    5. Waschmaschine
    Waschmaschine
    • Slowman
      Slowman @Asgothian last edited by Slowman
      @Asgothian
      So, denke mal das es so passt. Den Wert Stromkosten holt er sich jetzt nur noch aus dem Datenpunkt. Den Rest habe ich umgeändert.
      Screenshot_2020-08-30 javascript - ioBroker(5).png Screenshot_2020-08-30 javascript - ioBroker(6).png
        <variables>
          <variable id="ZM0_}Z7tdRGw|OEboSUb">Geschirrspüler Start</variable>
          <variable id="eA~.c[yxGq8R8{!f%:h#">Geschirrspüler Ende</variable>
          <variable id="mB|+S;|3QAoN;5)#v~5u">Startzeit</variable>
          <variable id="Hhe!Hg(xh7gHuy(6hLlx">Geschirrspueler_EinAus</variable>
          <variable type="timeout" id="timeout4">timeout4</variable>
          <variable id="Y6O#H}N0!M,ytg,|2#=p">EndZeit</variable>
          <variable id="E!Psgr8)b[wT9RI9HC[">Dauer</variable>
          <variable type="timeout" id="timeout2">timeout2</variable>
          <variable id="6zR3cy!$c$@HV6PVyN2!">Stromverbrauch pro Waschgang</variable>
          <variable id="A/ePxr2pS]eX9Gqw8qOT">Stromkosten pro Waschgang</variable>
        </variables>
        <block type="variables_set" id="iv@mYR:]_^Upop_#qFH;" x="838" y="-62">
          <field name="VAR" id="ZM0_}Z7tdRGw|OEboSUb">Geschirrspüler Start</field>
            <block type="math_number" id="8cbWw~V?WpG?Ccg#quGr">
              <field name="NUM">0</field>
            <block type="variables_set" id="VK~5i!)A9wx1YlVROhEu">
              <field name="VAR" id="eA~.c[yxGq8R8{!f%:h#">Geschirrspüler Ende</field>
                <block type="math_number" id="bNEma8]R^c,:H*N9q#W_">
                <block type="variables_set" id="UgHqqacY6TM}7wOP;wsy">
                  <field name="VAR" id="mB|+S;|3QAoN;5)#v~5u">Startzeit</field>
                    <block type="math_number" id=")00MK5w]q^f%?v+:k60k">
                    <block type="variables_set" id="i@;~wXOo)(5+=$9v:QF">
                      <field name="VAR" id="Hhe!Hg(xh7gHuy(6hLlx">Geschirrspueler_EinAus</field>
                        <block type="logic_boolean" id="stD7DD67D[4(YSQ3dCvR">
                        <block type="on_ext" id="%l??Ns0%ZOhlZQJn)RIY">
                          <value name="OID0">
                            <shadow type="field_oid" id="8p+iN2CjzC1M$2o|Xq=m">
                              <field name="oid">shelly.0.SHPLG-S#F8C02D#1.Relay0.Power</field>
                            <block type="controls_if" id="-4y,4m5H68[U,UjJH(0">
                                <block type="logic_operation" id="-^U__L=#GGG_LD~6o~hg" inline="false">
                                  <field name="OP">AND</field>
                                  <comment pinned="false" h="84" w="432">Falls Maschinengang erkannt (Wattzahl &gt;200) UND Modus ist auf falsch dann starte und schreibe den aktuellen verbrauch in den Datenpunkt</comment>
                                    <block type="logic_compare" id="-%Kg)H+S;{}Yyd@cqe=l">
                                      <field name="OP">GTE</field>
                                        <block type="on_source" id="QS5)==Ahwtfe.nNTlR@">
                                        <block type="math_number" id="OT1x**T)z3hCtGxhqDDI">
                                          <field name="NUM">100</field>
                                    <block type="logic_compare" id=",LW++gUB/lbO[yiNJdv">
                                      <field name="OP">EQ</field>
                                        <block type="variables_get" id="[$/1md}o9xogfLp!}WA">
                                        <block type="logic_boolean" id="V}KP*,b;J,.3q802Q0l^">
                                <block type="variables_set" id="HHIFm}6:U#VVrIRv7e|">
                                    <block type="logic_boolean" id="%.!o$LmcZOm0##5WWoJ">
                                    <block type="comment" id="#niZnE_tgmb6Kk@Fr$fl">
                                      <field name="COMMENT">Falls ein Programm ein paar Stunden vorher gestartet wurde sieht man wenn ob die Maschine Startet</field>
                                        <block type="telegram" id="n~A-iElr}zQGmh%dFiiq">
                                          <field name="LOG"></field>
                                          <value name="MESSAGE">
                                            <shadow type="text" id="Wo1gRgI.3j=lL!S+j/dX">
