    4. Test Adapter time-switch v2.0.x GitHub/Latest
    • Stephan Schleich
      Stephan Schleich @sigi234 last edited by Stephan Schleich
      @sigi234 komisch, sieht damit nicht so wie auf deim letzten Bild aus, die Wochentage sind gleich groß geblieben und haben auch keine farbe, muss ich mich mal spielen, aber Vielen Dank 👍
      /** Time-Switch Widget **/
      app-on-off-schedule-widget {
          /* Primary color (button background, toggle switch color) */
          --ts-widget-primary-color: #337ab7;
          /* Background color of the widget */
          --ts-widget-bg-color: #424242;
          /* Background color of the triggers */
          --ts-widget-trigger-bg-color: #272727;
          /* Foreground color (font color and scrollbar color) */
          --ts-widget-fg-color: white;
          /* Font color of the switched states id */
          --ts-widget-oid-fg-color: #a5a5a5;
          /* Font color in buttons */
          --ts-widget-btn-fg-color: white;
          /* Font color of a disabled weekday */
          --ts-widget-weekdays-disabled-fg-color: red;
          /* Font color of an enabled weekday */
          --ts-widget-weekdays-enabled-fg-color: green;
          /* Font color of the name of the widget (defaults to --ts-widget-fg-color) */
          --ts-widget-name-fg-color: white;
          /* Font color of switched time (defaults to --ts-widget-fg-color) */
          --ts-widget-switched-time-fg-color: white;
          /* Font color of switched value (defaults to --ts-widget-fg-color)*/
          --ts-widget-switched-value-fg-color: white;
          /* Font color of the astro time (defaults to --ts-widget-fg-color) */
          --ts-widget-astro-time-fg-color: black;
          /* Font color of the astro time's shift */
          --ts-widget-astro-shift-fg-color: #5d5d5d;
          /* Font family used in the whole widget */
          --ts-widget-font-family: 'Roboto', 'Segoe UI', BlinkMacSystemFont, system-ui, -apple-system;
          /* Font size of the name of the widget */
          --ts-widget-name-font-size: 2em;
          /* Font size of the switched oid */
          --ts-widget-oid-font-size: 12px;
          /* Applies a filter to icons used in buttons (safe, edit, remove, cancel), for
             white use invert(1) and for black invert(0) */
          --ts-widget-img-btn-filter: invert(1);
          /* Add trigger dropdown background color */
          --ts-widget-add-trigger-dropdown-bg-color: #f1f1f1;
          /* Add trigger dropdown font color */
          --ts-widget-add-trigger-dropdown-fg-color: black;
          /* Add trigger dropdown hover background color */
          --ts-widget-add-trigger-dropdown-hover-bg-color: #ddd;
          /* ! Changing these may break the layout, change at your own risk */
          /* Font size of weekdays */
          --ts-widget-weekdays-font-size: 16px;
          /* Font size of switched value (on/off) */
          --ts-widget-switched-value-font-size: 2em;
          /* Font size of switched time */
          --ts-widget-switched-time-font-size: 2em;
          /* Font size of the astro time (e.g. Sunrise, ...) */
          --ts-widget-astro-time-font-size: 1.5em;
          /* Font size of the astro time's shift */
          --ts-widget-astro-shift-font-size: 1em;
        sigi234 Forum Testing Most Active @Stephan Schleich last edited by
        @Stephan-Schleich
        So, das Richtige!
        Stephan Schleich 1 Reply Last reply Reply Quote 1
        • Stephan Schleich
          @sigi234 Danke, hab's schon gefunden 🙂
          • qqolli
            qqolli @walli545 last edited by
            @walli545
            Hallo Walli,
            ich habe Deinen Adapter istallier, aber wenn ich die Adaptereinstellungen öffne, kann ich zwar einen neuen Schaltplan hinzufügen, aber nicht editieren:
            Widget taucht in der Vis auf, aber ohne gültige ID geht er natürlich nicht.
            Stephan Schleich 1 Reply Last reply Reply Quote 0
            • Stephan Schleich
              Stephan Schleich @qqolli last edited by
              @qqolli Das setzt du dann alles via Widget in der Vis
              qqolli 1 Reply Last reply Reply Quote 0
              • qqolli
                qqolli @Stephan Schleich last edited by
                @Stephan-Schleich
                Hallo Stephan,
                wie soll das gehen? In der Anleitung steht, das das in den Adaptereinstellungen zu erfolgen hat, erst dann gibt es eine gültige ID; diese ist dann in der Vis einzutragen.
                In der Vis steht dann:
                • Stephan Schleich
                  • qqolli
                    @Stephan-Schleich
                    Das geht leider auch nicht:
                    oder muss unter stateID[1] zwingend ein alias angegeben werden?
                      sigi234 Forum Testing Most Active @qqolli last edited by
                      @qqolli
                      Welche Version vom Adapter?
