    4. VIS von Sigi234
    VIS von Sigi234
      sigi234 Forum Testing Most Active @Segway last edited by sigi234
      @Segway sagte in VIS von Sigi234:
      Diese Tunein View ?
      Ja , eher geeignet.
      Wenn per HTTP dann das:
      [{"tpl":"tplIconHttpGet","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"url":"http://","text":"AV4","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"1245px","top":"512px","background-color":"#000000","background":"","width":"150px","height":"30px","border-color":"#e3e3e3","color":"#d7cec1","z-index":"1","border-radius":"5px","border-width":"1px","border-style":"solid","line-height":""},"widgetSet":"jqui"}]
      • Segway
        Segway @sigi234 last edited by
        @sigi234 sagte in VIS von Sigi234:
        Diese Tunein View ?
        Ja , eher geeignet.
        Ich mach das per upnp Adapter da ich direkt den Stream an den Wlan Lautsprecher möchte damit nicht irgendein App auf dem Handy oder Pc laufen muss!
        Ich schau mal nach dem TuneIn View 👍
          ChrisXY @sigi234 last edited by
          @sigi234 Mich würde aber deine Menü Lösung auch Intressieren 😉 Hab so viele schöne Seiten aber das richtig gute Menü fehlt irgendwie noch
          • I
            Idefix01 @ChrisXY last edited by
            @sigi234
            Kannst du bitte mal deine komplette Vis sowie die Logos als zip-Export hier posten?
              ChrisXY @kukoratsch last edited by
              Die Alarm viev .txt hier sind die Umlaute kaputt 😉
              Hab das icons-mfd-svg geladen und Aktiviert. Jedoch ist im Verzeichnis nichts drin ..
              /icons-mfd-svg/ ist leer.
              • Negalein
                Negalein Global Moderator @ChrisXY last edited by Negalein
                @ChrisXY sagte in VIS von Sigi234:
                Nein, wurde nur nicht richtig von dir runtergeladen.
                direkt im Browser geöffnet
                Speichern unter und mit Notepad++ geöffnet
                Rechtsklick auf Link --> speichern unter --> mit vernünftigem Editor öffnen (zB Notepad++)
                sigi234 1 Reply Last reply Reply Quote 2
                  sigi234 Forum Testing Most Active @Negalein last edited by
                  @Negalein sagte in VIS von Sigi234:
                  Guter Hinweis, habe es mal im 1.Post hinzugefügt. 👍
                    MartyBr @sigi234 last edited by
                    @sigi234 Hallo Sigi,
                    ich setze deinen Alarm View zum Alarm Adapter ein. Nun bin ich auf die Idee gekommen, den Vis-Material Adapter gegen den Vis-Material-Advanced zu tauschen (also alten deinstallieren und neuen zu installieren).
                    Nun sind bei den Fensterkontakten und den Bewegungsmeldern die roten bzw. grünen Einfärbungen verschwunden.
                    In der VIS sehe ich nur CSS Klassen.
                    Kannst du mir hier weiterhelfen?
                      sigi234 Forum Testing Most Active @MartyBr last edited by
                      @MartyBr
                      Muss ich mir ansehen
                        @sigi234 Hier noch einige Infos:
                        Die Einstellung von Widget:
                        Das Widget:
                        [{"tpl":"tplImage","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-mfd-svg/message_presence.svg","stretch":false,"visibility-oid":"hm-rpc.2.000918A98BEDEF.1.MOTION","name":"Alarm Bewegung Vorraum red","filterkey":"Bild","class":"mdui-red-glow"},"style":{"left":"340px","top":"632px","z-index":"5","width":"79px","height":"66px"},"widgetSet":"basic"}]
                        Hier CSS (Ist zu lang für das Code-Feld):
                        css.txt
                          @MartyBr sagte in VIS von Sigi234:
                          Funktioniert bei mir, aber was hat das mit Vis-Material-Advanced zu tun?
                            @sigi234 Das ist ja die einzige Änderung, die ich gemacht habe. Ich finde auch keinen Punkt, der darauf hinweist. Daher mein Hilferuf an die Spezialisten.
                              sigi234 Forum Testing Most Active @MartyBr last edited by sigi234
                              Aha, seit dieser geht es nicht mehr?
                              Hast du unter CSS das? (gekürzt sind ca.4472 Zeilen)
                              ##### Material Design CSS for ioBroker.vis
                              (c) 2017ff Uhula, MIT License
                              source: https://github.com/Uhula/ioBroker-Material-Design-Style
                              changelog: https://github.com/Uhula/ioBroker-Material-Design-Style/blob/master/changelog.MD
                              :root {
                                --release : 'MDCSS v2.5';
                                --release-date : '30.04.2020';
                              Und unter Skripte auch was?
                              Mach mal:
                              iobroker stop vis
                              iobroker upload vis
                              iobroker start vis
                              Browser Cache leeren.
                              M 3 Replies Last reply Reply Quote 0
                                @sigi234 Wo finde ich das MDCSS v2.5?
                                VIS reload have ich schon gemacht. Ohne Erfolg.
                                Im CSS habe ich eigentlich nur das CCS für den Pollenadapter.
                                Der Code ist leider sehr lang.
                                  @sigi234
                                  Habe den Thread gefunden.
                                  Hier der Inhalt im Reiter Script
                                  function hslToRgb(h, s, l){
                                      var r, g, b;
                                      if(s === 0) {
                                          r = g = b = l; // achromatic
                                      }else{
                                          var hue2rgb = function hue2rgb(p, q, t){
                                              if(t < 0) t += 1;
                                              if(t > 1) t -= 1;
                                              if(t < 1/6) return p + (q - p) * 6 * t;
                                              if(t < 1/2) return q;
                                              if(t < 2/3) return p + (q - p) * (2/3 - t) * 6;
                                              return p;
                                          var q = l < 0.5 ? l * (1 + s) : l + s - l * s;
                                          var p = 2 * l - q;
                                          r = hue2rgb(p, q, h + 1/3);
                                          g = hue2rgb(p, q, h);
                                          b = hue2rgb(p, q, h - 1/3);
                                      return [Math.round(r * 255), Math.round(g * 255), Math.round(b * 255)];
                                  function numberToColorHsl(i) {
                                      // as the function expects a value between 0 and 1, and red = 0° and green = 120°
                                      // we convert the input to the appropriate hue value
                                      var hue = i * 1.2 / 360;
                                      // we convert hsl to rgb (saturation 100%, lightness 50%)
                                      var rgb = hslToRgb(hue, 1, .5);
                                      // we format to css value and return
                                      return 'rgb(' + rgb[0] + ',' + rgb[1] + ',' + rgb[2] + ')';
                                  setTimeout(function () {
                                      // click-Eventhandler für "mdui-scale-" setzen
                                      $("#vis_container").on("click", "[class*='PINbutton']", function (event) {
                                          addNumber($(this));
                                          console.log("test");
                                          //$("[id*='w00027']")["0"].innerText='16';
                                          console.log($("[id*='w00040']"));
                                          //["0"].attributes["0"].value
                                      $("#vis_container").on("click", "[class*='PINbutton clear']", function (event) {
                                          clearForm($(this));
                                          //$("[id*='w00040']")["0"].innerText='16';
                                          console.log($("[id*='w00040']")["0"].innerText);
                                  }, 1000);
                                  function addNumber(e) {
                                      //document.getElementById('PINbox').value = document.getElementById('PINbox').value+element.value;
                                      var id = MDUI.getTargetID(e);
                                      var v = $("[id*='w00040']")["0"].innerText;
                                      $("[id*='w00040']")["0"].innerText = (v + e.attr("data-val"));
                                      console.log("V=" + v + " eigen:  " + e.attr("data-val") + "  td_ " + id);
                                  function clearForm(e) {
                                      //document.getElementById('PINbox').value = "";
                                      $("[id*='w00040']")["0"].innerText = "";
                                  function submitForm(e) {
                                      if (e.value === "") {
                                          alert("Enter a PIN");
                                      } else {
                                          alert("Your PIN has been sent! - " + e.value);
                                          data = {
                                              pin: e.value
                                  		apiCall( data, function( r ) {
                                  			$( "#logo" ).attr( "src", r.site_logo );
                                  			$( ".title-msg" ).text( r.site_msg );
                                  			accent = r.accent;
                                  			$( ".accent-bg" ).css( "background-color", accent );
                                          $("#PINbox").val("");
                                    @sigi234
                                    Ich habe jetzt mal den CSS Code in der Version 2.5 eingespielt und einen neuen upload VIS gemacht.
                                    Keine Besserung.
                                      @sigi234
                                      Keine Besserung.
                                      Skripte auch? Und CSS unter Projekt?