                                              <field name="TEXT">Geschirrspüler läuft jetzt</field>
                                          <value name="USERNAME">
                                            <block type="text" id="BW6HWl3D$1GxO~]!7=|/">
                                              <field name="TEXT">Frank</field>
                                            <block type="variables_set" id=":|$gI;wDf+V^N6RD,#T%">
                                                <block type="get_value" id="b$lgvB*z^u:a@_hX4hL]">
                                                  <field name="OID">shelly.0.SHPLG-S#F8C02D#1.Relay0.Energy</field>
                                                <block type="comment" id="~kES-^z;=BjbpxXK9yo}">
                                                  <field name="COMMENT">Startzeit speichern zur Berechnung der gesamt Laufzeit</field>
                                                    <block type="variables_set" id="wN^[UA.lTmij81cgn#[@">
                                                        <block type="time_get" id="!~RJI|{hH)+qo._Sk]q;">
                                                          <field name="OPTION">mid</field>
                              <value name="IF1">
                                <block type="logic_operation" id="[:7QWv4Op8S6o@lG45(y" inline="false">
                                    <block type="logic_operation" id="Y(DY5TjFzyX=D_%6;##7" inline="false">
                                      <comment pinned="false" h="49" w="563">Falls der Verbrauch vorher grösser 3 Watt ist dun dann unter 2.9 fällt und der Modus ist Wahr dann beende den Waschmodus.</comment>
                                        <block type="logic_compare" id="ydDpT$dnoB]3iV0{BiSL">
                                            <block type="on_source" id="TI;SFi6{]mr@]Ir[QtYg">
                                              <field name="ATTR">oldState.val</field>
                                            <block type="math_number" id="wCZMQjlh5X9NCvvT5hm">
                                              <field name="NUM">4</field>
                                        <block type="logic_compare" id="igy_8vlVI|k$sL-O!Ya">
                                          <field name="OP">LT</field>
                                            <block type="on_source" id="oKi^o%$Qa%i0^MVE?s)Y">
                                            <block type="math_number" id="bx}yjZ_C7J2#/$NzLoS">
                                              <field name="NUM">3.9</field>
                                    <block type="logic_compare" id="}A,!m2TVXL.^LQWg%!e|">
                                        <block type="variables_get" id="r/rnzWL?1!/.2!+pr@5(">
                                        <block type="logic_boolean" id="S,c^%FKOd(.(Q(BL!=g">
                              <statement name="DO1">
                                <block type="comment" id="l_UxyF[7l.W[9+KCjUzR">
                                  <field name="COMMENT">Zusätzliches Timeout "Wenn für 3 Minuten weniger wie 2 Watt verbraucht werden ist die Maschine Fertig</field>
                                    <block type="timeouts_settimeout" id="FT-Aebrk1nQxA(D0}bjX">
                                      <field name="NAME">timeout4</field>
                                      <field name="DELAY">58</field>
                                        <block type="controls_if" id="z#h:Sgr$YhLz;/sJ:;q+">
                                            <block type="logic_operation" id="k8k9;Ypy[xEoy_mm2)_">
                                              <comment pinned="false" h="80" w="160">Falls Verbrauch unter 3 Watt fällt und der Modus ist Wahr dann beende den Waschmodus.</comment>
                                                <block type="logic_compare" id="kgv@}Wxf%H71-6[LoA2">
                                                    <block type="get_value" id="p,SxCr5G+PUY,ToS?g64">
                                                      <field name="OID">shelly.0.SHPLG-S#F8C02D#1.Relay0.Power</field>
                                                    <block type="math_number" id="OqAYX/y!j21Y]dVWdJ82">
                                                <block type="logic_compare" id="7k@eXCwx[(!$|iKjlX?">
                                                    <block type="variables_get" id="_DQp6uLs##,TQ84hTu,X">
