    4. Test Adapter WhatsAPP-CMB
      Homoran Global Moderator Administrators @Negalein last edited by
      @Negalein sagte in Test Adapter WhatsAPP-CMB:
      Lieber ein Ösi als ein Preusse
      kommt immer auf den Blickwinkel an 🤣
      • Negalein
        hab mal auf Debug gestellt.
        Seh da aber auch nicht mehr.
        whatsapp-cmb.0	2020-08-30 16:56:30.174	debug	(6301) system.adapter.admin.0: logging true
        whatsapp-cmb.0	2020-08-30 16:56:26.597	error	(6301) Please set the default phone number.
        whatsapp-cmb.0	2020-08-30 16:56:15.895	info	(6301) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
        whatsapp-cmb.0	2020-08-30 16:56:14.462	debug	(6301) statesDB connected
        whatsapp-cmb.0	2020-08-30 16:56:14.461	debug	(6301) States connected to redis: 0.0.0.0:9000
        whatsapp-cmb.0	2020-08-30 16:56:14.436	debug	(6301) States create System PubSub Client
        whatsapp-cmb.0	2020-08-30 16:56:14.434	debug	(6301) States create User PubSub Client
        whatsapp-cmb.0	2020-08-30 16:56:14.420	debug	(6301) Redis States: Use Redis connection: 0.0.0.0:9000
        whatsapp-cmb.0	2020-08-30 16:56:14.417	debug	(6301) objectDB connected
        whatsapp-cmb.0	2020-08-30 16:56:14.411	debug	(6301) Objects connected to redis: 0.0.0.0:9001
        whatsapp-cmb.0	2020-08-30 16:56:14.385	debug	(6301) Objects client initialize lua scripts
        whatsapp-cmb.0	2020-08-30 16:56:14.384	debug	(6301) Objects create User PubSub Client
        whatsapp-cmb.0	2020-08-30 16:56:14.383	debug	(6301) Objects create System PubSub Client
        whatsapp-cmb.0	2020-08-30 16:56:14.378	debug	(6301) Objects client ready ... initialize now
        whatsapp-cmb.0	2020-08-30 16:56:14.341	debug	(6301) Redis Objects: Use Redis connection: 0.0.0.0:9001
        whatsapp-cmb.0	2020-08-30 16:56:10.749	info	(5905) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        whatsapp-cmb.0	2020-08-30 16:56:10.748	info	(5905) terminating
        whatsapp-cmb.0	2020-08-30 16:56:10.246	info	(5905) Got terminate signal TERMINATE_YOURSELF
        whatsapp-cmb.0	2020-08-30 16:55:56.315	error	(5905) Please set the default phone number.
        whatsapp-cmb.0	2020-08-30 16:55:44.830	info	(5905) starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.17.0, js-controller: 3.1.6
        whatsapp-cmb.0	2020-08-30 16:55:39.606	info	(24852) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        whatsapp-cmb.0	2020-08-30 16:55:39.605	info	(24852) terminating
        whatsapp-cmb.0	2020-08-30 16:55:39.103	info	(24852) Got terminate signal TERMINATE_YOURSELF
        • Negalein
          direkt über den Link funktioniert es.
          https://api.callmebot.com/whatsapp.php?phone=+43680xxxxxxx&text=This+is+a+test&apikey=xxxxxx
          Ralla66 Negalein 2 Replies Last reply Reply Quote 0
          • Ralla66
            Ralla66 Most Active @Negalein last edited by Ralla66
            @Negalein
            merkwürdig, habe die Version 0.1.0.
            Zwischen den Starts kein Stop im Log bei dir.
            Haste mal dein System neu gestartet ?
            • Negalein
              Negalein Global Moderator @Ralla66 last edited by
              @Ralla66 sagte in Test Adapter WhatsAPP-CMB:
              Ja, auch schon gemacht. Brachte nichts.
              Ralla66 1 Reply Last reply Reply Quote 0
              • Ralla66
                @Negalein
                Adapter Terminated siehste im Log ?
                  Homoran Global Moderator Administrators @Ralla66 last edited by
                  @Ralla66 aber 156 sollte OK sein, wenn ich mich nicht irre.
                  Da wird er an der Konfig gespielt haben, was den Adapter restartet
                  • Negalein
                    Negalein Global Moderator @Homoran last edited by
                    @Homoran sagte in Test Adapter WhatsAPP-CMB:
                    genau. da hab ich ihn auf debug gestellt.
                    Der Screenshot mit dem 156 ist von @Ralla66
                    Bei mir scheint es nicht auf.
                      A Former User @Negalein last edited by
                      @Negalein bei mir geht die 0.1.3 auch nicht.. hatte noch keine Zeit mehr zu testen...
                      • Negalein
                        Negalein Global Moderator @Guest last edited by
                        @ilovegym sagte in Test Adapter WhatsAPP-CMB:
                        Danke, gut zu wissen.
                        Dann warte ich mal bis @Bluefox es sieht.
                          crunchip Forum Testing Most Active @Negalein last edited by
                          @Negalein grad getestet, 0.1.3 funktioniert noch bei mir
                          sigi234 Negalein 2 Replies Last reply Reply Quote 1
                            sigi234 Forum Testing Most Active @crunchip last edited by
                            @crunchip sagte in Test Adapter WhatsAPP-CMB:
                            Dito
                            • Negalein
                              Negalein Global Moderator @crunchip last edited by
                              ich bin gleich auf 0.1.3 bei der Erstinstallation gegangen.
                              Eventuell läufts bei euch, weil ihr schon die Vorversion lauffähig hattet.
                                sigi234 Forum Testing Most Active @Negalein last edited by
                                Bot Code bekommen?
                                • Negalein
                                  Negalein Global Moderator @Negalein last edited by
                                  @sigi234 sagte in Test Adapter WhatsAPP-CMB:
                                  Bot Code bekommen?
                                  Ja, direkt im Browser funktioniert es.
                                    @Negalein es gibt von Apollon bereits ein pull request auf git wegen dem Fehler in der 0.1.3.
                                    Geh auf die 0.0.1 zurück, dann läuft das... Erstmal..
                                    • Negalein
                                      Negalein Global Moderator @Guest last edited by Negalein
                                      Danke, so dringend benötige ich ihn nicht.Wird @Bluefox schon früher oder später fixen. 😀
                                      • MathiasJ
                                        MathiasJ last edited by
                                        Ich nutze WhatsApp-cmb schon seit längerem bei Homematic.
                                        Nun ist es hier angekommen. 👍
                                        Ich werde dann mal ein paar Tests damit machen.
                                        Wenn ich Besuch vom Nachbarn bekomme, habe ich ihn damit genervt. 😊
                                        Bei mir kann ich es nicht versuchen, habe kein WhatsApp.
                                        Gruß,
                                        Mathias
                                        • 4
                                          4-Real last edited by
                                          hab Ihn auch getestet, soweit funktioniert er auch wie er soll. Danke erstmal dafür.
                                          Das einzige was mich aber stört ist die sehr sehr lange verzögerung beim erhalten einer Nachricht..
                                          Da bleibe ich dann doch lieber erstmal bei Telegram.
                                            @Negalein hat er freundlicherweise heute morgen gemacht, Version 0.1.6 läuft und hat diesen Fehler nicht mehr.
                                            adapter tester
                                            47
                                            172
                                            38460
