    4. Zigbee Pairing Problem
    UNSOLVED Zigbee Pairing Problem
    • efxz
      efxz last edited by efxz
      Ich möchte ein neues Gerät pairen und bekomme folgenden output:
      Error: DeviceConfigure failed 0x04cf8cdf3c771fac lumi.sen_ill.mgl01, attempt 2 (Error: Bind 0x04cf8cdf3c771fac/1 genPowerCfg from '0x00124b001940c071/1' failed (AREQ - ZDO - bindRsp after 10000ms)
          at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
          at listOnTimeout (internal/timers.js:549:17)
          at processTimers (internal/timers.js:492:7)). undefined
      Error: DeviceConfigure failed 0x04cf8cdf3c771fac lumi.sen_ill.mgl01, attempt 1 (Error: Bind 0x04cf8cdf3c771fac/1 genPowerCfg from '0x00124b001940c071/1' failed (AREQ - ZDO - bindRsp after 10000ms)
      zigbee.0	2020-08-30 11:28:58.325	error	(20771) DeviceConfigure failed 0x04cf8cdf3c771fac lumi.sen_ill.mgl01, attempt 4 (Error: Bind 0x04cf8cdf3c771fac/1 genPowerCfg from '0x00124b001940c071/1' failed (AREQ - ZDO - bindRsp after 10000ms)
      Der Helligkeitssensor läuft ohne probs
      ```model:GZCGQ01LM
      description:MiJia light intensity sensor
      supports:illuminance
      model:lumi.sen_ill.mgl01
      type:EndDevice
      nwk:61257
      manuf id:4718
      manufacturer:LUMI
      power:Battery
      app version:21
      hard version:1
      zcl version:3
      stack version:2
      date code:20191118
      build:2019www.
      interviewed:true
      configured:true
      endpoint:1
      profile:260
      input clusters:genBasic (0)
      msIlluminanceMeasurement (1024)
      genIdentify (3)
      genPowerCfg (1)
      output clusters:genIdentify (3)
      Thomas Braun arteck Asgothian 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @efxz last edited by
        @efxz
        Die Screenshots sind so schlecht lesbar. Textausgaben aus den Logfiles als Text in CodeTags </> posten.
          arteck Developer Most Active @efxz last edited by
          @efxz
          adapeterversion ? bzw. wann aufgespielt ??
          efxz 1 Reply Last reply Reply Quote 0
          • efxz
            efxz @arteck last edited by
            @arteck
            version 1.21 am 31.08. von git
            meine anderen 3 Instanzen laufen ohne probs
              @efxz was denn für andere 3 instanzen ? und was ist 1.21 .. kenn ich nicht
              • Asgothian
                Asgothian Developer @efxz last edited by
                @efxz
                Der Fehler weist darauf hin das der Sensor auf die Anfrage sich zu konfigurieren keine Antwort sendet, bzw. das der Zigbee Stick diese Antwort nicht bekommt.
                Woran das liegt ist schwer zu sagen. Auch bedeutet es nicht unbedingt das das Gerät nicht funktioniert.
                Mögliche Ursachen sind:
                • Funkempfang des Gerätes ist schlecht
                • Sendeleistung des Gerätes reicht nicht um die Antwort zum Koordinator zu bringen
                • Das Gerät hat einen defekt und braucht zu lange um eine Konfigurationsantwort zu senden / sendet gar keine
                Die Software ist da sicher nicht fehlerhaft, ansonsten wäre das Log voll mit Meldungen.
                A.
                • efxz
                  @arteck
                  ich habe noch drei slaves mit zigbee instanzen am laufen
                  hier die version 1.2.1
                  • Asgothian
                    @efxz
                    • Frage: Nutzen die 4 Instanzen unterschiedliche Frequenzen für die Zigbee Netze oder die gleiche Frequenz ?
                    • Frage: Gibt es zwischen den Netzen einen Bereich in dem sie Überlappen ?
                    A.
                    efxz 1 Reply Last reply Reply Quote 1
                    • efxz
                      efxz @Asgothian last edited by
                      @Asgothian
                      zwei Instanzen könnten sich überlappen.. jeweils Erdgeschoss und Dachgeschoss , aber mit unterschiedlichen Kanälen 11 und 15
                      habe nun einen neuen stick angehangen, aber immer noch die gleichen probs. seltsam ist auch, das der pairingmodus zwischendrin willkürlich stoppt
                      • efxz
                        efxz @efxz last edited by
                        @efxz
                        habe die Instanz neu angelegt.
                        bin wie hier beschrieben vorgegangen:
                        Link Text
                        zigbee pairing problem
                        801
