    4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    UNSOLVED Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    • birdy
      birdy @Asgothian last edited by
      @Asgothian
      pi@raspberrypi:/opt/iobroker $ npm rebuild
      > serialport@6.2.2 install /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
      > prebuild-install || node-gyp rebuild
      prebuild-install WARN install No prebuilt binaries found (target=12.18.4 runtime=node arch=arm platform=linux)
      make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/build“ wird betreten
        CXX(target) Release/obj.target/serialport/src/serialport.o
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’
         v8::String::Utf8Value path(info[0]->ToString());
      In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67:0,
                       from ../../nan/nan.h:54,
                       from ../src/./serialport.h:6,
                       from ../src/serialport.cpp:1:
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
         V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2668:44: note:   candidate expects 1 argument, 0 provided
      In file included from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8-internal.h:14:0,
                       from /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:27,
                       from /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:67,
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                       Local<String> ToString(Isolate* isolate) const);
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2684:31: note:   candidate expects 1 argument, 0 provided
      ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’
         v8::Local<v8::Object> options = info[1]->ToObject();
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
         V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2672:44: note:   candidate expects 1 argument, 0 provided
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                       Local<Object> ToObject(Isolate* isolate) const);
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:2686:31: note:   candidate expects 1 argument, 0 provided
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
      ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
         data->callback.Call(2, argv);
      In file included from ../src/./serialport.h:6:0,
      ../../nan/nan.h:1740:3: note: declared here
         Call(int argc, v8::Local<v8::Value> argv[]) const {
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’
      ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
      ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
         data->callback.Call(1, argv);
      ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
      ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
      ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’
      ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
      ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
      ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       an::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/v8.h:3499:22: note: declared here
                       bool Set(Local<Value> key, Local<Value> value));
      ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       an::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
      ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       an::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
      ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
      ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       ::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
      ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
      ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void
         void init(v8::Handle<v8::Object> target) {
      ../src/serialport.cpp:460:13: error: ‘Handle’ is not a member of ‘v8’
      ../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token
      ../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope
      In file included from ../../nan/nan.h:54:0,
      ../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope
       NODE_MODULE(serialport, init);
      /home/iobroker/.cache/node-gyp/12.18.4/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
             (node::addon_register_func) (regfunc),                          \
      ../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’
      serialport.target.mk:112: die Regel für Ziel „Release/obj.target/serialport/src/serialport.o“ scheiterte
      make: *** [Release/obj.target/serialport/src/serialport.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp ERR! System Linux 4.19.66-v7+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.discovery/node_modules/serialport
      gyp ERR! node -v v12.18.4
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the serialport@6.2.2 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T13_36_22_955Z-debug.log
      Das kommt bei npm rebuild...
      Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @birdy last edited by
        @birdy Bring mal dein Grundsystem auf Stand. Da läuft ein alter Kernel, sofern du da Buster laufen hast.
        birdy 1 Reply Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @birdy last edited by
          @birdy
          installiere Ihn über die Katzte neu :
          https://github.com/ioBroker/ioBroker.zigbee
          • birdy
            birdy @Thomas Braun last edited by
            @Thomas-Braun
            pi@raspberrypi:/opt/iobroker $ cat /etc/os-release
            PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="9"
            VERSION="9 (stretch)"
            VERSION_CODENAME=stretch
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Habe ich vor der npm Aktualisierung mit sudu apt-get update und upgrade auf den letzten Stand gebracht.
              Thomas Braun Most Active @birdy last edited by Thomas Braun
              @birdy Bei Stretch kann das mit dem alten Kernel sein.
              Was liefert denn das
              iobroker update
              iobroker upgrade
              nun zurück?
              npm hast du selber aktualisiert? Das kommt eigentlich in einer passenden Version beim Paket nodejs mit.
              Hast du nodeJS sauber im System?
              • birdy
                birdy @Glasfaser last edited by
                @Glasfaser
                Funktioniert leider auch nicht...
                $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee --debug
                install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
                NPM version: 6.14.6
                npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                npm ERR! code ENOTSUP
                npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR! notsup Required: {"node":"~0.10.0"}npm ERR! notsup Actual:   {"npm":"6.14.6","node":"12.18.4"}
                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T13_51_38_768Z-debug.log
                upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sylvania_rt.png img/sylvania_rt.png image/png
                upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_ht.png img/sensor_ht.png image/png
                upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lightbar.png img/philips_hue_lightbar.png image/png
                upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_ceiling_tw.png img/osram_ceiling_tw.png image/png
                upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-plug.png img/lightify-plug.png image/png
                upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr.png img/innr.png image/png
                upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_bulb.png img/gledopto_bulb.png image/png
                upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cube.png img/cube.png image/png
                upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral2.png img/ctrl_neutral2.png image/png
                upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_neutral1.png img/ctrl_neutral1.png image/png
                upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln1.png img/ctrl_ln1.png image/png
                upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/contact.png img/contact.png image/png
                upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_plug.png img/bitron_plug.png image/png
                upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_v.png img/battery_v.png image/png
                upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/battery_p.png img/battery_p.png image/png
                upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
                upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_bulb.png img/aqara_bulb.png image/png
                upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara.switch.png img/aqara.switch.png image/png
                upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.remote.control.png img/TRADFRI.remote.control.png image/png
                upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
                upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                Update "system.adapter.zigbee.0"
                process exited with code 0
                • Glasfaser
                  @birdy
                  Zeige mal @Thomas-Braun diese Ausgabe :
                  which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  • birdy
                    @Thomas-Braun
                    Ich denke, da müsste alles passen.
                    pi@raspberrypi:/opt/iobroker $ npm -v
                    6.14.6
                    pi@raspberrypi:/opt/iobroker $ nodejs -v
                    v12.18.4
                    pi@raspberrypi:/opt/iobroker $ node -v
                    v12.18.4
                    • birdy
                      @Glasfaser
                      pi@raspberrypi:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      v12.18.4
                      /usr/bin/node
                      v12.18.4
                      /usr/bin/npm
                      6.14.6
                      nodejs:
                        Installiert:           12.18.4-1nodesource1
                        Installationskandidat: 12.18.4-1nodesource1
                        Versionstabelle:
                       *** 12.18.4-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                              100 /var/lib/dpkg/status
                           8.11.1~dfsg-2~bpo9+1 500
                              500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
                           4.8.2~dfsg-1 500
                              500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                      • Glasfaser
                        @Thomas-Braun
                        Verzeichnis
                        .npm
                        ist da nicht was quer installiert !?
