    4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    • Palm_Maniac
      Palm_Maniac @Dutchman last edited by
      @Dutchman
      Hier sind meine:
        "from": "system.host.Server(KuhnHome).cli",
        "ts": 1597074537164,
        "user": "system.user.admin",
        "protectedNative": [],
        "encryptedNative": [],
        "instanceObjects": [],
        "objects": [
            "_id": "_design/custom",
            "language": "javascript",
            "views": {
              "state": {
                "map": "function(doc) { if (doc.type === 'state' && (doc.common.custom || doc.common.history)) emit(doc._id, doc.common.custom || doc.common.history) }"
            "ts": 1597074537164
        "enums": {},
        "common": {
          "name": "sourceanalytix",
          "version": "0.4.5",
          "title": "SourceAnalytix",
          "platform": "Javascript/Node.js",
          "main": "main.js",
          "extIcon": "https://raw.githubusercontent.com/iobroker-community-adapters/ioBroker.sourceanalytix/master/admin/sourceanalytix.png",
          "readme": "https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/blob/master/README.md",
          "loglevel": "warn",
          "mode": "daemon",
          "type": "energy",
          "installedVersion": "0.4.5",
          "host": "Server(KuhnHome)",
          "license": "MIT",
          "installedFrom": "https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/tarball/5d2f40414330ed5bae3bbb675ee9a4cacd34dd72",
          "restartSchedule": "0,15 * * * *",
          "enabled": true,
          "materialize": true,
          "supportCustoms": true,
          "compact": true,
          "news": {
            "0.2.25": {
              "en": "add option in state setting to automatically OR manually choose the meassurement unit",
              "de": "Option in Zustandseinstellung hinzufügen, um die Maßeinheit automatisch ODER manuell auszuwählen",
              "ru": "добавить опцию в настройке состояния, чтобы автоматически или вручную выбрать единицу измерения",
              "pt": "adicione a opção na configuração de estado para automaticamente OU escolha manualmente a unidade de medida",
              "nl": "optie toevoegen in de statusinstelling om automatisch of handmatig de meeteenheid te kiezen",
              "fr": "ajout d'option dans le réglage d'état pour choisir automatiquement OU manuellement l'unité de mesure",
              "it": "aggiungere l'opzione nell'impostazione dello stato automaticamente O selezionare manualmente l'unità di misura",
              "es": "Agregue la opción en la configuración de estado para seleccionar automáticamente O manualmente la unidad de medida",
              "pl": "dodać opcję w ustawieniu stanu, aby automatycznie LUB ręcznie wybrać jednostkę miary",
              "zh-cn": "在状态设置中添加选项以自动或手动选择测量单位"
            "0.2.24": {
              "en": "add support for heating pumps",
              "de": "Unterstützung für Heizungspumpen hinzufügen",
              "ru": "добавить поддержку для тепловых насосов",
              "pt": "adicione suporte para bombas de aquecimento",
              "nl": "voeg ondersteuning toe voor verwarmingspompen",
              "fr": "ajouter un support pour les pompes à chaleur",
              "it": "aggiungere il supporto per le pompe di calore",
              "es": "añadir soporte para bombas de calor",
              "pl": "dodaj wsparcie dla pomp grzewczych",
              "zh-cn": "增加对加热泵的支持"
            "0.2.2": {
              "en": "Final fix for start values, several code improvements",
              "de": "Endfix für Startwerte, verschiedene Code-Verbesserungen",
              "ru": "Окончательное исправление для начальных значений, несколько улучшений кода",
              "pt": "Correção final para valores iniciais, várias melhorias no código",
              "nl": "Laatste fix voor startwaarden, verschillende codeverbeteringen",
              "fr": "Correctif final pour les valeurs de départ, plusieurs améliorations de code",
              "it": "Correzione finale per i valori iniziali, diversi miglioramenti del codice",
              "es": "Arreglo final para valores de inicio, varias mejoras de código",
              "pl": "Ostateczna poprawka wartości początkowych, kilka ulepszeń kodu",
              "zh-cn": "0.2.2起始值的最终修复,几个代码改进"
            "0.2.1": {
              "en": "Several bugs fixed",
              "de": "Mehrere Fehler behoben",
              "ru": "Исправлено несколько ошибок",
              "pt": "Vários bugs corrigidos",
              "nl": "Verschillende bugs verholpen",
              "fr": "Plusieurs bugs corrigés",
              "it": "Diversi errori risolti",
              "es": "Varios errores corregidos",
              "pl": "Naprawiono kilka błędów",
              "zh-cn": "修复了几个错误"
            "0.2.0": {
              "en": "Public Release candidate",
              "de": "Öffentlicher Release-Kandidat",
