    4. Test Adapter SmartControl 0.3.x-0.6.x Latest
    • dslraser
      @Mic
      ich habe meine Instanz nochmal gelöscht und dann von GitHub die 0.3.2 installiert.
      Jetzt ist das Log okay
      smartcontrol.0	2020-09-13 19:53:48.896	info	(7452) Subscribing to all target devices and trigger states. 0 trigger schedules activated...
      smartcontrol.0	2020-09-13 19:53:48.498	info	(7452) Adapter admin configuration successfully validated...
      smartcontrol.0	2020-09-13 19:53:46.466	info	(7452) starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.smartcontrol, node: v12.18.3, js-controller: 3.1.6
      host.iobroker	2020-09-13 19:53:44.821	info	instance system.adapter.smartcontrol.0 started with pid 7452
      host.iobroker	2020-09-13 19:53:42.282	info	instance system.adapter.smartcontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      smartcontrol.0	2020-09-13 19:53:41.759	info	(7437) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      smartcontrol.0	2020-09-13 19:53:41.758	info	(7437) terminating
      smartcontrol.0	2020-09-13 19:53:41.757	info	(7437) Stopping adapter instance successfully proceeded...
      smartcontrol.0	2020-09-13 19:53:41.756	info	(7437) (1) schedules cleared...
      smartcontrol.0	2020-09-13 19:53:41.755	info	(7437) (0) timers were active and have been cleared...
      smartcontrol.0	2020-09-13 19:53:41.753	info	(7437) Got terminate signal TERMINATE_YOURSELF
      host.iobroker	2020-09-13 19:53:41.749	info	stopInstance system.adapter.smartcontrol.0 send kill signal
        crunchip Forum Testing Most Active @Mic last edited by crunchip
        @Mic sagte in Test Adapter SmartControl 0.3.x GitHub (ab 12.09.20):
        Mit 0.3.2 nun neue Option (per Default deaktiviert):
        jetzt bin ich aber grad verwirrt, installiert, anschliessend im log
        smartcontrol.0	2020-09-13 19:56:36.124	error	(22323) [_asyncOnReady()] – 1 error(s) occurred while processing state generation of options.
        smartcontrol.0	2020-09-13 19:56:36.122	error	(22323) [tableConditions] We were not able to generate a valid state path. This is what was determined to be not valid: [smartcontrol.0.options.Conditions.Is Front Door Locked?.active].
        smartcontrol.0.options.Conditions.Is Front Door Locked gehört ja zu deinen voreingestellten Beispielen, hab die Beispiele noch nicht gelöscht und sind seit beginn ja deaktiviert
        Chaot Mic 2 Replies Last reply Reply Quote 0
        • Chaot
          Chaot @crunchip last edited by
          @crunchip Kam bei mir auch mit der neuen Version.
          Ich habe den gelöscht. Aber war doch etwas verwundert....😲
          • Mic
            Mic Developer @MichMein last edited by
            @MichMein sagte in Test Adapter SmartControl 0.3.x GitHub (ab 12.09.20):
            @Mic, ich finde es nahezu unfassbar mit welcher Hingabe und Geschwindigkeit Du hier den Adapter nach vorne bringst. RESPEKT
            Bist jetzt konnte ich tatsächlich alles was ich so an Blockly´s hatte in den Adapter migrieren, echt toll.
            Ich würde mir wünschen, wenn der Adapter so weit fertig ist, das Du Dir dein ein oder anderen Adapter vornimmst, "forkst" und diesen dann ebenfalls so usernah weiterentwickelst 🙄
            Vielen dank für dein tolles Feedback 😊
            • da_Woody
              da_Woody @Mic last edited by
              @Mic said in Test Adapter SmartControl 0.3.x GitHub (ab 12.09.20):
              nu, wo @MichMein recht hat, hat er recht! 😄
              • Mic
                Mic Developer @crunchip last edited by
                @crunchip sagte in Test Adapter SmartControl 0.3.x GitHub (ab 12.09.20):
                Das wird dir auch im JS-Adapter so passieren
                eben, da wird es sofort angemeckert
                Nur als Nachtrag. 😉
                Auch der JS-Adapter wird hier nicht sofort erkennen, wenn du einen Datenpunkt umbenennst. Beispiel
                const datenpunkt = '0_userdata.0.example_state';
                setTimeout(() => {
                    log(`State-Wert: ${getState(datenpunkt).val}`)
                }, 60*1000);
                Der wird das erst anmeckern, sobald das setTimeout() ausgeführt wird.
