    • simatec
      simatec Developer Most Active @BoehserWolf last edited by
      @BoehserWolf
      Bitte poste mal den Debuglog von Backitup
        BoehserWolf @simatec last edited by
        @simatec Gerade manuell ausgeführt. Der Datenpunkt steht weiterhin auf false.
        backitup.0	2020-09-20 12:42:51.127	debug	(32749) system.adapter.admin.0: logging true
        backitup.0	2020-09-20 12:41:47.829	debug	(32749) system.adapter.admin.0: logging false
        backitup.0	2020-09-20 12:41:22.662	debug	(32749) system.adapter.admin.0: logging true
        backitup.0	2020-09-20 12:41:11.453	debug	(32749) [iobroker] exec: done
        backitup.0	2020-09-20 12:41:11.452	debug	(32749) [iobroker] exec: done
        backitup.0	2020-09-20 12:41:11.452	debug	(32749) [iobroker/history] backitup.0.history.json
        backitup.0	2020-09-20 12:41:11.452	debug	(32749) [iobroker/history] backitup.0.history.html
        backitup.0	2020-09-20 12:41:11.446	debug	(32749) [iobroker/clean] done
        backitup.0	2020-09-20 12:41:11.445	debug	(32749) [iobroker/iobroker] done
        backitup.0	2020-09-20 12:41:10.435	debug	(32749) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_20-12_41_07_iobroker_wald_backupiobroker.tar.gz
        backitup.0	2020-09-20 12:41:08.875	debug	(32749) system.adapter.admin.0: logging false
        backitup.0	2020-09-20 12:41:08.480	debug	(32749) [iobroker/iobroker] host.iobroker 5414 objects saved
        backitup.0	2020-09-20 12:41:08.471	debug	(32749) [iobroker/iobroker] host.iobroker 4997 states saved
        backitup.0	2020-09-20 12:41:07.300	debug	(32749) Backup has started ...
        backitup.0	2020-09-20 12:40:19.566	debug	(32749) No backup file was found
        backitup.0	2020-09-20 12:40:19.565	debug	(32749) [ccu] 10 30 01 */3 * *
        backitup.0	2020-09-20 12:40:19.564	info	(32749) [ccu] backup was activated at 01:30 every 3 day(s)
        backitup.0	2020-09-20 12:40:19.563	debug	(32749) [iobroker] 10 30 03 */1 * *
        backitup.0	2020-09-20 12:40:19.558	info	(32749) [iobroker] backup was activated at 03:30 every 1 day(s)
        backitup.0	2020-09-20 12:40:19.540	info	(32749) starting. Version 1.6.7 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.22.1, js-controller: 3.1.6
        backitup.0	2020-09-20 12:40:19.535	info	(32749) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        backitup.0	2020-09-20 12:40:19.533	debug	(32749) Plugin sentry Initialize Plugin (enabled=true)
        backitup.0	2020-09-20 12:40:19.275	debug	(32749) statesDB connected
        backitup.0	2020-09-20 12:40:19.275	debug	(32749) States connected to redis: 127.0.0.1:9000
        backitup.0	2020-09-20 12:40:19.273	debug	(32749) States create System PubSub Client
        backitup.0	2020-09-20 12:40:19.272	debug	(32749) States create User PubSub Client
        backitup.0	2020-09-20 12:40:19.270	debug	(32749) Redis States: Use Redis connection: 127.0.0.1:9000
        backitup.0	2020-09-20 12:40:19.269	debug	(32749) objectDB connected
        backitup.0	2020-09-20 12:40:19.267	debug	(32749) Objects connected to redis: 127.0.0.1:9001
        backitup.0	2020-09-20 12:40:19.263	debug	(32749) Objects client initialize lua scripts
        backitup.0	2020-09-20 12:40:19.263	debug	(32749) Objects create User PubSub Client
        backitup.0	2020-09-20 12:40:19.263	debug	(32749) Objects create System PubSub Client
        backitup.0	2020-09-20 12:40:19.261	debug	(32749) Objects client ready ... initialize now
        backitup.0	2020-09-20 12:40:19.249	debug	(32749) Redis Objects: Use Redis connection: 127.0.0.1:9001
          ltsalvatore last edited by
          hallo zusammen,
          kurze frage..
          mir wurde empfohlen, mein anliegen in diesem thread zu posten...
