    • mickym
      mickym Most Active @simatec last edited by mickym
      @simatec said in Test Adapter Backitup v1.6.x:
      @mickym
      Hast du manuell das Backup ausgeführt? Da wird nix gelöscht ... nur über die Automatik.
      OK nun automatisch - nur keine Veränderung. Man sieht dass er von den ersten beiden Typen nun 3 Versionen weggeschmissen hat, aber zigbee wird gar nicht angefasst.
      2020-09-04 17:45:02.371 - info: backitup.0 (18197) starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
      2020-09-04 17:45:02.467 - info: backitup.0 (18197) [iobroker] backup was activated at 17:50 every 1 day(s)
      2020-09-04 17:45:02.486 - debug: backitup.0 (18197) No backup file was found
      2020-09-04 17:50:10.183 - debug: backitup.0 (18197) Backup has started ...
      2020-09-04 17:50:12.696 - debug: backitup.0 (18197) [iobroker/iobroker] host.MWHome 3657 states saved
      2020-09-04 17:50:12.728 - debug: backitup.0 (18197) [iobroker/iobroker] host.MWHome 3310 objects saved
      2020-09-04 17:51:34.041 - info: info.0 (18961) Popup news was read...
      2020-09-04 17:53:24.539 - debug: backitup.0 (18197) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_04-17_50_10_backupiobroker.tar.gz
      2020-09-04 17:53:25.566 - debug: backitup.0 (18197) [iobroker/iobroker] done
      2020-09-04 17:53:28.145 - debug: backitup.0 (18197) [iobroker/mysql] MySql File deleted!
      2020-09-04 17:53:28.149 - debug: backitup.0 (18197) [iobroker/mysql] done
      2020-09-04 17:53:28.166 - debug: backitup.0 (18197) [iobroker/zigbee] found zigbee database: zigbee.0
      2020-09-04 17:53:28.167 - debug: backitup.0 (18197) [iobroker/zigbee] done
      2020-09-04 17:53:28.187 - debug: backitup.0 (18197) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_12-02_00_10_backupiobroker.tar.gz
      2020-09-04 17:53:28.198 - debug: backitup.0 (18197) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_11-02_00_10_backupiobroker.tar.gz
      2020-09-04 17:53:28.204 - debug: backitup.0 (18197) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_10-02_00_10_backupiobroker.tar.gz
      2020-09-04 17:53:28.217 - debug: backitup.0 (18197) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_12-02_03_21_backupiobroker.tar.gz
      2020-09-04 17:53:28.221 - debug: backitup.0 (18197) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_11-02_03_32_backupiobroker.tar.gz
      2020-09-04 17:53:28.224 - debug: backitup.0 (18197) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_10-02_03_24_backupiobroker.tar.gz
      2020-09-04 17:53:28.229 - debug: backitup.0 (18197) [iobroker/clean] done
      2020-09-04 17:53:28.244 - debug: backitup.0 (18197) [iobroker] exec: done
      2020-09-04 17:53:28.274 - debug: backitup.0 (18197) [iobroker/history] backitup.0.history.html
      2020-09-04 17:53:28.277 - debug: backitup.0 (18197) [iobroker] exec: done
      2020-09-04 17:53:28.280 - debug: backitup.0 (18197) [iobroker/history] backitup.0.history.json
      2020-09-04 17:53:28.285 - debug: backitup.0 (18197) [iobroker] exec: done
      harrym simatec 2 Replies Last reply Reply Quote 0
      • harrym
        harrym @mickym last edited by
        @mickym war da nicht was mit zigbee und deconz ... und ner eigenen datenbank?
        Ich hab zigbee nicht in Verwendung ....
        • simatec
          simatec Developer Most Active @mickym last edited by
          @mickym
          Hast du von Github die Version installiert?
          Falls ja, mache mal einen Upload.
          Wie gesagt, bei mir wird zigbee gelöscht und dadurch ist es schwer den Fehler zu reproduzieren.
          • simatec
            simatec Developer Most Active @Mike Hellracer last edited by
            @Mike-Hellracer
            So einfach ist es leider nicht ...
            Wie gesagt ... ist aktuell nix geplant.
            harrym M 2 Replies Last reply Reply Quote 0
            • harrym
              harrym @simatec last edited by
              @simatec und mach mMn auch keinerlei Sinn .....
