    4. iob windows - wieder crash - ich brauch Hilfe
    UNSOLVED iob windows - wieder crash - ich brauch Hilfe
    • bahnuhr
      bahnuhr Forum Testing Most Active @AlCalzone last edited by bahnuhr
      @AlCalzone sagte in iob windows - wieder crash - ich brauch Hilfe:
      Was steht dann in der Logdatei, wenn Admin nicht startet?
      dies:
      2020-09-04 10:06:21.724  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 2.1.0 js-controller starting
      2020-09-04 10:06:21.726  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
      2020-09-04 10:06:21.726  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:06:21.733  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:95b3:6841:c582:82ee fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:06:21.760  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:06:21.770  - info: host.NUC-Buero(SmartHome) 3 instances found
      2020-09-04 10:06:21.772  - info: host.NUC-Buero(SmartHome) starting 3 instances
      2020-09-04 10:06:21.782  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 4936
      2020-09-04 10:06:22.405  - info: host.NUC-Buero(SmartHome) received SIGINT
      2020-09-04 10:06:22.406  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:06:22.406  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 (force=false, process=false)
      2020-09-04 10:06:22.406  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 (force=false, process=false)
      2020-09-04 10:06:22.407  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:06:22.427  - info: admin.0 (4936) starting. Version 3.6.12 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0
      2020-09-04 10:06:22.435  - info: admin.0 (4936) requesting all states
      2020-09-04 10:06:22.435  - info: admin.0 (4936) requesting all objects
      2020-09-04 10:06:22.444  - info: admin.0 (4936) received all objects
      2020-09-04 10:06:22.447  - warn: admin.0 (4936) Repository cannot be read
      2020-09-04 10:06:22.457  - info: admin.0 (4936) http server listening on port 8081
      2020-09-04 10:06:22.458  - info: admin.0 (4936) Use link "http://localhost:8081" to configure.
      2020-09-04 10:06:23.413  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 killing pid 4936
      2020-09-04 10:06:23.424  - warn: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated due to SIGTERM
      2020-09-04 10:06:23.424  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code null ()
      2020-09-04 10:06:23.424  - info: host.NUC-Buero(SmartHome) All instances are stopped.
      2020-09-04 10:06:23.431  - info: host.NUC-Buero(SmartHome) terminated
      2020-09-04 10:06:29.368  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 2.1.0 js-controller starting
      2020-09-04 10:06:29.370  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
      2020-09-04 10:06:29.371  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:06:29.377  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:95b3:6841:c582:82ee fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:06:29.401  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:06:29.411  - info: host.NUC-Buero(SmartHome) 3 instances found
      2020-09-04 10:06:29.413  - info: host.NUC-Buero(SmartHome) starting 3 instances
      2020-09-04 10:06:29.421  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 4864
      2020-09-04 10:06:30.097  - info: admin.0 (4864) starting. Version 3.6.12 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0
      2020-09-04 10:06:30.104  - info: admin.0 (4864) requesting all states
      2020-09-04 10:06:30.104  - info: admin.0 (4864) requesting all objects
      2020-09-04 10:06:30.115  - info: admin.0 (4864) received all objects
      2020-09-04 10:06:30.116  - warn: admin.0 (4864) Repository cannot be read
      2020-09-04 10:06:30.127  - info: admin.0 (4864) http server listening on port 8081
      2020-09-04 10:06:30.127  - info: admin.0 (4864) Use link "http://localhost:8081" to configure.
      2020-09-04 10:06:33.417  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 started with pid 3360
      2020-09-04 10:06:33.856  - info: discovery.0 (3360) starting. Version 1.3.0 in C:/iobroker/SmartHome/node_modules/iobroker.discovery, node: v10.17.0
      2020-09-04 10:06:37.421  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 started with pid 7688
      2020-09-04 10:06:38.490  - info: info.0 (7688) starting. Version 1.5.6 in C:/iobroker/SmartHome/node_modules/iobroker.info, node: v10.17.0
      2020-09-04 10:06:38.937  - info: info.0 (7688) Popup news was read...
