    4. Apple Homekit Siri
    Apple Homekit Siri
    • eric2905
      eric2905 last edited by
      bei mir schmiert der Adapter ab.
      Hier das Log dazu:
      host-iobroker 2016-07-28 21:21:14.848 info instance system.adapter.homekit.0 started with pid 1734
      host-iobroker 2016-07-28 21:21:04.884 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      tankerkoenig-0 2016-07-28 21:21:04.371 info force terminating adapter after 1 minute
      host-iobroker 2016-07-28 21:20:44.842 info Restart adapter system.adapter.homekit.0 because enabled
      host-iobroker 2016-07-28 21:20:44.841 error instance system.adapter.homekit.0 terminated with code 0 (OK)
      Error: 2016-07-28 21:20:44.822 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Error: 2016-07-28 21:20:44.822 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
      Error: 2016-07-28 21:20:44.822 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
      Error: 2016-07-28 21:20:44.822 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
      Error: 2016-07-28 21:20:44.822 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
      Error: 2016-07-28 21:20:44.822 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:215:19)
      Error: 2016-07-28 21:20:44.822 error at require (internal/module.js:12:17)
      Error: 2016-07-28 21:20:44.822 error at Module.require (module.js:353:17)
      Error: 2016-07-28 21:20:44.822 error at Function.Module._load (module.js:276:25)
      Error: 2016-07-28 21:20:44.822 error at Function.Module._resolveFilename (module.js:325:15)
      Error: 2016-07-28 21:20:44.822 error Cannot find module 'hap-nodejs/node_modules/node-persist'
      uncaught 2016-07-28 21:20:44.821 error exception: Cannot find module 'hap-nodejs/node_modules/node-persist'
      homekit-0 2016-07-28 21:20:44.789 info hap-nodejs starting...
      homekit-0 2016-07-28 21:20:44.787 debug received all objects
      homekit-0 2016-07-28 21:20:44.394 debug received all states
      homekit-0 2016-07-28 21:20:43.344 debug requesting all objects
      homekit-0 2016-07-28 21:20:43.340 debug requesting all states
      homekit-0 2016-07-28 21:20:43.336 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.homekit
      homekit-0 2016-07-28 21:20:43.244 debug statesDB connected
      homekit-0 2016-07-28 21:20:43.231 debug objectDB connected
      host-iobroker 2016-07-28 21:20:42.559 info instance system.adapter.homekit.0 started with pid 1725
      Die Installation des Adapters lief ohne Probleme durch (Errorcode 0).
      Fehlt dem Adapter irgendwas an Installationsfiles?
      Gruß,
      Eric
        Michy last edited by
        Diese Fehler:
        schließen für mich auf das Fehlen von Modul node-persist hin…
        Die Version 0.1.5 bekomme ich übrigens nicht installiert.
        Hat die schon jemand installiert und getestet?!
        Gruß Michy
        • Bluefox
          Bluefox last edited by
          Es wird node 4.x.x gebraucht.
          • jens.maus
            jens.maus last edited by
            @Bluefox:
            Es wird node 4.x.x gebraucht. `
            Vielleicht solltest du überlegen das minimum an nodejs version auf 4.x.x zu pumpen und beim start von ioBroker darauf zu prüfen?
            Ich habe hier aber node 4.4.7 und dort bekomme ich aber trotzdem nicht das homekit mit ioBroker verbunden - es schmiert aber auch nicht ab?!?!
            • eric2905
              Hi Mich,
              @Michy:
              schließen für mich auf das Fehlen von Modul node-persist hin… `
              nee, das war's leider nicht - die Fehlermeldung bleibt gleich.
              Noch jemand eine Idee?
              Gruß,
              Eric
                @eric2905:
                Hi Mich,
                @Michy:
                Gruß,
                Eric `
                Hi Eric,
                Danke für dein Feedback! Dann müssen wir weiter suchen..
