    4. Test Adapter WhatsAPP-CMB
      liv-in-sky @sigi234 last edited by liv-in-sky
      @sigi234
      habe dieses blockly
       <variables>
         <variable id="TF3()M^!V42=QkiyOm+f">nachricht</variable>
         <variable id="my?#k2uA64T5eQ0-#.Wi">empfaenger</variable>
         <variable id="0/b1Xq;3ErYPhA!,E|A~">fritzboxDaten</variable>
       </variables>
       <block type="on" id="3mAnq90XGX#sQcRw+Da-" x="62" y="37">
         <field name="OID">0_userdata.0.Whatsapp.Nachricht</field>
           <block type="variables_set" id="Gx8{1il!]D/d|O(NfNuF">
             <field name="VAR" id="TF3()M^!V42=QkiyOm+f">nachricht</field>
               <block type="get_value" id="?7y)#g+teW$xgMU,;|#C">
               <block type="variables_set" id="ggiKBm9h^*~wYW|-d:=5">
                 <field name="VAR" id="my?#k2uA64T5eQ0-#.Wi">empfaenger</field>
                   <block type="get_value" id="ii[@en/*KayJ13sH76({">
                     <field name="OID">0_userdata.0.Whatsapp.Empfaenger</field>
                   <block type="whatsapp-cmb" id="]KokBjSl=4abZZNgZ2M,">
                     <field name="INSTANCE">.0</field>
                     <field name="LOG"></field>
                     <value name="MESSAGE">
                       <shadow type="text" id="y~./:CUX~M|;Y$dwx6~.">
                       <block type="variables_get" id="t:/f?u9[,vh)gkv,HOt+">
                     <value name="PHONE">
                       <block type="variables_get" id="ix`%.`_jeB:5qyNP43V+">
       <block type="comment" id="P/;:xv6E`R%m#tbg-67q" x="713" y="12">
         <field name="COMMENT">beispiel fritzbox  anrufer weiterleiten</field>
           <block type="on" id="C~|R!i$v7we|RhweNTap">
             <field name="OID">tr-064.0.callmonitor.inbound.json</field>
               <block type="variables_set" id="1ZRUV,C{kr{,:ZF2}k5F">
                 <field name="VAR" id="0/b1Xq;3ErYPhA!,E|A~">fritzboxDaten</field>
                   <block type="procedures_callcustomreturn" id="L%Zm9CFNu/,v?j+;1415">
                     <mutation name="etwas tun"></mutation>
                   <block type="control" id="NkK=xjWivX9PS(r$0fsc">
                       <block type="variables_get" id="NN?$T#qfvJ:v2liYNzH^">
       <block type="procedures_defcustomreturn" id="V?trlfmJQv7Kn*3CT+da" x="713" y="287">
         <mutation statements="false"></mutation>
         <field name="NAME">etwas tun</field>
         <field name="SCRIPT">DQpsZXQgbXlEYXRhID0gSlNPTi5wYXJzZShnZXRTdGF0ZSgidHItMDY0LjAuY2FsbG1vbml0b3IuaW5ib3VuZC5qc29uIikudmFsKQ0KDQoNCg0KcmV0dXJuIGBBbnJ1ZiBhbiBGcml0emJveA0KTnVtbWVyOiAke215RGF0YS5jYWxsZXJ9XG4NCk5hbWU6ICR7bXlEYXRhLmNhbGxlck5hbWV9XG4NClVocnplaXQ6ICR7bXlEYXRhLnRpbWVzdGFtcH1gOw==</field>
      das hat 2 datenpunkte - empfänger und nachricht (selber anlegen) - wenn nun jmd in der fritzbox anruft - schreibt die nummer und den empfänger in den datenpunkt nachricht- dann kommt die message - natürlich ist bis dahin der anruf vorbei - aber wenn du unterwegs bist, weißt du, wer angerufen hat - ich habe im moment nur meine nummer im dp empfänger
      das blockly triggert auf nachricht dp - wenn du eine andere nummer angeben willst, zuerst den empfänger datenpunkt schreiben und dann den text - dann wird getriggert
        sigi234 Forum Testing Most Active @liv-in-sky last edited by
        @liv-in-sky sagte in Test Adapter WhatsAPP-CMB:
        Welche Werte?
        Wo?