                                                    <block type="logic_boolean" id="m[z$R3x+t7q:t3NePYda">
                                            <block type="variables_set" id="qp?4+EqX93)A7YpT,6t">
                                              <field name="VAR" id="Y6O#H}N0!M,ytg,|2#=p">EndZeit</field>
                                                <block type="time_get" id="GGpCtGnJ^|XKC8!mS_S">
                                                <block type="variables_set" id="%6t-7+/fnYOGIfAn+5qZ">
                                                  <field name="VAR" id="E!Psgr8)b[wT9RI9HC[">Dauer</field>
                                                    <block type="math_arithmetic" id="weAo4py)IC-58@is52Cg">
                                                        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="i0wQ=PLCNBKJc5hpz7w7">
                                                          <field name="NUM">1</field>
                                                        <block type="variables_get" id="BzJhg};$iBly2m!o}f">
                                                        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=":dsZj_obi1eBcP%hJC">
                                                        <block type="variables_get" id="(j[-tV+kr]?e7G1s}-m4">
                                                    <block type="variables_set" id="vj!Vu=sDr5yt.:ZU#OfU">
                                                        <block type="logic_boolean" id="5xCJ(QRB3mIo5.f1Fsg">
                                                        <block type="variables_set" id="w5M[qUK=HD;mzLUoU@hK">
                                                            <block type="get_value" id="}_}=j6pEBm+0afN/394(">
                                                            <block type="controls_if" id="RMHH_kch:3FQxQaWZ]lG">
        <block type="logic_compare" id="aQAt;O+zWr%|HvV+j=P;">
        <field name="OP">GT</field>
        <block type="variables_get" id="Diq%z$U$)7AU#3nVC$@T">
        <block type="math_number" id="?yyDu7by5#NGlcmd1pve">
        <field name="NUM">2</field>
        <block type="timeouts_settimeout" id=",NjGW@Wtt+n7RKNkcxK!">
        <field name="DELAY">5</field>
        <block type="comment" id="P5Kh.,h#^UMV[v9Yzkh">
        <field name="COMMENT">Daten Schreiben für History Verbrauch pro Waschgang</field>
        <block type="variables_set" id="SX5GEsOAo0@yW:@TRwa.">
        <field name="VAR" id="6zR3cy!$c$@HV6PVyN2!">Stromverbrauch pro Waschgang</field>
        <block type="math_arithmetic" id="MHdw2]y[BCS~xV|[m3_T">
        <field name="OP">DIVIDE</field>
        <shadow type="math_number" id=";x*EJIT-UHcl7Q0j{G#U">
        <block type="math_rndfixed" id="%DceoHsJ1|2ktnX;ik;Y">
        <field name="n">2</field>
        <value name="x">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="}[m8CJ[~.H(X2Ez)$MNC">
        <field name="NUM">3.1234</field>
        <block type="math_arithmetic" id="B1^}sQT!K1/]T@W1L[xe" inline="false">
        <block type="get_value_var" id="NE:F^hWocTr{gUS)^@+C">
        <value name="OID">
        <shadow type="text" id="3,LTg[wy.`^G94cq1a9U">
        <field name="TEXT"></field>
        <block type="variables_get" id="nFN@SA]Ly$)Yxe1!haUM">
        <shadow type="math_number" id=")KC,Lt~MMGdb=v/v*dsR">
        <block type="get_value_var" id="UjRGZ[Ue75(_M[ns82He">
        <value name="OID">
        <shadow type="text">
        <block type="variables_get" id="{|N8PR7|_,8J=eXQy:zw">
        <shadow type="math_number" id="HI4EdrTO/8H*p;STQrM">
        <field name="NUM">1000</field>
        <block type="comment" id="gigTfir/Q3o9S2gzD{90">
        <field name="COMMENT">Ausrechnen der Stromkosten für diesen Waschgang und in den Datenpunkt schreiben</field>
        <block type="variables_set" id="O#@cdr5/Wy!Z2G_`7AO7">
        <field name="VAR" id="A/ePxr2pS]eX9Gqw8qOT">Stromkosten pro Waschgang</field>
        <block type="math_rndfixed" id="}:X/;ygx%4P%rz05DOma">
        <field name="n">4</field>
        <value name="x">
        <block type="math_arithmetic" id="8~CdvibGo?t^vfDF.ry">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=";xEJIT-UHcl7Q0j{G#U">
        <block type="math_arithmetic" id="jk_su~s;-F0M0+89zf6!">
        <shadow type="math_number" id=";xEJIT-UHcl7Q0j{G#U">
        <block type="get_value_var" id="prkh^UeeTL-n$}%VsXjN">
        <value name="OID">
