    4. JavaScript
    5. HowTo Sharp Aquos Steuern
      MartyBr @Jey Cee last edited by
      @Jey-Cee
      Ich habe javascript mal auf debug gestellt:
      javascript.0	2020-09-27 16:06:11.522	info	(1091) received all states
      javascript.0	2020-09-27 16:06:11.472	info	(1091) received all objects
      javascript.0	2020-09-27 16:06:11.227	info	(1091) requesting all objects
      javascript.0	2020-09-27 16:06:11.227	info	(1091) requesting all states
      javascript.0	2020-09-27 16:06:11.226	debug	(1091) Loaded TypeScript definitions for request: ["node_modules/@types/request/package.json","node_modules/@types/request/index.d.ts"]
      javascript.0	2020-09-27 16:06:11.215	debug	(1091) Loaded TypeScript definitions for node: ["node_modules/@types/node/package.json","node_modules/@types/node/index.d.ts","node_modules/@types/node/base.d.ts","node_modules/@types/node/ts3.6/base
      javascript.0	2020-09-27 16:06:11.181	info	(1091) starting. Version 4.8.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.18.4, js-controller: 3.1.6
      javascript.0	2020-09-27 16:06:11.126	debug	(1091) Plugin sentry Initialize Plugin (enabled=true)
      javascript.0	2020-09-27 16:06:10.831	debug	(1091) statesDB connected
      javascript.0	2020-09-27 16:06:10.831	debug	(1091) States connected to redis: 127.0.0.1:9000
      javascript.0	2020-09-27 16:06:10.828	debug	(1091) States create System PubSub Client
      javascript.0	2020-09-27 16:06:10.827	debug	(1091) States create User PubSub Client
      javascript.0	2020-09-27 16:06:10.824	debug	(1091) Redis States: Use Redis connection: 127.0.0.1:9000
      javascript.0	2020-09-27 16:06:10.824	debug	(1091) objectDB connected
      javascript.0	2020-09-27 16:06:10.821	debug	(1091) Objects connected to redis: 127.0.0.1:9001
      javascript.0	2020-09-27 16:06:10.816	debug	(1091) Objects client initialize lua scripts
      javascript.0	2020-09-27 16:06:10.816	debug	(1091) Objects create User PubSub Client
      javascript.0	2020-09-27 16:06:10.815	debug	(1091) Objects create System PubSub Client
      javascript.0	2020-09-27 16:06:10.814	debug	(1091) Objects client ready ... initialize now
      javascript.0	2020-09-27 16:06:10.805	debug	(1091) Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.iobroker-test	2020-09-27 16:06:10.271	info	instance system.adapter.javascript.0 started with pid 1091
      host.iobroker-test	2020-09-27 16:06:07.778	info	instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      javascript.0	2020-09-27 16:06:07.299	debug	(1076) system.adapter.admin.0: logging true
      javascript.0	2020-09-27 16:06:07.264	info	(1076) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      javascript.0	2020-09-27 16:06:07.264	debug	(1076) Plugin sentry destroyed
      javascript.0	2020-09-27 16:06:07.264	info	(1076) terminating
      javascript.0	2020-09-27 16:06:07.263	info	(1076) Got terminate signal TERMINATE_YOURSELF
      host.iobroker-test	2020-09-27 16:06:07.261	info	stopInstance system.adapter.javascript.0 send kill signal
      host.iobroker-test	2020-09-27 16:06:07.258	info	stopInstance system.adapter.javascript.0 (force=false, process=true)
      javascript.0	2020-09-27 16:06:06.347	debug	(1076) system.adapter.admin.0: logging false
        MartyBr @MartyBr last edited by
        @Jey-Cee
        Der sharp-aquas wird leider nicht installiert.
        • Jey Cee
          Jey Cee Developer @MartyBr last edited by
          @MartyBr dann versuch es mal so:
          cd /opt/iobroker/node_modules/iobroker.javascript
          npm install sharp-aquos
            @Jey-Cee
            martin@iobroker-test:/opt/iobroker/node_modules/iobroker.javascript$ npm install sharp-aquos
            [sudo] Passwort für martin:
            + sharp-aquos@0.0.7
            added 1 package and audited 3 packages in 0.679s
            found 0 vulnerabilities
               │      New patch version of npm available! 6.14.6 → 6.14.8       │
               │   Changelog: https://github.com/npm/cli/releases/tag/v6.14.8   │
               │               Run npm install -g npm to update!                │
            Dann Javascript neugestartet und dein Script läuft 👍
            Vielen Dank
            • Jey Cee
              Ich hab das Skript angepasst, wichtige Änderung damit auch wirklich geschalten wird nach einer Abfrage.
                @Jey-Cee Ah, sehr gut. Das installiere ich dann mal schnell.
                  @Jey-Cee
                  Das Script ohne Fehler. Ich bekomme nur keine Daten. Wo wird denn der Admin und das Kennwort gesetzt? Ich kann mich nicht erinnern, dass ich im Fernseher ein Kennwort gesetzt habe.
                  Martin
                  • Jey Cee
                    @MartyBr ist fest hinterlegt. Gelesen wird ja nur der Aktuelle status von mute power und volume, angezeigt wird das in den selben Objekten mit denen du auch steuerst. Wenn du am TV zum Beispiel die Lautstärke änderst wird das dann in das Objekt in ioBroker geschrieben, aber mit einer Verzögerung von 15 Sekunden (oder was du eingestellt hast).
                      @Jey-Cee
                      Dann funktioniert das Script leider nicht an meinen LC-46LE830E nicht
                      Schade 😧
                      Danke trotzdem für deine Unterstützung. Plane für das nächste Jahr einen neuen von LG.
                      • Jey Cee
                        @MartyBr sagte in HowTo Sharp Aquos Steuern:
                        LC-46LE830E
                        Achso da war noch was:
                        Sharp Aquos Setup
                        • Ensure the television is turned on.
                        • Hit the 'Menu' button on your remote.
                        • Navigate to 'Initial Setup'
                        • Navigate to 'Internet Setup'
                        • Navigate to 'Aquos Remote Control'
                        • Enable the Remote Control functionality.
                        • Go to Detailed Settings and set a username/password.
                        M 2 Replies Last reply Reply Quote 1
                          @Jey-Cee
                          Okay, dann teste ich das mal.
                            @Jey-Cee Das war es!!!!!!!
                            Also funktioniert auch der LC-46LE830E
                            Vielen Dank und ein schönes Wochenende
                            Martin
                              @Jey-Cee
                              Planst du auch Steuerfunktionen für die Sharp Fernseher?
                              • Jey Cee
                                @MartyBr ich hab das Skript nur für jemand zusammen gezimmert und dachte ich stell das mal hier rein damit auch andere was davon haben.
                                Wenn da jemand erweitert nehme ich das gerne im ersten Post auf, aber von mir kommt da nichts weiter.
                                  Ankh_Morpork @Jey Cee last edited by
                                  @Jey-Cee das mit "weiteren Steuerungen" hab ich mir auch schon überlegt. Das will ich aber mal selber schaffen. 😆
                                  Danke dir nochmal für die tolle Arbeit.
                                  javascript template
                                  1590