          @sigi234 du mußt die beiden datenpunkte selber in deinem system anlegen (beide sind zeichenfolge/strings)) und dann im blockly korrigieren
          bei mir
            @sigi234
            um eine nachricht (alarm) zu senden, schreibst du nach dem einrichten der datenpunkte und des scriptes in jedem anderen script, in dem du einen alarm versenden willst einfach nur in den datenpunkt "nachricht" - dann wird das gesendet an den empfänger der im datenpunkt empfänger steht (bei mir ist das nur eine nummer, daher steht im datenpunkt empfänger immer meine telefonnummer
            möchte man an einen andere nummer senden, mußt du zuerst den datenpunjkt empfänger schreiben (mit der gewünschten nummer) und dann erst den datenpunkt nachricht - denn auf diesen wird getriggert
              @sigi234
              oder ganz einfach - nur für die fritzbox benachrichtigung:
               <block type="comment" id="{Y]qq+v3Mbp[^/L0@|m$" x="512" y="237">
                 <field name="COMMENT">fritzbox anruf</field>
                           <block type="procedures_callcustomreturn" id="s!flgU^ekzRrm=m,Q?*f">
                Danke, läuft.👍
                • harrym
                  harrym last edited by
                  2020-09-02 19:51:19.846 - error: whatsapp-cmb.1 (32416) Cannot send message:
                  Message to: xxxxxx
                  Text to send: xxxxxx
                  There was an ERROR!!!
                  Error Num:2
                  Error Text:mysqli::__construct(): (HY000/2002): Connection timed out
                  Was will mir der Error genau sagen? Timed Out beim bot?
                    michihorn @harrym last edited by michihorn
                    Ich hatte den Adapter auch laufen, seit heute bekomme ich aber Fehler im LOG
                    whatsapp-cmb.0	2020-09-02 22:26:00.227	error	(1784) Cannot send message: <p>Message to: +4915253938xxx<p>Text to send: Rtest<p>There was an ERROR!!!<p><u>Error Num:</u>2<p><u>Error Text:</u>mysqli::__construct(): (HY000/2002): Connection timed o
                    whatsapp-cmb.0	2020-09-02 22:26:00.010	info	(1784) Send Rtest to +4915253938xxx
                    whatsapp-cmb.0	2020-09-02 22:25:00.028	info	(1784) Send Rtest to +4915253938xxx
                    Habe die 1.1.6 installiert
                    Michael
                      el_malto last edited by
                      Warum sind die Telefonnummern auf Github und der Homepage unterschiedlich?
                      harrym 1 Reply Last reply Reply Quote 0
                      • harrym
                        harrym @el_malto last edited by
                        @el_malto und warum @Homoran und @sigi234 haben ösis 664 ala Freud im Kopf?
                          el_malto @harrym last edited by
                          @harrym sagte in Test Adapter WhatsAPP-CMB:
                          • da_Woody
                            da_Woody @el_malto last edited by
                            @el_malto weil bei uns ein anbieter 664 als handyvorwahl hat und wir das automatisch lesen und statt 644 eingeben. die macht der gewohnheit... 😉 ich bin auch auf die schnauze gefallen...
                              el_malto @da_Woody last edited by
                              @da_Woody das war ja aber nur ein Tippfehler eurerseits. Auf Github und der HP stehen aber wirklich zwei unterschiedliche Nummern.
                              • da_Woody
                                @el_malto jap, schau mal nach meinem posting vom 2. September. 😉
                                und dann schlug der tappfühler auch noch zu. 😄
                                  @da_Woody ja das ist mir alles klar. Erklärt aber nicht warum da nun zwei unterschiedliche Nummern stehen.
                                  • da_Woody
                                    da_Woody @el_malto last edited by da_Woody
                                    @el_malto rischtisch, erklärts nicht. denk mal, dadurch das ganze ja noch beta ist, einfach vergessen wurde die nummer zu ändern.
                                    edith: grad nachgelinst. der blogbeitrag ist von March 28, 2020...
                                      Vielleicht kann da @Bluefox ja was zu sagen.
                                      Des Weiteren würde mich die Privatsphäre interessieren. Die Nachrichten werden ja über einer dieser Nummern versendet. Der "Eigentümer" der Nummer müsste ja eigentlich alle Nachrichten einsehen können.
                                      da_Woody Bluefox 2 Replies Last reply Reply Quote 0
                                      • da_Woody
                                        @el_malto wie kommst du auf die idea?
                                        wenn du dir den link anschaust
                                        https://api.callmebot.com/whatsapp.php?phone=[phone_number]&text=[message]&apikey=[your_apikey]
                                        gibts da nur die nummer an den du verschickst, die message und deinen apikey.
                                          @da_Woody und von welcher Nummer bekommst du die Nachrichten?
                                          • da_Woody
                                            @el_malto ja und? selbst wenn das jemand lesen sollte, weis er halt das die WaMa, oder der Trockner fertig ist. IMHO wird das einfach durchgereicht, wenn nicht sogar verschlüsselt. da bin ich etwas schmerzbefreit. privates geht sicher nicht über den broker raus.
                                            adapter tester
                                            47
                                            172
                                            38470