                        birdy Thomas Braun 2 Replies Last reply Reply Quote 0
                        • birdy
                          @Glasfaser
                          Äääh... Keine Berechtigung? Sorry, ich habe nur rudimentäre Linux-Kenntnisse...
                          pi@raspberrypi:/opt/iobroker $ /home/iobroker/.npm/_logs/2020-09-20T13_51_38_768Z-debug.log
                          -bash: /home/iobroker/.npm/_logs/2020-09-20T13_51_38_768Z-debug.log: Keine Berechtigung
                            @birdy Das passt, der User pi darf nicht in die Dateien vom User iobroker schauen.
                            Mich würde ja immer noch die Ausgabe von
                            iobroker update
                            iobroker upgrade
                            interessieren. Aber die unterliegt offenbar der Geheimhaltung.
                            • birdy
                              @Thomas-Braun
                              Kommt gleich, ein paar adapter werden aktualisiert. Ist danach wieder ein npm rebuild zu machen?
                                @birdy Erstmal nicht. Wenn das durch ist schauen wir ggf. weiter.
                                  Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
                                  @Glasfaser Nö, ist nicht quer. Wenn der User iobroker was mir npm macht dann landet das natürlich auch in dessen home-Verzeichnis. Wo auch sonst, außer in /opt/iobroker (wegen sudoer) darf der ja nix machen
                                  • birdy
                                    @Thomas-Braun
                                    so, eine ordentliche Litanei...
                                    pi@raspberrypi:/opt/iobroker $ iobroker upgrade
                                    Adapter "admin"          is up to date.
                                    Adapter "alarm"          is not installed.
                                    Adapter "alexa2"         is up to date.
                                    Adapter "alpha2"         is not installed.
                                    Adapter "amazon-dash"    is not installed.
                                    Adapter "artnet"         is not installed.
                                    Adapter "asterisk"       is not installed.
                                    Adapter "asuswrt"        is not installed.
                                    Adapter "b-control-em"   is not installed.
                                    Update backitup from @1.1.4 to @1.6.7
                                    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                    NPM version: 6.14.6
                                    npm install iobroker.backitup@1.6.7 --loglevel error --prefix "/opt/iobroker" (S           ystem call)
                                    Package pixman-1 was not found in the pkg-config search path.
                                    Perhaps you should add the directory containing `pixman-1.pc'
                                    to the PKG_CONFIG_PATH environment variable
                                    No package 'pixman-1' found
                                    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in bindin           g.gyp. while trying to load binding.gyp
                                    gyp ERR! configure error
                                    gyp ERR! stack Error: `gyp` failed with exit code: 1
                                    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modu           les/node-gyp/lib/configure.js:351:16)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces           s.js:275:12)
                                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy           p/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/nod           e_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_pat           h=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_ab           i_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                                    gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                    gyp ERR! not ok
                                    node-pre-gyp ERR! build error
                                    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_mo           dules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --           module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name           =canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_ver           sion=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (           1)
                                    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modu           les/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
                                    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                                    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/chi           ld_process.js:286:5)
                                    node-pre-gyp ERR! System Linux 4.19.66-v7+
                                    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/nod           e_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                                    node-pre-gyp ERR! node -v v12.18.4
                                    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                    node-pre-gyp ERR! not ok
                                    ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
                                    info sharp Attempting to build from source via node-gyp but this may fail due to            the above error
                                    info sharp Please see https://sharp.pixelplumbing.com/install for required depen           dencies
                                    ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht ge           funden
                                     #include <vips/vips8>
                                    compilation terminated.
                                    make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
                                    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module           s/node-gyp/lib/build.js:194:23)
                                    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy           p/bin/node-gyp.js" "rebuild"
                                    gyp ERR! cwd /opt/iobroker/node_modules/sharp
                                    gyp ERR! not ok
                                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/wor           ds.js words.js application/javascript
                                    Update "system.adapter.backitup.0"
                                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ind           ex_m.html index_m.html text/html
                                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ind           ex.html index.html text/html
                                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/bac           kitup.png backitup.png image/png
                                    Adapter "backitup" updated
                                    host.raspberrypi Adapter "system.adapter.backitup.0" is started
                                    Adapter "beckhoff"       is not installed.
                                    Adapter "benq"           is not installed.
                                    Adapter "binance"        is not installed.
                                    Adapter "ble"            is not installed.
                                    Adapter "bmw"            is not installed.
                                    Adapter "bosesoundtouch" is not installed.
                                    Adapter "botvac"         is not installed.
                                    Adapter "bring"          is not installed.
                                    Adapter "broadlink2"     is up to date.
                                    Adapter "bsblan"         is not installed.
                                    Adapter "bshb"           is not installed.
                                    Adapter "chromecast"     is not installed.
                                    Adapter "cloud"          is not installed.
                                    Adapter "comfoair"       is not installed.
                                    Adapter "contactid"      is not installed.
                                    Adapter "coronavirus-statistics" is not installed.
                                    Adapter "countdown"      is not installed.
                                    Adapter "cul"            is not installed.
                                    Adapter "daikin"         is not installed.
