      crunchip Forum Testing Most Active @JackDaniel last edited by crunchip
      @JackDaniel @Zefau das hatte ich auch schon probiert, auch gestern schon,
      ich bekomme bei beiden links, NPM Error
      2020-09-24 09:10:06.023 - info: host.IoBroker iobroker url "https://github.com/Zefau/ioBroker.jarvis/tree/v1.0.x"
      2020-09-24 09:10:08.883 - info: host.IoBroker iobroker install https://github.com/Zefau/ioBroker.jarvis/tree/v1.0.x/tarball/f5db8ba0d18656637b818275b358de41a6a1207a
      2020-09-24 09:10:09.909 - info: host.IoBroker iobroker NPM version: 6.14.6
      2020-09-24 09:10:09.915 - info: host.IoBroker iobroker npm install https://github.com/Zefau/ioBroker.jarvis/tree/v1.0.x/tarball/f5db8ba0d18656637b818275b358de41a6a1207a --loglevel error --prefix "/opt/iobroker" (System call)
      2020-09-24 09:10:35.430 - info: host.IoBroker iobroker npm
      2020-09-24 09:10:35.436 - info: host.IoBroker iobroker ERR! code E404npm ERR! 404 Not Found - GET https://github.com/Zefau/ioBroker.jarvis/tree/v1.0.x/tarball/f5db8ba0d18656637b818275b358de41a6a1207anpm ERR! 404 npm ERR! 404 'https://github.com/Zefau/ioBroker.jarvis/tree/v1.0.x/tarball/f5db8ba0d18656637b818275b358de41a6a1207a' is not in the npm registry.npm ERR! 404 Your package name is not valid, because npm
      2020-09-24 09:10:35.443 - info: host.IoBroker iobroker ERR! 404 1. name can only contain URL-friendly charactersnpm ERR! 404 2. name can no longer contain capital lettersnpm ERR! 404 npm ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
      2020-09-24 09:10:35.454 - info: host.IoBroker iobroker npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-09-24T07_10_35_439Z-debug.log
      2020-09-24 09:05:07.605 - info: host.IoBroker iobroker url "https://github.com/Zefau/ioBroker.jarvis/releases/tag/v1.0.0-rc.15"
      2020-09-24 09:05:11.375 - info: host.IoBroker iobroker install https://github.com/Zefau/ioBroker.jarvis/releases/tag/v1.0.0-rc.15/tarball/f5db8ba0d18656637b818275b358de41a6a1207a
      2020-09-24 09:05:12.222 - info: host.IoBroker iobroker NPM version: 6.14.6
      2020-09-24 09:05:12.226 - info: host.IoBroker iobroker npm install https://github.com/Zefau/ioBroker.jarvis/releases/tag/v1.0.0-rc.15/tarball/f5db8ba0d18656637b818275b358de41a6a1207a --loglevel error --prefix "/opt/iobroker" (System call)
      2020-09-24 09:05:47.559 - info: host.IoBroker iobroker npm ERR! code ENOPACKAGEJSONnpm ERR! package.json Non-registry package missing package.json: https://github.com/Zefau/ioBroker.jarvis/releases/tag/v1.0.0-rc.15/tarball/f5db8ba0d18656637b818275b358de41a6a1207a.npm ERR! package.json npm can't find a package.json file in your current directory.npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-09-24T07_05_47_134Z-debug.log
      ja jetzt gerade eben zeigt er rc.15 verfügbar an, kanns aber nicht installieren
        WW1983 @crunchip last edited by
        @crunchip said in jarvis - just another remarkable vis:
        Probier es mal mit dem Link. So mache ich das zumindest:
        Zefau/ioBroker.jarvis#v1.0.x
          crunchip Forum Testing Most Active @WW1983 last edited by
          @WW1983 hatte ich auch schon, siehe installiert (1.1.0-beta5), vorher hatte ich 1.0.0.-rc.7 drauf und seitdem kein update mehr gemacht
            Gibt es aktuelle eine Möglichkeit „Checkbox“ als Auswahl zu nutzen? Bzw. den herkömmlichen „Switch-Button“ zu einer Checkbox zu ändern:
            Zefau 2 Replies Last reply Reply Quote 0
            • Zefau
              Zefau @WW1983 last edited by Zefau
              @WW1983 nein, nehme ich gerne mit auf, https://github.com/Zefau/ioBroker.jarvis/issues/109
              Zefau created this issue in Zefau/ioBroker.jarvis
              closed add a CheckboxAction #109
                WW1983 @Zefau last edited by
                Was mir einfällt ist noch das Einfügen von Bildern. Ich habe z.B. ein QR Code fürs Gäste WLAN hinterlegt
                • Zefau
                  @WW1983 https://github.com/Zefau/ioBroker.jarvis/issues/110
                  closed add new module DisplayImage #110
                    @Zefau said in jarvis - just another remarkable vis:
                    @JackDaniel sagte in jarvis - just another remarkable vis:
                    zu deiner frage, ich habe in der gerätekonfig unter datenpunkt stil das hier eingetragen {"Geschlossen":"#41f316"}, damit wollte ich erreichen das geschlosssen in grüner farbe angezeigt wird.
