    4. Gosund SP1 auf Tasmota - Keine Aktualisierung
    • Ralla66
      Ralla66 Most Active @Master67 last edited by Ralla66
      @Master67
      Dann schau in der Tasmota Console nach ob Mqtt überhaupt sendet.
      Master67 1 Reply Last reply Reply Quote 0
        crunchip Forum Testing Most Active @Ralla66 last edited by
        @Ralla66 hast recht, ist schon lange her😊 , hatte damals meinen sonoff auf 1885 eingerichtet
        MQTT
        Port - Port where the server will run (Default 1883). WebSockets will always run on port+1 (Default 1884)
        • Master67
          Master67 @Ralla66 last edited by
          @Ralla66 sagte in Gosund SP1 auf Tasmota - Keine Aktualisierung:
          @Master67
          Okay.... was muss ich Eingeben um das zu sehen?
          Ralla66 1 Reply Last reply Reply Quote 0
          • Ralla66
            @Master67
            Auf einen Tasmota SP1 gehen, im Hauptmenue Konsole anklicken.
            • Master67
              @Master67
              ..... 🙂 ja das war mir klar.... aber bei mir sieht das für den SP1 so aus (ich schau mir gleich noch die "echten" Sonoffs an)
              21:30:07 MQT: stat/%topic%/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box Fon WLAN 7360 SL","FRITZ!Box 6591 Cable MF"],"TelePeriod":0,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00006000"]}}
              21:30:07 MQT: stat/%topic%/STATUS4 = {"StatusMEM":{"ProgramSize":593,"Free":408,"Heap":23,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"144051","FlashFrequency":40,"FlashMode":3,"Features":["00000407","8FDAE797","04368001","000000CD","010013C0","C000F981","00004004"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37","Sensors":"1,2,3,4,5,6"}}
              21:30:07 MQT: stat/%topic%/STATUS5 = {"StatusNET":{"Hostname":"%topic%-0076","IPAddress":"192.168.178.XX","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.178.xx","Mac":"F4:CF:A2:08:E0:4C","Webserver":2,"WifiConfig":2,"WifiPower":17.0}}
              21:30:07 MQT: stat/%topic%/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.XX","MqttPort":1883,"MqttClientMask":"Sonoff-HomeLab","MqttClient":"Sonoff-HomeLab","MqttUser":"olaf.himmelberg@XXX.com","MqttCount":2,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
              21:30:07 MQT: stat/%topic%/STATUS7 = {"StatusTIM":{"UTC":"2020-09-14T20:30:07","Local":"2020-09-14T21:30:07","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezone":"+01:00","Sunrise":"06:26","Sunset":"19:04"}}
              21:30:07 MQT: stat/%topic%/STATUS9 = {"StatusPTH":{"PowerDelta":0,"PowerLow":0,"PowerHigh":0,"VoltageLow":0,"VoltageHigh":0,"CurrentLow":0,"CurrentHigh":0}}
              21:30:07 MQT: stat/%topic%/STATUS10 = {"StatusSNS":{"Time":"2020-09-14T21:30:07","ENERGY":{"TotalStartTime":"2020-09-10T13:07:47","Total":56.608,"Yesterday":13.314,"Today":11.922,"Period":1,"Power":532,"ApparentPower":594,"ReactivePower":263,"Factor":0.90,"Voltage":226,"Current":2.630}}}
              21:30:07 MQT: stat/%topic%/STATUS11 = {"StatusSTS":{"Time":"2020-09-14T21:30:07","Uptime":"3T05:13:48","UptimeSec":278028,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":2,"POWER":"ON","Wifi":{"AP
              Master67 crunchip 2 Replies Last reply Reply Quote 0
              • Master67
                Master67 @Master67 last edited by
                @Master67 hier mal eine geflashte SWA1... Läuft schon sehr lange so 🙂
                t":514,"SSId":["FRITZ!Box 6490 Cable","FRITZ!Box 6591 Cable MF"],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00006000"]}}
                21:39:03 MQT: Sonoff-LampeBüro/STATUS4 = {"StatusMEM":{"ProgramSize":593,"Free":408,"Heap":21,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"1440A1","FlashFrequency":40,"FlashMode":3,"Features":["00000407","8FDAE797","04368001","000000CD","010013C0","C000F981","00004004"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37","Sensors":"1,2,3,4,5,6"}}
                21:39:03 MQT: Sonoff-LampeBüro/STATUS5 = {"StatusNET":{"Hostname":"Sonoff-Lampe Büro","IPAddress":"192.168.178.27","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.178.XX","Mac":"DC:4F:22:24:AA:1F","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
                21:39:03 MQT: Sonoff-LampeBüro/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.31","MqttPort":1883,"MqttClientMask":"Sonoff-Lampe Büro","MqttClient":"Sonoff-Lampe Büro","MqttUser":"olaf.himmelberg@me.com","MqttCount":42,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