                                    Update daswetter from @2.8.0 to @3.0.1
                                    host.raspberrypi Adapter "system.adapter.daswetter.0" is stopped.
                                    NPM version: 6.14.6
                                    npm install iobroker.daswetter@3.0.1 --loglevel error --prefix "/opt/iobroker" (           System call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    Update "system.adapter.daswetter.0"
                                    upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/galeria2-Beaufort/75.png icons/viento-wind/galeria2-Beaufort/           75.png image/png
                                    upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/galeria2-Beaufort/3.png icons/viento-wind/galeria2-Beaufort/3           .png image/png
                                    upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/galeria1/16.png icons/viento-wind/galeria1/16.png image/png
                                    upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/Beaufort-White/60.png icons/viento-wind/Beaufort-White/60.png            image/png
                                    upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/Beaufort-White/15.png icons/viento-wind/Beaufort-White/15.png            image/png
                                    upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/tiempo-weather/galeria6/11.svg icons/tiempo-weather/galeria6/11.svg image           /svg+xml
                                    upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/tiempo-weather/galeria5/PNG/White/9.png icons/tiempo-weather/galeria5/PNG           /White/9.png image/png
                                    upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/tiempo-weather/galeria4/3.png icons/tiempo-weather/galeria4/3.png image/p           ng
                                    upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria4/11.png icons/tiempo-weather/galeria4/11.png image/           png
                                    upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria3/2.png icons/tiempo-weather/galeria3/2.png image/pn           g
                                    upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria3/10.png icons/tiempo-weather/galeria3/10.png image/           png
                                    upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria2/19.png icons/tiempo-weather/galeria2/19.png image/           png
                                    upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria2/1.png icons/tiempo-weather/galeria2/1.png image/pn           g
                                    upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria1/18.png icons/tiempo-weather/galeria1/18.png image/           png
                                    upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/9.png icons/luna-moon/9.png image/png
                                    upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/26.png icons/luna-moon/26.png image/png
                                    upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/25.png icons/luna-moon/25.png image/png
                                    upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/24.png icons/luna-moon/24.png image/png
                                    upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/23.png icons/luna-moon/23.png image/png
                                    upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/22.png icons/luna-moon/22.png image/png
                                    upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/21.png icons/luna-moon/21.png image/png
                                    upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/20.png icons/luna-moon/20.png image/png
                                    upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/2.png icons/luna-moon/2.png image/png
                                    upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/19.png icons/luna-moon/19.png image/png
                                    upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/18.png icons/luna-moon/18.png image/png
                                    upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/17.png icons/luna-moon/17.png image/png
                                    upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/16.png icons/luna-moon/16.png image/png
                                    upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/15.png icons/luna-moon/15.png image/png
                                    upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/14.png icons/luna-moon/14.png image/png
                                    upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/13.png icons/luna-moon/13.png image/png
                                    upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/12.png icons/luna-moon/12.png image/png
                                    upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/11.png icons/luna-moon/11.png image/png
                                    upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/10.png icons/luna-moon/10.png image/png
                                    upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/1.png icons/luna-moon/1.png image/png
                                    upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/0.png icons/luna-moon/0.png image/png
                                    upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/d           aswettercom.png daswettercom.png image/png
                                    Adapter "daswetter" updated
                                    host.raspberrypi Adapter "system.adapter.daswetter.0" is started
                                    Adapter "deconz"         is not installed.
                                    Adapter "denon"          is not installed.
                                    Adapter "devices"        is not installed.
                                    Adapter "digitalstrom"   is not installed.
                                    Adapter "discovergy"     is not installed.
                                    Update discovery from @1.3.0 to @2.3.7
                                    NPM version: 6.14.6
                                    npm install iobroker.discovery@2.3.7 --loglevel error --prefix "/opt/iobroker" (           System call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/w           ords.js words.js application/javascript
                                    Update "system.adapter.discovery.0"
                                    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/t           ranslateTools.js translateTools.js application/javascript
                                    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/s           ettings_m.html settings_m.html text/html
                                    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/s           ettings.html settings.html text/html
                                    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i           ndex_m.html index_m.html text/html
                                    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i           ndex.html index.html text/html
                                    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/d           iscovery.png discovery.png image/png
                                    Adapter "discovery" updated
                                    Adapter "doorio"         is not installed.
                                    Adapter "ds18b20"        is not installed.
                                    Adapter "dwd"            is not installed.
                                    Adapter "ebus"           is not installed.
                                    Adapter "ecovacs-deebot" is not installed.
                                    Adapter "egigeozone"     is not installed.
                                    Adapter "ekey"           is not installed.
                                    Adapter "email"          is not installed.
                                    Adapter "emby"           is not installed.
                                    Adapter "energymanager"  is not installed.
                                    Adapter "enet"           is not installed.
                                    Adapter "epson_stylus_px830" is not installed.
                                    Adapter "exchangerates"  is not installed.
                                    Adapter "fakeroku"       is not installed.
                                    Adapter "fb-checkpresence" is not installed.
                                    Adapter "feiertage"      is not installed.
                                    Adapter "fhem"           is not installed.
                                    Adapter "find-my-iphone" is not installed.
                                    Adapter "firetv"         is not installed.
                                    Adapter "flot"           is up to date.
                                    Adapter "foobar2000"     is not installed.
                                    Adapter "fritzbox"       is not installed.
                                    Adapter "fritzdect"      is not installed.
                                    Adapter "fronius"        is not installed.
                                    Adapter "fullcalendar"   is not installed.
                                    Adapter "fullybrowser"   is not installed.
                                    Adapter "g-homa"         is not installed.
                                    Adapter "geofency"       is not installed.
                                    Adapter "gruenbeck"      is not installed.
                                    Adapter "habpanel"       is not installed.
                                    Adapter "haier"          is not installed.
                                    Adapter "ham"            is not installed.
