    5. [gelöst] Waschmaschine/Trockner fertig
    • Phantomkommander
      Phantomkommander @ITCrowd last edited by
      @ITCrowd das blockly würde ich gerne mal ausprobieren. Würdest du es mir zur Verfügung stellen? 🙈
      • I
        ITCrowd @Phantomkommander last edited by ITCrowd
        @Phantomkommander ```
        <variables>
        <variable id="2KlqHZ;4GC+4e}]=n2">Lautstärke</variable>
        <variable id="AtH_kFvL]@aM;j?F;vw|">O_V_Alexa1</variable>
        <variable type="interval" id="Tick_1m">Tick_1m</variable>
        <variable id="(-92ai~xO3+X[TCGX0_">O_V_Alexa2</variable>
        <variable id="ROXk:)ndsMeX9csWRILz">Meldung_L</variable>
        <variable id=",J;nOmMBh{zSVR%,-6UX">O_S_Alexa1</variable>
        <variable id="|IZMxer2;YdsNXVuD=">Zähler_L</variable> <variable id="3GF+g~hD+u{;xNrDO@h6">O_S_Alexa2</variable> </variables> <block type="comment" id="C1TS:F;JeN4f-~ef%/#Y" x="13" y="13"> <field name="COMMENT">Tick_1m</field> <next> <block type="timeouts_setinterval" id="vZy@)c%*@9qOL0h%@;,G"> <field name="NAME">Tick_1m</field> <field name="INTERVAL">1</field> <field name="UNIT">min</field> <statement name="STATEMENT"> <block type="toggle" id="(_qzVDP.wG-u2b)9D1ow"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">0_userdata.0.DP_Allgemein.Tick_1m</field> <field name="WITH_DELAY">FALSE</field> </block> </statement> </block> </next> </block> <block type="variables_set" id="JmwzY/SJq@)TukF#p]uZ" x="13" y="138"> <field name="VAR" id="2KlqHZ;4GC+4e}]=n2">Lautstärke</field> <value name="VALUE"> <block type="math_number" id="{1N!?ISTYf)kf9k|aUh">
        <field name="NUM">35</field>
        <block type="variables_set" id="BOg;eMsB7w7E$kWWM?nV">
        <field name="VAR" id="AtH_kFvL]@aM;j?F;vw|">O_V_Alexa1</field>
        <block type="field_oid" id="F](b^V6/TP]hFo17G5?^">
        <field name="oid">alexa2.0.Echo-Devices.G090P308915205CX.Commands.speak-volume</field>
        <block type="variables_set" id="sPX*VP9@O51lS69WoD">
        <field name="VAR" id="(-92ai~xO3+X[TCGX0_">O_V_Alexa2</field>
        <block type="field_oid" id="Ha#I4)#iWQ#RESgPkwSI">
        <field name="oid">alexa2.0.Echo-Devices.G090U509848603VC.Commands.speak-volume</field>
        <block type="variables_set" id="S;|g(q.As|bdJ01N@%P"> <field name="VAR" id=",J;nOmMBh{zSVR%,-6UX">O_S_Alexa1</field> <value name="VALUE"> <block type="field_oid" id="zv:4McKr3:}uoTr9Dt?t"> <field name="oid">alexa2.0.Echo-Devices.G090P308915205CX.Commands.speak</field> </block> </value> <next> <block type="variables_set" id="T9p1^6~9[UiqA$baMmZ">
        <field name="VAR" id="3GF+g~hD+u{;xNrDO@h6">O_S_Alexa2</field>
        <block type="field_oid" id="HsBE;#}tBtrtn%wk#!F">
        <field name="oid">alexa2.0.Echo-Devices.G090U509848603VC.Commands.speak</field>
        <block type="schedule" id="FNPHMI4k%oWmRd+~B,:l" x="13" y="313">
        <field name="SCHEDULE">0 9 * * </field>
        <block type="variables_set" id="BMev:L38.d-nq%^4~CQ?">
        <block type="math_number" id=",eT4uxBCoE7a01h=~BC">
        <block type="schedule" id=":;azAAnVS}-9%Qs@dK">
        <field name="SCHEDULE">0 21 * * *</field>
