    4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    UNSOLVED Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
      Thomas Braun Most Active @birdy last edited by Thomas Braun
      @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
      cd /opt/iobroker
      npm i iobroker.zigbee@1.2.1
      birdy 1 Reply Last reply Reply Quote 0
      • birdy
        birdy @Thomas Braun last edited by
        @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
        cd /opt/iobroker
        Hab aber vergessen, iobroker zu stoppen... Schlecht?
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concentrate@^0.2.3 (node_modules/unpi/node_modules/concentrate):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for concentrate@0.2.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: concentrate@0.2.3
        npm ERR! code ENOTSUP
        npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})
        npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
        npm ERR! notsup Required: {"node":"~0.10.0"}
        npm ERR! notsup Actual:   {"npm":"6.14.6","node":"12.18.4"}
        npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_27_48_926Z-debug.log
          @birdy
          Versuch mal dissolve rauszukicken.
          Ein aktuelles zigbee benötigt das nicht mehr.
          npm uninstall dissolve
          • birdy
            @birdy
            Ein akutelles zigbee benötigt das nicht mehr.
            vorher iobroker stoppen?
              @birdy
              Kannst du machen.
                Wenn das nicht klappt versuch mal mit
                npm uninstall dissolve --save
                • birdy
                  @Thomas-Braun
                  pi@raspberrypi:/opt/iobroker $ npm uninstall dissolve
                  npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
                  > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
                  > node-pre-gyp install --fallback-to-build
                  node-pre-gyp WARN Using request for node-pre-gyp https download
                  node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
                  node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
                  Package cairo was not found in the pkg-config search path.
                  Perhaps you should add the directory containing `cairo.pc'
                  to the PKG_CONFIG_PATH environment variable
                  No package 'cairo' found
                  gyp: Call to 'pkg-config cairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                  gyp ERR! configure error
                  gyp ERR! stack Error: `gyp` failed with exit code: 1
                  gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
                  gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
                  gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                  gyp ERR! System Linux 4.19.66-v7+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
                  gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  gyp ERR! node -v v12.18.4
                  gyp ERR! node-gyp -v v5.1.0
                  gyp ERR! not ok
                  node-pre-gyp ERR! build error
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
                  node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                  node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
                  node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                  node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                  node-pre-gyp ERR! System Linux 4.19.66-v7+
                  node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                  node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
                  node-pre-gyp ERR! node -v v12.18.4
                  node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                  node-pre-gyp ERR! not ok
                  > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
                  > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
                  ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
                  info sharp Attempting to build from source via node-gyp but this may fail due to the above error
                  info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
                  make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
                    CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
                    AR(target) Release/obj.target/../node-addon-api/src/nothing.a
                    COPY Release/nothing.a
                    TOUCH Release/obj.target/libvips-cpp.stamp
                    CXX(target) Release/obj.target/sharp/src/common.o
                  ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
                   #include <vips/vips8>
                  compilation terminated.
                  sharp.target.mk:138: die Regel für Ziel „Release/obj.target/sharp/src/common.o“ scheiterte
                  make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
                  make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
                  gyp ERR! stack Error: `make` failed with exit code: 2
                  gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/sharp
                  gyp ERR! not ok
                  > iobroker@1.0.8 install /opt/iobroker/node_modules/iobroker
                  > node lib/setup.js
                  NPM version: 6.14.8
                  NPM 5 is currently NOT supported!
                  Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
                  You need to make sure to downgrade again with the above command after you
                  installed an update to nodejs/npm!
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 (node_modules/canvas):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! iobroker@1.0.8 install: `node lib/setup.js`
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the iobroker@1.0.8 install script.
                  npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_36_28_808Z-debug.log
                  • birdy
                    @Thomas-Braun
                    So nebenbei möchte ich mich mal bei dir für die Zeit, die du in den fall investierst, bedanken!
                      @birdy
                      Wie gesagt: Viele viele Baustellen.
                      Vermutlich geht das schneller, wenn du das System komplett neuinstallierst (Buster) und dann dein Backup in den ioBroker einspielst.
                      birdy 2 Replies Last reply Reply Quote 1
                      • birdy
                        @Thomas-Braun
                        aber jetzt ganz schlimm:
                        pi@raspberrypi:/opt/iobroker $ start iobroker
                        -bash: start: Kommando nicht gefunden.
                        Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          Glasfaser @birdy last edited by
                          @birdy
                          iobroker start
                            @birdy
                            Nö. Das heißt ja auch
                            iobroker start
                            • birdy
                              @birdy
                              iobroker start
                              Sorry, bin schon etwas durch den Wind...
                                @birdy
                                Die Meldung bzgl. cairo dürfest du mit
                                sudo apt install libcairo2-dev
                                schon mal loswerden. Ändert aber nix am Umfang der Großbaustelle.
                                • birdy
                                  @Thomas-Braun
                                  Aber was soll ich jetzt mit dem deistallierten dissolve machen?
                                  Nochmal?
                                    @birdy
                                    Probier mal. Ich bin nicht mal sicher das dissolve sich jetzt aufgelöst hat...
                                    • birdy
                                      @Thomas-Braun
                                      Scheint nicht so... 😞
                                      pi@raspberrypi:/opt/iobroker $ npm i iobroker.zigbee@1.2.1
                                      npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_51_25_317Z-debug.log
                                        Unsupported engine for concentrate@0.2.3: wanted: "node":"~0.10.0"}
                                        Da hast du übrigens den nächsten alten Hund.
                                        Wer weiß was da noch alles nach oben gespült wird.
                                        Ich würde das Ding plattmachen und ein Backup des ioBrokers einspielen. Backitup hast du ja hoffentlich am Start?
                                        • birdy
                                          @Thomas-Braun
                                          Ja, Backup habe ich, Komplett und Standard... Ist eine Variante zu bevorzugen?
                                            @birdy
                                            Die Unterscheidung zwischen Komplett und Standard kenne ich nicht. Vermutlich eine alte Einstellung.
                                            Du kannst aber auch mal den hier probieren:
                                            iobroker stop
                                            curl -sL https://iobroker.net/fix.sh | bash -
                                            iobroker start
                                            npm i iobroker.zigbee@1.2.1 --force
                                            kannst du auch nochmal versuchen.
                                            zigbee
                                            5875
