    4. nach update von dem js-controller fehler
    UNSOLVED nach update von dem js-controller fehler
      Ragnar-Lodbrok last edited by
      ich überwache wann die Waschmaschiene fertig ist, was bis jetzt immer wunderbar ging.
      Seit dem Update des JS habe ich diesen Fehler:
      Was ist at Object.<anonymous> ?
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at processImmediate (timers.js:658:5)
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at tryOnImmediate (timers.js:676:5)
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at runCallback (timers.js:705:18)
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
      javascript.0	2020-09-02 17:27:24.219	error	(16965) at Object.<anonymous> (script.js.System-intern.Waschmaschine:8:80)
      javascript.0	2020-09-02 17:27:24.218	error	(16965) at script.js.System-intern.Waschmaschine:8:19
      javascript.0	2020-09-02 17:27:24.218	error	(16965) Error in callback: ReferenceError: unbenannt is not defined
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at process.topLevelDomainCallback (domain.js:126:23)
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at processImmediate (timers.js:658:5)
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at tryOnImmediate (timers.js:676:5)
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at runCallback (timers.js:705:18)
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5384:37)
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:451:25)
      javascript.0	2020-09-02 17:25:40.209	error	(16965) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1052:38)
      javascript.0	2020-09-02 17:25:40.208	error	(16965) at Object.<anonymous> (script.js.System-intern.Waschmaschine:8:80)
      javascript.0	2020-09-02 17:25:40.208	error	(16965) at script.js.System-intern.Waschmaschine:8:19
      javascript.0	2020-09-02 17:25:40.208	error	(16965) Error in callback: ReferenceError: unbenannt is not defined
      javascript.0	2020-09-02 17:24:12.214	error	(16965) at process.topLevelDomainCallback (domain.js:126:23)
      javascript.0	2020-09-02 17:24:12.213	error	(16965) at processImmediate (timers.js:658:5)
      javascript.0	2020-09-02 17:24:12.213	error	(16965) at tryOnImmediate (timers.js:676:5)
      javascript.0	2020-09-02 17:24:12.213	error	(16965) at runCallback (timers.js:705:18)
        paul53 @Ragnar-Lodbrok last edited by
        @Ragnar-Lodbrok
        Was steht in Zeilen 7 und 8 des erzeugten Javascript-Codes ?
                <field name="OP">AND</field>
          <block xmlns="https://developers.google.com/blockly/xml" type="schedule" id="rX*VvB{_?-2wsjy+)f85" x="212" y="412">
            <field name="SCHEDULE">{"time":{"start":"10:00","end":"20:00","mode":"hours","interval":1},"period":{"days":1}}</field>
              <block type="controls_if" id="tgx}w*8Nfo7}3;n,niO^">
                  <block type="logic_operation" id="LnS=VjTC^$~g~:({%166" inline="false">
                      <block type="time_compare_ex" id="Df^%Q70?B)tq;Pa#*mfx">
                        <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                        <value name="START_TIME">
                          <shadow type="text" id="D32Z#J0))0rE6VN8J;]U">
                            <field name="TEXT">11:00</field>
            @Ragnar-Lodbrok
            Nicht XML-Export, sondern erzeugter Javascript-Code.
              sorry 🙂
              (function () {if (timeout) {clearTimeout(timeout); timeout = null;}})();
                @Ragnar-Lodbrok
                Das ist wirklich Zeile 8 ? Ich würde ein getState() erwarten:
                  doch das ist die Zeile.
                    @Ragnar-Lodbrok
                    Prüfe mal den Datenpunkt "CURRENT" bzw. dessen Zuweisung.
                      @Ragnar-Lodbrok
                      Du stoppst timeout, verwendest dann aber timeout2. Stoppe timeout2 !
                      object.anonymous