        <block type="variables_set" id="w$Y.,29T4cUP;OfG-?3">
        <block type="math_number" id="ff/sOazFBuf9Y#CI)?(f">
        <field name="NUM">30</field>
        <block type="on_ext" id="oA36h6vbN8|i1PnKU{P" x="13" y="538"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="1"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="F}{o)*z$;u(kmrr=fdl+"> <field name="oid">0_userdata.0.DP_Allgemein.Tick_1m</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="3PE2ma]/f_03(um[t~Eu"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_compare" id="k3{j9Umw?iy#?LIxJ[/J"> <field name="OP">GT</field> <value name="A"> <block type="get_value" id="?I;.nBHX@-,)[[Qx#FTR"> <field name="ATTR">val</field> <field name="OID">sonoff.0.DVES_DBB6B4.ENERGY_Current</field> </block> </value> <value name="B"> <block type="math_number" id="f,M)V4Wd_1F3TS7|A84F"> <field name="NUM">0.5</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="_sm~y.(OrH-5?GMx!Iv">
        <field name="VAR" id="ROXk:)ndsMeX9csWRILz">Meldung_L</field>
        <block type="logic_boolean" id="9!he:ZmJOCmxdWM/J?F"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="=FIPC?2F0?PMy(WlnbuF"> <field name="VAR" id="|IZMx*er2;YdsNXVuD=">Zähler_L</field>
        <block type="math_number" id="G|foxL/Un3=}lxJyVfqD">
        <field name="NUM">0</field>
        <value name="IF1">
        <block type="logic_operation" id="n2}7jR7LDu4,mY]Ibc." inline="false">
        <field name="OP">AND</field>
        <block type="logic_compare" id="{c|47|voMaD,plPNw@N0">
        <field name="OP">LT</field>
        <block type="get_value" id="R]{Q+8vLT(d)$?bhwvDR">
        <block type="math_number" id="k.GQOs{83K+fIvu:2k_K">
        <field name="NUM">0.1</field>
        <block type="variables_get" id="ttfcY$oxpJx^m(%VHct}">
        <statement name="DO1">
        <block type="controls_if" id="N[taU#Tnkyf6:VIUO09x">
        <block type="logic_compare" id="RxRzmEK6Q$^=i;kFW0n0">
        <block type="variables_get" id="1]@T]Y.{{h?1OX5Te1XI">
        <field name="VAR" id="|IZMxer2;YdsNXVuD=">Zähler_L</field> </block> </value> <value name="B"> <block type="math_number" id="$8SYvFCwE-(0ybO/hULD"> <field name="NUM">5</field> </block> </value> </block> </value> <statement name="DO0"> <block type="math_change" id="EM$p37vj5Q{{C]jsWs/9"> <field name="VAR" id="|IZMx*er2;YdsNXVuD=">Zähler_L</field>
        <value name="DELTA">
        <shadow type="math_number" id="azoK3iowe][Qlq+FhH~w">
        <field name="NUM">1</field>
        <statement name="ELSE">
        <block type="debug" id="T=jI+0y-REES}/gXetd">
        <value name="TEXT">
        <shadow type="text" id="IUws6Mur{1Nm{lTvk{f.">
        <field name="TEXT">### Waschmaschine links fertig.</field>
        <block type="control" id="vA1CGC:$c/le=FU!wf)7">
        <field name="OID">0_userdata.0.DP_Allgemein.DP_StatusListe</field>
        <block type="text" id="i!Z5qx:R6Pa+W5gyO|+">
        <field name="TEXT">= Waschmaschine links fertig.</field>
        <block type="control_ex" id="{oLr6R[Q]#fqHF_-EE_J" inline="true">
        <value name="OID">
        <shadow type="field_oid" id="z+28]gjEW4z!S^9wvBO">
        <field name="oid">Object ID</field>
