    4. Fehlermeldung beim Update auf Javascript 4.8.1
    UNSOLVED Fehlermeldung beim Update auf Javascript 4.8.1
    • Chaot
      Chaot @Thomas Braun last edited by
      @Thomas-Braun sagte in Fehlermeldung beim Update auf Javascript 4.8.1:
      dmesg
      [    1.758122] zbud: loaded
      [    1.758976] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    1.759392] fuse: init (API version 7.31)
      [    1.759435] *** VALIDATE fuse ***
      [    1.759442] *** VALIDATE fuse ***
      [    1.759661] Platform Keyring initialized
      [    1.765459] Key type asymmetric registered
      [    1.765465] Asymmetric key parser 'x509' registered
      [    1.765484] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
      [    1.765589] io scheduler mq-deadline registered
      [    1.766061] pwm-lpss 0000:00:1a.0: can't derive routing for PCI INT A
      [    1.766069] pwm-lpss 0000:00:1a.0: PCI INT A: not connected
      [    1.766699] pcieport 0000:00:13.0: PME: Signaling with IRQ 122
      [    1.767116] pcieport 0000:00:13.1: PME: Signaling with IRQ 123
      [    1.767537] pcieport 0000:00:13.2: PME: Signaling with IRQ 124
      [    1.767668] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
      [    1.767819] intel_idle: Please enable MWAIT in BIOS SETUP
      [    1.768039] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
      [    1.768225] ACPI: Power Button [PWRB]
      [    1.768315] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
      [    1.768363] ACPI: Sleep Button [SLPB]
      [    1.775171] thermal LNXTHERM:00: registered as thermal_zone0
      [    1.775182] ACPI: Thermal Zone [TZ01] (60 C)
      [    1.775574] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
      [    1.781063] Linux agpgart interface v0.103
      [    1.781798] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
      [    1.781815] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
      [    1.796216] loop: module loaded
      [    1.797655] libphy: Fixed MDIO Bus: probed
      [    1.797666] tun: Universal TUN/TAP device driver, 1.6
      [    1.797882] PPP generic driver version 2.4.2
      [    1.798168] i8042: PNP: No PS/2 controller found.
      [    1.798174] i8042: Probing ports directly.
      [    1.811309] serio: i8042 KBD port at 0x60,0x64 irq 1
      [    1.811327] serio: i8042 AUX port at 0x60,0x64 irq 12
      [    1.812018] mousedev: PS/2 mouse device common for all mice
      [    1.812635] rtc_cmos 00:04: RTC can wake from S4
      [    1.813461] rtc_cmos 00:04: registered as rtc0
      [    1.813501] rtc_cmos 00:04: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
      [    1.813519] i2c /dev entries driver
      [    1.813630] device-mapper: uevent: version 1.0.3
      [    1.813962] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
      [    1.814054] platform eisa.0: Probing EISA bus 0
      [    1.814077] platform eisa.0: EISA: Cannot allocate resource for mainboard
      [    1.814085] platform eisa.0: Cannot allocate resource for EISA slot 1
      [    1.814090] platform eisa.0: Cannot allocate resource for EISA slot 2
      [    1.814096] platform eisa.0: Cannot allocate resource for EISA slot 3
      [    1.814102] platform eisa.0: Cannot allocate resource for EISA slot 4
      [    1.814107] platform eisa.0: Cannot allocate resource for EISA slot 5
      [    1.814113] platform eisa.0: Cannot allocate resource for EISA slot 6
      [    1.814118] platform eisa.0: Cannot allocate resource for EISA slot 7
      [    1.814124] platform eisa.0: Cannot allocate resource for EISA slot 8
      [    1.814129] platform eisa.0: EISA: Detected 0 cards
      [    1.814146] intel_pstate: Intel P-state driver initializing
      [    1.815397] ledtrig-cpu: registered to indicate activity on CPUs
      [    1.815405] EFI Variables Facility v0.08 2004-May-17
      [    1.827115] input: AT Raw Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
      [    1.848213] drop_monitor: Initializing network drop monitor service
      [    1.848483] NET: Registered protocol family 10
      [    1.863541] Segment Routing with IPv6
      [    1.863600] NET: Registered protocol family 17
      [    1.863645] Bridge firewalling registered
      [    1.863889] Key type dns_resolver registered
      [    1.864900] RAS: Correctable Errors collector initialized.
      [    1.865009] microcode: sig=0x506c9, pf=0x1, revision=0x20
      [    1.865226] microcode: Microcode Update Driver: v2.2.
      [    1.865405] *** VALIDATE rdt ***
      [    1.865419] resctrl: L2 allocation detected
      [    1.865426] IPI shorthand broadcast: enabled
      [    1.865441] sched_clock: Marking stable (1863818466, 1575076)->(1871941484, -6547942)
      [    1.865772] registered taskstats version 1
      [    1.865790] Loading compiled-in X.509 certificates
      [    1.865847] zswap: loaded using pool lzo/zbud
      [    1.866219] Key type ._fscrypt registered
      [    1.866229] Key type .fscrypt registered
      [    1.880724] Key type big_key registered
      [    1.880747] Key type trusted registered
      [    1.888023] Key type encrypted registered
      [    1.888045] AppArmor: AppArmor sha1 policy hashing enabled
      [    1.889410] integrity: Loading X.509 certificate: UEFI:db
      [    1.889500] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
      [    1.889506] integrity: Loading X.509 certificate: UEFI:db
      [    1.889555] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
      [    1.891351] ima: Allocated hash algorithm: sha1
      [    1.920485] ima: No architecture policies found
      [    1.920521] evm: Initialising EVM extended attributes:
      [    1.920525] evm: security.selinux
      [    1.920527] evm: security.SMACK64
      [    1.920529] evm: security.SMACK64EXEC
      [    1.920531] evm: security.SMACK64TRANSMUTE
      [    1.920533] evm: security.SMACK64MMAP
      [    1.920535] evm: security.apparmor
      [    1.920537] evm: security.ima
      [    1.920539] evm: security.capability
      [    1.920542] evm: HMAC attrs: 0x1
      [    1.921315] PM:   Magic number: 4:480:843
      [    1.921687] rtc_cmos 00:04: setting system clock to 2020-09-13T16:48:44 UTC (1600015724)
      [    1.923626] Freeing unused decrypted memory: 2040K
      [    1.924601] Freeing unused kernel image memory: 2696K
      [    1.925347] Write protecting the kernel read-only data: 22528k
      [    1.926540] Freeing unused kernel image memory: 2008K
      [    1.927161] Freeing unused kernel image memory: 1164K
      [    1.944858] x86/mm: Checked W+X mappings: passed, no W+X pages found.
      [    1.944935] x86/mm: Checking user space page tables
      [    1.961723] x86/mm: Checked W+X mappings: passed, no W+X pages found.
      [    1.961730] Run /init as init process
      [    2.227550] ahci 0000:00:12.0: version 3.0
      [    2.233018] idma64 idma64.0: Found Intel integrated DMA 64-bit
      [    2.237989] ahci 0000:00:12.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
      [    2.238001] ahci 0000:00:12.0: flags: 64bit ncq sntf pm clo only pmp pio slum part deso sadm sds apst
      [    2.239965] idma64 idma64.1: Found Intel integrated DMA 64-bit
      [    2.240547] idma64 idma64.2: Found Intel integrated DMA 64-bit
      [    2.240982] idma64 idma64.3: Found Intel integrated DMA 64-bit
      [    2.241528] scsi host0: ahci
      [    2.241803] idma64 idma64.4: Found Intel integrated DMA 64-bit
      [    2.242488] scsi host1: ahci
      [    2.242615] ata1: SATA max UDMA/133 abar m2048@0x91423000 port 0x91423100 irq 125
      [    2.242622] ata2: SATA max UDMA/133 abar m2048@0x91423000 port 0x91423180 irq 125
      [    2.245524] libphy: r8169: probed
      [    2.245792] r8169 0000:03:00.0 eth0: RTL8168h/8111h, f4:4d:30:6a:a6:9f, XID 541, IRQ 127
      [    2.245799] r8169 0000:03:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
      [    2.263716] i801_smbus 0000:00:1f.1: can't derive routing for PCI INT A
      [    2.263726] i801_smbus 0000:00:1f.1: PCI INT A: not connected
      [    2.263757] i801_smbus 0000:00:1f.1: SPD Write Disable is set
      [    2.263784] i801_smbus 0000:00:1f.1: SMBus using polling
      [    2.264040] xhci_hcd 0000:00:15.0: xHCI Host Controller
      [    2.264067] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 1
      [    2.265198] xhci_hcd 0000:00:15.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
      [    2.265279] xhci_hcd 0000:00:15.0: cache line size of 64 is not supported
      [    2.265635] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
      [    2.265643] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.265648] usb usb1: Product: xHCI Host Controller
      [    2.265651] usb usb1: Manufacturer: Linux 5.4.60-1-pve xhci-hcd
      [    2.265655] usb usb1: SerialNumber: 0000:00:15.0
      [    2.266005] hub 1-0:1.0: USB hub found
      [    2.266033] hub 1-0:1.0: 8 ports detected
      [    2.267091] xhci_hcd 0000:00:15.0: xHCI Host Controller
      [    2.267107] xhci_hcd 0000:00:15.0: new USB bus registered, assigned bus number 2
      [    2.267116] xhci_hcd 0000:00:15.0: Host supports USB 3.0 SuperSpeed
      [    2.267227] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
      [    2.267233] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
      [    2.267237] usb usb2: Product: xHCI Host Controller
      [    2.267241] usb usb2: Manufacturer: Linux 5.4.60-1-pve xhci-hcd
      [    2.267244] usb usb2: SerialNumber: 0000:00:15.0
      [    2.267451] hub 2-0:1.0: USB hub found
      [    2.267472] hub 2-0:1.0: 7 ports detected
      [    2.299625] r8169 0000:03:00.0 enp3s0: renamed from eth0
      [    2.559731] ata2: SATA link down (SStatus 4 SControl 300)
      [    2.601516] usb 1-4: new full-speed USB device number 2 using xhci_hcd
      [    2.721528] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
