    4. Test Adapter worx v1.2.X (Kress/Landxcape)
    • Meistertr
      Meistertr Developer @schmuh last edited by
      @schmuh sorry nun sollte es wieder gehen wichtig sind nun alle funktionen die die neue App bietet, es ist nun alles mit drin
        schmuh @Meistertr last edited by schmuh
        @Meistertr
        leider geht es noch nicht,
        host.srv-iob-001	2020-08-28 16:51:57.172	info	Restart adapter system.adapter.worx.0 because enabled
        host.srv-iob-001	2020-08-28 16:51:57.172	info	instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
        worx.0	2020-08-28 16:51:56.662	info	(28748) Terminated (NO_ERROR): Without reason
        worx.0	2020-08-28 16:51:56.662	info	(28748) terminating
        worx.0	2020-08-28 16:51:56.626	info	(28748) cleaned everything up...
        worx.0	2020-08-28 16:51:56.626	error	(28748) ReferenceError: status is not defined at Worx.setStates (/opt/iobroker/node_modules/iobroker.worx/main.js:375:9) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.worx/main.js
        worx.0	2020-08-28 16:51:56.626	error	(28748) unhandled promise rejection: status is not defined
        worx.0	2020-08-28 16:51:56.625	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        worx.0	2020-08-28 16:51:52.817	info	(28748) worx is selected
        worx.0	2020-08-28 16:51:52.807	info	(28748) starting. Version 1.2.2 in /opt/iobroker/node_modules/iobroker.worx, node: v12.18.3, js-controller: 3.1.6
        host.srv-iob-001	2020-08-28 16:51:52.079	info	instance system.adapter.worx.0 started with pid 28748
        Wenn ich sonst was testen kann, lass es mich gerne wissen.
        Hier noch ein Auszug aus dem Debug:
        worx.0	2020-08-28 16:56:08.421	info	(29000) cleaned everything up...
        worx.0	2020-08-28 16:56:08.421	error	(29000) ReferenceError: status is not defined at Worx.setStates (/opt/iobroker/node_modules/iobroker.worx/main.js:375:9) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.worx/main.js
        worx.0	2020-08-28 16:56:08.421	error	(29000) unhandled promise rejection: status is not defined
        worx.0	2020-08-28 16:56:08.421	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        worx.0	2020-08-28 16:56:08.416	debug	(29000) Test Status: 1
        Meistertr 1 Reply Last reply Reply Quote 0
        • Meistertr
          @schmuh jetzt sollte es gehen
          C S 2 Replies Last reply Reply Quote 0
            Cosmicbase @Meistertr last edited by
            @Meistertr laut dem changelog 1.2.2 soll der Partymode funktionieren. Ich finde leider weder ein Status noch einen Button.
            Soll der schon funktionieren, und wenn ja wie?
            Grüße Markus
              @Meistertr
              Super, funktioniert wieder, vielen Dank.
              Beste Grüße
              Werner
              • Meistertr
                Meistertr Developer @Cosmicbase last edited by
                @Cosmicbase es sollte unter mower ein object mit partymode sein. Das falls nicht bitte einmal ein debuglog
                • Meistertr
                  so die 1.2.3 sollte nun final sein. also bitte testen und Fehler melden. ich konnte keine mehr finden
                    @Meistertr Partymode in 1.2.3 nicht gefunden.
                    Habe den Adapter komplett deinstalliert und über Git neu installiert.
                    Log Datei:
                    2020-08-29 21:04:02.035 - info: host.raspberrypi stopInstance system.adapter.worx.0 (force=false, process=true)
                    2020-08-29 21:04:02.041 - info: host.raspberrypi stopInstance system.adapter.worx.0 send kill signal
                    2020-08-29 21:04:02.046 - info: worx.0 (3412) Got terminate signal TERMINATE_YOURSELF
                    2020-08-29 21:04:02.050 - info: worx.0 (3412) cleaned everything up...
                    2020-08-29 21:04:02.051 - info: worx.0 (3412) terminating
                    2020-08-29 21:04:02.053 - info: worx.0 (3412) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2020-08-29 21:04:02.585 - info: host.raspberrypi instance system.adapter.worx.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2020-08-29 21:04:05.129 - info: host.raspberrypi instance system.adapter.worx.0 started with pid 4163
                    2020-08-29 21:04:07.374 - info: worx.0 (4163) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.worx, node: v12.18.1, js-controller: 3.1.6
                    2020-08-29 21:04:07.416 - info: worx.0 (4163) worx is selected
                    • Meistertr
                      @Cosmicbase welches Modell hast du? Kannst du den Adapter mal auf debug stellen. Und den log oben runterladen und die Zeile mit get data from api. Posten
                        Cosmicbase @Meistertr last edited by Cosmicbase
                        @Meistertr sorry für das schlechte Timing. Partymode ist da👍.