      2020-09-04 10:07:13.731  - info: host.NUC-Buero(SmartHome) Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      2020-09-04 10:09:09.096  - info: host.NUC-Buero(SmartHome) received SIGINT
      2020-09-04 10:09:09.092  - info: admin.0 (4864) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:09:09.097  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:09:09.097  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 (force=false, process=true)
      2020-09-04 10:09:09.097  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 (force=false, process=true)
      2020-09-04 10:09:09.097  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:09:09.097  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 send kill signal
      2020-09-04 10:09:09.098  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 send kill signal
      2020-09-04 10:09:09.092  - info: discovery.0 (3360) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:09:09.096  - info: info.0 (7688) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:09:09.092  - info: discovery.0 (3360) terminating
      2020-09-04 10:09:09.093  - info: discovery.0 (3360) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:09:09.093  - info: admin.0 (4864) terminating http server on port 8081
      2020-09-04 10:09:09.093  - info: admin.0 (4864) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:09:09.097  - info: info.0 (7688) cleaned everything up...
      2020-09-04 10:09:09.097  - info: info.0 (7688) terminating
      2020-09-04 10:09:09.097  - info: info.0 (7688) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:09:09.627  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:09:09.628  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:09:09.628  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:09:09.628  - info: host.NUC-Buero(SmartHome) All instances are stopped.
      2020-09-04 10:09:09.709  - info: host.NUC-Buero(SmartHome) terminated
      2020-09-04 10:09:20.175  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 2.1.0 js-controller starting
      2020-09-04 10:09:20.177  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
      2020-09-04 10:09:20.177  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:09:20.184  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:95b3:6841:c582:82ee fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:09:20.243  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:09:20.255  - info: host.NUC-Buero(SmartHome) 3 instances found
      2020-09-04 10:09:20.257  - info: host.NUC-Buero(SmartHome) starting 3 instances
      2020-09-04 10:09:20.266  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 8016
      2020-09-04 10:09:20.921  - info: admin.0 (8016) starting. Version 3.6.12 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0
      2020-09-04 10:09:20.928  - info: admin.0 (8016) requesting all states
      2020-09-04 10:09:20.928  - info: admin.0 (8016) requesting all objects
      2020-09-04 10:09:21.010  - info: admin.0 (8016) received all objects
      2020-09-04 10:09:21.029  - info: admin.0 (8016) http server listening on port 8081
      2020-09-04 10:09:21.029  - info: admin.0 (8016) Use link "http://localhost:8081" to configure.
      2020-09-04 10:09:24.261  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 started with pid 7104
      2020-09-04 10:09:24.628  - info: discovery.0 (7104) starting. Version 1.3.0 in C:/iobroker/SmartHome/node_modules/iobroker.discovery, node: v10.17.0
      2020-09-04 10:09:28.271  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 started with pid 8112
      2020-09-04 10:09:29.325  - info: info.0 (8112) starting. Version 1.5.6 in C:/iobroker/SmartHome/node_modules/iobroker.info, node: v10.17.0
      2020-09-04 10:09:29.765  - info: info.0 (8112) Popup news was read...
      2020-09-04 10:11:34.202  - info: host.NUC-Buero(SmartHome) received SIGINT
      2020-09-04 10:11:34.204  - info: admin.0 (8016) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:11:34.203  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:11:34.203  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 (force=false, process=true)
      2020-09-04 10:11:34.204  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 (force=false, process=true)
      2020-09-04 10:11:34.204  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:11:34.204  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 send kill signal
      2020-09-04 10:11:34.204  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 send kill signal
      2020-09-04 10:11:34.204  - info: discovery.0 (7104) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:11:34.199  - info: info.0 (8112) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:11:34.204  - info: admin.0 (8016) terminating http server on port 8081
      2020-09-04 10:11:34.204  - info: discovery.0 (7104) terminating
      2020-09-04 10:11:34.205  - info: admin.0 (8016) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:11:34.205  - info: discovery.0 (7104) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:11:34.199  - info: info.0 (8112) cleaned everything up...
