anfangen kann. Ist eher was für den Winter.
                Aber es hat ja mal funktioniert.
                Oder wurde durch irgend ein Update des Adapters mal was geändert in der Hinsicht?
                  moviehunter @moviehunter last edited by
                  @moviehunter said in Test Adapter mihome-vacuum v2.0.x:
                  Welche Informationen benötigt ihr, um mir helfen zu können?
                    @SchuetzeSchulz kann ich so direkt nicht sagen. Ich glaube in einer früheren Version würde mal erst Pause und dann charge gesendet. Vlt kannst das ja Bei dir mal ausprobieren?
                      dirkhe Developer @moviehunter last edited by
                      @moviehunter ggf.mal die mihome App öffnen und einen Moment warten, dazu muss der natürlich Internet haben und mit der App connected sein. Wenn das alles nicht hilft,anstimmt irgendwas mit deinem Token nicht, würde ich vermuten
                        Hallo Dirk,
                        habe das eben ausprobiert.
                        Mit clean_home gestartet, kurz gewartet und dann erst "pause" und dann "home" gedrückt.
                        Das funktioniert.
                        Kann man das irgendwie im "clean_home" false auch so machen? Gern auch als Haken in den Einstellungen?
                          blackeagle998 @dirkhe last edited by
                          @dirkhe
                          Danke für die Info, auch wenn ich mir etwas anderes erhofft hatte 🙁
                            @SchuetzeSchulz das mit der Einstellung ist eine gute Idee. Ich schaue mal, das ich das einbaue
                              Das wäre klasse...
                                moviehunter @dirkhe last edited by
                                @dirkhe
                                danke für die Rückmeldung.
                                Das mit dem App öffnen klappt leider nicht. Nutze die App regelmäßig um den Sauber zu starten, teilweise von zu Hause, teilweise von unterwegs. Somit kann ich auf jeden Fall gewährleisten, dass der Sauger Internet hat.
                                Den Token habe ich nun 3mal neu eingegeben, ohne Besserung.
                                Bekomme bei "Verbunden mit mihome-vacuum" einfach keine Verbindung.
                                Hatte vorher die stable Version 2.0.7 installiert.
                                Dort hatte ich bei "Verbunden mit mihome-vacuum" ein true...trotzdem hat sich der Sauger nicht gerührt.
                                Nun bei der aktuell installierten 2.2.3 habe ich bei "Verbunden mit mihome-vacuum" ein false und natürlich tut sich beim Sauger auch nichts... Hast du weitere Lösungsvorschläge?
                                Viele Grüße
                                coyote D 2 Replies Last reply Reply Quote 0
                                • coyote
                                  coyote Most Active @moviehunter last edited by
                                  @dirkhe @Meistertr ist es möglich von ValetudoRE verschiedene Karten über den Adapter zu laden?
                                    @moviehunter Nein, dann habe ich auch keine Idee mehr. Aber wir reden von der mihome App und nicht der roborock App? Warum gibst du den Token ein und holst ihn dir nicht per adapter?
                                      moviehunter @dirkhe last edited by moviehunter
                                      @dirkhe Ja klar...im iobroker habe ich den Adapter mihome-vacuum Version 2.2.3
                                      Also Android App nutze ich die Xiaomi Home App Version 5.8.7
                                      Den Token beziehe ich ja durch das Eingeben meiner Zugangsdaten aus der Android App.
                                      Dann muss ich den Token ja unten nochmal manuell eingeben oder sehe ich das falsch? Jedenfalls wenn ich das nicht tue, bekomme ich immer eine Fehlermeldung beim speichern.
                                      Was genau bedeuten denn die drei Zeilen, wenn man über den bei mir gelben Button geht bei Instanzen?
                                      Verbunden mit Host: wahr
                                      Lebenszeichen: wahr
                                      Verbunden mit mihome-vacuum: falsch
                                      Habe jetzt nochmal die stable 2.0.7 installiert. Dort ist die Lampe wieder grün aber trotzdem keine Reaktion vom Sauber...