              "ru": "Публичный релиз кандидата",
              "pt": "Candidato de lançamento público",
              "nl": "Public Release-kandidaat",
              "fr": "Candidat à la diffusion publique",
              "it": "Candidato a rilascio pubblico",
              "es": "Candidato de lanzamiento público",
              "pl": "Kandydat na Public Release",
              "zh-cn": "公开发布候选人"
            "0.1.9": {
              "en": "Preparation of stable 0.2.0, calculation logic and configuration interface redesigned",
              "de": "Vorbereitung von 0.2.0 stabilisiert, Berechnungslogik und Konfigurationsschnittstelle neu gestaltet",
              "ru": "Подготовка стабильной версии 0.2.0, логика расчета и интерфейс конфигурации переработаны",
              "pt": "Preparação do estável 0.2.0, lógica de cálculo e interface de configuração redesenhada",
              "nl": "Voorbereiding van stabiele 0.2.0, berekeningslogica en configuratie-interface opnieuw ontworpen",
              "fr": "Préparation de la version stable 0.2.0, de la logique de calcul et de l'interface de configuration repensés",
              "it": "Preparazione di 0.2.0 stabile, logica di calcolo e interfaccia di configurazione ridisegnata",
              "es": "Preparación de estable 0.2.0, lógica de cálculo y configuración de interfaz rediseñada",
              "pl": "Przygotowanie stabilnego 0.2.0, logika obliczeniowa i interfejs konfiguracyjny przeprojektowany",
              "zh-cn": "准备稳定的0.2.0,重新设计计算逻辑和配置接口"
            "0.1.0": {
              "en": "Public beta release",
              "de": "Öffentliche Betaversion",
              "ru": "публичная бета-версия",
              "pt": "versão beta pública",
              "nl": "Public beta-release",
              "fr": "Version bêta publique 0.1.0",
              "it": "Versione beta pubblica",
              "es": "Public beta pública",
              "pl": "Publiczne wydanie beta",
              "zh-cn": "0.1.0公开测试版"
            "0.0.9": {
              "en": "Prepare Public Beta",
              "de": "Erste öffentliche Beta",
              "ru": "Первая публичная бета",
              "pt": "Primeiro beta público",
              "nl": "Eerste openbare bèta",
              "fr": "Première bêta publique",
              "it": "Prima beta pubblica",
              "es": "Primera beta pública",
              "pl": "Pierwsza publiczna beta",
              "zh-cn": "首次公开测试版"
            "0.2.26": {
              "en": "Fix issue in calculations for gas environments and liquids",
              "de": "Problem in Berechnungen für Gasumgebungen und Flüssigkeiten behoben",
              "ru": "Исправлена ​​ошибка в расчетах для газовых сред и жидкостей.",
              "pt": "Corrigir problema em cálculos para ambientes de gás e líquidos",
              "nl": "Probleem verhelpen bij berekeningen voor gasomgevingen en vloeistoffen",
              "fr": "Correction d'un problème dans les calculs pour les environnements de gaz et les liquides",
              "it": "Risolto il problema nei calcoli per ambienti a gas e liquidi",
              "es": "Solucionar el problema en los cálculos para ambientes de gas y líquidos.",
              "pl": "Napraw problem w obliczeniach dla środowisk gazowych i cieczy",
              "zh-cn": "解决气体环境和液体计算中的问题"
            "0.2.27": {
              "en": "Fixed issue related to multihost installations with slave as target",
              "de": "Problem bei Multihost-Installationen mit Slave als Ziel behoben",
              "ru": "Исправлена ​​проблема, связанная с установкой нескольких хостов с ведомым в качестве цели",
              "pt": "Corrigido problema relacionado a instalações multi-host com escravo como alvo",
              "nl": "Probleem opgelost met multihost-installaties met slaaf als doelwit",
              "fr": "Résolution du problème lié aux installations multihôtes avec esclave comme cible",
              "it": "Risolto il problema relativo alle installazioni multihost con slave come destinazione",
              "es": "Se solucionó el problema relacionado con las instalaciones multihost con esclavo como destino",
              "pl": "Naprawiono problem związany z instalacjami multihost z niewolnikiem jako celem",
              "zh-cn": "修复了与slave作为目标的多主机安装相关的问题"
            "0.2.281": {
              "en": "Calculation w to kWh implemented & several code improvements",
              "de": "Berechnung w bis kWh implementiert & mehrere Code-Verbesserungen",
              "ru": "Выполнен расчет с использованием кВтч и несколько улучшений кода",
              "pt": "Cálculo w para kWh implementado e várias melhorias de código",
              "nl": "Berekening w tot kWh geïmplementeerd & verschillende codeverbeteringen",
              "fr": "Calcul w en kWh mis en œuvre & plusieurs améliorations de code",
              "it": "Calcolo w in kWh implementato e numerosi miglioramenti del codice",