      2020-09-04 10:11:34.199  - info: info.0 (8112) terminating
      2020-09-04 10:11:34.200  - info: info.0 (8112) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:11:34.734  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:11:34.734  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:11:34.736  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:11:34.736  - info: host.NUC-Buero(SmartHome) All instances are stopped.
      2020-09-04 10:11:34.815  - info: host.NUC-Buero(SmartHome) terminated
      2020-09-04 10:13:15.876  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 2.2.10 js-controller starting
      2020-09-04 10:13:15.879  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-09-04 10:13:15.879  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:13:15.886  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:95b3:6841:c582:82ee fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:13:15.949  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:13:15.963  - info: host.NUC-Buero(SmartHome) 3 instances found
      2020-09-04 10:13:15.966  - info: host.NUC-Buero(SmartHome) starting 3 instances
      2020-09-04 10:13:15.976  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 6132
      2020-09-04 10:13:16.696  - info: admin.0 (6132) starting. Version 3.6.12 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0
      2020-09-04 10:13:16.703  - info: admin.0 (6132) requesting all states
      2020-09-04 10:13:16.703  - info: admin.0 (6132) requesting all objects
      2020-09-04 10:13:16.787  - info: admin.0 (6132) received all objects
      2020-09-04 10:13:16.806  - info: admin.0 (6132) http server listening on port 8081
      2020-09-04 10:13:16.806  - info: admin.0 (6132) Use link "http://localhost:8081" to configure.
      2020-09-04 10:13:19.980  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 started with pid 3244
      2020-09-04 10:13:20.339  - info: discovery.0 (3244) starting. Version 1.3.0 in C:/iobroker/SmartHome/node_modules/iobroker.discovery, node: v10.17.0
      2020-09-04 10:13:23.977  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 started with pid 11416
      2020-09-04 10:13:25.010  - info: info.0 (11416) starting. Version 1.5.6 in C:/iobroker/SmartHome/node_modules/iobroker.info, node: v10.17.0
      2020-09-04 10:13:25.427  - info: info.0 (11416) Popup news was read...
      2020-09-04 10:14:57.566  - info: host.NUC-Buero(SmartHome) iobroker upgrade admin
      2020-09-04 10:14:58.648  - info: host.NUC-Buero(SmartHome) iobroker Update admin from @3.6.12 to @4.0.10
      2020-09-04 10:14:58.653  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Adapter "system.adapter.admin.0" is stopped.
      2020-09-04 10:14:58.657  - info: host.NUC-Buero(SmartHome) "system.adapter.admin.0" disabled
      2020-09-04 10:14:58.658  - info: admin.0 (6132) Adapter is disabled => stop
      2020-09-04 10:14:58.658  - info: admin.0 (6132) terminating http server on port 8081
      2020-09-04 10:14:58.658  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:14:58.658  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:14:58.664  - info: admin.0 (6132) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:14:58.667  - info: admin.0 (6132) terminating
      2020-09-04 10:14:58.668  - info: admin.0 (6132) Terminated (NO_ERROR): Without reason
      2020-09-04 10:14:59.182  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2020-09-04 10:14:59.243  - info: host.NUC-Buero(SmartHome) iobroker NPM version: 6.11.3
      2020-09-04 10:14:59.243  - info: host.NUC-Buero(SmartHome) iobroker npm install iobroker.admin@4.0.10 --loglevel error (System call)
      2020-09-04 10:15:09.256  - info: host.NUC-Buero(SmartHome) iobroker gyp
      2020-09-04 10:15:09.256  - info: host.NUC-Buero(SmartHome) iobroker  ERR! build error gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack     at ChildProcess.onExit (C:\iobroker\SmartHome\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:193:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      2020-09-04 10:15:09.256  - info: host.NUC-Buero(SmartHome) iobroker gyp ERR! System Windows_NT 10.0.18363gyp
      2020-09-04 10:15:09.256  - info: host.NUC-Buero(SmartHome) iobroker ERR! command "C:\\iobroker\\SmartHome\\nodejs\\node.exe" "C:\\iobroker\\SmartHome\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\iobroker\SmartHome\node_modules\unix-dgramgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3
      2020-09-04 10:15:09.257  - info: host.NUC-Buero(SmartHome) iobroker gyp ERR! not ok
      2020-09-04 10:15:09.539  - info: host.NUC-Buero(SmartHome) iobroker upload [3] admin.admin C:/iobroker/SmartHome/node_modules/iobroker.admin/admin/words.js words.js application/javascript