                                      version: v2.5 30.04.2020
                                      // Zur sicheren CSS-Erkennung der Runtime eine CSS-Klasse anlegen
                                      document.documentElement.className +=  " mdui-runtime";
                                      // Überprüfen ob touch zur Verfügung steht und entsprechend eine
                                      // CSS Klasse touch bzw no-touch erzeugen
                                          (("ontouchstart" in document.documentElement) ? " mdui-touch" : " mdui-notouch");
                                         MDUI
                                         Sammlung von JS-Funktionen für das Material Design
                                      var MDUI = (function () {
                                      let defConfig = {"primary_color":"indigo",
                                                       "secondary_color":"blue",
                                                       "content_color":"#f8f8f8",
                                                       "color1":"#ff0000",
                                                       "color1_dark":"#800000",
                                                       "color2":"#00ff00",
                                                       "color2_dark":"#008000",
                                                       "color3":"#0000ff",
                                                       "color3_dark":"#000080"
                                          lastConfig = defConfig,
                                          styleSheet = null,
                                          lastPageID = "";
                                          observerSlider = null;
                                          observerConfig = null;
                                          observerPage = null;
                                          observerDialog = null;
                                          swipe = {enabled:false};
                                          tooltip = {hint:null, timeout:null};
                                          lockclick = false;
                                      //                      light         normal        dark
                                      let colors = {
                                              red:        {c200:"#ff7961", c500:"#f44336", c700:"#ba000d" },
                                              pink:       {c200:"#ff6090", c500:"#e91e63", c700:"#b0003a" },
                                              purple:     {c200:"#d05ce3", c500:"#9c27b0", c700:"#6a0080" },
                                              deeppurple: {c200:"#9a67ea", c500:"#673ab7", c700:"#320b86" },
                                              indigo:     {c200:"#757de8", c500:"#3f51b5", c700:"#002984" },
                                              blue:       {c200:"#6ec6ff", c500:"#2196f3", c700:"#0069c0" },
                                              lightblue:  {c200:"#67daff", c500:"#03a9f4", c700:"#007ac1" },
                                              cyan:       {c200:"#62efff", c500:"#00bcd4", c700:"#008ba3" },
                                              teal:       {c200:"#52c7b8", c500:"#009688", c700:"#00675b" },
                                              green:      {c200:"#80e27e", c500:"#4caf50", c700:"#087f23" },
                                              lightgreen: {c200:"#bef67a", c500:"#8bc34a", c700:"#5a9216" },
                                              lime:       {c200:"#ffff6e", c500:"#cddc39", c700:"#99aa00" },
                                              yellow:     {c200:"#ffff72", c500:"#ffeb3b", c700:"#c8b900" },
                                              amber:      {c200:"#fff350", c500:"#ffc107", c700:"#c79100" },
                                              orange:     {c200:"#ffc947", c500:"#ff9800", c700:"#c66900" },
                                              deeporange: {c200:"#ff8a50", c500:"#ff5722", c700:"#c41c00" },
                                              brown:      {c200:"#a98274", c500:"#795548", c700:"#4b2c20" },
                                              grey:       {c200:"#cfcfcf", c500:"#9e9e9e", c700:"#707070" },
                                              darkgrey:   {c200:"#383838", c500:"#303030", c700:"#212121" },
                                              bluegrey:   {c200:"#8eacbb", c500:"#607d8b", c700:"#34515e" },
                                              white:      {c200:"#ffffff", c500:"#f8f8f8", c700:"#f0f0f0" },
                                              black:      {c200:"#303030", c500:"#212121", c700:"#000000" }
                                      function _init() {
                                          observerSlider = new MutationObserver(function(mutations) {
                                              mutations.forEach(function(mutation) {
                                                  _onChangeSlider( mutation.target );
                                          observerConfig = new MutationObserver(function(mutations) {
                                                  _onChangeConfig( mutation.target );
                                          observerPage = new MutationObserver(function(mutations) {
                                                  _onChangePage( mutation.target );
                                          observerDialog = new MutationObserver(function(mutations) {
                                                  _onChangeDialog( mutation.target );
                                      // für alle ui-slider-handle Instanzen "style" überwachen um die Wertanzeige via css
                                      // durchführen zu können (vis rendert dort die left/bottom neu)
                                      function _initObserverSlider() {
                                          observerSlider.disconnect();
                                          let nodelist = document.querySelectorAll('.mdui-slider .ui-slider-handle');
                                          if (nodelist) {
                                              let i;
                                              for (i = 0; i < nodelist.length; i++) {
                                                 _onChangeSlider( nodelist[i] );
                                                 observerSlider.observe(nodelist[i], {
                                                    attributes: true,
                                                    attributeFilter: ["style"]
                                      // für mdui-config Elemente überwachen
                                      function _initObserverConfig() {
                                          observerConfig.disconnect();
                                          let nodelist = document.querySelectorAll('.mdui-config');
                                          if (nodelist) {
                                              let i;
                                                 observerConfig.observe(nodelist[i], {
                                                    subtree: true,
                                                    childList: true
                                      // vis_container überwachen: childlist
                                      function _initObserverPage() {
                                          observerPage.disconnect();
                                          let nodelist = document.querySelectorAll('#vis_container');
                                          if (nodelist) {
                                              let i;
                                                 observerPage.observe(nodelist[i], {
                                                    subtree: true,
                                                    childList: true
                                      // ui-dialog
                                      function _initObserverDialog() {
                                          observerDialog.disconnect();
                                          let nodelist = document.querySelectorAll('.ui-dialog');
                                          if (nodelist) {
                                              let i;
                                                 observerDialog.observe(nodelist[i], {
                                                    attributes: true,
                                      // ui-slider haben keine Werte im HTML, lediglich "left" bzw. "bottom" (bei vertikal)
                                      // werden für das ui-slider-handle gerendert. Hier wird dieser Wert in ein
                                      // neues Attribut "mdui-slider-value" gesetzt um dieses via CSS als Bubble
                                      // anzeigen zu können
                                      function _onChangeSlider( ele ) {
                                          let value = "0%";
                                          if (ele.style.left!=="")
                                              value = ele.style.left;
                                          if (ele.style.bottom!=="")
                                              value = ele.style.bottom;
                                          // nn% -> nn
                                          value = value.replace(/%/g, "");
                                              ele.style.width = (100 - value) + "%";
                                              ele.style.height = (100 - value) + "%";
                                          // mdui-range angegeben?
                                          let values = ele.parentElement.parentElement.className;
                                          values = _getSuffix(values, "mdui-range-");
                                          if (values!="") {
                                              values = values.split("-");
                                              if (values.length>1)
                                                  value = value/100 * (values[1]-values[0]) + values[0] * 1.0;
                                              else if (values.length>0)
                                                  value = value/100 * values[0];
                                          if (Math.abs(value)<10)
                                            value = Math.round( value*10 ) / 10;
                                          else
                                            value = Math.round( value );
                                          ele.setAttribute("mdui-slider-value",value);
                                      // wenn sich die config ändert, muss evtl ein reload der Seite stattfinden
                                      function _onChangeConfig( ele ) {
                                          _getConfig();
                                          _patchColors();
                                          _patchWidgetColors();
                                          _initObserverConfig();
                                      function _onLoad() {
                                        let sel = "#"+lastPageID+" ";
                                        try {
                                              $(sel+"[class*='mdui-onload'][class*='mdui-expand']:not(.mdui-active)").each( function (index) {
                                                  _toggleExpand( $(this) );
                                              $(sel+"[class*='mdui-onload'][class*='mdui-toggle']:not(.mdui-active)").each( function (index) {
                                                  _handleToggle( $(this) );
                                              $(sel+"[class*='mdui-onload'][class*='mdui-fullscreen']:not(.mdui-active)").each( function (index) {
                                                  _toggleFullscreen( $(this) );
                                        } catch(err) { console.log("[MDUI._onLoad] ",err.message ); }
                                      function _onChangePage( ele ) {
                                          let pageID = "";
                                          let $eles = $( "#vis_container>:not([style*='display: none'])[id*='visview_']" );
                                          if ( $eles.length < 1 || $eles.length > 2) return;
                                          pageID = $eles[$eles.length-1].id;
                                      //console.log("[MDUI.onChangePage] ",lastPageID," ",pageID);
                                          // wenn ein ui-datepicker hinzugekommen ist, dann dort die Farben anpassen
                                          if (this.datepickerCount != $(".ui-datepicker").length ) {
                                              this.datepickerCount = $(".ui-datepicker").length;
                                              _patchColors();
                                          // beim Seitenwechsel ausführen
                                          if ( (pageID!="") && (lastPageID!=pageID) ) {
                                              lastPageID=pageID;
                                              setTimeout( function () {
                                                  _getConfig();
                                                  _patchColors();
                                                  _handleTables();
                                                  _handleDialogs();
                                                  _handleInputs();
                                                  _handleVIS();
                                                  _initObserverSlider();
                                                  _initObserverDialog();
                                                  _onResizeWindow( $(window) );
                                                  _onLoad();
                                                  // favicon anpassen
                                                  $("#vis_container>:not([style*='display: none']) .mdui-favicon img").each( function (index) {
                                                      if ($(this)[0].src)
                                                           $("link[rel='shortcut icon']").attr("href", $(this)[0].src);
                                                  // page-name anpassen
                                                  let pagename = decodeURI( window.location.hash.substr(1,255) );