              • mickym
                mickym Most Active @harrym last edited by
                @harrym nee - ich nutze den deconz nicht - sondern den zigbee-Adapter mit CC2531. Und wie gesagt die Backups laufen auch und der Adapter sichert anscheinend die shepherd.db. Mir gehts ja um das Löschen nach x Tagen - das bei allen anderen Typen funktioniert.
                • mickym
                  @simatec habe ich gemacht:
                  Installiert habe ich direkt so:
                  Ich lass das Backup - nochmal mit silly durchlaufen - vielleicht sieht man dann was. 😉
                  Ergebnis:
                  Man sieht auch nicht mehr. 😞
                  • simatec
                    @mickym
                    Ich werde versuchen, dass noch einmal zu rekonstruieren.
                    Was du noch einmal machen könntest, wäre den iobroker fix auszuführen, damit auch alle Rechte passen
                    • MichMein
                      MichMein last edited by
                      unter „Haupteinstellungen“, „weitere Einstellungen“ gibt es History Einträge, wofür genau ist das? Und unter „ioBroker“ gibt es „Stück“, das steht doch für die Anzahl der maximalen Backups?
                      harrym 1 Reply Last reply Reply Quote 0
                      • harrym
                        harrym @MichMein last edited by
                        @MichMein history ist die datenbank .... falls du daten loggst
                        MichMein 1 Reply Last reply Reply Quote 0
                        • MichMein
                          MichMein @harrym last edited by
                          @harrym aha, ähnliches hatte ich vermutet war mir aber nicht ganz sicher. Danke
                            Mike Hellracer @simatec last edited by
                            @simatec
                            Ok nicht so schlimm.
                            Ich versuche es ein wenig einfacher zu formulieren und stelle es als request.
                            Vlt gibt es ja irgendwann mal die option des wöchentlich / monatlichen Backup.
                            • mickym
                              @simatec Habe ich gemacht - alles Bestens mit dem Fix - Status unverändert!
                              iobroker fix
                              library: loaded
                              Library version=2020-06-12
                                  Welcome to the ioBroker installation fixer!
                                  Script version: 2020-06-15
                                  You might need to enter your password a couple of times.
                                  Installing prerequisites (1/3)
                              Holen:1 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                              Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                              OK:3 https://deb.nodesource.com/node_12.x buster InRelease
                              Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [330 kB]
                              Es wurden 378 kB in 2 s geholt (238 kB/s).
                              Installed gcc-c++
                                  Checking ioBroker user and directory permissions (2/3)
                              Created /etc/sudoers.d/iobroker
                              Fixing directory permissions...
                                  Checking autostart (3/3)
                              Enabling autostart...
                              Autostart enabled!
                                  Your installation was fixed successfully
                                  Run iobroker start to start ioBroker again!
                              Gleiches Ergebnis - der Adapter fasst die zigbee- Dateien nicht an.
                              2020-09-04 19:07:39.892 - info: host.MWHome instance system.adapter.backitup.0 started with pid 15511
                              2020-09-04 19:07:42.802 - debug: backitup.0 (15511) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2020-09-04 19:07:42.835 - debug: backitup.0 (15511) Objects client ready ... initialize now
                              2020-09-04 19:07:42.838 - debug: backitup.0 (15511) Objects create System PubSub Client
                              2020-09-04 19:07:42.840 - debug: backitup.0 (15511) Objects create User PubSub Client
                              2020-09-04 19:07:42.841 - debug: backitup.0 (15511) Objects client initialize lua scripts
                              2020-09-04 19:07:42.853 - debug: backitup.0 (15511) Objects connected to redis: 127.0.0.1:9001
                              2020-09-04 19:07:42.859 - debug: backitup.0 (15511) objectDB connected
                              2020-09-04 19:07:42.862 - debug: backitup.0 (15511) Redis States: Use Redis connection: 127.0.0.1:9000
                              2020-09-04 19:07:42.869 - debug: backitup.0 (15511) States create User PubSub Client
                              2020-09-04 19:07:42.872 - debug: backitup.0 (15511) States create System PubSub Client
                              2020-09-04 19:07:42.881 - debug: backitup.0 (15511) States connected to redis: 127.0.0.1:9000
                              2020-09-04 19:07:42.882 - debug: backitup.0 (15511) statesDB connected
                              2020-09-04 19:07:43.291 - debug: backitup.0 (15511) Plugin sentry Initialize Plugin (enabled=true)
                              2020-09-04 19:07:43.495 - info: backitup.0 (15511) starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
                              2020-09-04 19:07:43.630 - info: backitup.0 (15511) [iobroker] backup was activated at 19:08 every 1 day(s)
                              2020-09-04 19:07:43.644 - debug: backitup.0 (15511) No backup file was found
                              2020-09-04 19:08:10.161 - debug: backitup.0 (15511) Backup has started ...