                • Mic
                  Mic Developer @crunchip last edited by Mic
                  @Chaot sagte in Test Adapter SmartControl 0.3.x GitHub (ab 12.09.20):
                  Sind noch "alte / legacy" Beispiele. Hab ich mittlerweile angepasst, aber das sieht man wohl nur, wenn man den Adapter löscht und neu installiert 🤔 .
                  Siehe hier aus der io-package.json:
                    "native": {
                      "fixNightNightEnd": true,
                      "motionIgnoreBriIfZoneOn": true,
                      "triggerStatesAck": "false",
                      "limitTriggerInterval": "2",
                      "extendedInfoLog": true,
                      "fancy-filter-input": "",
                      "executeZoneAlways": false,
                      "validateDeactivatedRows": false,
                      "tableTriggerMotion": [
                          "active": true,
                          "name": "Motion.Bad",
                          "stateId": "smartcontrol.0.Test.trigger.Bathroom_motion",
                          "stateVal": "true",
                          "duration": "10",
                          "notIfManual": false,
                          "briStateId": "smartcontrol.0.Test.brightness.Bathroom_bri",
                          "briThreshold": "100"
                          "active": true,
                          "name": "Motion.Flur.Sensor #1",
                          "stateId": "smartcontrol.0.Test.trigger.Hallway1_motion",
                          "stateVal": "true",
                          "duration": "120",
                          "briStateId": "smartcontrol.0.Test.brightness.Hallway1_bri",
                          "briThreshold": "70"
                          "active": true,
                          "name": "Motion.Flur.Sensor #2",
                          "stateId": "smartcontrol.0.Test.trigger.Hallway2_motion",
                          "stateVal": "true",
                          "duration": "120",
                          "briStateId": "smartcontrol.0.Test.brightness.Hallway2_bri",
                          "briThreshold": "60"
                      "tableTriggerDevices": [
                          "active": true,
                          "name": "Andere.Bad.Wandschalter",
                          "userState": false,
                          "stateId": "smartcontrol.0.Test.trigger.Bathroom_wall-switch",
                          "stateVal": "true",
                          "targetOff": false,
                          "isToggle": false
                          "active": true,
                          "name": "Andere.Flur.Wandschalter #1",
                          "userState": false,
                          "stateId": "smartcontrol.0.Test.trigger.Hallway1_wall-switch",
                          "stateVal": "true",
                          "targetOff": false,
                          "isToggle": false
                          "active": true,
                          "name": "Andere.Flur.Wandschalter #2",
                          "userState": false,
                          "stateId": "smartcontrol.0.Test.trigger.Hallway2_wall-switch",
                          "stateVal": "true",
                          "targetOff": false,
                          "isToggle": false
                          "active": true,
                          "name": "Lese-Ecke.Jemand setzt sich",
                          "userState": false,
                          "stateId": "smartcontrol.0.Test.trigger.RelaxPersonSitting",
                          "stateVal": "true",
                          "targetOff": false,
                          "isToggle": false
                      "tableTriggerTimes": [
                          "active": true,
                          "name": "Zeit.Jede Stunde in Minute 42",
                          "time": "42 * * * *",
                          "additionalConditions": [],
                          "additionalConditionsAll": false,
                          "never": [],
                          "neverAll": false,
                          "targetOff": false
                          "active": true,
                          "name": "Zeit.22:00 Mo-Fr",
                          "time": "0 22 * * 1-5",
                            "Jemand anwesend"
                          "never": [],