                                    Adapter "ham-wemo"       is not installed.
                                    Adapter "harmony"        is not installed.
                                    Adapter "heatingcontrol" is not installed.
                                    Adapter "heytech"        is not installed.
                                    Adapter "hid"            is not installed.
                                    Update history from @1.8.6 to @1.9.10
                                    NPM version: 6.14.6
                                    npm install iobroker.history@1.9.10 --loglevel error --prefix "/opt/iobroker" (S           ystem call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words           Custom.js wordsCustom.js application/javascript
                                    upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words           .js words.js application/javascript
                                    upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index           _m.html index_m.html text/html
                                    upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index           .html index.html text/html
                                    upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/histo           ry.png history.png image/png
                                    upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo           m_m.html custom_m.html text/html
                                    upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo           m.html custom.html text/html
                                    Adapter "history" updated
                                    Adapter "hm-rega"        is not installed.
                                    Adapter "hm-rpc"         is not installed.
                                    Adapter "hmip"           is not installed.
                                    Adapter "homeconnect"    is not installed.
                                    Adapter "homee"          is not installed.
                                    Adapter "homepilot"      is not installed.
                                    Adapter "hp-ilo"         is not installed.
                                    Adapter "hs100"          is not installed.
                                    Adapter "hue"            is not installed.
                                    Adapter "hue-extended"   is not installed.
                                    Adapter "ical"           is not installed.
                                    Adapter "icons-addictive-flavour-png" is not installed.
                                    Adapter "icons-fatcow-hosting" is not installed.
                                    Adapter "icons-icons8"   is not installed.
                                    Adapter "icons-material-png" is not installed.
                                    Adapter "icons-material-svg" is not installed.
                                    Adapter "icons-mfd-png"  is not installed.
                                    Adapter "icons-mfd-svg"  is not installed.
                                    Adapter "icons-open-icon-library-png" is not installed.
                                    Adapter "icons-ultimate-png" is up to date.
                                    Adapter "influxdb"       is not installed.
                                    Adapter "info"           is up to date.
                                    Adapter "innogy-smarthome" is not installed.
                                    Adapter "iogo"           is not installed.
                                    Adapter "iot"            is up to date.
                                    Adapter "iqontrol"       is not installed.
                                    Adapter "javascript"     is up to date.
                                    Adapter "jeelink"        is not installed.
                                    Adapter "kecontact"      is not installed.
                                    Adapter "klf200"         is not installed.
                                    Adapter "km200"          is not installed.
                                    Adapter "knmi-weather"   is not installed.
                                    Adapter "knx"            is not installed.
                                    Adapter "kodi"           is not installed.
                                    Adapter "kress"          is not installed.
                                    Adapter "lametric"       is not installed.
                                    Adapter "landroid"       is not installed.
                                    Adapter "lcn"            is not installed.
                                    Adapter "letrika_comgw"  is not installed.
                                    Adapter "lgtv"           is not installed.
                                    Adapter "lgtv-rs"        is not installed.
                                    Adapter "lgtv11"         is not installed.
                                    Adapter "lifx"           is not installed.
                                    Adapter "lightify"       is not installed.
                                    Adapter "link"           is not installed.
                                    Adapter "linkeddevices"  is not installed.
                                    Adapter "logparser"      is not installed.
                                    Adapter "lovelace"       is not installed.
                                    Adapter "loxone"         is not installed.
                                    Adapter "luftdaten"      is not installed.
                                    Adapter "lupusec"        is not installed.
                                    Adapter "luxtronik1"     is not installed.
                                    Adapter "material"       is not installed.
                                    Adapter "maxcube"        is not installed.
                                    Adapter "maxcul"         is not installed.
                                    Adapter "mbus"           is not installed.
                                    Adapter "mclighting"     is not installed.
                                    Adapter "megad"          is not installed.
                                    Adapter "megadd"         is not installed.
                                    Adapter "megaesp"        is not installed.
                                    Adapter "melcloud"       is not installed.
                                    Adapter "mercedesme"     is not installed.
                                    Adapter "mercury"        is not installed.
                                    Adapter "meross"         is not installed.
                                    Adapter "meteoalarm"     is not installed.
                                    Adapter "midea"          is not installed.
                                    Adapter "miele"          is not installed.
                                    Adapter "mielecloudservice" is not installed.
                                    Adapter "mihome"         is not installed.
                                    Adapter "mihome-lamp"    is not installed.
                                    Adapter "mihome-plug"    is not installed.
                                    Adapter "mihome-vacuum"  is not installed.
                                    Adapter "mikrotik"       is not installed.
                                    Adapter "milight"        is not installed.
                                    Adapter "milight-smart-light" is not installed.
                                    Adapter "mobile"         is not installed.
                                    Adapter "modbus"         is not installed.
                                    Adapter "moma"           is not installed.
                                    Adapter "mpd"            is not installed.
                                    Update mqtt from @2.0.4 to @2.1.4
                                    NPM version: 6.14.6
                                    npm install iobroker.mqtt@2.1.4 --loglevel error --prefix "/opt/iobroker" (Syste           m call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js wo           rds.js application/javascript
                                    Update "system.adapter.mqtt.0"
                                    upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mq           tt.png image/png
                                    upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.htm           l index_m.html text/html
                                    upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html            index.html text/html
                                    Adapter "mqtt" updated
                                    Adapter "mqtt-client"    is not installed.
                                    Adapter "musiccast"      is not installed.
                                    Adapter "mysensors"      is not installed.
                                    Adapter "nanoleaf-lightpanels" is not installed.
                                    Adapter "nello"          is not installed.
                                    Adapter "netatmo"        is not installed.
                                    Adapter "nibeuplink"     is not installed.
                                    Adapter "nina"           is not installed.
                                    Adapter "node-red"       is not installed.