                                                  $(".mdui-page-name").each( function (index) {
                                                      $(this).html( pagename );
                                                  $(".mdui-page-title").each( function (index) {
                                                      // "pageMeine_ioBroker_Vis" -> "Meine ioBroker Vis"
                                                      let title = '';
                                                      let c;
                                                      for (let i=0; i<pagename.length; i++) {
                                                          c = pagename[i];
                                                          if (title=='') {
                                                              if (c==c.toUpperCase()) title += c;
                                                          } else {
                                                              if (c=='_') c = ' ';
                                                              title += c;
                                                      $(this).html( title );
                                              }, 100);
                                          _initObserverPage();
                                      // wenn ein Dialog sichtbar wird, dann seine Farben anpassen
                                      function _onChangeDialog( ele ) {
                                          //_handleDialogs();
                                      // liefert den suffix einer gegebenen class zurück
                                      // Bsp: mdui-target-w00002 -> w00002
                                      //      mdui-range-100-200 -> 100-200
                                      function _getSuffix( s, classname ) {
                                          let suf = "";
                                          if (s.includes(classname)) {
                                              suf = s.substr(s.indexOf(classname)+classname.length,1000)+" ";
                                              suf = suf.substr(0,suf.indexOf(" "));
                                          return suf;
                                      // liefert den suffix einer gegebenen class eine $ele zurück
                                      function _getClassSuffix( $ele, classname ) {
                                          if ($ele)
                                              return _getSuffix($ele.attr( "class" ),classname);
                                          else
                                              return "";
                                      // aktuelle mdui-config entladen
                                      function _getConfig() {
                                          $("#vis_container>:not([style*='display: none']) [class*='mdui-config ']").each( function (index) {
                                              try {
                                                  lastConfig = JSON.parse("{"+$(this)[0].innerText+"}");
                                              } catch(err) { console.log( "MDUI._getConfig: ", err.message ); }
                                          if (!lastConfig.hasOwnProperty("primary_color"))
                                              lastConfig.primary_color = defConfig.primary_color
                                          if (!lastConfig.hasOwnProperty("secondary_color"))
                                              lastConfig.secondary_color = defConfig.secondary_color;
                                          if (!lastConfig.hasOwnProperty("content_color"))
                                              lastConfig.content_color = defConfig.content_color;
                                      function _getGroupID( ele ) { return _getClassSuffix(ele, "mdui-group-" ); }
                                      function _getTargetID( ele ) { return _getClassSuffix(ele, "mdui-target-" ); }
                                      function _getScrollbarWidth() {
                                          let $outer = $('<div>').css({visibility: 'hidden', width: 100, overflow: 'scroll'}).appendTo('body'),
                                              widthWithScroll = $('<div>').css({width: '100%'}).appendTo($outer).outerWidth();
                                          $outer.remove();
                                          return 100 - widthWithScroll;
                                      function _getScrollbarHeight() {
                                          var $outer = $('<div>').css({visibility: 'hidden', height: 100, overflow: 'scroll'}).appendTo('body'),
                                              heightWithScroll = $('<div>').css({height: '100%'}).appendTo($outer).outerHeight();
                                          $outer.remove();
                                          return 100 - heightWithScroll;
                                      // action: command(param1,param2,...)
                                      function _executeAction(action){ try {
                                          if (action) {
                                              let cmd = action.split('(')[0];
                                              let param = action.split('(')[1];
                                              param = param.slice(0,param.length-1);
                                              param = param.split(',');
                                              switch (cmd.toUpperCase() ) {
                                                  case 'SETVALUE' :
                                                      vis.setValue(param[0], param[1]);
                                                      break;
                                                  case 'CHANGEVIEW' :
                                                      vis.changeView( param[0] );
                                                      break;
                                                  //showMessage(message, title, icon, width, callback)
                                                  case 'SHOWMESSAGE' :
                                                      vis.showMessage( param[0], param[1], param[2], param[3] );
                                                      _patchColors();
                                                      break;
                                      } catch(err) { console.log( "[MDUI._executeAction] " + err.message ); }
                                      function _isDarkTheme(ele) {
                                        while (ele) {
                                            if (ele.classList.contains('mdui-dark'))
                                                return true;
                                            ele = ele.parentElement;
                                        return false;
                                      function _formatDatetime(date, format) {
                                          function fill(comp) {
                                              return ((parseInt(comp) < 10) ? ('0' + comp) : comp)
                                          var months = ['Jan', 'Feb', 'Mär', 'Apr', 'Mai', 'Jun', 'Jul', 'Aug', 'Sep', 'Okt', 'Nov', 'Dez'];
                                          var d = format;
                                          var o = {
                                                  "y+": date.getFullYear(), // year
                                                  "m+": fill(date.getMonth()+1), //month
                                                  "M+": months[date.getMonth()], //month
                                                  "d+": fill(date.getDate()), //day
                                                  "H+": fill((date.getHours() > 12) ? date.getHours() % 12 : date.getHours()), //hour
                                                  "h+": fill(date.getHours()), //hour
                                                  "n+": fill(date.getMinutes()), //minute
                                                  "s+": fill(date.getSeconds()), //second
                                                  "S+": fill(date.getMilliseconds()), //millisecond,
                                                  "b+": (date.getHours() >= 12) ? 'PM' : 'AM'
                                          for (var k in o) {
                                              if (new RegExp("(" + k + ")").test(format)) {
                                                  d = d.replace(RegExp.$1, o[k]);
                                          return d;
                                      // alle Elemente mit class "mdui-group-XXX" togglen, in denen
                                      // XXX aus class "mdui-group-XXX" des ele ist UND
                                      // alle Elemente mit class "mdui-target-XXX" togglen, in denen
                                      // XXX aus class "mdui-target-XXX" des ele ist
                                      function _handleToggle( $ele ) {
                                          $ele.toggleClass("ui-state-active");
                                          $ele.toggleClass("mdui-active");
                                          var id = _getGroupID( $ele );
                                          if (id!=="")
                                              $("[class*='mdui-group-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
                                                  $(this).toggleClass("mdui-hide");
                                                  $(this).toggleClass("mdui-hide-show");
                                          id = _getTargetID( $ele );
                                          if (id!=="")
                                              $( "[class*='mdui-target-"+id+"']").not("[class*='mdui-toggle']").each( function (index) {
                                      // das nächste übergeordnete .mdui-card* Element wird
                                      // - collapsed, wenn es expanded ist
                                      // - expanded, wenn es collapsed ist
                                      function _toggleExpand( $ele ){
                                          if (!$ele) return;
                                          let $target = $ele.closest("[class*='mdui-listitem']");
                                          if ($target.length===0) $target = $ele.closest("[class*='mdui-card']");
                                          if ($target.length===0) return;
                                          // wurde im ele eine Höhe mit angegeben?
                                          let h = _getClassSuffix( $ele, "mdui-expand-" ) ;
                                          if (h==="") h="64";
                                          // element um 180° drehen
                                          let styleold = $ele.attr("styleold");
                                          if (styleold) {
                                              $ele.attr("style",styleold);
                                              $ele.removeAttr("styleold");
                                          } else {
                                              styleold = $ele.attr("style");
                                              $ele.attr("styleold",styleold);
                                              $ele.attr("style",styleold + " transform:rotate(180deg); transition:transform 0.33s; ");
                                          // target Element expandieren oder collabieren
                                          styleold = $target.attr("styleold") || "";
                                          if (styleold!=="") {
                                              $target.attr("style",styleold + " transition:all 0.33s;");
                                              $target.removeAttr("styleold");
                                          } else {
                                              styleold = $target.attr("style") || "";
                                              if (styleold==="") styleold="top:0;";
                                              $target.attr("styleold",styleold);
                                              $target.attr("style",styleold + " max-height:"+h+"px !important; " + " min-height:"+h+"px !important; transition:all 0.33s; ");
                                      // das nächste übergeordnete .vis-view Element wird
                                      // - fullscreen angezeigt, wenn es noch nicht fullscreen ist
                                      // - wieder normal angezeigt, wenn es fullscreen ist
                                      /* <div class="vis-widget mdui-button mdui-fullscreen mdui-center vis-tpl-basic-HTML" style="width: 36px; height: 36px; left: calc(100% - 52px); top: 16px; z-index: 1;" id="w00005">
                                              <div class="vis-widget-body">
                                                  <i class="material-icons">fullscreen</i>
                                              </div>
                                          </div>
                                      function _toggleFullscreen( $ele ){
                                          if (!$ele) return;
                                          let $target = $ele.closest(".vis-view");
                                          if (!$target) return;
                                          var styleold = $target.attr("styleold");
                                          if (styleold) {
                                              let html = $ele.html();
                                              html = html.replace(/fullscreen_exit/g, "fullscreen");
                                              $ele.html( html );
                                              $target.attr("style",styleold);
                                              $target.appendTo(".mdui-id-"+$target.attr("id"));
                                          } else {
                                              html = html.replace(/fullscreen/g, "fullscreen_exit");
                                              $ele.html( html );
                                              $target.parent().addClass("mdui-id-"+$target.attr("id"));
                                              $target.attr("styleold",$target.attr("style"));
                                              // dark-theme?
