    5. Sendto (Mail kommen dauernd)!?
      Homoran Global Moderator Administrators @BLRD last edited by
      @BLRD dann mach mal einen Export
        BLRD @Homoran last edited by BLRD
        @Homoran
        Bitte schön:
          <variables>
            <variable type="timeout" id="timeout2">timeout2</variable>
          </variables>
          <block type="on" id="sh_6?8^;9ExO-}/4Dx:." x="-162" y="-212">
            <field name="OID">paw.0.SM-G975F.info.battery.level</field>
              <block type="controls_if" id="CI$h@O!ge0Zuvw#O,7%y">
                  <block type="logic_compare" id="CtN*18c!yPmh!L-ar{o$">
                    <field name="OP">LTE</field>
                      <block type="get_value" id="y6SiNnTcOh/x=P2Ie/.D">
                      <block type="math_number" id="SfOi94m6!*DR]4wQkHWC">
                        <field name="NUM">16</field>
                  <block type="control" id="xMKb+i^s]uHe4{f^dgmL">
                    <field name="OID">sonoff.0.SonoffDRNr6STSZ.POWER</field>
                      <block type="logic_boolean" id="C)jl1W_Ggi9m.yS/.e!U">
                      <block type="timeouts_settimeout" id="o^M.H~G-gM*13]=[Y;t=">
                        <field name="DELAY">1</field>
                          <block type="email" id="c^1YAQq[9;XSU~ESj:@%">
                            <field name="INSTANCE">.0</field>
                            <field name="IS_HTML">TRUE</field>
                            <field name="LOG"></field>
                            <value name="TO">
                              <shadow type="text" id="M4Y/2YvI/VN$(alq{Z,D">
                                <field name="TEXT">Gelöscht!</field>
                            <value name="TEXT">
                              <shadow type="text" id="vVZ2Cdt6V`$!K[:3U+g^">
                                <field name="TEXT">Handy wird geladen !</field>
                            <value name="SUBJECT">
                              <shadow type="text" id="9.X--}ix]gEKn!ythfn|">
                          <block type="timeouts_cleartimeout" id="TX2uqN-xrJ~F^ta`!gvI">
                <value name="IF1">
                  <block type="logic_compare" id="l;ns{D^Q)3;aLtd~Cema">
                    <field name="OP">GTE</field>
                      <block type="get_value" id="$$L!iJarhK;9B:sU=DeP">
                      <block type="math_number" id="Km~-p2@r7ayYw;0}6lCP">
                        <field name="NUM">85</field>
                <statement name="DO1">
                  <block type="control" id="f60qJA%{@*P)F4ZT+|6+">
                      <block type="logic_boolean" id="},/;ADTzl5ym^:fr,tTa">
                      <block type="timeouts_settimeout" id="h6h?^r*KD1LZQ|EGRaha">
                          <block type="email" id="Bkg^?/-3v1;n^5=PK@a@">
                            <value name="TO">
                              <shadow type="text" id=".fm=Rk(N8m{mz^UVp33m">
                            <value name="TEXT">
                              <shadow type="text" id="Ufspt[!gJWLZi7|{rhxL">
                                <field name="TEXT">Handy wird nicht geladen !</field>
                              <shadow type="text" id="F@`oz|/UPf)cq$8$LhT-">
                          <block type="timeouts_cleartimeout" id="=Wu~k/SbK?ozKBY#]7)p">
          @BLRD nutzt nix - kann ich nicht importieren
            crunchip Forum Testing Most Active @BLRD last edited by crunchip
            @BLRD nicht vom sonoff, sondern vom paw.0
            Zum battery.level gibt es wahrscheinlich noch einen paw.0.xyz.plugged/charging oder so in der Art
              paul53 @BLRD last edited by paul53
              @BLRD sagte:
              Bitte schön:
              Vorschlag:
               <variables>
                 <variable id="o5QWq1D-uG;sTenPDfvN">laden</variable>
                 <variable id="gkq+0V)+.8?y$@tO!n:l">msg</variable>
               </variables>
                           <block type="on_source" id="+tgC2FeeP-t6(#I#78sX">
                       <block type="variables_set" id="1;?}XCYp^byO;gy^O2@A">
                         <field name="VAR" id="o5QWq1D-uG;sTenPDfvN">laden</field>
                           <block type="logic_boolean" id="WgQ0([/)DWM5/eaBRVki">
                           <block type="variables_set" id="}7W[2Vy[mlFnDLV@Sg#b">
                             <field name="VAR" id="gkq+0V)+.8?y$@tO!n:l">msg</field>
                               <block type="text" id="1WkJE4,cqqho{[hL]n~F">
                     <value name="IF1">
                           <block type="on_source" id="tzHBF]WB=%[rk-xpo9l|">
                       <block type="variables_set" id="ELB.|ah!Fiv3aQ6@8pf=">
                           <block type="logic_boolean" id="B@Ge,Laaw5c}#yqyDajk">
                           <block type="variables_set" id="sVKmL1oqI9rAR.)R;bf}">
                               <block type="text" id="L`C/*L{_kNMN$]T!{{*{">
                       <block type="controls_if" id="u}DJxe5;6%N]U{*k*[G1">
                           <block type="logic_compare" id="hy(~rHnh9(9kbsEnve?U">
                             <field name="OP">NEQ</field>
                               <block type="variables_get" id="=YrpL4}hjW+AK_9Z]kjy">
                               <block type="get_value_var" id="WSdI_4h)+G?V~(q|v?jF">
                                 <value name="OID">
                                   <shadow type="text" id=")AZRTGG%av*E|jhn2`0C">
                                     <field name="TEXT">sonoff.0.SonoffDRNr6STSZ.POWER</field>
                               <block type="variables_get" id="U[;@I~N.b,oAMl^N28B9">
                                 <value name="TO">
                                 <value name="TEXT">
                                   <block type="variables_get" id="3F[s#5(mj6~*)!Nqr2zo">
                                   <block type="variables_get" id="bpOd/R~)a*h]@-6#Td+v">
              Homoran B 2 Replies Last reply Reply Quote 0
                @Homoran
                @crunchip
                Brauche ein moment, da der Rock abgestürzt ist.
