    4. Test Adapter Linux Control v1.x.x
      liv-in-sky @Ceel last edited by
      @Ceel sagte in Test Adapter Linux Control v0.x.x:
      nct6775
      vielleicht hier: https://bbs.archlinux.org/viewtopic.php?pid=1440350#p1440350
        Ceel @liv-in-sky last edited by
        @liv-in-sky ein sensors-detect und ein REBOOT reicht
        pch_cannonlake-virtual-0
        Adapter: Virtual device
        temp1:        +56.0°C
        coretemp-isa-0000
        Adapter: ISA adapter
        Package id 0:  +55.0°C  (high = +80.0°C, crit = +100.0°C)
        Core 0:        +48.0°C  (high = +80.0°C, crit = +100.0°C)
        Core 1:        +55.0°C  (high = +80.0°C, crit = +100.0°C)
        Core 2:        +48.0°C  (high = +80.0°C, crit = +100.0°C)
        Core 3:        +45.0°C  (high = +80.0°C, crit = +100.0°C)
        nct6793-isa-0290
        in0:                    +1.17 V  (min =  +0.00 V, max =  +1.74 V)
        in1:                    +1.86 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in2:                    +3.31 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in3:                    +3.36 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in4:                    +0.27 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in5:                    +0.15 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in6:                    +0.69 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in7:                    +3.30 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in8:                    +3.07 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in9:                    +1.06 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in10:                   +0.18 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in11:                   +0.15 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in12:                   +1.86 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in13:                   +1.72 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        in14:                   +0.21 V  (min =  +0.00 V, max =  +0.00 V)  ALARM
        fan1:                     0 RPM  (min =    0 RPM)
        fan2:                  1010 RPM  (min =    0 RPM)
        fan3:                     0 RPM  (min =    0 RPM)
        fan4:                     0 RPM  (min =    0 RPM)
        fan5:                     0 RPM  (min =    0 RPM)
        fan6:                     0 RPM  (min =    0 RPM)
        SYSTIN:                +111.0°C  (high =  +0.0°C, hyst =  +0.0°C)  sensor = thermistor
        CPUTIN:                 +47.5°C    sensor = thermistor
        AUXTIN0:                +44.0°C  (high =  +0.0°C, hyst =  +0.0°C)  ALARM  sensor = thermistor
        AUXTIN1:               +105.0°C    sensor = thermistor
        AUXTIN2:               +103.0°C    sensor = thermistor
        AUXTIN3:               +101.0°C    sensor = thermistor
        PECI Agent 0:           +56.5°C  (high = +80.0°C, hyst = +75.0°C)
                                         (crit = +100.0°C)
        PCH_CHIP_CPU_MAX_TEMP:   +0.0°C
        PCH_CHIP_TEMP:           +0.0°C
        PCH_CPU_TEMP:            +0.0°C
        intrusion0:            OK
        intrusion1:            ALARM
        beep_enable:           disabled
          @Ceel
          cool - werden andere sicher auch noch gebrauchen können !
          • da_Woody
            da_Woody @liv-in-sky last edited by da_Woody
            @liv-in-sky neugierig wie ich mal bin:
            root@Homeserver:~# sensors
            nouveau-pci-0100
            Adapter: PCI adapter
            GPU core:     +0.88 V  (min =  +0.82 V, max =  +1.21 V)
            fan1:           0 RPM
            temp1:        +44.0°C  (high = +95.0°C, hyst =  +3.0°C)
                                   (crit = +105.0°C, hyst =  +5.0°C)
                                   (emerg = +135.0°C, hyst =  +5.0°C)
            power1:       22.57 W  (crit = 200.00 mW)
            acpitz-acpi-0
            Adapter: ACPI interface
            temp1:        +27.8°C  (crit = +105.0°C)
            temp2:        +29.8°C  (crit = +105.0°C)
            coretemp-isa-0000
            Package id 0:  +47.0°C  (high = +80.0°C, crit = +100.0°C)
            Core 0:        +47.0°C  (high = +80.0°C, crit = +100.0°C)
            Core 1:        +42.0°C  (high = +80.0°C, crit = +100.0°C)
            Core 2:        +40.0°C  (high = +80.0°C, crit = +100.0°C)
            Core 3:        +38.0°C  (high = +80.0°C, crit = +100.0°C)
            root@Homeserver:~#
              liv-in-sky @da_Woody last edited by
              @da_Woody
              schaut doch gut aus
              • da_Woody
                @liv-in-sky jep. war noch zu faul die gfx auszubauen... 😄
                  liv-in-sky @Scrounger last edited by liv-in-sky
                  @Scrounger
                  ich habe immer wieder ein problem mit den selbst definierten buttons. es ist ein raspi 4 . der refresh button funktioniert noch aber alle selbstangelegten buttons nicht - es kommt auch kein eintrag im log, dass er etwas ausführen würde (beim refresh schon). andere daten (folder, befehle) werden auch geholt und upgedatet.
                  es scheint sich auch nur um den einen client zu handeln - andere server mit ihen buttons funktionieren
                  nachdem ich die instanz neustarte funktioniert es wieder - der raspi wird erst später eingeschalten (mein iobroker startet um 6:30 neu) .
                  nochmal den ablauf
                  • um 6:30 startet proxmox server mit allen containern
                  • gegen 8 wird raspi4 eingeschalten - buttons funktionieren dann nicht
                  • neustart der instanz
                  • dann funktionieren die buttons - den restlichen tag über
                  hast du eine idee dazu ?