        <block type="variables_get" id="wlLlWszvDF3qCGsn9EN"> <field name="VAR" id="AtH_kFvL]@aM;j?F;vw|">O_V_Alexa1</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean" id="qP7si6f*A{[nxyj|R}-d"> <field name="BOOL">TRUE</field> </shadow> <block type="variables_get" id="4g(r/}q$2ipQg?X+FfA*"> <field name="VAR" id="2KlqHZ;4GC+4e}]=n2">Lautstärke</field> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="(i,_PgIW==|IdJ/.HdEq"> <field name="NUM">0</field> </shadow> </value> <next> <block type="control_ex" id="EqVK@S4zs/^LwnP1X5Kt" inline="true"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid"> <field name="oid">Object ID</field> </shadow> <block type="variables_get" id="h@$Pq[qjb#1%)jt^]oFp"> <field name="VAR" id="(-92ai~xO*3+X[TCGX0_">O_V_Alexa2</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean"> <field name="BOOL">TRUE</field> </shadow> <block type="variables_get" id="L1K-VBSA{nk~_Lu~]xYr"> <field name="VAR" id="2KlqHZ;4GC+4e}]=n2">Lautstärke</field> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="y6WtA#!XOhre%0Vt9d.u"> <field name="NUM">0</field> </shadow> </value> <next> <block type="control_ex" id="C5miROO@/(LT=f^ZYqLh" inline="true"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid"> <field name="oid">Object ID</field> </shadow> <block type="variables_get" id="0ZS(Th(0i#Wa9Eif]4Ho"> <field name="VAR" id=",J;nOmMBh{zSVR%,-6UX">O_S_Alexa1</field> </block> </value> <value name="VALUE"> <shadow type="logic_boolean" id="jN=nu2H1c#J}Zw[xh~eG"> <field name="BOOL">TRUE</field> </shadow> <block type="text" id="V$Zd/$}Q18Jy}faaz{+O"> <field name="TEXT">Das Waschprogramm der linken Waschmaschine wurde beendet.</field> </block> </value> <value name="DELAY_MS"> <shadow type="math_number" id="7PUi_Z|Z=dS_ej]y#*#">
        <block type="control_ex" id="SW90#+3@Raj7vSb(+KHN" inline="true">
        <value name="OID">
        <block type="variables_get" id="JiHpn96#vmfbXUAZ#;pf">
        <block type="text" id="FU)nu(WD6a{6Zocl8Hs">
        <shadow type="math_number" id=":,L[FXsr=M]I!yBpOF#=">
        <block type="variables_set" id="G=Kf3z3NKQBY7^x83$v9">
        <block type="logic_boolean" id="2D|_djAMg6)-9Y+%u^E0">
        <block type="variables_set" id=";@t{ux@#cl+IWv^:#:LD">
        <field name="VAR" id="|IZMxer2;YdsN`XVuD=">Zähler_L</field>
        <block type="math_number" id="%Q!-JYQ=3K;FQ[tn3tWl">
        [/s]
        • da_Woody
          da_Woody @ITCrowd last edited by
          @ITCrowd sorry, in code tags wäre das ganze brauchbarer und leserlicher.
          • Asgothian
            Asgothian Developer @init5 last edited by
            @init5 sagte in Waschmaschine/Trockner fertig:
            Ich hoffe so sehr, dass jemand von euch den Fehler findet. Es würde den WAF für weitere Projekte dienen
            Den Fehler.. so einfach ist das nicht. Fangen wir mal vorne an:
            • Du Triggerst auf "wurde aktualisiert", sprich das Skript springt auch dann an wenn sich die Leistungsaufnahme nicht ändert
            • Du nutzt für "WaMa_running" einen Datenpunkt. Da wäre eine Variable sinnvoller.
            • Du setzt den Zähler nur bei jedem Skriptstart auf 0.
