    4. HM-Rega Systemvariable werden nicht gesetzt
    UNSOLVED HM-Rega Systemvariable werden nicht gesetzt
    • foxriver76
      foxriver76 Developer @knopers1 last edited by foxriver76
      @knopers1 zeig mal bitte das JSON nach dem Doppelpunkt. Synchronisierst du auch unsichtbare Variablen?
        knopers1 @foxriver76 last edited by knopers1
        @foxriver76 said in HM-Rega Systemvariable werden nicht gesetzt:
        Hi foxriver76,
        zb. die Gartentemperatur.
          "from": "system.adapter.hm-rega.0",
          "ts": 1601059037188,
          "user": "system.user.admin",
          "common": {
            "name": "Garten_Temperatur",
            "type": "number",
            "role": "state",
            "unit": "C",
            "desc": "Wemo Außentemperatur",
            "min": 0,
            "max": 70,
            "read": true,
            "write": true,
            "custom": {
              "history.0": {
                "enabled": true,
                "changesOnly": true,
                "debounce": 10000,
                "maxLength": 960,
                "retention": 259200,
                "changesRelogInterval": 0,
                "changesMinDelta": 0
          "native": {
            "Name": "Garten_Temperatur",
            "TypeName": "VARDP",
            "DPInfo": "Wemo Außentemperatur",
            "ValueUnit": "C",
            "ValueList": "",
            "ValueMin": 0,
            "ValueMax": 70,
            "ValueType": 4,
            "ValueSubType": 0
          "acl": {
            "object": 1638,
            "owner": "system.user.admin",
            "state": 1638
          "_id": "hm-rega.0.7570",
          "type": "state"
        oder
          "_id": "hm-rega.0.5022",
          "type": "state",
          "common": {
            "name": "Alarmanlage",
            "type": "boolean",
            "read": true,
            "write": true,
            "role": "state",
            "states": {
              "0": "unscharf",
              "1": "scharf"
          "native": {
            "Name": "Alarmanlage",
            "DPInfo": "",
            "ValueMin": null,
            "ValueMax": null,
            "ValueUnit": "",
            "ValueType": 2,
            "ValueSubType": 2,
            "ValueList": "unscharf;scharf"
          "ts": 1601059037187,
          "acl": {
            "object": 1636,
            "state": 1636
        oder
          "_id": "hm-rega.0.8915",
          "type": "state",
          "common": {
            "name": "Status_DutyCycle",
            "type": "number",
            "read": true,
            "write": true,
            "role": "state",
            "min": 0,
            "max": 100,
            "unit": "%",
            "custom": {
              "history.0": {
                "enabled": true,
                "debounce": 10000,
                "maxLength": 960,
          "native": {
            "Name": "Status_DutyCycle",
            "DPInfo": "",
            "ValueMin": 0,
            "ValueMax": 100,
            "ValueUnit": "%",
            "ValueType": 4,
            "ValueSubType": 0,
            "ValueList": ""
          "ts": 1601059037189,
          "acl": {
            "object": 1636,
            "state": 1636
        Den Hacken mit unsichtbaren Variablen habe ich erst bei der letzten HM-Rega Version entdeckt. Ich wußte auch nicht dass es unsichbare Variablen gibt.... Mit oder ohne den Hacken werden die Variablen nicht aktualisiert... Ich habe teilweise auch einige Variablen dort für meine Alarmanlage. Das muß laufen, deshalb bin ich bis jetzt bei der Version x.x.17 geblieben.