                                    Adapter "nuki"           is not installed.
                                    Adapter "nuki-extended"  is not installed.
                                    Adapter "nut"            is not installed.
                                    Adapter "odl"            is not installed.
                                    Adapter "oilfox"         is not installed.
                                    Adapter "onkyo"          is not installed.
                                    Adapter "onvif"          is not installed.
                                    Adapter "openhab"        is not installed.
                                    Adapter "openligadb"     is not installed.
                                    Adapter "openweathermap" is not installed.
                                    Adapter "opi"            is not installed.
                                    Adapter "oppoplayer"     is not installed.
                                    Adapter "owfs"           is not installed.
                                    Adapter "owntracks"      is not installed.
                                    Adapter "panasonic-viera" is not installed.
                                    Adapter "parser"         is up to date.
                                    Adapter "paw"            is not installed.
                                    Adapter "phantomjs"      is not installed.
                                    Adapter "pi-hole"        is not installed.
                                    Adapter "piface"         is not installed.
                                    Adapter "pimatic"        is not installed.
                                    Update ping from @1.3.2 to @1.4.8
                                    NPM version: 6.14.6
                                    npm install iobroker.ping@1.4.8 --loglevel error --prefix "/opt/iobroker" (Syste           m call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js wo           rds.js application/javascript
                                    Update "system.adapter.ping.0"
                                    upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png pi           ng.png image/png
                                    upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.htm           l index_m.html text/html
                                    upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html            index.html text/html
                                    Adapter "ping" updated
                                    Adapter "places"         is not installed.
                                    Adapter "plex"           is not installed.
                                    Adapter "plexconnect"    is not installed.
                                    Adapter "pollenflug"     is not installed.
                                    Adapter "proxmox"        is not installed.
                                    Adapter "proxy"          is not installed.
                                    Adapter "pushbullet"     is not installed.
                                    Adapter "pushover"       is not installed.
                                    Adapter "pushsafer"      is not installed.
                                    Adapter "radar2"         is not installed.
                                    Adapter "radiohead"      is not installed.
                                    Adapter "rflink"         is not installed.
                                    Adapter "rickshaw"       is up to date.
                                    Adapter "ring"           is not installed.
                                    Adapter "robonect"       is not installed.
                                    Adapter "roomba"         is not installed.
                                    Adapter "rpi2"           is not installed.
                                    Adapter "s7"             is not installed.
                                    Adapter "samsung"        is not installed.
                                    Adapter "sayit"          is not installed.
                                    Adapter "sbfspot"        is not installed.
                                    Adapter "scenes"         is up to date.
                                    Adapter "schoolfree"     is not installed.
                                    Adapter "shelly"         is not installed.
                                    Adapter "shuttercontrol" is not installed.
                                    Adapter "sia"            is not installed.
                                    Adapter "siegenia"       is not installed.
                                    Adapter "simple-api"     is up to date.
                                    Adapter "smappee"        is not installed.
                                    Adapter "smartgarden"    is not installed.
                                    Adapter "smartmeter"     is not installed.
                                    Adapter "snips"          is not installed.
                                    Adapter "snmp"           is not installed.
                                    Adapter "socketio"       is up to date.
                                    Adapter "solarlog"       is not installed.
                                    Adapter "solarviewdatareader" is not installed.
                                    Adapter "solarwetter"    is not installed.
                                    Adapter "sonnen"         is not installed.
                                    Update sonoff from @2.2.2 to @2.3.3
                                    NPM version: 6.14.6
                                    npm install iobroker.sonoff@2.3.3 --loglevel error --prefix "/opt/iobroker" (Sys           tem call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.j           s words.js application/javascript
                                    Update "system.adapter.sonoff.0"
                                    upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.           png sonoff.png image/png
                                    upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m           .html index_m.html text/html
                                    upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.h           tml index.html text/html
                                    Adapter "sonoff" updated
                                    Adapter "sonos"          is not installed.
                                    Adapter "sony-bravia"    is not installed.
                                    Adapter "spotify-premium" is not installed.
                                    Update sql from @1.9.4 to @1.15.2
                                    host.raspberrypi Adapter "system.adapter.sql.0" is stopped.