      [    2.721944] ata1.00: supports DRM functions and may not be fully accessible
      [    2.722223] ata1.00: ATA-10: CT500MX500SSD1, M3CR023, max UDMA/133
      [    2.722234] ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
      [    2.724939] ata1.00: supports DRM functions and may not be fully accessible
      [    2.727278] ata1.00: configured for UDMA/133
      [    2.737516] ahci 0000:00:12.0: port does not support device sleep
      [    2.738275] scsi 0:0:0:0: Direct-Access     ATA      CT500MX500SSD1   023  PQ: 0 ANSI: 5
      [    2.738864] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
      [    2.738871] sd 0:0:0:0: [sda] 4096-byte physical blocks
      [    2.738892] sd 0:0:0:0: [sda] Write Protect is off
      [    2.738897] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
      [    2.738928] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
      [    2.738964] sd 0:0:0:0: Attached scsi generic sg0 type 0
      [    2.757888]  sda: sda1 sda2 sda3
      [    2.759023] sd 0:0:0:0: [sda] supports TCG Opal
      [    2.759032] sd 0:0:0:0: [sda] Attached SCSI disk
      [    3.401989] usb 1-4: New USB device found, idVendor=0463, idProduct=ffff, bcdDevice= 2.02
      [    3.402000] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=4
      [    3.402005] usb 1-4: Product: Eaton 3S
      [    3.402008] usb 1-4: Manufacturer: EATON
      [    3.402011] usb 1-4: SerialNumber: Blank
      [    3.405136] hidraw: raw HID events driver (C) Jiri Kosina
      [    3.529345] usb 1-8: new full-speed USB device number 3 using xhci_hcd
      [    3.678786] usb 1-8: New USB device found, idVendor=8087, idProduct=0aa7, bcdDevice= 0.01
      [    3.678797] usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
      [    5.549312] raid6: sse2x4   gen()  5892 MB/s
      [    5.597311] raid6: sse2x4   xor()  2686 MB/s
      [    5.645314] raid6: sse2x2   gen()  5437 MB/s
      [    5.693318] raid6: sse2x2   xor()  3359 MB/s
      [    5.741320] raid6: sse2x1   gen()  4976 MB/s
      [    5.789309] raid6: sse2x1   xor()  2891 MB/s
      [    5.789312] raid6: using algorithm sse2x4 gen() 5892 MB/s
      [    5.789314] raid6: .... xor() 2686 MB/s, rmw enabled
      [    5.789317] raid6: using ssse3x2 recovery algorithm
      [    5.790721] xor: measuring software checksum speed
      [    5.829309]    prefetch64-sse: 10789.000 MB/sec
      [    5.869309]    generic_sse:  9413.000 MB/sec
      [    5.869312] xor: using function: prefetch64-sse (10789.000 MB/sec)
      [    5.884397] Btrfs loaded, crc32c=crc32c-intel
      [    6.346649] usbcore: registered new interface driver usbhid
      [    6.346658] usbhid: USB HID core driver
      [    6.350645] hid-generic 0003:0463:FFFF.0001: hiddev0,hidraw0: USB HID v1.10 Device [EATON Eaton 3S] on usb-0000:00:15.0-4/input0
      [    6.407292] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
      [    6.679870] systemd[1]: Inserted module 'autofs4'
      [    6.766797] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
      [    6.785758] systemd[1]: Detected architecture x86-64.
      [    6.810098] systemd[1]: Set hostname to <pve>.
      [    7.017821] systemd[1]: /lib/systemd/system/nut-monitor.service:6: PIDFile= references path below legacy directory /var/run/, updating /var/run/nut/upsmon.pid \xe2\x86\x92 /run/nut/upsmon.pid; please update the unit file accordingly.
      [    7.051486] systemd[1]: Listening on Journal Audit Socket.
      [    7.051989] systemd[1]: Listening on LVM2 poll daemon socket.
      [    7.052178] systemd[1]: Listening on Device-mapper event daemon FIFOs.
      [    7.061619] systemd[1]: Listening on RPCbind Server Activation Socket.
      [    7.062045] systemd[1]: Listening on udev Kernel Socket.
      [    7.062316] systemd[1]: Listening on Syslog Socket.
      [    7.103403] VFIO - User Level meta-driver version: 0.3
      [    7.112284] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
      [    7.112904] RPC: Registered named UNIX socket transport module.
      [    7.112914] RPC: Registered udp transport module.
      [    7.112916] RPC: Registered tcp transport module.
      [    7.112919] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    7.123634] vfio-pci 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
      [    7.141324] vfio_pci: add [8086:5a85[ffffffff:ffffffff]] class 0x000000/00000000
      [    7.148740] Loading iSCSI transport class v2.0-870.
      [    7.157568] iscsi: registered transport (tcp)
      [    7.196834] iscsi: registered transport (iser)
      [    7.215892] spl: loading out-of-tree module taints kernel.
      [    7.231392] znvpair: module license 'CDDL' taints kernel.
      [    7.231402] Disabling lock debugging due to kernel taint
      [    7.249177] systemd-journald[360]: Received request to flush runtime journal from PID 1
      [    7.427773] ite_cir: Auto-detected model: ITE8708 CIR transceiver
      [    7.427782] ite_cir: Using model: ITE8708 CIR transceiver
      [    7.427786] ite_cir: TX-capable: 1
      [    7.427788] ite_cir: Sample period (ns): 8680
      [    7.427791] ite_cir: TX carrier frequency (Hz): 38000
      [    7.427793] ite_cir: TX duty cycle (%): 33
      [    7.427796] ite_cir: RX low carrier frequency (Hz): 0
      [    7.427798] ite_cir: RX high carrier frequency (Hz): 0
      [    7.465271] Registered IR keymap rc-rc6-mce
      [    7.473444] IR RC6 protocol handler initialized
      [    7.499629] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    7.501027] Bluetooth: Core ver 2.22
      [    7.501060] NET: Registered protocol family 31
      [    7.501064] Bluetooth: HCI device and connection manager initialized
      [    7.501072] Bluetooth: HCI socket layer initialized
      [    7.501077] Bluetooth: L2CAP socket layer initialized
      [    7.501083] Bluetooth: SCO socket layer initialized
      [    7.502096] rc rc0: ITE8708 CIR transceiver as /devices/virtual/rc/rc0
      [    7.502211] rc rc0: lirc_dev: driver ite-cir registered at minor = 0, raw IR receiver, raw IR transmitter
      [    7.502269] input: ITE8708 CIR transceiver as /devices/virtual/rc/rc0/input5
      [    7.503416] ite_cir: driver has been successfully loaded
      [    7.506610] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    7.508436] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    7.508451] cfg80211: failed to load regulatory.db
      [    7.508807] usbcore: registered new interface driver btusb
      [    7.510006] dw-apb-uart.1: ttyS4 at MMIO 0x91420000 (irq = 4, base_baud = 115200) is a 16550A
      [    7.520753] Bluetooth: hci0: read Intel version: 370810225019140f00
      [    7.521501] Intel(R) Wireless WiFi driver for Linux
      [    7.521511] Copyright(c) 2003- 2015 Intel Corporation
      [    7.521642] bluetooth hci0: Direct firmware load for intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq failed with error -2
      [    7.521650] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
      [    7.521658] Bluetooth: hci0: failed to open Intel firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq (-2)
      [    7.521686] bluetooth hci0: Direct firmware load for intel/ibt-hw-37.8.bseq failed with error -2
      [    7.521691] Bluetooth: hci0: failed to open default fw file: intel/ibt-hw-37.8.bseq
      [    7.530570] iwlwifi 0000:02:00.0: loaded firmware version 29.163394017.0 op_mode iwlmvm
      [    7.535621] input: PC Speaker as /devices/platform/pcspkr/input/input6
      [    7.560493] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 3168, REV=0x220
      [    7.636709] sof-audio-pci 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040380
      [    7.637087] sof-audio-pci 0000:00:0e.0: warning: No matching ASoC machine driver found
      [    7.637117] sof-audio-pci 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if 0x040380
      [    7.749413] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
      [    7.749423] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
      [    7.749426] RAPL PMU: hw unit of domain package 2^-14 Joules
      [    7.749429] RAPL PMU: hw unit of domain dram 2^-14 Joules
      [    7.749432] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
      [    7.759571] iwlwifi 0000:02:00.0: base HW address: 30:e3:7a:bf:28:95
      [    7.761405] cryptd: max_cpu_qlen set to 1000
      [    7.789630] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
      [    7.790207] thermal thermal_zone1: failed to read out thermal zone (-61)
      [    7.796636] SSE version of gcm_enc/dec engaged.
      [    7.940434] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
      [    8.433652] Adding 7340028k swap on /dev/mapper/pve-swap.  Priority:-2 extents:1 across:7340028k SSFS
      [    8.449963] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
      [    8.450008] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
      [    8.450051] EDAC pnd2: b_cr_touud_hi_pci=000000002 ret=0
      [    8.450092] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
      [    8.450133] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
      [    8.450176] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
      [    8.450216] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
      [    8.450301] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
      [    8.450344] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
      [    8.450385] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    8.450426] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    8.450467] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    8.450508] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    8.450509] EDAC pnd2: ECC disabled on channel 0
      [    8.450516] EDAC pnd2: ECC disabled on channel 2
      [    8.450519] EDAC pnd2: Failed to register device with error -22.
