    4. Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
    UNSOLVED Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]
      Thomas Braun Most Active @birdy last edited by
      @birdy
      sudo apt update
      sagt jetzt, dass alle Pakete aktuell seien? Oder wird da noch was zurückgehalten?
      birdy 1 Reply Last reply Reply Quote 0
      • birdy
        birdy @Thomas Braun last edited by
        @Thomas-Braun said in Zigbee Instanz rot nach node.js Update auf v12.18.4:
        @birdy
        sudo apt update
        pi@raspberrypi:~ $ sudo apt update
        OK:1 http://archive.raspberrypi.org/debian stretch InRelease
        OK:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
        OK:3 https://deb.nodesource.com/node_12.x stretch InRelease
        Alle Pakete sind aktuell.
          Thomas Braun Most Active @birdy last edited by Thomas Braun
          @birdy
          Gut, passt.
          Jetzt müssen wir nochmal nach 'canvas' schauen.
          cd /opt/iobroker
          npm i canvas
          • birdy
            @birdy
            Gut, passt.
            cd /opt/iobroker
            npm i canvas
            Da scheint noch was im Argen zu sein...
            pi@raspberrypi:~ $ cd /opt/iobroker
            pi@raspberrypi:/opt/iobroker $ npm i canvas
            > canvas@2.6.1 install /opt/iobroker/node_modules/canvas
            > node-pre-gyp install --fallback-to-build
            node-pre-gyp WARN Using request for node-pre-gyp https download
            node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
            node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.18.4 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
            make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
              SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
              COPY Release/canvas-postbuild.node
              CXX(target) Release/obj.target/canvas/src/backend/Backend.o
              CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
              CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
            In file included from ../src/backend/PdfBackend.h:4:0,
                             from ../src/backend/PdfBackend.cc:1:
            ../src/backend/../closure.h:6:21: fatal error: jpeglib.h: Datei oder Verzeichnis nicht gefunden
             #include <jpeglib.h>
            compilation terminated.
            canvas.target.mk:142: die Regel für Ziel „Release/obj.target/canvas/src/backend/PdfBackend.o“ scheiterte
            make: *** [Release/obj.target/canvas/src/backend/PdfBackend.o] Fehler 1
            make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
            gyp ERR! build error
            gyp ERR! stack Error: `make` failed with exit code: 2
            gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
            gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
            gyp ERR! System Linux 4.19.66-v7+
            gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
            gyp ERR! cwd /opt/iobroker/node_modules/canvas
            gyp ERR! node -v v12.18.4
            gyp ERR! node-gyp -v v5.1.0
            gyp ERR! not ok
            node-pre-gyp ERR! build error
            node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
            node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
            node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
            node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
            node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
            node-pre-gyp ERR! System Linux 4.19.66-v7+
            node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
            node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
            node-pre-gyp ERR! node -v v12.18.4
            node-pre-gyp ERR! node-pre-gyp -v v0.11.0
            node-pre-gyp ERR! not ok
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the canvas@2.6.1 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            npm ERR!     /home/iobroker/.npm/_logs/2020-09-20T19_00_07_883Z-debug.log
              @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4:
              jpeglib.h
              apt policy libgdcm2-dev
              • birdy
                jpeglib.h
                pi@raspberrypi:/opt/iobroker $ apt policy libgdcm2-dev
                libgdcm2-dev:
                  Installiert:           2.6.6-3
                  Installationskandidat: 2.6.6-3
                  Versionstabelle:
                 *** 2.6.6-3 500
                        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                        100 /var/lib/dpkg/status
                  @birdy
                  sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                  • birdy
                    @birdy
                    pi@raspberrypi:/opt/iobroker $ sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                    build-essential ist schon die neueste Version (12.3).
                    libpango1.0-dev ist schon die neueste Version (1.40.5-1).
                    libcairo2-dev ist schon die neueste Version (1.14.8-1+rpi1).
                    Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                      coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15 realpath
                    Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                    Vorgeschlagene Pakete:
                      librsvg2-doc
                    Die folgenden NEUEN Pakete werden installiert:
                      gir1.2-rsvg-2.0 libgdk-pixbuf2.0-dev libgif-dev libjpeg-dev
                      libjpeg62-turbo-dev librsvg2-dev
                    0 aktualisiert, 6 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                    Es müssen 447 kB an Archiven heruntergeladen werden.
                    Nach dieser Operation werden 1.409 kB Plattenplatz zusätzlich benutzt.
                    Holen:1 http://mirror.inode.at/raspbian/raspbian stretch/main armhf gir1.2-rsvg-2.0 armhf 2.40.21-0+deb9u1 [15,3 kB]
                    Holen:2 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libgdk-pixbuf2.0-dev armhf 2.36.5-2+deb9u2 [53,8 kB]
                    Holen:3 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libgif-dev armhf 5.1.4-0.4 [43,0 kB]
                    Holen:4 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libjpeg62-turbo-dev armhf 1:1.5.1-2+deb9u1 [179 kB]
                    Holen:5 http://mirror.inode.at/raspbian/raspbian stretch/main armhf libjpeg-dev all 1:1.5.1-2+deb9u1 [56,5 kB]
                    Holen:6 http://mirror.inode.at/raspbian/raspbian stretch/main armhf librsvg2-dev armhf 2.40.21-0+deb9u1 [99,4 kB]
                    Es wurden 447 kB in 1 s geholt (338 kB/s).
                    Vormals nicht ausgewähltes Paket gir1.2-rsvg-2.0:armhf wird gewählt.
                    (Lese Datenbank ... 133212 Dateien und Verzeichnisse sind derzeit installiert.)