        • foxriver76
          @knopers1 ich meine das JSON aus dem log, nach Cannot parse answer for variables:
            @foxriver76
            hmm, im Log kommen keine weitere Informationen hinter dem :
            siehe selbst:
            2020-09-26 20:27:24.022 - info: host.raspberrypi iobroker Adapter "hm-rega" updated
            2020-09-26 20:27:24.301 - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2020-09-26 20:27:25.047 - info: host.raspberrypi iobroker exit 0
            2020-09-26 20:27:26.831 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 22671
            2020-09-26 20:27:29.021 - info: hm-rega.0 (22671) starting. Version 2.6.21 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.18.4, js-controller: 3.1.6
            2020-09-26 20:27:29.177 - info: hm-rega.0 (22671) [REGASCRIPTS] Successfully updated polling.fn
            2020-09-26 20:27:29.205 - info: hm-rega.0 (22671) [REGASCRIPTS] Successfully updated pollingInv.fn
            2020-09-26 20:27:29.220 - info: hm-rega.0 (22671) [REGASCRIPTS] Successfully updated variables.fn
            2020-09-26 20:27:29.228 - info: hm-rega.0 (22671) [REGASCRIPTS] Successfully updated variablesInv.fn
            2020-09-26 20:27:29.230 - info: hm-rega.0 (22671) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
            2020-09-26 20:27:29.547 - info: hm-rega.0 (22671) ReGaHSS 192.168.1.70 up
            2020-09-26 20:27:29.600 - info: hm-rega.0 (22671) time difference local-ccu 1s
            2020-09-26 20:27:29.661 - info: hm-rega.0 (22671) update favorites to enum.favorites
            2020-09-26 20:27:30.152 - info: hm-rega.0 (22671) got 31 programs
            2020-09-26 20:27:30.254 - info: hm-rega.0 (22671) added/updated 31 programs
            2020-09-26 20:27:30.255 - info: hm-rega.0 (22671) deleted 0 programs
            2020-09-26 20:27:30.422 - info: hm-rega.0 (22671) got 12 variables
            2020-09-26 20:27:30.688 - error: hm-rega.0 (22671) Cannot parse answer for variables:
            2020-09-26 20:27:31.061 - info: hm-rega.0 (22671) added/updated 1 objects
            2020-09-26 20:27:31.063 - info: hm-rega.0 (22671) request state values
            2020-09-26 20:27:32.626 - info: hm-rega.0 (22671) got state values
            Anbei noch zwei Bilder
            • foxriver76
              @knopers1 ist das im logfile oder aus dem admin rauskopiert? Admin ist immer abgeschnitten dann oben zb auf log herunterladen
                @foxriver76
                ich habe die Info aus dem Log heruntergeladen.
                die Version 2.6.21 habe ich dafür installiert.
                Danach wieder auf die 2.6.17 zurück, hierbei auch aus dem Log heruntergeladen.
                2020-09-26 20:37:18.331 - info: host.raspberrypi iobroker upgrade hm-rega@2.6.17
                2020-09-26 20:37:20.425 - info: host.raspberrypi iobroker Update hm-rega from @2.6.21 to @2.6.17
                2020-09-26 20:37:21.028 - info: host.raspberrypi iobroker NPM version: 6.14.6
                2020-09-26 20:37:21.030 - info: host.raspberrypi iobroker npm install iobroker.hm-rega@2.6.17 --loglevel error --prefix "/opt/iobroker" (System call)
                2020-09-26 20:37:43.453 - info: host.raspberrypi iobroker upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
                2020-09-26 20:37:43.545 - info: host.raspberrypi iobroker Update "system.adapter.hm-rega.0"
                2020-09-26 20:37:43.607 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=true)
                2020-09-26 20:37:43.612 - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 send kill signal
                2020-09-26 20:37:43.616 - info: hm-rega.0 (28031) Got terminate signal TERMINATE_YOURSELF
                2020-09-26 20:37:43.619 - info: hm-rega.0 (28031) terminating
                2020-09-26 20:37:43.620 - info: hm-rega.0 (28031) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2020-09-26 20:37:43.713 - info: host.raspberrypi iobroker upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
                2020-09-26 20:37:43.771 - info: host.raspberrypi iobroker upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
                2020-09-26 20:37:43.829 - info: host.raspberrypi iobroker upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
                2020-09-26 20:37:43.886 - info: host.raspberrypi iobroker Adapter "hm-rega" updated
                2020-09-26 20:37:44.177 - info: host.raspberrypi instance system.adapter.hm-rega.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2020-09-26 20:37:44.911 - info: host.raspberrypi iobroker exit 0
                2020-09-26 20:37:46.695 - info: host.raspberrypi instance system.adapter.hm-rega.0 started with pid 29866
                2020-09-26 20:37:49.194 - info: hm-rega.0 (29866) starting. Version 2.6.17 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v12.18.4, js-controller: 3.1.6
                2020-09-26 20:37:49.327 - info: hm-rega.0 (29866) [REGASCRIPTS] Successfully updated polling.fn
                2020-09-26 20:37:49.335 - info: hm-rega.0 (29866) [REGASCRIPTS] Successfully updated pollingInv.fn
                2020-09-26 20:37:49.350 - info: hm-rega.0 (29866) [REGASCRIPTS] Successfully updated variables.fn
                2020-09-26 20:37:49.357 - info: hm-rega.0 (29866) [REGASCRIPTS] Successfully updated variablesInv.fn
                2020-09-26 20:37:49.359 - info: hm-rega.0 (29866) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
                2020-09-26 20:37:49.878 - info: hm-rega.0 (29866) ReGaHSS 192.168.1.70 up
                2020-09-26 20:37:49.952 - info: hm-rega.0 (29866) time difference local-ccu 1s
                2020-09-26 20:37:49.992 - info: hm-rega.0 (29866) update favorites to enum.favorites
                2020-09-26 20:37:50.411 - info: hm-rega.0 (29866) got 31 programs
                2020-09-26 20:37:50.508 - info: hm-rega.0 (29866) added/updated 31 programs
                2020-09-26 20:37:50.509 - info: hm-rega.0 (29866) deleted 0 programs
                2020-09-26 20:37:50.649 - info: hm-rega.0 (29866) got 12 variables
                2020-09-26 20:37:51.034 - info: hm-rega.0 (29866) added/updated 12 variables
                2020-09-26 20:37:51.034 - info: hm-rega.0 (29866) deleted 0 variables
                2020-09-26 20:37:51.436 - info: hm-rega.0 (29866) added/updated 1 objects
                2020-09-26 20:37:51.437 - info: hm-rega.0 (29866) request state values
                2020-09-26 20:37:53.232 - info: hm-rega.0 (29866) got state values
                • foxriver76
                  @knopers1 ok führe mal bitte das folgende Skript auf deiner CCU aus und zeige dir Ausgabe.