      [    8.798680] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
      [    8.798730] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
      [    8.798773] EDAC pnd2: b_cr_touud_hi_pci=000000002 ret=0
      [    8.798816] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
      [    8.798859] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
      [    8.798902] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
      [    8.798943] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
      [    8.799027] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
      [    8.799069] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
      [    8.799110] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    8.799152] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    8.799196] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    8.799236] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    8.799238] EDAC pnd2: ECC disabled on channel 0
      [    8.799245] EDAC pnd2: ECC disabled on channel 2
      [    8.799248] EDAC pnd2: Failed to register device with error -22.
      [    8.802023] intel_telemetry_core Init
      [    8.805965] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
      [    9.031137] ZFS: Loaded module v0.8.4-pve1, ZFS pool version 5000, ZFS filesystem version 5
      [    9.089770] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
      [    9.089813] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
      [    9.089854] EDAC pnd2: b_cr_touud_hi_pci=000000002 ret=0
      [    9.089886] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
      [    9.089898] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
      [    9.089942] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
      [    9.089987] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
      [    9.090027] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
      [    9.090108] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
      [    9.090151] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
      [    9.090192] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    9.090233] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    9.090274] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    9.090315] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    9.090316] EDAC pnd2: ECC disabled on channel 0
      [    9.090324] EDAC pnd2: ECC disabled on channel 2
      [    9.090327] EDAC pnd2: Failed to register device with error -22.
      [    9.093206] intel_rapl_common: Found RAPL domain package
      [    9.093214] intel_rapl_common: Found RAPL domain core
      [    9.093219] intel_rapl_common: Found RAPL domain uncore
      [    9.093223] intel_rapl_common: Found RAPL domain dram
      [    9.166329] EDAC pnd2: b_cr_tolud_pci=080000001 ret=0
      [    9.166334] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
      [    9.166372] EDAC pnd2: b_cr_touud_lo_pci=080000000 ret=0
      [    9.166417] EDAC pnd2: b_cr_touud_hi_pci=000000002 ret=0
      [    9.166459] EDAC pnd2: b_cr_asym_mem_region0_mchbar=000000000 ret=0
      [    9.166502] EDAC pnd2: b_cr_asym_mem_region1_mchbar=000000000 ret=0
      [    9.166544] EDAC pnd2: b_cr_mot_out_base_mchbar=000000000 ret=0
      [    9.166585] EDAC pnd2: b_cr_mot_out_mask_mchbar=000000000 ret=0
      [    9.166667] EDAC pnd2: b_cr_slice_channel_hash=80000d9480001248 ret=0
      [    9.166708] EDAC pnd2: b_cr_asym_2way_mem_region_mchbar=000000000 ret=0
      [    9.166749] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    9.166790] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    9.166836] EDAC pnd2: d_cr_drp0=0e000c005 ret=0
      [    9.166877] EDAC pnd2: d_cr_drp0=000000000 ret=2
      [    9.166881] EDAC pnd2: ECC disabled on channel 0
      [    9.166888] EDAC pnd2: ECC disabled on channel 2
      [    9.166891] EDAC pnd2: Failed to register device with error -22.
      [    9.226909] Invalid pltconfig, ensure IPC1 device is enabled in BIOS
      [    9.403253] audit: type=1400 audit(1600015731.975:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=583 comm="apparmor_parser"
      [    9.404657] audit: type=1400 audit(1600015731.975:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=584 comm="apparmor_parser"
      [    9.404674] audit: type=1400 audit(1600015731.975:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=584 comm="apparmor_parser"
      [    9.413983] audit: type=1400 audit(1600015731.987:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default" pid=585 comm="apparmor_parser"
      [    9.413999] audit: type=1400 audit(1600015731.987:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-cgns" pid=585 comm="apparmor_parser"
      [    9.414007] audit: type=1400 audit(1600015731.987:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-with-mounting" pid=585 comm="apparmor_parser"
      [    9.414015] audit: type=1400 audit(1600015731.987:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default-with-nesting" pid=585 comm="apparmor_parser"
      [    9.414423] audit: type=1400 audit(1600015731.987:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=586 comm="apparmor_parser"
      [    9.416315] audit: type=1400 audit(1600015731.987:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=590 comm="apparmor_parser"
      [    9.416345] audit: type=1400 audit(1600015731.987:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=590 comm="apparmor_parser"
      [    9.499058] vmbr0: port 1(enp3s0) entered blocking state
      [    9.499069] vmbr0: port 1(enp3s0) entered disabled state
      [    9.512436] device enp3s0 entered promiscuous mode
      [    9.550519] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
      [    9.552197] Generic FE-GE Realtek PHY r8169-300:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
      [    9.565627] new mount options do not match the existing superblock, will be ignored
      [    9.609155] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [    9.609165] Bluetooth: BNEP filters: protocol multicast
      [    9.609173] Bluetooth: BNEP socket layer initialized
      [    9.686504] r8169 0000:03:00.0 enp3s0: Link is Down
      [    9.693847] vmbr0: port 1(enp3s0) entered blocking state
      [    9.693859] vmbr0: port 1(enp3s0) entered forwarding state
      [    9.964789] bpfilter: Loaded bpfilter_umh pid 747
      [    9.965264] Started bpfilter
      [   10.521435] vmbr0: port 1(enp3s0) entered disabled state
      [   13.090300] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control rx/tx
      [   13.090336] vmbr0: port 1(enp3s0) entered blocking state
      [   13.090341] vmbr0: port 1(enp3s0) entered forwarding state
      [   13.090447] IPv6: ADDRCONF(NETDEV_CHANGE): vmbr0: link becomes ready
      [   21.961067] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null)
      [   22.735203] kauditd_printk_skb: 6 callbacks suppressed
      [   22.735206] audit: type=1400 audit(1600015745.307:18): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-105_</var/lib/lxc>" pid=1176 comm="apparmor_parser"
      [   23.039359] EXT4-fs (dm-7): warning: mounting fs with errors, running e2fsck is recommended
      [   23.040135] EXT4-fs (dm-7): mounted filesystem with ordered data mode. Opts: (null)
      [   23.797484] audit: type=1400 audit(1600015746.371:19): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-103_</var/lib/lxc>" pid=1222 comm="apparmor_parser"
      [   24.011474] fwbr105i0: port 1(fwln105i0) entered blocking state
      [   24.011485] fwbr105i0: port 1(fwln105i0) entered disabled state
      [   24.011693] device fwln105i0 entered promiscuous mode
      [   24.011817] fwbr105i0: port 1(fwln105i0) entered blocking state
      [   24.011822] fwbr105i0: port 1(fwln105i0) entered forwarding state
      [   24.020701] vmbr0: port 2(fwpr105p0) entered blocking state
      [   24.020712] vmbr0: port 2(fwpr105p0) entered disabled state
      [   24.020908] device fwpr105p0 entered promiscuous mode
      [   24.021020] vmbr0: port 2(fwpr105p0) entered blocking state
      [   24.021026] vmbr0: port 2(fwpr105p0) entered forwarding state
      [   24.030113] fwbr105i0: port 2(veth105i0) entered blocking state
      [   24.030124] fwbr105i0: port 2(veth105i0) entered disabled state
      [   24.030324] device veth105i0 entered promiscuous mode
      [   24.092030] eth0: renamed from vethfVT4BX
      [   25.014110] vmbr0: port 3(veth103i0) entered blocking state
      [   25.014121] vmbr0: port 3(veth103i0) entered disabled state
      [   25.014387] device veth103i0 entered promiscuous mode
      [   25.054799] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   25.054863] fwbr105i0: port 2(veth105i0) entered blocking state
      [   25.054869] fwbr105i0: port 2(veth105i0) entered forwarding state
      [   25.080627] eth0: renamed from vethuPbJFI
      [   25.968218] audit: type=1400 audit(1600015748.539:20): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-103_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=1568 comm="(networkd)" srcname="/" flags="rw, rbind"
      [   26.032224] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   26.032304] vmbr0: port 3(veth103i0) entered blocking state
      [   26.032310] vmbr0: port 3(veth103i0) entered forwarding state
      [   26.218424] audit: type=1400 audit(1600015748.791:21): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-103_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=1667 comm="(resolved)" srcname="/" flags="rw, rbind"
      [   26.382422] audit: type=1400 audit(1600015748.955:22): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-103_</var/lib/lxc>//&:lxc-103_<-var-lib-lxc>:unconfined" pid=1664 comm="apparmor_parser"
      [   26.477127] audit: type=1400 audit(1600015749.047:23): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-103_</var/lib/lxc>//&:lxc-103_<-var-lib-lxc>:unconfined" pid=1666 comm="apparmor_parser"
      [   26.568002] audit: type=1400 audit(1600015749.139:24): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-103_</var/lib/lxc>//&:lxc-103_<-var-lib-lxc>:unconfined" pid=1663 comm="apparmor_parser"