              "es": "Cálculo w a kWh implementado y varias mejoras de código.",
              "pl": "Wprowadzono obliczenia w do kWh i wprowadzono kilka ulepszeń kodu",
              "zh-cn": "计算w到kWh实施和几个代码改进"
            "0.2.41": {
            "0.1.3": {
              "en": "m³ Implemented",
              "de": "m³ umgesetzt",
              "ru": "м³ Реализовано",
              "pt": "m³ implementado",
              "nl": "m³ geïmplementeerd",
              "fr": "m³ mis en œuvre",
              "it": "m³ Implementato",
              "es": "m³ Implementado",
              "pl": "m³ Wdrożony",
              "zh-cn": "已实施m³"
            "0.2.5": {
              "en": "Fix wrong storage of start meter values, thank you xXBJXx",
              "de": "Fehler beim Speichern der Startzählerwerte behoben, danke xXBJXx",
              "ru": "Исправьте неправильное хранение значений стартового счетчика, спасибо xXBJXx",
              "pt": "Corrigir o armazenamento errado dos valores do medidor inicial, obrigado xXBJXx",
              "nl": "Herstel verkeerde opslag van startmeterwaarden, bedankt xXBJXx",
              "fr": "Correction du mauvais stockage des valeurs initiales du compteur, merci xXBJXx",
              "it": "Correggi l'archiviazione errata dei valori del misuratore di avvio, grazie xXBJXx",
              "es": "Arregle el almacenamiento incorrecto de los valores de inicio del medidor, gracias xXBJXx",
              "pl": "Napraw nieprawidłowe przechowywanie początkowych wartości liczników, dziękuję xXBJXx",
              "zh-cn": "修复了启动仪表值的错误存储,谢谢xXBJXx"
            "0.4.1": {
              "en": "Bugfixes",
              "de": "Fehlerbehebung",
              "ru": "Исправление ошибок",
              "pt": "Correções de bugs",
              "nl": "Bugfixes",
              "fr": "Corrections de bugs",
              "it": "Correzioni di bug",
              "es": "Corrección de errores",
              "pl": "Poprawki błędów",
              "zh-cn": "Bug修复"
            "0.4.0": {
              "en": "Adapter completely redesigned, please test carefully",
              "de": "Adapter komplett neu gestaltet, bitte sorgfältig testen",
              "ru": "Адаптер полностью переработан, пожалуйста, проверьте внимательно",
              "pt": "Adaptador completamente redesenhado, teste com cuidado",
              "nl": "Adapter volledig opnieuw ontworpen, test zorgvuldig",
              "fr": "Adaptateur entièrement repensé, veuillez tester soigneusement",
              "it": "Adattatore completamente riprogettato, si prega di testare attentamente",
              "es": "Adaptador completamente rediseñado, por favor pruebe cuidadosamente",
              "pl": "Adapter całkowicie przeprojektowany, proszę przetestować dokładnie",
              "zh-cn": "适配器完全重新设计,请仔细测试"
            "0.3.0": {
              "zh-cn": "已实施m³"
            "0.4.2": {
              "en": "Bugfixes",
              "nl": "Bugfixes",
              "zh-cn": "Bug修复"
            "0.4.5": {
              "en": "Work in progress"
          "titleLang": {
            "en": "SourceAnalytix",
            "de": "SourceAnalytix",
            "ru": "SourceAnalytix",
            "pt": "SourceAnalytix",
            "nl": "SourceAnalytix",
            "fr": "SourceAnalytix",
            "it": "SourceAnalytix",
            "es": "SourceAnalytix",
            "pl": "SourceAnalytix",
            "zh-cn": "SourceAnalytix"
          "desc": {
            "en": "Detailed statistics of your energy, gas and liquid consumption. Allows annual report and details according to weekly, monthly and quarterly consumption data.",
            "de": "Detaillierte Statistiken Ihres Energie-, Gas- und Flüssigkeitsverbrauchs. Ermöglicht Jahresberichte und Details gemäß wöchentlichen, monatlichen und vierteljährlichen Verbrauchsdaten.",
            "ru": "Подробная статистика вашего потребления энергии, газа и жидкости. Позволяет годовой отчет и подробную информацию в соответствии с еженедельными, ежемесячными и квартальными данными потребления.",
            "pt": "Estatísticas detalhadas de seu consumo de energia, gás e líquido. Permite relatório anual e detalhes de acordo com dados de consumo semanais, mensais e trimestrais.",
            "nl": "Gedetailleerde statistieken van uw energie-, gas- en vloeistofverbruik. Staat jaarverslag en details toe op basis van wekelijkse, maandelijkse en driemaandelijkse verbruiksgegevens.",
            "fr": "Statistiques détaillées de votre consommation d'énergie, de gaz et de liquide. Permet un rapport annuel et des détails selon les données de consommation hebdomadaires, mensuelles et trimestrielles.",
            "it": "Statistiche dettagliate sul consumo di energia, gas e liquidi. Consente report e dettagli annuali in base ai dati di consumo settimanali, mensili e trimestrali.",
            "es": "Estadísticas detalladas de su consumo de energía, gas y líquido. Permite informes anuales y detalles según datos de consumo semanal, mensual y trimestral.",
