    4. XBOX Adapter Fehler Pi4
    SOLVED XBOX Adapter Fehler Pi4
      Smallfeuer @Thomas Braun last edited by
      @Thomas-Braun Hab ich mal gemacht:
      pi@Pi4IOBroker:/opt/iobroker $ node -v
      v12.18.4
      pi@Pi4IOBroker:/opt/iobroker $ nodejs -v
      v12.18.4
      host.Pi4IOBroker	2020-09-24 20:24:11.035	info	instance system.adapter.xbox.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      xbox.0	2020-09-24 20:24:10.505	info	(4675) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      xbox.0	2020-09-24 20:24:10.503	info	(4675) terminating
      xbox.0	2020-09-24 20:24:10.502	info	(4675) [END] cleaned everything up...
      xbox.0	2020-09-24 20:24:10.484	info	(4675) [END] REST server stopped
      xbox.0	2020-09-24 20:24:10.443	debug	(4675) [LOGOUT] <=== Failed to logout: undefined
      xbox.0	2020-09-24 20:24:10.422	info	(4675) Got terminate signal TERMINATE_YOURSELF
      host.Pi4IOBroker	2020-09-24 20:24:10.415	info	stopInstance system.adapter.xbox.0 send kill signal
      host.Pi4IOBroker	2020-09-24 20:24:10.411	info	stopInstance system.adapter.xbox.0 (force=false, process=true)
      host.Pi4IOBroker	2020-09-24 20:24:10.407	info	"system.adapter.xbox.0" disabled
      xbox.0	2020-09-24 20:24:08.921	warn	(4675) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:24:08.920	debug	(4675) Could not parse body
      xbox.0	2020-09-24 20:24:06.414	warn	(4675) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:24:06.414	debug	(4675) Could not parse body
      xbox.0	2020-09-24 20:24:06.402	debug	(4675) [LOGOUT] <=== Failed to logout: undefined
      xbox.0	2020-09-24 20:24:01.309	info	(4675) [START] Starting REST server
      xbox.0	2020-09-24 20:24:01.307	debug	(4675) [START] IP address is 192.168.178.5
      xbox.0	2020-09-24 20:24:01.276	info	(4675) starting. Version 0.6.4 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.18.4, js-controller: 3.1.6
      xbox.0	2020-09-24 20:24:00.519	debug	(4675) statesDB connected
      xbox.0	2020-09-24 20:24:00.518	debug	(4675) States connected to redis: 0.0.0.0:9000
      xbox.0	2020-09-24 20:24:00.510	debug	(4675) States create System PubSub Client
      xbox.0	2020-09-24 20:24:00.507	debug	(4675) States create User PubSub Client
      xbox.0	2020-09-24 20:24:00.500	debug	(4675) Redis States: Use Redis connection: 0.0.0.0:9000
      xbox.0	2020-09-24 20:24:00.497	debug	(4675) objectDB connected
      xbox.0	2020-09-24 20:24:00.491	debug	(4675) Objects connected to redis: 0.0.0.0:9001
      xbox.0	2020-09-24 20:24:00.479	debug	(4675) Objects client initialize lua scripts
      xbox.0	2020-09-24 20:24:00.478	debug	(4675) Objects create User PubSub Client
      xbox.0	2020-09-24 20:24:00.476	debug	(4675) Objects create System PubSub Client
      xbox.0	2020-09-24 20:24:00.458	debug	(4675) Objects client ready ... initialize now
      xbox.0	2020-09-24 20:24:00.415	debug	(4675) Redis Objects: Use Redis connection: 0.0.0.0:9001
      host.Pi4IOBroker	2020-09-24 20:23:59.206	info	instance system.adapter.xbox.0 started with pid 4675
      host.Pi4IOBroker	2020-09-24 20:23:59.161	info	"system.adapter.xbox.0" enabled
      downgrade auf 0,6,4 und dann wieder auf 0.6.5
      box.0	2020-09-24 20:28:02.528	warn	(4818) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:28:02.527	debug	(4818) Could not parse body
      xbox.0	2020-09-24 20:28:00.558	debug	(4818) [PING] Xbox offline