                          "neverAll": false,
                          "targetOff": false
                          "active": true,
                          "name": "Zeit.04:05 Sonntags",
                          "time": "5 4 * * sun",
                          "never": [],
                          "neverAll": false,
                          "targetOff": false
                          "active": true,
                          "name": "Zeit.30 Minutes nach Sonnenuntergang",
                          "time": "sunset+30",
                          "never": [],
                          "neverAll": false,
                          "targetOff": false
                      "tableTargetDevices": [
                          "active": true,
                          "name": "Bad.EG.Licht",
                          "onState": "smartcontrol.0.Test.light.Bathroom",
                          "onValue": "true",
                          "noTargetOnCheck": false,
                          "offState": "smartcontrol.0.Test.light.Bathroom",
                          "offValue": "false",
                          "noTargetOffCheck": false
                          "active": true,
                          "name": "Bad.EG.Radio",
                          "onState": "smartcontrol.0.Test.radio.Bathroom",
                          "onValue": "Smooth Jazz",
                          "offState": "smartcontrol.0.Test.radio.Bathroom",
                          "offValue": "Musik aus",
                          "active": true,
                          "name": "Flur.Light",
                          "onState": "smartcontrol.0.Test.light.Hallway",
                          "onValue": "true",
                          "offState": "smartcontrol.0.Test.light.Hallway",
                          "active": true,
                          "name": "Lese-Ecke.Deckenlicht",
                          "onState": "smartcontrol.0.Test.light.RelaxAreaCeiling",
                          "onValue": "true",
                          "offState": "smartcontrol.0.Test.light.RelaxAreaCeiling",
                          "active": true,
                          "name": "Lese-Ecke.Wandlicht",
                          "onState": "smartcontrol.0.Test.light.RelaxAreaWall",
                          "onValue": "true",
                          "offState": "smartcontrol.0.Test.light.RelaxAreaWall",
                      "tableZones": [
                          "active": true,
                          "name": "Bad Erdgeschoss",
                          "triggers": [
                            "Motion.Bad",
                          "targets": [
                            "Bad.EG.Licht",
                            "Bad.EG.Radio"
                          "offAfter": "7000",
                          "executeAlways": false,
                          "executionJson": "[{\"active\":true,\"start\":\"06:00\",\"end\":\"09:00\",\"mon\":true,\"tue\":true,\"wed\":true,\"thu\":true,\"fri\":true,\"sat\":false,\"sun\":false,\"additionalConditions\":[],\"never\":[\"Feiertag heute\",\"Keiner anwesend\"]},{\"active\":true,\"start\":\"08:00\",\"end\":\"11:00\",\"mon\":true,\"tue\":true,\"wed\":true,\"thu\":true,\"fri\":true,\"sat\":false,\"sun\":false,\"additionalConditions\":[\"Feiertag heute\"],\"never\":[\"Keiner anwesend\"]},{\"active\":true,\"start\":\"08:00\",\"end\":\"11:00\",\"mon\":false,\"tue\":false,\"wed\":false,\"thu\":false,\"fri\":false,\"sat\":true,\"sun\":true,\"additionalConditions\":[],\"never\":[\"Feiertag heute\",\"Keiner anwesend\"]}]"
                          "active": true,
                          "name": "Flur",
                          "triggers": [
                          "targets": [
                            "Flur.Light"
                          "offAfter": "500",
                          "executeAlways": true,
                          "executionJson": ""
                          "active": true,
                          "name": "Leseecke",
                          "triggers": [
                          "targets": [
                          "offAfter": "10000",
                          "executionJson": "[{\"active\":true,\"start\":\"sunset+30\",\"end\":\"sunrise\",\"mon\":true,\"tue\":true,\"wed\":true,\"thu\":true,\"fri\":true,\"sat\":false,\"sun\":false,\"additionalConditions\":[\"Jemand anwesend\"],\"never\":[]}]"