      [   26.746812] audit: type=1400 audit(1600015749.319:25): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-103_</var/lib/lxc>//&:lxc-103_<-var-lib-lxc>:unconfined" pid=1688 comm="apparmor_parser"
      [   26.845988] audit: type=1400 audit(1600015749.419:26): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-103_</var/lib/lxc>//&:lxc-103_<-var-lib-lxc>:unconfined" pid=1690 comm="apparmor_parser"
      [   26.935090] audit: type=1400 audit(1600015749.507:27): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-103_</var/lib/lxc>//&:lxc-103_<-var-lib-lxc>:unconfined" pid=1687 comm="apparmor_parser"
      [   54.869496] EXT4-fs (dm-8): warning: mounting fs with errors, running e2fsck is recommended
      [   54.872197] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
      [   55.709724] kauditd_printk_skb: 1 callbacks suppressed
      [   55.709727] audit: type=1400 audit(1600015778.581:29): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-106_</var/lib/lxc>" pid=2257 comm="apparmor_parser"
      [   56.991891] fwbr106i0: port 1(fwln106i0) entered blocking state
      [   56.991902] fwbr106i0: port 1(fwln106i0) entered disabled state
      [   56.992028] device fwln106i0 entered promiscuous mode
      [   56.992099] fwbr106i0: port 1(fwln106i0) entered blocking state
      [   56.992104] fwbr106i0: port 1(fwln106i0) entered forwarding state
      [   57.000179] vmbr0: port 4(fwpr106p0) entered blocking state
      [   57.000190] vmbr0: port 4(fwpr106p0) entered disabled state
      [   57.000327] device fwpr106p0 entered promiscuous mode
      [   57.000380] vmbr0: port 4(fwpr106p0) entered blocking state
      [   57.000386] vmbr0: port 4(fwpr106p0) entered forwarding state
      [   57.007612] fwbr106i0: port 2(veth106i0) entered blocking state
      [   57.007624] fwbr106i0: port 2(veth106i0) entered disabled state
      [   57.007760] device veth106i0 entered promiscuous mode
      [   57.066327] eth0: renamed from vethEaCMPM
      [   57.822708] audit: type=1400 audit(1600015780.708:30): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-106_</var/lib/lxc>" name="/run/rpc_pipefs/" pid=2376 comm="mount" fstype="rpc_pipefs" srcname="sunrpc"
      [   57.868246] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
      [   57.869707] audit: type=1400 audit(1600015780.756:31): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-106_</var/lib/lxc>" name="/proc/fs/nfsd/" pid=2378 comm="mount" fstype="nfsd" srcname="nfsd"
      [   57.870254] audit: type=1400 audit(1600015780.756:32): apparmor="DENIED" operation="mount" info="failed type match" error=-13 profile="lxc-106_</var/lib/lxc>" name="/proc/fs/nfsd/" pid=2378 comm="mount" fstype="nfsd" srcname="nfsd" flags="ro"
      [   58.580909] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [   58.580980] fwbr106i0: port 2(veth106i0) entered blocking state
      [   58.580986] fwbr106i0: port 2(veth106i0) entered forwarding state
      [   65.714357] IPv4: martian destination 0.0.0.0 from 192.168.8.176, dev eth0
      [   65.993016] IPv4: martian destination 0.0.0.0 from 192.168.8.168, dev eth0
      [   68.415189] sof-audio-pci 0000:00:0e.0: couldn't bind with audio component
      [   68.415219] sof-audio-pci 0000:00:0e.0: init of i915 and HDMI codec failed
      [   68.415395] sof-audio-pci 0000:00:0e.0: use msi interrupt mode
      [   68.420861] sof-audio-pci 0000:00:0e.0: hda codecs found, mask 5
      [   68.420873] sof-audio-pci 0000:00:0e.0: using HDA machine driver skl_hda_dsp_generic now
      [   68.420880] sof-audio-pci 0000:00:0e.0: error: unknown DSP message 0x0
      [   69.425793] sof-audio-pci 0000:00:0e.0: codec #0 probe error, ret: -5
      [   70.436593] sof-audio-pci 0000:00:0e.0: codec #2 probe error, ret: -5
      [   70.436700] sof-audio-pci 0000:00:0e.0: Direct firmware load for intel/sof/sof-apl.ri failed with error -2
      [   70.436709] sof-audio-pci 0000:00:0e.0: error: request firmware intel/sof/sof-apl.ri failed err: -2
      [   70.436714] sof-audio-pci 0000:00:0e.0: error: failed to load DSP firmware -2
      [   70.487157] sof-audio-pci 0000:00:0e.0: error: reset enter failed: core_mask 3 adspcs 0x1d003c
      [   70.487170] sof-audio-pci 0000:00:0e.0: error: dsp core reset failed: core_mask 3
      [   70.487394] sof-audio-pci 0000:00:0e.0: error: sof_probe_work failed err: -2
      [  192.846608] FS-Cache: Loaded
      [  192.886130] FS-Cache: Netfs 'nfs' registered for caching
      [  193.137508] NFS: Registering the id_resolver key type
      [  193.137545] Key type id_resolver registered
      [  193.137548] Key type id_legacy registered
      [  332.578427] EXT4-fs (dm-7): error count since last fsck: 4
      [  332.578438] EXT4-fs (dm-7): initial error at time 1585170792: ext4_orphan_add:2970
      [  332.578443] EXT4-fs (dm-7): last error at time 1585170792: ext4_journal_check_start:61
      [  365.345339] EXT4-fs (dm-8): error count since last fsck: 2
      [  365.345351] EXT4-fs (dm-8): initial error at time 1585170792: ext4_journal_check_start:61
      [  365.345356] EXT4-fs (dm-8): last error at time 1585170792: ext4_journal_check_start:61
      [ 1364.312155] perf: interrupt took too long (2572 > 2500), lowering kernel.perf_event_max_sample_rate to 77750
      [ 1440.486916] EXT4-fs warning (device loop0): ext4_multi_mount_protect:322: MMP interval 42 higher than expected, please wait.
      [ 1445.385535] EXT4-fs warning (device loop1): ext4_multi_mount_protect:322: MMP interval 42 higher than expected, please wait.
      [ 1488.881597] EXT4-fs (loop0): 1 orphan inode deleted
      [ 1488.881607] EXT4-fs (loop0): recovery complete
      [ 1488.897809] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      [ 1489.233450] audit: type=1400 audit(1600017212.210:33): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-100_</var/lib/lxc>" pid=4356 comm="apparmor_parser"
      [ 1489.961119] EXT4-fs (loop1): 2 orphan inodes deleted
      [ 1489.961130] EXT4-fs (loop1): recovery complete
      [ 1489.997252] EXT4-fs (loop1): mounted filesystem with ordered data mode. Opts: (null)
      [ 1490.325818] audit: type=1400 audit(1600017213.302:34): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-109_</var/lib/lxc>" pid=4468 comm="apparmor_parser"
      [ 1490.562828] vmbr0: port 5(veth100i0) entered blocking state
      [ 1490.562838] vmbr0: port 5(veth100i0) entered disabled state
      [ 1490.562965] device veth100i0 entered promiscuous mode
      [ 1490.630922] eth0: renamed from vethVhfynP
      [ 1491.602972] fwbr109i0: port 1(fwln109i0) entered blocking state
      [ 1491.602986] fwbr109i0: port 1(fwln109i0) entered disabled state
      [ 1491.603287] device fwln109i0 entered promiscuous mode
      [ 1491.603503] fwbr109i0: port 1(fwln109i0) entered blocking state
      [ 1491.603510] fwbr109i0: port 1(fwln109i0) entered forwarding state
      [ 1491.614792] vmbr0: port 6(fwpr109p0) entered blocking state
      [ 1491.614802] vmbr0: port 6(fwpr109p0) entered disabled state
      [ 1491.615004] device fwpr109p0 entered promiscuous mode
      [ 1491.615090] vmbr0: port 6(fwpr109p0) entered blocking state
      [ 1491.615096] vmbr0: port 6(fwpr109p0) entered forwarding state
      [ 1491.625040] fwbr109i0: port 2(veth109i0) entered blocking state
      [ 1491.625052] fwbr109i0: port 2(veth109i0) entered disabled state
      [ 1491.625209] device veth109i0 entered promiscuous mode
      [ 1491.708619] eth0: renamed from veth3opfOg
      [ 1498.462346] audit: type=1400 audit(1600017221.438:35): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-100_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=4955 comm="(networkd)" srcname="/" flags="rw, rbind"
      [ 1498.907003] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [ 1498.907080] vmbr0: port 5(veth100i0) entered blocking state
      [ 1498.907088] vmbr0: port 5(veth100i0) entered forwarding state
      [ 1499.481065] audit: type=1400 audit(1600017222.458:36): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-109_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=4990 comm="(networkd)" srcname="/" flags="rw, rbind"
      [ 1500.262214] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [ 1500.262289] fwbr109i0: port 2(veth109i0) entered blocking state
      [ 1500.262296] fwbr109i0: port 2(veth109i0) entered forwarding state
      [ 1502.425801] audit: type=1400 audit(1600017225.402:37): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-109_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=5143 comm="(resolved)" srcname="/" flags="rw, rbind"
      [ 1502.826163] audit: type=1400 audit(1600017225.802:38): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5206 comm="apparmor_parser"
      [ 1503.020654] audit: type=1400 audit(1600017225.998:39): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=5141 comm="apparmor_parser"
      [ 1503.196520] audit: type=1400 audit(1600017226.174:40): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5206 comm="apparmor_parser"
      [ 1503.205548] audit: type=1400 audit(1600017226.182:41): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5230 comm="apparmor_parser"
      [ 1503.276006] audit: type=1400 audit(1600017226.254:42): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=5210 comm="apparmor_parser"
      [ 1503.373585] audit: type=1400 audit(1600017226.350:43): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5230 comm="apparmor_parser"
      [ 1503.395098] audit: type=1400 audit(1600017226.374:44): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5231 comm="apparmor_parser"
      [ 1503.465995] kauditd_printk_skb: 2 callbacks suppressed
      [ 1503.465998] audit: type=1400 audit(1600017226.442:47): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5243 comm="apparmor_parser"
      [ 1503.601947] audit: type=1400 audit(1600017226.578:48): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=5241 comm="apparmor_parser"
      [ 1503.695446] audit: type=1400 audit(1600017226.674:49): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5243 comm="apparmor_parser"
