    4. ham.homebridge-devolo fehler
    UNSOLVED ham.homebridge-devolo fehler
      Thomas Braun Most Active @BaronT last edited by Thomas Braun
      @BaronT https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      Schau dir Teil 1.1 an.
        BaronT @Thomas Braun last edited by
        @Thomas-Braun Supi Danke. Super Anleitung.👍
        Leider habe ich immer noch die fehlermeldungen.😧
        2020-08-31 23:38:46.027 - error: ham.0 (1394) uncaught exception: Cannot read property 'length' of undefined
        2020-08-31 23:38:46.028 - error: ham.0 (1394) TypeError: Cannot read property 'length' of undefined
        at /opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/Devolo.js:363:47
        at /opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloApi.js:185:17
        at IncomingMessage. (/opt/iobroker/node_modules/iobroker.ham/node_modules/node-devolo/dist/DevoloApi.js:69:21)
        at IncomingMessage.emit (events.js:327:22)
        at endReadableNT (_stream_readable.js:1220:12)
        at processTicksAndRejections (internal/process/task_queues.js:84:21)
        2020-08-31 23:38:46.029 - info: ham.0 (1394) cleaned everything up...
        2020-08-31 23:38:46.047 - warn: ham.0 (1394) Exception: TypeError: Cannot read property 'length' of undefined
        2020-08-31 23:38:46.054 - info: ham.0 (1394) terminating
        2020-08-31 23:38:46.055 - info: ham.0 (1394) Terminated (NO_ERROR): Without reason
        2020-08-31 23:38:46.616 - error: host.raspberrypi Caught by controller[0]: [2020-8-31 23:38:42] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-devolo' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo'.
        2020-08-31 23:38:46.618 - error: host.raspberrypi Caught by controller[1]: [2020-8-31 23:38:42] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
          @BaronT Ich hatte nichts anderes erwartet.
          Da scheint irgendwas doppelt gemoppelt zu sein. Aber vom ham hab ich keine Ahnung.
          Bitte Konsolentext in CodeTags setzen.
            @Thomas-Braun So?
            Mfg Tobi
            2020-09-02 20:17:32.555 - info: host.raspberrypi "system.adapter.ham.0" enabled
            2020-09-02 20:17:32.593 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 4018
            2020-09-02 20:17:33.446 - debug: ham.0 (4018) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-09-02 20:17:33.480 - debug: ham.0 (4018) Objects client ready ... initialize now
            2020-09-02 20:17:33.484 - debug: ham.0 (4018) Objects create System PubSub Client
            2020-09-02 20:17:33.485 - debug: ham.0 (4018) Objects create User PubSub Client
            2020-09-02 20:17:33.486 - debug: ham.0 (4018) Objects client initialize lua scripts
            2020-09-02 20:17:33.500 - debug: ham.0 (4018) Objects connected to redis: 127.0.0.1:9001
            2020-09-02 20:17:33.507 - debug: ham.0 (4018) objectDB connected
            2020-09-02 20:17:33.509 - debug: ham.0 (4018) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-09-02 20:17:33.516 - debug: ham.0 (4018) States create User PubSub Client
            2020-09-02 20:17:33.519 - debug: ham.0 (4018) States create System PubSub Client
            2020-09-02 20:17:33.529 - debug: ham.0 (4018) States connected to redis: 127.0.0.1:9000
            2020-09-02 20:17:33.530 - debug: ham.0 (4018) statesDB connected
            2020-09-02 20:17:33.667 - info: ham.0 (4018) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.3, js-controller: 3.1.6
            2020-09-02 20:17:33.695 - info: ham.0 (4018) Install/Update the following Libraries: homebridge-devolo
            2020-09-02 20:17:33.696 - info: ham.0 (4018) Install/Update homebridge-devolo
            2020-09-02 20:17:33.697 - info: ham.0 (4018) All Libraries installed/updated
            2020-09-02 20:17:35.145 - debug: ham.0 (4018) [2020-9-2 20:17:35] Loaded plugin: homebridge-devolo
            2020-09-02 20:17:35.147 - debug: ham.0 (4018) [2020-9-2 20:17:35] Registering platform 'homebridge-devolo.Devolo'
            2020-09-02 20:17:35.148 - debug: ham.0 (4018) [2020-9-2 20:17:35] ---
            2020-09-02 20:17:35.156 - debug: ham.0 (4018) [2020-9-2 20:17:35] Loading 1 platforms...
