    4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    UNSOLVED Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    • birdy
      birdy @Thomas Braun last edited by
      @Thomas-Braun
      Kommt gleich, ein paar adapter werden aktualisiert. Ist danach wieder ein npm rebuild zu machen?
        Thomas Braun Most Active @birdy last edited by
        @birdy Erstmal nicht. Wenn das durch ist schauen wir ggf. weiter.
        birdy 1 Reply Last reply Reply Quote 0
          Thomas Braun Most Active @Glasfaser last edited by Thomas Braun
          @Glasfaser Nö, ist nicht quer. Wenn der User iobroker was mir npm macht dann landet das natürlich auch in dessen home-Verzeichnis. Wo auch sonst, außer in /opt/iobroker (wegen sudoer) darf der ja nix machen
          • birdy
            @Thomas-Braun
            so, eine ordentliche Litanei...
            pi@raspberrypi:/opt/iobroker $ iobroker upgrade
            Adapter "admin"          is up to date.
            Adapter "alarm"          is not installed.
            Adapter "alexa2"         is up to date.
            Adapter "alpha2"         is not installed.
            Adapter "amazon-dash"    is not installed.
            Adapter "artnet"         is not installed.
            Adapter "asterisk"       is not installed.
            Adapter "asuswrt"        is not installed.
            Adapter "b-control-em"   is not installed.
            Update backitup from @1.1.4 to @1.6.7
            host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
            NPM version: 6.14.6
            npm install iobroker.backitup@1.6.7 --loglevel error --prefix "/opt/iobroker" (S           ystem call)
            Package pixman-1 was not found in the pkg-config search path.
            Perhaps you should add the directory containing `pixman-1.pc'
            to the PKG_CONFIG_PATH environment variable
            No package 'pixman-1' found
            gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in bindin           g.gyp. while trying to load binding.gyp
            gyp ERR! configure error
            gyp ERR! stack Error: `gyp` failed with exit code: 1
            gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modu           les/node-gyp/lib/configure.js:351:16)
            gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces           s.js:275:12)
            gyp ERR! System Linux 4.19.66-v7+
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy           p/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/nod           e_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_pat           h=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_ab           i_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
            gyp ERR! cwd /opt/iobroker/node_modules/canvas
            gyp ERR! node -v v12.18.4
            gyp ERR! node-gyp -v v5.1.0
            gyp ERR! not ok
            node-pre-gyp ERR! build error
            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_mo           dules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --           module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name           =canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_ver           sion=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (           1)
            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modu           les/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/chi           ld_process.js:286:5)
            node-pre-gyp ERR! System Linux 4.19.66-v7+
            node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/nod           e_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
            node-pre-gyp ERR! node -v v12.18.4
            node-pre-gyp ERR! node-pre-gyp -v v0.11.0
            node-pre-gyp ERR! not ok
            ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
            info sharp Attempting to build from source via node-gyp but this may fail due to            the above error
            info sharp Please see https://sharp.pixelplumbing.com/install for required depen           dencies
            ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht ge           funden
             #include <vips/vips8>
            compilation terminated.
            make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module           s/node-gyp/lib/build.js:194:23)
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy           p/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/sharp
            gyp ERR! not ok
            upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/wor           ds.js words.js application/javascript
            Update "system.adapter.backitup.0"
            upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ind           ex_m.html index_m.html text/html
            upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ind           ex.html index.html text/html
            upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/bac           kitup.png backitup.png image/png
            Adapter "backitup" updated
            host.raspberrypi Adapter "system.adapter.backitup.0" is started
            Adapter "beckhoff"       is not installed.
            Adapter "benq"           is not installed.
            Adapter "binance"        is not installed.
            Adapter "ble"            is not installed.
            Adapter "bmw"            is not installed.
            Adapter "bosesoundtouch" is not installed.
            Adapter "botvac"         is not installed.
            Adapter "bring"          is not installed.
            Adapter "broadlink2"     is up to date.
            Adapter "bsblan"         is not installed.
            Adapter "bshb"           is not installed.
            Adapter "chromecast"     is not installed.
            Adapter "cloud"          is not installed.
            Adapter "comfoair"       is not installed.
            Adapter "contactid"      is not installed.
            Adapter "coronavirus-statistics" is not installed.
            Adapter "countdown"      is not installed.
            Adapter "cul"            is not installed.
            Adapter "daikin"         is not installed.
            Update daswetter from @2.8.0 to @3.0.1
            host.raspberrypi Adapter "system.adapter.daswetter.0" is stopped.