      [ 1503.714073] audit: type=1400 audit(1600017226.690:50): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5255 comm="apparmor_parser"
      [ 1503.789388] audit: type=1400 audit(1600017226.766:51): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=5240 comm="apparmor_parser"
      [ 1503.818742] audit: type=1400 audit(1600017226.798:52): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=5247 comm="apparmor_parser"
      [ 1504.083574] audit: type=1400 audit(1600017227.062:53): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5255 comm="apparmor_parser"
      [ 1504.091218] audit: type=1400 audit(1600017227.070:54): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5257 comm="apparmor_parser"
      [ 1504.253973] audit: type=1400 audit(1600017227.230:55): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5257 comm="apparmor_parser"
      [ 1504.261128] audit: type=1400 audit(1600017227.238:56): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-109_</var/lib/lxc>//&:lxc-109_<-var-lib-lxc>:unconfined" pid=5264 comm="apparmor_parser"
      [ 1660.278248] perf: interrupt took too long (3236 > 3215), lowering kernel.perf_event_max_sample_rate to 61750
      [ 2067.261459] perf: interrupt took too long (4068 > 4045), lowering kernel.perf_event_max_sample_rate to 49000
      [ 2586.466410] perf: interrupt took too long (5096 > 5085), lowering kernel.perf_event_max_sample_rate to 39000
      [ 3121.916581] IPv4: martian destination 0.0.0.0 from 192.168.8.176, dev eth0
      [ 3591.132588] perf: interrupt took too long (6374 > 6370), lowering kernel.perf_event_max_sample_rate to 31250
      [10224.355210] perf: interrupt took too long (8070 > 7967), lowering kernel.perf_event_max_sample_rate to 24750
      [12479.152831] IPv4: martian destination 0.0.0.0 from 192.168.8.176, dev eth0
      [33080.866637] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [33080.866651] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [33394.949390] EXT4-fs (dm-10): error count since last fsck: 4
      [33394.949401] EXT4-fs (dm-10): initial error at time 1585170792: ext4_orphan_add:2970
      [33394.949406] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [33470.682091] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [33470.682104] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [92572.981109] EXT4-fs (dm-8): error count since last fsck: 2
      [92572.981123] EXT4-fs (dm-7): error count since last fsck: 4
      [92572.981137] EXT4-fs (dm-7): initial error at time 1585170792: ext4_orphan_add:2970
      [92572.981182] EXT4-fs (dm-7): last error at time 1585170792: ext4_journal_check_start:61
      [92572.981299] EXT4-fs (dm-8): initial error at time 1585170792: ext4_journal_check_start:61
      [92572.981336] EXT4-fs (dm-8): last error at time 1585170792: ext4_journal_check_start:61
      [119479.210047] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [119479.210061] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [119786.354864] EXT4-fs (dm-10): error count since last fsck: 4
      [119786.354875] EXT4-fs (dm-10): initial error at time 1585170792: ext4_orphan_add:2970
      [119786.354880] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [119851.550126] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [119851.550138] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [184846.144487] EXT4-fs (dm-7): error count since last fsck: 4
      [184846.144512] EXT4-fs (dm-8): error count since last fsck: 2
      [184846.144532] EXT4-fs (dm-7): initial error at time 1585170792: ext4_orphan_add:2970
      [184846.144552] EXT4-fs (dm-7): last error at time 1585170792: ext4_journal_check_start:61
      [184846.144606] EXT4-fs (dm-8): initial error at time 1585170792: ext4_journal_check_start:61
      [184846.144622] EXT4-fs (dm-8): last error at time 1585170792: ext4_journal_check_start:61
      [205878.418076] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [205878.418090] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [206194.140251] EXT4-fs (dm-10): error count since last fsck: 4
      [206194.140263] EXT4-fs (dm-10): initial error at time 1585170792: ext4_orphan_add:2970
      [206194.140268] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [206241.789454] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [206241.789468] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [206295.725921] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [206295.725935] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [206603.733372] EXT4-fs (dm-10): error count since last fsck: 2
      [206603.733384] EXT4-fs (dm-10): initial error at time 1585170792: ext4_journal_check_start:61
      [206603.733389] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [277119.305360] EXT4-fs (dm-8): error count since last fsck: 2
      [277119.305372] EXT4-fs (dm-8): initial error at time 1585170792: ext4_journal_check_start:61
      [277119.305377] EXT4-fs (dm-8): last error at time 1585170792: ext4_journal_check_start:61
      [277119.305424] EXT4-fs (dm-7): error count since last fsck: 4
      [277119.305464] EXT4-fs (dm-7): initial error at time 1585170792: ext4_orphan_add:2970
      [277119.305469] EXT4-fs (dm-7): last error at time 1585170792: ext4_journal_check_start:61
      [292277.302758] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [292277.302771] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [292585.545213] EXT4-fs (dm-10): error count since last fsck: 4
      [292585.545231] EXT4-fs (dm-10): initial error at time 1585170792: ext4_orphan_add:2970
      [292585.545236] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [292638.080673] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [292638.080686] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [301954.992676] INFO: task loop1:2120 blocked for more than 120 seconds.
      [301954.992699]       Tainted: P           O      5.4.60-1-pve #1
      [301954.992701] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [301954.992706] loop1           D    0  2120      2 0x80004000
      [301954.992712] Call Trace:
      [301954.992726]  __schedule+0x2e6/0x6f0
      [301954.992731]  schedule+0x33/0xa0
      [301954.992735]  io_schedule+0x16/0x40
      [301954.992741]  wait_on_page_bit+0x141/0x210
      [301954.992745]  ? file_fdatawait_range+0x30/0x30
      [301954.992750]  wait_on_page_writeback+0x43/0x90
      [301954.992754]  __filemap_fdatawait_range+0xae/0x120
      [301954.992759]  file_write_and_wait_range+0xa0/0xc0
      [301954.992783]  nfs_file_fsync+0x33/0x1a0 [nfs]
      [301954.992787]  ? __switch_to_asm+0x34/0x70
      [301954.992792]  vfs_fsync_range+0x48/0x80
      [301954.992796]  ? __switch_to_asm+0x34/0x70
      [301954.992799]  ? __switch_to_asm+0x40/0x70
      [301954.992802]  vfs_fsync+0x1c/0x20
      [301954.992808]  loop_queue_work+0x3b6/0xa53
      [301954.992813]  ? __switch_to+0x85/0x480
      [301954.992816]  ? __switch_to_asm+0x40/0x70
      [301954.992819]  ? __switch_to_asm+0x34/0x70
      [301954.992823]  ? __schedule+0x2ee/0x6f0
      [301954.992828]  kthread_worker_fn+0x79/0x1c0
      [301954.992832]  loop_kthread_worker_fn+0x1e/0x20
      [301954.992837]  kthread+0x120/0x140
      [301954.992840]  ? loop_info64_to_compat+0x210/0x210
      [301954.992844]  ? kthread_park+0x90/0x90
      [301954.992848]  ret_from_fork+0x35/0x40
      [301954.992854] INFO: task kmmpd-loop1:4369 blocked for more than 120 seconds.
      [301954.992857]       Tainted: P           O      5.4.60-1-pve #1
      [301954.992860] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [301954.992864] kmmpd-loop1     D    0  4369      2 0x80004000
      [301954.992867] Call Trace:
      [301954.992872]  __schedule+0x2e6/0x6f0
      [301954.992877]  ? wbt_exit+0x30/0x30
      [301954.992880]  ? __wbt_done+0x40/0x40
      [301954.992884]  schedule+0x33/0xa0
      [301954.992888]  io_schedule+0x16/0x40
      [301954.992892]  rq_qos_wait+0xf7/0x170
      [301954.992896]  ? sysv68_partition+0x2d0/0x2d0
      [301954.992900]  ? wbt_exit+0x30/0x30
      [301954.992904]  wbt_wait+0x9f/0xe0
      [301954.992907]  __rq_qos_throttle+0x28/0x40
      [301954.992912]  blk_mq_make_request+0x11f/0x5b0
      [301954.992917]  generic_make_request+0xcf/0x310
      [301954.992921]  submit_bio+0x46/0x1c0
      [301954.992926]  ? bio_add_page+0x67/0x90
      [301954.992930]  submit_bh_wbc+0x182/0x1b0
      [301954.992933]  submit_bh+0x13/0x20
      [301954.992937]  write_mmp_block+0xc0/0x120
      [301954.992941]  kmmpd+0x19a/0x3c0
      [301954.992945]  kthread+0x120/0x140
      [301954.992948]  ? __dump_mmp_msg+0x70/0x70
      [301954.992952]  ? kthread_park+0x90/0x90
      [301954.992956]  ret_from_fork+0x35/0x40
      [301954.992993] INFO: task mongod:7656 blocked for more than 120 seconds.
      [301954.992997]       Tainted: P           O      5.4.60-1-pve #1
      [301954.992999] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [301954.993003] mongod          D    0  7656   7437 0x00004100
      [301954.993007] Call Trace:
      [301954.993012]  __schedule+0x2e6/0x6f0
      [301954.993015]  ? __switch_to_asm+0x40/0x70
      [301954.993019]  schedule+0x33/0xa0
      [301954.993023]  schedule_timeout+0x205/0x330
      [301954.993026]  ? __schedule+0x2ee/0x6f0
      [301954.993030]  ? generic_make_request+0xcf/0x310
      [301954.993035]  io_schedule_timeout+0x1e/0x50
      [301954.993038]  wait_for_completion_io+0xb7/0x140
      [301954.993043]  ? wake_up_q+0x80/0x80
      [301954.993047]  submit_bio_wait+0x61/0x90
      [301954.993052]  blkdev_issue_flush+0x8e/0xc0
      [301954.993056]  ext4_sync_file+0x3a0/0x3d0
      [301954.993060]  vfs_fsync_range+0x48/0x80
      [301954.993064]  ? __fget_light+0x59/0x70
      [301954.993067]  do_fsync+0x3d/0x70
      [301954.993070]  __x64_sys_fdatasync+0x17/0x20
      [301954.993075]  do_syscall_64+0x57/0x190
      [301954.993079]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
      [301954.993084] RIP: 0033:0x7fe7a347a3e7
      [301954.993093] Code: Bad RIP value.