                    Vorbereitung zum Entpacken von .../0-gir1.2-rsvg-2.0_2.40.21-0+deb9u1_armhf.deb ...
                    Entpacken von gir1.2-rsvg-2.0:armhf (2.40.21-0+deb9u1) ...
                    Vormals nicht ausgewähltes Paket libgdk-pixbuf2.0-dev wird gewählt.
                    Vorbereitung zum Entpacken von .../1-libgdk-pixbuf2.0-dev_2.36.5-2+deb9u2_armhf.deb ...
                    Entpacken von libgdk-pixbuf2.0-dev (2.36.5-2+deb9u2) ...
                    Vormals nicht ausgewähltes Paket libgif-dev wird gewählt.
                    Vorbereitung zum Entpacken von .../2-libgif-dev_5.1.4-0.4_armhf.deb ...
                    Entpacken von libgif-dev (5.1.4-0.4) ...
                    Vormals nicht ausgewähltes Paket libjpeg62-turbo-dev:armhf wird gewählt.
                    Vorbereitung zum Entpacken von .../3-libjpeg62-turbo-dev_1%3a1.5.1-2+deb9u1_armhf.deb ...
                    Entpacken von libjpeg62-turbo-dev:armhf (1:1.5.1-2+deb9u1) ...
                    Vormals nicht ausgewähltes Paket libjpeg-dev wird gewählt.
                    Vorbereitung zum Entpacken von .../4-libjpeg-dev_1%3a1.5.1-2+deb9u1_all.deb ...
                    Entpacken von libjpeg-dev (1:1.5.1-2+deb9u1) ...
                    Vormals nicht ausgewähltes Paket librsvg2-dev:armhf wird gewählt.
                    Vorbereitung zum Entpacken von .../5-librsvg2-dev_2.40.21-0+deb9u1_armhf.deb ...
                    Entpacken von librsvg2-dev:armhf (2.40.21-0+deb9u1) ...
                    libgif-dev (5.1.4-0.4) wird eingerichtet ...
                    libgdk-pixbuf2.0-dev (2.36.5-2+deb9u2) wird eingerichtet ...
                    gir1.2-rsvg-2.0:armhf (2.40.21-0+deb9u1) wird eingerichtet ...
                    Trigger für man-db (2.7.6.1-2) werden verarbeitet ...
                    libjpeg62-turbo-dev:armhf (1:1.5.1-2+deb9u1) wird eingerichtet ...
                    librsvg2-dev:armhf (2.40.21-0+deb9u1) wird eingerichtet ...
                    libjpeg-dev (1:1.5.1-2+deb9u1) wird eingerichtet ...
                      @birdy
                      Dann schau nochmal, ob canvas nun baut:
                      cd /opt/iobroker
                      npm i canvas
                        @birdy
                        sudo apt autoremove
                        haut die Meldungen über die nicht mehr benötigten Pakete weg.
                        birdy 2 Replies Last reply Reply Quote 0
                        • birdy
                          @birdy
                          sudo apt autoremove
                          Schaut gut aus...
                            CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
                            CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
                          ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
                          ../src/bmp/BMPParser.cc:189:16: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                             E(ptr - data > imgdOffset, "image data overlaps with another structure");
                          ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
                           #define E(cond, msg) if(cond) return setErr(msg)
                          ../src/bmp/BMPParser.cc:204:27: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                             E(ptr - data + imgdSize > len, "not enough image data");
                            CXX(target) Release/obj.target/canvas/src/Backends.o
                            CXX(target) Release/obj.target/canvas/src/Canvas.o
                          ../src/Canvas.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE Canvas::ToBuffer(Nan::NAN_METHOD_ARGS_TYPE)’:
                          ../src/Canvas.cc:415:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
                               if (canvas->nBytes() > node::Buffer::kMaxLength) {
                            CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
                            CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
                            CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                            CXX(target) Release/obj.target/canvas/src/closure.o
                            CXX(target) Release/obj.target/canvas/src/color.o
                            CXX(target) Release/obj.target/canvas/src/Image.o
                            CXX(target) Release/obj.target/canvas/src/ImageData.o
                            CXX(target) Release/obj.target/canvas/src/init.o
                            CXX(target) Release/obj.target/canvas/src/register_font.o
                            SOLINK_MODULE(target) Release/obj.target/canvas.node
                            COPY Release/canvas.node
                          + canvas@2.6.1
                          added 6 packages from 15 contributors in 176.083s
                          20 packages are looking for funding
                            run `npm fund` for details
                          • birdy
                            @birdy
                            sudo apt autoremove
                            pi@raspberrypi:/opt/iobroker $ sudo apt autoremove
                            Die folgenden Pakete werden ENTFERNT:
                            0 aktualisiert, 0 neu installiert, 4 zu entfernen und 0 nicht aktualisiert.
                            Nach dieser Operation werden 9.219 kB Plattenplatz freigegeben.
                            Möchten Sie fortfahren? [J/n] J
                            (Lese Datenbank ... 133294 Dateien und Verzeichnisse sind derzeit installiert.)
                            Entfernen von coinor-libipopt1v5 (3.11.9-2.1) ...
                            Entfernen von libmumps-seq-4.10.0 (4.10.0.dfsg-4+b1) ...
                            Entfernen von libraw15:armhf (0.17.2-6+deb9u1) ...
                            Entfernen von realpath (8.26-3) ...
                            Trigger für libc-bin (2.24-11+deb9u4) werden verarbeitet ...
                              @birdy
                              Dann müsste dein System jetzt sauber sein.
                              iobroker update
                              iobroker upgrade
                              meckert jetzt nix mehr an?