                Habe die aktuellste Version also, 4.x.x installiert. Bei mir kommt trotzdem der gleiche Fehler.
                Gruß Michy
                • Bluefox
                  Ich kann euch leider nicht helfen.
                  Aber im August sollte mein Nachbarn mit viel Apple Geräten den ioBroker installieren und ich hoffe, das ich bei ihm das testen kann.
                    @Bluefox:
                    Aber im August sollte mein Nachbarn mit viel Apple Geräten den ioBroker installieren und ich hoffe, das ich bei ihm das testen kann. `
                    Das wäre super. Mir fällt bisher erstmal kein möglicher Lösungsansatz ein.
                      Gibt es schon neue Erkenntnisse? Werde das gleiche später nochmal mit der IOS 10 Beta 3 versuchen,
                      denke aber nicht dass es das gewesen ist.
                      Gruß Michy
                        Griesemer last edited by
                        also ich bekomme weder die 0.1.4 noch die 0.1.5 stabil. Der Homekit Adapter veraschiedet sich regelmäßig nach wenigen Sekunden.
                        Hier ein Beispiel. Vielleicht hilft es ja beim debuggen.
                        ! host-ioBroker 2016-08-08 17:32:51.204 info instance system.adapter.homekit.0 terminated with code 0 (OK)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                        ! TypeError: 2016-08-08 17:32:51.057 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                        ! TypeError: 2016-08-08 17:32:51.057 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:280:67)
                        ! TypeError: 2016-08-08 17:32:51.057 error at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit/main.js:511:41)
                        ! TypeError: 2016-08-08 17:32:51.057 error Cannot read property 'CurrentRelativeHumidity' of undefined
                        ! uncaught 2016-08-08 17:32:51.051 error exception: Cannot read property 'CurrentRelativeHumidity' of undefined
                        ! homekit-0 2016-08-08 17:32:50.872 info hap-nodejs starting…
                        ! homekit-0 2016-08-08 17:32:44.580 info starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.homekit
                        ! host-ioBroker 2016-08-08 17:32:39.796 info instance system.adapter.homekit.0 started with pid 7457
                          @Griesemer:
                          ! host-ioBroker 2016-08-08 17:32:39.796 info instance system.adapter.homekit.0 started with pid 7457 `
                          Kommando zurück! Das hat mir ja keine Ruhe gelassen und nachdem ich die Instanz des Adapters gelöscht und neu installiert hatte, läuft es ohne Fehler im Log. Jetzt werde ich mich mal vorantasten. Wäre schön, wenn weitere Devices in den Adapter integriert würden; auf GitHub habe ich allerdings gesehen, dass offensichtlich schon länger nicht mehr an dem Adapter gearbeitet wird. Wäre wirklich schade.
                            Franzel61 last edited by
                            Hallo ,
                            Viel der Sensoren kann man - solange sie Schalter/Steckdosen/Temperaturegeber oder Heizungsregeler sind in der List nachpflegen … jedoch vermisse ich die Steuerung der Rolladen ... wenn jemand dafür eine Lösung hat bin ich zufrieden ... sehr zufrieden tolles Project
                              Bobohne last edited by
                              Hallo zusammen!
                              Gibt es denn schon eine Möglichkeit die Instanz auf Windows laufen zu lassen?
                              Michael
                                JW86 last edited by
                                Hallo Zusammen,
                                ich arbeite gerade an einem neuen Homekit Adapter da der bisherige mir zu wenig Features bietet (u.a. fehlt mir auch die Rolladensteuerung).
                                Sobald ich was zum testen habe, werde ich es hier posten.
                                Zum Thema Windows:
                                Mit folgender Anleitung konnte ich HAP-NodeJS (der eigentliche Homekit Connector) unter Windows zum Laufen bekommen:
                                https://github.com/nfarina/homebridge/w … on-Windows
                                Man muss natürlich nicht alle Schritte durchführen die dort beschrieben sind, da man ja nicht HomeBridge installieren will. Aber ein Großteil der Schritte ist notwendig.