                              2020-09-04 19:08:12.731 - debug: backitup.0 (15511) [iobroker/iobroker] host.MWHome 3657 states saved
                              2020-09-04 19:08:12.760 - debug: backitup.0 (15511) [iobroker/iobroker] host.MWHome 3310 objects saved
                              2020-09-04 19:11:10.489 - debug: backitup.0 (15511) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_04-19_08_10_backupiobroker.tar.gz
                              2020-09-04 19:11:11.517 - debug: backitup.0 (15511) [iobroker/iobroker] done
                              2020-09-04 19:11:11.780 - debug: backitup.0 (15511) [iobroker/mysql] MySql File deleted!
                              2020-09-04 19:11:11.782 - debug: backitup.0 (15511) [iobroker/mysql] done
                              2020-09-04 19:11:11.793 - debug: backitup.0 (15511) [iobroker/zigbee] found zigbee database: zigbee.0
                              2020-09-04 19:11:11.794 - debug: backitup.0 (15511) [iobroker/zigbee] done
                              2020-09-04 19:11:11.837 - debug: backitup.0 (15511) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_15-02_00_10_backupiobroker.tar.gz
                              2020-09-04 19:11:11.863 - debug: backitup.0 (15511) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_15-02_03_15_backupiobroker.tar.gz
                              2020-09-04 19:11:11.866 - debug: backitup.0 (15511) [iobroker/clean] done
                              2020-09-04 19:11:11.895 - debug: backitup.0 (15511) [iobroker] exec: done
                              2020-09-04 19:11:11.931 - debug: backitup.0 (15511) [iobroker/history] backitup.0.history.html
                              2020-09-04 19:11:11.934 - debug: backitup.0 (15511) [iobroker] exec: done
                              2020-09-04 19:11:11.937 - debug: backitup.0 (15511) [iobroker/history] backitup.0.history.json
                              2020-09-04 19:11:11.940 - debug: backitup.0 (15511) [iobroker] exec: done
                              • simatec
                                @mickym
                                Werde mir das die Tage noch einmal intensiver anschauen und testen.
                                • mickym
                                  @simatec OK Danke - so schlimm ist das Problem ja nicht - zudem die Dateien ja recht klein sind. Ich kanns ja auch manuell erst mal löschen.
                                  Aber schau mal - ich wusste doch, dass ich das schon mal gelesen hatte von dem Problem und auch der Screenshot zeigt auch hier, dass es sich nur um die zigbee Backups handelt. Also scheine ich nicht alleine das Problem zu haben- und hat mE deshalb auch nichts mit Rechten zu tun, da die anderen Backups ja gelöscht werden.
                                  Hier ist wohl der Parallelthread
                                  • simatec
                                    Ab sofort ist die Version 1.6.5 auf Github und in Kürze auch im latest verfügbar ...
                                    Changelog
                                    1.6.5 (07.09.2020)
                                    • (simatec) Bugfix GoogleDrive Rate Limit errors
                                    • (simatec) small fixes on zigbee backup
                                    mickym 1 Reply Last reply Reply Quote 1
                                    • mickym
                                      @simatec Hallo - habe mich schon gefreut - und gleich getestet. 😉 - Leider gab es bei mir keinerlei Veränderungen. 😞
                                      Muss ich erst mal alle alten zigbee-Backups löschen bzw. aus dem Verzeichnis entfernen und dann warten?
                                      Hier wieder Auszug aus dem Log - die zigbee Backups werden gar nicht angefasst.