                              • birdy
                                @birdy
                                iobroker update
                                iobroker upgrade
                                pi@raspberrypi:/opt/iobroker $ iobroker update
                                Used repository: default
                                hash unchanged, use cached sources
                                update done
                                Adapter    "admin"         : 4.0.10   , installed 4.0.10
                                Adapter    "alarm"         : 1.2.3
                                Adapter    "alexa2"        : 3.3.1    , installed 3.3.1
                                Adapter    "alpha2"        : 1.0.0
                                Adapter    "amazon-dash"   : 1.1.0
                                Adapter    "artnet"        : 1.2.2
                                Adapter    "asterisk"      : 1.0.6
                                Adapter    "asuswrt"       : 1.0.1
                                Adapter    "b-control-em"  : 0.2.1
                                Adapter    "backitup"      : 1.6.7    , installed 1.6.7
                                Adapter    "beckhoff"      : 1.2.2
                                Adapter    "benq"          : 0.2.0
                                Adapter    "binance"       : 1.1.3
                                Adapter    "ble"           : 0.11.8
                                Adapter    "bmw"           : 1.3.3
                                Adapter    "bosesoundtouch": 0.2.4
                                Adapter    "botvac"        : 1.0.0
                                Adapter    "bring"         : 1.7.2
                                Adapter    "broadlink2"    : 2.0.3    , installed 2.0.3
                                Adapter    "bsblan"        : 0.1.5
                                Adapter    "bshb"          : 0.1.10
                                Adapter    "chromecast"    : 2.3.1
                                Adapter    "cloud"         : 3.0.4    , installed 3.0.4
                                Adapter    "comfoair"      : 0.3.2
                                Adapter    "contactid"     : 1.0.1
                                Adapter    "coronavirus-statistics": 0.6.0
                                Adapter    "countdown"     : 1.1.0
                                Adapter    "cul"           : 1.2.1
                                Adapter    "daikin"        : 1.0.5
                                Adapter    "daswetter"     : 3.0.1    , installed 3.0.1
                                Adapter    "deconz"        : 1.3.10
                                Adapter    "denon"         : 1.7.7
                                Adapter    "devices"       : 0.3.6
                                Adapter    "digitalstrom"  : 0.5.5
                                Adapter    "discovergy"    : 0.5.0
                                Adapter    "discovery"     : 2.3.7    , installed 2.3.7
                                Adapter    "doorio"        : 1.0.10
                                Adapter    "ds18b20"       : 1.1.4
                                Adapter    "dwd"           : 2.4.10
                                Adapter    "ebus"          : 2.1.1
                                Adapter    "ecovacs-deebot": 1.0.3
                                Adapter    "egigeozone"    : 0.1.2
                                Adapter    "ekey"          : 1.1.0
                                Adapter    "email"         : 1.0.7
                                Adapter    "emby"          : 1.0.2
                                Adapter    "energymanager" : 1.2.3
                                Adapter    "enet"          : 1.0.1
                                Adapter    "epson_stylus_px830": 0.2.1
                                Adapter    "exchangerates" : 0.0.13
                                Adapter    "fakeroku"      : 0.2.1
                                Adapter    "fb-checkpresence": 1.0.4
                                Adapter    "feiertage"     : 1.0.17
                                Adapter    "fhem"          : 1.5.3
                                Adapter    "find-my-iphone": 0.2.15
                                Adapter    "firetv"        : 0.0.27
                                Adapter    "flot"          : 1.9.2    , installed 1.9.2
                                Adapter    "foobar2000"    : 2.0.3
                                Adapter    "fritzbox"      : 0.2.1
                                Adapter    "fritzdect"     : 0.2.4
                                Adapter    "fronius"       : 1.0.5
                                Adapter    "fullcalendar"  : 1.1.0
                                Adapter    "fullybrowser"  : 2.0.1
                                Adapter    "g-homa"        : 0.5.3
                                Adapter    "geofency"      : 0.3.2
                                Adapter    "gruenbeck"     : 0.0.18
                                Adapter    "habpanel"      : 0.4.3
                                Adapter    "haier"         : 1.0.2
                                Adapter    "ham"           : 1.1.2
                                Adapter    "ham-wemo"      : 1.0.1
                                Adapter    "harmony"       : 1.2.2
                                Adapter    "heatingcontrol": 0.5.7
                                Adapter    "heytech"       : 0.2.0
                                Adapter    "hid"           : 0.1.17
                                Adapter    "history"       : 1.9.10   , installed 1.9.10
                                Adapter    "hm-rega"       : 2.6.14
                                Adapter    "hm-rpc"        : 1.14.15
                                Adapter    "hmip"          : 1.2.2
                                Adapter    "homeconnect"   : 0.0.30
                                Adapter    "homee"         : 1.0.7
                                Adapter    "homepilot"     : 1.0.3
                                Adapter    "hp-ilo"        : 1.0.6
                                Adapter    "hs100"         : 2.0.1
                                Adapter    "hue"           : 3.3.5
                                Adapter    "hue-extended"  : 2.0.0
                                Adapter    "ical"          : 1.7.4
                                Adapter    "icons-addictive-flavour-png": 0.1.0
                                Adapter    "icons-fatcow-hosting": 0.1.0
                                Adapter    "icons-icons8"  : 0.0.1
                                Adapter    "icons-material-png": 0.1.0
                                Adapter    "icons-material-svg": 0.1.0
                                Adapter    "icons-mfd-png" : 1.0.2
                                Adapter    "icons-mfd-svg" : 1.0.2
                                Adapter    "icons-open-icon-library-png": 0.1.2
                                Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
                                Adapter    "influxdb"      : 1.9.1
                                Adapter    "info"          : 1.7.2    , installed 1.7.2
                                Adapter    "innogy-smarthome": 0.3.6
                                Adapter    "iogo"          : 0.5.10