            "pl": "Szczegółowe statystyki zużycia energii, gazu i cieczy. Umożliwia raport roczny i szczegóły zgodnie z tygodniowymi, miesięcznymi i kwartalnymi danymi dotyczącymi zużycia.",
            "zh-cn": "您的能源,气体和液体消耗的详细统计信息。允许根据每周,每月和每季度的消费数据提供年度报告和详细信息。"
          "authors": [
            "DutchmanNL <rdrozda86@gmail.com>"
          "keywords": [
            "energy",
            "power",
            "analytics",
            "consumption",
            "meassurement",
            "data"
          "dependencies": [
              "admin": ">=3.0.0"
              "js-controller": ">=1.4.2"
          "contributors": [
            "xXBJXx"
          "plugins": {
            "sentry": {
              "dsn": "https://2cd80ab3d4b94677b1b513547054e480@sentry.iobroker.net/24"
          "icon": "sourceanalytix.png"
        "native": {
          "keep_days": "7",
          "keep_weeks": "4",
          "keep_quarters": "2",
          "keep_months": "4",
          "keep_years": "1",
          "unit_price_power": "0.238",
          "unit_price_power_night": "",
          "unit_price_power_delivery": "0.1221",
          "basic_price_power": "8.33",
          "unit_price_heatpump": "0.24",
          "unit_price_heatpump_night": "0.22",
          "basic_price_heatpump": "15",
          "unit_price_gas": "0.32",
          "basic_price_gas": "13",
          "unit_price_water": "0.07",
          "basic_price_water": "22",
          "unit_price_oil": "0.12",
          "basic_price_oil": "31",
          "intervall": "5",
          "impuls": 400,
          "store_year": true,
          "store_days": true,
          "store_weeks": true,
          "store_months": true,
          "store_quarters": true,
          "store_years": true,
          "store_period": false,
          "developer_logging": false,
          "status_logging": false,
          "store_periode": true,
          "unitConfig": [
              "uName": "kWh",
              "uDes": "Power kiloWatt hours",
              "uStore": "kWh",
              "uFactor": "1"
              "uName": "w",
              "uDes": "Power watt to kiloWatt hours",
              "uStore": "kWh",
              "uFactor": "1000"
              "uName": "m3",
              "uDes": "Volumes kubieke meters m3 to m³",
              "uStore": "m³",
              "uFactor": "1"
              "uName": "m³ ",
              "uDes": "Volumes kubieke meters m³ ",
              "uStore": "m³",
              "uFactor": "1"
              "uName": "l",
              "uDes": "Volumes liters to kubieke meters m³ ",
              "uStore": "m³",
              "uFactor": "1000"
          "pricesConfig": [
              "uCat": "ElectricityDay",
              "uDes": "Electricity consumption Day price",
              "uPpU": "0,27",
              "uPpM": "15"
              "uCat": "ElectricityDelivery",
              "uDes": "Electricity Delivery Earnings",
              "uPpU": "0,17",
              "uPpM": "15"
              "uCat": "ElectricityNight",
              "uDes": "Electricity consumption Night price",
              "uPpU": "0,24",
              "uPpM": "15"
              "uCat": "Heatpump",
              "uDes": "Heatpomp costs by unit",
              "uPpU": "0,24",
              "uPpM": "31"
              "uCat": "Gas",
              "uDes": "Gas costs by unit",
              "uPpU": "0,12",
              "uPpM": "31"
              "uCat": "Oil",
              "uDes": "Oil costs by unit",
              "uPpU": "0,12",
              "uPpM": "7,38"
              "uCat": "Water",
              "uDes": "Water costs by unit",
              "uPpU": "0,07",
              "uPpM": "22"
          "pricesDefinition": [
              "cat": "ElectricityDay",
              "des": "Electricity consumption Day price",
              "costType": "costs",
              "unitType": "kWh",
              "uPpU": "0.248",
              "uPpM": "10,71"
              "cat": "ElectricityDelivery",
              "des": "Electricity Delivery Earnings",
              "costType": "earnings",
              "unitType": "kWh",
              "uPpU": "0.12",
              "uPpM": "0"
              "cat": "Gas",
              "des": "Gas costs by unit",
              "unitType": "m³",
              "uPpU": "0.12",
              "uPpM": "31"
              "cat": "Water",
              "des": "Water costs by unit",
              "unitType": "m³",
              "uPpU": "0.07",
              "uPpM": "22"
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
        "_id": "system.adapter.sourceanalytix.0",
        "type": "instance"
      • Dutchman
        Dutchman Developer Most Active Administrators @Palm_Maniac last edited by
        @Palm_Maniac sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
        Hier sind meine:
        danke dir, ich sehe hier nix ungewöhnliches was die NULL werte verursachen konnte werde weiter suchen.
