    4. Test Adapter mihome-vacuum v2.0.x
      blacksheep587 @moviehunter last edited by blacksheep587
      Hallo Zusammen,
      ich habe heute versucht den mihome-vacuum adapter zum Laufen zu kriegen, er wird aber nur Gelb und ich bekomme keine Verbindung zum Robi. Token auslesen hat mit der Anleitung soweit geklappt. Anbei mal die Fehlermeldung aus dem Log:
      mihome-vacuum.0	2020-09-01 20:12:57.820	error	(19455) Cannot send ping: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:57.817	info	(19455) Disconnect
      mihome-vacuum.0	2020-09-01 20:12:50.835	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:50.829	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:45.831	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:45.825	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:40.828	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:40.827	error	(19455) Cannot send command: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:38.338	info	(19455) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-09-01 20:12:37.870	error	(19455) Cannot send ping: Error: getaddrinfo ENOTFOUND 192.168.178.32
      mihome-vacuum.0	2020-09-01 20:12:37.813	info	(19455) Disconnect
      mihome-vacuum.0	2020-09-01 20:12:37.776	info	(19455) Cloud control disabled
      mihome-vacuum.0	2020-09-01 20:12:37.771	info	(19455) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-09-01 20:12:37.697	info	(19455) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.22.0, js-controller: 3.1.6
      mihome-vacuum.0	2020-09-01 20:12:37.412	warn	(19455) This object will not be created in future versions. Please report this to the developer.
      mihome-vacuum.0	2020-09-01 20:12:37.409	warn	(19455) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
      mihome-vacuum.0	2020-09-01 20:12:31.622	info	(19440) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      mihome-vacuum.0	2020-09-01 20:12:31.620	info	(19440) terminating
      mihome-vacuum.0	2020-09-01 20:12:31.616	info	(19440) Got terminate signal TERMINATE_YOURSELF
      Habt ihr eine Idee?
      Danke schon mal.
      Thomas Braun D 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @blacksheep587 last edited by
        @blacksheep587 Bitte Konsolentext in CodeTags setzen. Danke.
          moviehunter @moviehunter last edited by
          @moviehunter said in Test Adapter mihome-vacuum v2.0.x:
          @dirkhe Ja klar...im iobroker habe ich den Adapter mihome-vacuum Version 2.2.3
          Also Android App nutze ich die Xiaomi Home App Version 5.8.7
          Den Token beziehe ich ja durch das Eingeben meiner Zugangsdaten aus der Android App.
          Dann muss ich den Token ja unten nochmal manuell eingeben oder sehe ich das falsch? Jedenfalls wenn ich das nicht tue, bekomme ich immer eine Fehlermeldung beim speichern.
          Was genau bedeuten denn die drei Zeilen, wenn man über den bei mir gelben Button geht bei Instanzen?
          Verbunden mit Host: wahr
          Lebenszeichen: wahr
          Verbunden mit mihome-vacuum: falsch
          Habe jetzt nochmal die stable 2.0.7 installiert. Dort ist die Lampe wieder grün aber trotzdem keine Reaktion vom Sauber...
          Hier mal ein Auszug ausm Log:
          mihome-vacuum.0	2020-09-01 20:50:41.069	debug	(1229) no answer for get_sound_volume(id:62) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:40.869	debug	(1229) no answer for get_clean_summary(id:61) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:40.669	debug	(1229) no answer for get_consumable(id:60) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:39.126	debug	(1229) no answer for get_sound_volume(id:58) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:38.930	debug	(1229) no answer for get_clean_summary(id:57) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:38.724	debug	(1229) no answer for get_consumable(id:56) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:38.525	debug	(1229) no answer for get_status(id:54) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:26.619	debug	(1229) no answer for get_status(id:53) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:25.461	debug	(1229) requesting params every: 60 Sec
          mihome-vacuum.0	2020-09-01 20:50:23.517	debug	(1229) requesting params every: 60 Sec
          mihome-vacuum.0	2020-09-01 20:50:23.514	info	(1229) Connected
          mihome-vacuum.0	2020-09-01 20:50:23.402	info	(1229) Disconnect
          mihome-vacuum.0	2020-09-01 20:50:21.401	info	(1229) should trigger cleaning all null, but is currently active. Add to queue
          mihome-vacuum.0	2020-09-01 20:50:21.396	debug	(1229) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2020-09-01 20:50:21.395	debug	(1229) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1598986221392,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1598986056217}
          mihome-vacuum.0	2020-09-01 20:50:16.618	debug	(1229) no answer for get_status(id:52) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:07.258	debug	(1229) no answer for get_sound_volume(id:51) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:07.057	debug	(1229) no answer for get_clean_summary(id:50) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:06.857	debug	(1229) no answer for get_consumable(id:49) received, giving up
          mihome-vacuum.0	2020-09-01 20:50:06.653	debug	(1229) no answer for get_status(id:47) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:56.590	debug	(1229) no answer for get_status(id:46) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:51.649	debug	(1229) requesting params every: 60 Sec
          mihome-vacuum.0	2020-09-01 20:49:51.646	info	(1229) Connected
          mihome-vacuum.0	2020-09-01 20:49:51.586	info	(1229) Disconnect
          mihome-vacuum.0	2020-09-01 20:49:46.589	debug	(1229) no answer for get_status(id:45) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:41.072	debug	(1229) no answer for get_sound_volume(id:44) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:40.870	debug	(1229) no answer for get_clean_summary(id:43) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:40.668	debug	(1229) no answer for get_consumable(id:42) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:37.255	debug	(1229) no answer for get_sound_volume(id:40) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:37.055	debug	(1229) no answer for get_clean_summary(id:39) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:36.853	debug	(1229) no answer for get_consumable(id:38) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:36.651	debug	(1229) no answer for get_status(id:36) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:26.583	debug	(1229) no answer for get_status(id:35) received, giving up
          mihome-vacuum.0	2020-09-01 20:49:25.461	debug	(1229) requesting params every: 60 Sec
          Ist der Adapter für alle Xiaomi Roboter kompatibel?