                                    NPM version: 6.14.6
                                    npm install iobroker.sql@1.15.2 --loglevel error --prefix "/opt/iobroker" (Syste           m call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    ../src/backup.cc: In static member function ‘static void node_sqlite3::Backup::W           ork_BeginInitialize(node_sqlite3::Database::Baton*)’:
                                    ../src/backup.cc:191:9: warning: unused variable ‘status’ [-Wunused-variable]
                                         int status = napi_create_async_work(
                                    In file included from ../src/backup.cc:4:0:
                                    ../src/backup.cc: In static member function ‘static void node_sqlite3::Backup::W           ork_BeginStep(node_sqlite3::Backup::Baton*)’:
                                    ../src/macros.h:175:9: warning: unused variable ‘status’ [-Wunused-variable]
                                         int status = napi_create_async_work(                                                  \
                                    ../src/backup.cc:263:5: note: in expansion of macro ‘BACKUP_BEGIN’
                                         BACKUP_BEGIN(Step);
                                    ../src/backup.cc: In static member function ‘static void node_sqlite3::Backup::W           ork_BeginFinish(node_sqlite3::Backup::Baton*)’:
                                    ../src/backup.cc:329:5: note: in expansion of macro ‘BACKUP_BEGIN’
                                         BACKUP_BEGIN(Finish);
                                    ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
                                    ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginClose(node_sqlite3::Database::Baton*)’:
                                    ../src/database.cc:240:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginExec(node_sqlite3::Database::Baton*)’:
                                    ../src/database.cc:557:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
                                    ../src/database.cc:667:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ../src/statement.cc: In function ‘bool OtherInstanceOf(Napi::Object, char*)’:
                                    ../src/statement.cc:35:24: warning: comparison with string literal results in un           specified behavior [-Waddress]
                                         if (object_type == "Date") {
                                    ../src/statement.cc:37:31: warning: comparison with string literal results in un           specified behavior [-Waddress]
                                         } else if (object_type == "RegExp") {
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:
                                    ../src/statement.cc:128:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    In file included from ../src/statement.cc:5:0:
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
                                    ../src/macros.h:145:9: warning: unused variable ‘status’ [-Wunused-variable]
                                    ../src/statement.cc:349:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                         STATEMENT_BEGIN(Bind);
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginGet(node_sqlite3::Statement::Baton*)’:
                                    ../src/statement.cc:400:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                         STATEMENT_BEGIN(Get);
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
                                    ../src/statement.cc:471:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                         STATEMENT_BEGIN(Run);
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginAll(node_sqlite3::Statement::Baton*)’:
                                    ../src/statement.cc:540:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                         STATEMENT_BEGIN(All);
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginEach(node_sqlite3::Statement::Baton*)’:
                                    ../src/statement.cc:640:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                         STATEMENT_BEGIN(Each);
                                    ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginReset(node_sqlite3::Statement::Baton*)’:
                                    ../src/statement.cc:766:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                                         STATEMENT_BEGIN(Reset);
                                    ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::Baton]’:
                                    ../src/statement.cc:337:42:   required from here
                                    ../src/statement.cc:243:60: warning: ISO C++ forbids converting a string constan           t to ‘char*’ [-Wwrite-strings]
                                             else if (!info[start].IsObject() || OtherInstanceOf(info[start].As<Obje           ct>(), "RegExp") || OtherInstanceOf(info[start].As<Object>(), "Date") || info[st           art].IsBuffer()) {
                                    ../src/statement.cc:243:115: warning: ISO C++ forbids converting a string consta           nt to ‘char*’ [-Wwrite-strings]
                                    ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::RowBaton]’:
                                    ../src/statement.cc:388:45:   required from here
                                    ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::RunBaton]’:
                                    ../src/statement.cc:459:45:   required from here
                                    ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::RowsBaton]’:
                                    ../src/statement.cc:528:46:   required from here
                                    ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::EachBaton]’:
                                    ../src/statement.cc:620:59:   required from here
                                    ../src/statement.cc: In instantiation of ‘node_sqlite3::Values::Field* node_sqli           te3::Statement::BindParameter(Napi::Value, T) [with T = int]’:
                                    ../src/statement.cc:240:58:   required from ‘T* node_sqlite3::Statement::Bind(co           nst Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::Baton]’
                                    ../src/statement.cc:188:29: warning: ISO C++ forbids converting a string constan           t to ‘char*’ [-Wwrite-strings]
                                         else if (OtherInstanceOf(source.As<Object>(), "RegExp")) {
                                    ../src/statement.cc:209:29: warning: ISO C++ forbids converting a string constan           t to ‘char*’ [-Wwrite-strings]
                                         else if (OtherInstanceOf(source.As<Object>(), "Date")) {
                                    ../src/statement.cc: In instantiation of ‘node_sqlite3::Values::Field* node_sqli           te3::Statement::BindParameter(Napi::Value, T) [with T = const char*]’:
                                    ../src/statement.cc:263:62:   required from ‘T* node_sqlite3::Statement::Bind(co           nst Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::Baton]’
                                    upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js word           s.js application/javascript
                                    Update "system.adapter.sql.0"
                                    upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.p           ng image/png
                                    upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html            index_m.html text/html
                                    upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html in           dex.html text/html
                                    upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html            custom_m.html text/html
                                    upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html c           ustom.html text/html
                                    Adapter "sql" updated
                                    host.raspberrypi Adapter "system.adapter.sql.0" is started
                                    Adapter "squeezebox"     is not installed.
                                    Adapter "squeezeboxrpc"  is not installed.
                                    Adapter "starline"       is not installed.
                                    Adapter "statistics"     is not installed.
                                    Adapter "stiebel-isg"    is not installed.
                                    Adapter "sunnyportal"    is not installed.
                                    Adapter "swiss-weather-api" is not installed.
                                    Adapter "synology"       is not installed.
                                    Adapter "systeminfo"     is not installed.
                                    Adapter "tahoma"         is not installed.
                                    Adapter "tankerkoenig"   is not installed.
                                    Update telegram from @1.4.3 to @1.5.9
                                    host.raspberrypi Adapter "system.adapter.telegram.0" is stopped.
                                    NPM version: 6.14.6
                                    npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (S           ystem call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/wor           ds.js words.js application/javascript
                                    Update "system.adapter.telegram.0"
                                    upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/tel           egram.png telegram.png image/png
                                    upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/ind           ex_m.html index_m.html text/html
                                    upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/ind           ex.html index.html text/html
                                    upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/cus           tom_m.html custom_m.html text/html
                                    upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blo           ckly.js blockly.js application/javascript
                                    Adapter "telegram" updated
                                    host.raspberrypi Adapter "system.adapter.telegram.0" is started
                                    Adapter "terminal"       is up to date.
                                    Adapter "tesla-motors"   is not installed.
                                    Update text2command from @1.2.5 to @1.3.0
                                    NPM version: 6.14.6
                                    npm install iobroker.text2command@1.3.0 --loglevel error --prefix "/opt/iobroker           " (System call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [4] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/words.js words.js application/javascript
                                    Update "system.adapter.text2command.0"
                                    upload [3] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/text2command.png text2command.png image/png
                                    upload [2] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/tab.js tab.js application/javascript
                                    upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/tab.html tab.html text/html
                                    upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/langModel.js langModel.js application/javascript
                                    Adapter "text2command" updated
                                    Adapter "tinker"         is not installed.
                                    Adapter "tr-064"         is not installed.