          ich bin aktuell auf der version 0.1.6 von dem whatsapp-cmb.0 adapter und wollte den adapter benutzen um mich benachrichtigen zu lassen, wenn backitup kein backup erstellen konnte.
          in dem whatsapp-cmb.0 habe ich soweit alles eingerichtet wie auf dem bild unten zu sehen incl. des api keys, welches ich per whatsapp bekommen hatte.
          in dem backitup.0 adapter habe ich soweit auch alles aktiviert
          doch leider kommt nichts bei mir an..mittlerweile sind schon ein paar stündchen vergangen...
          wenn ich eine test nachricht verschicke über
          https://api.callmebot.com/whatsapp.php?phone=[phone_number]&text=[message]&apikey=[your_apikey]
          funktioniert es einwandfrei...
          kann es sein, dass der backtitup adapter das noch nicht sauber integriert hat bzw. in der aktuellesten version 1.6.7 ein problem hat?
          • simatec
            simatec Developer Most Active @ltsalvatore last edited by
            @ltsalvatore sagte in Test Adapter Backitup v1.6.x:
            Da du in den Einstellungen das Häkchen "Benachrichtigung nur bei Fehlern" aktiv hast, kommt auch nur eine Meldung bei Fehlern.
              ltsalvatore @simatec last edited by ltsalvatore
              @simatec sagte in Test Adapter Backitup v1.6.x:
              hi simatec
              ich habe sowohl mit als auch ohne dieser option getestet.
              ich habe auch absichtlich ein fehler in den einstellungen gesetzt um entsprechend ein fehler zu simulieren.
              • simatec
                @ltsalvatore
                Dann teste, ob deine Einstellungen im Whatsapp Adapter korrekt sind und schicke dir Testnachrichten aus iobroker (Blockly oder Javascript)
                Backitup verwendet am Ende die gleichen Funktionen ...
                Ansonsten bitte debuglog schicken
                  @ltsalvatore
                  hi simatec,
                  über blockly und objekt "send message" funktioniert es einwandfrei.
                  ich habe dann diverse male getestet und es scheint wohl tatsächlich daran zu liegen, was man beim backitup adapter als benachrichtigungsstil auswählt.
                  wenn ich "kurze benachrichtigungen" wähle, dann kommen die messages sofort an.
                  wähle ich stattdessen "lange benachrichtigungen" kommt nichts an...
                  mir reicht im endeffekt die kurze benachrichtigung vollkommen aus... sollte sich doch jemand das ganze noch mal im detail anschauen wollen hier das log file:
                  whatsapp-cmb.0	2020-09-22 22:56:19.396	debug	(29603) system.adapter.admin.0: logging true
                  whatsapp-cmb.0	2020-09-22 22:53:27.906	debug	(29603) system.adapter.admin.0: logging false
                  whatsapp-cmb.0	2020-09-22 22:50:24.653	debug	(29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:50 Uhr erstellt.<p><b>Message queued.</b> You will receive it in a few sec
                  whatsapp-cmb.0	2020-09-22 22:50:24.388	debug	(29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A50%20Uhr%20erstellt.&apike
                  whatsapp-cmb.0	2020-09-22 22:50:24.388	info	Ein neues iobroker Backup wurde am 22. September 2020 um 22:50 Uhr erstellt. to +491799700000
                  whatsapp-cmb.0	2020-09-22 22:50:24.388	info	(29603) Send BackItUp:
                  whatsapp-cmb.0	2020-09-22 22:48:55.316	debug	(29603) system.adapter.admin.0: logging true
                  whatsapp-cmb.0	2020-09-22 22:48:41.649	debug	(29603) system.adapter.admin.0: logging false
                  whatsapp-cmb.0	2020-09-22 22:47:24.706	debug	(29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:47 Uhr erstellt, und unter //192.168.111.100/"prv\Salva\P1\Backups\Server\
