    Blockly
      Arminhh last edited by
      moin Bluefox
      ich habe den Javascript Adapter heute morgen geupdatet.
      Ich weiß nicht ob mein script falsch ist oder ein fehler vorliegt.
      Hier die Logausgabe
      ReferenceError:	2016-08-20 10:07:55.690	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      ReferenceError:	2016-08-20 10:07:55.690	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      ReferenceError:	2016-08-20 10:07:55.690	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2113:37)
      ReferenceError:	2016-08-20 10:07:55.690	error	at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:222:17)
      ReferenceError:	2016-08-20 10:07:55.690	error	at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:544:17)
      ReferenceError:	2016-08-20 10:07:55.690	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2831:28)
      ReferenceError:	2016-08-20 10:07:55.690	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2812:17)
      ReferenceError:	2016-08-20 10:07:55.690	error	at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:548:48
      ReferenceError:	2016-08-20 10:07:55.690	error	at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1228:48)
      ReferenceError:	2016-08-20 10:07:55.690	error	at Object. (script.js.Diverses.BloklyAnwesend:3:7)
      ReferenceError:	2016-08-20 10:07:55.690	error	getValue is not defined
      message	2016-08-20 10:07:55.689	error	ping.0.Test.192_168_167_164 [object Object] getValue is not defined
      javascript-0	2016-08-20 10:06:56.134	info	script.js.Diverses.BloklyAnwesend: registered 1 subscription and 0 schedules
      javascript-0	2016-08-20 10:06:56.120	info	Start javascript script.js.Diverses.BloklyAnwesend
      javascript-0	2016-08-20 10:06:56.090	info	Stop script script.js.Diverses.BloklyAnwesend
      on({id: "ping.0.Test.192_168_167_164"/*SamsungS7*/, change: "ne"}, function (obj) {
        var value = obj.state.val;
        if (getValue("ping.0.Test.192_168_167_164").val == (function (){var val = true; if (val === 'true') return true; if (val === 'false') return false; return !!val;})()) {
          console.log('Ping ist true');
          setState("hm-rega.0.950"/*Anwesenheit*/, (function (){var val = true; if (val === 'true') return true; if (val === 'false') return false; return !!val;})());
          console.log('Variable Anwesend auf true');
          sendTo("pushover", {
             message: 'Armin ist Anwesend',
             sound: ""
        } else {
          console.log('Ping ist false');
          setState("hm-rega.0.950"/*Anwesenheit*/, (function (){var val = 0; if (val === 'true') return true; if (val === 'false') return false; return !!val;})());
          console.log('Variable Anwesend auf false');
             message: 'Armin ist Abwesend',
             sound: ""
      wenn die lange Zeile von Blockly // mit kopiert wird lässt sich der Beitrag nicht hoch laden!
      wo ist der Fehler?
      Danke für die Hilfe!
      mfg
      Armin
      P.s. was bedeutet über rechte Maustaste Baustein zusammenfalten?
      • rantanplan
        rantanplan last edited by
        @Arminhh:
        P.s. was bedeutet über rechte Maustaste Baustein zusammenfalten? `
        Das was da steht. 😄
        Probiere es doch aus und Du wirst sehen was passiert.
        • Bluefox
          Bluefox last edited by
          @Arminhh:
          moin Bluefox
          Hier die Logausgabe
                 sound: ""
            } else {
                 sound: ""
          wo ist der Fehler?
          mfg
          Armin
          Du hast aber "iobroker upload javascript" nicht aufgerufen.
          • rantanplan
            @Bluefox:
            @rantanplan:
            Jetzt müssen Blockly-Scipte, bei mir nur noch laufen. Bitte noch mal vom git updaten. Habe jetzt getValue=>getState gefixt.
            Leider noch nicht. Immer noch der gleiche Fehler.
            JS 2.3.3
            "ioBroker update javascript" durchgeführt.
            Den Triger mal gelöscht und wieder neu angelegt.
            Leider kein Erfolg.
            "getValue is not defined
            error hm-rega.0.14256 [object Object] getValue is not defined"
              apollon77 last edited by
              Beiu mir hats geplappt. Durchgeführt wie im ersten Post.