                        War wohl mein Fehler. Hatte die 1.2.0 versehentlich wieder installiert.
                        Danke für die tolle Arbeit.
                        Gibt es für den Partymodus auch ein Status wie z.B. Home (1) oder Mowing (7)?
                          skokarl last edited by
                          Morgen,
                          läuft bei mir bisher, super vielen Dank.
                          [offtopic]
                          hat jemand zufällig nen animiertes gif vom Landroid ? Wäre als Animation toll
                          wenn man sehen könnte das sich was bewegt wenn der Mäher startet
                            Cosmicbase @skokarl last edited by Cosmicbase
                            @Meistertr ich hätte da noch was interessantes. 2 Statistiken lassen sich in der App Zurücksetzen aber werden vom Adapter nicht gezogen.
                            Siehe Screenshot.Screenshot_20200830_094627_it.positec.landroid.jpgScreenshot_20200830_095220_com.android.chrome.jpg
                            • Meistertr
                              @Cosmicbase ad läuft nur app intern, wenn interesse besteht muss man sich hier ein script für basteln
                                Semmy @Meistertr last edited by
                                @Meistertr Hallo. Ich habe einen Kress Mission 110 mit Firmware 3.08. Funktionieren die neuen Funktionen auch schon mit dieser Firmware oder braucht es hierfür erst ein update?
                                Viele Grüße
                                Semmy
                                • Meistertr
                                  Meistertr Developer @Semmy last edited by
                                  @Semmy da kann ich keine aussage drüber treffen, da ich keinen Kress habe und es auch nur wenige Kress nutzer gibt. würde sagen einfach ausprobieren
                                    @Meistertr Ok, die neuen Einträge sind bei mir noch nicht vorhanden, vielleicht kommt ja hier auch noch ein Firmware-update.
                                    • Meistertr
                                      Da keine negativen Rückmeldungen mehr kommen, kann ich geht Adapter dann ins stable
                                      J 1 Reply Last reply Reply Quote 2
                                        Jack01 @Meistertr last edited by
                                        @Meistertr Ist installiert und läuft wie immer problemlos (nur passiv als Anzeige mit Worx WR106SI)👍
                                        hsteinme 1 Reply Last reply Reply Quote 0
                                        • hsteinme
                                          hsteinme @Jack01 last edited by
                                          Ich habe den Double Scheduler unter der FW 3.16 und mit der Adapter Version 1.2.3 getestet. Alle Mähzeiten, sowohl die ersten als auch die zweiten, werden in den Datenpunkten korrekt abgestellt. Erste Mähzeiten kann ich - wie seit eh und je - auch ändern. Nur bei den zweiten Mähzeiten gelingen mir keine Änderungen. Wenn ich etwas an einer zweiten Mähzeit ändere, wird nach dem Auslösen in Sekundenschnelle der vorherige Wert wieder angezeigt. Eine Übertragung der Änderung zum MQTT-Servr findet ebenfalls nicht statt.
                                          20200902_friday2.startTime.pdf
                                          Für mich stellt sich zunächst die Frage, ob hier ein tragisches Einzelschicksal vorliegt (da vielleicht an meiner Installation irgendwas "schief" ist) oder ob dies eine generelle Problematik darstellt. Daher meine herzliche Bitte: Könnt Ihr bitte diesen Testfall auf Eurer Installtion durchspielen, und hier mitteilen, ob Eure Update-Versuche mit zweiten Mähzeiten erfolgreich sind. Dieser Test kann manuell (also ohne Skripteinsatz) in den Datenpunkten im Objekte-Reiter durchgeführt werden.
                                          Heißen Dank im Voraus für Eure Unterstützung.
                                            Bastel2001 @hsteinme last edited by Bastel2001
                                            @Meistertr
                                            Guten Tag. Vorab erstmal besten Dank für den Adapter, er funktioniert tadellos. Wenn Du mal wieder was daran machst, hätte ich einen Wunsch, kannst Du bitte einen "Letzter Zugriff" einbauen, also die Zeit wann die aktuellen Datensätze aktualisiert wurden. Ich habe mir zwar was selber gebaut, aber das könnte ich dann wieder verwerfen und es wäre wesentlich einfacher. Besten Dank schonemal.
                                            cu Bastel
                                            kress landxcape worx
                                            2289