                  https://raw.githubusercontent.com/ioBroker/ioBroker.hm-rega/master/regascripts/variables.fn
                    @foxriver76
                    ehh, ich kann Dir echt leider nicht weiterhelfen......
                    Das Script ist kopiert und ausgeführt. Es kommt keine Ausgabe! Ich habe auch die CCU neugestartet. Nichts...
                    Die standart WriteLine("Hallo Welt!");, bring sofort die Ausgabe...
                    Die Variable "Status_Duty Cycles" ist ein Script auf der CCU2
                    Die Garten_Temperatur und das andere Zeug... kommt von der Selbstbau-Wetterstation.
                    Die Daten werden alle 30.min an die CCU übertragen und als Systemvariable ausgegeben.
                    Ich würde gerne Dir weiter helfen, nur wie?
                    K foxriver76 2 Replies Last reply Reply Quote 0
                      knopers1 @knopers1 last edited by knopers1
                      Hilft Dir diese Ausgabe weiter?
                      Script:
                      !# variablesInv.fn 0.1
                      !# Dieses Script gibt die Systemvariablen (inklusive unsichtbarer) als JSON String aus
                      !# 7'2019 foxriver76 https://github.com/foxriver76 [basierend auf variables.fn (hobbyquaker)]
                      object oSysVar;
                      string sSysVarId;
                      string sValueType;
                      string sValue;
                      boolean bFirst = true;
                      Write('{');
                      !# due to the fact that service messages can be automatically acknowledged, we have to loop over all and check
                      var servs = dom.GetObject(ID_SERVICES);
                      string id;
                      integer serviceMessages = 0;
                      foreach(id, servs.EnumIDs())
                        var service = dom.GetObject(id);
                        if(service)
                          if(service.IsTypeOf(OT_ALARMDP) && (service.Used() == true) && (service.Enabled() == true) && (service.AlState() == asOncoming))
                            serviceMessages = serviceMessages + 1;
                      WriteLine('"40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":' # dom.GetObject(40).Value() # ',"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},');
                      Write('"41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":' # serviceMessages # ',"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""}');
                      foreach (sSysVarId, dom.GetObject(ID_SYSTEM_VARIABLES).EnumIDs()) {
                        WriteLine(',');
                        oSysVar     = dom.GetObject(sSysVarId);
                        sValueType  = oSysVar.ValueType();
                        Write('"' # sSysVarId # '":{"Name":"');
                        WriteURL(oSysVar.Name());
                        Write('","TypeName":"' # oSysVar.TypeName());
                        Write('","DPInfo":"');
                        WriteURL(oSysVar.DPInfo());
                        Write('","Value":');
                        if (sValueType == 20) {
                          Write('"');
                        	WriteURL(oSysVar.Value());
                          Write('"');
                        } else {
                          sValue = oSysVar.Value();
                          if (sValueType == 2) {
                              if (sValue) {
                                  Write("true");
                              } else {
                                  Write("false");
                          } else {
                             if (sValue == "") {
                                  Write("0");
                             } else {
                                  Write(sValue);
                        string sValueMin = oSysVar.ValueMin();
                        if (sValueMin == '') {
                            sValueMin = 'null';
                        string sValueMax = oSysVar.ValueMax();
                        if (sValueMax == '') {
                            sValueMax = 'null';
                        Write(',"Timestamp":"' # oSysVar.Timestamp());
                        Write('","ValueMin":' # sValueMin # ',"ValueMax":' # sValueMax # ',"ValueUnit":"');
                        WriteURL(oSysVar.ValueUnit());
                        Write('","ValueType":' # sValueType # ',"ValueSubType":' # oSysVar.ValueSubType());
                          Write(',"ValueList":"');
                          WriteURL(oSysVar.ValueName0() # ';' # oSysVar.ValueName1());
                        } else {