                                              if ($ele.closest(".mdui-content.mdui-dark").length) $target.addClass("mdui-dark");
                                              $target.attr("style","position:fixed; left:8px; top:8px; min-width:0; width:calc(100% - 16px); min-height:0; height:calc(100% - 16px); z-index: 2147483647 !important; background-color: "+lastConfig.content_color+" !important;   box-shadow: 0 0 0 1px rgba(0,0,0,0.3), 0 14px 28px rgba(0,0,0,0.65), 0 10px 10px rgba(0,0,0,0.62); border-radius: 4px;");
                                              $target.appendTo( "body" );
                                      // ele muss class Einträge für das Target und den Skalierungsmodus haben
                                      // "mdui-target-(id) mdui-scale-(scalemode)"
                                      // id: Ziel-Element mit id=id, welches ein zu skalierendes img enthält
                                      // scalemode: fit / hfit / vfit / in / out / (number)
                                      // number: Zahl in %
                                      function _scale( ele ) {
                                          var id = _getTargetID( ele );
                                          var $img = $( "#"+id+" img" );
                                          if ($img) {
                                              var scale = _getClassSuffix(ele, "mdui-scale-" );
                                              $img.width("1px"); // Scrollbars entfernen um die echte Höhe zu bekommen
                                              $img.height("1px");
                                              var dim = {
                                                  pw : $img.parent().width(),
                                                  ph : $img.parent().height(),
                                                  w  : $img[0].naturalWidth,
                                                  h  : $img[0].naturalHeight
                                              switch(scale) {
                                                  case "fit":
                                                      if (dim.pw / dim.w < dim.ph / dim.h ) scale = dim.pw / dim.w;
                                                      else scale = dim.ph / dim.h;
                                                      break;
                                                  case "hfit":
                                                      else scale = (dim.pw - _getScrollbarWidth() - 4  ) / dim.w;
                                                      break;
                                                  case "vfit":
                                                      if ( dim.pw / dim.w > dim.ph / dim.h ) scale = dim.ph / dim.h;
                                                      else scale = (dim.ph - _getScrollbarHeight() - 4  ) / dim.h;
                                                      break;
                                                  case "in":
                                                  case "out":
                                                      var old = $img.attr( "style" );
                                                      old = old.substr(old.indexOf("scale(")+6,20);
                                                      old = old.substr(0,old.indexOf(")"));
                                                      if (old * 1==0) scale = 1;
                                                      else if (scale=="in") scale = old * 1.41;
                                                           else scale = old / 1.41;
                                                      break;
                                                  default:
                                                      if (scale<=0 || scale>10000)
                                                          scale = 100;
                                                      scale = scale/100;
                                              scale = Math.round(scale*100)/100;
                                              $img.attr( "style", "position:absolute;top:0;left:0;transform-origin:0 0;transition: transform 0.3s ease-out; transform:scale("+scale+");" );
                                      // ersetzt im src-Attribute des Unter-Elements von (id) den "&range=&
                                      // durch den Wert des in ele angegebenen (span). Für flot-Diagramme
                                      // "mdui-target-(id) mdui-timespan-(span)"
                                      // id: Ziel-Element mit id=id, welches das flot (src) enthält
                                      // span: inc / dec / (number)
                                      // number: Zahl in Minuten
                                      function _timespan( ele ) {
                                          var src = "";
                                          function __patchParam( paramName, offset ) {
                                              let reParam = RegExp(paramName+"=[^&]*", "i");
                                              let reVal = RegExp("[+-][0-9]*", "i");
                                              let param = src.match(reParam);
                                              console.log("timespan param:",param);
                                              if ( param ) {
                                                  param = param[0];
                                                  let paramval = param.match( reVal );
                                                  if (paramval) {
                                                      paramval = Math.floor(paramval) + offset;
                                                      param = param.replace( reVal, paramval<0 ? paramval : "-0" );
                                                  } else {
                                                      if ( (param[param.length-2]=="/") && ("smhdwMy".indexOf(param[param.length-1])>=0) )
                                                          param = param.substr(0,param.length-2) + (offset<0 ? offset : "-0") + param[param.length-1] + param.substr(param.length-2,2);
                                                  console.log("timespan src:",src);
                                                  src = src.replace(reParam, param);
                                          var target = $( "#"+id+" [src]" );
                                          if (target) {
                                              let timespan = _getClassSuffix(ele, "mdui-timespan-" );
                                              src = target.attr( "src" );
                                              // flot
                                              if (src.indexOf("&range=">=0)) {
                                                  let min = src.substr(src.indexOf("&range=")+7,20);
                                                  min = min.substr(0,min.indexOf("&"));
                                                  switch(timespan) {
                                                      case "inc":
                                                          min = min * 2;
                                                          break;
                                                      case "dec":
                                                          min = min / 2;
                                                          break;
                                                      default:
                                                          if ( timespan<=0 )
                                                              timespan = 1440;
                                                          min = timespan;
                                                  src = src.replace(/&range=[0-9]*&/g, "&range="+min+"&");
                                                  target.attr("src",src);
                                              // grafana
                                              // from=now/d, from=now-1d/d
                                              if (src.indexOf("from=">=0) && src.indexOf("to=">=0)) {
                                                  __patchParam( "from", timespan=="inc" ? +1 : -1);
                                                  __patchParam( "to", timespan=="inc" ? +1 : -1);
                                      // ersetzt im src-Attribute des Unter-Elements von (id) einen url-Parameter
                                      function _srcparam( ele ) {
                                          if (target) {
                                              let params = _getClassSuffix(ele, "mdui-srcparam-" ).split("&");
                                              let src = target.attr( "src" );
                                              // grafana
                                              // http://192.168.2.8:3000/d/ek8fMryWz/iobroker-cpu?orgId=1&from=1580383496316&to=1580405096316&var-ID_WC_Temp=20&var-ID_HZR_Temp=17&panelId=4&fullscreen
                                              for (let i=0; i<params.length; i++) {
                                                  let key = params[i].substr(0,params[i].indexOf("="));
                                                  let value = params[i].substr(key.length+1,1000);
                                                  let re = new RegExp(key+"=[^&]*", 'g');
                                                  src = src.replace(re, key+"="+value);  // encodeURI()
                                      function _resetTable( $ele, $table ) {
                                          $table.find("tbody>tr").each( function(index) {
                                              $(this).width("auto");
                                              $(this).height("auto");
                                              $(this).find("td").each( function(index) {
                                                  $(this).attr("labelth","");
                                      function _handleTable( $ele, $table, opt ) {
                                          function setColWidth( colwidth ) {
                                                  $(this).outerWidth(colwidth);
                                          function setColHeight() {
                                              var height = 0;
                                                  if ($(this).height() > height ) height = $(this).height();
                                              if ( height > 0 )
                                                      $(this).height( height );
                                          var innerWidth = $ele.innerWidth();
                                          _resetTable($ele, $table);
                                          if (opt.label) {
                                              // Zellen mit Labels aus <th> ergänzen ?