            NPM version: 6.14.6
            npm install iobroker.daswetter@3.0.1 --loglevel error --prefix "/opt/iobroker" (           System call)
            gyp ERR! not ok
            gyp ERR! not ok
            Update "system.adapter.daswetter.0"
            upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/galeria2-Beaufort/75.png icons/viento-wind/galeria2-Beaufort/           75.png image/png
            upload [400] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/galeria2-Beaufort/3.png icons/viento-wind/galeria2-Beaufort/3           .png image/png
            upload [350] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/galeria1/16.png icons/viento-wind/galeria1/16.png image/png
            upload [300] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/Beaufort-White/60.png icons/viento-wind/Beaufort-White/60.png            image/png
            upload [250] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/viento-wind/Beaufort-White/15.png icons/viento-wind/Beaufort-White/15.png            image/png
            upload [200] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/tiempo-weather/galeria6/11.svg icons/tiempo-weather/galeria6/11.svg image           /svg+xml
            upload [150] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/tiempo-weather/galeria5/PNG/White/9.png icons/tiempo-weather/galeria5/PNG           /White/9.png image/png
            upload [100] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin           /icons/tiempo-weather/galeria4/3.png icons/tiempo-weather/galeria4/3.png image/p           ng
            upload [90] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria4/11.png icons/tiempo-weather/galeria4/11.png image/           png
            upload [80] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria3/2.png icons/tiempo-weather/galeria3/2.png image/pn           g
            upload [70] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria3/10.png icons/tiempo-weather/galeria3/10.png image/           png
            upload [60] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria2/19.png icons/tiempo-weather/galeria2/19.png image/           png
            upload [50] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria2/1.png icons/tiempo-weather/galeria2/1.png image/pn           g
            upload [40] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/tiempo-weather/galeria1/18.png icons/tiempo-weather/galeria1/18.png image/           png
            upload [30] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/9.png icons/luna-moon/9.png image/png
            upload [20] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/26.png icons/luna-moon/26.png image/png
            upload [19] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/25.png icons/luna-moon/25.png image/png
            upload [18] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/24.png icons/luna-moon/24.png image/png
            upload [17] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/23.png icons/luna-moon/23.png image/png
            upload [16] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/22.png icons/luna-moon/22.png image/png
            upload [15] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/21.png icons/luna-moon/21.png image/png
            upload [14] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/20.png icons/luna-moon/20.png image/png
            upload [13] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/2.png icons/luna-moon/2.png image/png
            upload [12] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/19.png icons/luna-moon/19.png image/png
            upload [11] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/18.png icons/luna-moon/18.png image/png
            upload [10] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/           icons/luna-moon/17.png icons/luna-moon/17.png image/png
            upload [9] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/16.png icons/luna-moon/16.png image/png
            upload [8] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/15.png icons/luna-moon/15.png image/png
            upload [7] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/14.png icons/luna-moon/14.png image/png
            upload [6] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/13.png icons/luna-moon/13.png image/png
            upload [5] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/12.png icons/luna-moon/12.png image/png
            upload [4] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/11.png icons/luna-moon/11.png image/png
            upload [3] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/10.png icons/luna-moon/10.png image/png
            upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/1.png icons/luna-moon/1.png image/png
            upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i           cons/luna-moon/0.png icons/luna-moon/0.png image/png
            upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/d           aswettercom.png daswettercom.png image/png
            Adapter "daswetter" updated
            host.raspberrypi Adapter "system.adapter.daswetter.0" is started
            Adapter "deconz"         is not installed.
            Adapter "denon"          is not installed.
            Adapter "devices"        is not installed.
            Adapter "digitalstrom"   is not installed.
            Adapter "discovergy"     is not installed.
            Update discovery from @1.3.0 to @2.3.7
            NPM version: 6.14.6
            npm install iobroker.discovery@2.3.7 --loglevel error --prefix "/opt/iobroker" (           System call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/w           ords.js words.js application/javascript
            Update "system.adapter.discovery.0"
            upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/t           ranslateTools.js translateTools.js application/javascript
            upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/s           ettings_m.html settings_m.html text/html
            upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/s           ettings.html settings.html text/html
            upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i           ndex_m.html index_m.html text/html
            upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/i           ndex.html index.html text/html
            upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/d           iscovery.png discovery.png image/png
            Adapter "discovery" updated
            Adapter "doorio"         is not installed.
            Adapter "ds18b20"        is not installed.
            Adapter "dwd"            is not installed.
            Adapter "ebus"           is not installed.
            Adapter "ecovacs-deebot" is not installed.
            Adapter "egigeozone"     is not installed.
            Adapter "ekey"           is not installed.
            Adapter "email"          is not installed.
            Adapter "emby"           is not installed.
            Adapter "energymanager"  is not installed.
            Adapter "enet"           is not installed.
            Adapter "epson_stylus_px830" is not installed.
            Adapter "exchangerates"  is not installed.
            Adapter "fakeroku"       is not installed.
            Adapter "fb-checkpresence" is not installed.
            Adapter "feiertage"      is not installed.
            Adapter "fhem"           is not installed.
            Adapter "find-my-iphone" is not installed.
            Adapter "firetv"         is not installed.
            Adapter "flot"           is up to date.
            Adapter "foobar2000"     is not installed.
            Adapter "fritzbox"       is not installed.
            Adapter "fritzdect"      is not installed.
            Adapter "fronius"        is not installed.
            Adapter "fullcalendar"   is not installed.
            Adapter "fullybrowser"   is not installed.
            Adapter "g-homa"         is not installed.
            Adapter "geofency"       is not installed.
            Adapter "gruenbeck"      is not installed.
            Adapter "habpanel"       is not installed.
            Adapter "haier"          is not installed.
            Adapter "ham"            is not installed.
            Adapter "ham-wemo"       is not installed.
            Adapter "harmony"        is not installed.
            Adapter "heatingcontrol" is not installed.
            Adapter "heytech"        is not installed.
            Adapter "hid"            is not installed.