      2020-09-04 10:15:09.553  - info: host.NUC-Buero(SmartHome) iobroker Update "system.adapter.admin.0"
      2020-09-04 10:15:09.619  - info: host.NUC-Buero(SmartHome) iobroker upload [2] admin.admin C:/iobroker/SmartHome/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
      2020-09-04 10:15:09.672  - info: host.NUC-Buero(SmartHome) iobroker upload [1] admin.admin C:/iobroker/SmartHome/node_modules/iobroker.admin/admin/index.html index.html text/html
      2020-09-04 10:15:09.725  - info: host.NUC-Buero(SmartHome) iobroker upload [0] admin.admin C:/iobroker/SmartHome/node_modules/iobroker.admin/admin/admin.png admin.png image/png
      2020-09-04 10:15:09.778  - info: host.NUC-Buero(SmartHome) iobroker Adapter "admin" updated
      2020-09-04 10:15:09.779  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Adapter "system.adapter.admin.0" is started
      2020-09-04 10:15:09.782  - info: host.NUC-Buero(SmartHome) "system.adapter.admin.0" enabled
      2020-09-04 10:15:09.785  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 6732
      2020-09-04 10:15:10.462  - info: admin.0 (6732) starting. Version 4.0.10 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0
      2020-09-04 10:15:10.471  - info: admin.0 (6732) requesting all states
      2020-09-04 10:15:10.471  - info: admin.0 (6732) requesting all objects
      2020-09-04 10:15:10.556  - info: admin.0 (6732) received all objects
      2020-09-04 10:15:10.576  - info: admin.0 (6732) http server listening on port 8081
      2020-09-04 10:15:10.576  - info: admin.0 (6732) Use link "http://localhost:8081" to configure.
      2020-09-04 10:15:10.800  - info: host.NUC-Buero(SmartHome) iobroker exit 0
      2020-09-04 10:15:52.125  - info: host.NUC-Buero(SmartHome) received SIGINT
      2020-09-04 10:15:52.127  - info: admin.0 (6732) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:15:52.126  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:15:52.126  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 (force=false, process=true)
      2020-09-04 10:15:52.126  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 (force=false, process=true)
      2020-09-04 10:15:52.126  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:15:52.126  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 send kill signal
      2020-09-04 10:15:52.127  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 send kill signal
      2020-09-04 10:15:52.125  - info: discovery.0 (3244) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:15:52.125  - info: info.0 (11416) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:15:52.125  - info: discovery.0 (3244) terminating
      2020-09-04 10:15:52.126  - info: discovery.0 (3244) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:15:52.126  - info: info.0 (11416) cleaned everything up...
      2020-09-04 10:15:52.126  - info: info.0 (11416) terminating
      2020-09-04 10:15:52.126  - info: info.0 (11416) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:15:52.127  - info: admin.0 (6732) terminating http server on port 8081
      2020-09-04 10:15:52.128  - info: admin.0 (6732) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:15:52.653  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:15:52.654  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:15:52.655  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:15:52.655  - info: host.NUC-Buero(SmartHome) All instances are stopped.
      2020-09-04 10:15:52.753  - info: host.NUC-Buero(SmartHome) terminated
      2020-09-04 10:15:57.319  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 2.2.10 js-controller starting
      2020-09-04 10:15:57.321  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-09-04 10:15:57.321  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:15:57.329  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:95b3:6841:c582:82ee fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:15:57.385  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:15:57.397  - info: host.NUC-Buero(SmartHome) 3 instances found
      2020-09-04 10:15:57.401  - info: host.NUC-Buero(SmartHome) starting 3 instances
      2020-09-04 10:15:57.410  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 6800
      2020-09-04 10:15:58.040  - info: admin.0 (6800) starting. Version 4.0.10 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0
      2020-09-04 10:15:58.046  - info: admin.0 (6800) requesting all states
      2020-09-04 10:15:58.047  - info: admin.0 (6800) requesting all objects
      2020-09-04 10:15:58.131  - info: admin.0 (6800) received all objects
      2020-09-04 10:15:58.149  - info: admin.0 (6800) http server listening on port 8081
      2020-09-04 10:15:58.149  - info: admin.0 (6800) Use link "http://localhost:8081" to configure.