      [301954.993096] RSP: 002b:00007fe79e357650 EFLAGS: 00000293 ORIG_RAX: 000000000000004b
      [301954.993101] RAX: ffffffffffffffda RBX: 0000000000000016 RCX: 00007fe7a347a3e7
      [301954.993104] RDX: 0000000000000000 RSI: 0000000000000016 RDI: 0000000000000016
      [301954.993108] RBP: 00007fe79e357690 R08: 0000000000000020 R09: 00007fe79e357690
      [301954.993111] R10: 000000005f62e874 R11: 0000000000000293 R12: 000055a8fdc240f0
      [301954.993115] R13: 000055a8f716376c R14: 000055a8fa8b2000 R15: 00007fe79e357870
      [301954.993121] INFO: task ftdc:7739 blocked for more than 120 seconds.
      [301954.993124]       Tainted: P           O      5.4.60-1-pve #1
      [301954.993127] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [301954.993130] ftdc            D    0  7739   7437 0x00004100
      [301954.993134] Call Trace:
      [301954.993139]  __schedule+0x2e6/0x6f0
      [301954.993143]  ? wbt_exit+0x30/0x30
      [301954.993147]  ? __wbt_done+0x40/0x40
      [301954.993150]  schedule+0x33/0xa0
      [301954.993154]  io_schedule+0x16/0x40
      [301954.993158]  rq_qos_wait+0xf7/0x170
      [301954.993161]  ? sysv68_partition+0x2d0/0x2d0
      [301954.993165]  ? wbt_exit+0x30/0x30
      [301954.993169]  wbt_wait+0x9f/0xe0
      [301954.993173]  __rq_qos_throttle+0x28/0x40
      [301954.993177]  blk_mq_make_request+0x11f/0x5b0
      [301954.993181]  generic_make_request+0xcf/0x310
      [301954.993185]  submit_bio+0x46/0x1c0
      [301954.993191]  ext4_io_submit+0x4d/0x60
      [301954.993195]  ext4_writepages+0x763/0xeb0
      [301954.993200]  ? ext4_bread_batch+0x56/0x180
      [301954.993205]  do_writepages+0x41/0xd0
      [301954.993208]  ? ext4_mark_inode_dirty+0x1d0/0x1d0
      [301954.993212]  ? do_writepages+0x41/0xd0
      [301954.993215]  ? ext4_fname_setup_filename+0x8b/0xb0
      [301954.993220]  __filemap_fdatawrite_range+0xcb/0x100
      [301954.993225]  filemap_flush+0x1c/0x20
      [301954.993229]  ext4_alloc_da_blocks+0x2c/0x70
      [301954.993232]  ext4_rename+0x6b0/0x8d0
      [301954.993237]  ext4_rename2+0x75/0xd0
      [301954.993242]  vfs_rename+0x305/0x9b0
      [301954.993247]  do_renameat2+0x3e8/0x580
      [301954.993252]  __x64_sys_rename+0x20/0x30
      [301954.993256]  do_syscall_64+0x57/0x190
      [301954.993259]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
      [301954.993263] RIP: 0033:0x7fe7a33deda7
      [301954.993267] Code: Bad RIP value.
      [301954.993269] RSP: 002b:00007fe79cb54318 EFLAGS: 00000202 ORIG_RAX: 0000000000000052
      [301954.993274] RAX: ffffffffffffffda RBX: 000055a8fe132450 RCX: 00007fe7a33deda7
      [301954.993277] RDX: 00007fe79cb54360 RSI: 000055a8fe0d8b80 RDI: 000055a8fe17b1e0
      [301954.993281] RBP: 00007fe79cb54340 R08: 00007fe79cb55700 R09: 000055a8f71654fc
      [301954.993284] R10: 00000000000001b6 R11: 0000000000000202 R12: 000055a8fe132430
      [301954.993287] R13: 00007fe79cb54360 R14: 00007fe79cb54720 R15: 000055a8fe5ac004
      [301954.993348] INFO: task kworker/u8:2:15931 blocked for more than 120 seconds.
      [301954.993353]       Tainted: P           O      5.4.60-1-pve #1
      [301954.993356] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [301954.993360] kworker/u8:2    D    0 15931      2 0x80004000
      [301954.993368] Workqueue: writeback wb_workfn (flush-7:1)
      [301954.993372] Call Trace:
      [301954.993378]  __schedule+0x2e6/0x6f0
      [301954.993383]  ? wbt_exit+0x30/0x30
      [301954.993386]  ? __wbt_done+0x40/0x40
      [301954.993390]  schedule+0x33/0xa0
      [301954.993394]  io_schedule+0x16/0x40
      [301954.993397]  rq_qos_wait+0xf7/0x170
      [301954.993401]  ? sysv68_partition+0x2d0/0x2d0
      [301954.993405]  ? wbt_exit+0x30/0x30
      [301954.993409]  wbt_wait+0x9f/0xe0
      [301954.993412]  __rq_qos_throttle+0x28/0x40
      [301954.993417]  blk_mq_make_request+0x11f/0x5b0
      [301954.993421]  generic_make_request+0xcf/0x310
      [301954.993425]  submit_bio+0x46/0x1c0
      [301954.993429]  ext4_io_submit+0x4d/0x60
      [301954.993433]  ext4_writepages+0x763/0xeb0
      [301954.993438]  ? deadline_remove_request+0x4e/0xb0
      [301954.993443]  do_writepages+0x41/0xd0
      [301954.993447]  ? ext4_mark_inode_dirty+0x1d0/0x1d0
      [301954.993450]  ? do_writepages+0x41/0xd0
      [301954.993454]  ? __wb_calc_thresh+0x3e/0x130
      [301954.993458]  __writeback_single_inode+0x40/0x350
      [301954.993463]  writeback_sb_inodes+0x211/0x500
      [301954.993468]  __writeback_inodes_wb+0x67/0xb0
      [301954.993472]  wb_writeback+0x25f/0x2f0
      [301954.993476]  wb_workfn+0x2ec/0x3e0
      [301954.993482]  process_one_work+0x20f/0x3d0
      [301954.993485]  worker_thread+0x34/0x400
      [301954.993490]  kthread+0x120/0x140
      [301954.993493]  ? process_one_work+0x3d0/0x3d0
      [301954.993497]  ? kthread_park+0x90/0x90
      [301954.993501]  ret_from_fork+0x35/0x40
      [302008.239689] nfs: server 192.168.8.55 not responding, still trying
      [302008.263456] nfs: server 192.168.8.55 OK
      [331052.497976] nfs: server 192.168.8.55 not responding, still trying
      [331052.671585] nfs: server 192.168.8.55 OK
      [369392.470357] EXT4-fs (dm-7): error count since last fsck: 4
      [369392.470381] EXT4-fs (dm-8): error count since last fsck: 2
      [369392.470479] EXT4-fs (dm-8): initial error at time 1585170792: ext4_journal_check_start:61
      [369392.470515] EXT4-fs (dm-7): initial error at time 1585170792: ext4_orphan_add:2970
      [369392.470534] EXT4-fs (dm-7): last error at time 1585170792: ext4_journal_check_start:61
      [369392.470580] EXT4-fs (dm-8): last error at time 1585170792: ext4_journal_check_start:61
      [378675.730592] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [378675.730605] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [378976.955231] EXT4-fs (dm-10): error count since last fsck: 4
      [378976.955242] EXT4-fs (dm-10): initial error at time 1585170792: ext4_orphan_add:2970
      [378976.955247] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [379060.887102] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [379060.887115] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [379115.389334] EXT4-fs (dm-10): write access unavailable, skipping orphan cleanup
      [379115.389349] EXT4-fs (dm-10): mounted filesystem without journal. Opts: noload
      [379419.311894] EXT4-fs (dm-10): error count since last fsck: 2
      [379419.311906] EXT4-fs (dm-10): initial error at time 1585170792: ext4_journal_check_start:61
      [379419.311911] EXT4-fs (dm-10): last error at time 1585170792: ext4_journal_check_start:61
      [432199.500291] nfs: server 192.168.8.55 not responding, still trying
      [432199.520059] nfs: server 192.168.8.55 OK
      [439416.505736] IPv4: martian destination 0.0.0.0 from 192.168.8.171, dev eth0
      [459396.488129] INFO: task loop0:1904 blocked for more than 120 seconds.
      [459396.488140]       Tainted: P           O      5.4.60-1-pve #1
      [459396.488143] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [459396.488148] loop0           D    0  1904      2 0x80004000
      [459396.488153] Call Trace:
      [459396.488166]  __schedule+0x2e6/0x6f0
      [459396.488170]  schedule+0x33/0xa0
      [459396.488174]  io_schedule+0x16/0x40
      [459396.488180]  wait_on_page_bit+0x141/0x210
      [459396.488185]  ? file_fdatawait_range+0x30/0x30
      [459396.488189]  wait_on_page_writeback+0x43/0x90
      [459396.488193]  __filemap_fdatawait_range+0xae/0x120
      [459396.488199]  file_write_and_wait_range+0xa0/0xc0
      [459396.488220]  nfs_file_fsync+0x33/0x1a0 [nfs]
      [459396.488224]  ? __switch_to_asm+0x34/0x70
      [459396.488229]  vfs_fsync_range+0x48/0x80
      [459396.488233]  ? __switch_to_asm+0x34/0x70
      [459396.488236]  ? __switch_to_asm+0x40/0x70
      [459396.488239]  vfs_fsync+0x1c/0x20
      [459396.488244]  loop_queue_work+0x3b6/0xa53
      [459396.488249]  ? __switch_to+0x85/0x480
      [459396.488252]  ? __switch_to_asm+0x40/0x70
      [459396.488255]  ? __switch_to_asm+0x34/0x70
      [459396.488259]  ? __schedule+0x2ee/0x6f0
      [459396.488264]  kthread_worker_fn+0x79/0x1c0
      [459396.488268]  loop_kthread_worker_fn+0x1e/0x20
      [459396.488272]  kthread+0x120/0x140
      [459396.488276]  ? loop_info64_to_compat+0x210/0x210
      [459396.488280]  ? kthread_park+0x90/0x90
      [459396.488283]  ret_from_fork+0x35/0x40
      [459396.488289] INFO: task kmmpd-loop0:4334 blocked for more than 120 seconds.