            kristina.da @kristina.da last edited by
            @Meistertr: Ich wollte nett nachfragen, ob du zu den MAP Änderung schon gekommen bist?
            Schönen Freitag euch Allen!
            Kristina
            Meistertr 1 Reply Last reply Reply Quote 0
              dirkhe Developer @blacksheep587 last edited by
              @blacksheep587 die Fehlermeldung ist doch eindeutig, der Roboter ist vom adapter über die eingegebene ip nicht erreichbar
              • Meistertr
                Meistertr Developer @kristina.da last edited by Meistertr
                @kristina-da angefangen. mir ist aber ein anderer Adapter dazwischen gekommen. die migration der neuen valetudo map ist etwas komplexer und erfordert mehr Arbeit als anfangs gedacht.
                K 2 Replies Last reply Reply Quote 1
                  kristina.da @Meistertr last edited by
                  @Meistertr: Okay kein Problem.
                    SchuetzeSchulz @dirkhe last edited by
                    @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                    @SchuetzeSchulz das mit der Einstellung ist eine gute Idee. Ich schaue mal, das ich das einbaue
                    Hallo Dirk,
                    konntest Du diesbezüglich schon was erreichen? Oder kannst mir evtl. einen Workaround nennen?
                      dirkhe Developer @SchuetzeSchulz last edited by
                      @SchuetzeSchulz Ist drin in der 2.2.4, bitte testen
                      • Bluelinux
                        Bluelinux last edited by
                        Halli Hallo... ist das richtig das die MAP momentan nicht geht? ich habe einen Vacuum Cleaner gen.1 und kann keine karte sehen. also jedenfalls nicht im iobroker. oder muss ich noch einen bestimmten adapter dafür installieren? habe den aktuellen mihome-vacuum 2.2.4 adapter drauf. Eventuell bin ich nicht alleine mit dem problem und jemand hat einen Tip für mich.
                        danke schon mal
                          Thomas Braun Most Active @Bluelinux last edited by Thomas Braun
                          @Bluelinux Log vom Adapter-Start? Vielleicht mal wieder canvas ...
                          Übrigens scheint deine Tastatur zu klemmen.
                          Bluelinux 1 Reply Last reply Reply Quote 0
                          • Bluelinux
                            Bluelinux @Thomas Braun last edited by
                            @Thomas-Braun nein nein meine Tastatur klemmt nicht. 😛 Ich habe mal den Adapter neu gestartet, und den Log dazu gespeichert.
                            2020-09-15 21:54:13.134 - info: host.ioBroker-Debian "system.adapter.mihome-vacuum.0" enabled
                            2020-09-15 21:54:13.181 - info: host.ioBroker-Debian instance system.adapter.mihome-vacuum.0 started with pid 10579
                            2020-09-15 21:54:17.571 - info: mihome-vacuum.0 (10579) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                            2020-09-15 21:54:17.640 - info: mihome-vacuum.0 (10579) Expert mode enabled, states created
                            2020-09-15 21:54:17.642 - info: mihome-vacuum.0 (10579) Create state clean_home for controlling by cloud adapter
                            2020-09-15 21:54:17.723 - info: mihome-vacuum.0 (10579) New generation or new fw(3.5.8,004018) detected, create new states goto and zoneclean
                            2020-09-15 21:54:17.913 - warn: mihome-vacuum.0 (10579) Time difference between Mihome Vacuum and ioBroker: 1 sec
                            2020-09-15 21:54:17.914 - info: mihome-vacuum.0 (10579) connecting, this can take up to 10 minutes ...