                21:39:03 MQT: Sonoff-LampeBüro/STATUS7 = {"StatusTIM":{"UTC":"2020-09-14T20:39:03","Local":"2020-09-14T21:39:03","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezone":"+01:00","Sunrise":"06:26","Sunset":"19:04"}}
                21:39:03 MQT: Sonoff-LampeBüro/STATUS10 = {"StatusSNS":{"Time":"2020-09-14T21:39:03"}}
                21:39:03 MQT: Sonoff-LampeBüro/STATUS11 = {"StatusSTS":{"Time":"2020-09-14T21:39:03","Uptime":"13T06:28:34","UptimeSec":1146514,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":42,"POWER":"ON","Wifi":{"AP":2,"SSId":"FRITZ!Box 6591 Cable MF","BSSId":"3C:A6:2F:34:6C:41","Channel":11,"RSSI":100,"Signal":-48,"LinkCount":17,"Downtime":"0T00:01:05"}}}
                21:39:19 MQT: Sonoff-LampeBüro/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.31","MqttPort":1883,"MqttClientMask":"Sonoff-Lampe Büro","MqttClient":"Sonoff-Lampe Büro","MqttUser":"olaf.himmelberg@XX.com","MqttCount":42,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
                21:39:19 MQT: Sonoff-LampeBüro/STATUS7 = {"StatusTIM":{"UTC":"2020-09-14T20:39:19","Local":"2020-09-14T21:39:19","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezone":"+01:00","Sunrise":"06:26","Sunset":"19:04"}}
                21:39:19 MQT: Sonoff-LampeBüro/STATUS10 = {"StatusSNS":{"Time":"2020-09-14T21:39:19"}}
                21:39:19 MQT: Sonoff-LampeBüro/STATUS11 = {"StatusSTS":{"Time":"2020-09-14T21:39:19","Uptime":"13T06:28:50","UptimeSec":1146530,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":42,"POWER":"ON","Wifi":{"AP":2,"SSId":"FRITZ!Box 6591 Cable MF","BSSId":"3C:A6:2F:34:6C:41","Channel":11,"RSSI":100,"Signal":-49,"LinkCount":17,"Downtime":"0T00:01:05"}}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS = {"Status":{"Module":18,"DeviceName":"Sonoff-Lampe Büro","FriendlyName":["Sonoff-Lampe Büro"],"Topic":"Sonoff-Lampe_Büro","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota.bin","RestartReason":"Software/System restart","Uptime":"13T06:28:58","StartupUTC":"2020-09-01T14:10:29","Sleep":50,"CfgHolder":4617,"BootCount":9,"BCResetTime":"2020-08-23T10:59:38","SaveCount":122,"SaveAddress":"FA000"}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS2 = {"StatusFWR":{"Version":"8.4.0(tasmota)","BuildDateTime":"2020.07.29 12:19:21","Boot":31,"Core":"2_7_2_1","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8266EX","CR":"508/699"}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 6490 Cable","FRITZ!Box 6591 Cable MF"],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00006000"]}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS4 = {"StatusMEM":{"ProgramSize":593,"Free":408,"Heap":23,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"1440A1","FlashFrequency":40,"FlashMode":3,"Features":["00000407","8FDAE797","04368001","000000CD","010013C0","C000F981","00004004"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37","Sensors":"1,2,3,4,5,6"}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS5 = {"StatusNET":{"Hostname":"Sonoff-Lampe Büro","IPAddress":"192.168.178.27","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.178.XX","Mac":"DC:4F:22:24:AA:1F","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.XX","MqttPort":1883,"MqttClientMask":"Sonoff-Lampe Büro","MqttClient":"Sonoff-Lampe Büro","MqttUser":"olaf.himmelberg@me.com","MqttCount":42,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS7 = {"StatusTIM":{"UTC":"2020-09-14T20:39:27","Local":"2020-09-14T21:39:27","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezone":"+01:00","Sunrise":"06:26","Sunset":"19:04"}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS10 = {"StatusSNS":{"Time":"2020-09-14T21:39:27"}}
                21:39:27 MQT: Sonoff-LampeBüro/STATUS11 = {"StatusSTS":{"Time":"2020-09-14T21:39:27","Uptime":"13T06:28:58","UptimeSec":1146538,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":42,"POWER":"ON","Wifi":{"AP":2,"SSId":"FRITZ!Box 6591 Cable MF","BSSId":"3C:A6:2F:34:6C:41","Channel":11,"RSSI":100,"Signal":-49,"LinkCount":17,"Downtime":"0T00:01:05"}}}
                  crunchip Forum Testing Most Active @Master67 last edited by
                  @Master67 und du hast immer noch TelePeriod 0
                  • Master67
                    @Master67 ..... und hier mal die von mir zurückgesetzte SP1... aber das, selbst mit dem "Finger Weg" Teil sieht nicht anders aus!