                                      2020-09-07 12:43:26.949 - info: host.MWHome instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2020-09-07 12:43:29.716 - info: host.MWHome instance system.adapter.backitup.0 started with pid 20066
                                      2020-09-07 12:43:32.649 - debug: backitup.0 (20066) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      2020-09-07 12:43:32.685 - debug: backitup.0 (20066) Objects client ready ... initialize now
                                      2020-09-07 12:43:32.689 - debug: backitup.0 (20066) Objects create System PubSub Client
                                      2020-09-07 12:43:32.691 - debug: backitup.0 (20066) Objects create User PubSub Client
                                      2020-09-07 12:43:32.692 - debug: backitup.0 (20066) Objects client initialize lua scripts
                                      2020-09-07 12:43:32.708 - debug: backitup.0 (20066) Objects connected to redis: 127.0.0.1:9001
                                      2020-09-07 12:43:32.716 - debug: backitup.0 (20066) objectDB connected
                                      2020-09-07 12:43:32.719 - debug: backitup.0 (20066) Redis States: Use Redis connection: 127.0.0.1:9000
                                      2020-09-07 12:43:32.758 - debug: backitup.0 (20066) States create User PubSub Client
                                      2020-09-07 12:43:32.769 - debug: backitup.0 (20066) States create System PubSub Client
                                      2020-09-07 12:43:32.787 - debug: backitup.0 (20066) States connected to redis: 127.0.0.1:9000
                                      2020-09-07 12:43:32.791 - debug: backitup.0 (20066) statesDB connected
                                      2020-09-07 12:43:33.311 - debug: backitup.0 (20066) Plugin sentry Initialize Plugin (enabled=true)
                                      2020-09-07 12:43:33.495 - info: backitup.0 (20066) starting. Version 1.6.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
                                      2020-09-07 12:43:33.575 - info: backitup.0 (20066) [iobroker] backup was activated at 12:45 every 1 day(s)
                                      2020-09-07 12:43:33.595 - debug: backitup.0 (20066) No backup file was found
                                      2020-09-07 12:45:10.176 - debug: backitup.0 (20066) Backup has started ...
                                      2020-09-07 12:45:12.690 - debug: backitup.0 (20066) [iobroker/iobroker] host.MWHome 3657 states saved
                                      2020-09-07 12:45:12.714 - debug: backitup.0 (20066) [iobroker/iobroker] host.MWHome 3310 objects saved
                                      2020-09-07 12:48:22.755 - debug: backitup.0 (20066) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_07-12_45_10_backupiobroker.tar.gz
                                      2020-09-07 12:48:23.818 - debug: backitup.0 (20066) [iobroker/iobroker] done
                                      2020-09-07 12:48:24.030 - debug: backitup.0 (20066) [iobroker/mysql] MySql File deleted!
                                      2020-09-07 12:48:24.032 - debug: backitup.0 (20066) [iobroker/mysql] done
                                      2020-09-07 12:48:24.040 - debug: backitup.0 (20066) [iobroker/zigbee] found zigbee database: zigbee.0
                                      2020-09-07 12:48:24.042 - debug: backitup.0 (20066) [iobroker/zigbee] done
                                      2020-09-07 12:48:24.066 - debug: backitup.0 (20066) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_19-02_00_10_backupiobroker.tar.gz
                                      2020-09-07 12:48:24.082 - debug: backitup.0 (20066) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_19-02_03_43_backupiobroker.tar.gz
                                      2020-09-07 12:48:24.086 - debug: backitup.0 (20066) [iobroker/clean] done
                                      2020-09-07 12:48:24.107 - debug: backitup.0 (20066) [iobroker] exec: done
                                      2020-09-07 12:48:24.147 - debug: backitup.0 (20066) [iobroker/history] backitup.0.history.html
                                      2020-09-07 12:48:24.150 - debug: backitup.0 (20066) [iobroker] exec: done
                                      2020-09-07 12:48:24.153 - debug: backitup.0 (20066) [iobroker/history] backitup.0.history.json
                                      2020-09-07 12:48:24.156 - debug: backitup.0 (20066) [iobroker] exec: done
                                      • simatec
                                        @mickym
                                        Habe es noch einmal getestet und kann keinen Fehler finden.
                                        Wo werden denn deine zigbee Backups nicht gelöscht?
                                        NAS, FTP, Google, Dropbox oder lokal?
                                        Am besten du löschst mal alle händisch und dann beobachten wir das mal genauer
                                        • mickym
                                          @simatec
                                          So alles ist lokal und auch im Standardverzeichnis /opt/iobroker/backups.
                                          In diesem Verzeichnis befinden sich (s. Screenshot und ls -la) sowohl die zigbee, mysql und iobroker backups. Also alles gleiches Verzeichnis und sowohl mysql und iobroker backups werden gelöscht. Somit sind irgendwelche Rechteprobleme beim Löschen ausgeschlossen - angelegt werden die Dateien ja auch.
                                          Nachdem das nun auch mit der neuen Version nicht funktioniert hat, habe ich folgendes gemacht:
                                          In der Konfiguration der backitup Instanz:
                                          1. zigbee backup - Haken entfernt - Adapter wurde neu gestartet
                                          2. zigbee backup - Haken wieder gesetzt - Adapter wurde neu gestartet
                                          3. alle zigbee backups von August bis Mai manuell aus dem Verzeichnis entfernt.