      xbox.0	2020-09-24 20:28:00.556	debug	(4818) [CHECK] Auth is not established
      xbox.0	2020-09-24 20:28:00.024	warn	(4818) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:28:00.022	debug	(4818) Could not parse body
      xbox.0	2020-09-24 20:27:57.514	warn	(4818) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:27:57.513	debug	(4818) Could not parse body
      xbox.0	2020-09-24 20:27:55.005	warn	(4818) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:27:55.004	debug	(4818) Could not parse body
      xbox.0	2020-09-24 20:27:52.498	warn	(4818) [LOGIN] Connection refused, will try again
      xbox.0	2020-09-24 20:27:52.497	debug	(4818) Could not parse body
      xbox.0	2020-09-24 20:27:52.486	debug	(4818) [LOGOUT] <=== Failed to logout: undefined
      xbox.0	2020-09-24 20:27:47.365	info	(4818) [START] Starting REST server
      xbox.0	2020-09-24 20:27:47.364	debug	(4818) [START] IP address is 192.168.178.5
      xbox.0	2020-09-24 20:27:47.332	info	(4818) starting. Version 0.6.5 in /opt/iobroker/node_modules/iobroker.xbox, node: v12.18.4, js-controller: 3.1.6
      xbox.0	2020-09-24 20:27:46.690	debug	(4818) statesDB connected
      xbox.0	2020-09-24 20:27:46.689	debug	(4818) States connected to redis: 0.0.0.0:9000
      xbox.0	2020-09-24 20:27:46.681	debug	(4818) States create System PubSub Client
      xbox.0	2020-09-24 20:27:46.678	debug	(4818) States create User PubSub Client
      xbox.0	2020-09-24 20:27:46.670	debug	(4818) Redis States: Use Redis connection: 0.0.0.0:9000
      xbox.0	2020-09-24 20:27:46.668	debug	(4818) objectDB connected
      xbox.0	2020-09-24 20:27:46.661	debug	(4818) Objects connected to redis: 0.0.0.0:9001
      xbox.0	2020-09-24 20:27:46.641	debug	(4818) Objects client initialize lua scripts
      xbox.0	2020-09-24 20:27:46.640	debug	(4818) Objects create User PubSub Client
      xbox.0	2020-09-24 20:27:46.638	debug	(4818) Objects create System PubSub Client
      xbox.0	2020-09-24 20:27:46.634	debug	(4818) Objects client ready ... initialize now
      xbox.0	2020-09-24 20:27:46.601	debug	(4818) Redis Objects: Use Redis connection: 0.0.0.0:9001
      host.Pi4IOBroker	2020-09-24 20:27:45.385	info	instance system.adapter.xbox.0 started with pid 4818
      host.Pi4IOBroker	2020-09-24 20:27:45.320	info	"system.adapter.xbox.0" enabled
      host.Pi4IOBroker	2020-09-24 20:27:16.543	info	iobroker exit 0
      host.Pi4IOBroker	2020-09-24 20:27:15.516	info	iobroker Adapter "xbox" updated
      host.Pi4IOBroker	2020-09-24 20:27:15.447	info	iobroker upload [0] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/index_m.html index_m.html text/html
      host.Pi4IOBroker	2020-09-24 20:27:15.391	info	iobroker upload [1] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/words.js words.js application/javascript
      host.Pi4IOBroker	2020-09-24 20:27:15.259	info	iobroker Update "system.adapter.xbox.0"
      host.Pi4IOBroker	2020-09-24 20:27:15.210	info	iobroker upload [2] xbox.admin /opt/iobroker/node_modules/iobroker.xbox/admin/xbox.png xbox.png image/png
      host.Pi4IOBroker	2020-09-24 20:25:58.530	info	iobroker npm install iobroker.xbox@0.6.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
      host.Pi4IOBroker	2020-09-24 20:25:58.527	info	iobroker NPM version: 6.14.6
      host.Pi4IOBroker	2020-09-24 20:25:57.925	info	iobroker Update xbox from @0.6.4 to @0.6.5
      Leider keine Verbesserung...