        <block type="variables_get" id="9aTw2Fq6Ee*]bt,IM:Mz">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id=")KC,Lt~MMGdb=v/vdsR">
        <block type="get_value" id="C2GwSFjOKe-T0-p9HB0">
        <field name="OID">0_userdata.0.Eigener_Datenpunkt.WaschmaschineVerbrauchKosten.Preis_KW</field>
        <shadow type="math_number" id="k|9t!~JsdR/2hn,.Ta~.">
        <block type="comment" id="wF!c?,7;T=c_:f5E$ca%">
        <field name="COMMENT">Alexa Benachrichtung</field>
        <block type="control" id="w3DS%f?P5Y+pO7;1V~SB">
        <field name="OID">alexa2.0.Echo-Devices.5f894234bce346edbb4a1adce0045f99.Commands.speak</field>
        <block type="text" id="vtK95A?T0Tj#c5DEZ[5~">
        <field name="TEXT">50;Geschirrspüler ist fertig</field>
        <block type="comment" id="@dC$^axcVYkgm8#naev1">
        <field name="COMMENT">Nachricht über Telegramm</field>
        <block type="telegram" id=":)Sqh|eio_J%+h7Q@6nJ">
        <shadow xmlns="http://www.w3.org/1999/xhtml" type="text" id="zaE.r=+WylppU_4Nmdx~">
        <field name="TEXT">Waschmaschine ist fertig</field>
        <block type="text_join" id="3,~.TJZeugM.!B%S1^X}">
        <mutation items="13"></mutation>
        <value name="ADD0">
        <block type="text" id="|9?4%icsy2}Q088ry:q">
        <field name="TEXT">😎😎😎 Die Geschirrspüler ist Fertig. 😎😎😎</field>
        <value name="ADD1">
        <block type="time_get" id="a?D^RPe+s+Si=kkfgj[">
        <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
        <field name="OPTION">custom</field>
        <field name="FORMAT">\n</field>
        <value name="ADD2">
        <block type="text" id="grfj-@D75~7#;4n|Zja">
        <field name="TEXT">Dauer: </field>
        <value name="ADD3">
        <block type="variables_get" id="n.X3BETU_{qnfXV+E~:">
        <value name="ADD4">
        <block type="text" id="hB0LeD{cRvcWSjG+y.+=">
        <field name="TEXT"> Minuten.</field>
        <value name="ADD5">
        <block type="time_get" id="cA93H,ih=ovnjMRR4?Q6">
        <value name="ADD6">
        <block type="text" id="iq5TjK!:5+gf]#fZ42]">
        <field name="TEXT">Verbrauch: </field>
        <value name="ADD7">
        <shadow type="math_number" id="}[m8CJ[~.H(X2Ez)$MNC">
        <block type="math_rndfixed" id="F$p9}8[w8:T(m=e~CovU">
        <value name="x">
        <shadow type="math_number" id="RA,BraD%kOetT,YHoI^E">
        <block type="get_value_var" id="m3kCO;qi/UVymfMc-a^S">
        <value name="OID">
        <block type="variables_get" id="itHxUmSztiKq#*Ks;J@g">
        <value name="ADD8">
        <block type="text" id="Gq}sI5FR]paEBl+;3+e">
        <field name="TEXT">kWh.</field>
        <value name="ADD9">
        <block type="time_get" id="Y::7Q};)~]J%;pazFL$-">
        <value name="ADD10">
        <block type="text" id=":9AW!oL(k/~DAOIvpo.B">
        <field name="TEXT">Kosten:</field>
        <value name="ADD11">
        <block type="math_rndfixed" id=",4=#-lGzI:f:Ap/,[n?9">
        <value name="x">
        <shadow type="math_number" id="xB4np%~c;TqHj([{.Tdr">
        <block type="get_value_var" id="||^gpO+zJzH_~C;0aP*_">
        <value name="OID">
        <block type="variables_get" id="}++0hy7-PR)Tb-8D|:)p">
        <value name="ADD12">
        <block type="text" id="Mjs)p.:/ObS*R{2tiwa7">
        <field name="TEXT">€</field>
        <block type="text" id="F-U1oN3NElzVk6CJ);7R">
        <block type="timeouts_settimeout" id="5eCX;s4%zZGWS;Kg_9D1">
        <field name="DELAY">40</field>
        <block type="variables_set" id="3p2f0I240p9[+F;-I-k/">
        <block type="math_number" id="pEblBF9FjJdAXjifbc)">
      Oder was faslch umgesetzt?
      Muss jetzt bloss mal schaune, das ich ein wenig Geschirr dreckig mache 😊
      • Asgothian
        Asgothian Developer @Slowman last edited by Asgothian
        @Slowman
        das ist soweit ok. Aber:
        Die Werte werden möglicherweise weiter nicht passen:
        Die Werte in dem Screenshot oben kommen ja von den jeweiligen "Energy" Datenpunkten deiner Energiemessung. Und da sieht man:
        Waschmaschine: Anfang 99.43, Ende 99.15. - Delta 0.4
        Spülmaschine: Anfang 119345, Ende 159382 - Delta 40000
        Wenn ich mir die Faustregel "Ein Waschgang kostet im Schnitt ca. 30 cent" anschaue, dann scheint die Waschmaschine den Energiewert in kW anzugeben während bei der Spülmaschine eher Watt angegeben sind.