      2020-09-04 10:16:01.411  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 started with pid 5372
      2020-09-04 10:16:01.839  - info: discovery.0 (5372) starting. Version 1.3.0 in C:/iobroker/SmartHome/node_modules/iobroker.discovery, node: v10.17.0
      2020-09-04 10:16:05.408  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 started with pid 4536
      2020-09-04 10:16:06.515  - info: info.0 (4536) starting. Version 1.5.6 in C:/iobroker/SmartHome/node_modules/iobroker.info, node: v10.17.0
      2020-09-04 10:16:06.938  - info: info.0 (4536) Popup news was read...
      2020-09-04 10:16:09.429  - info: host.NUC-Buero(SmartHome) iobroker del discovery.0
      2020-09-04 10:16:10.457  - info: host.NUC-Buero(SmartHome) iobroker Delete adapter "discovery.0"
      2020-09-04 10:16:10.460  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Counted 1 instances of discovery.0
      2020-09-04 10:16:10.468  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Counted 5 states of discovery.0
      2020-09-04 10:16:10.471  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Counted 14 states of system.adapter.discovery.0
      2020-09-04 10:16:10.546  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Deleting 20 object(s).
      2020-09-04 10:16:10.583  - info: host.NUC-Buero(SmartHome) object deleted system.adapter.discovery.0
      2020-09-04 10:16:10.584  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 (force=false, process=true)
      2020-09-04 10:16:10.584  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.discovery.0 send kill signal
      2020-09-04 10:16:10.602  - info: discovery.0 (5372) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:16:10.603  - info: discovery.0 (5372) terminating
      2020-09-04 10:16:10.604  - info: discovery.0 (5372) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:16:11.118  - info: host.NUC-Buero(SmartHome) instance system.adapter.discovery.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:16:11.118  - info: host.NUC-Buero(SmartHome) Do not restart adapter system.adapter.discovery.0 because disabled or deleted
      2020-09-04 10:16:11.594  - info: host.NUC-Buero(SmartHome) iobroker exit 0
      2020-09-04 10:16:45.175  - info: host.NUC-Buero(SmartHome) iobroker del discovery
      2020-09-04 10:16:46.198  - info: host.NUC-Buero(SmartHome) iobroker Delete adapter "discovery"
      2020-09-04 10:16:46.203  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) Counted 1 adapter for discovery
      2020-09-04 10:16:46.216  - info: host.NUC-Buero(SmartHome) iobroker host.NUC-Buero(SmartHome) object discovery.admin deletedhost.NUC-Buero(SmartHome) Deleting 1 object(s).
      2020-09-04 10:16:46.220  - info: host.NUC-Buero(SmartHome) iobroker npm uninstall iobroker.discovery --silent (System call)
      2020-09-04 10:16:53.910  - info: host.NUC-Buero(SmartHome) iobroker exit 0
      2020-09-04 10:17:14.202  - info: host.NUC-Buero(SmartHome) received SIGINT
      2020-09-04 10:17:14.203  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:17:14.203  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 (force=false, process=true)
      2020-09-04 10:17:14.203  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:17:14.204  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 send kill signal
      2020-09-04 10:17:14.204  - info: admin.0 (6800) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:17:14.198  - info: info.0 (4536) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:17:14.199  - info: info.0 (4536) cleaned everything up...
      2020-09-04 10:17:14.199  - info: info.0 (4536) terminating
      2020-09-04 10:17:14.200  - info: info.0 (4536) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:17:14.204  - info: admin.0 (6800) terminating http server on port 8081
      2020-09-04 10:17:14.205  - info: admin.0 (6800) terminating
      2020-09-04 10:17:14.205  - info: admin.0 (6800) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2020-09-04 10:17:14.721  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:17:14.724  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code 4294967196 (START_IMMEDIATELY_AFTER_STOP_HEX)
      2020-09-04 10:17:14.724  - info: host.NUC-Buero(SmartHome) All instances are stopped.
