    4. Test Adapter WhatsAPP-CMB
      crunchip Forum Testing Most Active last edited by crunchip
      ich bekomm das ohne Fehler irgendwie nicht gebacken, Nachricht kam zwar an, aber im log erscheint
      javascript.0	2020-08-28 17:22:53.931	error	(1053) at processTicksAndRejections (internal/process/task_queues.js:97:5)
      javascript.0	2020-08-28 17:22:53.931	error	(1053) at runMicrotasks (<anonymous>)
      javascript.0	2020-08-28 17:22:53.931	error	(1053) at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
      javascript.0	2020-08-28 17:22:53.930	error	(1053) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      javascript.0	2020-08-28 17:22:53.930	error	(1053) at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17
      javascript.0	2020-08-28 17:22:53.930	error	(1053) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1139:17
      javascript.0	2020-08-28 17:22:53.929	error	(1053) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1555:17
      javascript.0	2020-08-28 17:22:53.929	error	(1053) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1502:37)
      javascript.0	2020-08-28 17:22:53.929	error	(1053) at compile (/opt/iobroker/node_modules/iobroker.javascript/main.js:1279:28)
      javascript.0	2020-08-28 17:22:53.929	error	(1053) at Object.createScript (vm.js:261:10)
      javascript.0	2020-08-28 17:22:53.928	error	(1053) at new Script (vm.js:88:7)
      javascript.0	2020-08-28 17:22:53.928	error	(1053) SyntaxError: Unexpected identifier
      javascript.0	2020-08-28 17:22:53.928	error	(1053) ^^^^^
      javascript.0	2020-08-28 17:22:53.928	error	(1053) phone: '+49xxxxxxxxxx'
      javascript.0	2020-08-28 17:22:53.927	error	(1053) script.js.whatsapp compile failed: at script.js.whatsapp:7
      EDIT: umgestellt von "Alle Instanzen" auf "whatsapp-cmb.0", jetzt funktioniert es fehlerfrei und kommt nach ca 20 sek.
      • Stephan Schleich
        Stephan Schleich @Bluefox last edited by
        @Bluefox Ist der Api Key dann fest auf die Rufnummer getrimmt die ihn anforderte? Nicht das wenn ich mal Umzieh über meine Rufnummer keinen weiteren mehr anfordern kann
        • dslraser
          Ich habe gerade mal versucht, an das Handy meiner Frau eine Nachricht zu senden. Das geht "noch" nicht, oder ?
          Jedenfalls kommt da nix an.
          (also gesendet über meine Nummer/API)
          crunchip Bluefox 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @dslraser last edited by
            @dslraser wie hast du das gemacht, wenn ich nen Empfänger mit angebe, egel ob meine oder eine andere kommt auch der oben genannte Fehler
            • dslraser
              dslraser Forum Testing Most Active @crunchip last edited by
              @crunchip
              bei Blockly kam bei mir auch Dein beschriebener Fehler. Bei JS kam kein Fehler.
              Ich habe sogar zwei Nummern in das JS eingetragen, stehen dann auch beide im LOG, kommt aber nichts an. Geht nur mit meiner Nummer.
              sendTo('whatsapp-cmb.0', 'send', {
                  text: 'My message',
                  phone: '+491234567890' // optional, if empty the message will be sent default configured number
                @dslraser ok, also liegt's am blockly, hatte nämlich erst ein blockly erstellt, da der Fehler kam, hatte ich das blockly auf JS umgewandelt, aber der Fehler blieb.
                  guergen @Bluefox last edited by guergen
                  @Bluefox Kein Problem, läuft auf Anhieb! (Ohne einen Empfänger einzugeben....)
                  • Bluefox
                    Bluefox @dslraser last edited by
                    @dslraser Also dieses Service ist nicht von mir.
                    Falls auf dieser Seite https://www.callmebot.com/blog/free-api-whatsapp-messages/ keine Antworten stehen, dann kenne ich auch keine.
                    • Negalein
                      bei mir kommt trotz default Number in den Einstellungen immer ein Fehler im Log und Nachricht kommt nicht an.
                      whatsapp-cmb.0	2020-08-30 16:38:01.379	error	(24852) Please set the default phone number.
                      Hab bereits meine Handynummer auf 2 Arten versucht.
                      Wie habt ihr sie eingegeben?
                      Ralla66 bahnuhr 2 Replies Last reply Reply Quote 0
                      • Ralla66
                        Ralla66 Most Active @Negalein last edited by Ralla66
                        @Negalein
                        ohne 0 beim Händy
                        also nicht 0171 sondern 171
                        In DE +49
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @Negalein last edited by
                          @Negalein sagte in Test Adapter WhatsAPP-CMB:
                          Fängt deine Handynummer wirklich mit 43 an ?