            Update history from @1.8.6 to @1.9.10
            NPM version: 6.14.6
            npm install iobroker.history@1.9.10 --loglevel error --prefix "/opt/iobroker" (S           ystem call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words           Custom.js wordsCustom.js application/javascript
            upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words           .js words.js application/javascript
            upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index           _m.html index_m.html text/html
            upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index           .html index.html text/html
            upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/histo           ry.png history.png image/png
            upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo           m_m.html custom_m.html text/html
            upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custo           m.html custom.html text/html
            Adapter "history" updated
            Adapter "hm-rega"        is not installed.
            Adapter "hm-rpc"         is not installed.
            Adapter "hmip"           is not installed.
            Adapter "homeconnect"    is not installed.
            Adapter "homee"          is not installed.
            Adapter "homepilot"      is not installed.
            Adapter "hp-ilo"         is not installed.
            Adapter "hs100"          is not installed.
            Adapter "hue"            is not installed.
            Adapter "hue-extended"   is not installed.
            Adapter "ical"           is not installed.
            Adapter "icons-addictive-flavour-png" is not installed.
            Adapter "icons-fatcow-hosting" is not installed.
            Adapter "icons-icons8"   is not installed.
            Adapter "icons-material-png" is not installed.
            Adapter "icons-material-svg" is not installed.
            Adapter "icons-mfd-png"  is not installed.
            Adapter "icons-mfd-svg"  is not installed.
            Adapter "icons-open-icon-library-png" is not installed.
            Adapter "icons-ultimate-png" is up to date.
            Adapter "influxdb"       is not installed.
            Adapter "info"           is up to date.
            Adapter "innogy-smarthome" is not installed.
            Adapter "iogo"           is not installed.
            Adapter "iot"            is up to date.
            Adapter "iqontrol"       is not installed.
            Adapter "javascript"     is up to date.
            Adapter "jeelink"        is not installed.
            Adapter "kecontact"      is not installed.
            Adapter "klf200"         is not installed.
            Adapter "km200"          is not installed.
            Adapter "knmi-weather"   is not installed.
            Adapter "knx"            is not installed.
            Adapter "kodi"           is not installed.
            Adapter "kress"          is not installed.
            Adapter "lametric"       is not installed.
            Adapter "landroid"       is not installed.
            Adapter "lcn"            is not installed.
            Adapter "letrika_comgw"  is not installed.
            Adapter "lgtv"           is not installed.
            Adapter "lgtv-rs"        is not installed.
            Adapter "lgtv11"         is not installed.
            Adapter "lifx"           is not installed.
            Adapter "lightify"       is not installed.
            Adapter "link"           is not installed.
            Adapter "linkeddevices"  is not installed.
            Adapter "logparser"      is not installed.
            Adapter "lovelace"       is not installed.
            Adapter "loxone"         is not installed.
            Adapter "luftdaten"      is not installed.
            Adapter "lupusec"        is not installed.
            Adapter "luxtronik1"     is not installed.
            Adapter "material"       is not installed.
            Adapter "maxcube"        is not installed.
            Adapter "maxcul"         is not installed.
            Adapter "mbus"           is not installed.
            Adapter "mclighting"     is not installed.
            Adapter "megad"          is not installed.
            Adapter "megadd"         is not installed.
            Adapter "megaesp"        is not installed.
            Adapter "melcloud"       is not installed.
            Adapter "mercedesme"     is not installed.
            Adapter "mercury"        is not installed.
            Adapter "meross"         is not installed.
            Adapter "meteoalarm"     is not installed.
            Adapter "midea"          is not installed.
            Adapter "miele"          is not installed.
            Adapter "mielecloudservice" is not installed.
            Adapter "mihome"         is not installed.
            Adapter "mihome-lamp"    is not installed.
            Adapter "mihome-plug"    is not installed.
            Adapter "mihome-vacuum"  is not installed.
            Adapter "mikrotik"       is not installed.
            Adapter "milight"        is not installed.
            Adapter "milight-smart-light" is not installed.
            Adapter "mobile"         is not installed.
            Adapter "modbus"         is not installed.
            Adapter "moma"           is not installed.
            Adapter "mpd"            is not installed.
            Update mqtt from @2.0.4 to @2.1.4
            NPM version: 6.14.6
            npm install iobroker.mqtt@2.1.4 --loglevel error --prefix "/opt/iobroker" (Syste           m call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js wo           rds.js application/javascript
            Update "system.adapter.mqtt.0"
            upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mq           tt.png image/png
            upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.htm           l index_m.html text/html
            upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html            index.html text/html
            Adapter "mqtt" updated
            Adapter "mqtt-client"    is not installed.
            Adapter "musiccast"      is not installed.
            Adapter "mysensors"      is not installed.
            Adapter "nanoleaf-lightpanels" is not installed.
            Adapter "nello"          is not installed.
            Adapter "netatmo"        is not installed.
            Adapter "nibeuplink"     is not installed.
            Adapter "nina"           is not installed.
            Adapter "node-red"       is not installed.
            Adapter "nuki"           is not installed.
            Adapter "nuki-extended"  is not installed.
            Adapter "nut"            is not installed.
            Adapter "odl"            is not installed.
            Adapter "oilfox"         is not installed.
            Adapter "onkyo"          is not installed.
            Adapter "onvif"          is not installed.
            Adapter "openhab"        is not installed.