                  whatsapp-cmb.0	2020-09-22 22:47:24.504	debug	(29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A47%20Uhr%20erstellt%2C%20u
                  whatsapp-cmb.0	2020-09-22 22:47:24.504	info	Ein neues iobroker Backup wurde am 22. September 2020 um 22:47 Uhr erstellt, und unter //192.168.111.100/"prv\Salva\P1\Backups\Server\Smarthome\iobroker\minimal" gespeichert. to +491799700000
                  whatsapp-cmb.0	2020-09-22 22:47:24.504	info	(29603) Send BackItUp:
                  whatsapp-cmb.0	2020-09-22 22:44:24.815	debug	(29603) <p>Message to: +491799700000<p>Text to send: BackItUp:%0AEin neues iobroker Backup wurde am 22. September 2020 um 22:44 Uhr erstellt.<p><b>Message queued.</b> You will receive it in a few sec
                  whatsapp-cmb.0	2020-09-22 22:44:24.502	debug	(29603) Call https://api.callmebot.com/whatsapp.php?phone=+491799700000&text=BackItUp%3A%0AEin%20neues%20iobroker%20Backup%20wurde%20am%2022.%20September%202020%20um%2022%3A44%20Uhr%20erstellt.&apike
                  whatsapp-cmb.0	2020-09-22 22:44:24.502	info	Ein neues iobroker Backup wurde am 22. September 2020 um 22:44 Uhr erstellt. to +491799700000
                  whatsapp-cmb.0	2020-09-22 22:44:24.502	info	(29603) Send BackItUp:
                  whatsapp-cmb.0	2020-09-22 22:43:17.411	info	(29603) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v10.21.0, js-controller: 3.1.6
                  whatsapp-cmb.0	2020-09-22 22:43:16.954	debug	(29603) statesDB connected
                  whatsapp-cmb.0	2020-09-22 22:43:16.954	debug	(29603) States connected to redis: 127.0.0.1:9000
                  whatsapp-cmb.0	2020-09-22 22:43:16.950	debug	(29603) States create System PubSub Client
                  whatsapp-cmb.0	2020-09-22 22:43:16.950	debug	(29603) States create User PubSub Client
                  whatsapp-cmb.0	2020-09-22 22:43:16.947	debug	(29603) Redis States: Use Redis connection: 127.0.0.1:9000
                  whatsapp-cmb.0	2020-09-22 22:43:16.946	debug	(29603) objectDB connected
                  whatsapp-cmb.0	2020-09-22 22:43:16.944	debug	(29603) Objects connected to redis: 127.0.0.1:9001
                  whatsapp-cmb.0	2020-09-22 22:43:16.939	debug	(29603) Objects client initialize lua scripts
                  whatsapp-cmb.0	2020-09-22 22:43:16.939	debug	(29603) Objects create User PubSub Client
                  whatsapp-cmb.0	2020-09-22 22:43:16.938	debug	(29603) Objects create System PubSub Client
                  whatsapp-cmb.0	2020-09-22 22:43:16.937	debug	(29603) Objects client ready ... initialize now
                  whatsapp-cmb.0	2020-09-22 22:43:16.921	debug	(29603) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  • simatec
                    @ltsalvatore
                    Schaue ich mir noch einmal an. Allerdings kann ich den Fehler nicht nachstellen, da auf meinem Dev-System "Lange Benachrichtigung" eingestellt ist und die Nachrichten sauber gesendet werden
                      Frank_y @BoehserWolf last edited by
                      @BoehserWolf sagte in Test Adapter Backitup v1.6.x:
                      @simatec Morgen, setzte backitup in v1.6.7 ein. Wurde heute morgen mit einer Fehlermeldung beim Backup in diesem Datenpunkt begrüßt:
                      backitup.0.history.iobrokerLastTime
                      Meldung:
                      error: 20. September 2020 um 03:30 Uhr
                      Wenn ich allerdings auf Filesystem Ebene nachsehe scheint alles ok:
                      ls -la
                      total 96200
                      drwxrwxrwx+ 2 iobroker iobroker    4096 Sep 20 03:30 .
                      drwxrwxrwx+ 8 iobroker iobroker    4096 Sep 19 10:05 ..