      [459396.488292]       Tainted: P           O      5.4.60-1-pve #1
      [459396.488295] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [459396.488299] kmmpd-loop0     D    0  4334      2 0x80004000
      [459396.488302] Call Trace:
      [459396.488307]  __schedule+0x2e6/0x6f0
      [459396.488311]  ? bit_wait_timeout+0xa0/0xa0
      [459396.488314]  schedule+0x33/0xa0
      [459396.488318]  io_schedule+0x16/0x40
      [459396.488322]  bit_wait_io+0x11/0x50
      [459396.488325]  __wait_on_bit+0x33/0xa0
      [459396.488330]  out_of_line_wait_on_bit+0x90/0xb0
      [459396.488334]  ? var_wake_function+0x30/0x30
      [459396.488338]  __wait_on_buffer+0x32/0x40
      [459396.488342]  write_mmp_block+0x104/0x120
      [459396.488346]  kmmpd+0x19a/0x3c0
      [459396.488350]  kthread+0x120/0x140
      [459396.488354]  ? __dump_mmp_msg+0x70/0x70
      [459396.488357]  ? kthread_park+0x90/0x90
      [459396.488361]  ret_from_fork+0x35/0x40
      [459396.488365] INFO: task jbd2/loop0-8:4347 blocked for more than 120 seconds.
      [459396.488369]       Tainted: P           O      5.4.60-1-pve #1
      [459396.488371] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [459396.488375] jbd2/loop0-8    D    0  4347      2 0x80004000
      [459396.488378] Call Trace:
      [459396.488383]  __schedule+0x2e6/0x6f0
      [459396.488386]  ? __switch_to_asm+0x40/0x70
      [459396.488390]  ? bit_wait_timeout+0xa0/0xa0
      [459396.488394]  schedule+0x33/0xa0
      [459396.488397]  io_schedule+0x16/0x40
      [459396.488401]  bit_wait_io+0x11/0x50
      [459396.488404]  __wait_on_bit+0x33/0xa0
      [459396.488409]  out_of_line_wait_on_bit+0x90/0xb0
      [459396.488412]  ? var_wake_function+0x30/0x30
      [459396.488416]  __wait_on_buffer+0x32/0x40
      [459396.488421]  jbd2_journal_commit_transaction+0x133a/0x1745
      [459396.488427]  kjournald2+0xc8/0x270
      [459396.488430]  ? wait_woken+0x80/0x80
      [459396.488435]  kthread+0x120/0x140
      [459396.488438]  ? commit_timeout+0x20/0x20
      [459396.488441]  ? kthread_park+0x90/0x90
      [459396.488445]  ret_from_fork+0x35/0x40
      [459396.488454] INFO: task systemd-journal:4850 blocked for more than 120 seconds.
      [459396.488458]       Tainted: P           O      5.4.60-1-pve #1
      [459396.488461] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [459396.488464] systemd-journal D    0  4850   4359 0x00004100
      [459396.488468] Call Trace:
      [459396.488472]  __schedule+0x2e6/0x6f0
      [459396.488476]  schedule+0x33/0xa0
      [459396.488479]  jbd2_log_wait_commit+0xaf/0x120
      [459396.488483]  ? wait_woken+0x80/0x80
      [459396.488486]  jbd2_complete_transaction+0x57/0x90
      [459396.488490]  ext4_sync_file+0x378/0x3d0
      [459396.488494]  vfs_fsync_range+0x48/0x80
      [459396.488497]  do_fsync+0x3d/0x70
      [459396.488501]  __x64_sys_fsync+0x14/0x20
      [459396.488505]  do_syscall_64+0x57/0x190
      [459396.488509]  entry_SYSCALL_64_after_hwframe+0x44/0xa9
      [459396.488514] RIP: 0033:0x7f7606a14337
      [459396.488524] Code: Bad RIP value.
      [459396.488527] RSP: 002b:00007ffe4eeff9e0 EFLAGS: 00000293 ORIG_RAX: 000000000000004a
      [459396.488532] RAX: ffffffffffffffda RBX: 0000000000000012 RCX: 00007f7606a14337
      [459396.488536] RDX: 0000000000000000 RSI: 000056389df4e390 RDI: 0000000000000012
      [459396.488539] RBP: 0000000000000001 R08: 00000000000000ca R09: 00007f760210c9d0
      [459396.488543] R10: 0000000000000000 R11: 0000000000000293 R12: 00007ffe4eeffb40
      [459396.488546] R13: 00007ffe4eeffb38 R14: 000056389df4e1a0 R15: 00007ffe4eeffd78
      [459396.488650] INFO: task kworker/u8:1:18511 blocked for more than 120 seconds.
      [459396.488653]       Tainted: P           O      5.4.60-1-pve #1
      [459396.488656] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
      [459396.488660] kworker/u8:1    D    0 18511      2 0x80004000
      [459396.488668] Workqueue: writeback wb_workfn (flush-7:0)
      [459396.488672] Call Trace:
      [459396.488678]  __schedule+0x2e6/0x6f0
      [459396.488684]  ? wbt_exit+0x30/0x30
      [459396.488687]  ? __wbt_done+0x40/0x40
      [459396.488691]  schedule+0x33/0xa0
      [459396.488695]  io_schedule+0x16/0x40
      [459396.488699]  rq_qos_wait+0xf7/0x170
      [459396.488703]  ? sysv68_partition+0x2d0/0x2d0
      [459396.488707]  ? wbt_exit+0x30/0x30
      [459396.488710]  wbt_wait+0x9f/0xe0
      [459396.488714]  __rq_qos_throttle+0x28/0x40
      [459396.488719]  blk_mq_make_request+0x11f/0x5b0
      [459396.488724]  generic_make_request+0xcf/0x310
      [459396.488728]  submit_bio+0x46/0x1c0
      [459396.488733]  ? bio_add_page+0x67/0x90
      [459396.488736]  submit_bh_wbc+0x182/0x1b0
      [459396.488740]  __block_write_full_page+0x21a/0x460
      [459396.488744]  ? blkdev_direct_IO+0x490/0x490
      [459396.488747]  block_write_full_page+0xb8/0x130
      [459396.488751]  blkdev_writepage+0x18/0x20
      [459396.488755]  __writepage+0x1d/0x50
      [459396.488758]  write_cache_pages+0x1cb/0x4a0
      [459396.488762]  ? _cond_resched+0x19/0x30
      [459396.488766]  ? __wb_calc_thresh+0x130/0x130
      [459396.488771]  ? check_preempt_curr+0x68/0x90
      [459396.488774]  ? ttwu_do_wakeup+0x1e/0x150
      [459396.488778]  generic_writepages+0x56/0x90
      [459396.488782]  blkdev_writepages+0xe/0x10
      [459396.488785]  do_writepages+0x41/0xd0
      [459396.488788]  ? __wb_calc_thresh+0x3e/0x130
      [459396.488793]  __writeback_single_inode+0x40/0x350
      [459396.488797]  writeback_sb_inodes+0x211/0x500
      [459396.488802]  __writeback_inodes_wb+0x67/0xb0
      [459396.488806]  wb_writeback+0x25f/0x2f0
      [459396.488811]  wb_workfn+0x2ec/0x3e0
      [459396.488814]  ? __switch_to_asm+0x34/0x70
      [459396.488821]  process_one_work+0x20f/0x3d0
      [459396.488824]  worker_thread+0x34/0x400
      [459396.488829]  kthread+0x120/0x140
      [459396.488832]  ? process_one_work+0x3d0/0x3d0
      [459396.488835]  ? kthread_park+0x90/0x90
      [459396.488839]  ret_from_fork+0x35/0x40
      [459427.207476] nfs: server 192.168.8.55 not responding, still trying
      [459427.461035] nfs: server 192.168.8.55 OK
      [461665.634418] EXT4-fs (dm-8): error count since last fsck: 2
      [461665.634431] EXT4-fs (dm-7): error count since last fsck: 4
      [461665.634434] EXT4-fs (dm-7): initial error at time 1585170792: ext4_orphan_add:2970
      [461665.634440] EXT4-fs (dm-8): initial error at time 1585170792: ext4_journal_check_start:61
      [461665.634447] EXT4-fs (dm-7): last error at time 1585170792: ext4_journal_check_start:61
      [461665.634451] EXT4-fs (dm-8): last error at time 1585170792: ext4_journal_check_start:61
      [495277.940862] IPv4: martian destination 0.0.0.0 from 192.168.8.168, dev eth0
      [495277.963767] IPv4: martian destination 0.0.0.0 from 192.168.8.176, dev eth0
      [495278.070942] IPv4: martian destination 0.0.0.0 from 192.168.8.152, dev eth0
      [495278.096378] IPv4: martian destination 0.0.0.0 from 192.168.8.171, dev eth0
      [495278.144056] IPv4: martian destination 0.0.0.0 from 192.168.8.172, dev eth0
      [495278.181485] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495278.211350] IPv4: martian destination 0.0.0.0 from 192.168.8.155, dev eth0
      [495278.329578] IPv4: martian destination 0.0.0.0 from 192.168.8.151, dev eth0
      [495278.522272] IPv4: martian destination 0.0.0.0 from 192.168.8.154, dev eth0
      [495278.718529] IPv4: martian destination 0.0.0.0 from 192.168.8.173, dev eth0
      [495299.952614] IPv4: martian destination 0.0.0.0 from 192.168.8.168, dev eth0
      [495299.977218] IPv4: martian destination 0.0.0.0 from 192.168.8.176, dev eth0
      [495300.078358] IPv4: martian destination 0.0.0.0 from 192.168.8.152, dev eth0
      [495300.121110] IPv4: martian destination 0.0.0.0 from 192.168.8.171, dev eth0
      [495300.148423] IPv4: martian destination 0.0.0.0 from 192.168.8.172, dev eth0
      [495300.179981] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495300.188602] IPv4: martian destination 0.0.0.0 from 192.168.8.155, dev eth0
      [495300.739324] IPv4: martian destination 0.0.0.0 from 192.168.8.173, dev eth0
      [495321.968531] IPv4: martian destination 0.0.0.0 from 192.168.8.168, dev eth0
      [495322.227844] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495322.708497] IPv4: martian destination 0.0.0.0 from 192.168.8.173, dev eth0
      [495333.203067] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495333.512852] IPv4: martian destination 0.0.0.0 from 192.168.8.154, dev eth0
      [495556.703731] vmbr0: port 5(veth100i0) entered disabled state
      [495556.704098] device veth100i0 left promiscuous mode
      [495556.704112] vmbr0: port 5(veth100i0) entered disabled state
      [495557.454461] kauditd_printk_skb: 4 callbacks suppressed