                            Homoran Global Moderator Administrators @bahnuhr last edited by Homoran
                            @bahnuhr sagte in Test Adapter WhatsAPP-CMB:
                            Ja! das ist ein Ösi 😉
                            • Negalein
                              Negalein Global Moderator @Ralla66 last edited by
                              @Ralla66 sagte in Test Adapter WhatsAPP-CMB:
                              ohne 0 beim Händy
                              ja, hab +43 680 bzw. +43680 probiert
                              @Homoran sagte in Test Adapter WhatsAPP-CMB:
                              Ja! das ist ein Ösi
                              Lieber ein Ösi als ein Preusse 😉😝😝😝
                                Homoran Global Moderator Administrators @Negalein last edited by
                                kommt immer auf den Blickwinkel an 🤣
                                • Negalein
                                  hab mal auf Debug gestellt.
                                  Seh da aber auch nicht mehr.
                                  whatsapp-cmb.0	2020-08-30 16:56:30.174	debug	(6301) system.adapter.admin.0: logging true
                                  whatsapp-cmb.0	2020-08-30 16:56:26.597	error	(6301) Please set the default phone number.
                                  whatsapp-cmb.0	2020-08-30 16:56:15.895	info	(6301) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
                                  whatsapp-cmb.0	2020-08-30 16:56:14.462	debug	(6301) statesDB connected
                                  whatsapp-cmb.0	2020-08-30 16:56:14.461	debug	(6301) States connected to redis: 0.0.0.0:9000
                                  whatsapp-cmb.0	2020-08-30 16:56:14.436	debug	(6301) States create System PubSub Client
                                  whatsapp-cmb.0	2020-08-30 16:56:14.434	debug	(6301) States create User PubSub Client
                                  whatsapp-cmb.0	2020-08-30 16:56:14.420	debug	(6301) Redis States: Use Redis connection: 0.0.0.0:9000
                                  whatsapp-cmb.0	2020-08-30 16:56:14.417	debug	(6301) objectDB connected
                                  whatsapp-cmb.0	2020-08-30 16:56:14.411	debug	(6301) Objects connected to redis: 0.0.0.0:9001
                                  whatsapp-cmb.0	2020-08-30 16:56:14.385	debug	(6301) Objects client initialize lua scripts
                                  whatsapp-cmb.0	2020-08-30 16:56:14.384	debug	(6301) Objects create User PubSub Client
                                  whatsapp-cmb.0	2020-08-30 16:56:14.383	debug	(6301) Objects create System PubSub Client
                                  whatsapp-cmb.0	2020-08-30 16:56:14.378	debug	(6301) Objects client ready ... initialize now
                                  whatsapp-cmb.0	2020-08-30 16:56:14.341	debug	(6301) Redis Objects: Use Redis connection: 0.0.0.0:9001
                                  whatsapp-cmb.0	2020-08-30 16:56:10.749	info	(5905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  whatsapp-cmb.0	2020-08-30 16:56:10.748	info	(5905) terminating
                                  whatsapp-cmb.0	2020-08-30 16:56:10.246	info	(5905) Got terminate signal TERMINATE_YOURSELF
                                  whatsapp-cmb.0	2020-08-30 16:55:56.315	error	(5905) Please set the default phone number.
                                  whatsapp-cmb.0	2020-08-30 16:55:44.830	info	(5905) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
                                  whatsapp-cmb.0	2020-08-30 16:55:39.606	info	(24852) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  whatsapp-cmb.0	2020-08-30 16:55:39.605	info	(24852) terminating
                                  whatsapp-cmb.0	2020-08-30 16:55:39.103	info	(24852) Got terminate signal TERMINATE_YOURSELF
                                  • Negalein
                                    direkt über den Link funktioniert es.
                                    https://api.callmebot.com/whatsapp.php?phone=+43680xxxxxxx&text=This+is+a+test&apikey=xxxxxx
                                    Ralla66 Negalein 2 Replies Last reply Reply Quote 0
                                    • Ralla66
                                      @Negalein
                                      merkwürdig, habe die Version 0.1.0.
                                      Zwischen den Starts kein Stop im Log bei dir.
                                      Haste mal dein System neu gestartet ?
                                      • Negalein
                                        Ja, auch schon gemacht. Brachte nichts.
                                        Ralla66 1 Reply Last reply Reply Quote 0
                                        • Ralla66
                                          @Negalein
                                          Adapter Terminated siehste im Log ?
                                            Homoran Global Moderator Administrators @Ralla66 last edited by
                                            @Ralla66 aber 156 sollte OK sein, wenn ich mich nicht irre.
                                            Da wird er an der Konfig gespielt haben, was den Adapter restartet
                                            adapter tester
                                            47
                                            172
                                            38455