            2020-09-02 20:17:35.158 - debug: ham.0 (4018) [2020-9-2 20:17:35] [Devolo] Initializing Devolo platform...
            2020-09-02 20:17:35.163 - debug: ham.0 (4018) [2020-9-2 20:17:35] [Devolo] HBDevoloPlatform > Searching for Devolo Central Unit.
            2020-09-02 20:17:35.177 - debug: ham.0 (4018) [2020-9-2 20:17:35] Loading 0 accessories...
            2020-09-02 20:17:35.253 - debug: ham.0 (4018) Trying to connect to socket.
            2020-09-02 20:17:35.679 - debug: ham.0 (4018) Websocket open
            2020-09-02 20:17:35.687 - debug: ham.0 (4018) [2020-9-2 20:17:35] [Devolo] HBDevoloPlatform > Central Unit found.
            2020-09-02 20:17:36.760 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 20:17:36.761 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 20:17:36.763 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 20:17:36.764 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 20:17:36.765 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 20:17:36.766 - debug: ham.0 (4018) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
            > Model: %s
            > ProductID: %s
            > ProductTypeID: %s
            > Sensors: %s
            2020-09-02 20:17:37.342 - error: ham.0 (4018) uncaught exception: Cannot read property 'length' of undefined
            2020-09-02 20:17:37.343 - error: ham.0 (4018) TypeError: Cannot read property 'length' of undefined
            2020-09-02 20:17:37.344 - info: ham.0 (4018) cleaned everything up...
            2020-09-02 20:17:37.351 - warn: ham.0 (4018) Exception: TypeError: Cannot read property 'length' of undefined
            2020-09-02 20:17:37.357 - info: ham.0 (4018) terminating
            2020-09-02 20:17:37.358 - info: ham.0 (4018) Terminated (NO_ERROR): Without reason
            2020-09-02 20:17:37.931 - error: host.raspberrypi Caught by controller[0]: [2020-9-2 20:17:34] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-devolo' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-devolo'.
            2020-09-02 20:17:37.932 - error: host.raspberrypi Caught by controller[1]: [2020-9-2 20:17:34] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
            2020-09-02 20:17:37.932 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
            2020-09-02 20:17:37.933 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
              BaronT @BaronT last edited by
              2020-09-02 23:13:50.185 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 25036
              2020-09-02 23:13:51.088 - debug: ham.0 (25036) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2020-09-02 23:13:51.127 - debug: ham.0 (25036) Objects client ready ... initialize now
              2020-09-02 23:13:51.131 - debug: ham.0 (25036) Objects create System PubSub Client
              2020-09-02 23:13:51.132 - debug: ham.0 (25036) Objects create User PubSub Client
              2020-09-02 23:13:51.133 - debug: ham.0 (25036) Objects client initialize lua scripts
              2020-09-02 23:13:51.147 - debug: ham.0 (25036) Objects connected to redis: 127.0.0.1:9001
              2020-09-02 23:13:51.153 - debug: ham.0 (25036) objectDB connected
              2020-09-02 23:13:51.156 - debug: ham.0 (25036) Redis States: Use Redis connection: 127.0.0.1:9000
              2020-09-02 23:13:51.163 - debug: ham.0 (25036) States create User PubSub Client
              2020-09-02 23:13:51.166 - debug: ham.0 (25036) States create System PubSub Client
              2020-09-02 23:13:51.188 - debug: ham.0 (25036) States connected to redis: 127.0.0.1:9000
              2020-09-02 23:13:51.189 - debug: ham.0 (25036) statesDB connected
              2020-09-02 23:13:51.419 - info: ham.0 (25036) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.3, js-controller: 3.1.6
              2020-09-02 23:13:51.448 - info: ham.0 (25036) Install/Update the following Libraries: homebridge-plugin-wrapper
              2020-09-02 23:13:51.449 - info: ham.0 (25036) Install/Update homebridge-plugin-wrapper
              2020-09-02 23:13:51.450 - info: ham.0 (25036) All Libraries installed/updated
              2020-09-02 23:13:52.860 - debug: ham.0 (25036) [2020-9-2 23:13:52] Loaded plugin: homebridge-devolo
              2020-09-02 23:13:52.863 - debug: ham.0 (25036) [2020-9-2 23:13:52] Registering platform 'homebridge-devolo.Devolo'
              2020-09-02 23:13:52.864 - debug: ham.0 (25036) [2020-9-2 23:13:52] ---
              2020-09-02 23:13:52.872 - debug: ham.0 (25036) [2020-9-2 23:13:52] Loading 1 platforms...