            Adapter "openligadb"     is not installed.
            Adapter "openweathermap" is not installed.
            Adapter "opi"            is not installed.
            Adapter "oppoplayer"     is not installed.
            Adapter "owfs"           is not installed.
            Adapter "owntracks"      is not installed.
            Adapter "panasonic-viera" is not installed.
            Adapter "parser"         is up to date.
            Adapter "paw"            is not installed.
            Adapter "phantomjs"      is not installed.
            Adapter "pi-hole"        is not installed.
            Adapter "piface"         is not installed.
            Adapter "pimatic"        is not installed.
            Update ping from @1.3.2 to @1.4.8
            NPM version: 6.14.6
            npm install iobroker.ping@1.4.8 --loglevel error --prefix "/opt/iobroker" (Syste           m call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js wo           rds.js application/javascript
            Update "system.adapter.ping.0"
            upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png pi           ng.png image/png
            upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.htm           l index_m.html text/html
            upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html            index.html text/html
            Adapter "ping" updated
            Adapter "places"         is not installed.
            Adapter "plex"           is not installed.
            Adapter "plexconnect"    is not installed.
            Adapter "pollenflug"     is not installed.
            Adapter "proxmox"        is not installed.
            Adapter "proxy"          is not installed.
            Adapter "pushbullet"     is not installed.
            Adapter "pushover"       is not installed.
            Adapter "pushsafer"      is not installed.
            Adapter "radar2"         is not installed.
            Adapter "radiohead"      is not installed.
            Adapter "rflink"         is not installed.
            Adapter "rickshaw"       is up to date.
            Adapter "ring"           is not installed.
            Adapter "robonect"       is not installed.
            Adapter "roomba"         is not installed.
            Adapter "rpi2"           is not installed.
            Adapter "s7"             is not installed.
            Adapter "samsung"        is not installed.
            Adapter "sayit"          is not installed.
            Adapter "sbfspot"        is not installed.
            Adapter "scenes"         is up to date.
            Adapter "schoolfree"     is not installed.
            Adapter "shelly"         is not installed.
            Adapter "shuttercontrol" is not installed.
            Adapter "sia"            is not installed.
            Adapter "siegenia"       is not installed.
            Adapter "simple-api"     is up to date.
            Adapter "smappee"        is not installed.
            Adapter "smartgarden"    is not installed.
            Adapter "smartmeter"     is not installed.
            Adapter "snips"          is not installed.
            Adapter "snmp"           is not installed.
            Adapter "socketio"       is up to date.
            Adapter "solarlog"       is not installed.
            Adapter "solarviewdatareader" is not installed.
            Adapter "solarwetter"    is not installed.
            Adapter "sonnen"         is not installed.
            Update sonoff from @2.2.2 to @2.3.3
            NPM version: 6.14.6
            npm install iobroker.sonoff@2.3.3 --loglevel error --prefix "/opt/iobroker" (Sys           tem call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/words.j           s words.js application/javascript
            Update "system.adapter.sonoff.0"
            upload [2] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/sonoff.           png sonoff.png image/png
            upload [1] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index_m           .html index_m.html text/html
            upload [0] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.h           tml index.html text/html
            Adapter "sonoff" updated
            Adapter "sonos"          is not installed.
            Adapter "sony-bravia"    is not installed.
            Adapter "spotify-premium" is not installed.
            Update sql from @1.9.4 to @1.15.2
            host.raspberrypi Adapter "system.adapter.sql.0" is stopped.
            NPM version: 6.14.6
            npm install iobroker.sql@1.15.2 --loglevel error --prefix "/opt/iobroker" (Syste           m call)
            gyp ERR! not ok
            gyp ERR! not ok
            ../src/backup.cc: In static member function ‘static void node_sqlite3::Backup::W           ork_BeginInitialize(node_sqlite3::Database::Baton*)’:
            ../src/backup.cc:191:9: warning: unused variable ‘status’ [-Wunused-variable]
                 int status = napi_create_async_work(
            In file included from ../src/backup.cc:4:0:
            ../src/backup.cc: In static member function ‘static void node_sqlite3::Backup::W           ork_BeginStep(node_sqlite3::Backup::Baton*)’:
            ../src/macros.h:175:9: warning: unused variable ‘status’ [-Wunused-variable]
                 int status = napi_create_async_work(                                                  \
            ../src/backup.cc:263:5: note: in expansion of macro ‘BACKUP_BEGIN’
                 BACKUP_BEGIN(Step);
            ../src/backup.cc: In static member function ‘static void node_sqlite3::Backup::W           ork_BeginFinish(node_sqlite3::Backup::Baton*)’:
            ../src/backup.cc:329:5: note: in expansion of macro ‘BACKUP_BEGIN’
                 BACKUP_BEGIN(Finish);
            ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
            ../src/database.cc:144:9: warning: unused variable ‘status’ [-Wunused-variable]
            ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginClose(node_sqlite3::Database::Baton*)’:
            ../src/database.cc:240:9: warning: unused variable ‘status’ [-Wunused-variable]
            ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginExec(node_sqlite3::Database::Baton*)’:
            ../src/database.cc:557:9: warning: unused variable ‘status’ [-Wunused-variable]
            ../src/database.cc: In static member function ‘static void node_sqlite3::Databas           e::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
            ../src/database.cc:667:9: warning: unused variable ‘status’ [-Wunused-variable]
            ../src/statement.cc: In function ‘bool OtherInstanceOf(Napi::Object, char*)’:
            ../src/statement.cc:35:24: warning: comparison with string literal results in un           specified behavior [-Waddress]
                 if (object_type == "Date") {
