    4. Test Adapter WhatsAPP-CMB
    • bahnuhr
      @Bluefox sagte in Test Adapter WhatsAPP-CMB:
      https://github.com/ioBroker/ioBroker.whatsapp-cmb
      Hat alles geklappt.
      Bei mir dauert es ca. 40 Sekunden bis die Nachricht ankommt.
      • dslraser
        dslraser Forum Testing Most Active @AlCalzone last edited by dslraser
        @AlCalzone sagte in Test Adapter WhatsAPP-CMB:
        oder kann man mit einem an mehrere Nummern senden?
        Sollte gehen, oder ? (noch nicht probiert)
        sendTo('whatsapp-cmb.0', 'send', {
            text: 'My message',
            phone: '+491234567890' // optional, if empty the message will be sent default configured number
        EDIT:
          crunchip Forum Testing Most Active last edited by crunchip
          ich bekomm das ohne Fehler irgendwie nicht gebacken, Nachricht kam zwar an, aber im log erscheint
          javascript.0	2020-08-28 17:22:53.931	error	(1053) at processTicksAndRejections (internal/process/task_queues.js:97:5)
          javascript.0	2020-08-28 17:22:53.931	error	(1053) at runMicrotasks (<anonymous>)
          javascript.0	2020-08-28 17:22:53.931	error	(1053) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
          javascript.0	2020-08-28 17:22:53.930	error	(1053) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
          javascript.0	2020-08-28 17:22:53.930	error	(1053) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
          javascript.0	2020-08-28 17:22:53.930	error	(1053) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1139:17
          javascript.0	2020-08-28 17:22:53.929	error	(1053) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1555:17
          javascript.0	2020-08-28 17:22:53.929	error	(1053) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1502:37)
          javascript.0	2020-08-28 17:22:53.929	error	(1053) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1279:28)
          javascript.0	2020-08-28 17:22:53.929	error	(1053) at Object.createScript (vm.js:261:10)
          javascript.0	2020-08-28 17:22:53.928	error	(1053) at new Script (vm.js:88:7)
          javascript.0	2020-08-28 17:22:53.928	error	(1053) SyntaxError: Unexpected identifier
          javascript.0	2020-08-28 17:22:53.928	error	(1053) ^^^^^
          javascript.0	2020-08-28 17:22:53.928	error	(1053) phone: '+49xxxxxxxxxx'
          javascript.0	2020-08-28 17:22:53.927	error	(1053) script.js.whatsapp compile failed: at script.js.whatsapp:7
          EDIT: umgestellt von "Alle Instanzen" auf "whatsapp-cmb.0", jetzt funktioniert es fehlerfrei und kommt nach ca 20 sek.
          • Stephan Schleich
            Stephan Schleich @Bluefox last edited by
            @Bluefox Ist der Api Key dann fest auf die Rufnummer getrimmt die ihn anforderte? Nicht das wenn ich mal Umzieh über meine Rufnummer keinen weiteren mehr anfordern kann
            • dslraser
              Ich habe gerade mal versucht, an das Handy meiner Frau eine Nachricht zu senden. Das geht "noch" nicht, oder ?
              Jedenfalls kommt da nix an.
              (also gesendet über meine Nummer/API)
              crunchip Bluefox 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @dslraser last edited by
                @dslraser wie hast du das gemacht, wenn ich nen Empfänger mit angebe, egel ob meine oder eine andere kommt auch der oben genannte Fehler
                • dslraser
                  dslraser Forum Testing Most Active @crunchip last edited by
                  @crunchip
                  bei Blockly kam bei mir auch Dein beschriebener Fehler. Bei JS kam kein Fehler.
                  Ich habe sogar zwei Nummern in das JS eingetragen, stehen dann auch beide im LOG, kommt aber nichts an. Geht nur mit meiner Nummer.
                      text: 'My message',
                    @dslraser ok, also liegt's am blockly, hatte nämlich erst ein blockly erstellt, da der Fehler kam, hatte ich das blockly auf JS umgewandelt, aber der Fehler blieb.
                      guergen @Bluefox last edited by guergen
                      @Bluefox Kein Problem, läuft auf Anhieb! (Ohne einen Empfänger einzugeben....)
                      • Bluefox
                        Bluefox @dslraser last edited by
                        @dslraser Also dieses Service ist nicht von mir.
                        Falls auf dieser Seite https://www.callmebot.com/blog/free-api-whatsapp-messages/ keine Antworten stehen, dann kenne ich auch keine.
                        • Negalein
                          bei mir kommt trotz default Number in den Einstellungen immer ein Fehler im Log und Nachricht kommt nicht an.
                          whatsapp-cmb.0	2020-08-30 16:38:01.379	error	(24852) Please set the default phone number.
                          Hab bereits meine Handynummer auf 2 Arten versucht.
                          Wie habt ihr sie eingegeben?