              2020-09-02 23:13:52.873 - debug: ham.0 (25036) [2020-9-2 23:13:52] [Devolo] Initializing Devolo platform...
              2020-09-02 23:13:52.879 - debug: ham.0 (25036) [2020-9-2 23:13:52] [Devolo] HBDevoloPlatform > Searching for Devolo Central Unit.
              2020-09-02 23:13:52.893 - debug: ham.0 (25036) [2020-9-2 23:13:52] Loading 0 accessories...
              2020-09-02 23:13:52.971 - debug: ham.0 (25036) Trying to connect to socket.
              2020-09-02 23:13:53.038 - debug: ham.0 (25036) Websocket open
              2020-09-02 23:13:53.042 - debug: ham.0 (25036) [2020-9-2 23:13:53] [Devolo] HBDevoloPlatform > Central Unit found.
              2020-09-02 23:13:54.096 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              2020-09-02 23:13:54.097 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              2020-09-02 23:13:54.098 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              2020-09-02 23:13:54.099 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              2020-09-02 23:13:54.100 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              2020-09-02 23:13:54.101 - debug: ham.0 (25036) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
              > Model: %s
              > ProductID: %s
              > ProductTypeID: %s
              > Sensors: %s
              2020-09-02 23:13:54.690 - error: ham.0 (25036) uncaught exception: Cannot read property 'length' of undefined
              2020-09-02 23:13:54.692 - error: ham.0 (25036) TypeError: Cannot read property 'length' of undefined
              at /usr/lib/node_modules/homebridge-devolo/node_modules/node-devolo/dist/Devolo.js:363:47
              at /usr/lib/node_modules/homebridge-devolo/node_modules/node-devolo/dist/DevoloApi.js:185:17
              at IncomingMessage. (/usr/lib/node_modules/homebridge-devolo/node_modules/node-devolo/dist/DevoloApi.js:69:21)
              2020-09-02 23:13:54.693 - info: ham.0 (25036) cleaned everything up...
              2020-09-02 23:13:54.714 - warn: ham.0 (25036) Exception: TypeError: Cannot read property 'length' of undefined
              2020-09-02 23:13:54.726 - info: ham.0 (25036) terminating
              2020-09-02 23:13:54.729 - info: ham.0 (25036) Terminated (NO_ERROR): Without reason
              2020-09-02 23:13:55.276 - error: host.raspberrypi Caught by controller[0]: [2020-9-2 23:13:52] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
              2020-09-02 23:13:55.277 - error: host.raspberrypi Caught by controller[1]: [2020-9-2 23:13:52] Plugin /usr/lib/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
              2020-09-02 23:13:55.278 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
              2020-09-02 23:13:55.279 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
              2020-09-02 23:13:58.241 - info: host.raspberrypi "system.adapter.ham.0" disabled
                @BaronT Da ist was doppelt.
                /usr/lib/node_modules sollte (so) nicht existieren. Mal als root angemeldet und dann iobroker installiert?
                  BaronT @Thomas Braun last edited by BaronT
                  @Thomas-Braun Das möchte ich nicht ausschließen.
                  Kann ich das einfach über die Konsole löschen oder muss ich den iobroker neu installieren?