                                Jens
                                  chka last edited by
                                  super, leider bekomme ich den aktuellen nicht mit iOS gebunden
                                    JW86 last edited by
                                    Hast du irgendeine Fehlermeldung? Oder findet das i-Gerät die Bridge einfach nicht?
                                      chka last edited by
                                      Das passwort ist richtig aber danach geht die kopplung schief.
                                      Den fehler haben hier mehrer wenn du die letzen seiten durchblätterst.
                                        wep4you2 last edited by
                                        Also erst mal danke für diesen tollen Adapter.
                                        Nachdem ich einige Tage serumprobiert habe, hab ich den Adapter heute auf einem Banana Pro erfolgreich zum Laufen gebracht,
                                        nachdem ich alles neu installiert habe, also Nodejs und Biobroker komplett von 0 weg installiert. Kann sowohl von der HomeKit App aus dem iOS 10 heraus als auch aus der EVE App erfolgreich auf meine Geräte zugreifen, verliert zwar zeitweise die Verbindung aber verbindet sich auch wieder.
                                        Mich würde jetzt interessieren wie ich nun mehr Devices ins HomeKit einbinden kann. Von Homematic hab ich noch einen Zwischenstecker, der wird zwar als Gerät angezeigt, aber der stürzt ab und reisst die anderen Devices im gleichen Raum mit, und meine optischen Fenster/Türkontakte zeigt er nicht an.
                                        Weiters würde ich gern auch die Netatmo und Netatmo Welcome einbinden, geht das mit Config oder ist das erst zu programmieren?
                                        • wendy2702
                                          wendy2702 last edited by
                                          ich versuche gerade den Homekit Adapter auf meinem Debian Wheezy zu installieren. Leider schlägt das immer fehl:
                                          ! $ ./iobroker add homekit
                                          ! npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
                                          ! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                                          ! compilation terminated.
                                          ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                                          ! gyp
                                          ! ERR! build error
                                          ! gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                          ! gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                                          ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
                                          ! gyp ERR! System Linux 3.16-0.bpo.2-amd64
                                          ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                          ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
                                          ! gyp ERR! node -v v4.5.0
                                          ! gyp ERR! node-gyp -v v3.4.0
                                          ! gyp ERR! not ok
                                          ! npm
                                          ! ERR! Linux 3.16-0.bpo.2-amd64
                                          ! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.5.0
                                          ! npm ERR! npm v2.15.9
                                          ! npm ERR! code ELIFECYCLE
                                          ! npm ERR! mdns@2.2.11 install: node-gyp rebuild
                                          ! npm ERR! Exit status 1
                                          ! npm ERR!
                                          ! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
                                          ! npm ERR! This is most likely a problem with the mdns package,
                                          ! npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                                          ! npm ERR! node-gyp rebuild
                                          ! npm ERR! You can get information on how to open an issue for this project with:
                                          ! npm ERR! npm bugs mdns
                                          ! npm ERR! Or if that isn't available, you can get their info via:
                                          ! npm ERR!
                                          ! npm ERR! npm owner ls mdns
                                          ! npm ERR! There is likely additional logging output above.
                                          ! npm ERR! Please include the following file with any support request:
                                          ! npm ERR! /npm-debug.log
                                          ! ERROR: host.openmediavault Cannot install iobroker.homekit: 1
                                          ! ERROR: process exited with code 25
                                          Node Version ist 4.5.0 –> ist das schon zu alt?
                                          Vielleicht sonst noch jemand eine Idee was fehlen könnte?
                                          EDIT:hat sich erledigt: fehlendes Paket installiert:
                                          ! sudo apt-get install libavahi-compat-libdnssd-dev
                                          Danke und Gruß
                                            chka last edited by
                                            den Fehler habe ich auch
                                            250
                                            52390