                                              var labels = [];
                                              $table.find("thead>tr>th").each( function(index) {
                                                  labels[index] = $(this).text();
                                                      if (index < labels.length)
                                                          $(this).attr("labelth",labels[index]);
                                          if (opt.colwidth>1) setColWidth(opt.colwidth);
                                          if (opt.colwidth>2) setColHeight();
                                          return true;
                                      /* Alle mdui-table durchlaufen und überprüfen, ob die minimale Width erreicht
                                      wurde um sie in den responsive State zu überführen
                                      mdui-table-(mode)(-opt1)(-opt2)...(-optn)
                                      mdui-table-ascard-r600-w200-l */
                                      function _handleTables( ) {
                                          $("[class*='mdui-table-']").each( function (index) {
                                              var $ele = $(this);
                                              var $table;
                                              $table = $ele;
                                              if (!$table.is("table")) $table=$table.find("table");
                                              if (!$table.is("table")) return true; // next each
                                              var classes = $ele.attr("class")
                                                  .split(" ")
                                                  .filter( function ( ele ) {
                                                          return  (ele.indexOf("mdui-table-opt") > -1); });
                                              var opts = [];
                                              var opt;
                                              for (var i = 0; i < classes.length; i++) {
                                                  opts[i] = [];
                                                  opts[i].reswidth = 9999;
                                                  opts[i].colwidth = 0;
                                                  opts[i].label = false;
                                                  opt = classes[i].substr(15,200).split("-");
                                                  for (var j = 0; j < opt.length; j++) {
                                                      switch(opt[j][0]) {
                                                      case "r":
                                                          opts[i].reswidth = parseInt(opt[j].substr(1,5));
                                                          break;
                                                      case "w":
                                                          opts[i].colwidth = parseInt(opt[j].substr(1,5));
                                                          break;
                                                      case "c":
                                                          if (opts[i].colwidth>0) opts[i].colwidth = (innerWidth-_getScrollbarWidth()) / opts[i].colwidth - 10;
                                                          break;
                                                      case "l":
                                                          opts[i].label = true;
                                                          break;
                                                      default:
                                              opts.sort(function(a, b){return a.reswidth-b.reswidth});
                                              if (opts.length === 0) return true; // next each
                                              var handled = false;
                                              for (i = 0; i < opts.length; i++) {
                                                  if ( innerWidth < opts[i].reswidth )
                                                     handled = _handleTable( $ele, $table, opts[i]);
                                                  if (handled) break;
                                              if (!handled) _resetTable($ele, $table);
                                      /* Dialogtitle|class=mdui-red-bg|style=min-width:50%;min-height:90%; */
                                      function _handleDialogs( ) {
                                        try {
                                          $("[class*='ui-dialog ']").each( function (index) {
                                              var $ele = $(this);
                                              var $title = $ele.find("div>span[class*='ui-dialog-title']");
                                              if ( ($title) && ($title.html()!=="") ) {
                                                 var html = '';
                                                 var params = $title.html().split("|");
                                                 var param = '';
                                                 for (var p = 0; p < params.length; p++) {
                                                     param = params[p];
                                                     if (param.substr(0,6)=="class=")
                                                        $ele.addClass(param.substr(6,1024));
                                                     else if (param.substr(0,6)=="style=") {
                                                             var csss =  $ele.attr('style') + param.substr(6,1024);
                                                             $ele.attr('style', csss );
                                                          } else html = html + param + " ";
                                                  $title.html( html );
                                        } catch(err) { console.log("[MDUI.handleDialogs] ", err.message ); }
                                      /* Aus dem "text" Input bei mdui-input-number ein "number" machen */
                                      function _handleInputs( ) {
                                        try {
                                          $("[class*='mdui-placeholder-']").each( function (index) {
                                              let s = _getClassSuffix( $(this), "mdui-placeholder-" );
                                              $(this).find("input").each( function (index) {
                                                  $(this)[0].placeholder = s;
                                          $(".mdui-input-number input").each( function () {
                                              let $ele = $(this);
                                              $ele[0].type = "number";
                                          $(".mdui-input-color input").each( function () {
                                              let $ele = $(this);
                                              $ele[0].type = "color";
                                          $(".mdui-input-date input").each( function () {
                                              let $ele = $(this);
                                              $ele[0].type = "date";
                                          $(".mdui-input-time input").each( function () {
                                              let $ele = $(this);
                                              $ele[0].type = "time";
                                        } catch(err) { console.log("[MDUI.handleInputs] ", err.message ); }
                                      function _handleVIS( ) { try {
                                          function _addHeadline(headline) {
                                              return `<tr>
                                      <td class='mdui-value mdui-blue'>${headline}</td>
                                      <td></td>
                                      </tr>`;
                                          function _addRow(key, keydef, val) {
                                              let icon = keydef.hasOwnProperty('icon')?keydef.icon:'';
                                              return `<tr>
                                      <td class='mdui-subtitle' style='width:50%;'>${key}</td>
                                      <td class='mdui-label' style='width:50%;'>${val}</td>
                                      </tr>`;
                                          const VIS_INFO = {
                                              'version':{'icon':'build'},
                                              'user':{'icon':'person'},
                                              'language':{'icon':'language'},
                                              'instance':{'icon':'looks_one'},
                                              'activeView':{'icon':'crop_square'},
                                              'isTouch':{'icon':'touch_app'},
                                              '__views_count':{},
                                              '__states_count':{}
                                          const VIS_INFO_CONN = {
                                              'namespace':{},
                                              '_isConnected':{},
                                              '_reloadInterval':{},
                                              '_reconnectInterval':{}
                                          const HEAD = `<table style='width:100%; table-layout:fixed; word-break:break-all;'>`;
                                          const FOOT = `</table>`;
                                          vis.__views_count = Object.keys(vis.views).length;
                                          vis.__states_count = Math.round( Object.keys(vis.states).length / 4);
                                          $(".mdui-vis-info").each( function () {
                                              let ele = $(this)[0];
                                              let html='', key='';
                                              html += _addHeadline('vis');
                                              for (key in VIS_INFO)
                                                  html += _addRow(key,VIS_INFO[key],vis[key]);
                                              html += _addHeadline('vis connection');
                                              for (key in VIS_INFO_CONN)
                                                  html += _addRow(key,VIS_INFO_CONN[key],vis.conn[key]);
                                              html += _addHeadline('views');
                                              for (key in vis.views) {
                                                  let val=vis.views[key].hasOwnProperty('widgets')?Object.keys(vis.views[key].widgets).length:'0';
                                                  html += _addRow(key,{},val+' Widgets');
                                              html += _addHeadline('states');
                                              for (key in vis.states) {
                                                  if (key.includes('.val'))
                                                      html += _addRow(key,{},vis.states[key]);
                                              ele.innerHTML = HEAD + html + FOOT;
                                      } catch(err) { console.log("[MDUI.handleVIS] ", err.message ); }
                                      // wandelt ein integer in die #rrggbb Darstellung um
                                      function _toRGB(n) {
                                          if ( (n.length>0) && ((n[0]<"0") || (n[0]>"9")) )
                                              return n;
                                          if(n < 0) {
                                              n = 0xFFFFFFFF + n + 1;
                                          return "#" + ("000000" + n.toString(16).toUpperCase()).substr(-6);
                                      // wandelt eine Farbe im hex-Format (#000000) in ein RGB-Array[2] um
                                      function _hexToRGB(hex) {
                                          var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
                                          return result
                                              ? [parseInt(result[1],16),parseInt(result[2],16),parseInt(result[3],16)]
                                              : [0,0,0];
                                      function _hexToRGBA(hex, transparence) {
                                          let RGB = _hexToRGB(hex);
                                          return 'rgba('+RGB[0]+','+RGB[1]+','+RGB[2]+','+transparence+')';
                                      function _getLuminance(r, g, b) {
                                          var a = [r, g, b].map(function (v) {
                                              v /= 255;
                                              return v <= 0.03928
                                                  ? v / 12.92
                                                  : Math.pow( (v + 0.055) / 1.055, 2.4 );
                                          return a[0] * 0.2126 + a[1] * 0.7152 + a[2] * 0.0722;
                                      function _contrast(rgb1, rgb2) {
                                          var l1 = _getLuminance(rgb1[0], rgb1[1], rgb1[2]) + 0.05;
                                          var l2 = _getLuminance(rgb2[0], rgb2[1], rgb2[2]) + 0.05;
                                          if ( l1 > l2 )
                                              return l1 / l2
                                          else
                                              return l2 / l1;
                                      // liefert die fontColor auf Basis der backgroundColor durch Berechnung
                                      // des Kontrasts
                                      function _getFontColor(bc) {
                                          if ( _contrast(_hexToRGB(bc),_hexToRGB("#000000")) < 6 )
                                              return "#ffffff";
                                          else
                                              return "#000000";
                                      // ersetzt in bekannten WIdgets schwarze und weisse Font
                                      function _patchWidgetColors( ) {
                                          let fontColor = _getFontColor( _getColorFromConfig("content_color",lastConfig.content_color,200,defConfig.content_color) );
                                          let isDark = fontColor=="#ffffff";
                                          // flot Widget
                                          $("#vis_container:not([style*='display: none']) iframe[src*='flot'],.ui-dialog iframe[src*='flot']").each(
                                            function (index) {
                                              var $ele = $(this)[0];
                                              var src = $ele.src;
                                              src = src.replace(/&bg=%23[0-9]*&/g, "&bg=%23f00000&");
                                              src = src.replace(/&x_labels_color=%23[0-9]*&/g, "&x_labels_color=%23f00000&");
                                              if (isDark) {
                                                  src = src.replace(/%23000000/g, "%23111111");
                                                  src = src.replace(/%23ffffff/g, "%23000001");
                                                  src = src.replace(/%23111111/g, "%23fffffe");
                                              } else {
                                                  src = src.replace(/%23000001/g, "%23111111");
                                                  src = src.replace(/%23fffffe/g, "%23000000");
                                                  src = src.replace(/%23111111/g, "%23ffffff");
                                              $ele.src = src;
                                          // svg-clock
                                          /* Striche, Ticks */
                                          $(".svg--clock defs line").each( function (index) {
                                              $(this)[0].style.stroke = fontColor;
                                          /* Stundenzeiger */
                                          $("#hands > g.hand--h").each( function (index) {
                                          $("#hands > g.hand--h > line").each( function (index) {
                                          /* Minutenzeiger */
                                          $("#hands > g.hand--m").each( function (index) {
                                          $("#hands > g.hand--m > line").each( function (index) {
                                          /* Ziffern */
                                          $(".svg--clock .svg--ticks text").each( function (index) {
                                              $(this)[0].style.fill = fontColor;
                                          // meteoblue (Wetter)
                                          $("#vis_container:not([style*='display: none']) iframe[src*='meteoblue'], .ui-dialog iframe[src*='meteoblue']").each( function (index) {
                                              var src = $ele.src;
                                              if (isDark) {
                                                  src = src.replace(/layout=light/g, "layout=dark");
                                              } else {
                                                  src = src.replace(/layout=dark/g, "layout=light");
                                              $ele.src = src;
                                          // flot Widget
                                          $("#vis_container:not([style*='display: none']) iframe[src*='orgId='],.ui-dialog iframe[src*='orgId=']").each(
                                              function (index) {
                                                var src = $ele.src;
                                                if (isDark) {
                                                    src = src.replace(/&theme=light/ig, "&theme=dark");
                                                } else {
                                                  src = src.replace(/&theme=dark/ig, "&theme=light");
                                                $ele.src = src;
                                      // holt den CSSFarbwert aus dem Colors-Array
                                      function _getColorFromColors( color, luminance ) {
                                          // colorType in Config?