                    @BaronT Da wäre ich äußerst vorsichtig. Ich würde da vielleicht erstmal nur den Verzeichnisnamen nur umbenennen. Z.B. in node_modules_test oder so. Das kannst du dann leichter wieder korrigieren.
                      @Thomas-Braun Okay dann probiere ich es morgen mal aus.
                        @BaronT Da liegt Zeuch von node bzw. npm drin, aber eigentlich keine Module direkt vom iobroker.
                          @BaronT sagte in ham.homebridge-devolo fehler:
                          Das ist halt auch so ein Grund warum man sich nicht als root direkt anmeldet.
                            @Thomas-Braun Das habe ich mittlerweile auch verstanden, dass man damit viel schaden anrichten kann.😕
                            Aber bei manchen Installationen muss man dies doch machen oder nicht?
                            Wie z.B. bei Node da ging es ohne root meine ich nicht.
                            Aber zurück zum Thema: 😊
                            Ich habe den Ordner unbenannt danach ging npm nicht mehr. Habe alles wieder zurück benannt und habe die Plugins im Ornder gelöscht.
                            Danach bekamm ich im Debug eine fehlermeldung das "homebridge-plugin" nicht im package.json unter keyword steht, habe dort "Homebride-plugin" eingegeben. Dannach hatte ich diese fehlermeldung weg.
                            Jetzt wird mir das im Debug angezeigtt wo ich nicht verstehe, was er mir sagen möchte:
                            2020-09-03 20:14:40.196 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 11044
                            2020-09-03 20:14:41.098 - debug: ham.0 (11044) Redis Objects: Use Redis connection: 127.0.0.1:9001
                            2020-09-03 20:14:41.129 - debug: ham.0 (11044) Objects client ready ... initialize now
                            2020-09-03 20:14:41.132 - debug: ham.0 (11044) Objects create System PubSub Client
                            2020-09-03 20:14:41.134 - debug: ham.0 (11044) Objects create User PubSub Client
                            2020-09-03 20:14:41.135 - debug: ham.0 (11044) Objects client initialize lua scripts
                            2020-09-03 20:14:41.151 - debug: ham.0 (11044) Objects connected to redis: 127.0.0.1:9001
                            2020-09-03 20:14:41.158 - debug: ham.0 (11044) objectDB connected
                            2020-09-03 20:14:41.160 - debug: ham.0 (11044) Redis States: Use Redis connection: 127.0.0.1:9000
                            2020-09-03 20:14:41.167 - debug: ham.0 (11044) States create User PubSub Client
                            2020-09-03 20:14:41.170 - debug: ham.0 (11044) States create System PubSub Client
                            2020-09-03 20:14:41.180 - debug: ham.0 (11044) States connected to redis: 127.0.0.1:9000
                            2020-09-03 20:14:41.181 - debug: ham.0 (11044) statesDB connected
                            2020-09-03 20:14:41.493 - info: ham.0 (11044) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.ham, node: v12.18.3, js-controller: 3.1.6
                            2020-09-03 20:14:41.522 - info: ham.0 (11044) Install/Update the following Libraries: homebridge-devolo
                            2020-09-03 20:14:41.523 - info: ham.0 (11044) Install/Update homebridge-devolo
                            2020-09-03 20:14:41.524 - info: ham.0 (11044) All Libraries installed/updated
                            2020-09-03 20:14:42.965 - debug: ham.0 (11044) [2020-9-3 20:14:42] Loaded plugin: homebridge-devolo
                            2020-09-03 20:14:42.968 - debug: ham.0 (11044) [2020-9-3 20:14:42] Registering platform 'homebridge-devolo.Devolo'
                            2020-09-03 20:14:42.969 - debug: ham.0 (11044) [2020-9-3 20:14:42] ---
                            2020-09-03 20:14:42.985 - debug: ham.0 (11044) [2020-9-3 20:14:42] Loading 1 platforms...
                            2020-09-03 20:14:42.986 - debug: ham.0 (11044) [2020-9-3 20:14:42] [Devolo] Initializing Devolo platform...
                            2020-09-03 20:14:42.992 - debug: ham.0 (11044) [2020-9-3 20:14:42] [Devolo] HBDevoloPlatform > Searching for Devolo Central Unit.