            ../src/statement.cc:37:31: warning: comparison with string literal results in un           specified behavior [-Waddress]
                 } else if (object_type == "RegExp") {
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:
            ../src/statement.cc:128:9: warning: unused variable ‘status’ [-Wunused-variable]
            In file included from ../src/statement.cc:5:0:
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
            ../src/macros.h:145:9: warning: unused variable ‘status’ [-Wunused-variable]
            ../src/statement.cc:349:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                 STATEMENT_BEGIN(Bind);
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginGet(node_sqlite3::Statement::Baton*)’:
            ../src/statement.cc:400:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                 STATEMENT_BEGIN(Get);
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
            ../src/statement.cc:471:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                 STATEMENT_BEGIN(Run);
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginAll(node_sqlite3::Statement::Baton*)’:
            ../src/statement.cc:540:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                 STATEMENT_BEGIN(All);
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginEach(node_sqlite3::Statement::Baton*)’:
            ../src/statement.cc:640:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                 STATEMENT_BEGIN(Each);
            ../src/statement.cc: In static member function ‘static void node_sqlite3::Statem           ent::Work_BeginReset(node_sqlite3::Statement::Baton*)’:
            ../src/statement.cc:766:5: note: in expansion of macro ‘STATEMENT_BEGIN’
                 STATEMENT_BEGIN(Reset);
            ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::Baton]’:
            ../src/statement.cc:337:42:   required from here
            ../src/statement.cc:243:60: warning: ISO C++ forbids converting a string constan           t to ‘char*’ [-Wwrite-strings]
                     else if (!info[start].IsObject() || OtherInstanceOf(info[start].As<Obje           ct>(), "RegExp") || OtherInstanceOf(info[start].As<Object>(), "Date") || info[st           art].IsBuffer()) {
            ../src/statement.cc:243:115: warning: ISO C++ forbids converting a string consta           nt to ‘char*’ [-Wwrite-strings]
            ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::RowBaton]’:
            ../src/statement.cc:388:45:   required from here
            ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::RunBaton]’:
            ../src/statement.cc:459:45:   required from here
            ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::RowsBaton]’:
            ../src/statement.cc:528:46:   required from here
            ../src/statement.cc: In instantiation of ‘T* node_sqlite3::Statement::Bind(const            Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::EachBaton]’:
            ../src/statement.cc:620:59:   required from here
            ../src/statement.cc: In instantiation of ‘node_sqlite3::Values::Field* node_sqli           te3::Statement::BindParameter(Napi::Value, T) [with T = int]’:
            ../src/statement.cc:240:58:   required from ‘T* node_sqlite3::Statement::Bind(co           nst Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::Baton]’
            ../src/statement.cc:188:29: warning: ISO C++ forbids converting a string constan           t to ‘char*’ [-Wwrite-strings]
                 else if (OtherInstanceOf(source.As<Object>(), "RegExp")) {
            ../src/statement.cc:209:29: warning: ISO C++ forbids converting a string constan           t to ‘char*’ [-Wwrite-strings]
                 else if (OtherInstanceOf(source.As<Object>(), "Date")) {
            ../src/statement.cc: In instantiation of ‘node_sqlite3::Values::Field* node_sqli           te3::Statement::BindParameter(Napi::Value, T) [with T = const char*]’:
            ../src/statement.cc:263:62:   required from ‘T* node_sqlite3::Statement::Bind(co           nst Napi::CallbackInfo&, int, int) [with T = node_sqlite3::Statement::Baton]’
            upload [5] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js word           s.js application/javascript
            Update "system.adapter.sql.0"
            upload [4] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.p           ng image/png
            upload [3] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index_m.html            index_m.html text/html
            upload [2] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/index.html in           dex.html text/html
            upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom_m.html            custom_m.html text/html
            upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/custom.html c           ustom.html text/html
            Adapter "sql" updated
            host.raspberrypi Adapter "system.adapter.sql.0" is started
            Adapter "squeezebox"     is not installed.
            Adapter "squeezeboxrpc"  is not installed.
            Adapter "starline"       is not installed.
            Adapter "statistics"     is not installed.
            Adapter "stiebel-isg"    is not installed.
            Adapter "sunnyportal"    is not installed.
            Adapter "swiss-weather-api" is not installed.
            Adapter "synology"       is not installed.
            Adapter "systeminfo"     is not installed.
            Adapter "tahoma"         is not installed.
            Adapter "tankerkoenig"   is not installed.
            Update telegram from @1.4.3 to @1.5.9
            host.raspberrypi Adapter "system.adapter.telegram.0" is stopped.
            NPM version: 6.14.6
            npm install iobroker.telegram@1.5.9 --loglevel error --prefix "/opt/iobroker" (S           ystem call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [5] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/wor           ds.js words.js application/javascript
            Update "system.adapter.telegram.0"
            upload [4] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/tel           egram.png telegram.png image/png
            upload [3] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/ind           ex_m.html index_m.html text/html
            upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/ind           ex.html index.html text/html
            upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/cus           tom_m.html custom_m.html text/html
            upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blo           ckly.js blockly.js application/javascript
            Adapter "telegram" updated
            host.raspberrypi Adapter "system.adapter.telegram.0" is started
            Adapter "terminal"       is up to date.