                                          if (colors.hasOwnProperty(color) )
                                              switch(luminance) {
                                                  case 200: color = colors[color].c200; break;
                                                  case 700: color = colors[color].c700; break;
                                                  default:  color =  colors[color].c500;
                                          return color;
                                      // wandelt den gewünschten Color-Wert in eine CSSColor um
                                      function _getColorFromConfig( colorType, color, luminance, defColor ) {
                                      //console.log("[_getColorFromConfig]:",colorType,color,luminance,defColor);
                                          if (lastConfig.hasOwnProperty(colorType) && colors.hasOwnProperty(lastConfig[colorType]) ) {
                                                  color = _getColorFromColors(lastConfig[colorType], luminance);
                                          // Check color
                                          try {
                                              let $div = $("<div>");
                                              $div.css("border", "1px solid "+color);
                                              $div = $div.css("border-color");
                                              if ( ($div=="") || ($div=="initial") ) color = _getColorFromColors(defColor,luminance);
                                          } catch(err) {
                                              console.log( "[MDUI.getColorFromConfig] (",color,") ", err.message );
                                      //console.log("[_getColorFromConfig] return:",color);
                                          return color;
                                      function _setBKColor(selector, bkcolor, varname) {
                                          // wenn die fc=#ffffff ist, also dark-scheme, dann mdui-dark setzen
                                          if (_getFontColor( bkcolor )=='#ffffff') $(selector).addClass("mdui-dark")
                                          else $(selector).removeClass("mdui-dark");
                                          if (varname!="") document.documentElement.style.setProperty(varname, bkcolor);
                                      function _patchColors() {
                                         try {
                                              let primary_color = defConfig.primary_color,
                                                  secondary_color = defConfig.secondary_color,
                                              // lastConfig entladen
                                              primary_color = _getColorFromConfig("primary_color",lastConfig.primary_color,500,defConfig.primary_color);
                                              let abar_color=primary_color;
                                              let tnav_color=primary_color;
                                              let bnav_color=primary_color;
                                              // abar
                                              abar_color = _getColorFromConfig("abar_color",lastConfig.abar_color,700,abar_color);
                                              _setBKColor('.mdui-abar',abar_color,'--abar-background');
                                              // tnav
                                              tnav_color = _getColorFromConfig("tnav_color",lastConfig.tnav_color,700,tnav_color);
                                              _setBKColor('.mdui-tnav',tnav_color,'--tnav-background');
                                              // bnav
                                              bnav_color = _getColorFromConfig("bnav_color",lastConfig.bnav_color,700,bnav_color);
                                              _setBKColor('.mdui-bnav',bnav_color,'--bnav-background');
                                              // content
                                              content_color = _getColorFromConfig("content_color",lastConfig.content_color,200,defConfig.content_color);
                                              let lnav_color = content_color;
                                              let rnav_color = content_color;
                                              _setBKColor('.mdui-content',content_color,'--content-background');
                                              _setBKColor('.ui-dialog',content_color,'');
                                              _setBKColor('.ui-datepicker',content_color,'');
                                              // lnav
                                              lnav_color = _getColorFromConfig("lnav_color",lastConfig.lnav_color,500,lnav_color);
                                              _setBKColor('.mdui-lnav',lnav_color,'--lnav-background');
                                              // rnav
                                              rnav_color = _getColorFromConfig("rnav_color",lastConfig.rnav_color,500,rnav_color);
                                              _setBKColor('.mdui-rnav',rnav_color,'--rnav-background');
                                              // secondary
                                              secondary_color = _getColorFromConfig("secondary_color",lastConfig.secondary_color,500,defConfig.secondary_color);
                                              document.documentElement.style.setProperty('--accent-color', secondary_color);
                                              document.documentElement.style.setProperty('--accent-color-033', _hexToRGBA(secondary_color, 0.33));
                                              // custom
                                              let custom = _getColorFromConfig("color1",lastConfig.color1,200,defConfig.color1);
                                              document.documentElement.style.setProperty('--color1', custom);
                                              custom = _getColorFromConfig("color1_dark",lastConfig.color1_dark,500,defConfig.color1_dark);
                                              document.documentElement.style.setProperty('--color1-dark', custom);
                                              custom = _getColorFromConfig("color2",lastConfig.color2,200,defConfig.color2);
                                              document.documentElement.style.setProperty('--color2', custom);
                                              custom = _getColorFromConfig("color2_dark",lastConfig.color2_dark,500,defConfig.color2_dark);
                                              document.documentElement.style.setProperty('--color2-dark', custom);
                                              custom = _getColorFromConfig("color3",lastConfig.color3,200,defConfig.color3);
                                              document.documentElement.style.setProperty('--color3', custom);
                                              custom = _getColorFromConfig("color3_dark",lastConfig.color3_dark,500,defConfig.color3_dark);
                                              document.documentElement.style.setProperty('--color3-dark', custom);
                                      //console.log("primary:",primary_color,"secondary:",secondary_color,"content:",content_color," abar:",abar_color," tnav:",tnav_color," lnav:",lnav_color);
                                          } catch(err) { console.log( "[MDUI.patchColors] " + err.message ); }
                                      function _onResizeWindow( $ele ) {
                                        var win = $ele; //this = window
                                      //console.log("[MDUI.onResizeWindow] width:",win.width());
                                        // lnav als fixiertes Seitenmenü?
                                        if (lastConfig.hasOwnProperty("lnav_fixed_width")) {
                                            if (win.width() >= lastConfig.lnav_fixed_width) {
                                                $( "#vis_container" ).addClass("mdui-lnav-fixed");
                                                // sofort öffnen?
                                                if ( (lastConfig.hasOwnProperty("lnav_fixed_open")) &&
                                                     (lastConfig.lnav_fixed_open=="true") ) {
                                                    $( "#vis_container" ).addClass( "mdui-lnav-fixed-open" );
                                            } else {
                                                $( "#vis_container" ).removeClass("mdui-lnav-fixed-open");
                                                $( "#vis_container" ).removeClass("mdui-lnav-fixed");
                                      // swipe
                                      // mdui-swipe-left?dist=48&background=red&icon=delete&text=Löschen&action=setValue(demo_listitem,listitem0+swipeleft+delete)
                                      function _checkSwipeTo(swipeTo, swipeX) { try {
                                          swipeX.enabled = false;
                                          let s = _getSuffix( swipe.ele.className, 'mdui-swipe-'+swipeTo+'?' );
                                          if (!s || s=='') return;
                                          s = '{"'+s.replace(/:/g,'":"')+'"}';
                                          s = s.replace(/;/g,'","');
                                          s = s.replace(/\+/g,' ');
                                          swipeX.opt = JSON.parse(s);
                                          swipeX.enabled = swipeX.opt.dist!=null;
                                          if (swipeX.enabled) {
                                              swipeX.ele = document.createElement('div');
                                              swipeX.ele.style.position = 'absolute';
                                              swipeX.ele.style.overflow = 'hidden';
                                              swipeX.ele.style.zIndex = '32000';
                                              switch (swipeTo) {
                                                  case 'left' :
                                                    swipeX.ele.style.left = (swipe.ele.offsetLeft + swipe.ele.offsetWidth - 2)+'px';
                                                    swipeX.ele.style.top = swipe.ele.offsetTop+'px';
                                                    swipeX.ele.style.height = swipe.ele.offsetHeight+'px';
                                                    swipeX.ele.style.width = '0px';
                                                    break;
                                                  case 'right' :
                                                    swipeX.ele.style.left = swipe.ele.offsetLeft + 2 +'px';
                                                    break;
                                                  case 'up' :
                                                    swipeX.ele.style.left = swipe.ele.offsetLeft+'px';
                                                    swipeX.ele.style.top = (swipe.ele.offsetTop+swipe.ele.offsetHeight-2)+'px';
                                                    swipeX.ele.style.height = '0px';
                                                    swipeX.ele.style.width = swipe.ele.offsetWidth+'px';
                                                    break;
                                                  case 'down' :
                                                    swipeX.ele.style.top = swipe.ele.offsetTop+2+'px';
                                                    break;
                                              if (swipeX.opt.background) {
                                                  swipeX.ele.style.background = _getColorFromColors( swipeX.opt.background, swipe.isDarkTheme?500:200 );
                                              swipeX.ele.style.display = 'flex';
                                              swipeX.ele.style.alignItems = 'center';
                                              swipeX.ele.style.justifyContent = 'center';
                                              swipeX.ele.style.flexWrap = 'wrap';
                                              s='';
                                              if (swipeX.opt.icon)
                                                  s ='<div class="mdui-icon">'+swipeX.opt.icon+'</div>';
                                              if (swipeX.opt.text)
                                                  s+= '<div style="font-size:0.7em">'+swipeX.opt.text+'</div>'
                                              swipeX.ele.innerHTML=s;
                                              // als sibling anhängen
                                              swipe.ele.parentNode.insertBefore(swipeX.ele, swipe.ele.nextSibling);  }
                                          } catch(err) { console.log( "[MDUI._checkSwipeTo] " + err.message ); }
                                      function _swipeStart() {
                                          swipe.swipeLeft={enabled:false};
                                          swipe.swipeRight={enabled:false};
                                          swipe.swipeUp={enabled:false};
                                          swipe.swipeDown={enabled:false};
                                      //    swipe.ele.classList.remove('mdui-lockclick');
                                          lockclick = false;
                                          swipe.isDarkTheme = _isDarkTheme(swipe.ele);
                                          // auf jede swipe-Art untersuchen
                                          _checkSwipeTo('left',swipe.swipeLeft);
                                          _checkSwipeTo('right',swipe.swipeRight);
                                          _checkSwipeTo('up',swipe.swipeUp);
                                          _checkSwipeTo('down',swipe.swipeDown);
                                          swipe.enabled =  swipe.swipeLeft.enabled || swipe.swipeRight.enabled || swipe.swipeUp.enabled || swipe.swipeDown.enabled;
                                      function _swipeMove() {
                                          if (!swipe.enabled) return false;
                                          let x=0, y=0;
                                          const tresholdStart = 0.25;
                                          const tresholdEnd = 0.90;
                                          // welche swipes sind aktiv?