                            2020-09-03 20:14:43.006 - debug: ham.0 (11044) [2020-9-3 20:14:43] Loading 0 accessories...
                            2020-09-03 20:14:43.464 - debug: ham.0 (11044) Trying to connect to socket.
                            2020-09-03 20:14:43.529 - debug: ham.0 (11044) Websocket open
                            2020-09-03 20:14:43.533 - debug: ham.0 (11044) [2020-9-3 20:14:43] [Devolo] HBDevoloPlatform > Central Unit found.
                            2020-09-03 20:14:44.593 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            2020-09-03 20:14:44.594 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            2020-09-03 20:14:44.595 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            2020-09-03 20:14:44.596 - debug: ham.0 (11044) Device > %s < is not supported (yet) or devolo has something changed. Open an issue on github and ask for adding it.
                            > Model: %s
                            > ProductID: %s
                            > ProductTypeID: %s
                            > Sensors: %s
                            2020-09-03 20:14:45.182 - error: ham.0 (11044) uncaught exception: Cannot read property 'length' of undefined
                            2020-09-03 20:14:45.185 - error: ham.0 (11044) TypeError: Cannot read property 'length' of undefined
                            2020-09-03 20:14:45.187 - info: ham.0 (11044) cleaned everything up...
                            2020-09-03 20:14:45.203 - warn: ham.0 (11044) Exception: TypeError: Cannot read property 'length' of undefined
                            2020-09-03 20:14:45.644 - info: ham.0 (11044) terminating
                            2020-09-03 20:14:45.645 - info: ham.0 (11044) Terminated (NO_ERROR): Without reason
                            2020-09-03 20:14:46.180 - error: host.raspberrypi Caught by controller[0]: [2020-9-3 20:14:42] ====================
                            2020-09-03 20:14:46.180 - error: host.raspberrypi Caught by controller[1]: [2020-9-3 20:14:42] ERROR LOADING PLUGIN homebridge-plugin-wrapper:
                            2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: [2020-9-3 20:14:42] Error: Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper does not contain the 'homebridge' package in 'engines'.
                            2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: at Plugin.load (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/plugin.js:49:11)
                            2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: at Server. (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:153:14)
                            2020-09-03 20:14:46.181 - error: host.raspberrypi Caught by controller[2]: at Array.forEach ()
                            2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:145:22)
                            2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:57:24)
                            2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:221:19)
                            2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:111:23)
                            2020-09-03 20:14:46.182 - error: host.raspberrypi Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.ham/main.js:276:39
                            2020-09-03 20:14:46.183 - error: host.raspberrypi Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.ham/main.js:177:27
                            2020-09-03 20:14:46.183 - error: host.raspberrypi Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4008:33
                            2020-09-03 20:14:46.183 - error: host.raspberrypi Caught by controller[3]: [2020-9-3 20:14:42] ====================
                            2020-09-03 20:14:46.184 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
                            2020-09-03 20:14:46.184 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
                              Aber bei manchen Installationen muss man dies doch machen oder nicht? Wie z.B. bei Node da ging es ohne root meine ich nicht.
                              Doch, auch die Installation via apt geht ohne root. sudo davor und gut ist. Unter Debian meldet man sich nie als root an. Der ist ja auch eigentlich gesperrt, aus Gründen.
                              Nach dem Umbenennen hättest du einfach nodeJS nochmal auf das System bügeln können. Aber so scheint es auch zu funktionieren, die Doublette ist wohl weg.
                                @Thomas-Braun said in ham.homebridge-devolo fehler:
                                Achso also nur sudo davor. Ich packe den root nicht mehr an.
                                Jap die ist weg. Kannst du denn erkennen was jetzt nicht richtig läuft?
                                (Anders gefragt ist mein Problem ggf. weg wenn ich alles nochmal neu installiere, also den kompletten Raspberry)
                                Mfg Tobi
                                  @BaronT Von ham habe ich wie gesagt keine Ahnung.
                                  devolo devolo homebridge ham homebridge accessories manager homebridge-devolo
                                  570