        Dei frage an die andere beiden war wegen dem cathegorie Fehler die hätte ich dan gerne noch 🙂
        G coyote 2 Replies Last reply Reply Quote 0
          gerald123 @Dutchman last edited by
          @Dutchman werde es dir senden sobald ich wieder Zuhause bin
          • coyote
            coyote Most Active @Dutchman last edited by
            @Dutchman ich schicke dir auch die RAW Daten, aber dauert noch ca. ne Stunde
            • Palm_Maniac
              Die NULL Werte werden ja immer um Mitternacht erzeugt. Startet man danach den Adapter neu, werden die richtigen Werte eingetragen. Es hat also was mit dem Tageswechsel und dem umkopieren von Werten zu tun, vermute ich.
              D Dutchman 2 Replies Last reply Reply Quote 0
                dtp @Palm_Maniac last edited by
                @Dutchman
                Schön, dass es hier weitergeht. Werde aber lieber erst mal auf die Version 0.5.0 warten. 😉
                • Dutchman
                  Dutchman Developer Most Active Administrators @Palm_Maniac last edited by Dutchman
                  I know, nur das merkwürdige ist das ich im code nicht finde wo der NULL herkommt.
                  Also was ich jetzt vor habe :
                  1. Problem mit cathegorieren
                    Verschiedene user melden Probleme mit bestimmten werte wo im Log der Eintrag kommt "cannot read cathegorie of undefined"
                    Ich vermute hierin eine fehl Konfiguration die entweder vom user oder ersten adapter start kommt.
                  Dafuer brauche ich die raw Objekten um diese zu analysieren
                  1. NULL Fehler nach mitternacht
                    Dieser tritt nicht immer auf, ist dadurch nicht aus Objekten 1:1 identifizierbar.
                    Ich werden in einer niesten beta version, welche die cathegorie Fehler beheben soll, booby trap einbauen damit ich die komplette Loggin und daten (Berechnung/null values usw als report bekomme zur weiteren Analyse.
                  Dafuer brauche ich dan tester wen es soweit ist om debug mäßig die stelle zu finden wo es genau schief geht.
                  Cheers,
                  Dutch
                  @dtp sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                  @Dutchman
                  Be my guest 🙂
                  coyote Palm_Maniac 2 Replies Last reply Reply Quote 0
                  • coyote
                    coyote Most Active @Dutchman last edited by coyote
                    @Dutchman also, ich bekomme diesen Fehler im Log, aber auch nur bei einem bestimmten Datenpunkt.