      2020-09-04 10:17:14.806  - info: host.NUC-Buero(SmartHome) terminated
      2020-09-04 10:18:37.439  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 3.1.6 js-controller starting
      2020-09-04 10:18:37.442  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-09-04 10:18:37.442  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:18:37.449  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:95b3:6841:c582:82ee fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:18:37.517  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:18:37.646  - info: host.NUC-Buero(SmartHome) 2 instances found
      2020-09-04 10:18:37.649  - info: host.NUC-Buero(SmartHome) starting 2 instances
      2020-09-04 10:18:37.664  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 10612
      2020-09-04 10:18:38.446  - info: admin.0 (10612) starting. Version 4.0.10 in C:/iobroker/SmartHome/node_modules/iobroker.admin, node: v10.17.0, js-controller: 3.1.6
      2020-09-04 10:18:38.455  - info: admin.0 (10612) requesting all states
      2020-09-04 10:18:38.455  - info: admin.0 (10612) requesting all objects
      2020-09-04 10:18:38.554  - info: admin.0 (10612) received all objects
      2020-09-04 10:18:38.570  - info: admin.0 (10612) http server listening on port 8081
      2020-09-04 10:18:38.571  - info: admin.0 (10612) Use link "http://localhost:8081" to configure.
      2020-09-04 10:18:41.669  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 started with pid 12820
      2020-09-04 10:18:42.741  - info: info.0 (12820) starting. Version 1.5.6 in C:/iobroker/SmartHome/node_modules/iobroker.info, node: v10.17.0, js-controller: 3.1.6
      2020-09-04 10:18:43.191  - info: info.0 (12820) Popup news was read...
      2020-09-04 10:18:43.200  - warn: info.0 (12820) adapter.objects.getObjectView is deprecated, and will be removed in the future. Please use adapter.getObjectView/Async. Report this to Developer!
      2020-09-04 10:20:16.396  - info: host.NUC-Buero(SmartHome) received SIGINT
      2020-09-04 10:20:16.398  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 (force=false, process=true)
      2020-09-04 10:20:16.398  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 (force=false, process=true)
      2020-09-04 10:20:16.399  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.admin.0 send kill signal
      2020-09-04 10:20:16.399  - info: host.NUC-Buero(SmartHome) stopInstance system.adapter.info.0 send kill signal
      2020-09-04 10:20:16.400  - info: info.0 (12820) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:20:16.399  - info: admin.0 (10612) Got terminate signal TERMINATE_YOURSELF
      2020-09-04 10:20:16.401  - info: info.0 (12820) cleaned everything up...
      2020-09-04 10:20:16.401  - info: info.0 (12820) terminating
      2020-09-04 10:20:16.402  - info: info.0 (12820) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-09-04 10:20:16.401  - info: admin.0 (10612) terminating http server on port 8081
      2020-09-04 10:20:16.402  - info: admin.0 (10612) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-09-04 10:20:16.925  - info: host.NUC-Buero(SmartHome) instance system.adapter.info.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-09-04 10:20:16.926  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-09-04 10:20:16.926  - info: host.NUC-Buero(SmartHome) All instances are stopped.