            Adapter "tesla-motors"   is not installed.
            Update text2command from @1.2.5 to @1.3.0
            NPM version: 6.14.6
            npm install iobroker.text2command@1.3.0 --loglevel error --prefix "/opt/iobroker           " (System call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [4] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/words.js words.js application/javascript
            Update "system.adapter.text2command.0"
            upload [3] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/text2command.png text2command.png image/png
            upload [2] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/tab.js tab.js application/javascript
            upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/tab.html tab.html text/html
            upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/a           dmin/langModel.js langModel.js application/javascript
            Adapter "text2command" updated
            Adapter "tinker"         is not installed.
            Adapter "tr-064"         is not installed.
            Adapter "tradfri"        is not installed.
            Adapter "trashschedule"  is not installed.
            Adapter "tunnelbroker-endpoint-updater" is not installed.
            Adapter "tuya"           is not installed.
            Adapter "tvspielfilm"    is not installed.
            Adapter "unifi"          is not installed.
            Adapter "upnp"           is not installed.
            Adapter "vaillant"       is not installed.
            Adapter "valloxmv"       is not installed.
            Adapter "vcard"          is not installed.
            Adapter "velux"          is not installed.
            Adapter "viessmann"      is not installed.
            Adapter "virtualpowermeter" is not installed.
            Adapter "vis"            is up to date.
            Adapter "vis-bars"       is not installed.
            Adapter "vis-canvas-gauges" is not installed.
            Adapter "vis-colorpicker" is not installed.
            Adapter "vis-fancyswitch" is up to date.
            Adapter "vis-google-fonts" is not installed.
            Update vis-history from @0.2.7 to @1.0.0
            NPM version: 6.14.6
            npm install iobroker.vis-history@1.0.0 --loglevel error --prefix "/opt/iobroker"            (System call)
            gyp ERR! not ok
            gyp ERR! not ok
            INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-history/www" was not fo           und! Nothing was uploaded or deleted.
            upload [0] vis-history.admin /opt/iobroker/node_modules/iobroker.vis-history/adm           in/vis-history.png vis-history.png image/png
            Adapter "system.adapter.vis.0" restarted.
            Update "system.adapter.vis-history.0"
            Adapter "vis-history" updated
            Adapter "vis-hqwidgets"  is up to date.
            Adapter "vis-icontwo"    is not installed.
            Adapter "vis-inventwo"   is not installed.
            Adapter "vis-jqui-mfd"   is up to date.
            Adapter "vis-justgage"   is not installed.
            Adapter "vis-keyboard"   is not installed.
            Adapter "vis-lcars"      is not installed.
            Adapter "vis-map"        is not installed.
            Adapter "vis-metro"      is up to date.
            Adapter "vis-players"    is not installed.
            Adapter "vis-plumb"      is not installed.
            Adapter "vis-rgraph"     is not installed.
            Adapter "vis-timeandweather" is up to date.
            Update vis-weather from @2.3.0 to @2.5.2
            NPM version: 6.14.6
            npm install iobroker.vis-weather@2.5.2 --loglevel error --prefix "/opt/iobroker"            (System call)
            gyp ERR! not ok
            gyp ERR! not ok
            INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not fo           und! Nothing was uploaded or deleted.
            upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/words.js words.js application/javascript
            Update "system.adapter.vis-weather.0"
            upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/vis-weather.png vis-weather.png image/png
            upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/index_m.html index_m.html text/html
            upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/adm           in/index.html index.html text/html
            Adapter "vis-weather" updated
            Adapter "vr200"          is not installed.
            Adapter "vw-connect"     is not installed.
            Update weatherunderground from @3.0.7 to @3.2.1
            NPM version: 6.14.6
            npm install iobroker.weatherunderground@3.2.1 --loglevel error --prefix "/opt/io           broker" (System call)
            gyp ERR! not ok
            gyp ERR! not ok
            upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatheru           nderground/admin/wu.png wu.png image/png
            upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatheru           nderground/admin/words.js words.js application/javascript
            upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatheru           nderground/admin/index_m.html index_m.html text/html
            Adapter "weatherunderground" updated
            Adapter "web"            is up to date.
            Adapter "weishaupt-wem"  is not installed.
            Adapter "wiffi-wz"       is not installed.
            Adapter "wifilight"      is not installed.
            Adapter "windows-control" is not installed.
            Adapter "wled"           is not installed.
            Adapter "wm-bus"         is not installed.
            Adapter "wolf"           is not installed.
            Adapter "worx"           is not installed.
            Adapter "xbox"           is not installed.
            Adapter "xs1"            is not installed.
            Adapter "yahka"          is not installed.
            Adapter "yamaha"         is not installed.
            Adapter "yeelight-2"     is not installed.
            Adapter "youtube"        is not installed.
            Adapter "yr"             is up to date.