                          WriteURL(oSysVar.ValueList());
                        Write('"}');
                      Write('}');
                      {"40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                      "41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":0,"ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                      "1233":{"Name":"Alarm","TypeName":"ALARMDP","DPInfo":"Alarmzustand","Value":false,"Timestamp":"1970-01-01 01:00:00","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":6,"ValueList":"nicht%20ausgel%F6st%3Bausgel%F6st"},
                      "5022":{"Name":"Alarmanlage","TypeName":"VARDP","DPInfo":"","Value":false,"Timestamp":"2020-09-27 12:10:33","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":2,"ValueList":"unscharf%3Bscharf"},
                      "40":{"Name":"Alarmmeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Alarmmeldungen","Value":0,"Timestamp":"2020-09-27 12:10:14","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                      "950":{"Name":"Anwesenheit","TypeName":"VARDP","DPInfo":"Anwesenheit","Value":true,"Timestamp":"2020-09-27 12:10:22","ValueMin":null,"ValueMax":null,"ValueUnit":"","ValueType":2,"ValueSubType":2,"ValueList":"nicht%20anwesend%3Banwesend"},
                      "7572":{"Name":"Garten_Akku","TypeName":"VARDP","DPInfo":"","Value":3.600000,"Timestamp":"2020-09-27 13:25:14","ValueMin":0,"ValueMax":5,"ValueUnit":"Volt","ValueType":4,"ValueSubType":0,"ValueList":""},
                      "7573":{"Name":"Garten_Hoehenmeter","TypeName":"VARDP","DPInfo":"","Value":23.990000,"Timestamp":"2020-09-27 13:25:14","ValueMin":0,"ValueMax":3500,"ValueUnit":"m","ValueType":4,"ValueSubType":0,"ValueList":""},
                      "7575":{"Name":"Garten_Luftdruck","TypeName":"VARDP","DPInfo":"","Value":999.410000,"Timestamp":"2020-09-27 13:25:14","ValueMin":0,"ValueMax":1200,"ValueUnit":"hPa","ValueType":4,"ValueSubType":0,"ValueList":""},
                      "7576":{"Name":"Garten_Luftfeuchtigkeit","TypeName":"VARDP","DPInfo":"","Value":82.050000,"Timestamp":"2020-09-27 13:25:14","ValueMin":0,"ValueMax":100,"ValueUnit":"%25","ValueType":4,"ValueSubType":0,"ValueList":""},
                      "7574":{"Name":"Garten_rel_Luftdruck","TypeName":"VARDP","DPInfo":"","Value":1002.260000,"Timestamp":"2020-09-27 13:25:14","ValueMin":0,"ValueMax":1200,"ValueUnit":"hPa","ValueType":4,"ValueSubType":0,"ValueList":""},
                      "7570":{"Name":"Garten_Temperatur","TypeName":"VARDP","DPInfo":"Wemo%20Au%DFentemperatur","Value":13.770000,"Timestamp":"2020-09-27 13:25:14","ValueMin":0,"ValueMax":70,"ValueUnit":"C","ValueType":4,"ValueSubType":0,"ValueList":""},
                      "41":{"Name":"Servicemeldungen","TypeName":"VARDP","DPInfo":"Anzahl%20Servicemeldungen","Value":0,"Timestamp":"2020-09-27 13:51:34","ValueMin":0,"ValueMax":65000,"ValueUnit":"","ValueType":16,"ValueSubType":0,"ValueList":""},
                      "8915":{"Name":"Status_DutyCycle","TypeName":"VARDP","DPInfo":"","Value":14.000000,"Timestamp":"2020-09-27 13:50:01","ValueMin":0,"ValueMax":100,"ValueUnit":"%25","ValueType":4,"ValueSubType":0,"ValueList":""}}
                      • foxriver76
                        @knopers1 keine Ausgabe heißt auch keine Fehlermeldung? Einfach nichts? 😉
                        Hast du’s einfach unter Skript testen ausprobiert?
                          @foxriver76
                          genau! Ich habe das Script unter "Script testen" ausprobiert.... Es kam keine Ausgabe beim Ausführen...
                          Das Script weiter tiefer, brachte zumindest eine Ausgabe im Feld nach dem Ausführen...
                          Momentan läuft noch die HM-Rega 2.6.17 auf dem RPI, sollte ich mit der neusten Version testen das Script?
                          • foxriver76
                            @knopers1 Hm keine Ausgabe heißt ja eigentlich es läuft noch.. ansonsten müsste Ergebnis oder Fehler ausgegeben werden. Nur sollten die zwei Versionen sich nicht so unterscheiden, dass das eine ewig dauern würde..
                              @foxriver76
                              danke für Deine Hilfe...
                              Ich habe den RegaAdapter auf Debug gestellt.
                              Ca. 16:15 Uhr habe ich die 2.6.17 gestartet, danach die V2.6.22 installiert und neugestartet.
                              Das Log sieht jetzt gut aus, damit kannst Du bestimmt den Fehler eingrenzen....
                              Neues Textdokument (2).txt
                              hallo
                              1272