              Macht vllt ne kleine Änder am Skript - ich weiss nicht mit welchem "Trigger" er den code neu generiert … ohne Änderung muss er das ja nicht 🙂
              Und Bluefox hat ein comment-Blockly eingebaut was man überall einfügen kann. cool.
              OT-Robomow: Gern 🙂 Ich plane für den Herbst noch den Umbau mit Tastensteuerung per HM-Batterieaktoren :-))
              • rantanplan
                @apollon77:
                OT-Robomow: Gern 🙂 Ich plane für den Herbst noch den Umbau mit Tastensteuerung per HM-Batterieaktoren :-)) `
                Alles gut!!!!!!!
                Script neu angelegt und es funktioniert. 😄
                Kommentar-Baustein ist echt klasse.
                (Was Bluefox so mal eben einbaut ist schon ein Hammer)
                Jetzt kann die Portierung von CCU.IO nach ioBroker anfangen.
                Wenn ich an meine Heizungssteuerung denke, wird das echt spannend. 😉
                @Bluefox. Wäre eine Rubrik "Blockly-Scripten" möglich? Dann wäre hier nur Testen.
                • rantanplan
                  Hallo Zusammen
                  und schon habe ich eine Frage.
                  Ich möchte einen Trigger, der immer auf 06:00 Uhr reagiert.
                  Da habe ich mir gedacht, nimm den Cron-Baustein.
                  Stunden / Jede ausgewählte Stunde / 06
                  Cron-Ausdruck: 6**
                  Da drunter steht aber "Jede Minute von 6 Stunde(n)"
                  Ist das nur eine falsche Anzeige? Hat das schon jemand ausprobiert?
                    Bei Cron ist das so korrekt.
                    Ein "*" steht immer für "jedes mal". Bei dir also "wenn Stunde=6 UND Minute=0 ODER 1 ODER 2 ODER 3..59"
                    Wenn Du also 6 Uhr haben willst musst du bei den Minuten noch die Minute "0" auswählen, damit gilt dann "wenn Stunde=6 UND Minute=0"
                    • rantanplan
                      Aha, wieder was gelernt. Danke!
                        @Bluefox: Mal wieder spontanes Feedback: In ScriptGUI war es einfach eine Textmeldung sowohl an Pushover zu senden als auch ins Log zu schreiben. Bei Blockly müsste man temporär Variablen nutzen oder alles doppelt bauen (also den Text-Blockly).
                        Wie wäre es damit das man bei den "Send-To"-Blocklys noch wäwhlen könnte ob die Meldung nach dem senden auch ins Log (mit entsprechender Severity) soll ?!
                        Und noch: Zugriff auf "oldValue" im Rahmen von Triggern wäre auch super
                        • rantanplan
                          @Bluefox
                          Ist es irgendwann geplant die Namen der Objekte in den Bausteinen anzuzeigen?
                          Das würde einiges vereinfachen.
                            EIne Info noch zu den Timeouts (weil gerade drüber gestolpert). Hier gibts aktuell nen Unterschied zu ScriptGUI!!
                            Die aktuelle Umsetzung bei Blockly behandelt exakt EINEN Timeout/Delay und kann exakt "den letzten gestarteten" Timeout/Delay wieder löschen mit den "clear"-Kommandos.
                            Bei ScriptGUI war das etwas allgemeiner und hat immer alle pot. laufenden Timeouts gelöscht anstelle nur den letzten
                            ScriptGUI hat dabei den Code hier erzeugt:
                            }var brake_29 = [] ;function  brake_29_in1 (data){brake_29.push(setTimeout(function(){codebox_5(data);},60000))}function  brake_29_in2 (data){while (brake_29.length > 0 ) clearTimeout(brake_29.pop());}
                            brake_29_in1 ist "Start" und brake_29_in2 war "Stop".
                            Ich denke das die ScriptGUI-Lösung ggf etwas einfacher für Nicht-Programmierer zu verstehen ist…
                            @Bluefox: kannst ja überlegen ob Du was änderst oder nicht. Falls ja wäre ne Info cool weil ichjetzt an ersten Teststellen was umbauen musste 🙂
                            • rantanplan
                              @Bluefox:
                              Ich überlege gerade, ob man die Tagen nicht von 1 bis 7 machen sollte. Aktuell kommen die 0 für Sonntag bis 6 für Samstag. Du wolltest aber sicher Wochentage erwischen. `
                              Hi, Bluefox
                              darüber würde ich mich freuen.