                                Adapter    "iot"           : 1.5.3    , installed 1.5.3
                                Adapter    "iqontrol"      : 1.2.4
                                Adapter    "javascript"    : 4.6.17   , installed 4.6.17
                                Adapter    "jeelink"       : 0.1.0
                                Controller "js-controller" : 3.1.6    , installed 3.1.6
                                Adapter    "kecontact"     : 0.1.0
                                Adapter    "klf200"        : 1.0.1
                                Adapter    "km200"         : 1.1.6
                                Adapter    "knmi-weather"  : 1.0.0
                                Adapter    "knx"           : 1.0.39
                                Adapter    "kodi"          : 2.0.4
                                Adapter    "kress"         : 2.5.5
                                Adapter    "lametric"      : 0.0.9
                                Adapter    "landroid"      : 1.0.3
                                Adapter    "lcn"           : 0.3.2
                                Adapter    "letrika_comgw" : 0.0.5
                                Adapter    "lgtv"          : 1.1.10
                                Adapter    "lgtv-rs"       : 0.1.0
                                Adapter    "lgtv11"        : 1.0.5
                                Adapter    "lifx"          : 0.1.0
                                Adapter    "lightify"      : 0.2.16
                                Adapter    "link"          : 0.5.9
                                Adapter    "linkeddevices" : 1.2.2
                                Adapter    "logparser"     : 1.0.4
                                Adapter    "lovelace"      : 1.0.16
                                Adapter    "loxone"        : 1.1.0
                                Adapter    "luftdaten"     : 0.0.17
                                Adapter    "lupusec"       : 1.2.6
                                Adapter    "luxtronik1"    : 0.2.2
                                Adapter    "material"      : 0.13.9
                                Adapter    "maxcube"       : 0.1.2
                                Adapter    "maxcul"        : 1.3.0
                                Adapter    "mbus"          : 2.2.2
                                Adapter    "mclighting"    : 0.1.1
                                Adapter    "megad"         : 1.2.1
                                Adapter    "megadd"        : 0.2.0
                                Adapter    "megaesp"       : 0.1.0
                                Adapter    "melcloud"      : 1.0.6
                                Adapter    "mercedesme"    : 0.0.21
                                Adapter    "mercury"       : 0.1.1
                                Adapter    "meross"        : 1.5.0
                                Adapter    "meteoalarm"    : 1.0.9
                                Adapter    "midea"         : 0.0.6
                                Adapter    "miele"         : 0.1.5
                                Adapter    "mielecloudservice": 2.0.0
                                Adapter    "mihome"        : 1.3.0
                                Adapter    "mihome-lamp"   : 1.1.0
                                Adapter    "mihome-plug"   : 0.2.0
                                Adapter    "mihome-vacuum" : 2.0.7
                                Adapter    "mikrotik"      : 1.0.11
                                Adapter    "milight"       : 0.3.6
                                Adapter    "milight-smart-light": 0.2.7
                                Adapter    "mobile"        : 1.0.1
                                Adapter    "modbus"        : 3.1.6
                                Adapter    "moma"          : 1.2.6
                                Adapter    "mpd"           : 1.0.5
                                Adapter    "mqtt"          : 2.1.4    , installed 2.1.4
                                Adapter    "mqtt-client"   : 1.3.1
                                Adapter    "musiccast"     : 0.1.3
                                Adapter    "mysensors"     : 2.0.1
                                Adapter    "nanoleaf-lightpanels": 0.8.1
                                Adapter    "nello"         : 2.0.6
                                Adapter    "netatmo"       : 1.3.1
                                Adapter    "nibeuplink"    : 0.3.0
                                Adapter    "nina"          : 0.0.22
                                Adapter    "node-red"      : 1.17.2
                                Adapter    "nuki"          : 1.3.1
                                Adapter    "nuki-extended" : 2.3.0
                                Adapter    "nut"           : 1.1.3
                                Adapter    "odl"           : 1.0.5
                                Adapter    "oilfox"        : 0.0.5
                                Adapter    "onkyo"         : 2.0.3
                                Adapter    "onvif"         : 0.4.4
                                Adapter    "openhab"       : 1.1.0
                                Adapter    "openligadb"    : 1.1.0
                                Adapter    "openweathermap": 0.1.0
                                Adapter    "opi"           : 0.1.1
                                Adapter    "oppoplayer"    : 0.2.1
                                Adapter    "owfs"          : 0.6.4
                                Adapter    "owntracks"     : 0.6.3
                                Adapter    "panasonic-viera": 1.0.2
                                Adapter    "parser"        : 1.0.7    , installed 1.0.7
                                Adapter    "paw"           : 0.0.7
                                Adapter    "phantomjs"     : 1.0.1
                                Adapter    "pi-hole"       : 1.3.1
                                Adapter    "piface"        : 1.0.0
                                Adapter    "pimatic"       : 0.3.0
                                Adapter    "ping"          : 1.4.8    , installed 1.4.8
                                Adapter    "places"        : 1.0.0
                                Adapter    "plex"          : 0.8.11
                                Adapter    "plexconnect"   : 0.0.7
                                Adapter    "pollenflug"    : 1.0.6
                                Adapter    "proxmox"       : 1.0.1
                                Adapter    "proxy"         : 1.1.1
                                Adapter    "pushbullet"    : 0.0.11
                                Adapter    "pushover"      : 2.0.2
                                Adapter    "pushsafer"     : 0.1.8
                                Adapter    "radar2"        : 1.0.9
                                Adapter    "radiohead"     : 1.0.7
                                Adapter    "rflink"        : 2.0.0
                                Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
                                Adapter    "ring"          : 1.1.3
                                Adapter    "robonect"      : 0.1.3
                                Adapter    "roomba"        : 1.1.1
                                Adapter    "rpi2"          : 1.2.0
