    2. English
    3. ioBroker general
    4. Zigbee adapter stopped working FIXED
      Thomas Braun Most Active @ap2017 last edited by
      @ap2017
      cd /opt/iobroker
      npm list serialport
      Should look similar to
      pi@raspberrypi:/opt/iobroker $ npm list serialport
      iobroker.inst@2.0.3 /opt/iobroker
      └─┬ iobroker.zigbee@1.2.1
        └─┬ zigbee-herdsman@0.12.117
          └── serialport@9.0.1
        ap2017 @Thomas Braun last edited by
        @Thomas-Braun said in Zigbee adapter stopped working:
        npm list serialport
        Here we go:
        • Asgothian
          Asgothian Developer @ap2017 last edited by
          @ap2017 I apologise. I should have put quotes around the "npm list", as that was the command i wanted you to check.
          As you can see, there is an extra serialport library installed, but each adapter has (should have) a usable version, so you should be able to remove the extra one.
          npm prune should get rid of it.
          A.
          A 2 Replies Last reply Reply Quote 0
            ap2017 @Asgothian last edited by
            @Asgothian No problem. I run the following, but still have same extraneous serial library 6..2.2 when run "npm list serialport"
            cd /opt/iobroker
            npm prune --dry-run
            sudo reboot
              @Asgothian As previously, keep getting these errors:
              zigbee.0 2020-09-24 10:39:10.082 error (2461) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-he
              zigbee.0 2020-09-24 10:39:10.081 error (2461) Failed to start Zigbee
              zigbee.0 2020-09-24 10:39:09.975 info (2461) Starting Zigbee...
              zigbee.0 2020-09-24 10:39:09.974 info (2461) Try to reconnect. 1 attempts left
              zigbee.0 2020-09-24 10:38:59.972 error (2461) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/z
              zigbee.0 2020-09-24 10:38:59.972 error (2461) Failed to start Zigbee
              • Asgothian
                @ap2017
                Of course.. the "npm prune --dry-run" only lists what it would do. This is to ensure that it doesn't get rid of something you want to keep
                once you checked the list, you can do "npm prune" (without the dry run)
                a Reboot is not needed..
                A.
                  @Asgothian The unwanted serial driver 6.2.2 disappeared after pruning, but it did not help to resolve the main issue, see errors below. I rebooted controller after pruning, just in case.
                  • Asgothian
                    @ap2017
                    Unfortunately, that is what i expected. Now you should no longer get any errors on an npm rebuild, but i have the feeling that is not the error. I am starting to think that the firmware on the Zigbee Board / Stick is not responding correctly.
                    As long as there is a message that the zigbee library cannot be initialized, the issue is most likely hardware related.
                    A.
                      Thomas Braun Most Active @Asgothian last edited by
                      @ap2017
                      Please stop the zwave Adapater and reboot. I may happen that the zwo adapters do block the port.
                      And I see a duplicate entry in the zwave entry. I think that only one entry should show there.
                        ap2017 @Thomas Braun last edited by ap2017
                        @Thomas-Braun I stopped both zwave and zigbee and rebooted, here is list of serial ports:
                        As I mentioned before, when zigbee is off, zwave works fine on both ports ACM0 and ACM1, so it looks like system works properly with ports.
                        What would be next step, try to uninstall and reinstall zigbee adapter again? Re-flash CC2531 dongle? Thank you.
                        • Asgothian
                          @ap2017
                          No.
                          Please verify if the Zigbee Adapter will start when
                          • no zwave sticks are connected to the system
                          • no zwave adapter is running.
                          A.
                            @Asgothian Sorry, how do I check if zigbee adapter started?
                            • Asgothian
                              @ap2017 Watch the log for an entry that the zigbee adapter started successfully, alternatively, watch the green light in the instance list.
                                ap2017 @Asgothian last edited by ap2017
                                @Asgothian Of course, I did not pay attention that you asked to disable zwave, not zigbee. Unplugging zwave dongle and disabling zwave adapter did not help. FYI, zigbee behaves same way for ACM0 and ACM1 ports
                                  @Asgothian Here is the latest debug log when trying to restart zigbee adapter. Anything comes to mind? Thank you for your time.
                                  zigbee.0 2020-09-27 17:53:02.239 error (4926) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
                                  zigbee.0 2020-09-27 17:53:02.239 error (4926) Failed to start Zigbee
                                  zigbee.0 2020-09-27 17:53:02.138 debug (4926) Starting zigbee-herdsman...
                                  zigbee.0 2020-09-27 17:53:02.137 info (4926) Starting Zigbee...
