    4. Test Adapter doorio v2.1.2
      MHeymann @MHeymann last edited by
      Hier mal ein Auszug aus der Log.
      Log.txt
      • Wal
        Wal Developer @MHeymann last edited by
        @MHeymann
        ist der Adapter dann grün ?
        Ich sehe den Error um 23:00 Uhr und um 23:03 Uhr sagt er dann Connect.
          MHeymann @Wal last edited by MHeymann
          @Wal
          Hab das gerade mal beobachtet. Wenn die Fehlermeldung kommt wird der Adapter rot und kurze Zeit später wider grün.
          doorio.0	2020-08-01 23:47:01.401	info	(15061) Connected to 192.168.2.26
          doorio.0	2020-08-01 23:47:01.179	info	(15061) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.doorio, node: v12.18.3, js-controller: 3.1.6
          doorio.0	2020-08-01 23:46:28.491	info	(14465) Terminated (NO_ERROR): Without reason
          doorio.0	2020-08-01 23:46:28.490	info	(14465) terminating
          doorio.0	2020-08-01 23:46:28.471	info	(14465) Disconnected from 192.168.2.26
          doorio.0	2020-08-01 23:46:28.469	error	(14465) uncaughtException: TypeError: Cannot read property 'val' of null
          doorio.0	2020-08-01 23:46:28.466	error	(14465) TypeError: Cannot read property 'val' of null at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50) at BaresipClient.onStateChange (/opt/iobroker/node_modules
          doorio.0	2020-08-01 23:46:28.463	error	(14465) uncaught exception: Cannot read property 'val' of null
          doorio.0	2020-08-01 23:46:05.129	info	(14465) Connected to 192.168.2.26
          doorio.0	2020-08-01 23:46:05.005	info	(14465) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.doorio, node: v12.18.3, js-controller: 3.1.6
          doorio.0	2020-08-01 23:45:32.511	info	(11483) Terminated (NO_ERROR): Without reason
          doorio.0	2020-08-01 23:45:32.494	info	(11483) terminating
          doorio.0	2020-08-01 23:45:32.474	info	(11483) Disconnected from 192.168.2.26
          doorio.0	2020-08-01 23:45:32.472	error	(11483) uncaughtException: TypeError: Cannot read property 'val' of null
          doorio.0	2020-08-01 23:45:32.470	error	(11483) TypeError: Cannot read property 'val' of null at send2Server (/opt/iobroker/node_modules/iobroker.doorio/lib/client.js:40:50) at BaresipClient.onStateChange (/opt/iobroker/node_modules
          doorio.0	2020-08-01 23:45:32.466	error	(11483) uncaught exception: Cannot read property 'val' of null
          doorio.0	2020-08-01 23:41:26.524	info	(11483) Connected to 192.168.2.26
          doorio.0	2020-08-01 23:41:26.358	info	(11483) starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.doorio, node: v12.18.3, js-controller: 3.1.6
          ioBroker verliert immer wider die Verbindung. Liegt das vielleicht doch an baresip? Gibt da ne Log Datei? Wenn ja wo finde ich die denn? Dann schaue ich da mal rein.
          Wal 2 Replies Last reply Reply Quote 0
          • Wal
            Wal Developer @MHeymann last edited by Wal
            @MHeymann
            nein, das liegt nicht an baresip. An deinem Log stört mich, das die Ganzen stateChange anscheinend über den DoorIO-Adapter geleitet werden. Bei mir sehe ich nur einen stateChange wenn geklingelt wird.
            Was wird hier bei dir angezeigt ?
            Evtl. wird der Adapter mit stateChange geflutet und hängt sich auf.
            Kannst du mal alle Adapter ausser Doorio und den Admin stoppen und sehen was passiert ?
            • Wal
              @MHeymann
              hab's gefunden, du hast in der Ring-Konfig das "none" entfernt und den Eingang nicht mit einem Object belegt.
              Der Adapter abonniert dadurch alle Objekte und irgend ein Objekt hat in der Val eine Null stehen.
              Edit: Was einem so nacht's im Bett alles einfällt 🙂
                @Wal
                Das kann gut sein das ds kein none bzw. garnichts steht. Ich werde das ausprobieren wenn ich zuhause bin.
                  @Wal
                  Jep das ist der Fehler. Ich hab wohl bei der Konfiguration des Adapters das "none" bei "Eingabe für Ring_2" gelöscht 😵. Kleiner Fehler große Wirkung.
                  Jetzt kann ich fleißig weiterbauen...
                  Vielen vielen Dank für die Unterstützung und den tollen Adapter.
                  LG 🙂
                  • Wal
                    @MHeymann
                    auf Github habe ich Version 1.0.9, die fängt den Fehler auf. 🙂
                    • Wal
                      Wal Developer last edited by
                      Auf Github was neues .
                      Eine zweite Nummer pro Klingel zum eintragen und jeweils 1 Objekt("detour") zugefügt.
                      Wird das Objekt auf "True" gesetzt, wird die zweite Nummer angerufen.
                      Falls man nicht zu Hause ist, könnte man sich so auf dem Handy anrufen lassen.
                        Ralf87 last edited by
                        ich versuche mich gerade an der Installation von baresip auf einem Raspberry Pi 4. Ich habe die Image Datei aus dem ersten Post genommen und installiert.
