      passuff @da_Woody last edited by
      Muss mich leider mit dem alten Problem zurückmelden:
      2020-08-30 02:00:22.296 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2020-08-30 02:00:22.349 - error: backitup.0 (29506) unhandled promise rejection: Rate Limit Exceeded
      2020-08-30 02:00:22.511 - error: backitup.0 (29506) Error: Rate Limit Exceeded
      at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:117:15)
      at runMicrotasks ()
      at processTicksAndRejections (internal/process/task_queues.js:97:5)
      at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:343:18)
      2020-08-30 02:00:22.512 - info: backitup.0 (29506) cleaned everything up...
      2020-08-30 02:00:22.610 - info: backitup.0 (29506) terminating
      2020-08-30 02:00:22.618 - info: backitup.0 (29506) Terminated (NO_ERROR): Without reason
      2020-08-30 02:00:23.179 - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2020-08-30 02:00:23.179 - error: host.iobroker Caught by controller[0]: Error: Rate Limit Exceeded
      2020-08-30 02:00:23.180 - error: host.iobroker Caught by controller[0]: at Gaxios._request (/opt/iobroker/node_modules/gaxios/src/gaxios.ts:117:15)
      2020-08-30 02:00:23.180 - error: host.iobroker Caught by controller[0]: at runMicrotasks ()
      2020-08-30 02:00:23.180 - error: host.iobroker Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2020-08-30 02:00:23.181 - error: host.iobroker Caught by controller[0]: at OAuth2Client.requestAsync (/opt/iobroker/node_modules/google-auth-library/build/src/auth/oauth2client.js:343:18)
      2020-08-30 02:00:23.181 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2020-08-30 02:00:23.181 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
      2020-08-30 02:00:53.215 - info: host.iobroker instance system.adapter.backitup.0 started with pid 20496
      2020-08-30 02:00:59.012 - info: backitup.0 (20496) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
      2020-08-30 02:00:59.113 - info: backitup.0 (20496) [iobroker] backup was activated at 02:00 every 1 day(s)
      2020-08-30 02:00:59.138 - info: backitup.0 (20496) [ccu] backup was activated at 01:30 every 1 day(s)
      Scheint, die 1.61 hat das Problem doch nicht vollständig behoben...
      simatec apollon77 2 Replies Last reply Reply Quote 0
      • simatec
        simatec Developer Most Active @passuff last edited by
        @passuff
        Bitte Files aus der Cloud mal löschen und dann erneut testen. Ich denke du hast zuviele Backups in der Cloud liegen und dementsprechend viele Anfragen
          Thomas Braun Most Active @simatec last edited by
          @passuff Nimm mal eine 'krumme' Uhrzeit. 01:28 oder sowas.
          • simatec
            Ab sofort steht die version 1.6.2 auf Github und in kürze auch im latest zur Verfügung ...
            Changelog
            1.6.2 (31.08.2020)
            • (simatec) added whatsapp-cmb support for notifications
              apollon77 @passuff last edited by
              @passuff Ist es bei dir reproduzierbar? Kannst Du bitte mal ein Debug Log machen und schicken?
              • simatec
                Ab sofort ist die version 1.6.3 auf Github und in kürze auch im latest verfügbar.
                Changelog
                1.6.3 (01.09.2020)
                • (simatec) dependencies for googleapis updated
                • (simatec) dependencies for dropbox-v2-api updated
                • (simatec) devdependencies updated
                PS: Für alle, die mit Google Drive Probleme hatten, bitte mal die Version intensiv testen und bei Fehlern bitte den Debug Log posten.
                  passuff @apollon77 last edited by
                  @apollon77
                  Seit zwei Tagen ohne Fehler. Ich vermute, es lag tatsächlich an der Anzahl der backups (5).
                  Soll ich wieder auf 5 gehen und die 1.6.3 installieren?
                  • simatec
                    @passuff
                    Ja bitte gehe mal wieder höher ... Eventuell hat Google den Bug nun fixen können.
                    Aber um sicher zu gehen, sollten wir das nochmal testen ...
                    • Negalein
                      Negalein Global Moderator @simatec last edited by
                      @simatec sagte in Test Adapter Backitup v1.6.x:
                      funktioniert bei mir nicht.
                      Such gerade noch das Log raus.