                  Homoran Global Moderator Administrators @paul53 last edited by Homoran
                  @paul53 Danke!
                  ich denke ich konnte nicht importieren weil ich den email Block nicht hatte
                    BLRD @paul53 last edited by
                    @paul53 sagte in Sendto (Mail kommen dauernd)!?:
                    @Rushmed
                    @Homoran
                    @crunchip
                    Dank paul 53 scheint es so zu gehen!
                    Ich werde dies beobachten und in den nächsten Tage eine definitive Rückmledung geben.
                    Danle an Alle.
                    VG
                    BLRD
                      Dragon @BLRD last edited by
                      @BLRD Ich muss dich leider enttäuschen. inder Liste welche von dir gesendet wurde ist kein Datenpunkt vorhanden, da weder eine Ladezustand (%) oder ein Datenpunkt für plugged vorhanden ist. im Gegenteil darin ist gar kein Punkt enthalten der irgendetwas mit dem angeschlossenen Gerät zu tun hat.
                      Falls das hier ein Gerät mit Energiemessung ist in welches dein Gerät eingesteckt wird, dann könntest du den Energy_Current als trigger nutzen.
                      Sehe aber grad, dass du bereits eine Lösung gefunden hast.
                        Dragon @crunchip last edited by
                        @crunchip an den hatte ich auch gedacht, lässt sich nur aus seinen angaben nicht erschließen.
                          BLRD @BLRD last edited by
                          @crunchip
                          @David-Froebus
                          @Homoran
                          anbei die Rückmeldung.
                          Ich habe oben den Import von oben (07.09.;11:09 hvon paul53) umgesetzt.
                          Jedoch habe ich nun die Mail siebenfach bekommen.
                          Also diese kommen doch wieder vermehrt. Warum?
                          Danke.
                          VG
                          BLRD
                            @BLRD nur zur Sicherheit wäre es schön dein Blockly zu sehen, nicht dass da beim Anpassen etwas schief gelaufen ist
                              @Homoran
                              Bitte schön.
                                <variables>
                                </variables>
                                      <value name="IF1">
                                                  <value name="OID">
                                                  <value name="TO">
                                                      <field name="TEXT">Gelöscht</field>
                                                  <value name="TEXT">
                                @BLRD das lässt sich auf dem Handy nicht in Blockly umwandeln 😞
                                ich meinte "sehen" wörtlich 😉
                                  @Homoran
                                    Homoran Global Moderator Administrators @BLRD last edited by Homoran
                                    @BLRD leider sind Die Bezeichnungen der Datenpunkte abgeschnitten
                                    Gehen wir mal davon aus, dass es die richtigen sind, bleibt die Frage ob die Werte auch im richtigen Bereich sind.
                                    Hast du diese mal geloggt und "analysiert"?
                                    nicht dass bei Werten >85% immer mal wieder ein "null" oder "0" erscheint
                                    Hilfreich wäre dann auch der Inhalt der message - dann müsste immer abwechselnd wird geladen und wird nicht geladen kommen
                                      @Homoran
                                      Sorry die Datenpunkte sind die richtigen.
                                      Wie mache iich dies loggen und analysieren?
                                      Danke.
                                        @BLRD sagte in Sendto (Mail kommen dauernd)!?:
                                        Den Datenpunkt unter Objekte mit dem History-Adapter loggen, dann die geloggten Daten ansehen
                                          @Homoran
                                          Ok kommt dann.
                                            @Homoran
                                            Anbei dies:
                                            muss ich bei den Einstellungen noch was ändern, da so ganz ausagekräftig ist dies nicht.
                                            2020-09-09T09 10 02.752Z_50points_paw.0.SM-G975F.info.battery.level__history.0.csv
                                            Danke.
                                            1118