                                          4. Anzahl der Backups die aufgehoben werden sollen von 30 auf 15 reduziert.
                                          Folge war, dass nun eine Menge der iobroker und mysql Backups weggeschmissen wurden, aber die zigbee Backups wurden weiterhin nicht angefasst.
                                          Hier das LOG:
                                          2020-09-07 12:56:03.701 - info: host.MWHome instance system.adapter.backitup.0 started with pid 24208
                                          2020-09-07 12:56:06.594 - debug: backitup.0 (24208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2020-09-07 12:56:06.626 - debug: backitup.0 (24208) Objects client ready ... initialize now
                                          2020-09-07 12:56:06.629 - debug: backitup.0 (24208) Objects create System PubSub Client
                                          2020-09-07 12:56:06.631 - debug: backitup.0 (24208) Objects create User PubSub Client
                                          2020-09-07 12:56:06.632 - debug: backitup.0 (24208) Objects client initialize lua scripts
                                          2020-09-07 12:56:06.643 - debug: backitup.0 (24208) Objects connected to redis: 127.0.0.1:9001
                                          2020-09-07 12:56:06.650 - debug: backitup.0 (24208) objectDB connected
                                          2020-09-07 12:56:06.652 - debug: backitup.0 (24208) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2020-09-07 12:56:06.659 - debug: backitup.0 (24208) States create User PubSub Client
                                          2020-09-07 12:56:06.662 - debug: backitup.0 (24208) States create System PubSub Client
                                          2020-09-07 12:56:06.671 - debug: backitup.0 (24208) States connected to redis: 127.0.0.1:9000
                                          2020-09-07 12:56:06.672 - debug: backitup.0 (24208) statesDB connected
                                          2020-09-07 12:56:07.223 - debug: backitup.0 (24208) Plugin sentry Initialize Plugin (enabled=true)
                                          2020-09-07 12:56:07.419 - info: backitup.0 (24208) starting. Version 1.6.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
                                          2020-09-07 12:56:07.500 - info: backitup.0 (24208) [iobroker] backup was activated at 12:57 every 1 day(s)
                                          2020-09-07 12:56:07.514 - debug: backitup.0 (24208) No backup file was found
                                          2020-09-07 12:57:10.170 - debug: backitup.0 (24208) Backup has started ...
                                          2020-09-07 12:57:12.695 - debug: backitup.0 (24208) [iobroker/iobroker] host.MWHome 3657 states saved
                                          2020-09-07 12:57:12.728 - debug: backitup.0 (24208) [iobroker/iobroker] host.MWHome 3310 objects saved
                                          2020-09-07 13:00:29.277 - debug: backitup.0 (24208) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_07-12_57_10_backupiobroker.tar.gz
                                          2020-09-07 13:00:30.301 - debug: backitup.0 (24208) [iobroker/iobroker] done
                                          2020-09-07 13:00:30.470 - debug: backitup.0 (24208) [iobroker/mysql] MySql File deleted!
                                          2020-09-07 13:00:30.472 - debug: backitup.0 (24208) [iobroker/mysql] done
                                          2020-09-07 13:00:30.478 - debug: backitup.0 (24208) [iobroker/zigbee] found zigbee database: zigbee.0
                                          2020-09-07 13:00:30.480 - debug: backitup.0 (24208) [iobroker/zigbee] done
                                          2020-09-07 13:00:30.510 - debug: backitup.0 (24208) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_20-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:00:30.524 - debug: backitup.0 (24208) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_20-02_03_30_backupiobroker.tar.gz
                                          2020-09-07 13:00:30.528 - debug: backitup.0 (24208) [iobroker/clean] done
                                          2020-09-07 13:00:30.548 - debug: backitup.0 (24208) [iobroker] exec: done
                                          2020-09-07 13:00:30.602 - debug: backitup.0 (24208) [iobroker/history] backitup.0.history.html
                                          2020-09-07 13:00:30.605 - debug: backitup.0 (24208) [iobroker] exec: done
                                          2020-09-07 13:00:30.607 - debug: backitup.0 (24208) [iobroker/history] backitup.0.history.json
                                          2020-09-07 13:00:30.610 - debug: backitup.0 (24208) [iobroker] exec: done
                                          2020-09-07 13:06:06.985 - debug: backitup.0 (24208) system.adapter.admin.0: logging false
                                          2020-09-07 13:06:10.206 - info: host.MWHome stopInstance system.adapter.backitup.0 (force=false, process=true)
                                          2020-09-07 13:06:10.212 - info: host.MWHome stopInstance system.adapter.backitup.0 send kill signal
                                          2020-09-07 13:06:10.217 - info: backitup.0 (24208) Got terminate signal TERMINATE_YOURSELF
                                          2020-09-07 13:06:10.218 - info: backitup.0 (24208) cleaned everything up...