                    21:44:47 MQT: stat/tasmota_D03663/STATUS10 = {"StatusSNS":{"Time":"2020-09-14T21:44:47","ENERGY":{"TotalStartTime":"2020-09-11T15:00:47","Total":0.496,"Yesterday":0.016,"Today":0.015,"Power":1,"ApparentPower":3,"ReactivePower":3,"Factor":0.24,"Voltage":230,"Current":0.011}}}
                    21:44:47 MQT: stat/tasmota_D03663/STATUS11 = {"StatusSTS":{"Time":"2020-09-14T21:44:47","Uptime":"3T04:31:43","UptimeSec":275503,"Heap":23,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box Fon WLAN 7360 SL","BSSId":"9C:C7:A6:63:34:50","Channel":13,"RSSI":54,"Signal":-73,"LinkCount":1,"Downtime":"0T00:00:03"}}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS = {"Status":{"Module":55,"DeviceName":"Sonoff-Kino","FriendlyName":["Sonoff-Kino"],"Topic":"tasmota_D03663","ButtonTopic":"0","Power":1,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota.bin","RestartReason":"Power On","Uptime":"3T04:31:51","StartupUTC":"2020-09-11T16:13:04","Sleep":50,"CfgHolder":4617,"BootCount":21,"BCResetTime":"2020-09-11T15:00:47","SaveCount":60,"SaveAddress":"F8000"}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS2 = {"StatusFWR":{"Version":"8.4.0(tasmota)","BuildDateTime":"2020.07.29 12:19:21","Boot":31,"Core":"2_7_2_1","SDK":"2.2.2-dev(38a443e)","CpuFrequency":80,"Hardware":"ESP8285","CR":"476/699"}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box Fon WLAN 7360 SL","FRITZ!Box 6591 Cable MF"],"TelePeriod":0,"Resolution":"558180C0","SetOption":["00008009","2805C8000100060000005A00000000000000","00000000","00006000"]}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS4 = {"StatusMEM":{"ProgramSize":593,"Free":408,"Heap":21,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"144051","FlashFrequency":40,"FlashMode":3,"Features":["00000407","8FDAE797","04368001","000000CD","010013C0","C000F981","00004004"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37","Sensors":"1,2,3,4,5,6"}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS5 = {"StatusNET":{"Hostname":"tasmota_D03663-5731","IPAddress":"192.168.178.xx","Gateway":"192.168.178.xx","Subnetmask":"255.255.255.0","DNSServer":"192.168.178.xx","Mac":"DC:4F:22:D0:36:63","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.31","MqttPort":1883,"MqttClientMask":"Sonoff-Kino","MqttClient":"Sonoff-Kino","MqttUser":"olaf.himmelberg@xx.com","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS7 = {"StatusTIM":{"UTC":"2020-09-14T20:44:55","Local":"2020-09-14T21:44:55","StartDST":"2020-03-29T02:00:00","EndDST":"2020-10-25T03:00:00","Timezone":"+01:00","Sunrise":"06:26","Sunset":"19:04"}}
                    21:44:55 MQT: stat/tasmota_D03663/STATUS9 = {"StatusPTH":{"PowerDelta":0,"PowerLow":0,"PowerHigh":0,"VoltageLow":0,"VoltageHigh":0,"CurrentLow":0,"CurrentHigh":0}}
                    • Master67
                      Master67 @crunchip last edited by
                      @crunchip sagte in Gosund SP1 auf Tasmota - Keine Aktualisierung:
                      Ja.... ich kann es auch direkt umstelle... soll ich 10 oder 300 versuchen, bei der SWA1 (die läuft) ist es 300!
                        @Master67 zur Verbrauchsmessung brauchste schon 10....5min is sinnfrei
                        • Ralla66
                          @Master67
                          du bekommst Status und keine Tele Daten.
                          Da haste was verbogen.
                          Geh kurz im Sonoff Adapter auf Port 1885 PW anpassen usw.
                          Gleiche in Tasmota.
                          Tele setze 10.
                          Dann Sonoff Adapter neu starten, dann müssen Tele Daten da sein.
                          Master67 1 Reply Last reply Reply Quote 1
                          • Master67
                            @Ralla66 .. @crunchip ..... erst mal Danke für euren Einsatz.... ich glaube ich dreh am Rad.... ich hab das wieder auf TelePeriod 10 gestellt (ich musste es nicht mal eintippen.. war noch in der Konsole gespeichert), bin dann (so wie beim erste mal auch) in die Objekte rein und konnte den Aktualisierungen zuschauen!
                            Also es läuft..... aber ehrlich ich weis nicht warum.... ich kann schon die "Aktualisierungen" erkennen weil "Grün".... aber das war vor zwei Tagen nicht so.... Puh.... was für ein Stress wegen eigentlich nichts.
                            Aber danke an euch, das ihr da nicht nachgelassen habt 👍 🕶 👍
                            Also setzten wir das mal auf gelöst...
                            • Ralla66
                              @Master67
                              Prima das es dir geholfen hat.
                              Geh aber mit Tasmota auf Port 1885.
                              Einfach Konflikte der Standartports vermeiden.
                              • Master67
                                @Master67
                                Einfach Konlikte der Standartports vermeiden.
                                Kann ich machen, ist da beim Tasmota kein großer Aufwand 😉
                                  Malz1902 last edited by
                                  Ich nutze seit nem halben Jahr Port 1883 mqtt und Port 1884 sonoff, ohne Probleme bisher
                                  gelöst
                                  3857