                      "tableConditions": [
                          "active": true,
                          "name": "Feiertag heute",
                          "conditionState": "smartcontrol.0.Test.condition.isHolidayToday",
                          "conditionValue": "true"
                          "active": true,
                          "name": "Haustür ist abgeschlossen",
                          "conditionState": "smartcontrol.0.Test.condition.isFrontDoorLocked",
                          "active": true,
                          "name": "Keiner anwesend",
                          "conditionState": "smartcontrol.0.Test.condition.isAnyonePresent",
                          "conditionValue": "false"
                          "active": true,
                          "name": "Jemand anwesend",
                    "instanceObjects": [
                        "_id": "info.connection",
                        "type": "state",
                        "common": {
                          "role": "indicator.connected",
                          "name": "If adapter configuration successfully validated",
                          "type": "boolean",
                          "read": true,
                          "write": false,
                          "def": false
                        "native": {}
                  Wahrscheinlich liegt es an dem Sonderzeichen "?" (Fragezeichen), ich hab beim Adapter Refactoring so einiges umgebaut und verbessert, und auch paar strengere Regeln eingebaut 😉
                  Cool wäre evtl. noch eine "Auf Werkseinstellungen zurücksetzen" Funktion, falls das einfach zu implementieren ist 🙂
                  Mic 1 Reply Last reply Reply Quote 0
                  • Mic
                    Mic Developer @Mic last edited by
                    Auf die schnelle noch ein Issue (Feature Request) eingebaut: 😎
                    Anfrage war von @hetti72
                    0.3.3
                    • (Mic-M) New feature for Motion sensors: the timer duration and brightness threshold can now be changed via states. These states are available under smartcontrol.0.options.TriggerMotion.xxx.<duration|briThreshold> for each of your motion sensors. Please note that any change will cause an adapter restart (for initializing and clearing all existing timers to apply the new values). Issue #18
                    Jetzt kann man für die Bewegungsmelder die Werte für den Timer (Einschaltdauer) und Helligkeits-Grenze in Datenpunkten einstellen. Für jeden Bewegungsmelder werden hierfür die entsprechenden Datenpunkte erstellt:
                    Bitte testen 🙂
                    Kaiser Franz Josef 1 Reply Last reply Reply Quote 2
                      @Mic ok, aber zumindest kamen bis jetzt die Error's in JS immer unmittelbar zeitnah, so das es gleich aufgefallen ist
                      und ich dann fragend da saß...😡 "mist, welches script läuft denn nun schon wieder nicht"
                      • Mic
                        Jo, und im JS.Adapter kannst halt auch einfach globales Suchen machen für bei Datenpunkt-Änderungen. Das geht über sämtliche Adapter und deren individueller Einstellungen natürlich nicht.
                        • Mic
                          Mic Developer @Mic last edited by Mic
                          Neue Version 0.3.4
                          • (Mic-M) Test: Implementation of markdown documentation files within adapter configuration by using zero-md for tables 'Target Devices' and 'Additional Conditions' to prepare adapter for multiple languages. Based on your language set in the adapter configuration, either German will be displayed (if language set to German) or English, if set language is not German.
                          Änderungen diesmal nur "unter der Haube".
                          Ich bereite gerade die Dokumentation in der Adapter-Konfiguration für Internationalisierung vor. In den Optionen "Ziel-Geräte" und "Zusätzliche Bedingungen" wird nun die Dokumentation nicht mehr aus der index_m.html direkt angezeigt, sondern es werden Markdown-Files von admin/doc-md/table-target-devices_de.md bzw. admin/doc-md/table-conditions_de.md geholt und direkt angezeigt in der Admin-Konfiguration.
                          Die Formatierung sieht soweit auch ganz gut aus.
                          Was man hier sieht kommt inhaltlich von diesem File (Github).
