Sendto (Mail kommen dauernd)!?
@BLRD nur zur Sicherheit wäre es schön dein Blockly zu sehen, nicht dass da beim Anpassen etwas schief gelaufen ist
Bitte schön.
<xml xmlns="https://developers.google.com/blockly/xml"> <variables> <variable id="o5QWq1D-uG;sTenPDfvN">laden</variable> <variable id="gkq+0V)+.8?y$@tO!n:l">msg</variable> </variables> <block type="on" id="sh_6?8^;9ExO-}/4Dx:." x="-162" y="-212"> <field name="OID">paw.0.SM-G975F.info.battery.level</field> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <statement name="STATEMENT"> <block type="controls_if" id="CI$h@O!ge0Zuvw#O,7%y"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_compare" id="CtN*18c!yPmh!L-ar{o$"> <field name="OP">LTE</field> <value name="A"> <block type="on_source" id="+tgC2FeeP-t6(#I#78sX"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="math_number" id="SfOi94m6!*DR]4wQkHWC"> <field name="NUM">16</field> </block> </value> </block> </value> <statement name="DO0"> <block type="variables_set" id="1;?}XCYp^byO;gy^O2@A"> <field name="VAR" id="o5QWq1D-uG;sTenPDfvN">laden</field> <value name="VALUE"> <block type="logic_boolean" id="WgQ0([/)DWM5/eaBRVki"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="variables_set" id="}7W[2Vy[mlFnDLV@Sg#b"> <field name="VAR" id="gkq+0V)+.8?y$@tO!n:l">msg</field> <value name="VALUE"> <block type="text" id="1WkJE4,cqqho{[hL]n~F"> <field name="TEXT">Handy wird geladen !</field> </block> </value> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_compare" id="l;ns{D^Q)3;aLtd~Cema"> <field name="OP">GTE</field> <value name="A"> <block type="on_source" id="tzHBF]WB=%[rk-xpo9l|"> <field name="ATTR">state.val</field> </block> </value> <value name="B"> <block type="math_number" id="Km~-p2@r7ayYw;0}6lCP"> <field name="NUM">85</field> </block> </value> </block> </value> <statement name="DO1"> <block type="variables_set" id="ELB.|ah!Fiv3aQ6@8pf="> <field name="VAR" id="o5QWq1D-uG;sTenPDfvN">laden</field> <value name="VALUE"> <block type="logic_boolean" id="B@Ge,Laaw5c}#yqyDajk"> <field name="BOOL">FALSE</field> </block> </value> <next> <block type="variables_set" id="sVKmL1oqI9rAR.)R;bf}"> <field name="VAR" id="gkq+0V)+.8?y$@tO!n:l">msg</field> <value name="VALUE"> <block type="text" id="L`C/*L{_kNMN$]T!{{*{"> <field name="TEXT">Handy wird nicht geladen !</field> </block> </value> </block> </next> </block> </statement> <next> <block type="controls_if" id="u}DJxe5;6%N]U{*k*[G1"> <value name="IF0"> <block type="logic_compare" id="hy(~rHnh9(9kbsEnve?U"> <field name="OP">NEQ</field> <value name="A"> <block type="variables_get" id="=YrpL4}hjW+AK_9Z]kjy"> <field name="VAR" id="o5QWq1D-uG;sTenPDfvN">laden</field> </block> </value> <value name="B"> <block type="get_value_var" id="WSdI_4h)+G?V~(q|v?jF"> <field name="ATTR">val</field> <value name="OID"> <shadow type="text" id=")AZRTGG%av*E|jhn2`0C"> <field name="TEXT">sonoff.0.SonoffDRNr6STSZ.POWER</field> </shadow> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control" id="f60qJA%{@*P)F4ZT+|6+"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">sonoff.0.SonoffDRNr6STSZ.POWER</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="variables_get" id="U[;@I~N.b,oAMl^N28B9"> <field name="VAR" id="o5QWq1D-uG;sTenPDfvN">laden</field> </block> </value> <next> <block type="email" id="Bkg^?/-3v1;n^5=PK@a@"> <field name="INSTANCE">.0</field> <field name="IS_HTML">TRUE</field> <field name="LOG"></field> <value name="TO"> <shadow type="text" id=".fm=Rk(N8m{mz^UVp33m"> <field name="TEXT">Gelöscht</field> </shadow> </value> <value name="TEXT"> <shadow type="text" id="Ufspt[!gJWLZi7|{rhxL"> <field name="TEXT">Handy wird nicht geladen !</field> </shadow> <block type="variables_get" id="3F[s#5(mj6~*)!Nqr2zo"> <field name="VAR" id="gkq+0V)+.8?y$@tO!n:l">msg</field> </block> </value> <value name="SUBJECT"> <shadow type="text" id="F@`oz|/UPf)cq$8$LhT-"> <field name="TEXT">Handy wird nicht geladen !</field> </shadow> <block type="variables_get" id="bpOd/R~)a*h]@-6#Td+v"> <field name="VAR" id="gkq+0V)+.8?y$@tO!n:l">msg</field> </block> </value> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </xml> -
@BLRD das lässt sich auf dem Handy nicht in Blockly umwandeln
ich meinte "sehen" wörtlich
@BLRD leider sind Die Bezeichnungen der Datenpunkte abgeschnitten
Gehen wir mal davon aus, dass es die richtigen sind, bleibt die Frage ob die Werte auch im richtigen Bereich sind.
Hast du diese mal geloggt und "analysiert"?
nicht dass bei Werten >85% immer mal wieder ein "null" oder "0" erscheint
Hilfreich wäre dann auch der Inhalt der message - dann müsste immer abwechselnd wird geladen und wird nicht geladen kommen -
Sorry die Datenpunkte sind die richtigen.
Wie mache iich dies loggen und analysieren?
Danke.
@BLRD sagte in Sendto (Mail kommen dauernd)!?:
Den Datenpunkt unter Objekte mit dem History-Adapter loggen, dann die geloggten Daten ansehen
Ok kommt dann.
Anbei dies:
muss ich bei den Einstellungen noch was ändern, da so ganz ausagekräftig ist dies nicht.
2020-09-09T09 10 02.752Z_50points_paw.0.SM-G975F.info.battery.level__history.0.csv
Danke.
was ist da nicht aussagekräftig?
Nimm ausnahmsweise die alte Doku
https://www.iobroker.net/docu/index-191.htm?page_id=144&lang=dein der neuen fehlt diese Seite aus irgendeinem Grund
https://www.iobroker.net/#de/adapters/adapterref/iobroker.history/README.md -
Ok, wass soll ich jetzt machen?