                                          2020-09-07 13:06:10.219 - info: backitup.0 (24208) terminating
                                          2020-09-07 13:06:10.220 - debug: backitup.0 (24208) Plugin sentry destroyed
                                          2020-09-07 13:06:10.220 - info: backitup.0 (24208) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2020-09-07 13:06:10.243 - debug: backitup.0 (24208) system.adapter.admin.0: logging true
                                          2020-09-07 13:06:10.752 - info: host.MWHome instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2020-09-07 13:06:13.261 - info: host.MWHome instance system.adapter.backitup.0 started with pid 27657
                                          2020-09-07 13:06:16.133 - debug: backitup.0 (27657) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2020-09-07 13:06:16.165 - debug: backitup.0 (27657) Objects client ready ... initialize now
                                          2020-09-07 13:06:16.169 - debug: backitup.0 (27657) Objects create System PubSub Client
                                          2020-09-07 13:06:16.170 - debug: backitup.0 (27657) Objects create User PubSub Client
                                          2020-09-07 13:06:16.171 - debug: backitup.0 (27657) Objects client initialize lua scripts
                                          2020-09-07 13:06:16.183 - debug: backitup.0 (27657) Objects connected to redis: 127.0.0.1:9001
                                          2020-09-07 13:06:16.189 - debug: backitup.0 (27657) objectDB connected
                                          2020-09-07 13:06:16.192 - debug: backitup.0 (27657) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2020-09-07 13:06:16.199 - debug: backitup.0 (27657) States create User PubSub Client
                                          2020-09-07 13:06:16.202 - debug: backitup.0 (27657) States create System PubSub Client
                                          2020-09-07 13:06:16.211 - debug: backitup.0 (27657) States connected to redis: 127.0.0.1:9000
                                          2020-09-07 13:06:16.212 - debug: backitup.0 (27657) statesDB connected
                                          2020-09-07 13:06:16.688 - debug: backitup.0 (27657) Plugin sentry Initialize Plugin (enabled=true)
                                          2020-09-07 13:06:16.844 - info: backitup.0 (27657) starting. Version 1.6.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
                                          2020-09-07 13:06:16.903 - info: backitup.0 (27657) [iobroker] backup was activated at 12:57 every 1 day(s)
                                          2020-09-07 13:06:16.923 - debug: backitup.0 (27657) No backup file was found
                                          2020-09-07 13:06:35.692 - info: host.MWHome stopInstance system.adapter.backitup.0 (force=false, process=true)
                                          2020-09-07 13:06:35.704 - info: host.MWHome stopInstance system.adapter.backitup.0 send kill signal
                                          2020-09-07 13:06:35.714 - info: backitup.0 (27657) Got terminate signal TERMINATE_YOURSELF
                                          2020-09-07 13:06:35.717 - info: backitup.0 (27657) cleaned everything up...