                          Für die Internationalisierung:
                          Stellt man in ioBroker die Sprache auf English oder einer anderen Sprache um, dann kommt jetzt aus dieser Datei:
                          Scheint soweit bei mir sehr gut zu funktionieren. Würde mich um Tests freuen 😉
                          Was sein kann (könnte): Inhalte werden nicht rechtzeitig geladen und/oder es erscheint was leeres... Bei mir ging es aber bislang, sowohl Chrome als auch Firefox.
                          F H 2 Replies Last reply Reply Quote 2
                            Funbug @Mic last edited by
                            Hallo Zusammen,
                            Zuerst mal vielen Dank für eure Arbeit! Der Adapter sieht echt toll aus und wird mir bestimmt den Einstig vereinfachen 🙂
                            Ich bin mal ehrlich und teile gleich mit, dass ich noch nicht Stunden mit dem Adapter verbracht habe.
                            Habe für einen Test mal ein Shelly 2.5 mit zwei Glühbirnen bestückt. Die Taster Eingänge am Shelly werden nicht angesteuert.
                            Somit wird der Shelly einzig als Relais genutzt. Zum Ansteuerung habe ich mal eine Bewegungsmelder von Xiaomi und einen Enocean Omnio 4-fach Taster verwendet.
                            Das mit dem Bewegungsmelder hat sofort und super funktioniert. Das Licht kann ich mit dem 4-fach Schalter einschalten, jedoch nicht mehr ausschalten.
                            Die Omnio Taster senden pro Kanal ein true bei Betätigung und ein false, sobald die Taste losgelassen wird.
                            Nun zu meinen Fragen:
                            1. Wie löse ich dies mit dem Taster, dass die eine Taste zum einschalten ist und die andere zum ausschalten des Lichts / Relais?
                            2. Gibt es schon eine Funktion in diesem Adapter um mit einem solchen Taster Lichter zu dimmen oder die Lautstärke zu erhöhen / senken?
                            Vielen Dank im Voraus
                            Gruss Thomas
                            crunchip Mic 2 Replies Last reply Reply Quote 0
                              crunchip Forum Testing Most Active @Funbug last edited by
                              @Funbug sagte in Test Adapter SmartControl 0.3.x GitHub (ab 12.09.20):
                              warum zwei Verschiedenen Taster belegen, du kannst das mit einen Taster machen und nimmst die Toggle Funktion.
                              siehe unter "Andere Auslöser"
                                Funbug @crunchip last edited by
                                @crunchip Die Möglichkeit habe ich gesehen und getestet. Jedoch möchte ich mit der Taste oben das Licht an schalten oder heller dimmen oder mit der Taste unten das Licht aus schalten oder dunkler dimmen... So meine Überlegung.
                                • Mic
                                  Mic Developer @Funbug last edited by Mic
                                  Im Idealfall hast du Datenpunkte wie etwa denon.0.zoneMain.volumeUp / denon.0.zoneMain.volumeDown oder entsprechend für das Dimmen.
                                  Welche Datenpunkte hast du da als Auslöser und was sind deine Zieldatenpunkte?
                                    @Mic Danke für Dein Feedback. Habe soeben nachgeguckt. Ich habe ein state mit dem Level in % sowie zwei Tasten für Dimm up und down. Die kann ich direkt zwar nicht bedienen, werde jedoch mal testen die anzusteuern über den Taster.
                                    Der Taster hat wie gesagt vier state's und ein state value in welchem wahrscheinlich unterschieden werden kann ob die Taste nun lang oder kurz betätigt wurde. Es gelang mir noch nicht die Werte zu verstehen....
                                    Wie schon erläutert bleibt das stat der jeweiligen Taste solange auf true, wie die Taste gedrückt bleibt. Wäre toll wenn dies irgendwie im Adapter erkannt werden könnte ob kurz oder lang gedrückt wird. Bei lang, wie lange oder eben so lange dann z.B. die % in definierbaren Schritten hochzählen...