            Update zigbee from @0.10.2 to @1.2.1
            NPM version: 6.14.6
            npm install iobroker.zigbee@1.2.1 --loglevel error --prefix "/opt/iobroker" (Sys           tem call)
            npm ERR! code ENOTSUP
            npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"           } (current: {"node":"12.18.4","npm":"6.14.6"})
            npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
            npm ERR! notsup Required: {"node":"~0.10.0"}
            npm ERR! notsup Actual:   {"npm":"6.14.6","node":"12.18.4"}
            npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T15_36_01_596Z-debug.log
            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index           _m.html index_m.html text/html
            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sy           lvania_rt.png img/sylvania_rt.png image/png
            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/se           nsor_ht.png img/sensor_ht.png image/png
            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ph           ilips_hue_lightbar.png img/philips_hue_lightbar.png image/png
            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/os           ram_ceiling_tw.png img/osram_ceiling_tw.png image/png
            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/li           ghtify-plug.png img/lightify-plug.png image/png
            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/in           nr.png img/innr.png image/png
            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gl           edopto_bulb.png img/gledopto_bulb.png image/png
            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cu           be.png img/cube.png image/png
            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_neutral2.png img/ctrl_neutral2.png image/png
            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_neutral1.png img/ctrl_neutral1.png image/png
            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_ln2.png img/ctrl_ln2.png image/png
            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ct           rl_ln1.png img/ctrl_ln1.png image/png
            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/co           ntact.png img/contact.png image/png
            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bi           tron_plug.png img/bitron_plug.png image/png
            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ba           ttery_v.png img/battery_v.png image/png
            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ba           ttery_p.png img/battery_p.png image/png
            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aq           ara_temperature_sensor.png img/aqara_temperature_sensor.png image/png
            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aq           ara_numan_body_sensor.png img/aqara_numan_body_sensor.png image/png
            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqa           ra_bulb.png img/aqara_bulb.png image/png
            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqa           ra.switch.png img/aqara.switch.png image/png
            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRA           DFRI.remote.control.png img/TRADFRI.remote.control.png image/png
            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRA           DFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLO           ALT.panel.WS.png img/FLOALT.panel.WS.png image/png
            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eur           otronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86s           w2.png img/86sw2.png image/png
            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86s           w1.png img/86sw1.png image/png
            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86p           lug.png img/86plug.png image/png
            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.j           s admin.js application/javascript
            Adapter "zigbee" updated
            Adapter "zont"           is not installed.
            Adapter "zwave"          is not installed.
            Adapter "zwave2"         is not installed.
              Thomas Braun Most Active @birdy last edited by Thomas Braun
              @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
              Da sind gleich mehrere Baustellen anhängig.
              I.
              pixman-1.pc
              sudo apt install libpixman-1-dev
              II. Dann noch libvips selber bauen.
              III.
              Veraltete Version von dissolve irgendwo in den Dependencies. Noch keine Ahnung wie man das auflösen kann.
              Das kommt (zumindest in der Ballung) daher:
              meine iobroker System nach langer zeit aktualisiert
              'Never change a running system' ist in meinen Augen nicht der richtige Ansatz.
              • birdy
                @Thomas-Braun
                I.) schaffe ich ja grad noch... Aber alles andere...
                Komisch, dass sonst jeder Adapter läuft und auch in der aktuellsten Version läuft.
                Zigbee lässt sich nicht Mal deistallieren:
                2020-09-20 17:52:50.111 - info: host.raspberrypi iobroker del zigbee
                2020-09-20 17:52:53.089 - info: host.raspberrypi iobroker Delete adapter "zigbee"
                2020-09-20 17:52:53.111 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of zigbee
                2020-09-20 17:52:53.126 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 meta of zigbee
                2020-09-20 17:52:53.133 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for zigbee
                2020-09-20 17:52:53.162 - info: host.raspberrypi iobroker host.raspberrypi Counted 1 channels of zigbee
                2020-09-20 17:52:53.177 - info: host.raspberrypi iobroker host.raspberrypi Counted 5 states of zigbee
                2020-09-20 17:52:53.192 - info: host.raspberrypi iobroker host.raspberrypi Counted 13 states of system.adapter.zigbee
                2020-09-20 17:52:53.207 - info: host.raspberrypi iobroker host.raspberrypi Counted 5 states (io.zigbee.*) from states
                2020-09-20 17:52:53.254 - info: host.raspberrypi iobroker host.raspberrypi Counted 3 states (system.adapter.zigbee.*) from states
                2020-09-20 17:52:56.022 - warn: readDir will not read this directory () in future versions: zigbee is not an object of type "meta"
                2020-09-20 17:52:56.102 - info: host.raspberrypi iobroker host.raspberrypi file zigbee.admin deleted
                2020-09-20 17:52:56.123 - info: host.raspberrypi iobroker host.raspberrypi object zigbee.admin deleted
                2020-09-20 17:52:56.126 - info: host.raspberrypi iobroker host.raspberrypi Deleting 22 object(s).
                2020-09-20 17:52:57.110 - error: host.raspberrypi Cannot write files: /opt/iobroker/iobroker-data/files/zigbee.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/iobroker-data/files/zigbee.admin/_data.json'
                2020-09-20 17:52:57.845 - info: host.raspberrypi object deleted system.adapter.zigbee.0
                2020-09-20 17:52:57.921 - info: host.raspberrypi iobroker host.raspberrypi Deleting 8 state(s).