                                    Adapter "tradfri"        is not installed.
                                    Adapter "trashschedule"  is not installed.
                                    Adapter "tunnelbroker-endpoint-updater" is not installed.
                                    Adapter "tuya"           is not installed.
                                    Adapter "tvspielfilm"    is not installed.
                                    Adapter "unifi"          is not installed.
                                    Adapter "upnp"           is not installed.
                                    Adapter "vaillant"       is not installed.
                                    Adapter "valloxmv"       is not installed.
                                    Adapter "vcard"          is not installed.
                                    Adapter "velux"          is not installed.
                                    Adapter "viessmann"      is not installed.
                                    Adapter "virtualpowermeter" is not installed.
                                    Adapter "vis"            is up to date.
                                    Adapter "vis-bars"       is not installed.
                                    Adapter "vis-canvas-gauges" is not installed.
                                    Adapter "vis-colorpicker" is not installed.
                                    Adapter "vis-fancyswitch" is up to date.
                                    Adapter "vis-google-fonts" is not installed.
                                    Update vis-history from @0.2.7 to @1.0.0
                                    NPM version: 6.14.6
                                    npm install iobroker.vis-history@1.0.0 --loglevel error --prefix "/opt/iobroker"            (System call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-history/www" was not fo           und! Nothing was uploaded or deleted.
                                    upload [0] vis-history.admin /opt/iobroker/node_modules/iobroker.vis-history/adm           in/vis-history.png vis-history.png image/png
                                    Adapter "system.adapter.vis.0" restarted.
                                    Update "system.adapter.vis-history.0"
                                    Adapter "vis-history" updated
                                    Adapter "vis-hqwidgets"  is up to date.
                                    Adapter "vis-icontwo"    is not installed.
                                    Adapter "vis-inventwo"   is not installed.
                                    Adapter "vis-jqui-mfd"   is up to date.
                                    Adapter "vis-justgage"   is not installed.
                                    Adapter "vis-keyboard"   is not installed.
                                    Adapter "vis-lcars"      is not installed.
                                    Adapter "vis-map"        is not installed.
                                    Adapter "vis-metro"      is up to date.
                                    Adapter "vis-players"    is not installed.
                                    Adapter "vis-plumb"      is not installed.
                                    Adapter "vis-rgraph"     is not installed.
                                    Adapter "vis-timeandweather" is up to date.
                                    Update vis-weather from @2.3.0 to @2.5.2
                                    NPM version: 6.14.6
                                    npm install iobroker.vis-weather@2.5.2 --loglevel error --prefix "/opt/iobroker"            (System call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not fo           und! Nothing was uploaded or deleted.
                                    upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/words.js words.js application/javascript
                                    Update "system.adapter.vis-weather.0"
                                    upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/vis-weather.png vis-weather.png image/png
                                    upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/index_m.html index_m.html text/html
                                    upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/index.html index.html text/html
                                    Adapter "vis-weather" updated
                                    Adapter "vr200"          is not installed.
                                    Adapter "vw-connect"     is not installed.
                                    Update weatherunderground from @3.0.7 to @3.2.1
                                    NPM version: 6.14.6
                                    npm install iobroker.weatherunderground@3.2.1 --loglevel error --prefix "/opt/io           broker" (System call)
                                    gyp ERR! not ok
                                    gyp ERR! not ok
                                    upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatheru           nderground/admin/wu.png wu.png image/png
                                    upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatheru           nderground/admin/words.js words.js application/javascript
                                    upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatheru           nderground/admin/index_m.html index_m.html text/html
                                    Adapter "weatherunderground" updated
                                    Adapter "web"            is up to date.
                                    Adapter "weishaupt-wem"  is not installed.
                                    Adapter "wiffi-wz"       is not installed.
                                    Adapter "wifilight"      is not installed.
                                    Adapter "windows-control" is not installed.
                                    Adapter "wled"           is not installed.
                                    Adapter "wm-bus"         is not installed.
                                    Adapter "wolf"           is not installed.
                                    Adapter "worx"           is not installed.
                                    Adapter "xbox"           is not installed.
                                    Adapter "xs1"            is not installed.
                                    Adapter "yahka"          is not installed.
                                    Adapter "yamaha"         is not installed.
                                    Adapter "yeelight-2"     is not installed.
                                    Adapter "youtube"        is not installed.
                                    Adapter "yr"             is up to date.
                                    Update zigbee from @0.10.2 to @1.2.1
                                    NPM version: 6.14.6
                                    npm install iobroker.zigbee@1.2.1 --loglevel error --prefix "/opt/iobroker" (Sys           tem call)
                                    npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"           } (current: {"node":"12.18.4","npm":"6.14.6"})
                                    npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T15_36_01_596Z-debug.log
                                    upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index           _m.html index_m.html text/html
                                    upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sy           lvania_rt.png img/sylvania_rt.png image/png
                                    upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/se           nsor_ht.png img/sensor_ht.png image/png
                                    upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ph           ilips_hue_lightbar.png img/philips_hue_lightbar.png image/png
                                    upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/os           ram_ceiling_tw.png img/osram_ceiling_tw.png image/png
                                    upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/li           ghtify-plug.png img/lightify-plug.png image/png
                                    upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/in           nr.png img/innr.png image/png
                                    upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gl           edopto_bulb.png img/gledopto_bulb.png image/png
                                    upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cu           be.png img/cube.png image/png
                                    upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_neutral2.png img/ctrl_neutral2.png image/png
                                    upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_neutral1.png img/ctrl_neutral1.png image/png
                                    upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_ln2.png img/ctrl_ln2.png image/png
                                    upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_ln1.png img/ctrl_ln1.png image/png
                                    upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/co           ntact.png img/contact.png image/png
                                    upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bi           tron_plug.png img/bitron_plug.png image/png
                                    upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ba           ttery_v.png img/battery_v.png image/png
                                    upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ba           ttery_p.png img/battery_p.png image/png
                                    upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aq           ara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
                                    upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aq           ara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
                                    upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqa           ra_bulb.png img/aqara_bulb.png image/png
                                    upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqa           ra.switch.png img/aqara.switch.png image/png
                                    upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRA           DFRI.remote.control.png img/TRADFRI.remote.control.png image/png
                                    upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRA           DFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
                                    upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLO           ALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                    upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eur           otronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                    upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86s           w2.png img/86sw2.png image/png
                                    upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86s           w1.png img/86sw1.png image/png
                                    upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86p           lug.png img/86plug.png image/png
                                    upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.j           s admin.js application/javascript
                                    Adapter "zigbee" updated
                                    Adapter "zont"           is not installed.