            • Jede Sekunde den Wert Abfragen ist Unsinn. Insbesondere da der Wert von dem Skript bei jedem Trigger, sprich jeder Aktualisierung des Stromwertes bereits 3x abgefragt wird (neben 3x abfrage auf den Datenpunkt "WaMa_running"
            Das Thema synchronisieren mit einem "heartbeat" (wie @ITCrowd es nutzt) sollte zwar funktionieren, ist aber eigentlich unnötig. Insbesondere erzeugt es (wenn es viele Skripte synchronisiert) regelmässige Spikes weil alle Skripte gleichzeitig losrennen) Notwendig ist nur ein sauberes "entprellen" des Messwertes. Zu dem Thema gibt es einige Beispiele im Forum, trotzdem aber noch einmal hier als "pseudocode" zum nachbauen.
            Mit der Folgenden Logik sollte es gehen:
            • Eine Variable für "WaMa running", bei Skript start auf falsch setzen
            • Ein Trigger auf "power", triggern auf "wurde geändert" (NICHT wurde aktualisiert)
            • Im Trigger als erstes die Abfrage falls Wert > 100 (Hinweis zum "wert" Baustein siehe Bild - der Baustein in dem Objekt ID steht lässt sich auf Wert umstellen - er beinhaltet immer den Wert des Objektes welchen den Trigger ausgelöst hat.1599421354043-screen-shot-2020-09-06-at-21.38.08.png
            • im Falls-Zweig: falls nicht "WaMa running" -> WaMa running auf wahr setzen, Telegramm Nachricht senden.
            • sonst Falls "Wert" < 5 und "letzter Wert" >= 5 ("letzter Wert" ist der gleiche Baustein wie "Wert", der kann auch auf den Wert des Objektes direkt bevor der Trigger aktiviert wurde gesetzt werden) - Dadurch wird dieser Zweig nur angesprochen wenn der Wert von >- 5 auf kleiner 5 wechselt
            • timeout 60 sekunden - im Timeout: falls "wert von Objekt ID Power" (Hier wirklich den Datenpunktwert NEU holen, sonst wird das nichts) -> Nachricht an Telegramm, WaMa Running = falsch setzen.
            • im sonst Zweig (von dem oben angegebenen "sonst Falls" : Timeout löschen.
            Noch ein Nachtrag zum Thema "variable oder State" für "WaMa running". Eine Variable macht mehr sinn für den Einsatzzweck, sofern du diese nicht zusätzlich irgendwo nutzen willst (Anzeige das die WaMa läuft, etc.). Sollte also ein Datenpunkt genutzt werden, dann macht es sinn als ERSTES im Trigger den Datenpunkt zu lesen und in eine lokale Variable zu übernehmen. Diese kannst du dann im Trigger mehrfach abfragen ohne jedesmal in den Objektbaum zu schauen.
            A.
            p.s. ich geb das lieber als Pseudocode raus - selber bauen und nachvollziehen ist besser als kopieren und hoffen es passt.
            • I
              init5 @Asgothian last edited by init5
              @Asgothian Vielen Dank für das Feedback. Ich brauchte ein bisschen um zu sehen wie weit ich damit komme.
              Ich benötige einen Datenpunkt für die Weiterverarbeitung. Dieser wird zum einen in VIS angezeigt und zum Anderen in History geloggt.
              Ich check es leider nicht ganz, bzw. nur die ersten Punkte. Im unteren Teil steige ich aus.
              Das ist der Stand, den ich verstanden habe 😞
              Kommt das etwa hin?
              Der Tipp mit dem Objekt ID Block, der sich auf das Objekt im Trigger bezieht ist echt hilfreich!
              • I
                ITCrowd @da_Woody last edited by
                @da_Woody Sorry, war schon spät. 🙄
                • w00dst0ck
                  w00dst0ck last edited by
                  Ich bin am Ende bei dieser Keep-it-simple Variante in Verbindung mit einer Fritz DECT Steckdose gelandet.
                  Vielleicht funktioniert es ja auch bei Dir?!
                  Unsere Waschmaschine verbraucht am Ende weniger als 5 Watt für den Knitterschutz und wenn dazwischen unter 1 Watt. Ggf. musst Du das für Deine Waschmaschine anpassen...
                  • Asgothian
                    @init5 Nein, so geht es nicht. Versuch mal dieses:
                    wobei Das Objekt 1 das Power Objekt ist, und das Objekt 2 das Objekt WaMa_running ist.