                      -rw-rw-rw-+ 1 iobroker iobroker 6842369 May  9 13:25 2020_05_09-13_25_34_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 8210513 Jun 10 18:53 2020_06_10-18_53_46_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 8298907 Jun 28 11:26 2020_06_28-11_26_20_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep  7 01:30 homematic_2020_09_07-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                      -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 10 01:30 homematic_2020_09_10-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                      -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 13 01:30 homematic_2020_09_13-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                      -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 16 01:30 homematic_2020_09_16-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                      -rw-rw-rw-+ 1 iobroker iobroker 6645760 Sep 19 01:30 homematic_2020_09_19-01_30_22_3.51.6.20200229_backupiobroker.tar.sbk
                      -rw-rw-rw-+ 1 iobroker iobroker 8345290 Sep 16 03:30 iobroker_2020_09_16-03_30_10_iobroker_wald_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 8345873 Sep 17 03:30 iobroker_2020_09_17-03_30_10_iobroker_wald_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 8345298 Sep 18 03:30 iobroker_2020_09_18-03_30_10_iobroker_wald_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 8449703 Sep 19 03:30 iobroker_2020_09_19-03_30_10_iobroker_wald_backupiobroker.tar.gz
                      -rw-rw-rw-+ 1 iobroker iobroker 8401710 Sep 20 03:30 iobroker_2020_09_20-03_30_10_iobroker_wald_backupiobroker.tar.gz
                      Das Archiv iobroker_2020_09_20-03_30_10_iobroker_wald_backupiobroker.tar.gz lässt sich entpacken und ist damit wohl i.O.
                      Eine Idee dazu?
                      Bei mir auch selber Effekt mit v1.6.7:
                      backitup.0.history.iobrokerLastTime "error: 23. September 2020 um 02:03 Uhr"
                      backitup.0.history.iobrokerSuccess "false"
                      json: [{"date":"23. September 2020 um 02:03 Uhr","name":"iobroker_2020_09_23-02_00_10_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},{"date":"21. September 2020 um 16:13 Uhr","name":"iobroker_2020_09_21-16_09_26_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},{"date":"21. September 2020 um 02:03 Uhr","name":"iobroker_2020_09_21-02_00_10_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},{"date":"19. September 2020 um 02:03 Uhr","name":"iobroker_2020_09_19-02_00_10_backupiobroker.tar.gz","type":"iobroker","storage":"Dropbox: Ja","filesize":"9MB","error":"none"},
                      laut json-Datenpunkt scheint alles in Ordnung zu sein. Die beiden anderen Datenpunkte zeigen einen Fehler. Datei ist auch auf Dropbox verfügbar.
                      Ich habe die iobrokerVM jetzt neu gestartet und schaue morgen noch einmal
                        Frank_y @Frank_y last edited by
                        auch ein Systemneustart bringt keine Änderung
                        backitup.0.history.iobrokerLastTime und backitup.0.history.iobrokerSuccess zeigen einen Fehler an
                        json zeigt alles i.O. an.
                        Datei ist auf Dropbox vorhanden
                        • simatec
                          simatec Developer Most Active @Frank_y last edited by
                          @Frank_y
                          Bitte führe iobroker fix aus und poste mal den Debuglog des Backupprozesses
                            Frank_y @simatec last edited by Negalein
                            @simatec
                            fixer ausgeführt (curl -fsL https://iobroker.net/fix.sh | bash -)
                            • adapter auf debug gestellt
                            cron-job liefert folgendes LOG
                            backitup.0	2020-09-24 18:03:57.755	debug	(17894) system.adapter.admin.0: logging true
                            backitup.0	2020-09-24 18:03:29.468	debug	(17894) [iobroker/clean] delete /opt/iobroker/backups/redis_2020_09_21-16_09_34_backupiobroker.tar.gz
                            backitup.0	2020-09-24 18:03:29.462	debug	(17894) [iobroker/clean] delete /opt/iobroker/backups/iobroker_2020_09_23-02_00_10_backupiobroker.tar.gz
                            backitup.0	2020-09-24 18:03:29.199	debug	(17894) [iobroker] exec: done
                            backitup.0	2020-09-24 18:03:29.190	debug	(17894) [iobroker] exec: done
                            backitup.0	2020-09-24 18:03:29.187	debug	(17894) [iobroker/history] backitup.0.history.json
                            backitup.0	2020-09-24 18:03:29.179	debug	(17894) [iobroker/history] backitup.0.history.html
                            backitup.0	2020-09-24 18:03:29.159	debug	(17894) [iobroker/clean] done
                            backitup.0	2020-09-24 18:03:29.151	debug	(17894) [iobroker/dropbox] done
                            backitup.0	2020-09-24 18:03:28.620	debug	(17894) [iobroker/dropbox] Dropbox: delete /backupDir/redis_2020_09_09-02_00_18_backupiobroker.tar.gz
                            backitup.0	2020-09-24 18:03:28.043	debug	(17894) [iobroker/dropbox] Dropbox: delete /backupDir/iobroker_2020_09_09-02_00_10_backupiobroker.tar.gz
                            backitup.0	2020-09-24 18:03:18.542	debug	(17894) [iobroker/dropbox] Dropbox: Copy redis_2020_09_24-18_00_17_backupiobroker.tar.gz...