                                    Adapter "zwave"          is not installed.
                                    Adapter "zwave2"         is not installed.
                                      @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
                                      Da sind gleich mehrere Baustellen anhängig.
                                      I.
                                      pixman-1.pc
                                      sudo apt install libpixman-1-dev
                                      II. Dann noch libvips selber bauen.
                                      III.
                                      Veraltete Version von dissolve irgendwo in den Dependencies. Noch keine Ahnung wie man das auflösen kann.
                                      Das kommt (zumindest in der Ballung) daher:
                                      meine iobroker System nach langer zeit aktualisiert
                                      'Never change a running system' ist in meinen Augen nicht der richtige Ansatz.
                                      • birdy
                                        @Thomas-Braun
                                        I.) schaffe ich ja grad noch... Aber alles andere...
                                        Komisch, dass sonst jeder Adapter läuft und auch in der aktuellsten Version läuft.
                                        Zigbee lässt sich nicht Mal deistallieren:
                                        2020-09-20 17:52:50.111 - info: host.raspberrypi iobroker del zigbee
                                        2020-09-20 17:52:53.089 - info: host.raspberrypi iobroker Delete adapter "zigbee"
                                        2020-09-20 17:52:53.111 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of zigbee
                                        2020-09-20 17:52:53.126 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 meta of zigbee
                                        2020-09-20 17:52:53.133 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for zigbee
                                        2020-09-20 17:52:53.162 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 channels of zigbee
                                        2020-09-20 17:52:53.177 - info: host.raspberrypi iobroker host.raspberrypi Counted 5 states of zigbee
                                        2020-09-20 17:52:53.192 - info: host.raspberrypi iobroker host.raspberrypi Counted 13 states of system.adapter.zigbee
                                        2020-09-20 17:52:53.207 - info: host.raspberrypi iobroker host.raspberrypi Counted 5 states (io.zigbee.*) from states
                                        2020-09-20 17:52:53.254 - info: host.raspberrypi iobroker host.raspberrypi Counted 3 states (system.adapter.zigbee.*) from states
                                        2020-09-20 17:52:56.022 - warn: readDir will not read this directory () in future versions: zigbee is not an object of type "meta"
                                        2020-09-20 17:52:56.102 - info: host.raspberrypi iobroker host.raspberrypi file zigbee.admin deleted
                                        2020-09-20 17:52:56.123 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.admin deleted
                                        2020-09-20 17:52:56.126 - info: host.raspberrypi iobroker host.raspberrypi Deleting 22 object(s).
                                        2020-09-20 17:52:57.110 - error: host.raspberrypi Cannot write files: /opt/iobroker/iobroker-data/files/zigbee.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/zigbee.admin/_data.json'
                                        2020-09-20 17:52:57.845 - info: host.raspberrypi object deleted system.adapter.zigbee.0
                                        2020-09-20 17:52:57.921 - info: host.raspberrypi iobroker host.raspberrypi Deleting 8 state(s).
                                        2020-09-20 17:52:58.299 - info: host.raspberrypi iobroker npm uninstall iobroker.zigbee --error --prefix "/opt/iobroker" (System call)
                                        2020-09-20 17:53:34.737 - info: host.raspberrypi iobroker npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                                        2020-09-20 17:54:19.960 - info: host.raspberrypi iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        2020-09-20 17:54:19.972 - info: host.raspberrypi iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        2020-09-20 17:54:19.982 - info: host.raspberrypi iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concentrate@^0.2.3 (node_modules/unpi/node_modules/concentrate):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for concentrate@0.2.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: concentrate@0.2.3
                                        2020-09-20 17:54:19.986 - info: host.raspberrypi iobroker
                                        2020-09-20 17:54:20.027 - info: host.raspberrypi iobroker npm ERR! code ENOTSUP
                                        2020-09-20 17:54:20.043 - info: host.raspberrypi iobroker npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR! notsup Required: {"node":"~0.10.0"}npm ERR! notsup Actual: {"npm":"6.14.6","node":"12.18.4"}
                                        2020-09-20 17:54:20.178 - info: host.raspberrypi iobroker
                                        2020-09-20 17:54:20.182 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-09-20T15_54_20_135Z-debug.log
                                        2020-09-20 17:54:20.251 - error: host.raspberrypi iobroker Error deleting adapter zigbee from disk: Error: host.raspberrypi: Cannot uninstall iobroker.zigbee: 1You might have to delete it yourself!
                                        2020-09-20 17:54:21.294 - info: host.raspberrypi iobroker exit 0
                                          @birdy
                                          Seltsamerweise ist bei mir dissolve gar nicht installiert:
                                          pi@raspberrypi:/opt/iobroker $ npm list dissolve
                                          iobroker.inst@2.0.3 /opt/iobroker
                                          └── (empty)
                                          • birdy
                                            @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
                                            @birdy
                                            └── (empty)
                                            Das bedeutet was? 🙂
                                            Thomas Braun birdy 2 Replies Last reply Reply Quote 0
                                            zigbee
                                            5875