                    {"Geschlossen": {"color":"#41f316"}}
                    Kann man die Schrift an blinken lassen? Kenne mich mit JSON überhaupt nicht aus
                    • Zefau
                      @WW1983 jetzt wird's speziell 😄 hast du ein Beispiel? Ansonsten nach blinkende Schrift mit CSS googeln
                      W D 2 Replies Last reply Reply Quote 1
                        Das war doch schon ein guter Hinweis. Danke dir
                          dos1973 @Zefau last edited by dos1973
                          @Zefau
                          hmm, irgendwie startet es bei mir nicht, habe schon die Most Fehler Seite studiert, sieht soweit ich das sehe kann alles nach Vorgabe aus. hast du einen Tipp
                          Wenn ich auf die Kachsel Jarvis klicke bekomme ich nur eine leere Seite.
                          Ich hatte es mal offen und konnte alle Shelly's importieren - danach habe ich eine rote Meldung "kein Verbindung" bekommen o.ä. seitdem nur noch eine weiße Seite.
                          http://192.168.10.10:8082/jarvis/index.html
                          Ich habe bestimmt irgendwas übersehen.
                          EDIT: nachdem ich in chrome den Link starte sehe ich wieder die Meldung. Im safari nur weiss...
                          • Zefau
                            Zefau @dos1973 last edited by
                            @dos1973 häng mal #socketPort=8084 an die URL ran.
                            M D 2 Replies Last reply Reply Quote 0
                              MollocH @Zefau last edited by
                              Hey,
                              zunächst mal tolle Arbeit. Bin gespannt wohin sich der Adapter noch entwickelt 🙂
                              Ich spiele gerade etwas damit herum und habe festgestellt, dass die Hue Lampen als brightness einen Wert zwischen 0 und 254 akzeptieren.
                              Nun erlaubt das LevelBody Element eine Auswahl von 0-100 .... Bevor ich jetzt anfange über Variablen den 0-254 Wert in einen 0-100 Wert umzurechnen, gibt es eine Möglichkeit das einzustellen ?
                              • Zefau
                                Zefau @MollocH last edited by
                                @MollocH welche hue adapter nutzt du denn? Ich meine, dass beide Adapter einen level Datenpunkt von 0-100 haben?
                                Marcel Baum 1 Reply Last reply Reply Quote 0
                                • Zefau
                                  Zefau @JackDaniel last edited by
                                  wäre es super wenn es buttonaction ohne dem text "anschalten" geben würde
                                  mit v1.1.0-beta.4 gibt es nun einen ButtonAction (https://github.com/Zefau/ioBroker.jarvis/issues/83).
                                  closed ButtonAction without label #83
                                  JackDaniel 1 Reply Last reply Reply Quote 0
                                  • Marcel Baum
                                    Marcel Baum @Zefau last edited by
                                    @Zefau
                                    Das gleiche Problem habe ich mit meinen Z-Wave Aktoren auch. Sie verlangen einen Wert von 0-99.
                                      @Zefau
                                      das funktioniert, Seite lädt. Muss ich dass immer manuell anhängen oder kannst du das fixen. ist das nur bei mir so??
                                      crunchip Zefau 2 Replies Last reply Reply Quote 0
                                        crunchip Forum Testing Most Active @dos1973 last edited by
                                        @dos1973 sollte automatisch gehen, funktioniert bei mir zumindest so
                                          Bei mir läuft jarvis auf einem iPad Air2 leider nicht. Auf einem neueren iPad läuft es. Jarvis wird aufgerufen, die Widgets werden geladen, aber leider passiert danach nichts mehr. Keine Fehlermeldung, nichts.
                                          Hat jemand eine Idee woran es liegen kann?
                                          dslraser Zefau 2 Replies Last reply Reply Quote 0
                                          • dslraser
                                            dslraser Forum Testing Most Active @WW1983 last edited by dslraser
                                            @WW1983 sagte in jarvis - just another remarkable vis:
                                            vermutlich liegt es daran...?
                                            https://forum.iobroker.net/post/424580
                                            W 2 Replies Last reply Reply Quote 1
                                            316
                                            6126
                                            4156737