                                      Hier mal ein Auszug ausm Log:
                                      mihome-vacuum.0	2020-09-01 20:50:41.069	debug	(1229) no answer for get_sound_volume(id:62) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:40.869	debug	(1229) no answer for get_clean_summary(id:61) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:40.669	debug	(1229) no answer for get_consumable(id:60) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:39.126	debug	(1229) no answer for get_sound_volume(id:58) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:38.930	debug	(1229) no answer for get_clean_summary(id:57) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:38.724	debug	(1229) no answer for get_consumable(id:56) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:38.525	debug	(1229) no answer for get_status(id:54) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:26.619	debug	(1229) no answer for get_status(id:53) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:25.461	debug	(1229) requesting params every: 60 Sec
                                      mihome-vacuum.0	2020-09-01 20:50:23.517	debug	(1229) requesting params every: 60 Sec
                                      mihome-vacuum.0	2020-09-01 20:50:23.514	info	(1229) Connected
                                      mihome-vacuum.0	2020-09-01 20:50:23.402	info	(1229) Disconnect
                                      mihome-vacuum.0	2020-09-01 20:50:21.401	info	(1229) should trigger cleaning all null, but is currently active. Add to queue
                                      mihome-vacuum.0	2020-09-01 20:50:21.396	debug	(1229) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                      mihome-vacuum.0	2020-09-01 20:50:21.395	debug	(1229) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1598986221392,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598986056217}
                                      mihome-vacuum.0	2020-09-01 20:50:16.618	debug	(1229) no answer for get_status(id:52) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:07.258	debug	(1229) no answer for get_sound_volume(id:51) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:07.057	debug	(1229) no answer for get_clean_summary(id:50) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:06.857	debug	(1229) no answer for get_consumable(id:49) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:50:06.653	debug	(1229) no answer for get_status(id:47) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:56.590	debug	(1229) no answer for get_status(id:46) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:51.649	debug	(1229) requesting params every: 60 Sec
                                      mihome-vacuum.0	2020-09-01 20:49:51.646	info	(1229) Connected
                                      mihome-vacuum.0	2020-09-01 20:49:51.586	info	(1229) Disconnect
                                      mihome-vacuum.0	2020-09-01 20:49:46.589	debug	(1229) no answer for get_status(id:45) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:41.072	debug	(1229) no answer for get_sound_volume(id:44) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:40.870	debug	(1229) no answer for get_clean_summary(id:43) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:40.668	debug	(1229) no answer for get_consumable(id:42) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:37.255	debug	(1229) no answer for get_sound_volume(id:40) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:37.055	debug	(1229) no answer for get_clean_summary(id:39) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:36.853	debug	(1229) no answer for get_consumable(id:38) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:36.651	debug	(1229) no answer for get_status(id:36) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:26.583	debug	(1229) no answer for get_status(id:35) received, giving up
                                      mihome-vacuum.0	2020-09-01 20:49:25.461	debug	(1229) requesting params every: 60 Sec
                                      B M 2 Replies Last reply Reply Quote 0
                                        blacksheep587 @moviehunter last edited by blacksheep587
                                        Hallo Zusammen,
                                        ich habe heute versucht den mihome-vacuum adapter zum Laufen zu kriegen, er wird aber nur Gelb und ich bekomme keine Verbindung zum Robi. Token auslesen hat mit der Anleitung soweit geklappt. Anbei mal die Fehlermeldung aus dem Log:
                                        mihome-vacuum.0	2020-09-01 20:12:57.820	error	(19455) Cannot send ping: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:57.817	info	(19455) Disconnect
                                        mihome-vacuum.0	2020-09-01 20:12:50.835	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:50.829	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:45.831	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:45.825	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:40.828	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:40.827	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:38.338	info	(19455) set nächster Timer: Nicht verfügbar
                                        mihome-vacuum.0	2020-09-01 20:12:37.870	error	(19455) Cannot send ping: Error: getaddrinfo ENOTFOUND 192.168.178.32
                                        mihome-vacuum.0	2020-09-01 20:12:37.813	info	(19455) Disconnect
                                        mihome-vacuum.0	2020-09-01 20:12:37.776	info	(19455) Cloud control disabled
                                        mihome-vacuum.0	2020-09-01 20:12:37.771	info	(19455) Expert mode disabled, states deleted
                                        mihome-vacuum.0	2020-09-01 20:12:37.697	info	(19455) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.22.0, js-controller: 3.1.6
                                        mihome-vacuum.0	2020-09-01 20:12:37.412	warn	(19455) This object will not be created in future versions. Please report this to the developer.
                                        mihome-vacuum.0	2020-09-01 20:12:37.409	warn	(19455) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        mihome-vacuum.0	2020-09-01 20:12:31.622	info	(19440) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        mihome-vacuum.0	2020-09-01 20:12:31.620	info	(19440) terminating
                                        mihome-vacuum.0	2020-09-01 20:12:31.616	info	(19440) Got terminate signal TERMINATE_YOURSELF
                                        Habt ihr eine Idee?
                                        Danke schon mal.
                                        Thomas Braun D 2 Replies Last reply Reply Quote 0
                                          Thomas Braun Most Active @blacksheep587 last edited by
                                          @blacksheep587 Bitte Konsolentext in CodeTags setzen. Danke.
                                            Lebenszeichen: wahr
                                            Ist der Adapter für alle Xiaomi Roboter kompatibel?
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            467871