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at processImmediate (timers.js:658:5)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at tryOnImmediate (timers.js:676:5)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at runCallback (timers.js:705:18)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at Immediate.setImmediate [as _onImmediate] (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5388:34)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at Sourceanalytix.emit (events.js:198:13)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at Sourceanalytix.onStateChange (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:418:11)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:784:26)
                    sourceanalytix.0	2020-09-03 15:37:15.814	error	(21251) [calculationHandler javascript.0.Wasserzaehler.StandAktuell] error: Cannot read property 'toLowerCase' of undefined, stack: TypeError: Cannot read property 'toLowerCase' of undefined
                    Hier die RAW Daten des Datenpunktes:
                      "common": {
                        "name": "javascript.0.Wasserzaehler.StandAktuell",
                        "role": "state",
                        "type": "mixed",
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "changesOnly": true,
                            "debounce": 0,
                            "maxLength": "10",
                            "retention": "31536000",
                            "changesRelogInterval": 0,
                            "changesMinDelta": 0,
                            "aliasId": ""
                          "sourceanalytix.0": {
                            "enabled": true,
                            "alias": "Wasserzaehler",
                            "state_type": "water_m3",
                            "state_unit": "m3",
                            "costs": false,
                            "consumption": true,
                            "meter_values": true,
                            "start_day": 0,
                            "start_week": 0,
                            "start_month": 0,
                            "start_quarter": 0,
                            "start_year": 0
                      "native": {},
                      "type": "state",
                      "ts": 1585067055007,
                      "_id": "javascript.0.Wasserzaehler.StandAktuell",
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                    Der hier funktioniert aber einwandfrei
                      "from": "system.adapter.sourceanalytix.0",
                      "ts": 1598911200350,
                      "common": {
                        "name": "javascript.0.Gaszaehler.Stand",
                        "role": "state",
                        "type": "number",
                        "custom": {
                          "history.0": {
                            "enabled": true,
                            "debounce": 0,
                            "maxLength": "10",
                            "aliasId": ""
                            "enabled": true,
                            "alias": "GasStand",
                            "selectedPrice": "Gasoline",
                            "selectedUnit": "m³",
                            "costs": false,
                            "start_day": 18037.689999986604,
                            "start_week": 18033.449999987282,
                            "start_month": 18034.77999998707,
                            "start_quarter": 17966.449999998007,
                            "start_year": 0,
                            "state_type": "gas",
                            "state_unit": "m3"
                      "native": {},
                      "acl": {
                        "object": 1636,
                        "state": 1636
                      "_id": "javascript.0.Gaszaehler.Stand",
                      "type": "state"
                    Dutchman crunchip 2 Replies Last reply Reply Quote 0
                    • Dutchman
                      Dutchman Developer Most Active Administrators @coyote last edited by
                      @coyote sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                      ok, jetzt brauche ich von dir noch dass RAW object der adapter Instanz wie im anderen post geschrieben (Expertenmodus an, Bleistift auf system....)
                      habe da ne Vermutung woran es liegt wen ich die daten so sehe, kan ich. mit Sicherheit sagen wen ich as andere raw object habe
                      • coyote
                        @Dutchman kein Problem (hatte ich irgendwie überlesen😵 )
                          "type": "instance",
                          "common": {
                            "version": "0.4.2",
                            "news": {
                              "0.1.0": {
                              "0.0.9": {
                                "zh-cn": "首次公开测试版"
                              "0.1.9 Preparation of stable 0.2.0, calculation logic and configuration interface redesigned": {
                                "en": "0.1.9 Preparation of stable 0.2.0, calculation logic and configuration interface redesigned",
                                "de": "0.1.9 Vorbereitung von 0.2.0 stabilisiert, Berechnungslogik und Konfigurationsschnittstelle neu gestaltet",
                                "ru": "0.1.9 Подготовка стабильной версии 0.2.0, логика расчета и интерфейс конфигурации переработаны",
                                "pt": "0.1.9 Preparação do estável 0.2.0, lógica de cálculo e interface de configuração redesenhada",
                                "nl": "0.1.9 Voorbereiding van stabiele 0.2.0, berekeningslogica en configuratie-interface opnieuw ontworpen",
                                "fr": "0.1.9 Préparation de la version stable 0.2.0, de la logique de calcul et de l'interface de configuration repensés",
                                "it": "0.1.9 Preparazione di 0.2.0 stabile, logica di calcolo e interfaccia di configurazione ridisegnata",
                                "es": "0.1.9 Preparación de estable 0.2.0, lógica de cálculo y configuración de interfaz rediseñada",
                                "pl": "0.1.9 Przygotowanie stabilnego 0.2.0, logika obliczeniowa i interfejs konfiguracyjny przeprojektowany",
                                "zh-cn": "0.1.9准备稳定的0.2.0,重新设计计算逻辑和配置接口"
                              "0.2.1 Several bugs fixed": {
                                "zh-cn": "修复了几个错误"
                              "0.2.0 Public Release candidate": {
                                "zh-cn": "公开发布候选人"
                              "0.2.1 Final fix for start values, several code improvements": {
                                "en": "0.2.1 Final fix for start values, several code improvements",
                                "de": "0.2.1 Endfix für Startwerte, verschiedene Code-Verbesserungen",
                                "ru": "0.2.1 Окончательное исправление для начальных значений, несколько улучшений кода",
                                "pt": "0.2.1 Correção final para valores iniciais, várias melhorias no código",