                    • I
                      init5 @w00dst0ck last edited by init5
                      @w00dst0ck Bei der Variante würde ich entweder ständig Meldungen bekommen, wenn die WaMa eine Pause macht, oder aber ich würde gar keine Meldung bekommen, weil die WaMa auch im Standby (wenn sie fertig ist) über 2W braucht.
                      @Asgothian Danke, ich habe es jetzt entsprechende angepasst. Der nächste Waschgang wird zeigen, ob es jetzt funktioniert. Was mir noch etwas komisch erscheint ist dieses "falls nicht WaMa_running". Ich gehe mal davon aus, dass das "falls WaMa_running nicht true" bedeutet, aber die Notation ist wie gesagt komisch.
                      • Asgothian
                        Der Falls block erwartet eine "Bedingung", die "wahr" oder "falsch" sein kann. Bei einer Variablen X die selber "wahr" oder "falsch" sein kann ist also "falls X" das gleiche wie "falls X = wahr". Und da ich Faul bin hab ich mir den Logikblock gespart und einfach nur "WaMa_running" statt "WaMa_running = wahr" gesetzt. Dito oben - wie du auch schon richtig erkannt hast.
                        • I
                          @Asgothian es funktioniert leider nicht. Es kommen nach wie vor ständig "WaMa läuft" und "WaMa fertig" Meldungen 😞
                          • Asgothian
                            @init5 kannst du mal bitte aufzeichnen wie sich der Datenpunkt "power" über die Zeit verhält ? Ich bin mir sicher das sich da etwas bewegt.
                            A.
                            • I
                              @Asgothian Den Datenpunkt habe ich bereits aufgezeichnet. Aber nach was suchen wir da genau?
                              Das komische ist, dass die Meldungen sogar mehrmals pro Minute kommen. Dabei sollte das Timeout doch zumindest verursachen, dass der Status "WaMa running = true" mindestens die gewählte Zeit lang gehalten wird?
                              • Asgothian
                                @init5 Zeig mir die Aufzeichnung bitte mal
                                • Asgothian
                                  Asgothian Developer @Asgothian last edited by
                                  @Asgothian Und bitte auch das Skript so wie du es gerade laufen hast
                                  • I
                                    @Asgothian
                                    Ich hatte leider noch die Eigenschaft "entprellen - nur aufzeichnen, wenn Wert min. 1000ms gleich" aktiviert.
                                    0 true shelly.0 2020-09-08 18:23:15.182
                                    3.83 true shelly.0 2020-09-08 18:23:11.171
                                    15.8 true shelly.0 2020-09-08 18:22:59.408
                                    15.92 true shelly.0 2020-09-08 18:22:55.174
                                    16.06 true shelly.0 2020-09-08 18:22:45.186
                                    16.85 true shelly.0 2020-09-08 18:22:30.187
                                    16.93 true shelly.0 2020-09-08 18:22:15.182
                                    19.03 true shelly.0 2020-09-08 18:22:14.174
                                    136.9 true shelly.0 2020-09-08 18:22:12.174
                                    437.7 true shelly.0 2020-09-08 18:21:59.551
                                    436.94 true shelly.0 2020-09-08 18:21:54.174
                                    439.89 true shelly.0 2020-09-08 18:21:39.175
                                    415.76 true shelly.0 2020-09-08 18:21:31.186
                                    417.03 true shelly.0 2020-09-08 18:21:16.175
                                    395.72 true shelly.0 2020-09-08 18:21:10.216
                                    419.37 true shelly.0 2020-09-08 18:21:07.178
                                    463.1 true shelly.0 2020-09-08 18:21:03.176
                                    433.36 true shelly.0 2020-09-08 18:21:01.173
                                    367.92 true shelly.0 2020-09-08 18:21:00.172
                                    302.74 true shelly.0 2020-09-08 18:20:58.174
                                    271.32 true shelly.0 2020-09-08 18:20:57.174
                                    302.98 true shelly.0 2020-09-08 18:20:55.175
                                    559.35 true shelly.0 2020-09-08 18:20:52.175
                                    653.75 true shelly.0 2020-09-08 18:20:51.174
                                    700.72 true shelly.0 2020-09-08 18:20:49.177