                                  zigbee.0 2020-09-27 17:53:02.137 info (4926) Try to reconnect. 1 attempts left
                                  zigbee.0 2020-09-27 17:52:52.136 error (4926) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
                                  zigbee.0 2020-09-27 17:52:52.135 error (4926) Failed to start Zigbee
                                  zigbee.0 2020-09-27 17:52:52.061 debug (4926) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_09_27-17_52_51.tar.gz success
                                  zigbee.0 2020-09-27 17:52:52.004 debug (4926) Starting zigbee-herdsman...
                                  zigbee.0 2020-09-27 17:52:52.003 info (4926) Starting Zigbee...
                                  zigbee.0 2020-09-27 17:52:51.977 debug (4926) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"database
                                  zigbee.0 2020-09-27 17:52:51.960 info (4926) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                  host.AP-Tiny 2020-09-27 17:52:51.188 info instance system.adapter.zigbee.0 started with pid 4926
                                  host.AP-Tiny 2020-09-27 17:52:48.684 info instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  zigbee.0 2020-09-27 17:52:48.172 error at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8270:22)
                                  zigbee.0 2020-09-27 17:52:48.172 error at Zigbee.emit (events.js:315:20)
                                  zigbee.0 2020-09-27 17:52:48.172 error at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:442:41)
                                  zigbee.0 2020-09-27 17:52:48.172 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:304:20)
                                  zigbee.0 2020-09-27 17:52:48.172 error at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:187:42)
                                  zigbee.0 2020-09-27 17:52:48.172 error at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:118:43)
                                  zigbee.0 2020-09-27 17:52:48.172 error at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:201:49)
                                  zigbee.0 2020-09-27 17:52:48.172 error at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:252:31)
                                  zigbee.0 2020-09-27 17:52:48.172 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:234:16)
                                  zigbee.0 2020-09-27 17:52:48.172 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:214:55)
                                  zigbee.0 2020-09-27 17:52:48.172 error (4705) TypeError: Cannot read property 'getEntries' of null
                                  zigbee.0 2020-09-27 17:52:48.171 error (4705) unhandled promise rejection: Cannot read property 'getEntries' of null
                                  Unhandled 2020-09-27 17:52:48.170 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee.0 2020-09-27 17:52:48.170 info (4705) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  zigbee.0 2020-09-27 17:52:48.169 info (4705) terminating
                                  zigbee.0 2020-09-27 17:52:48.169 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:308:33))
                                  zigbee.0 2020-09-27 17:52:48.169 error at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:199:16)
                                  zigbee.0 2020-09-27 17:52:48.169 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
                                  zigbee.0 2020-09-27 17:52:48.169 error at new Promise (<anonymous>)
                                  zigbee.0 2020-09-27 17:52:48.169 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
                                  zigbee.0 2020-09-27 17:52:48.169 error at Generator.next (<anonymous>)
                                  zigbee.0 2020-09-27 17:52:48.169 error at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:200:18)
                                  zigbee.0 2020-09-27 17:52:48.169 error at Controller.databaseSave (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:219:45)
                                  zigbee.0 2020-09-27 17:52:48.169 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
                                  zigbee.0 2020-09-27 17:52:48.169 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
                                  zigbee.0 2020-09-27 17:52:48.169 error (4705) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
                                  zigbee.0 2020-09-27 17:52:48.168 info (4705) Zigbee: disabling joining new devices.
                                  zigbee.0 2020-09-27 17:52:48.166 info (4705) cleaned everything up...
                                  zigbee.0 2020-09-27 17:52:48.165 info (4705) Got terminate signal TERMINATE_YOURSELF
                                  host.AP-Tiny 2020-09-27 17:52:48.163 info stopInstance system.adapter.zigbee.0 send kill signal
                                  host.AP-Tiny 2020-09-27 17:52:48.159 info stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                  • Asgothian
                                    @ap2017 Things that come to mind:
                                    • Put the log in code tags, makes it more readable
                                    • The serial port is still locked.
                                    • This is not the first entry after trying to start the adapter. It shows a restart attempt.
                                    Please follow these steps, and post the resulting log (in code tags)
                                    • Disable the zigbee instance
                                    • stop the iobroker
                                    • verify that no process has the serial device open
                                    lsof /def/ttyACM1
                                    • If no process has the serial device open, start iobroker
                                    • check again if any process has the serial port open
                                    • delete the current log (Delete, not clear, in the log view)
                                    • attempt to start the zigbee adapter. If it does not start, disable it again, then post the log file.
                                    A.
                                      @Asgothian said in Zigbee adapter stopped working:
                                      lsof /def/ttyACM1
                                      When iobroker stopped and started same status of serial port is reported (hopefully there is no error in command):
                                      Here is log after zigbee adapter started
                                      zigbee.0	2020-09-28 23:23:31.400	error	(26678) Error: Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/
                                      zigbee.0	2020-09-28 23:23:31.399	error	(26678) Failed to start Zigbee
                                      zigbee.0	2020-09-28 23:23:23.829	debug	(26678) Starting zigbee-herdsman...