                                          2020-09-07 13:06:35.719 - info: backitup.0 (27657) terminating
                                          2020-09-07 13:06:35.721 - debug: backitup.0 (27657) Plugin sentry destroyed
                                          2020-09-07 13:06:35.723 - info: backitup.0 (27657) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2020-09-07 13:06:36.283 - info: host.MWHome instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          2020-09-07 13:06:38.790 - info: host.MWHome instance system.adapter.backitup.0 started with pid 27777
                                          2020-09-07 13:06:41.613 - debug: backitup.0 (27777) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2020-09-07 13:06:41.659 - debug: backitup.0 (27777) Objects client ready ... initialize now
                                          2020-09-07 13:06:41.664 - debug: backitup.0 (27777) Objects create System PubSub Client
                                          2020-09-07 13:06:41.665 - debug: backitup.0 (27777) Objects create User PubSub Client
                                          2020-09-07 13:06:41.667 - debug: backitup.0 (27777) Objects client initialize lua scripts
                                          2020-09-07 13:06:41.691 - debug: backitup.0 (27777) Objects connected to redis: 127.0.0.1:9001
                                          2020-09-07 13:06:41.698 - debug: backitup.0 (27777) objectDB connected
                                          2020-09-07 13:06:41.700 - debug: backitup.0 (27777) Redis States: Use Redis connection: 127.0.0.1:9000
                                          2020-09-07 13:06:41.708 - debug: backitup.0 (27777) States create User PubSub Client
                                          2020-09-07 13:06:41.711 - debug: backitup.0 (27777) States create System PubSub Client
                                          2020-09-07 13:06:41.720 - debug: backitup.0 (27777) States connected to redis: 127.0.0.1:9000
                                          2020-09-07 13:06:41.721 - debug: backitup.0 (27777) statesDB connected
                                          2020-09-07 13:06:42.525 - debug: backitup.0 (27777) Plugin sentry Initialize Plugin (enabled=true)
                                          2020-09-07 13:06:42.725 - info: backitup.0 (27777) starting. Version 1.6.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.18.3, js-controller: 3.1.6
                                          2020-09-07 13:06:42.781 - info: backitup.0 (27777) [iobroker] backup was activated at 13:07 every 1 day(s)
                                          2020-09-07 13:06:42.801 - debug: backitup.0 (27777) No backup file was found
                                          2020-09-07 13:07:10.170 - debug: backitup.0 (27777) Backup has started ...
                                          2020-09-07 13:07:12.639 - debug: backitup.0 (27777) [iobroker/iobroker] host.MWHome 3657 states saved
                                          2020-09-07 13:07:12.680 - debug: backitup.0 (27777) [iobroker/iobroker] host.MWHome 3310 objects saved
                                          2020-09-07 13:10:28.859 - debug: backitup.0 (27777) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_07-13_07_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:29.902 - debug: backitup.0 (27777) [iobroker/iobroker] done
                                          2020-09-07 13:10:32.432 - debug: backitup.0 (27777) [iobroker/mysql] MySql File deleted!
                                          2020-09-07 13:10:32.436 - debug: backitup.0 (27777) [iobroker/mysql] done
                                          2020-09-07 13:10:32.444 - debug: backitup.0 (27777) [iobroker/zigbee] found zigbee database: zigbee.0
                                          2020-09-07 13:10:32.446 - debug: backitup.0 (27777) [iobroker/zigbee] done
                                          2020-09-07 13:10:32.469 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_03-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.482 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_02-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.485 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_01-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.498 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_31-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.507 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_30-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.522 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_29-03_45_32_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.531 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_29-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.546 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_29-01_15_37_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.552 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_28-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.562 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_27-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.578 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_26-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.588 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_25-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.598 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_24-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.609 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_23-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.616 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_22-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.626 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_08_21-02_00_10_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.640 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_09_03-02_03_23_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.644 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_09_02-02_03_39_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.650 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_09_01-02_03_33_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.655 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_31-02_03_26_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.659 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_30-02_03_53_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.666 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_29-03_48_32_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.670 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_29-02_03_28_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.676 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_29-01_18_56_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.679 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_28-02_03_25_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.685 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_27-02_03_23_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.690 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_26-02_03_35_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.695 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_25-02_03_19_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.700 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_24-02_03_12_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.705 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_23-02_03_23_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.711 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_22-02_03_12_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.721 - debug: backitup.0 (27777) [iobroker/clean] delete /opt/iobroker/backups/mysql_2020_08_21-02_03_24_backupiobroker.tar.gz
                                          2020-09-07 13:10:32.726 - debug: backitup.0 (27777) [iobroker/clean] done
                                          2020-09-07 13:10:32.773 - debug: backitup.0 (27777) [iobroker] exec: done
                                          2020-09-07 13:10:32.874 - debug: backitup.0 (27777) [iobroker/history] backitup.0.history.html
                                          2020-09-07 13:10:32.877 - debug: backitup.0 (27777) [iobroker] exec: done
                                          2020-09-07 13:10:32.880 - debug: backitup.0 (27777) [iobroker/history] backitup.0.history.json
                                          2020-09-07 13:10:32.886 - debug: backitup.0 (27777) [iobroker] exec: done
                                          cat backups.txt
                                          insgesamt 1182064
                                          drwxr-xr-x 2 iobroker iobroker    20480 Sep  7 13:10 .
                                          drwxrwxr-x 4 root     adm          4096 Sep 10  2019 ..