                                "nl": "0.2.1 Laatste fix voor startwaarden, verschillende codeverbeteringen",
                                "fr": "0.2.1 Correctif final pour les valeurs de départ, plusieurs améliorations de code",
                                "it": "0.2.1 Correzione finale per i valori iniziali, diversi miglioramenti del codice",
                                "es": "0.2.1 Arreglo final para valores de inicio, varias mejoras de código",
                                "pl": "0.2.1 Ostateczna poprawka wartości początkowych, kilka ulepszeń kodu",
                                "zh-cn": "0.2.1起始值的最终修复,几个代码改进"
                              "0.2.26": {
                              "0.2.25": {
                              "0.2.24": {
                              "0.2.2": {
                              "0.2.1": {
                                "zh-cn": "修复了几个错误"
                              "0.2.0": {
                                "zh-cn": "公开发布候选人"
                              "0.1.9": {
                              "0.2.27": {
                              "0.2.281": {
                              "0.2.5": {
                              "0.2.41": {
                              "0.1.3": {
                                "zh-cn": "已实施m³"
                              "0.4.0": {
                              "0.3.0": {
                                "zh-cn": "已实施m³"
                              "0.4.2": {
                                "en": "Bugfixes",
                                "nl": "Bugfixes",
                                "zh-cn": "Bug修复"
                              "0.4.5": {
                            "titleLang": {
                            "desc": {
                            "authors": [
                            "keywords": [
                              "energy",
                              "power",
                              "analytics",
                              "consumption",
                              "meassurement",
                              "data"
                            "main": "main.js",
                            "icon": "sourceanalytix.png",
                            "enabled": true,
                            "loglevel": "warn",
                            "mode": "daemon",
                            "type": "energy",
                            "installedVersion": "0.4.2",
                            "host": "debian",
                            "dependencies": [
                                "admin": ">=3.0.0"
                            "license": "MIT",
                            "compact": true,
                            "contributors": [
                              "xXBJXx"
                            "installedFrom": "iobroker.sourceanalytix@0.4.2",
                            "plugins": {
                              "sentry": {
                          "native": {
                            "store_year": true,
                            "store_days": true,
                            "store_quarters": false,
                            "store_years": false,
                            "keep_days": "7",
                            "keep_weeks": "4",
                            "keep_months": "4",
                            "keep_years": "1",
                            "unit_price_power": "0.26",
                            "unit_price_power_night": "0",
                            "unit_price_power_delivery": "0",
                            "basic_price_power": "12.40",
                            "unit_price_gas": "0.51",
                            "basic_price_gas": "17.90",
                            "intervall": "5",
                            "status_logging": true,
                            "store_periode": false,
                            "impuls": 400,
                            "unitConfig": [
                                "uName": "kWh",
                                "uStore": "kWh",
                                "uFactor": "1"
                                "uName": "w",
                                "uStore": "kWh",
                                "uFactor": "1000"
                                "uName": "m3",
                                "uStore": "m³",
                                "uFactor": "1"
                                "uName": "m³ ",
                                "uStore": "m³",
                                "uFactor": "1"
                                "uName": "l",
                                "uStore": "m³",
                                "uFactor": "1000"
                            "pricesConfig": [
                                "uPpU": "0,27",
                                "uPpM": "15"
                                "uPpU": "0,17",
                                "uPpM": "15"
                                "uPpU": "0,24",
                                "uPpM": "15"
                                "uCat": "Heatpump",
                                "uPpU": "0,24",
                                "uPpM": "31"
                                "uCat": "Gas",
                                "uPpU": "0,12",
                                "uPpM": "31"
                                "uCat": "Oil",
                                "uPpU": "0,12",
                                "uPpM": "7,38"
                                "uCat": "Water",
                                "uPpU": "0,07",
                                "uPpM": "22"
                                "unitType": "kWh",
                                "uPpU": "0.27",
                                "uPpM": "15"
                                "cat": "Water",
                                "unitType": "m³",
                                "uPpU": "0.07",
                                "uPpM": "22"
                                "cat": "Gas",
                                "des": "Gas Test",
                                "unitType": "m³",
                                "uPpU": "0.12",
                                "uPpM": "32"
                                "cat": "Gasoline",
                                "des": "Gas",
                                "unitType": "m³",
                                "uPpU": "0.15",
                                "uPpM": "35"
                          "ts": 1599140542951,
                          "acl": {
                            "object": 1636,
                          "objects": [
                              "views": {
                                "state": {
                              "from": "system.host.debian.cli",
                              "ts": 1599140136776
                          "enums": {}
                        • Palm_Maniac
                          @Dutchman
                          Bei mir taucht der Fehler immer auf. Ich habe viele Geräte, die ich mit SA erfasse und da ist immer einer oder mehr dabei, wo das dann passiert, hauptsächlich bei den Daten des Wechselrichters der Photovoltaikanlage. Sag mir was ich wo einstellen soll um entsprechende Logs zu bekommen, dann mache ich das.