                                Adapter    "s7"            : 1.1.8
                                Adapter    "samsung"       : 0.2.9
                                Adapter    "sayit"         : 1.9.8
                                Adapter    "sbfspot"       : 4.0.0
                                Adapter    "scenes"        : 1.1.0    , installed 1.1.0
                                Adapter    "schoolfree"    : 0.6.3
                                Adapter    "shelly"        : 4.0.2
                                Adapter    "shuttercontrol": 0.8.6
                                Adapter    "sia"           : 1.0.4
                                Adapter    "siegenia"      : 1.0.0
                                Adapter    "simple-api"    : 2.4.6    , installed 2.4.6
                                Adapter    "smappee"       : 0.2.2
                                Adapter    "smartgarden"   : 1.0.1
                                Adapter    "smartmeter"    : 3.1.2
                                Adapter    "snips"         : 1.5.1
                                Adapter    "snmp"          : 0.5.0
                                Adapter    "socketio"      : 3.0.13   , installed 3.0.13
                                Adapter    "solarlog"      : 2.0.0
                                Adapter    "solarviewdatareader": 0.2.1
                                Adapter    "solarwetter"   : 1.0.0
                                Adapter    "sonnen"        : 1.6.0
                                Adapter    "sonoff"        : 2.3.3    , installed 2.3.3
                                Adapter    "sonos"         : 2.1.0
                                Adapter    "sony-bravia"   : 1.0.1
                                Adapter    "spotify-premium": 1.0.0
                                Adapter    "sql"           : 1.15.2   , installed 1.15.2
                                Adapter    "squeezebox"    : 1.0.0
                                Adapter    "squeezeboxrpc" : 1.0.0
                                Adapter    "starline"      : 1.0.0
                                Adapter    "statistics"    : 0.2.2
                                Adapter    "stiebel-isg"   : 1.5.1
                                Adapter    "sunnyportal"   : 0.1.5
                                Adapter    "swiss-weather-api": 0.3.2
                                Adapter    "synology"      : 0.1.18
                                Adapter    "systeminfo"    : 0.3.1
                                Adapter    "tahoma"        : 0.3.2
                                Adapter    "tankerkoenig"  : 2.0.5
                                Adapter    "telegram"      : 1.5.9    , installed 1.5.9
                                Adapter    "terminal"      : 0.1.2    , installed 0.1.2
                                Adapter    "tesla-motors"  : 0.2.3
                                Adapter    "text2command"  : 1.3.0    , installed 1.3.0
                                Adapter    "tinker"        : 1.1.0
                                Adapter    "tr-064"        : 4.0.9
                                Adapter    "tradfri"       : 2.6.3
                                Adapter    "trashschedule" : 0.0.11
                                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                Adapter    "tuya"          : 3.3.12
                                Adapter    "tvspielfilm"   : 1.0.4
                                Adapter    "unifi"         : 0.5.8
                                Adapter    "upnp"          : 1.0.16
                                Adapter    "vaillant"      : 0.0.10
                                Adapter    "valloxmv"      : 1.1.1
                                Adapter    "vcard"         : 0.0.9
                                Adapter    "velux"         : 0.0.5
                                Adapter    "viessmann"     : 1.3.0
                                Adapter    "virtualpowermeter": 1.2.1
                                Adapter    "vis"           : 1.2.12   , installed 1.2.12
                                Adapter    "vis-bars"      : 0.1.4
                                Adapter    "vis-canvas-gauges": 0.1.5
                                Adapter    "vis-colorpicker": 1.1.1
                                Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
                                Adapter    "vis-google-fonts": 0.1.0
                                Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
                                Adapter    "vis-hqwidgets" : 1.1.4    , installed 1.1.4
                                Adapter    "vis-icontwo"   : 0.19.0
                                Adapter    "vis-inventwo"  : 1.3.8
                                Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                                Adapter    "vis-justgage"  : 1.0.2
                                Adapter    "vis-keyboard"  : 0.0.2
                                Adapter    "vis-lcars"     : 1.0.4
                                Adapter    "vis-map"       : 1.0.4
                                Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
                                Adapter    "vis-players"   : 0.1.6
                                Adapter    "vis-plumb"     : 1.0.2
                                Adapter    "vis-rgraph"    : 0.0.2
                                Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                                Adapter    "vis-weather"   : 2.5.2    , installed 2.5.2
                                Adapter    "vr200"         : 1.0.0
                                Adapter    "vw-connect"    : 0.0.15
                                Adapter    "weatherunderground": 3.2.1   , installed 3.2.1
                                Adapter    "web"           : 3.0.12   , installed 3.0.12
                                Adapter    "weishaupt-wem" : 0.0.8
                                Adapter    "wiffi-wz"      : 2.2.0
                                Adapter    "wifilight"     : 1.1.0
                                Adapter    "windows-control": 0.1.5
                                Adapter    "wled"          : 0.5.2
                                Adapter    "wm-bus"        : 0.1.12
                                Adapter    "wolf"          : 0.9.2
                                Adapter    "worx"          : 1.2.3
                                Adapter    "xbox"          : 0.6.5
                                Adapter    "xs1"           : 1.0.2
                                Adapter    "yahka"         : 0.11.0
                                Adapter    "yamaha"        : 0.3.19
                                Adapter    "yeelight-2"    : 1.0.3
                                Adapter    "youtube"       : 0.0.11
                                Adapter    "yr"            : 2.0.3    , installed 2.0.3
                                Adapter    "zigbee"        : 1.2.1    , installed 1.2.1
                                Adapter    "zont"          : 0.5.3
                                Adapter    "zwave"         : 2.0.1
                                Adapter    "zwave2"        : 1.5.0
                                pi@raspberrypi:/opt/iobroker $ iobroker upgrade
                                Adapter "admin"          is up to date.