                        Wollte dann Baresip accounts anlegen und wenn ich anschließend baresip -v ausführe bekomme ich die Meldung:
                        ua: SIP Transport failed: Adress allready in use
                        ua: Init failed Adress allready in use
                        Ich hoffe ihr könnt mir helfen.
                        Grüße Ralf
                        • Wal
                          Wal Developer @Ralf87 last edited by
                          @Ralf87 ,
                          im Image ist ein Baresip-Service schon vorhanden. Du startest Baresip zum zweiten mal. Falls du baresip -v ausführen möchtest, musst du erst ein "sudo systemctl stop baresip" machen.
                            peterfido @Wal last edited by
                            @Wal
                            ich habe Baresip jetzt auf einer virtuellen Maschine im Proxmox auf dem NUC installiert. DoorIO funktioniert damit.
                            Meine Fragen:
                            1. Besteht die Möglichkeit die Rufnummer des Anrufenden mit auszugeben?
                            2. Gibt es eine Alternative zu "answermode=auto", sodass DoorIO nur bei bestimmten Anrufern abhebt?
                            Vielen Dank im Voraus.
                            • Wal
                              Wal Developer @peterfido last edited by
                              @peterfido sagte in Test Adapter doorio v1.0.x:
                              @Wal
                              Meine Fragen:
                              Ich steh im Moment auf dem Schlauch 🙂 , möchtest du DoorIO zweckentfremden ?
                              Die Rufnummer von der Klingel ist doch immer gleich.
                              So wie ich das lese möchtest du die Türstation anrufen was ja geht, aber im Normalfall ruft die Türstation an wenn jemand klingelt. Ich denke ein Objekt befüllen das die Nummer des Anrufenden zur Türstation zeigt, müsste zu machen sein. Da muss ich mal die Baresipmeldungen durchforsten.
                              P 2 Replies Last reply Reply Quote 0
                                @Wal
                                Ja, erweitern, oder halt zweckentfremden 😉
                                Ich dachte mir eine Steuerung per Telefon und DTMF-Codes. Klappt soweit auch schon. Mir fehlt halt eine Möglichkeit, nur auf bestimmte Rufnummern zu reagieren.
                                Die Nummer kann ich mir nun schon anzeigen lassen. Was mir jetzt noch fehlt, ist dass nur bei bestimmten Nummern abgehoben wird.
                                  peterfido @Wal last edited by peterfido
                                  @Wal
                                  Die Anrufernummer filtere ich so raus (client.js:
                                  //Zeile 186 im 'call_closed':
                                  adapter.setState('CALLING_NUMBER', 'none', true);
                                  //dann, nach 'call_closed':
                                                     case ('CALL_INCOMING'):
                                                         let callerID = jsonContent.peeruri;
                                                         var pos = callerID.indexOf(":");
                                                         if (pos >= 0){
                                                             callerID = callerID.substring(pos + 1);
                                                         pos = callerID.indexOf("@");
                                                         if (pos >= 0){
                                                             callerID = callerID.substring(0, pos - 1);
                                                         adapter.log.debug('incoming call from:' + callerID);
                                                         adapter.setState('CALLING_NUMBER', callerID, true);
                                                        break;
                                  Das Objekt 'CALLING_NUMBER' habe ich schon bei der io-package.json hinzugefügt.
                                  Dann wollte ich noch mehrere Telefonnummern (4 oder mehr) parametrierbar machen. Da kämpfe ich allerdings gerade mit dem
                                                         var stateswl = "";
                                                         adapter.getState('whitelist.NUMBER_1', function (err, state) {
                                                             stateswl = state.val;
                                                         if (callerID.indexOf(stateswl) >= 0) {
                                                           inWL = true;
                                  Die Werte wollte ich dann nach der getstate mit der callerID vergleichen. Allerdings bekomme ich die Variable 'stateswl' nicht global ausgelesen.
                                  Da mache ich dann nächstes Wochenende weiter...
                                  Und dem Baresip sagen, dass er abheben soll, fehlt halt auch noch.
                                  • Wal
                                    @peterfido
                                    Abheben müsste so funktionieren :
                                    client.write(Netstring.write('{"command":"accept","params":""}'))
                                    Der "answermode" muss da aber auf "manual" eingestellt sein.
                                      @Wal
                                      Perfekt, danke. Das funktioniert. 😊
                                        So, die Erweiterung ist soweit eingebaut. Allerdings aktuell nur in meinem Fork. Es fehlen noch einige Übersetzungen.
                                        Möglich ist jetzt die Angabe von bis zu 6 Telefonnummern (Ausschnitte reichen), bei welchen überhaupt der Anruf angenommen werden soll. Zusätzlich kann man jede Rufnummer wählen.
                                        Gibt man in den Einstellungen an, dass Baresip automatisch abhebt, dann läuft es so, wie gehabt.
                                        Vielen Dank für die prima Vorlage.
                                        Wal 1 Reply Last reply Reply Quote 1
                                        • Wal
                                          Wenn du ein Pull Request machst, kann ich das übernehmen.
                                            @Wal
                                            Okay, ist erledigt.
                                            door intercom doorpi türsprechstelle
                                            34
                                            583
                                            123094