        Smallfeuer @r0b1zZle last edited by
        @r0b1zZle
        @foxriver76
        Habe heut die Version 0.7.0 installiert die bei Github online ist... ENDLICH 😉 Danke @foxriver76
        Bischen Lustig das es zum Release der neuen Xbox Series läuft... jetzt hab ich nen bischen Angst vor dem Upgrade :). Aber mal schauen...
          Smallfeuer @foxriver76 last edited by
          @foxriver76
          Muss ich auf Microsoft Live ID noch etwas freischalten ? Oder in der XBoxOneX? Anschalten via Alexa Skill funktioniert bereits, das war damals die alternative.
          Es muss auch die Live ID eingetragen werden und nicht die Globale ID, richtig?
          • foxriver76
            foxriver76 Developer @Smallfeuer last edited by
            @Smallfeuer ja Live Id der Konsole. Was passiert wenn du den Server mal manuell startest?
              @foxriver76 da lande ich wieder bei den grenlet Fehlern... was immer das ist 😉
              pi@Pi4IOBroker:/opt/iobroker $ /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
              -bash: /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js: Datei oder Verzeichnis nicht gefunden
              /usr/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: greenlet.greenlet size changed, may indicate binary incompatibility. Expected 72 from C header, got 76 from PyObject
                return f(*args, **kwds)
              Starting REST server from dedicated script
              Xbox SmartGlass main client started
              Xbox Smartglass REST server started on 127.0.0.1:5557
                Smallfeuer @foxriver76 last edited by Smallfeuer
                @foxriver76 Soll ich den Fix nochmal laufen lassen?
                Binary compatibility issues on Python 3.7/Linux
                #1260
                Übergangslösung:
                pip install -U --force-reinstall --no-binary :all: gevent
                Ich sehe grad, das sind die falschen Zeilen in dem Workaround 😞 Da hab ich wohl nicht ordentlich geschaut beim ersten mal.... dann wird das wohl nicht helfen.
                • foxriver76
                  @Smallfeuer Anscheinend machen die Freunde öfter mal was kaputt (https://github.com/python-greenlet/greenlet/issues/179).
                  Funktioniert deine Lösung?
                  jamadden created this issue in python-greenlet/greenlet
                  closed Proposal: SemVer approach to default ABI changes #179
                    @foxriver76 Hier kommt folgendes:
                    Defaulting to user installation because normal site-packages is not writeableCollecting gevent
                      Using cached gevent-20.9.0.tar.gz (5.8 MB)
                      Installing build dependencies ... done
                      Getting requirements to build wheel ... done
                        Preparing wheel metadata ... done
                    Collecting zope.event
                      Using cached zope.event-4.5.0.tar.gz (18 kB)
                    Collecting zope.interface
                      Using cached zope.interface-5.1.0.tar.gz (225 kB)
                    Collecting greenlet>=0.4.17; platform_python_implementation == "CPython"
                      Using cached greenlet-0.4.17.tar.gz (61 kB)
                    Collecting setuptools
                      Using cached setuptools-44.1.1.zip (858 kB)
                    Skipping wheel build for zope.event, due to binaries being disabled for it.
                    Skipping wheel build for zope.interface, due to binaries being disabled for it.
                    Skipping wheel build for greenlet, due to binaries being disabled for it.
                    Skipping wheel build for setuptools, due to binaries being disabled for it.
                    Building wheels for collected packages: gevent
                      Building wheel for gevent (PEP 517) ... done
                      Created wheel for gevent: filename=gevent-20.9.0-cp27-cp27mu-linux_armv7l.whl size=4501677 sha256=34465c35edb88c52b43a8565da7443a911e1feea7161dcb1d10647a3653d50b3
                      Stored in directory: /home/pi/.cache/pip/wheels/3b/b7/3e/f9e38f94c533b9b3549acf90ae8fc70283aab07f8f01ff527a
                    Successfully built gevent
                    Installing collected packages: setuptools, zope.event, zope.interface, greenlet, gevent
                      Attempting uninstall: setuptools
                        Found existing installation: setuptools 44.1.1
                        Uninstalling setuptools-44.1.1:
                          Successfully uninstalled setuptools-44.1.1
                        Running setup.py install for setuptools ... done
                      Attempting uninstall: zope.event
                        Found existing installation: zope.event 4.5.0
                        Uninstalling zope.event-4.5.0:
                          Successfully uninstalled zope.event-4.5.0
                        Running setup.py install for zope.event ... done
                      Attempting uninstall: zope.interface
                        Found existing installation: zope.interface 5.1.0
                        Uninstalling zope.interface-5.1.0:
                          Successfully uninstalled zope.interface-5.1.0
                        Running setup.py install for zope.interface ... done
                      Attempting uninstall: greenlet
                        Found existing installation: greenlet 0.4.17
                        Uninstalling greenlet-0.4.17:
                          Successfully uninstalled greenlet-0.4.17
                        Running setup.py install for greenlet ... done
                      Attempting uninstall: gevent
                        Found existing installation: gevent 1.3.7
                        Uninstalling gevent-1.3.7:
                          Successfully uninstalled gevent-1.3.7
                    ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts.