                2020-09-20 17:52:58.299 - info: host.raspberrypi iobroker npm uninstall iobroker.zigbee --error --prefix "/opt/iobroker" (System call)
                2020-09-20 17:53:34.737 - info: host.raspberrypi iobroker npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                2020-09-20 17:54:19.960 - info: host.raspberrypi iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                2020-09-20 17:54:19.972 - info: host.raspberrypi iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                2020-09-20 17:54:19.982 - info: host.raspberrypi iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concentrate@^0.2.3 (node_modules/unpi/node_modules/concentrate):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for concentrate@0.2.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: concentrate@0.2.3
                2020-09-20 17:54:19.986 - info: host.raspberrypi iobroker
                2020-09-20 17:54:20.027 - info: host.raspberrypi iobroker npm ERR! code ENOTSUP
                2020-09-20 17:54:20.043 - info: host.raspberrypi iobroker npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3npm ERR! notsup Required: {"node":"~0.10.0"}npm ERR! notsup Actual: {"npm":"6.14.6","node":"12.18.4"}
                2020-09-20 17:54:20.178 - info: host.raspberrypi iobroker
                2020-09-20 17:54:20.182 - info: host.raspberrypi iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-09-20T15_54_20_135Z-debug.log
                2020-09-20 17:54:20.251 - error: host.raspberrypi iobroker Error deleting adapter zigbee from disk: Error: host.raspberrypi: Cannot uninstall iobroker.zigbee: 1You might have to delete it yourself!
                2020-09-20 17:54:21.294 - info: host.raspberrypi iobroker exit 0
                  @birdy
                  Seltsamerweise ist bei mir dissolve gar nicht installiert:
                  pi@raspberrypi:/opt/iobroker $ npm list dissolve
                  iobroker.inst@2.0.3 /opt/iobroker
                  └── (empty)
                  • birdy
                    @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
                    @birdy
                    └── (empty)
                    Das bedeutet was? 🙂
                    Thomas Braun birdy 2 Replies Last reply Reply Quote 0
                      @birdy
                      Das du da ggf. irgendeine Leiche im Keller hast. Denn wir haben soweit ich das sehe ganz ähnliche Adapter installiert. Was liefert denn der Befehl auf deinem System?
                      • birdy
                        birdy @birdy last edited by
                        @birdy
                        Es würde mir ja schon reichen, wenn ich den Adapter weg bekomme und wieder neu installieren könnte... 😰
                          @birdy
                          Dann musst du halt irgendwo anfangen das Gebilde zu sanieren.
                          • birdy
                            birdy @Thomas Braun last edited by birdy
                            @birdy
                            iobroker.inst@1.0.8 /opt/iobroker
                            └─┬ iobroker.zigbee@0.10.2
                              └─┬ zigbee-shepherd@0.3.0
                                └─┬ zcl-packet@0.2.4
                                  └─┬ dissolve-chunks@1.3.0
                                    └── dissolve@0.3.3
                            Was sagt diese Meldung aus?
                              cd /opt/iobroker
                              npm i iobroker.zigbee@1.2.1
                              • birdy
                                cd /opt/iobroker
                                Hab aber vergessen, iobroker zu stoppen... Schlecht?
                                npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_27_48_926Z-debug.log
                                  @birdy
                                  Versuch mal dissolve rauszukicken.
                                  Ein aktuelles zigbee benötigt das nicht mehr.
                                  npm uninstall dissolve
                                  • birdy
                                    @birdy
                                    Ein akutelles zigbee benötigt das nicht mehr.
                                    vorher iobroker stoppen?
                                      @birdy
                                      Kannst du machen.
                                        Wenn das nicht klappt versuch mal mit
                                        npm uninstall dissolve --save
                                        • birdy
                                          @Thomas-Braun
                                          pi@raspberrypi:/opt/iobroker $ npm uninstall dissolve
                                          > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
                                          > node-pre-gyp install --fallback-to-build
                                          node-pre-gyp WARN Using request for node-pre-gyp https download
                                          node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
                                          node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
                                          Package cairo was not found in the pkg-config search path.
                                          Perhaps you should add the directory containing `cairo.pc'
                                          No package 'cairo' found
                                          gyp: Call to 'pkg-config cairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                                          gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                                          gyp ERR! not ok
                                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
                                          > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                                          info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                                          make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
                                            CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                                            AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                                            COPY Release/nothing.a
                                            TOUCH Release/obj.target/libvips-cpp.stamp
                                            CXX(target) Release/obj.target/sharp/src/common.o
                                          ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
                                          sharp.target.mk:138: die Regel für Ziel „Release/obj.target/sharp/src/common.o“ scheiterte
                                          make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
                                          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                          gyp ERR! not ok
                                          > iobroker@1.0.8 install /opt/iobroker/node_modules/iobroker
                                          > node lib/setup.js
                                          NPM version: 6.14.8
                                          NPM 5 is currently NOT supported!
                                          Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
                                          You need to make sure to downgrade again with the above command after you
                                          installed an update to nodejs/npm!
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 (node_modules/canvas):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! iobroker@1.0.8 install: `node lib/setup.js`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the iobroker@1.0.8 install script.
                                          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                          npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_36_28_808Z-debug.log
                                          • birdy
                                            @Thomas-Braun
                                            So nebenbei möchte ich mich mal bei dir für die Zeit, die du in den fall investierst, bedanken!
                                            zigbee
                                            5875
