    4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    UNSOLVED Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    • birdy
      birdy @Thomas Braun last edited by
      @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
      @birdy
      Versuch mal dissolve rauszukicken.
      Ein akutelles zigbee benötigt das nicht mehr.
      npm uninstall dissolve
      vorher iobroker stoppen?
        Thomas Braun Most Active @birdy last edited by
        @birdy
        Kannst du machen.
        birdy 1 Reply Last reply Reply Quote 0
          @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
          Wenn das nicht klappt versuch mal mit
          npm uninstall dissolve --save
          • birdy
            @Thomas-Braun
            pi@raspberrypi:/opt/iobroker $ npm uninstall dissolve
            npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
            > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
            > node-pre-gyp install --fallback-to-build
            node-pre-gyp WARN Using request for node-pre-gyp https download
            node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
            node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
            Package cairo was not found in the pkg-config search path.
            Perhaps you should add the directory containing `cairo.pc'
            to the PKG_CONFIG_PATH environment variable
            No package 'cairo' found
            gyp: Call to 'pkg-config cairo --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
            gyp ERR! configure error
            gyp ERR! stack Error: `gyp` failed with exit code: 1
            gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
            gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
            gyp ERR! System Linux 4.19.66-v7+
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
            gyp ERR! cwd /opt/iobroker/node_modules/canvas
            gyp ERR! node -v v12.18.4
            gyp ERR! node-gyp -v v5.1.0
            gyp ERR! not ok
            node-pre-gyp ERR! build error
            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
            node-pre-gyp ERR! System Linux 4.19.66-v7+
            node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
            node-pre-gyp ERR! node -v v12.18.4
            node-pre-gyp ERR! node-pre-gyp -v v0.11.0
            node-pre-gyp ERR! not ok
            > sharp@0.25.2 install /opt/iobroker/node_modules/sharp
            > (node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)
            ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
            info sharp Attempting to build from source via node-gyp but this may fail due to the above error
            info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
            make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird betreten
              CC(target) Release/obj.target/nothing/../node-addon-api/src/nothing.o
              AR(target) Release/obj.target/../node-addon-api/src/nothing.a
              COPY Release/nothing.a
              TOUCH Release/obj.target/libvips-cpp.stamp
              CXX(target) Release/obj.target/sharp/src/common.o
            ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
             #include <vips/vips8>
            compilation terminated.
            sharp.target.mk:138: die Regel für Ziel „Release/obj.target/sharp/src/common.o“ scheiterte
            make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
            make: Verzeichnis „/opt/iobroker/node_modules/sharp/build“ wird verlassen
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
            gyp ERR! cwd /opt/iobroker/node_modules/sharp
            gyp ERR! not ok
            > iobroker@1.0.8 install /opt/iobroker/node_modules/iobroker
            > node lib/setup.js
            NPM version: 6.14.8
            NPM 5 is currently NOT supported!
            Please use "npm install -g npm@4" to downgrade npm to 4.x and try again.
            You need to make sure to downgrade again with the above command after you
            installed an update to nodejs/npm!
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.5 (node_modules/iobroker.info/node_modules/osx-temperature-sensor):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: concentrate@^0.2.3 (node_modules/unpi/node_modules/concentrate):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported engine for concentrate@0.2.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Not compatible with your version of node/npm: concentrate@0.2.3
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 (node_modules/canvas):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 (node_modules/sharp):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sharp@0.25.2 install: `(node install/libvips && node install/dll-copy && prebuild-install --runtime=napi) || (node-gyp rebuild && node install/dll-copy)`
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! iobroker@1.0.8 install: `node lib/setup.js`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the iobroker@1.0.8 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_36_28_808Z-debug.log
            • birdy
              @Thomas-Braun
              So nebenbei möchte ich mich mal bei dir für die Zeit, die du in den fall investierst, bedanken!
                @birdy
                Wie gesagt: Viele viele Baustellen.