                                    749.26 true shelly.0 2020-09-08 18:20:46.173
                                    353.25 true shelly.0 2020-09-08 18:20:43.176
                                    281.23 true shelly.0 2020-09-08 18:20:29.421
                                    282.14 true shelly.0 2020-09-08 18:20:14.423
                                    280.56 true shelly.0 2020-09-08 18:19:59.412
                                    281.52 true shelly.0 2020-09-08 18:19:44.441
                                    284.8 true shelly.0 2020-09-08 18:19:29.434
                                    288.18 true shelly.0 2020-09-08 18:19:14.424
                                    285.69 true shelly.0 2020-09-08 18:18:59.406
                                    286.6 true shelly.0 2020-09-08 18:18:46.181
                                    284.22 true shelly.0 2020-09-08 18:18:31.179
                                    286.5 true shelly.0 2020-09-08 18:18:16.182
                                    299.45 true shelly.0 2020-09-08 18:18:01.175
                                    258.98 true shelly.0 2020-09-08 18:17:59.416
                                    265.4 true shelly.0 2020-09-08 18:17:57.175
                                    558.79 true shelly.0 2020-09-08 18:17:43.177
                                    1034.19 true shelly.0 2020-09-08 18:17:40.178
                                    204.41 true shelly.0 2020-09-08 18:17:37.197
                                    199.74 true shelly.0 2020-09-08 18:17:22.176
                                    219.35 true shelly.0 2020-09-08 18:17:20.193
                                    249.79 true shelly.0 2020-09-08 18:17:19.178
                                    232.93 true shelly.0 2020-09-08 18:17:17.179
                                    90.04 true shelly.0 2020-09-08 18:17:14.176
                                    Das Skript sieht aus, wie du es vorgschlagen hast
                                    • Asgothian
                                      Asgothian Developer @init5 last edited by Asgothian
                                      @init5 Das mit dem entprellen solltest du noch einmal abschalten und neu aufnehmen. Am Besten dann als Textdatei oder Code hinter Spoiler posten.
                                      Ich gehe davon aus das bei den nicht entstellten Werten sich der Grund versteckt warum das Skript ständig "start" und "ende" meldet.
                                      Alternativ mal bitte vor jeweils vor dem Telegramm Baustein den Folgenden Baustein einbauen:
                                      und
                                      Dann kannst Du im Log sehen wie die Werte aussehen gestartet und angehalten wird.
                                      A.
                                      I 2 Replies Last reply Reply Quote 0
                                      • I
                                        @Asgothian Die beiden debug outputs hab ich eingebaut und morgen wird gewaschen. Die Werte aus meinem letzten Post in in einen Spoiler verpackt. Vielen Dank für deine Ausdauer!
                                        • I
                                          @Asgothian Heute liefen einige Waschgänge und was soll ich sagen ... es funktioniert. Dein Skript läuft und tut was es soll. Das Problem lag woanders. Und zwar habe ich beim vielen rumtesten immer mal den aktuellen Stand dupliziert. Scheinbar bin ich in der Zeile verrutscht und es lief nicht das aktuelle.
                                          Hier fehlte im Sonst Zweig die Bedingung "und vorheriger Wert >5". Zudem waren die Werte noch vom Typ Text und nicht aus dem Mathematik-Block, wie bei dir. Bei letzterem weiß ich nicht ob es einen Unterschied macht.
                                          Jetzt passt es auf jeden Fall und ich kann anfangen den Trockner mit zu überwachen und solche Späße wir den Verbrauch mit einzubauen. Vielen Dank!
                                          • Asgothian
                                            Das macht auf jeden Fall einen entsprechenden Unterschied. Textvergleich und numerischer Vergleich liefern nicht immer die gleichen Werte.
                                            Ansonsten, fein das es läuft. Ich hatte schon irgendwas komisches im Verdacht.
                                            A.
                                            blockly javascript
                                            10
                                            41
                                            4892