                      • qqolli
                        qqolli @sigi234 last edited by
                        @sigi234
                        Hallo Sigi,
                        es ist die v.2.1.0
                        • Stephan Schleich
                          @qqolli Lösch mal den Eintrag in der Instanz und legs neu an, wenn man manuell im Objekt was rummodelt spinnt es machmal hatte ich schon mal, konnte via Widget nix mehr editieren
                          • qqolli
                            @Stephan-Schleich
                            Das bringt leider rein gar nichts.
                            Wenn ich den Adapter neu starte bekomme ich im Log die folgende Ausgabe:
                            time-switch.0	2020-09-18 19:45:01.652	info	2
                            time-switch.0	2020-09-18 19:45:01.652	info	(27697) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.time-switch, node: v12.18.4, js-controller: 3.1.6
                            time-switch.0	2020-09-18 19:44:58.012	warn	(26761) Got terminate signal. Checking desired PID: 27697 vs own PID 26761
                            time-switch.0	2020-09-18 19:44:58.005	info	(26761) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            time-switch.0	2020-09-18 19:44:58.003	info	(26761) terminating
                            time-switch.0	2020-09-18 19:44:58.002	info	(26761) cleaned everything up...
                            time-switch.0	2020-09-18 19:44:57.997	warn	(26761) Got terminate signal. Checking desired PID: 0 vs own PID 26761
                            • Stephan Schleich
                              @qqolli Kein Plan dann.
                              @walli545 Die Standard Größe muss größer werden Astro wird am Anfang verdeckt
                              Stephan Schleich qqolli 2 Replies Last reply Reply Quote 0
                              • Stephan Schleich
                                Stephan Schleich @Stephan Schleich last edited by
                                @walli545 Gäbe es auch eine Möglichkeit die Automatik mit einer Anwesenheitsprüfung zu kombinieren?
                                • qqolli
                                  @Stephan-Schleich
                                  Kein Problem, hab ihn am Ende doch noch zum laufen gebracht 🙂
                                  • walli545
                                    walli545 @AndreasW63 last edited by walli545
                                    @AndreasW63 Hallo, gibt es Fehlermeldungen in der Browserconsole (F12)? Bzw. im Adapterlog (im Admin)?
                                    @qqolli Evtl. könntest du kurz beschreiben was das Problem war bzw. was du gemacht hast falls andere ebenfalls darauf stoßen
                                    @Stephan-Schleich ich habe bereits das Backend für ein Feature implementiert, mit dem man zusätzlich einen State angeben kann, der vor dem auslösen geprüft wird und nur wenn dieser true ist, wird auch geschalten. Meinst du soetwas?
                                    @all Sorry für meine späte Rückmeldung, aber ich komme aktuell beruflich/privat nicht viel dazu etwas zu machen deswegen habe ich auch in letzter Zeit nicht weiterentwickelt. Falls ich wieder mal Zeit habe melde ich mich hier😬
                                    Stephan Schleich qqolli 2 Replies Last reply Reply Quote 1
                                    • Stephan Schleich
                                      Stephan Schleich @walli545 last edited by
                                      @walli545 Perfekt, genau das meinte ich. Top 👍🏻
                                        michihorn last edited by michihorn
                                        Hallöchen sieht super aus der Adapter, kann man evtl. auchnoch irgendwie die Beschreibung des Datenpunktes ausblenden?
                                        Michael
                                        EDIT: Habs gefunden
                                        • qqolli
                                          @walli545
                                          Sorry, da hast Du natürlich recht. Bei mir war es schlicht und einfach ein Leerzeichen zu viel am Ende. Hatte die ID vom Adapter kopiert und dabei ist das zusätzliche Leerzeichen am Ende reingekommen. Nachdem ich es entfernt hatte war alles gut 🙂
                                          Noch eine Frage, kann man das Widget "skalieren", da es doch recht groß ist. Wenn ich es verkleinere werden viele Teile verdeckt, die man dan mittels Scrollbalken wieder sichtbar machen kann. Meine aktuelle Version ist die v.2.1.0.
                                          walli545 1 Reply Last reply Reply Quote 0
                                            AndreasW63 last edited by AndreasW63
                                            mittlerweile habe ich mehrere Schaltuhren mit dem Adapter "time-switch" erstellt.
                                            Die Schaltuhren funktionieren mit den eingestellten Schaltzeiten ganz prima.
                                            Gerne würde ich die Uhren auch mit den Parametern "Sonnenaufgang" bzw. "Sonnenuntergang" steuern.
                                            Bisher kommen ich da nicht weiter. In den Einstellungen des Javascript Adapters habe ich unter den Astro-Einstellungen Wert mit der Bezeichnung "Sonnenaufgang" bzw. "-untergang" gefunden. Diese werden vom Adapter "time-switch" vermutlich ignoriert oder nicht ausgewertet.
                                            Wie komme ich hier weiter.
                                            Gruß Andreas
                                            adapter switch test time vis zeitschaltuhr
                                            75
                                            481
                                            113761