      [495557.454464] audit: type=1400 audit(1600511288.577:61): apparmor="STATUS" operation="profile_remove" profile="/usr/bin/lxc-start" name="lxc-100_</var/lib/lxc>" pid=11864 comm="apparmor_parser"
      [495813.905576] audit: type=1400 audit(1600511545.033:62): apparmor="STATUS" operation="profile_load" profile="/usr/bin/lxc-start" name="lxc-100_</var/lib/lxc>" pid=17814 comm="apparmor_parser"
      [495815.139710] vmbr0: port 5(veth100i0) entered blocking state
      [495815.139721] vmbr0: port 5(veth100i0) entered disabled state
      [495815.139925] device veth100i0 entered promiscuous mode
      [495815.221004] eth0: renamed from vethFAuIbb
      [495819.937519] audit: type=1400 audit(1600511551.066:63): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-100_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=18036 comm="(networkd)" srcname="/" flags="rw, rbind"
      [495820.524382] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
      [495820.524495] vmbr0: port 5(veth100i0) entered blocking state
      [495820.524500] vmbr0: port 5(veth100i0) entered forwarding state
      [495825.439141] audit: type=1400 audit(1600511556.570:64): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=18228 comm="apparmor_parser"
      [495825.815878] audit: type=1400 audit(1600511556.946:65): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=18234 comm="apparmor_parser"
      [495826.039905] audit: type=1400 audit(1600511557.170:66): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=18227 comm="apparmor_parser"
      [495826.199265] audit: type=1400 audit(1600511557.330:67): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=18244 comm="apparmor_parser"
      [495826.426026] audit: type=1400 audit(1600511557.554:68): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=18248 comm="apparmor_parser"
      [495826.549012] audit: type=1400 audit(1600511557.678:69): apparmor="STATUS" operation="profile_replace" info="not policy admin" error=-13 label="lxc-100_</var/lib/lxc>//&:lxc-100_<-var-lib-lxc>:unconfined" pid=18243 comm="apparmor_parser"
      [495832.311100] audit: type=1400 audit(1600511563.442:70): apparmor="DENIED" operation="mount" info="failed flags match" error=-13 profile="lxc-100_</var/lib/lxc>" name="/run/systemd/unit-root/" pid=18737 comm="(resolved)" srcname="/" flags="rw, rbind"
      [495926.081569] IPv4: martian destination 0.0.0.0 from 192.168.8.171, dev eth0
      [495926.173548] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495926.215757] IPv4: martian destination 0.0.0.0 from 192.168.8.155, dev eth0
      [495948.178370] IPv4: martian destination 0.0.0.0 from 192.168.8.172, dev eth0
      [495948.206551] IPv4: martian destination 0.0.0.0 from 192.168.8.155, dev eth0
      [495948.217168] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495948.349852] IPv4: martian destination 0.0.0.0 from 192.168.8.151, dev eth0
      [495948.493270] IPv4: martian destination 0.0.0.0 from 192.168.8.154, dev eth0
      [495948.735690] IPv4: martian destination 0.0.0.0 from 192.168.8.173, dev eth0
      [495969.937301] IPv4: martian destination 0.0.0.0 from 192.168.8.168, dev eth0
      [495969.941899] IPv4: martian destination 0.0.0.0 from 192.168.8.176, dev eth0
      [495970.051592] IPv4: martian destination 0.0.0.0 from 192.168.8.152, dev eth0
      [495970.087150] IPv4: martian destination 0.0.0.0 from 192.168.8.171, dev eth0
      [495970.145192] IPv4: martian destination 0.0.0.0 from 192.168.8.172, dev eth0
      [495970.178524] IPv4: martian destination 0.0.0.0 from 192.168.8.153, dev eth0
      [495970.207967] IPv4: martian destination 0.0.0.0 from 192.168.8.155, dev eth0
      [495970.313078] IPv4: martian destination 0.0.0.0 from 192.168.8.151, dev eth0
      [495970.502401] IPv4: martian destination 0.0.0.0 from 192.168.8.154, dev eth0
      [495970.723860] IPv4: martian destination 0.0.0.0 from 192.168.8.173, dev eth0
      • Chaot
        Chaot @Thomas Braun last edited by
        @Thomas-Braun
        gehe ich runter auf 4.8.0 kommt:
        javascript.0	2020-09-19 12:39:46.780	error	(30182) WARN deprecated har-validator@5.1.5: this library is no longer supported
        javascript.0	2020-09-19 12:39:46.778	error	(30182) npm
        javascript.0	2020-09-19 12:39:45.759	error	(30182) npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        javascript.0	2020-09-19 12:39:43.600	error	(30182) Cannot install request: 254
        javascript.0	2020-09-19 12:39:43.561	error	(30182) ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2020-09-19T10_39_43_541Z-debug.log
        javascript.0	2020-09-19 12:39:43.556	error	(30182) npm
        javascript.0	2020-09-19 12:39:43.553	error	(30182)
        javascript.0	2020-09-19 12:39:43.537	error	(30182) ERR! enoent
        javascript.0	2020-09-19 12:39:43.535	error	(30182) enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match' npm ERR! enoent This is related to npm not being able to find a f
        javascript.0	2020-09-19 12:39:43.534	error	(30182) npm ERR!
        javascript.0	2020-09-19 12:39:43.525	error	(30182) ERR! code ENOENT npm ERR! syscall access npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match npm ERR! errno -2
        javascript.0	2020-09-19 12:39:43.524	error	(30182) npm
        javascript.0	2020-09-19 12:39:43.334	error	(30182) checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match npm WARN checkPermissions Missing write access to /opt/iobroker/node_module
        javascript.0	2020-09-19 12:39:43.330	error	(30182) npm WARN
        javascript.0	2020-09-19 12:39:39.875	error	(30182) WARN deprecated har-validator@5.1.5: this library is no longer supported
        javascript.0	2020-09-19 12:39:39.873	error	(30182) npm
        javascript.0	2020-09-19 12:39:38.650	error	(30182) npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        Ich habe von "balanced-match" noch nie was gehört.
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
          Thomas Braun Most Active @Chaot last edited by
          @Chaot
          Das Dateisystem hat einen Schuß.
          • Chaot
            @Thomas-Braun Im Container? Wie ist denn das passiert?
              @Chaot
              Vermutlich eher auf der Hardware / Festplatte. Jedenfalls werden da verwaiste inodes angemeckert. Das ist i. d. R. ein Hinweis auf Probleme mit dem Speichermedium.
              • Chaot
                Chaot @Thomas Braun last edited by Chaot
                @Thomas-Braun Seltsam. Proxmox läuft ohne jegliche Fehlermeldung und es gab auch keinen Crash in letzter Zeit. Die SSD ist gerade mal 8 Monate alt.
                Gibt es unter linux ein tool das zu prüfen? Ähnlich chkdsk?
                  @Chaot Klar.
                  fschck
                  Das ist aber bereits ausgeführt worden.
                  Siehe hier:
                  Das heißt aber nicht, das das System jetzt wieder geheilt ist. Es gibt dir nur die Gelegenheit evtl. ein Backup zu ziehen und dann nach getauschter Hardware das System neuaufzusetzen.
                  • Chaot
                    @Thomas-Braun
                    So, das scheinbar defekte Dateisystem habe ich vermutlich gefunden. Zwei Container hatten heute Nacht einen Absturz beim Backup und standen auf Locked.
                    Beide entsperrt und der Rechtfehler/Schreibfehler war plötzlich weg.
                    Jetzt bleibt noch das hier:
                    javascript.0	2020-09-19 18:39:51.560	error	(15995) WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/
                    javascript.0	2020-09-19 18:39:51.557	error	(15995) npm
                    javascript.0	2020-09-19 18:39:16.069	error	(15995) har-validator@5.1.5: this library is no longer supported
                    javascript.0	2020-09-19 18:39:16.067	error	(15995) WARN deprecated
                    javascript.0	2020-09-19 18:39:16.066	error	(15995) npm
                    javascript.0	2020-09-19 18:39:14.415	error	(15995) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    javascript.0	2020-09-19 18:39:14.413	error	(15995) npm
                      @Chaot Sollten nur Warnings sein.
                      • Chaot
                        @Thomas-Braun Ja, dachte ich ja auch, aber wird als Error angezeigt in schönem Rot 😲
                          @Chaot Funktioniert irgendwas nicht? Ist halt Beta-Status, da kann sowas passieren.
                          • Chaot
                            @Thomas-Braun Nö, scheint alles zu funktionieren.
                            Interssanterweise ist der Fehler weg wenn ich request-promise-native entferne und dann neu angebe.
                            Bitte nicht als Kritik verstehen. Ich denke das es sinnvoll ist wenn Fehlermeldungen auftauchen das die öffentlich abgearbeitet werden damit eventuell mitlesende Entwicker noch ein paar Stellschrauben drehen können falls es sie betrifft.
                              @Chaot Das macht man in git.
                              javascript adapter
                              795