        Du musst also nachschauen in welchen Einheiten deine Energiemessung stattfindet. Nur wenn da auch vergleichbare Einheiten genutzt werden kannst du identische Skripte nutzen. Ansonsten musst du die Formel hier anpassen: Screen Shot 2020-08-30 at 12.08.15 .png
        A.
        Slowman 1 Reply Last reply Reply Quote 1
        • Slowman
          @Asgothian
          Danke, man eh darauf bin ich nicht gekommen 🙄
          Sind beides Shellys, da denkt man an so was nicht.
          Slowman 1 Reply Last reply Reply Quote 0
          • Slowman
            Slowman @Slowman last edited by
            @Asgothian
            Muss doch irgendwo ein Fehler sein 🙄
            • Asgothian
              @Slowman Stimmt.. lesen hilft..
              bei diesen Bausteinen muss das "wert von" weg..
              Statt dessen einfach "Stromverbrauch pro Waschgang" nehmen.
              Das gleiche überall da wo mit der Variable rechnen willst.
              A.
              • Slowman
                @Asgothian
                Danke, habe es jetzt abgeändert.
                • Asgothian
                  @Slowman so sollte es passen
                  • Slowman
                    @Asgothian
                    Mit dem niedrigen KW Anzeige, kenne ich den Fehler. Aber warum der Preis 0,00€ nicht. Schaut noch mal einer rüber.
                    • Asgothian
                      @Slowman Das Skript macht genau das was es soll.
                      Wenn ich die Daten aus dem Objektbaum-Screenshot ansetze, dann ist
                      verbrauch * Stromkosten / 1000 = 0.11 * 26.19 / 1000 = 0.0028809. Das auf 2 Nachkommastellen gerundet ist.. 0 🙂
                      A.
                      • Slowman
                        @Asgothian
                        Oh man, die Rechnung verstehe ich. Das ist jetzt Waschmaschine, wo der auch falsch rechnet.
                        Ich kommt nicht drauf, wa sich ändern muss 🙄
                        • Asgothian
                          @Slowman Du musst dir anschauen warum die in dem Screenshot markierten Werte so unterschiedlich sind. Ich gehe davon aus das es an der verwendeten Mess-Hardware bzw. deren Einstellungen liegt.
                          Da kann ich Dir nur helfen wenn wir da gemeinsam drauf schauen.1598776648945-screenshot_2020-08-30-objects-iobroker-1.png
                          • Slowman
                            @Asgothian
                            Ich habe die Shelly alle jetzt nochmal aufgesetzt und die obigen Punkte alle gelöscht, außer den Datenpunkt Preis_KW. Diese anderen Punkte brauche ich doch nicht mehr? Variable "Geschirrspüler Start" "- Stop" zählt doch dies oder auch einen Denkfehler.
                            Strompreis verlinkt.
                            • Asgothian
                              @Slowman Das stimmt. Allerdings musst du schauen das die Werte bei Spülmaschine und Waschmaschine zumindest in der gleichen Grössenordnung sind. Dann kannst du die Formeln in den Skripten anpassen.
                              A.
                              • Slowman
                                @Asgothian
                                Danke für die Antwort.
                                Wenn wir jetzt von den Datenpunkten Verbrauch ausgehen (Bild 3.Postings über meins). Brauche ich bei WaMa kein /1000 , da es ja in KW angezeigt wird und bei Geschirrspüler ist bei den Datenpunkte der "Wurm" drin. Watt kann ja die Anzeige auch nicht sein /1000 und deziWatt /100000. Mal sehen und beobachten. Ich werde mal eine 60W Birne ran hängen, geht bestimmt schneller als immer zu warten, bis sie läuft 😊
                                • Xenon
                                  Xenon Forum Testing Developer last edited by
                                  Vielleicht wäre das für den ein oder anderen hier noch was, mein neustes Projekt zu genau dem Thema hier. Steht noch ziemlich am Anfang. Kostenberechnung ist noch nicht mit drin ..
                                  https://forum.iobroker.net/topic/36531/vorl-gerätezustandsüberw-benachrichtigung-bei-start-ende
                                  blockly
                                  16
                                  109
                                  10157