                          Ralla66 bahnuhr 2 Replies Last reply Reply Quote 0
                          • Ralla66
                            Ralla66 Most Active @Negalein last edited by Ralla66
                            @Negalein
                            ohne 0 beim Händy
                            also nicht 0171 sondern 171
                            In DE +49
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @Negalein last edited by
                              @Negalein sagte in Test Adapter WhatsAPP-CMB:
                              Fängt deine Handynummer wirklich mit 43 an ?
                                Homoran Global Moderator Administrators @bahnuhr last edited by Homoran
                                @bahnuhr sagte in Test Adapter WhatsAPP-CMB:
                                Ja! das ist ein Ösi 😉
                                • Negalein
                                  Negalein Global Moderator @Ralla66 last edited by
                                  @Ralla66 sagte in Test Adapter WhatsAPP-CMB:
                                  ohne 0 beim Händy
                                  ja, hab +43 680 bzw. +43680 probiert
                                  @Homoran sagte in Test Adapter WhatsAPP-CMB:
                                  Ja! das ist ein Ösi
                                  Lieber ein Ösi als ein Preusse 😉😝😝😝
                                    Homoran Global Moderator Administrators @Negalein last edited by
                                    kommt immer auf den Blickwinkel an 🤣
                                    • Negalein
                                      hab mal auf Debug gestellt.
                                      Seh da aber auch nicht mehr.
                                      whatsapp-cmb.0	2020-08-30 16:56:30.174	debug	(6301) system.adapter.admin.0: logging true
                                      whatsapp-cmb.0	2020-08-30 16:56:26.597	error	(6301) Please set the default phone number.
                                      whatsapp-cmb.0	2020-08-30 16:56:15.895	info	(6301) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
                                      whatsapp-cmb.0	2020-08-30 16:56:14.462	debug	(6301) statesDB connected
                                      whatsapp-cmb.0	2020-08-30 16:56:14.461	debug	(6301) States connected to redis: 0.0.0.0:9000
                                      whatsapp-cmb.0	2020-08-30 16:56:14.436	debug	(6301) States create System PubSub Client
                                      whatsapp-cmb.0	2020-08-30 16:56:14.434	debug	(6301) States create User PubSub Client
                                      whatsapp-cmb.0	2020-08-30 16:56:14.420	debug	(6301) Redis States: Use Redis connection: 0.0.0.0:9000
                                      whatsapp-cmb.0	2020-08-30 16:56:14.417	debug	(6301) objectDB connected
                                      whatsapp-cmb.0	2020-08-30 16:56:14.411	debug	(6301) Objects connected to redis: 0.0.0.0:9001
                                      whatsapp-cmb.0	2020-08-30 16:56:14.385	debug	(6301) Objects client initialize lua scripts
                                      whatsapp-cmb.0	2020-08-30 16:56:14.384	debug	(6301) Objects create User PubSub Client
                                      whatsapp-cmb.0	2020-08-30 16:56:14.383	debug	(6301) Objects create System PubSub Client
                                      whatsapp-cmb.0	2020-08-30 16:56:14.378	debug	(6301) Objects client ready ... initialize now
                                      whatsapp-cmb.0	2020-08-30 16:56:14.341	debug	(6301) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                      whatsapp-cmb.0	2020-08-30 16:56:10.749	info	(5905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      whatsapp-cmb.0	2020-08-30 16:56:10.748	info	(5905) terminating
                                      whatsapp-cmb.0	2020-08-30 16:56:10.246	info	(5905) Got terminate signal TERMINATE_YOURSELF
                                      whatsapp-cmb.0	2020-08-30 16:55:56.315	error	(5905) Please set the default phone number.
                                      whatsapp-cmb.0	2020-08-30 16:55:44.830	info	(5905) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
                                      whatsapp-cmb.0	2020-08-30 16:55:39.606	info	(24852) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      whatsapp-cmb.0	2020-08-30 16:55:39.605	info	(24852) terminating
                                      whatsapp-cmb.0	2020-08-30 16:55:39.103	info	(24852) Got terminate signal TERMINATE_YOURSELF
                                      • Negalein
                                        direkt über den Link funktioniert es.
                                        https://api.callmebot.com/whatsapp.php?phone=+43680xxxxxxx&text=This+is+a+test&apikey=xxxxxx
                                        Ralla66 Negalein 2 Replies Last reply Reply Quote 0
                                        • Ralla66
                                          @Negalein
                                          merkwürdig, habe die Version 0.1.0.
                                          Zwischen den Starts kein Stop im Log bei dir.
                                          Haste mal dein System neu gestartet ?
                                          • Negalein
                                            Ja, auch schon gemacht. Brachte nichts.
                                            Ralla66 1 Reply Last reply Reply Quote 0
                                            adapter tester
                                            47
                                            172
                                            38455