                  Scrounger 2 Replies Last reply Reply Quote 0
                  • Scrounger
                    Scrounger Developer @liv-in-sky last edited by
                    @liv-in-sky
                    Ja hab ne Idee woran das liegen könnte - schau ich mir an.
                    • Scrounger
                      @liv-in-sky
                      Teste bitte die aktuelle github version, sollte jetzt wieder funktionieren.
                        @Scrounger ich installiere und schaue was morgen früh passiert - auf jeden fall schon mal danke
                        • Scrounger
                          @liv-in-sky hatte schon vermutet daß ich bis morgen 8h warten muss 😉
                            @Scrounger moin
                            sieht ganz gut aus - nutze "barrier" beim raspi und konnte dies sofort einschalten über button - adapter reagiert
                            danke fürs fixen
                            Mono990 1 Reply Last reply Reply Quote 0
                            • Mono990
                              Mono990 @liv-in-sky last edited by
                              Ich bekomme den adapter leider garnicht installiert. Er downloadet alles sagt dann das erfolgreich installiert wurde.
                              aber ich kann den adapter nirgentwo finden bei bei Instanzen oder Objekte.
                              Habe Raspi4
                                liv-in-sky @Mono990 last edited by liv-in-sky
                                @Mono990 wenn du über github installierst, musst du im adapter tab ein plus drücken (ganz rechts beim adapter by listview) und die instanz selber anlegen
                                • Mono990
                                  Mono990 @Scrounger last edited by
                                  @Scrounger
                                  Habe 2 server erfolgreich eingebunden aber mein Synology NAS macht noch schwierigkeiten. ich bekomme im Log diese fehlermeldung.
                                  weiß jemand wie ich das beheben kann?
                                  linux-control.0	2020-10-11 21:59:55.608	error	(30942) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js
                                  linux-control.0	2020-10-11 21:59:55.605	error	(30942) [getConnection] Could not establish a connection to 'synology' (192.168.188.2:22)!
                                  linux-control.0	2020-10-11 21:59:51.512	info	(30942) successful received data from debianiobroker (192.168.188.3:22)
                                  linux-control.0	2020-10-11 21:59:50.843	info	(30942) getting data from synology (192.168.188.2:22)
                                  linux-control.0	2020-10-11 21:59:43.999	info	(30942) getting data from debianiobroker (192.168.188.3:22)
                                  linux-control.0	2020-10-11 21:59:39.544	info	(30942) successful received data from proxmox (192.168.188.4:22)
                                  linux-control.0	2020-10-11 21:59:38.855	info	(30942) getting data from proxmox (192.168.188.4:22)
                                  linux-control.0	2020-10-11 21:58:50.831	error	(30942) [getConnection] error: All configured authentication methods failed, stack: Error: All configured authentication methods failed at doNextAuth (/opt/iobroker/node_modules/ssh2/lib/client.js
                                  linux-control.0	2020-10-11 21:58:50.827	error	(30942) [getConnection] Could not establish a connection to 'synology' (192.168.188.2:22)!
                                  linux-control.0	2020-10-11 21:58:44.637	info	(30942) getting data from synology (192.168.188.2:22)
                                  linux-control.0	2020-10-11 21:58:43.996	info	(30942) successful received data from debianiobroker (192.168.188.3:22)
                                  linux-control.0	2020-10-11 21:58:38.852	info	(30942) successful received data from proxmox (192.168.188.4:22)
                                  linux-control.0	2020-10-11 21:58:38.098	info	(30942) getting data from proxmox (192.168.188.4:22)
                                  linux-control.0	2020-10-11 21:58:36.290	info	(30942) getting data from debianiobroker (192.168.188.3:22)
                                  • Glasfaser
                                    Glasfaser @Mono990 last edited by Glasfaser
                                    @Mono990 sagte in Test Adapter Linux Control v0.x.x:
                                    Mit deinem Admin Benutzer sich anmelden , nicht mit einem angelegten Benutzer der auch Administrationsrechte zugewiesen hat .
                                      liv-in-sky @Glasfaser last edited by
                                      @Glasfaser
                                      @Mono990
                                      wir haben uns mit dem admin user angemeldet - über putty geht's - aber der adapter bringt die fehler - ich habe keine synology erfahrung, daher dachten wir mal, wir versuchen es hier
                                        @Glasfaser
                                        ps: falls du sowas anbietest - vielleicht magst du mit teamviewer mal draufsehen
                                          @Segway hat eine anleitung für die temp messung für linux gemacht
                                          https://forum.iobroker.net/topic/37925/temperatur-auslesen-eines-anderen-rechners-howto
                                          vielleicht braucht es jmd für diesen adapter
                                          • Segway
                                            Segway last edited by
                                            So, ich probiere gerade diesen Adapter aus, da ich ursprünglich ja einen anderen Weg gegangen bin.
                                            Soweit alles gut - folgende Frage / Phänomen:
                                            Wenn die genrellen Tabs NICHT angeklickt sind ich aber die einzelnen zu den "Rechnern" hinzugefügt habe, scheinen die Datenpunkte nicht angelegt zu werden. Oder mache ich was falsch ?
                                            adapter control hardware linux steuern
                                            70
                                            675
                                            163983