                                Adapter "alarm"          is not installed.
                                Adapter "alexa2"         is up to date.
                                Adapter "alpha2"         is not installed.
                                Adapter "amazon-dash"    is not installed.
                                Adapter "artnet"         is not installed.
                                Adapter "asterisk"       is not installed.
                                Adapter "asuswrt"        is not installed.
                                Adapter "b-control-em"   is not installed.
                                Adapter "backitup"       is up to date.
                                Adapter "beckhoff"       is not installed.
                                Adapter "benq"           is not installed.
                                Adapter "binance"        is not installed.
                                Adapter "ble"            is not installed.
                                Adapter "bmw"            is not installed.
                                Adapter "bosesoundtouch" is not installed.
                                Adapter "botvac"         is not installed.
                                Adapter "bring"          is not installed.
                                Adapter "broadlink2"     is up to date.
                                Adapter "bsblan"         is not installed.
                                Adapter "bshb"           is not installed.
                                Adapter "chromecast"     is not installed.
                                Adapter "cloud"          is up to date.
                                Adapter "comfoair"       is not installed.
                                Adapter "contactid"      is not installed.
                                Adapter "coronavirus-statistics" is not installed.
                                Adapter "countdown"      is not installed.
                                Adapter "cul"            is not installed.
                                Adapter "daikin"         is not installed.
                                Adapter "daswetter"      is up to date.
                                Adapter "deconz"         is not installed.
                                Adapter "denon"          is not installed.
                                Adapter "devices"        is not installed.
                                Adapter "digitalstrom"   is not installed.
                                Adapter "discovergy"     is not installed.
                                Adapter "discovery"      is up to date.
                                Adapter "doorio"         is not installed.
                                Adapter "ds18b20"        is not installed.
                                Adapter "dwd"            is not installed.
                                Adapter "ebus"           is not installed.
                                Adapter "ecovacs-deebot" is not installed.
                                Adapter "egigeozone"     is not installed.
                                Adapter "ekey"           is not installed.
                                Adapter "email"          is not installed.
                                Adapter "emby"           is not installed.
                                Adapter "energymanager"  is not installed.
                                Adapter "enet"           is not installed.
                                Adapter "epson_stylus_px830" is not installed.
                                Adapter "exchangerates"  is not installed.
                                Adapter "fakeroku"       is not installed.
                                Adapter "fb-checkpresence" is not installed.
                                Adapter "feiertage"      is not installed.
                                Adapter "fhem"           is not installed.
                                Adapter "find-my-iphone" is not installed.
                                Adapter "firetv"         is not installed.
                                Adapter "flot"           is up to date.
                                Adapter "foobar2000"     is not installed.
                                Adapter "fritzbox"       is not installed.
                                Adapter "fritzdect"      is not installed.
                                Adapter "fronius"        is not installed.
                                Adapter "fullcalendar"   is not installed.
                                Adapter "fullybrowser"   is not installed.
                                Adapter "g-homa"         is not installed.
                                Adapter "geofency"       is not installed.
                                Adapter "gruenbeck"      is not installed.
                                Adapter "habpanel"       is not installed.
                                Adapter "haier"          is not installed.
                                Adapter "ham"            is not installed.
                                Adapter "ham-wemo"       is not installed.
                                Adapter "harmony"        is not installed.
                                Adapter "heatingcontrol" is not installed.
                                Adapter "heytech"        is not installed.
                                Adapter "hid"            is not installed.
                                Adapter "history"        is up to date.
                                Adapter "hm-rega"        is not installed.
                                Adapter "hm-rpc"         is not installed.
                                Adapter "hmip"           is not installed.
                                Adapter "homeconnect"    is not installed.
                                Adapter "homee"          is not installed.
                                Adapter "homepilot"      is not installed.
                                Adapter "hp-ilo"         is not installed.
                                Adapter "hs100"          is not installed.
                                Adapter "hue"            is not installed.
                                Adapter "hue-extended"   is not installed.
                                Adapter "ical"           is not installed.
                                Adapter "icons-addictive-flavour-png" is not installed.
                                Adapter "icons-fatcow-hosting" is not installed.
                                Adapter "icons-icons8"   is not installed.
                                Adapter "icons-material-png" is not installed.
                                Adapter "icons-material-svg" is not installed.
                                Adapter "icons-mfd-png"  is not installed.
                                Adapter "icons-mfd-svg"  is not installed.
                                Adapter "icons-open-icon-library-png" is not installed.
                                Adapter "icons-ultimate-png" is up to date.
                                Adapter "influxdb"       is not installed.
                                Adapter "info"           is up to date.
                                Adapter "innogy-smarthome" is not installed.
                                Adapter "iogo"           is not installed.
                                Adapter "iot"            is up to date.
                                Adapter "iqontrol"       is not installed.
                                Adapter "javascript"     is up to date.
                                Adapter "jeelink"        is not installed.
                                Adapter "kecontact"      is not installed.
                                Adapter "klf200"         is not installed.
                                Adapter "km200"          is not installed.
                                Adapter "knmi-weather"   is not installed.
                                Adapter "knx"            is not installed.
                                Adapter "kodi"           is not installed.
                                Adapter "kress"          is not installed.
                                Adapter "lametric"       is not installed.
                                Adapter "landroid"       is not installed.