                            2020-09-15 21:54:17.988 - info: mihome-vacuum.0 (10579) Connected
                            2020-09-15 21:54:18.942 - info: mihome-vacuum.0 (10579) set nächster Timer: Nicht verfügbar
                            2020-09-15 21:54:18.997 - info: mihome-vacuum.0 (10579) create state for carpet_mode
                            Eventuell siehst du ja hier das Problem. Ich bin leider mit meinem Latein am ende.
                              @Bluelinux Da ist nichts ungewöhnliches zu sehen.
                                Hallo Dirk.
                                Funktioniert super! Vielen lieben Dank für die schnelle Realisierung!
                                • Bluelinux
                                  @Thomas-Braun du hattest was von eventuell "Canvas" Probleme gesprochen. Was meinst du denn damit? Muss der Roboter geroutet sein dafür?
                                    @Bluelinux
                                    'canvas' ist eine Grafik-Bibliothek, die von diversen Adaptern für die Darstellung von z. B. hier der Karte verwendet wird. Das entsprechende node-Modul wird aber nicht immer richtig installiert.
                                    Ich glaube aber der Adapter meckert das an bei einem Start, mindestens aber bei der Installation steht dazu dann was im log-file.
                                    • Bluelinux
                                      @Thomas-Braun achso, den Adapter habe ich installiert. Müsste nicht in den Objekten wenigstens eine Map-URL sein? eventuell liegt ja dort das Problem, denn der Datenpunkt ist leer. Wenn der Button "Karte Laden" gedrückt wird, dann passiert leider nix.
                                      • B4n4n3
                                        B4n4n3 last edited by B4n4n3
                                        Bei mir sieht es aus wie bei Bluelinux. Map URL leer.
                                        Hier mal mein Log vom Adapterstart.
                                        mihome-vacuum.0	2020-09-18 17:15:35.555	warn	(12019) Could not receive Mappointer, giving up
                                        mihome-vacuum.0	2020-09-18 17:15:15.059	warn	(12019) Could not receive Mappointer, giving up
                                        mihome-vacuum.0	2020-09-18 17:15:09.459	info	(12019) create state for carpet_mode
                                        mihome-vacuum.0	2020-09-18 17:15:08.881	info	(12019) set nächster Timer: Nicht verfügbar
                                        mihome-vacuum.0	2020-09-18 17:15:08.450	info	(12019) Connected
                                        mihome-vacuum.0	2020-09-18 17:15:08.411	info	(12019) connecting, this can take up to 10 minutes ...
                                        mihome-vacuum.0	2020-09-18 17:15:08.411	warn	(12019) Time difference between Mihome Vacuum and ioBroker: -58 sec
                                        mihome-vacuum.0	2020-09-18 17:15:08.398	info	(12019) New generation or new fw(3.5.8,004018) detected, create new states goto and zoneclean
                                        mihome-vacuum.0	2020-09-18 17:15:08.361	info	(12019) Cloud control disabled
                                        mihome-vacuum.0	2020-09-18 17:15:08.359	info	(12019) Expert mode disabled, states deleted
                                        mihome-vacuum.0	2020-09-18 17:15:07.749	info	(12019) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.1.6
                                        mihome-vacuum.0	2020-09-18 17:15:03.451	info	(1637) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        mihome-vacuum.0	2020-09-18 17:15:03.409	info	(1637) terminating
                                        mihome-vacuum.0	2020-09-18 17:15:03.268	info	(1637) Got terminate signal TERMINATE_YOURSELF
                                        mihome-vacuum.0	2020-09-18 17:14:53.699	warn	(1637) Could not receive Mappointer, giving up
                                        EDIT: OK liegt evtl. an der Version ... ist bei mir noch die 2.1.1 ... ich hab als Verwahrungsort "latest" eingestellt. Ist die 2.2.4 nur direkt auf github zu finden?
                                        • Meistertr
                                          hallo Leute ich muss mal eine Kurze umfrage machen, Ich brauche alle Modelbezeichnungen die igr mit dem adapter zur Zeit am laufen habt
                                          Folgende habe ich schon:
                                              'roborock.vacuum.s5' : VacuumManager,
                                              'roborock.vacuum.s6' : VacuumManager,
                                              'roborock.vacuum.m1s' : VacuumManager,
                                              'rockrobo.vacuum.v1' : VacuumManager
                                          R C F 3 Replies Last reply Reply Quote 0
                                            Rushmed Most Active @Meistertr last edited by
                                            @Meistertr Ich hab nen s6 maxV
                                            roborock.vacuum.a10
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            444465
