      dos1973 @Zefau last edited by
      @Zefau
      Bei mir klappt das nicht.
      192.168.10.10:8082/jarvis/index.html#socketPort=8084&keepParams=true
      Im Browser Ok, funktioniert.
      Von Homescreen: konnte keine Verbindungen herstellen
      • Zefau
        Zefau @dos1973 last edited by
        @dos1973 danke für die Details bzgl. des Fehlers mit dem Tab Vollbild. Jetzt konnte ich es nachstellen und beheben.
          crunchip Forum Testing Most Active @Zefau last edited by crunchip
          @Zefau meinst du die RAW vom Sensor selbst? brauchst dann von jeder Art Sensor?
          Tür/Fenster Sensor
          "type": "device",
          "common": {
          "name": "Haustür",
          "type": "MCCGQ11LM",
          "icon": "img/sensor_magnet_aq2.png"
          "native": {
          "id": "00158d00023700c4"
          "from": "system.adapter.zigbee.0",
          "user": "system.user.admin",
          "ts": 1601140687760,
          "_id": "zigbee.0.00158d00023700c4",
          "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          BWM
          "type": "device",
          "common": {
          "name": "Wohn/Esszimmer",
          "type": "RTCGQ11LM",
          "icon": "img/aqara_numan_body_sensor.png"
          "native": {
          "id": "00158d000236b3f9"
          "ts": 1601140687762,
          "_id": "zigbee.0.00158d000236b3f9",
          "acl": {
          "object": 1636,
          Klima
          "type": "device",
          "common": {
          "name": "Noel-Klima",
          "type": "WSDCGQ01LM",
          "icon": "img/sensor_ht.png"
          "native": {
          "id": "00158d000221a574"
          "ts": 1601140687763,
          "_id": "zigbee.0.00158d000221a574",
          "acl": {
          "object": 1636,
          Klima(mit Luftdruck)
          "type": "device",
          "common": {
          "name": "Bürofenster",
          "native": {
          "id": "00158d00036b3fef"
          "_id": "zigbee.0.00158d00036b3fef",
          "acl": {
          "object": 1636,
          Rauchmelder
          "type": "device",
          "common": {
          "name": "WZ-Rauchmelder",
          "type": "JTYJ-GD-01LM/BW",
          "icon": "img/smoke.png"
          "native": {
          "id": "00158d0001bbb0dd"
          "_id": "zigbee.0.00158d0001bbb0dd",
          "acl": {
          "object": 1636,
          Wasser-Sensor
          "type": "device",
          "common": {
          "name": "Wasserleg-Waschmaschine",
          "type": "SJCGQ11LM",
          "icon": "img/sensor_wleak_aq1.png"
          "native": {
          "id": "00158d00023368c4"
          "ts": 1601140687775,
          "_id": "zigbee.0.00158d00023368c4",
          "acl": {
          "object": 1636,
          Lichtsensor
          "type": "device",
          "common": {
          "name": "Lichtsensor-Süd",
          "type": "GZCGQ01LM",
          "icon": "img/lumi_sen_ill_mgl01.png"
          "native": {
          "id": "04cf8cdf3c7cf5ce"
          "_id": "zigbee.0.04cf8cdf3c7cf5ce",
          "acl": {
          "object": 1636,
          Steckdose
          "type": "device",
          "common": {
          "name": "Noel-Radio",
          "type": "AB3257001NJ",
          "icon": "img/lightify-plug.png"
          "native": {
          "id": "7cb03eaa0a087ff3"
          "ts": 1601140687759,
          "_id": "zigbee.0.7cb03eaa0a087ff3",
          "acl": {
          "object": 1636,
          • Zefau
            @dos1973 sagte in jarvis - just another remarkable vis:
            Das war nur ein Beispiel von mir. Ist das der Link, den ioBroker vom Dashboard aus öffnet? Also stimmt der abweichende Port mit 8084? Hast du https aktiviert?
              @Zefau
              Nee kein https.
              Aber der link funktioniert im Browser
                Ente @Dirk Gier last edited by
                Hallo an alle,
                hat noch jemand das Problem, das die Chartfunktion nicht funktioniert?
                • Zefau
                  wenn ich jetzt den Button setze - ENDE
                  ist es mit der v1.0.3 nun behoben?
                    @Zefau bekomme nur die 1.01 als Installation
                    • Zefau
                      Zefau @crunchip last edited by
                      @crunchip sagte in jarvis - just another remarkable vis:
                      Zigbee fehlen die eigentlichen trigger Datenpunkte der einzelnen Sensoren, um zu sehen ob/wann dieser ausgelöst hat(gelb markiert),
                      Mit v1.0.0-beta.10 habe ich die zusätzlichen Datenpunkte in Zigbee und Sonoff hinzugefügt. Magst du es mal testen?
                      crunchip 1 Reply Last reply Reply Quote 1
                      • Zefau
                        Zefau @dslraser last edited by
                        @dslraser sagte in jarvis - just another remarkable vis:
                        Ich muß das später machen. Ich bin gleich erstmal wech...
                        Einen ersten Wurf kannst du mit v1.0.0-beta.10 testen. Danke dir.
                          @Zefau
                          mit dem Update auf 103, funktioniert der Fullscreenmodus!
                            dos1973 @dos1973 last edited by dos1973
                            @Zefau
                            ich hätte da noch etwas ...
                            so schaut es auf meinem iPad aus... iPad Air IOS 14.0
                            eigentlich müsse die Kachel über die volle Breite gehen:
                            • Zefau
                              Wie sieht die Layout (nicht Widget) Konfiguration aus? Bitte immer möglichst viele Informationen.
                              • I
                                iR0fl @Bielefelder81 last edited by
                                @Bielefelder81
                                Wenn man Tomaten auf den Augen hat... ich habe da wie verrückt rumgesucht und mdirobot-vacuum, oder auch irgendwelche URLs eingetragen. 😵
                                Das kann ich habe auch noch irgendetwas über npm auf dem Pi installiert, aber was solls 🤦
                                Danke Dir!
                                  @Zefau
                                  anbei die Screenshots
                                  im Browser wird die Kachel auf voller Breite angezeigt
                                    @Zefau mit den Datenpunkten sieht es nun gut aus.
                                    Jetzt hab ich auch die Geräte importiert, jedoch steh ich bei folgendem Problem, ich kann keine Auswählen.
                                    edit: hab jetzt doch mal den Ordner gelöscht, jetzt funktioniert es
                                      WW1983 last edited by
                                      Wenn ich Jarvis auf dem Homebildschirm ablege (iPhone oder iPad). Die App starten will, diese aber vorher schonmal auf war, dann erscheint Jarvis kurz und anschließend ein weißer Bildschirm. Erst wenn ich die App vollständig im Hintergrund schließe, dann funktioniert es.
                                        robbyrc @WW1983 last edited by
                                        @WW1983 Das habe ich auch. Tritt auch mit der iobroker-App auf. In der iobroker-App hilft hier das Runterziehen vom Bildschirm, damit die Seite komplett neu geladen wird.
                                          WW1983 @robbyrc last edited by
                                          @robbyrc said in jarvis - just another remarkable vis:
                                          Ah ok. mit der IoBroker App habe ich es noch nicht probiert.
                                            Ente @Ente last edited by
                                            @Ente said in jarvis - just another remarkable vis:
                                            Hallo an alle,
                                            Hat sich irgendwie von alleine gelöst. Wird jetzt grafisch angezeigt.
                                            316
                                            6126
                                            4116935