                    We recommend you use --use-feature=2020-resolver to test your packages with the new resolver before it becomes the default.
                    xbox-smartglass-core 1.1.1 requires gevent==1.3.7, but you'll have gevent 20.9.0 which is incompatible.
                      Smallfeuer @Smallfeuer last edited by
                      @foxriver76 nach manuellem Start des Servers die gleichen Fehler, also durch das Workaround kein Eingriff an den betroffenen Zeilen -und auf Grund der Meldung am Ende auch keine Option:
                      **%(#ff0000)[ERROR: After October 2020 you may experience errors when installing or updating packages. This is because pip will change the way that it resolves dependency conflicts]**
                        @foxriver76 Hab mal eine LOG von der Installation gemacht:
                        > iobroker.xbox@0.6.8 install /opt/iobroker/node_modules/iobroker.xbox
                        > npip install
                        No python_modules directory; installing pip locally if needed.
                        Successfully completed pip check.
                        Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                        Collecting xbox-smartglass-core>=1.2.2
                          Using cached xbox_smartglass_core-1.2.2-py2.py3-none-any.whl (84 kB)
                        Collecting gevent==1.5a3
                          Downloading https://www.piwheels.org/simple/gevent/gevent-1.5a3-cp37-cp37m-linux_armv7l.whl (6.3 MB)
                        Collecting xbox-webapi>=1.1.8
                          Using cached xbox_webapi-1.1.8-py2.py3-none-any.whl (48 kB)
                        Collecting Flask
                          Using cached Flask-1.1.2-py2.py3-none-any.whl (94 kB)
                        Collecting cryptography==2.8
                          Downloading https://www.piwheels.org/simple/cryptography/cryptography-2.8-cp37-cp37m-linux_armv7l.whl (852 kB)
                        Collecting marshmallow-objects
                          Using cached marshmallow_objects-2.3.0-py3-none-any.whl (6.7 kB)
                        Collecting dpkt
                          Using cached dpkt-1.9.4-py3-none-any.whl (149 kB)
                        Collecting construct==2.10.56
                          Downloading https://www.piwheels.org/simple/construct/construct-2.10.56-py3-none-any.whl (56 kB)
                        Collecting greenlet>=0.4.14; platform_python_implementation == "CPython"
                          Downloading https://www.piwheels.org/simple/greenlet/greenlet-0.4.17-cp37-cp37m-linux_armv7l.whl (47 kB)
                        Collecting appdirs
                          Using cached appdirs-1.4.4-py2.py3-none-any.whl (9.6 kB)
                        Collecting urwid
                          Downloading https://www.piwheels.org/simple/urwid/urwid-2.1.1-cp37-cp37m-linux_armv7l.whl (258 kB)
                        Requirement already satisfied: requests in /usr/lib/python3/dist-packages (from xbox-webapi>=1.1.8->xbox-smartglass-core>=1.2.2) (2.21.0)
                        Collecting demjson
                          Downloading https://www.piwheels.org/simple/demjson/demjson-2.2.4-py3-none-any.whl (60 kB)
                        Collecting itsdangerous>=0.24
                          Using cached itsdangerous-1.1.0-py2.py3-none-any.whl (16 kB)
                        Collecting click>=5.1
                          Using cached click-7.1.2-py2.py3-none-any.whl (82 kB)
                        Collecting Werkzeug>=0.15
                          Using cached Werkzeug-1.0.1-py2.py3-none-any.whl (298 kB)
                        Collecting Jinja2>=2.10.1
                          Using cached Jinja2-2.11.2-py2.py3-none-any.whl (125 kB)