      2020-09-04 10:20:17.010  - info: host.NUC-Buero(SmartHome) terminated
      2020-09-04 10:23:02.887  - info: host.NUC-Buero(SmartHome) iobroker.js-controller version 3.1.6 js-controller starting
      2020-09-04 10:23:02.890  - info: host.NUC-Buero(SmartHome) Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
      2020-09-04 10:23:02.891  - info: host.NUC-Buero(SmartHome) hostname: NUC-Buero(SmartHome), node: v10.17.0
      2020-09-04 10:23:02.898  - info: host.NUC-Buero(SmartHome) ip addresses: 2a03:93e0:200:1480:d017:fd2e:42ca:1c77 2a03:93e0:200:1480:3c3a:f8e0:49dc:b58e fe80::d017:fd2e:42ca:1c77 192.168.243.100
      2020-09-04 10:23:02.963  - info: host.NUC-Buero(SmartHome)  Error inMem-objects listening on port 9001
      2020-09-04 10:23:03.011  - info: host.NUC-Buero(SmartHome) connected to Objects and States
      2020-09-04 10:23:03.326  - info: host.NUC-Buero(SmartHome) 2 instances found
      2020-09-04 10:23:03.328  - info: host.NUC-Buero(SmartHome) starting 2 instances
      2020-09-04 10:23:03.347  - info: host.NUC-Buero(SmartHome) instance system.adapter.admin.0 started with pid 464
      2020-09-04 10:23:04.877  - error: Socket.io Server detected. Please update to js-controller 2.0 or higher!
      2020-09-04 10:23:04.878  - error: Socket.io Server detected. Please update to js-controller 2.0 or higher!
      2020-09-04 10:23:05.184  - error: Socket.io Server detected. Please update to js-controller 2.0 or higher!
      2020-09-04 10:23:05.497  - error: Socket.io Server detected. Please update to js-controller 2.0 or higher!
      2020-09-04 10:23:05.498  - error: Socket.io Server detected. Please update to js-controller 2.0 or higher!
      2020-09-04 10:27:33.068  - error: Socket.io Server detected. Please update to js-controller 2.0 or higher!
      Habe die mittleren Zeilen ... gelöscht.
      War zuviel für den Beitrag.
      • AlCalzone
        AlCalzone Developer @bahnuhr last edited by
        @bahnuhr Super danke!
        • AlCalzone
          Also wir konnten das Rätsel zum Teil lösen. Bei @bahnuhr blockiert irgendetwas Port 9001, während ioBroker versucht zu starten. Wenn beim Installieren Port 9101 für die Objects DB ausgewählt wird, klappt es wie gewünscht.
            Thomas Braun Most Active @AlCalzone last edited by
            @AlCalzone Gibt es da nicht sowas wie netstat unter Betriebssystemen?
            AlCalzone bahnuhr 2 Replies Last reply Reply Quote 0
            • AlCalzone
              AlCalzone Developer @Thomas Braun last edited by AlCalzone
              @Thomas-Braun Ja, das liefert nur die ioBroker-Instanz, die behauptet, nicht auf den Port zugreifen zu können 🤷‍♂️ Sobald die gestoppt wird, ist auch nichts mehr da, was 9001 nutzt.
              • bahnuhr
                bahnuhr Forum Testing Most Active @Thomas Braun last edited by
                @Thomas-Braun sagte in iob windows - wieder crash - ich brauch Hilfe:
                netstat
                Ja, ich konnte mit netstat die PID ermitteln, die ich dann mit taskkill gestoppt habe.
                Der Installer lief dann durch und funktionierte.
                Bis zu einem Neustart des PC.
                Dann ging nix mehr.
                Dann Installer mit 9101 installiert und jetzt läuft es auch nach dem Neustart.
                Was noch nicht klappt ist multihost. Hatte aber bisher immer geklappt.
                Hat sich da etwas geändert?
                Weiß das jemand?
                oder stört wieder irgendwas auf meiner Kiste.
                Homoran da_Woody 2 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @bahnuhr last edited by Homoran
                  @bahnuhr sagte in iob windows - wieder crash - ich brauch Hilfe:
                  bei dir!
                  Weiß das jemand?
                  Ja! Du! 😉
                  so könnte man es auch sagen.
                  Ich denke du hast den Slave immer noch auf Port 9001 gemapped
                  • da_Woody
                    da_Woody @bahnuhr last edited by
                    @bahnuhr hast du zufällig ein synology nas mit surveilance station? die hat mit https 9001...
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @Homoran last edited by
                      @Homoran sagte in iob windows - wieder crash - ich brauch Hilfe:
                      Ne, hab ja mit iobroker setup custom umgestellt auf 9101
                      Slave hat den Master auch gefunden und connected.
                      Aber der admin startet dann nicht mehr.