                                          if (swipe.swipeLeft.enabled) {
                                                swipe.swipeLeft.val = swipe.clientX - swipe.fromX;
                                                if ( 0-swipe.swipeLeft.val > swipe.swipeLeft.opt.dist ) swipe.swipeLeft.val = 0-swipe.swipeLeft.opt.dist;
                                                swipe.swipeLeft.active = swipe.swipeLeft.val <= 0-swipe.swipeLeft.opt.dist*tresholdStart;
                                                swipe.swipeLeft.swiped = swipe.swipeLeft.val <= (0-swipe.swipeLeft.opt.dist)*tresholdEnd;
                                                if (swipe.swipeLeft.active) x = swipe.swipeLeft.val;
                                          if (swipe.swipeRight.enabled) {
                                                swipe.swipeRight.val = swipe.clientX - swipe.fromX;
                                                if ( swipe.swipeRight.val > swipe.swipeRight.opt.dist ) swipe.swipeRight.val = swipe.swipeRight.opt.dist;
                                                swipe.swipeRight.active = swipe.swipeRight.val >= swipe.swipeRight.opt.dist*tresholdStart;
                                                swipe.swipeRight.swiped = swipe.swipeRight.val >= swipe.swipeRight.opt.dist*tresholdEnd;
                                                if (swipe.swipeRight.active) x = swipe.swipeRight.val;
                                          if (swipe.swipeUp.enabled) {
                                                swipe.swipeUp.val = swipe.clientY - swipe.fromY;
                                                if ( 0-swipe.swipeUp.val > swipe.swipeUp.opt.dist ) swipe.swipeUp.val = 0-swipe.swipeUp.opt.dist;
                                                swipe.swipeUp.active = swipe.swipeUp.val <= 0-swipe.swipeUp.opt.dist*tresholdStart;
                                                swipe.swipeUp.swiped = swipe.swipeUp.val <= (0-swipe.swipeUp.opt.dist)*tresholdEnd;
                                                if (swipe.swipeUp.active) y = swipe.swipeUp.val;
                                          if (swipe.swipeDown.enabled) {
                                                swipe.swipeDown.val = swipe.clientY - swipe.fromY;
                                                if ( swipe.swipeDown.val > swipe.swipeDown.opt.dist ) swipe.swipeDown.val = swipe.swipeDown.opt.dist;
                                                swipe.swipeDown.active = swipe.swipeDown.val >= swipe.swipeDown.opt.dist*tresholdStart;
                                                swipe.swipeDown.swiped = swipe.swipeDown.val >= swipe.swipeDown.opt.dist*tresholdEnd;
                                                if (swipe.swipeDown.active) y = swipe.swipeDown.val;
                                          // aktive swipes anwenden
                                              if (swipe.swipeLeft.active ) {
                                                  swipe.swipeLeft.ele.style.width = (0-swipe.swipeLeft.val)+'px';
                                                  swipe.swipeLeft.ele.style.transform = 'translate('+swipe.swipeLeft.val+'px,'+y+'px)';
                                                  if (swipe.swipeLeft.swiped) swipe.swipeLeft.ele.style.borderRadius = '0';
                                                  else swipe.swipeLeft.ele.style.borderRadius = '0 5em 5em 0';
                                              } else {
                                                  swipe.swipeLeft.ele.style.width = '0';
                                              if (swipe.swipeRight.active ) {
                                                  swipe.swipeRight.ele.style.width = swipe.swipeRight.val+'px';
                                                  swipe.swipeRight.ele.style.transform = 'translate(0px,'+y+'px)';
                                                  if (swipe.swipeRight.swiped) swipe.swipeRight.ele.style.borderRadius = '0';
                                                  else swipe.swipeRight.ele.style.borderRadius = '5em 0  0 5em';
                                              } else {
                                                   swipe.swipeRight.ele.style.width = '0';
                                              if (swipe.swipeUp.active) {
                                                  swipe.swipeUp.ele.style.height = (0-swipe.swipeUp.val)+'px';
                                                  swipe.swipeUp.ele.style.transform = 'translate('+x+'px,'+swipe.swipeUp.val+'px)';
                                                  if (swipe.swipeUp.swiped) swipe.swipeUp.ele.style.borderRadius = '0';
                                                  else swipe.swipeUp.ele.style.borderRadius = '0 0 5em 5em';
                                              } else {
                                                  swipe.swipeUp.ele.style.height = '0';
                                              if (swipe.swipeDown.active ) {
                                                  swipe.swipeDown.ele.style.height = swipe.swipeDown.val+'px';
                                                  swipe.swipeDown.ele.style.transform = 'translate('+x+'px,0px)';
                                                  if (swipe.swipeDown.swiped) swipe.swipeDown.ele.style.borderRadius = '0';
                                                  else swipe.swipeDown.ele.style.borderRadius = '5em 5em 0 0';
                                              } else {
                                                  swipe.swipeDown.ele.style.height = '0';
                                          if (x==0 && y==0) {
                                              swipe.ele.style.transform = 'none';
                                              return true;
                                          } else {
                                              swipe.ele.style.transform = 'translate('+x+'px,'+y+'px)';
                                              // nach dem 1.swipe click sperren
                                      //        swipe.ele.classList.add('mdui-lockclick');
                                              lockclick = true;
                                              return false;
                                      function _swipeEnd() {
                                          if (!swipe.enabled) return;
                                          if (swipe.swipeLeft.enabled) swipe.swipeLeft.ele.remove();
                                          if (swipe.swipeRight.enabled) swipe.swipeRight.ele.remove();
                                          if (swipe.swipeUp.enabled) swipe.swipeUp.ele.remove();
                                          if (swipe.swipeDown.enabled) swipe.swipeDown.ele.remove();
                                          if ( swipe.swipeLeft.swiped ) _executeAction(swipe.swipeLeft.opt.action);
                                          if ( swipe.swipeRight.swiped ) _executeAction(swipe.swipeRight.opt.action);
                                          if ( swipe.swipeUp.swiped ) _executeAction(swipe.swipeUp.opt.action);
                                          if ( swipe.swipeDown.swiped ) _executeAction(swipe.swipeDown.opt.action);
                                          swipe.enabled = false;
                                      function _swipeTouchStart(event, $ele) {
                                          let touchobj = event.originalEvent.changedTouches[0]; // erster Finger
                                          swipe.fromX = parseInt(touchobj.clientX);
                                          swipe.fromY = parseInt(touchobj.clientY);
                                          swipe.ele = $ele[0];
                                          _swipeStart();
                                      function _swipeTouchMove(event, $ele) {
                                          swipe.clientX = parseInt(touchobj.clientX);
                                          swipe.clientY = parseInt(touchobj.clientY);
                                          _swipeMove();
                                          event.preventDefault();
                                          event.stopImmediatePropagation();
                                      function _swipeTouchEnd(event, $ele) {
                                          _swipeEnd();
                                      function _swipeMouseDown(event, $ele) {
                                          if (swipe.enabled) return;
                                          swipe.fromX = parseInt(event.originalEvent.x);
                                          swipe.fromY = parseInt(event.originalEvent.y);
                                          _swipeStart();
                                          if (swipe.enabled) {
                                            _captureMouseEvents(_swipeMouseMove, _swipeMouseUp);
                                            event.stopPropagation();
                                      function _swipeMouseMove(event, $ele) {
                                          swipe.clientX = parseInt(event.originalEvent.x);
                                          swipe.clientY = parseInt(event.originalEvent.y);
                                          if (_swipeMove()) {
                                      function _swipeMouseUp(event, $ele) {
                                      console.log('_swipeMouseUp' );
                                          _swipeEnd();
                                          _releaseMouseEvents(_swipeMouseMove, _swipeMouseUp);
                                      function _releaseMouseEvents(move,up) {
                                        document.removeEventListener ('mousemove', move, true);
                                        document.removeEventListener ('mouseup', up, true);
                                      function _captureMouseEvents (move,up) {
                                        document.addEventListener ('mousemove', move, true);
                                        document.addEventListener ('mouseup', up, true);
                                      // click
                                      function _click(event, $ele) { try {
                                      console.log('_click');
                                          // durch swipe gelockt?