                        Requirement already satisfied: six>=1.4.1 in /usr/lib/python3/dist-packages (from cryptography==2.8->xbox-smartglass-core>=1.2.2) (1.12.0)
                        Collecting cffi!=1.11.3,>=1.8
                          Downloading https://www.piwheels.org/simple/cffi/cffi-1.14.3-cp37-cp37m-linux_armv7l.whl (345 kB)
                        Collecting marshmallow>=3.0.0
                          Using cached marshmallow-3.8.0-py2.py3-none-any.whl (46 kB)
                        Collecting MarkupSafe>=0.23
                          Downloading https://www.piwheels.org/simple/markupsafe/MarkupSafe-1.1.1-cp37-cp37m-linux_armv7l.whl (33 kB)
                        Collecting pycparser
                          Using cached pycparser-2.20-py2.py3-none-any.whl (112 kB)
                        Installing collected packages: greenlet, gevent, appdirs, urwid, demjson, xbox-webapi, itsdangerous, click, Werkzeug, MarkupSafe, Jinja2, Flask, pycparser, cffi, cryptography, marshmallow, marshmallow-objects, dpkt, construct, xbox-smartglass-core
                        Successfully installed Flask-1.1.2 Jinja2-2.11.2 MarkupSafe-1.1.1 Werkzeug-1.0.1 appdirs-1.4.4 cffi-1.14.3 click-7.1.2 construct-2.10.56 cryptography-2.8 demjson-2.2.4 dpkt-1.9.4 gevent-1.5a3 greenlet-0.4.17 itsdangerous-1.1.0 marshmallow-3.8.0 marshmallow-objects-2.3.0 pycparser-2.20 urwid-2.1.1 xbox-smartglass-core-1.2.2 xbox-webapi-1.1.8
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
                        + iobroker.xbox@0.6.8
                        added 1 package from 1 contributor and removed 1702 packages in 77.297s
                        npm update hatt die WARN auch nicht weg bekommen- ist aber wenn ich das hier richtig lese nur für WIN User wichtig.
                        Unsupported platform for fsevents@1.0.14: wanted
                          @foxriver76 falls es etwas nutzt:
                          In der _bootstrap.py Zeile 72 steht dann: "if lock is None:" Leider reichen meine Linux Kenntnisse hier bei weitem nicht aus 😞 74 wäre dann "tid = lock.owner"
                              def has_deadlock(self):
                                  # Deadlock avoidance for concurrent circular imports.
                                  me = _thread.get_ident()
                                  tid = self.owner
                                  while True:
                                      lock = _blocking_on.get(tid)
                                      if lock is None:
                                          return False
                                      tid = lock.owner
                                      if tid == me:
                            Wenn die Xbox läuft kommt noch dieser Fehler:
                            xbox.0	2020-09-25 12:30:13.259	debug	(1823) [CONNECT] Ping response, but provided LiveID has not been discovered until now
                            xbox.0	2020-09-25 12:30:13.258	debug	(1823) [CONNECT] Check connection
                            xbox.0	2020-09-25 12:30:13.256	error	(1823) [DISCOVER] <=== connect ECONNREFUSED 127.0.0.1:5557
                            xbox.0	2020-09-25 12:30:13.248	debug	(1823) [DISCOVER] Searching for consoles
                            xbox.0	2020-09-25 12:30:13.245	debug	(1823) [PING] Xbox online
                            xbox.0	2020-09-25 12:30:13.243	debug	(1823) [CHECK] Auth is not established
                            xbox.0	2020-09-25 12:30:11.776	warn	(1823) [LOGIN] Connection refused, will try again
                            xbox.0	2020-09-25 12:30:11.775	debug	(1823) Could not parse body
                            xbox.0	2020-09-25 12:30:09.268	warn	(1823) [LOGIN] Connection refused, will try again
                              @foxriver76 Der Workaround bringt nichts, hast du noch eine Idee was ich testen kann, bzw. gehst du dem Problem aktuell noch nach?