                                      zigbee.0	2020-09-28 23:23:23.829	info	(26678) Starting Zigbee...
                                      zigbee.0	2020-09-28 23:23:23.828	info	(26678) Try to reconnect. 1 attempts left
                                      zigbee.0	2020-09-28 23:23:13.828	error	at /opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:242:12
                                      zigbee.0	2020-09-28 23:23:13.828	error	at SerialPort._error (/opt/iobroker/node_modules/serialport/node_modules/@serialport/stream/lib/index.js:198:14)
                                      zigbee.0	2020-09-28 23:23:13.828	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                      zigbee.0	2020-09-28 23:23:13.828	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                      zigbee.0	2020-09-28 23:23:13.828	error	at new Promise (<anonymous>)
                                      zigbee.0	2020-09-28 23:23:13.828	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                      zigbee.0	2020-09-28 23:23:13.828	error	at Generator.next (<anonymous>)
                                      zigbee.0	2020-09-28 23:23:13.828	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                      zigbee.0	2020-09-28 23:23:13.828	error	(26678) Error: Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/ttyACM1'
                                      zigbee.0	2020-09-28 23:23:13.827	error	(26678) Failed to start Zigbee
                                      zigbee.0	2020-09-28 23:23:13.744	debug	(26678) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2020_09_28-23_23_13.tar.gz success
                                      zigbee.0	2020-09-28 23:23:13.666	debug	(26678) Starting zigbee-herdsman...
                                      zigbee.0	2020-09-28 23:23:13.665	info	(26678) Starting Zigbee...
                                      zigbee.0	2020-09-28 23:23:13.628	debug	(26678) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databa
                                      zigbee.0	2020-09-28 23:23:13.611	info	(26678) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.4, js-controller: 3.1.6
                                      zigbee.0	2020-09-28 23:23:13.150	debug	(26678) statesDB connected
                                      zigbee.0	2020-09-28 23:23:13.150	debug	(26678) States connected to redis: 127.0.0.1:9000
                                      zigbee.0	2020-09-28 23:23:13.146	debug	(26678) States create System PubSub Client
                                      zigbee.0	2020-09-28 23:23:13.145	debug	(26678) States create User PubSub Client
                                      zigbee.0	2020-09-28 23:23:13.142	debug	(26678) Redis States: Use Redis connection: 127.0.0.1:9000
                                      zigbee.0	2020-09-28 23:23:13.141	debug	(26678) objectDB connected
                                      zigbee.0	2020-09-28 23:23:13.138	debug	(26678) Objects connected to redis: 127.0.0.1:9001
                                      zigbee.0	2020-09-28 23:23:13.129	debug	(26678) Objects client initialize lua scripts
                                      zigbee.0	2020-09-28 23:23:13.128	debug	(26678) Objects create User PubSub Client
                                      zigbee.0	2020-09-28 23:23:13.128	debug	(26678) Objects create System PubSub Client
                                      zigbee.0	2020-09-28 23:23:13.126	debug	(26678) Objects client ready ... initialize now
                                      zigbee.0	2020-09-28 23:23:13.105	debug	(26678) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.AP-Tiny	2020-09-28 23:23:12.547	info	instance system.adapter.zigbee.0 started with pid 26678
                                        @ap2017
                                        lsof /dev/ttyACM1
                                        would be correct.
                                          @Thomas-Braun Here is response for lsof /dev/ttyACM1 Not sure what it means, is port being used or not? Getting same response with ioBroker on or off
                                          ap@AP-Tiny:~$ lsof /dev/ttyACM1
                                          ap@AP-Tiny:~$
                                            ap2017 @ap2017 last edited by
                                            @ap2017 Here is response to "npm list serialport"
                                            if it helps
                                            ap@AP-Tiny:/opt/iobroker$ npm list serialport
                                            ├─┬ iobroker.discovery@2.3.11
                                            │ └── serialport@8.0.8
                                            ├─┬ iobroker.mysensors@2.0.1
                                            │ └── serialport@7.1.5
                                            ├─┬ iobroker.zigbee@1.2.1
                                            │ └─┬ zigbee-herdsman@0.13.8
                                            │   └── serialport@9.0.1
                                            └─┬ iobroker.zwave2@1.7.0-alpha.2
                                              └─┬ zwave-js@5.0.0-alpha.3
                                                ├─┬ @zwave-js/serial@5.0.0-alpha.0
                                            zigbee
                                            6997