                                      if (ele.classList.contains('mdui-lockclick')) {
                                              return;
                                          if (lockclick) {
                                              lockclick=false;
                                              return;
                                          let s = _getSuffix( $ele[0].className, 'mdui-click?' );
                                          let opt = JSON.parse(s);
                                          if (opt.action)
                                              _executeAction(opt.action);
                                      } catch(err) { console.log( "[MDUI._click] " + err.message ); }
                                      // tooltip
                                      // mdui-tooltip?text:(text);background:(color);state:(stateid)
                                      function _tooltipShow(ele) { try {
                                          if (tooltip.timeout!=null) clearTimeout(tooltip.timeout);
                                          tooltip.timeout = null;
                                          if (tooltip.hint!=null) tooltip.hint.remove();
                                          tooltip.ele = ele;
                                          tooltip.timeout = setTimeout( () => {
                                            let s = _getSuffix( tooltip.ele.className, 'mdui-tooltip?' );
                                            tooltip.opt = JSON.parse(s);
                                            // text aus state ?
                                            if (tooltip.opt.state && vis.states.hasOwnProperty(tooltip.opt.state+'.val'))
                                                tooltip.opt.text += ' ' + vis.states[tooltip.opt.state+'.val'];
                                            let rect = tooltip.ele.getBoundingClientRect();
                                            let win = tooltip.ele.ownerDocument.defaultView;
                                            rect.top = rect.top + win.pageYOffset,
                                            rect.left = rect.left + win.pageXOffset
                                            tooltip.hint = document.createElement('div');
                                            tooltip.hint.classList.add('mdui-tooltip');
                                            tooltip.hint.style.left = rect.left+'px';
                                            tooltip.hint.style.top = rect.top+'px';
                                            if (tooltip.opt.background)
                                                tooltip.hint.style.background = _getColorFromColors( tooltip.opt.background, 500) ;
                                            tooltip.hint.innerHTML=tooltip.opt.text;
                                            document.documentElement.appendChild(tooltip.hint);
                                            tooltip.width = tooltip.hint.clientWidth;
                                            tooltip.height = tooltip.hint.clientHeight;
                                            let x = (rect.left-tooltip.width/2+tooltip.ele.offsetWidth/2);
                                            if (x<0) x = 8;
                                            if (x+tooltip.width > document.documentElement.clientWidth) x=document.documentElement.clientWidth - tooltip.width - 8;
                                            tooltip.hint.style.left = Math.floor(x)+'px';
                                            let y = rect.top + tooltip.ele.offsetHeight + 8;
                                            if (y+tooltip.height > document.documentElement.clientHeight) y= document.documentElement.clientHeight - tooltip.height - rect.height - 8;
                                            tooltip.hint.style.top = Math.floor(y)+'px';
                                            tooltip.timeout = setTimeout(_tooltipHide, 1000 + s.length * 40);
                                          }, 700);
                                      } catch(err) { console.log( "[MDUI._tooltipShow] " + err.message ); }
                                      function _tooltipHide() {
                                          if (tooltip.hint==null) return;
                                          tooltip.hint = null;
                                      function _tooltipMouseEnter(event, $ele) {
                                          _tooltipShow($ele[0]);
                                      function _tooltipMouseLeave(event, $ele) {
                                          _tooltipHide();
                                      return {
                                          init: _init,
                                          initObserverPage:_initObserverPage,
                                          handleToggle: _handleToggle,
                                          toggleFullscreen: _toggleFullscreen,
                                          toggleExpand: _toggleExpand,
                                          scale: _scale,
                                          timespan: _timespan,
                                          srcparam: _srcparam,
                                          handleTables: _handleTables,
                                          handleDialogs: _handleDialogs,
                                          onChangePage : _onChangePage,
                                          onLoad : _onLoad,
                                          patchColors : _patchColors,
                                          swipeTouchStart : _swipeTouchStart,
                                          swipeTouchMove : _swipeTouchMove,
                                          swipeTouchEnd : _swipeTouchEnd,
                                          swipeMouseDown : _swipeMouseDown,
                                          swipeMouseMove : _swipeMouseMove,
                                          swipeMouseUp : _swipeMouseUp,
                                          tooltipMouseEnter : _tooltipMouseEnter,
                                          tooltipMouseLeave : _tooltipMouseLeave,
                                          click : _click,
                                          onResizeWindow : _onResizeWindow
                                      // Eventhandler für body-Delegators setzen (früher:#vis_container)
                                      function mdui_init() {
                                          MDUI.init();
                                          // click-Event für das left-nav Element zum Öffnen
                                          $("body").on( "click", ".mdui-lnavbutton", function() {
                                              // lnav als popupmenu oder fixed?
                                              if ($( "#vis_container.mdui-lnav-fixed" ).length==0)
                                                  $( ".mdui-lnav" ).toggleClass( "mdui-lnav-open" );
                                              else
                                                  $( "#vis_container" ).toggleClass( "mdui-lnav-fixed-open" );
                                          // click-Event für die left-nav zum Schließen
                                          $("body").on( "click", ".mdui-lnav", function() {
                                                  $( ".mdui-lnav" ).removeClass( "mdui-lnav-open" );
                                          // click-Event für das right-nav Element zum Öffnen
                                          $("body").on( "click", ".mdui-rnavbutton", function() {
                                              $( ".mdui-rnav" ).addClass( "mdui-rnav-open" );
                                          // click-Event für die right-nav zum Schließen
                                          $("body").on( "click", ".mdui-rnav", function() {
                                              $( ".mdui-rnav" ).removeClass( "mdui-rnav-open" );
                                          $("body").on( "click", "[class*='mdui-scale-']", function(event) {
                                              MDUI.scale( $(this) );
                                          // click-Handler für "mdui-toggle"
                                          $("body").on( "click", "[class*='mdui-toggle']", function(event) {
                                              MDUI.handleToggle( $(this) );
                                          // click-Handler für "mdui-info"
                                          $("body").on( "click", ".mdui-info", function(event) {
                                          // click-Handler für "mdui-expand"
                                          $("body").on( "click", "[class*='mdui-expand']", function(event) {
                                              MDUI.toggleExpand( $(this) );
                                          // click-Handler für "mdui-fullscreen"
                                          $("body").on( "click", ".mdui-fullscreen", function(event) {
                                              MDUI.toggleFullscreen( $(this) );
                                          // click-Handler für "mdui-timepsan-"
                                          $("body").on( "click", "[class*='mdui-timespan-']", function(event) {
                                              MDUI.timespan( $(this) );
                                          // click-Handler für "mdui-srcparam-"
                                          $("body").on( "click", "[class*='mdui-srcparam-']", function(event) {
                                              MDUI.srcparam( $(this) );
                                          // event-Handler für "mdui-swipe"
                                          $("body").on( "touchstart", "[class*='mdui-swipe']", function(event) {
                                              MDUI.swipeTouchStart(event, $(this) );
                                          $("body").on( "touchmove", "[class*='mdui-swipe']", function(event) {
                                              MDUI.swipeTouchMove(event, $(this) );
                                          $("body").on( "touchend", "[class*='mdui-swipe']", function(event) {
                                              MDUI.swipeTouchEnd(event, $(this) );
                                          $("body").on( "mousedown", "[class*='mdui-swipe']", function(event) {
                                              MDUI.swipeMouseDown(event, $(this) );
                                          $("body").on( "mousemove", "[class*='mdui-swipe']", function(event) {
                                              MDUI.swipeMouseMove(event, $(this) );
                                          $("body").on( "mouseup", "[class*='mdui-swipe']", function(event) {
                                              MDUI.swipeMouseUp(event, $(this) );
                                          // event-Handler für "mdui-click"
                                          $("body").on( "click", "[class*='mdui-click']", function(event) {
                                              MDUI.click(event, $(this) );
                                          // event-Handler für tooltips
                                          $("body").on( "mouseenter", "[class*='mdui-tooltip']", function(event) {
                                              MDUI.tooltipMouseEnter(event, $(this) );
                                          $("body").on( "mouseleave", "[class*='mdui-tooltip']", function(event) {
                                              MDUI.tooltipMouseLeave(event, $(this) );
                                          $("body").on( "click", "[class*='mdui-tooltip']", function(event) {
                                          $( window ).on("resize", function() {
                                            MDUI.handleTables( $(this) );
                                            MDUI.onResizeWindow( $(this) );
                                          MDUI.initObserverPage();
                                          // für den ersten load einmal aufrufen
                                          setTimeout( MDUI.onChangePage(), 100);
                                      setTimeout( mdui_init(), 100);
                                      // vis ... Menu ausblenden
                                      if (typeof app !== 'undefined') $('#cordova_menu').hide();
                                        @sigi234 Das Script ist auch eingespielt, ich habe den ioBroker komplett neu gestartet. Keine Änderung.
                                        Cache im Browser geleert, auch anderen Browser getestet, keine Änderung.
                                          @MartyBr
                                          Komisch, ist es schon mal gegangen? Welche Vis Version?
                                            MartyBr @sigi234 last edited by MartyBr
                                            @sigi234 Das lief ja die ganze Zeit, genau bis heute. Bis ich auf die Idee mit dem Material Advanced Adapter gekommen bin. In der Test Umgebung hatte ich auch keine Probleme, es betrifft nur genau diese Icons / Widgets im Alarm View 😞
                                            VIS: 1.2.4
                                            Web: 3.0.9
                                            Kannst du mir mal ein Bewegungsmelder Widget posten? Das teste ich dann mal.
                                            ode abfrage vis vis projekte
                                            151
                                            1344
                                            598608