                              • foxriver76
                                @Smallfeuer Es gibt mittlerweile zumindest ein Issue bei smartglass-core https://github.com/OpenXbox/xbox-smartglass-core-python/issues/42
                                foxt created this issue in OpenXbox/xbox-smartglass-core-python
                                closed SIGSEGV whenever I try to do anything. #42
                                  r0b1zZle last edited by r0b1zZle
                                  Gibt es schon Neuigkeiten? Stehe vor dem selben Problem.
                                  pi@raspi:~ $ /opt/iobroker/node_modules/iobroker.xbox/lib/../node_modules/nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server || /opt/iobroker/node_modules/iobroker.xbox/lib/../../nopy/src/nopy.js /opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server
                                  /usr/local/lib/python3.7/importlib/_bootstrap.py:219: RuntimeWarning: greenlet.greenlet size changed, may indicate binary incompatibility. Expected 72 from C header, got 76 from PyObject
                                  Traceback (most recent call last):
                                    File "/opt/iobroker/node_modules/iobroker.xbox/lib/../python_modules/bin/xbox-rest-server", line 5, in <module>
                                      from xbox.scripts.rest_server import main
                                    File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/scripts/rest_server.py", line 6, in <module>
                                      from xbox.scripts import main_cli  # noqa: E402
                                    File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/scripts/main_cli.py", line 20, in <module>
                                      from xbox.handlers import tui, gamepad_input, text_input, fallout4_relay
                                    File "/opt/iobroker/node_modules/iobroker.xbox/python_modules/lib/python3.7/site-packages/xbox/handlers/tui.py", line 8, in <module>
                                      import urwid
                                  ModuleNotFoundError: No module named 'urwid'
                                  pi@raspi:~ $ pip install "urwid==2.0.1"
                                  Requirement already satisfied: urwid==2.0.1 in ./.local/lib/python3.7/site-packages (2.0.1)
                                  foxriver76 S 2 Replies Last reply Reply Quote 0
                                  • foxriver76
                                    foxriver76 Developer @r0b1zZle last edited by
                                    @r0b1zZle es sind mittlerwele zwei Issues offen im smartglass package, habe nun auch nochmal was zu geschrieben. Kann von meiner Seite leider nichts machen.
                                      @foxriver76 Danke trotzdem für deine Mühe.
                                      @r0b1zZle Das Problem besteht bei mir noch immer. Wenn sich im Issue etwas tut wäre es toll eine Info zu bekommen. Würde mich dann nochmal ransetzen und probieren ob ich es zum Laufen bekomme. Aktuell scheint der Adapter sogar in die Alexa Skill Verbindung rein zu gretschen. Immer wenn ich den Adapter an hatte, kann ich den Skill neu installieren, dass er wieder läuft. Über Iobroker ist es immerhin möglich die Alexa Xbox devices einzuschalten, leider funktioniert die Rückmeldung zu langsam und ungenau. Ansonsten wäre das für die Steuerung eine alternative gewesen.
                                      Also Abwarten.....
                                        r0b1zZle @Smallfeuer last edited by r0b1zZle
                                        @Smallfeuer Hier steht noch, dass man ein Downgrade auf Greenlet 0.4.13 machen soll. Hat bei mir aber nichts gebracht, eventuell bei euch?
                                          @r0b1zZle
                                          @foxriver76
                                          • foxriver76
                                            @Smallfeuer Leider habe ich noch keine Rückmeldung zu der Authentifizierunggeschichte von Team Open Xbox, das möchte ich definitiv wieder verbessern. Ich hoffe die Series X is bald wieder im MS Store on stock, damit man sie mit Guthaben kaufen kann. 😉
                                              @foxriver76 Ja, das einloggen war etwas fehlerbehaftet und ist im weißen Screen von firefox geendet... eine schöne Bestätigung wäre da noch gut. Aber es läuft erstmal...👍
                                              Gibts hier irgendwo eine XBox billiger? 😊
                                              foxriver76 U 2 Replies Last reply Reply Quote 0
                                              xbox adapter
                                              2753