                                          -rw-r--r-- 1 iobroker iobroker 80288808 Sep  4 00:54 iobroker_2020_09_04-00_51_17_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80288864 Sep  4 00:59 iobroker_2020_09_04-00_55_45_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80288796 Sep  4 02:03 iobroker_2020_09_04-02_00_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80305811 Sep  4 15:56 iobroker_2020_09_04-15_53_26_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80306117 Sep  4 17:29 iobroker_2020_09_04-17_26_37_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80306331 Sep  4 17:53 iobroker_2020_09_04-17_50_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80306445 Sep  4 18:23 iobroker_2020_09_04-18_20_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80306132 Sep  4 18:35 iobroker_2020_09_04-18_32_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80308902 Sep  4 19:11 iobroker_2020_09_04-19_08_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80303733 Sep  5 02:03 iobroker_2020_09_05-02_00_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80304698 Sep  6 02:03 iobroker_2020_09_06-02_00_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80305650 Sep  7 02:03 iobroker_2020_09_07-02_00_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80303920 Sep  7 12:48 iobroker_2020_09_07-12_45_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80304328 Sep  7 13:00 iobroker_2020_09_07-12_57_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker 80304001 Sep  7 13:10 iobroker_2020_09_07-13_07_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker  1888533 Dez 20  2019 minimal_2019_12_20-23_35_48_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker  1888770 Dez 20  2019 minimal_2019_12_20-23_44_54_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker  1891755 Dez 21  2019 minimal_2019_12_21-02_00_10_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  4 00:54 mysql_2020_09_04-00_54_55_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1057 Sep  4 00:59 mysql_2020_09_04-00_59_09_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1057 Sep  4 02:03 mysql_2020_09_04-02_03_27_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1057 Sep  4 15:56 mysql_2020_09_04-15_56_30_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1060 Sep  4 17:29 mysql_2020_09_04-17_29_51_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  4 17:53 mysql_2020_09_04-17_53_25_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  4 18:23 mysql_2020_09_04-18_23_24_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1060 Sep  4 18:35 mysql_2020_09_04-18_35_25_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1057 Sep  4 19:11 mysql_2020_09_04-19_11_11_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  5 02:03 mysql_2020_09_05-02_03_24_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  6 02:03 mysql_2020_09_06-02_03_16_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1057 Sep  7 02:03 mysql_2020_09_07-02_03_11_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  7 12:48 mysql_2020_09_07-12_48_23_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  7 13:00 mysql_2020_09_07-13_00_30_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     1058 Sep  7 13:10 mysql_2020_09_07-13_10_29_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2697 Sep  1 02:03 zigbee.0_2020_09_01-02_03_34_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2685 Sep  2 02:03 zigbee.0_2020_09_02-02_03_44_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2685 Sep  3 02:03 zigbee.0_2020_09_03-02_03_24_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2713 Sep  4 00:54 zigbee.0_2020_09_04-00_54_55_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2713 Sep  4 00:59 zigbee.0_2020_09_04-00_59_11_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2713 Sep  4 02:03 zigbee.0_2020_09_04-02_03_27_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2701 Sep  4 15:56 zigbee.0_2020_09_04-15_56_30_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2701 Sep  4 17:29 zigbee.0_2020_09_04-17_29_51_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2701 Sep  4 17:53 zigbee.0_2020_09_04-17_53_28_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2701 Sep  4 18:23 zigbee.0_2020_09_04-18_23_24_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2701 Sep  4 18:35 zigbee.0_2020_09_04-18_35_25_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2710 Sep  4 19:11 zigbee.0_2020_09_04-19_11_11_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2687 Sep  5 02:03 zigbee.0_2020_09_05-02_03_24_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2687 Sep  6 02:03 zigbee.0_2020_09_06-02_03_16_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2687 Sep  7 02:03 zigbee.0_2020_09_07-02_03_14_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2687 Sep  7 12:48 zigbee.0_2020_09_07-12_48_24_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2687 Sep  7 13:00 zigbee.0_2020_09_07-13_00_30_backupiobroker.tar.gz
                                          -rw-r--r-- 1 iobroker iobroker     2687 Sep  7 13:10 zigbee.0_2020_09_07-13_10_32_backupiobroker.tar.gz
                                          Ich habe mir ja schon gedacht, dass evtl. die Anzahl der Dateien zum Bereinigen zuviel sind. Aber nun sind es nur noch 18 bei eingestellten 15 und wie gesagt, der fasst das ja laut Log nicht an.
                                          • mickym
                                            @simatec was meinst mit alle löschen - gar keine zigbees mehr, aber dann hat der Adapter ja nichts mehr zum löschen?
                                            170
                                            2780
                                            2344657