                              Tage 1 bis 7 ist leicher zu verarbeiten.
                              Bekommen wir eine Info falls das umgestellt wird?
                              • rantanplan
                                Wenn ein Fehler im Script erkannt wird, läuft das Script weiter.
                                Wäre es nicht besser/sicherer, wenn es gleichzeitig gestoppt wird?
                                • rantanplan
                                  Auch wenn ich läßtig werde :oops:
                                  Das setzten einer boolschen HM-Systemvariable klappt bei mir nicht.
                                  schedule("* * * * *", function () {
                                    console.log('Starte HF MF Feiertag');
                                    // setzte Heute_Frei unwahr
                                    setState("hm-rega.0.8862"/*Heute_Frei*/, false, true);
                                    // chk Morgen_Frei
                                    // chk Wochenende?
                                    // chk Feiertag?
                                  Bug? Oder bin ich zu blöd? :?
                                    War da nicht was das Rega-Variablen nur bei "ack=false" gesendet werden. Dann wäre das blöd weil im Blockly nicht einstellbar 😞
                                    • rantanplan
                                      Ja… ich schon wieder.
                                      (Bei uns regnet es 😄 )
                                      Zwei weitere Logik-Bausteine wären klasse.
                                      Jeweils für AND und OR, bei denen man mehrere Bedingungen hinzufügen kann.
                                      Bei ScriptGUI sieht das so aus.
                                      Bei "AND" diese Logik.
                                      Ist sowas in Blockly möglich?
                                      • rantanplan
                                        @apollon77:
                                        War da nicht was das Rega-Variablen nur bei "ack=false" gesendet werden. Dann wäre das blöd weil im Blockly nicht einstellbar 😞 `
                                        Hi Apollon77
                                        Heißt das, ich kann mit ioBroker/Blockly keine HM-Systemvariablen ändern? :shock:
                                        Das wäre für mich das Aus! :evil:
                                          Da hab ich gerade nur halbwissen bzw ein "da war doch mal was, weil ich selbst das so nicht nutze (ich hab alles was solche Variablen sind schon früher nach CCU.io umgezogen und in der CCU nur noch welche die ich dann woanders lese.
                                          Schau mal hier http://forum.iobroker.net/viewtopic.php?f=22&t=3328 … wenn ich das richtig lese versuchs mal mit dem "command"-Baustein anstelle dem "setze Wert"-Baustein.
                                          Zu Multi AND bzw OR gibt unter "Logik" den "... and ..." Baustein. Dort kannst Du jeweils wieder so einen "... and ..." Baustein reinsetzen und damit alle deine Sachen verketten. Gleiches gilt für "or".
                                          Habe im COde geschaut - es wird scheinbar nicht geklammert, also sind die alle gleichwertig und damit gleichbedeutend mit deinem ScriptGUI-Baustein (nur um einiges schlechter lesbar weil eeeelend lang 😉 )
                                          Versuchs mal damit
                                          • rantanplan
                                            @apollon77:
                                            …und in der CCU nur noch welche die ich dann woanders lese. `
                                            Genau darum geht es!
                                            HM-SV's lassen sich von JEDER xBeliebigen App anzeigen und steuern.
                                            Ich wollte/will nie von einem Programm abhängig sein/werden.
                                            CCU.io ist da ein gutes Beispiel. Starker Anfang und dann Ende.
                                            @apollon77:
                                            Schau mal hier http://forum.iobroker.net/viewtopic.php?f=22&t=3328 … wenn ich das richtig lese versuchs mal mit dem "command"-Baustein anstelle dem "setze Wert"-Baustein. `
                                            Ich habe versucht es zu lesen (etwas aufbebracht). Mein Eindruck…zu umständlich.
                                            Ist mir unbegreiflich das ioBroker nicht das auf die Reihe bekommt, was ALLE anderen können.
                                            @Bluefox. Sorry, ich bin gerade etwas sauer. Habe aber noch die Hoffnung, das es ein Bug in Blockly ist.
                                            @apollon77:
                                            …(nur um einiges schlechter lesbar weil eeeelend lang 😉 ) `
                                            Ja, Möglichkeit ist da. Aber wie Du schön beschrieben hast …eeeelend lang. 😄
                                            332
                                            74366