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @da_Woody last edited by
                        @da_Woody sagte in iob windows - wieder crash - ich brauch Hilfe:
                        synology hab ich.
                        Da hab ich aber nichts geändert.
                        Und vorher ging es ja.
                        Auch komisch.
                        • bahnuhr
                          So Fazit von dem ganzen Drama der letzten Tage.
                          • Ich möchte aber eigentlich win
                          • Wenn updates oder irgendwas anderes passiert (sonstige Installation) geht mit Sicherheit (zumindest bei mir) etwas schief.
                          • Und dann bin ich ewig beschäftigt, dass es wieder läuft.
                          Ich brauche also ein System wo man einfach den aktuellen Stand sichert um dann wieder zurück zu kommen.
                          Mit meinen manuellen Sicherungen der Dateien klappt es mal mehr mal weniger.
                          Irgendwo hab ich gelesen, dass man meine primäre Anforderung:
                          -> einfach wieder auf den aktuellen Stand zurück wenn etwas schief läuft
                          mit proxmox hin bekommt ?
                          Ist das die Lösung ?
                          Habt ihr mal einen Link oder Beschreibung für mich.
                          Läuft momentan alles auf linux raus, glaub ich.
                          Wollte ich aber eigentlich nie dran.
                          mfg
                          harrym Homoran Asgothian 3 Replies Last reply Reply Quote 0
                          • harrym
                            harrym @bahnuhr last edited by
                            ja
                            Proxmox iso ... https://www.proxmox.com/de/downloads/category/iso-images-pve
                            da hast du alles sofort fertig.
                            • AlCalzone
                              Was steht im Log?
                              harrym 1 Reply Last reply Reply Quote 0
                              • harrym
                                harrym @AlCalzone last edited by
                                @AlCalzone windows schießt sich doch selbst ins Knie bei Updates .... denk doch nur mal in der kurzen Vergangenheit .....
                                Drucker wurden nicht mehr erkannt, Keyboard war tot und vieles mehr. Wie willst du da vernünftig mit nem Installer agieren, wenn MS$ selbst diverse Upgrades/Updates zurückzieht?
                                  ich weiß nicht so recht.
                                  Proxmox ist ein eigenständiges Betriebssystem auf dem du dann VMs mit einem beliebigen Betriebssystem aufbauen kannst.
                                  Von diesen VMs kann man in "sekundenschnelle" einen so genannten Snapshot erstellen, der genauso schnell wiederhergestellt wird.
                                  ähnliches kannst du aber auch unter Windows mit Drive Imagern machen (Paragon (kostenlos) oder Acronis)
                                  ist nicht ganz dasselbe, da du in deinem Fall dein ganzes WIN mitsichern würdest. Wenn du natürlich einen WIN-Rechner nur für ioBroker hast wäre das der schnellste Weg.
                                  Festplatte in zwei Partionen unterteilen (besser zwei Festplatten zur physikalischen Redundanz) Acronis true image oder Paragon Backup & recovery installieren und vor einem Update einen Spiegel der Systemplatte auf der Sicherungsplatte ablegen.
                                  Geht was schief kannst du in Minuten den alten Zustand wieder herstellen
                                    Homoran Global Moderator Administrators @harrym last edited by
                                    @harrym sagte in iob windows - wieder crash - ich brauch Hilfe:
                                    naja - so schnell schießen die Preußen auch nicht.
                                    harrym 1 Reply Last reply Reply Quote 1
                                    • harrym
                                      harrym @Homoran last edited by
                                      @Homoran mim iso schon. Da haste mal den Proxmox sofort am laufen. Ne VM oder Container ... sind dann nur ein paar Mausklicks.
                                        jepp - aber eben noch keine VM, noch kein no-subscription, und natürlich nicht sofort iobroker unter WINDoof drauf.
                                        und schon gar nicht mit der iso auf einem bestehenden Windoof installieren 😉
                                        • harrym
                                          @Homoran aber der hauptfehler windoof ist mal weg ... proxmox läuft unter linux gggggggg
                                            nicht wirklich 😉
                                            also wird es auf ein WIN-VM hinauslaufen 😉
                                            error windows
                                            2932
