    4. Test Adapter AlarmControl V0.1.x
      canim @sigi234 last edited by
      Geile Adapter :)!, Ich würde das ganze ohne Presens machen können. Kannst du die Option mit RFID hinzufügen statt Presens?
      wawyo 1 Reply Last reply Reply Quote 0
        web4wasch last edited by
        Servus zusammen,
        hört sich gut an!!!!! 🙂
        Bei mir springt die Instanz nicht auf grün ---> Auszug aus dem Log
        host.ioBrokerMaster	2020-09-16 20:37:42.707	error	instance system.adapter.alarmcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.ioBrokerMaster	2020-09-16 20:37:42.707	error	Caught by controller[0]: }
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js' ]
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12) {
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
        host.ioBrokerMaster	2020-09-16 20:37:42.706	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.alarmcontrol/main.js:4:35)
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:840:27)
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:957:15)
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.alarmcontrol/main.js
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: Require stack:
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: Error: Cannot find module 'moment-duration-format'
        host.ioBrokerMaster	2020-09-16 20:37:42.705	error	Caught by controller[0]: ^
        host.ioBrokerMaster	2020-09-16 20:37:42.704	error	Caught by controller[0]: throw err;
        host.ioBrokerMaster	2020-09-16 20:37:42.704	error	Caught by controller[0]: internal/modules/cjs/loader.js:960
        evtl einer ne Idee?
        Danke für die RI.
        Glasfaser wawyo 3 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @web4wasch last edited by
          @web4wasch sagte in Test Adapter AlarmControl V0.1.x:
          Trage den Adapter in JS Instanz ein
            web4wasch @Glasfaser last edited by
            @Glasfaser Adapter ist vorhanden....!
            das ist es leider nicht...
            • Glasfaser
              @web4wasch
              Nimm den Adapter mal raus ..
              js stoppen... Adapter raus ... js starten
              js stoppen ... Eintrag vom Adapter wieder rein .. js starten
                @Glasfaser
                gleiches Problem.
                • Glasfaser
                  @web4wasch
                  ioBroker bzw. dein System mal neu gestartet
                    @Glasfaser
                    nö, habe ich nicht gemacht! Ist immer der letzte Ausweg und meiner Meinung bringt das nicht viel.
                    Sonst läuft ja alles stabil... Und die anderen hatten auch Problem damit.
                    Adapter über Katze "Beliebig" und https://github.com/spayrosam/iobroker.alarmcontrol installiert und Instanz angelegt, mehr habe ich nicht gemacht. Evtl weiß ja @wawyo etwas dazu.
                    Danke dir erstmal, Gruß.
                    W 1 Reply Last reply Reply Quote -1
                      web4wasch @web4wasch last edited by
                      @web4wasch said in Test Adapter AlarmControl V0.1.x:
                      ....auch KEIN Problem damit! meinte ich 😉
                      • Glasfaser
                        Glasfaser @web4wasch last edited by Glasfaser
                        @web4wasch
                        Wäre auch noch eine Möglichkeit :
                        cd /opt/iobroker
                        npm install moment-duration-format
                          @Glasfaser
                          das war das Zauberwort!!!! Danke dir... Versteh ich zwar nicht ganz, aber na ja! 😉
                          Soll ich dann alle Adapter JS über die Konsole installieren????????
                          • Glasfaser
                            Kurz und Knapp .. nein ... das war wohl/hoffentlich eine Ausnahme !
                              was muss ich denn im Telegram Objekt eintragen? Kann ich verschiedene User auswählen?
                              Danke.
                                @Glasfaser
                                Ich hab noch ne andere Frage ---> habe gesehen das du "View Alarmanlage..." deine gepostet hast.
                                Ich würde gerne von CCU auf ioBroker umziehen, mit welchen Mitteln (Script, Adapter etc.) setzt du deine Alarmanlage um?
                                Danke dir für die RI.
                                wawyo Glasfaser 2 Replies Last reply Reply Quote 0
                                • wawyo
                                  wawyo Developer @web4wasch last edited by
                                  @sigi234 said in Test Adapter AlarmControl V0.1.x:
                                  @wawyo
                                  Ok, ist das Icon Problem gelöst?
                                  das Icon taucht nur bei Telegram Nachrichten (Alexa wird gesteuert mit dem selben satz aber ohne Icon)
                                  Bitte stellen Sie sicher, dass Du das Telegrammobjekt nicht mit dem Alexa-Objekt verwechselt hast.
                                  • wawyo
                                    Servus zusammen,
                                    evtl einer ne Idee?
                                    Danke für die RI.
                                    Bitte installiere moment.js
                                    Install moment.js package:
                                    npm install moment --save-prod
                                    • wawyo
                                      wawyo Developer @canim last edited by
                                      @canim said in Test Adapter AlarmControl V0.1.x:
                                      Im Moment ist Präsenz der Kern des Adapters. Vielleicht kann ich RFID für einen späteren Zeitpunkt einfügen 😉
                                      • wawyo
                                        Danke.
                                        Derzeit ist nur ein Empfänger möglich.
                                        • wawyo
                                          wawyo Developer @web4wasch last edited by wawyo
                                          Vielen Dank für all Feedback.
                                          Der nächste Sensor wäre ein Steckdosenergiesensor mit Verbrauchsanzeige und Abschaltoption (nützlich zum Aufladen von Mobiltelefonen, Waschmaschine und ..)
                                          • wawyo
                                            wawyo Developer @wawyo last edited by
                                            Tipp für Alle
                                            Folgende szenario:
                                            Person X vergisst immer wieder, das Licht auszuschalten.
                                            Wie löse ich das Problem?
                                            Um das Problem zu lösen, brauche ich 1x Andere-Sensoren:
                                            Fertig 😉
                                            1.0k
                                            alarmanlage countdown motionsensor presence detection tür-fenster-kontakt zeitschaltuhr
                                            7928