                Vermutlich geht das schneller, wenn du das System komplett neuinstallierst (Buster) und dann dein Backup in den ioBroker einspielst.
                birdy 2 Replies Last reply Reply Quote 1
                • birdy
                  @Thomas-Braun
                  aber jetzt ganz schlimm:
                  pi@raspberrypi:/opt/iobroker $ start iobroker
                  -bash: start: Kommando nicht gefunden.
                  Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Glasfaser @birdy last edited by
                    @birdy
                    iobroker start
                      @birdy
                      Nö. Das heißt ja auch
                      iobroker start
                      • birdy
                        @birdy
                        iobroker start
                        Sorry, bin schon etwas durch den Wind...
                          @birdy
                          Die Meldung bzgl. cairo dürfest du mit
                          sudo apt install libcairo2-dev
                          schon mal loswerden. Ändert aber nix am Umfang der Großbaustelle.
                          • birdy
                            @Thomas-Braun
                            Aber was soll ich jetzt mit dem deistallierten dissolve machen?
                            Nochmal?
                            npm i iobroker.zigbee@1.2.1
                              @birdy
                              Probier mal. Ich bin nicht mal sicher das dissolve sich jetzt aufgelöst hat...
                              • birdy
                                @Thomas-Braun
                                Scheint nicht so... 😞
                                pi@raspberrypi:/opt/iobroker $ npm i iobroker.zigbee@1.2.1
                                npm ERR! code ENOTSUP
                                npm ERR! notsup Unsupported engine for dissolve@0.3.3: wanted: {"node":"~0.10.0"} (current: {"node":"12.18.4","npm":"6.14.6"})
                                npm ERR! notsup Not compatible with your version of node/npm: dissolve@0.3.3
                                npm ERR! notsup Required: {"node":"~0.10.0"}
                                npm ERR! notsup Actual:   {"npm":"6.14.6","node":"12.18.4"}
                                npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T16_51_25_317Z-debug.log
                                  Thomas Braun Most Active @birdy last edited by Thomas Braun
                                  Unsupported engine for concentrate@0.2.3: wanted: "node":"~0.10.0"}
                                  Da hast du übrigens den nächsten alten Hund.
                                  Wer weiß was da noch alles nach oben gespült wird.
                                  Ich würde das Ding plattmachen und ein Backup des ioBrokers einspielen. Backitup hast du ja hoffentlich am Start?
                                  • birdy
                                    @Thomas-Braun
                                    Ja, Backup habe ich, Komplett und Standard... Ist eine Variante zu bevorzugen?
                                      @birdy
                                      Die Unterscheidung zwischen Komplett und Standard kenne ich nicht. Vermutlich eine alte Einstellung.
                                      Du kannst aber auch mal den hier probieren:
                                      iobroker stop
                                      curl -sL https://iobroker.net/fix.sh | bash -
                                      iobroker start
                                      npm i iobroker.zigbee@1.2.1 --force
                                      kannst du auch nochmal versuchen.
                                      • birdy
                                        @birdy
                                        iobroker stop
                                        iobroker start
                                        Nach dem Fix sieht es aber besser aus:
                                        pi@raspberrypi:~ $ npm i iobroker.zigbee@1.2.1                                  npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
                                        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                        npm WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                                        npm WARN pi No description
                                        npm WARN pi No repository field.
                                        npm WARN pi No README data
                                        npm WARN pi No license field.
                                        + iobroker.zigbee@1.2.1
                                        updated 1 package and audited 113 packages in 38.913s
                                        38 packages are looking for funding
                                          run `npm fund` for details
                                        found 4 high severity vulnerabilities
                                          run `npm audit fix` to fix them, or `npm audit` for details
                                          @birdy
                                          Das sieht doch gar nicht mal so schlecht aus.
                                          [Edit:] Im falschen Verzeichnis ausgeführt.
                                          Dann bleiben noch die anderen Baustellen wie 'canvas' z. B.
                                          • birdy
                                            @Thomas-Braun
                                            Zigbee Adapter bleibt aber trotzdem auf 0.10.2
                                            zigbee
                                            5875