                          • Dutchman
                            Dutchman Developer Most Active Administrators @coyote last edited by Dutchman
                            @Dutchman kein Problem (hatte ich irgendwie überlesen )
                            Fehler gefunden !
                            Du hast im object ausgewählt
                            Das gibt es aber nicht in deiner preis definition, trage in dieser Tabelle mal water_m3 ein
                            Wen das klappt muss ich code anpassen das der Fehler eindeutiger kommt aber bin mir fast sicher das dies die Ursache ist
                            Oder besser, wähle beim Datenpunkt den richtigen meassurement type den water (ohne _m3) steht standard in der Tabelle
                            • coyote
                              @Dutchman hm, sieht bei mir anders aus:
                              Und wenn ich keinen Type auswähle kommt:
                              sourceanalytix.0	2020-09-03 15:58:24.838	error	(21924) Sorry unite type undefined not supported (yet), javascript.0.Wasserzaehler.StandAktuell will be ignored from calculations!
                              sourceanalytix.0	2020-09-03 15:58:24.838	error	(21924) Identifying unit failed, please ensure state has a propper unit assigned or the unit is manually choosen in state settings !
                              sourceanalytix.0	2020-09-03 15:58:24.835	error	(21924) Sorry unite type undefined not supported (yet), javascript.0.Wasserzaehler.StandAktuell will be ignored from calculations!
                              sourceanalytix.0	2020-09-03 15:58:24.835	error	(21924) Identifying unit failed, please ensure state has a propper unit assigned or the unit is manually choosen in state settings !
                              • Dutchman
                                falsche Einstellungen, beim object selber und dan nicht die unit sonder den typen aendern bitte
                                Nicht
                                Also hier in de Einstellungen :
                                Unit = Welche Einheit
                                Type = Welche Berechnung (gas, Wasser oder was man auch immer in die Tabelle eingefügt hat)
                                Der Fehler wird verursacht weil es den eingestellten typen nicht finden kan
                                  crunchip Forum Testing Most Active @coyote last edited by
                                  @coyote dein Wasserzähler hat aber
                                  "type": "mixed", anstatt number
                                  • Dutchman
                                    Dutchman Developer Most Active Administrators @crunchip last edited by
                                    @crunchip sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                    sollte egal sein
                                    • coyote
                                      @Dutchman hab ich aber doch oder ich stehe gerade auf dem Schlauch:
                                      Ich habe auch anstatt Water mal Gas ausgewählt, bringt aber keine Änderung, ist ja der gleiche Type
                                      • Dutchman
                                        dan zeig mal was jetzt im log kommt und wieder die raw daten des objects bitte
                                        • coyote
                                          @Dutchman na genau das was ich vorhin gepostet hab:
                                          sourceanalytix.0	2020-09-03 16:07:49.372	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                          sourceanalytix.0	2020-09-03 16:07:49.372	error	at Sourceanalytix.initialize (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:271:16)
                                          sourceanalytix.0	2020-09-03 16:07:49.372	error	at Sourceanalytix.calculationHandler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:784:26)
                                          sourceanalytix.0	2020-09-03 16:07:49.372	error	(24266) [calculationHandler javascript.0.Wasserzaehler.StandAktuell] error: Cannot read property 'toLowerCase' of undefined, stack: TypeError: Cannot read property 'toLowerCase' of undefined
                                          RAW:
                                            "common": {
                                              "role": "state",
                                              "type": "mixed",
                                              "custom": {
                                                "history.0": {
                                                  "enabled": true,
                                                  "debounce": 0,
                                                  "maxLength": "10",
                                                  "aliasId": ""
                                                  "enabled": true,
                                                  "state_unit": "m3",
                                                  "costs": false,
                                                  "start_day": 0,
                                                  "start_week": 0,
                                                  "start_month": 0,
                                                  "start_quarter": 0,
                                                  "start_year": 0
                                            "native": {},
                                            "type": "state",
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636,
                                          • Dutchman
                                            RAW
                                            die werte wurden nicht übernommen !
                                            ander das mal im raw object nach water bitte
                                            coyote G 3 Replies Last reply Reply Quote 0
                                            81.1k
                                            adapter sourceanalytix testen update
                                            103
                                            1082
                                            352748