                                    Wie sieht es aus mit Einschalten mit der einen Taste und ausschalten mit der anderen? Danke und Gruss Thomas
                                    2020-09-17 22_03_30-objects - ioBroker.png 2020-09-17 22_01_03-objects - ioBroker.png
                                    • Mic
                                      @Funbug
                                      Hi Thomas,
                                      Etwaiges lang/kurz drücken etc. kann Smart Control nicht abbilden, weil das bei jedem Gerät/Adapter usw. anders ist. Hatte mich vor über 2 Jahren mal mit einem Philips Hue Dimmer Switch auseinandergesetzt - und das nur als ein Beispiel von vielen tausenden Geräten.
                                      Der Adapter braucht konkrete Auslöser, also z.B. "Taste 4 von Schalter xyz wurde lang gedrückt" per Datenpunkt. Falls das deine Umgebung für dieses Gerät nicht liefert: du könntest Blockly/JS-Adapter nutzen, oder auch den Adapter-Entwickler bezüglich Umsetzbarkeit fragen. Ich brauch halt was konkretes als Auslöser 😉
                                      Z.B. Du legst 2 Auslöser an, z.B.
                                        @Mic
                                        Hallo Mic,
                                        Danke für Deine Hilfestellung.
                                        Somit muss / werde ich die Funktion kurz / lang jeweils in einem Blockly lösen müssen und dann neue states generieren, richtig?
                                        Sorry, bin noch ganz am Anfang von der Geschichte und arbeite mich langsam in das Thema ein 🙂
                                        Zwei Auslöser habe ich generiert. Nur haben die beiden jeweils ja nur das "true" was die ausgeben. Gehe davon aus, dass dann im Abschnitt 4. Zonen für diejenige Lampe dann auch zwei Ausführungen gesetzt werden müssen. Wie unterscheidet sich denn der Auslöser für Einschalten vom Auslöser Ausschalten?
                                        Gruss Thomas
                                        • Mic
                                          Ich kenne leider deine Hardware nicht, also was da bei kurz/lang drücken in den Datenpunkten passiert, das müsstest du separat hier im Forum fragen. Der Adapter braucht einen konkreten Auslöser, z.B. Datenpunkt xyz geht auf true oder auf 45 usw.
                                          Das ist gut so 😉 Sie sollen ja was auslösen...
                                          Siehe Toggle: https://forum.iobroker.net/post/490036
                                            hetti72 @Mic last edited by hetti72
                                            @Mic Ich habe mal eine Frage zur ausführungsreihenfolge von zeitlich überlappenden Zonen. Gibt es die möglichkeit zu beinflussen in welcher Reihenfolge die Zonen bei Auslösung abgearbeitet werden?
                                            Man hat ja die Möglichkeit die Zonen in der Liste nach oben und unten zu schieben, aber ich konnte noch keinen Unterschied im verhalten feststellen.
                                            Hintergrund: Ich nutze mehrere Zonen um verschiedene Helligkeiten (Nachtlicht) zu unterschiedlichen Uhrzeiten zu realisieren. bis jetzt hatte ich das Nachtlich zum beginn der Nacht starten lassen, das hat gut gepasst. Mittlerweile beginnt die Nacht schon recht früh und das passt nicht mehr zu den Lebensgewohnheiten.
                                            Ich hätte gerne das das Nachtlicht zum beginn der Nacht startet aber frühestens um 23 Uhr.
                                            Wenn man nun die Reihenfolge der Abarbeitung bestimmen könnte, hätte man mehr möglichkeiten mit Zeitüberlappungen zu arbeiten.
                                            Denkbar wäre auch eine Option mit der festgelegt werden kann das wenn eine Zone ausgelöst hat keine weiteren Zonen mit dem gleichen Auslöser mehr ausgeführt werden.
                                            Wäre so etwas umsetzbar? Soll ich dazu einen Feature Request öffnen?
                                            gruß,
                                            Frank
                                            da_Woody Mic 2 Replies Last reply Reply Quote 0
                                            adapter bewegungsmelder ifttt lichter smartcontrol test zeitplan
                                            92
                                            995
                                            304851