                            backitup.0	2020-09-24 18:00:18.148	debug	(17894) [iobroker/dropbox] Dropbox: Copy iobroker_2020_09_24-18_00_10_backupiobroker.tar.gz...
                            backitup.0	2020-09-24 18:00:18.139	debug	(17894) [iobroker/redis] done
                            backitup.0	2020-09-24 18:00:17.974	debug	(17894) [iobroker/iobroker] done
                            backitup.0	2020-09-24 18:00:16.948	debug	(17894) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_09_24-18_00_10_backupiobroker.tar.gz
                            backitup.0	2020-09-24 18:00:12.747	debug	(17894) [iobroker/iobroker] host.iobrokerVM 4876 objects saved
                            ba[ckitup.0	2020-09-24 18:00:12.715	debug	(17894) [iobroker/iobroker] host.iobrokerVM 4042 states saved
                            backitup.0	2020-09-24 18:00:10.143	debug	(17894) Backup has started ...
                            backitup.0	2020-09-24 17:57:01.485	debug	(17894) system.adapter.admin.0: logging false
                            backitup.0	2020-09-24 17:55:42.772	debug	(17894) system.adapter.admin.0: logging true
                            backitup.0	2020-09-24 17:55:37.241	debug	(17894) system.adapter.admin.0: logging false[Link Text](Link Adresse)](Link Adresse)
                            Leider bleiben beide Datenpunkte fehlerhaft
                            Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
                            Hier gehts zur Hilfe.
                              @simatec
                              habe danach noch einmal manuell <jetzt sichern> angestoßen und dann bestätigen beide Datenpunkte das korrekte backup:
                              backitup.0.history.iobrokerLastTime 24. September 2020 um 18:10 Uhr
                              backitup.0.history.iobrokerSuccess true
                              das Log sieht genauso aus
                              ->es hat irgendetwas mit dem Cron-Job zu tun
                              • simatec
                                @Frank_y
                                history wird nicht sauber beendet.
                                Hatten wir hier schonmal gehabt. ..
                                • Instanz löschen
                                • Adapter löschen
                                • iobroker neustarten
                                • backitup neu installieren und einrichten
                                Scheint so, als ob bei deinem Update was schief gelaufen ist
                                  Frank_y @simatec last edited by Frank_y
                                  @simatec
                                  alles gemacht, gleiches Bild:
                                  -manuelle Auslösung in Ordnung
                                  -über den cron-job werden die Datenpunkte nicht richtig gesetzt
                                  bin per Rollback wieder zurück zur v1.5.8....hier läuft alles einwandfrei durch, manuell und per cron
                                  • simatec
                                    @Frank_y
                                    Was steht bei der 1.6.7 in folgenden Objekt nach dem Backup?
                                    backitup.0.output.line
                                    Gib mir mal bitte den Inhalt ...
                                      @simatec
                                      [DEBUG] [clean] - delete /opt/iobroker/backups/redis_2020_09_09-02_00_18_backupiobroker.tar.gz
                                      • simatec
                                        @Frank_y
                                        Kann das sein, dass genau hier das Problem liegt?
                                        Laut deinem anderen Post, gibt es in dem Ordner kein Redis-Backup.
                                        Stimmen deine Rechte in dem Ordner backup
                                          @simatec
                                          die Ordner-Berechtigungen sind in beiden Versionen gleich:
                                          v.1.5.8:
                                          v1.6.7:
                                          Wenn ich manuell starte funktioniert ja auch alles. Auch beim Cron-Job werden Backups erstellt. Nur die Rückmeldungen in den beiden Datenpunkt scheinen nicht korrekt
                                          • simatec
                                            simatec Developer Most Active @Frank_y last edited by simatec
                                            @Frank_y
                                            Bei einem manuellen Backup werden keine alten Dateien gelöscht.
                                            Deshalb kommt der Fehler dort nicht.
                                            Zeige doch bitte mal den kompletten Inhalt deines Backup-Ordners ...
                                            170
                                            2780
                                            2344118