                      • simatec
                        simatec Developer Most Active @Negalein last edited by
                        @Negalein sagte in Test Adapter Backitup v1.6.x:
                        nicht
                        Bitte debug log und natürlich auch vorher den whatsapp-cmb Adapter konfigurieren ...
                        • Negalein
                          Negalein Global Moderator @simatec last edited by Negalein
                          Whatsapp-cmb ist konfiguriert.
                          Hier das Log von gestern.
                          2020-08-31 23:14:55.249  - info: whatsapp-cmb.0 (28256) Send BackItUp:
                          Ein neues iobroker Backup wurde am 31. August 2020 um 23:14 Uhr erstellt, und nach www27.xxxxxxxx.com/backupDir/minimal via Ftp kopiert/verschoben und in der Dropbox gespeichert. to +43680xxxxxxx
                          2020-08-31 23:14:55.249  - debug: whatsapp-cmb.0 (28256) Call https://api.callmebot.com/whatsapp.php?phone=+43680xxxxxxx&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2031.%20August%202020%20um%2023%3A14%20Uhr%20erstellt%2C%20und%20nach%20www27.xxxxxxxx.com%2FbackupDir%2Fminimal%20via%20Ftp%20kopiert%2Fverschoben%20und%20in%20der%20Dropbox%20gespeichert.&apikey=xxxxxx&source=iobroker
                          2020-08-31 23:14:55.624  - debug: whatsapp-cmb.0 (28256) <p>Message to: +43680xxxxxxx<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 31. August 2020 um 23:14 Uhr erstellt, und nach www27.xxxxxxxx.com/backupDir/minimal via Ftp kopiert/verschoben und in der Dropbox gespeichert.<p><b>Message queued.</b> You will receive it in a few seconds.
                          Direkt über den angegebenen Link funktionierte die Nachricht.
                          Direkt von Backit kam nichts.
                          K simatec 2 Replies Last reply Reply Quote 0
                            Kueppert @Negalein last edited by
                            @Negalein willst deine Handynummer nicht "schwärzen" ? ^^
                            • simatec
                              simatec Developer Most Active @Negalein last edited by simatec
                              @Negalein
                              Hab gerade nochmal getestet ... Die Meldung kommt so ca. 20 Sekunden versetzt ... Was aber nicht mit backitup zu tun hat.
                              Zeige mal die Whatsapp Config in Backitup und den debug log von backitup
                              • Negalein
                                Negalein Global Moderator @Kueppert last edited by
                                @Kueppert sagte in Test Adapter Backitup v1.6.x:
                                Upps, falsches Log kopiert. Danke für den Hinweis.
                                Ich auch gerade nochmal.
                                Jetzt hat es funktioniert. Die Nachricht von Gestern ist noch immer nicht gekommen. Wird im Nirvana verschollen sein.
                                  @passuff Falls Du ne Idee hast wieviele Files da lagen pack nochmal welche rein das wir den fehler ggf nochmal sehen 🙂
                                    @apollon77
                                    Es waren 5 files. Ich habe diese wiederhergestellt. Ich werde berichten.
                                      passuff @passuff last edited by
                                      Heute nacht lief das Backup problemlos durch... Sieht für mich erst mal gelöst aus. Ich berichte sobald sich was ändert.
                                      Danke !
                                      • mickym
                                        mickym Most Active @simatec last edited by
                                        @simatec Ich habe mal auf die neueste Version aktualisiert - da ich auch das Problem habe, dass die zigbee backups nicht nach konfigurierter Anzahl gelöscht werden. Bei mir sind 30 eingestellt. Ich dachte, ich hätte gelesen, dass das Problem schon mal thematisiert wurde und dachte das sei mittlerweile gelöst - aber dem scheint nicht so - oder sollte die älteren Updates nicht automatisch gelöscht werden. Bei den normalen mysql und iobroker backups funktioniert es.
                                        • simatec
                                          simatec Developer Most Active @mickym last edited by
                                          @mickym
                                          Versuche mal bitte die Version 1.6.4 von Github. Habe versucht da mal was zu fixen, kann es aber selber aktuell leider nicht testen
                                          • simatec
                                            Ab sofort steht die version 1.6.4 auf Github und in kürze auch im latest zur Verfügung ...
                                            Changelog
                                            1.6.4 (04.09.2020)
                                            • (simatec) small fixes for sentry.io
                                            • (simatec) small fixes on zigbee backup
                                            170
                                            2780
                                            2345497