                                Adapter "lcn"            is not installed.
                                Adapter "letrika_comgw"  is not installed.
                                Adapter "lgtv"           is not installed.
                                Adapter "lgtv-rs"        is not installed.
                                Adapter "lgtv11"         is not installed.
                                Adapter "lifx"           is not installed.
                                Adapter "lightify"       is not installed.
                                Adapter "link"           is not installed.
                                Adapter "linkeddevices"  is not installed.
                                Adapter "logparser"      is not installed.
                                Adapter "lovelace"       is not installed.
                                Adapter "loxone"         is not installed.
                                Adapter "luftdaten"      is not installed.
                                Adapter "lupusec"        is not installed.
                                Adapter "luxtronik1"     is not installed.
                                Adapter "material"       is not installed.
                                Adapter "maxcube"        is not installed.
                                Adapter "maxcul"         is not installed.
                                Adapter "mbus"           is not installed.
                                Adapter "mclighting"     is not installed.
                                Adapter "megad"          is not installed.
                                Adapter "megadd"         is not installed.
                                Adapter "megaesp"        is not installed.
                                Adapter "melcloud"       is not installed.
                                Adapter "mercedesme"     is not installed.
                                Adapter "mercury"        is not installed.
                                Adapter "meross"         is not installed.
                                Adapter "meteoalarm"     is not installed.
                                Adapter "midea"          is not installed.
                                Adapter "miele"          is not installed.
                                Adapter "mielecloudservice" is not installed.
                                Adapter "mihome"         is not installed.
                                Adapter "mihome-lamp"    is not installed.
                                Adapter "mihome-plug"    is not installed.
                                Adapter "mihome-vacuum"  is not installed.
                                Adapter "mikrotik"       is not installed.
                                Adapter "milight"        is not installed.
                                Adapter "milight-smart-light" is not installed.
                                Adapter "mobile"         is not installed.
                                Adapter "modbus"         is not installed.
                                Adapter "moma"           is not installed.
                                Adapter "mpd"            is not installed.
                                Adapter "mqtt"           is up to date.
                                Adapter "mqtt-client"    is not installed.
                                Adapter "musiccast"      is not installed.
                                Adapter "mysensors"      is not installed.
                                Adapter "nanoleaf-lightpanels" is not installed.
                                Adapter "nello"          is not installed.
                                Adapter "netatmo"        is not installed.
                                Adapter "nibeuplink"     is not installed.
                                Adapter "nina"           is not installed.
                                Adapter "node-red"       is not installed.
                                Adapter "nuki"           is not installed.
                                Adapter "nuki-extended"  is not installed.
                                Adapter "nut"            is not installed.
                                Adapter "odl"            is not installed.
                                Adapter "oilfox"         is not installed.
                                Adapter "onkyo"          is not installed.
                                Adapter "onvif"          is not installed.
                                Adapter "openhab"        is not installed.
                                Adapter "openligadb"     is not installed.
                                Adapter "openweathermap" is not installed.
                                Adapter "opi"            is not installed.
                                Adapter "oppoplayer"     is not installed.
                                Adapter "owfs"           is not installed.
                                Adapter "owntracks"      is not installed.
                                Adapter "panasonic-viera" is not installed.
                                Adapter "parser"         is up to date.
                                Adapter "paw"            is not installed.
                                Adapter "phantomjs"      is not installed.
                                Adapter "pi-hole"        is not installed.
                                Adapter "piface"         is not installed.
                                Adapter "pimatic"        is not installed.
                                Adapter "ping"           is up to date.
                                Adapter "places"         is not installed.
                                Adapter "plex"           is not installed.
                                Adapter "plexconnect"    is not installed.
                                Adapter "pollenflug"     is not installed.
                                Adapter "proxmox"        is not installed.
                                Adapter "proxy"          is not installed.
                                Adapter "pushbullet"     is not installed.
                                Adapter "pushover"       is not installed.
                                Adapter "pushsafer"      is not installed.
                                Adapter "radar2"         is not installed.
                                Adapter "radiohead"      is not installed.
                                Adapter "rflink"         is not installed.
                                Adapter "rickshaw"       is up to date.
                                Adapter "ring"           is not installed.
                                Adapter "robonect"       is not installed.
                                Adapter "roomba"         is not installed.
                                Adapter "rpi2"           is not installed.
                                Adapter "s7"             is not installed.
                                Adapter "samsung"        is not installed.
                                Adapter "sayit"          is not installed.
                                Adapter "sbfspot"        is not installed.
                                Adapter "scenes"         is up to date.
                                Adapter "schoolfree"     is not installed.
                                Adapter "shelly"         is not installed.
                                Adapter "shuttercontrol" is not installed.
                                Adapter "sia"            is not installed.
                                Adapter "siegenia"       is not installed.
                                Adapter "simple-api"     is up to date.
                                Adapter "smappee"        is not installed.
                                Adapter "smartgarden"    is not installed.
                                Adapter "smartmeter"     is not installed.
                                Adapter "snips"          is not installed.
                                Adapter "snmp"           is not installed.
                                Adapter "socketio"       is up to date.
                                Adapter "solarlog"       is not installed.
                                Adapter "solarviewdatareader" is not installed.
                                Adapter "solarwetter"    is not installed.
                                Adapter "sonnen"         is not installed.
                                Adapter "sonoff"         is up to date.
                                Adapter "sonos"          is not installed.
                                Adapter "sony-bravia"    is not installed.
                                Adapter "spotify-premium" is not installed.
                                Adapter "sql"            is up to date.
                                Adapter "squeezebox"     is not installed.
                                Adapter "squeezeboxrpc"  is not installed.
                                Adapter "starline"       is not installed.
                                Adapter "statistics"     is not installed.
                                Adapter "stiebel-isg"    is not installed.
                                Adapter "sunnyportal"    is not installed.
                                Adapter "swiss-weather-api" is not installed.
                                Adapter "synology"       is not installed.
                                Adapter "systeminfo"     is not installed.
                                Adapter "tahoma"         is not installed.
                                Adapter "tankerkoenig"   is not installed.
                                Adapter "telegram"       is up to date.
                                Adapter "terminal"       is up to date.
                                Adapter "tesla-motors"   is not installed.
                                Adapter "text2command"   is up to date.
                                Adapter "tinker"         is not installed.
                                Adapter "tr-064"         is not installed.
                                Adapter "tradfri"        is not installed.
                                Adapter "trashschedule"  is not installed.
                                Adapter "tunnelbroker-endpoint-updater" is not installed.
                                Adapter "tuya"           is not installed.
                                Adapter "tvspielfilm"    is not installed.
                                Adapter "unifi"          is not installed.
                                Adapter "upnp"           is not installed.
                                Adapter "vaillant"       is not installed.
                                Adapter "valloxmv"       is not installed.
                                Adapter "vcard"          is not installed.
                                Adapter "velux"          is not installed.
                                Adapter "viessmann"      is not installed.
                                Adapter "virtualpowermeter" is not installed.
                                Adapter "vis"            is up to date.
                                Adapter "vis-bars"       is not installed.
                                Adapter "vis-canvas-gauges" is not installed.
                                Adapter "vis-colorpicker" is not installed.
                                Adapter "vis-fancyswitch" is up to date.
                                Adapter "vis-google-fonts" is not installed.
                                Adapter "vis-history"    is up to date.
                                Adapter "vis-hqwidgets"  is up to date.
                                Adapter "vis-icontwo"    is not installed.
                                Adapter "vis-inventwo"   is not installed.
                                Adapter "vis-jqui-mfd"   is up to date.
                                Adapter "vis-justgage"   is not installed.
                                Adapter "vis-keyboard"   is not installed.
                                Adapter "vis-lcars"      is not installed.
                                Adapter "vis-map"        is not installed.
                                Adapter "vis-metro"      is up to date.
                                Adapter "vis-players"    is not installed.
                                Adapter "vis-plumb"      is not installed.
                                Adapter "vis-rgraph"     is not installed.
                                Adapter "vis-timeandweather" is up to date.
                                Adapter "vis-weather"    is up to date.
                                Adapter "vr200"          is not installed.
                                Adapter "vw-connect"     is not installed.
                                Adapter "weatherunderground" is up to date.
                                Adapter "web"            is up to date.
                                Adapter "weishaupt-wem"  is not installed.
                                Adapter "wiffi-wz"       is not installed.
                                Adapter "wifilight"      is not installed.
                                Adapter "windows-control" is not installed.
                                Adapter "wled"           is not installed.
                                Adapter "wm-bus"         is not installed.
                                Adapter "wolf"           is not installed.
                                Adapter "worx"           is not installed.
                                Adapter "xbox"           is not installed.
                                Adapter "xs1"            is not installed.
                                Adapter "yahka"          is not installed.
                                Adapter "yamaha"         is not installed.
                                Adapter "yeelight-2"     is not installed.
                                Adapter "youtube"        is not installed.
                                Adapter "yr"             is up to date.
                                Adapter "zigbee"         is up to date.
                                Adapter "zont"           is not installed.
                                Adapter "zwave"          is not installed.
                                Adapter "zwave2"         is not installed.
                                Perfekt! 🙂
                                  @birdy
                                  Gut.
                                  Schau mal mit
                                  npm list canvas
                                  nach, ob das Modul auch drin ist.
                                  Und dann künftig etwas regelmäßiger updaten/upgraden, dann ist das auch wesentlich weniger komplex.
                                  • birdy
                                    npm list canvas
                                    pi@raspberrypi:/opt/iobroker $ npm list canvas
                                    iobroker.inst@1.0.8 /opt/iobroker
                                    ├── canvas@2.6.1
                                    └─┬ iobroker.iot@1.5.3
                                      └── canvas@2.6.1  deduped
                                    Danke, danke, danke und nochmal danke für deine Hilfe und die Zeit, die du investiert hast! Ich hätte das niemlas geschafft, nicht mal ansatzweise...
                                      @birdy
                                      Was mir gerade noch einfällt (Wegen der Pakete im autoremove)
                                      In welchem RunLevel läuft die Kiste eigentlich?
                                      who -r
                                      Wenn da runlevel 5 kommt (und die Kiste keinen Desktop benötigt, weil du da eh nur per SSH draufgehst), dann stell auf RL3 um.
                                      • birdy
                                        @Thomas-Braun
                                        Sorry, war gestern nicht mehr online und sitze jetzt im Büro...
                                        Werde am Abend den Runlevel kontrollieren, aber den Desktop möchte ich mir schon behalten, da ich manchmal über VNC auf den Raspi zugreife.
                                          @birdy sagte in Zigbee Instanz rot nach node.js Update auf v12.18.4 [Gelöst]:
                                          Rate ich von ab. Wie du gesehen hast administriert man das System über SSH / Kommandozeile. VNC ist unnötiger Overhead.
                                          • birdy
                                            Ja, ist schon klar. Aber ich habe ja nicht immer jemanden wie dich parat, der mich an der Hand zur Problemlösung führt... 😉 Und wenn ich mal kurz etwas nachsehen will (Dateimanager), ist VNC für mich dann angenehmer, als Kommandozeilenbefehle einzutippen.
                                            zigbee
                                            5875
