    4. IoBroker startet nach Xiaomi Adapter Installation nicht mehr
    UNSOLVED IoBroker startet nach Xiaomi Adapter Installation nicht mehr
      Thomas Braun Most Active @SG_IoBroker last edited by Thomas Braun
      @SG_IoBroker
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      Kannst auch mal schauen, was da so läuft:
      ps aux | grep io.
        SG_IoBroker @Thomas Braun last edited by
        npm WARN rollback Rolling back iobroker.js-controller@3.1.6 failed (this is probably harmless): EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/node_modules/debug/src/browser.js'
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm ERR! code EACCES
        npm ERR! syscall unlink
        npm ERR! path /opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json
        npm ERR! errno -13
        npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json'
        npm ERR!  { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json']
        npm ERR!   cause:
        npm ERR!    { Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json'
        npm ERR!      errno: -13,
        npm ERR!      code: 'EACCES',
        npm ERR!      syscall: 'unlink',
        npm ERR!      path:
        npm ERR!       '/opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json' },
        npm ERR!   stack:
        npm ERR!    'Error: EACCES: permission denied, unlink \'/opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json\'',
        npm ERR!   path:
        npm ERR!    '/opt/iobroker/node_modules/.iobroker.js-controller.DELETE/conf/iobroker-dist.json',
        npm ERR!   parent: 'iobroker' }
        npm ERR!
        npm ERR! The operation was rejected by your operating system.
        npm ERR! It is likely you do not have the permissions to access this file as the current user
        npm ERR!
        npm ERR! If you believe this might be a permissions issue, please double-check the
        npm ERR! permissions of the file and its containing directories, or try running
        npm ERR! the command again as root/Administrator.
        npm ERR!     /home/iobroker/.npm/_logs/2020-09-27T18_12_59_224Z-debug.log
        S Thomas Braun 2 Replies Last reply Reply Quote 0
          SG_IoBroker @SG_IoBroker last edited by
          @SG_IoBroker
          root        10  0.0  0.0      0     0 ?        S    19:40   0:00 [migration/0]
          root        13  0.0  0.0      0     0 ?        S    19:40   0:00 [migration/1]
          root        18  0.0  0.0      0     0 ?        S    19:40   0:00 [migration/2]
          root        23  0.0  0.0      0     0 ?        S    19:40   0:00 [migration/3]
          root       445  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       595  0.0  0.0      0     0 ?        S<   19:40   0:00 [rpciod]
          root       618  0.0  0.0      0     0 ?        S<   19:40   0:00 [nfsiod]
          root       619  0.0  0.0      0     0 ?        S<   19:40   0:00 [cifsiod]
          root       720  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       721  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       722  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       723  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       724  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       725  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       726  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       727  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       728  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       729  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       730  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       731  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       732  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       733  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       734  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       735  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       769  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       772  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       775  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       778  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       781  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       784  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       787  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       790  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       794  0.0  0.0      0     0 ?        S<   19:40   0:00 [bioset]
          root       945  0.0  0.0      0     0 ?        S<   19:41   0:00 [dm_bufio_cache]
          root       954  0.0  0.0      0     0 ?        S<   19:41   0:00 [bioset]
          root       963  0.0  0.0      0     0 ?        S<   19:41   0:00 [bioset]
          root       965  0.0  0.0      0     0 ?        S<   19:41   0:00 [bioset]
          root       967  0.0  0.0      0     0 ?        S<   19:41   0:00 [bioset]
          root      1105  0.0  0.0      0     0 ?        S<   19:41   0:00 [bioset]
          message+  1510  0.0  0.3   6600  3656 ?        Ss   19:41   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
          root      1962  0.0  0.6  29608  6232 ?        Sl   19:41   0:00 lightdm --session-child 14 17
          pi        1998  0.0  1.1  50692 11244 ?        Ssl  19:41   0:00 /usr/bin/lxses ion -s LXDE-pi -e LXDE
          pi        2008  0.0  0.3   6504  3532 ?        Ss   19:41   0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation
          pi        2113  0.0  0.0   3796   220 ?        Ss   19:41   0:00 /usr/bin/ssh-agent x-session-manager
          pi       13260  0.0  0.0   4376   544 pts/0    S+   20:14   0:00 grep --color=auto io.
            @SG_IoBroker
            sudo whoami
            groups
            who -r
              @Thomas-Braun
              pi@Banana-Pi:/opt/iobroker $ sudo whoami
              root
              pi@Banana-Pi:/opt/iobroker $ groups
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              pi@Banana-Pi:/opt/iobroker $ who -r
                       run-level 5  2020-09-27 19:42
                @SG_IoBroker Du gehst doch eh per SSH auf die Kiste. Warum läuft die dann in RunLevel5? Stell die auf RL3 um.
                Kann es sein, dass das Dateisystem nur lesend eingehängt ist?
                mount | sort
                Kannst auch mal in die
                dmesg
                reinschauen.
                  Wildbill @Thomas Braun last edited by
                  @Thomas-Braun @SG_IoBroker War da nicht was, dass die Fehlermeldung "EACCES" auf eine sterbende SD-Karte hindeutet? Würde auch erklären, warum das Filesystem nur noch readonly eingehängt ist.
                  Gruss, Jürgen
                  Thomas Braun S 2 Replies Last reply Reply Quote 0
                    Thomas Braun Most Active @Wildbill last edited by
                    @Wildbill
                    Ist es das? Ich habe noch keine Rückmeldung dahingehend gesehen.
                    Allerdings deutet
                    das auch auf ein ro-gemountetes Filesystem hin. Er kam ja eigentlich mit entsprechenden Rechten an.
                      SG_IoBroker @Wildbill last edited by
                      @Wildbill
                      pi@Banana-Pi:/opt/iobroker $ mount | sort
                      cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
                      cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
                      cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
                      cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
                      cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
                      cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
                      cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
                      cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
                      cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
                      cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
                      configfs on /sys/kernel/config type configfs (rw,relatime)
                      debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                      /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
                      /dev/mmcblk0p2 on / type ext4 (rw,noatime,block_validity,delalloc,barrier,user_xattr,acl,stripe=1024)
                      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
                      fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
                      gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
                      mqueue on /dev/mqueue type mqueue (rw,relatime)
                      proc on /proc type proc (rw,relatime)
                      pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
                      securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
                      selinuxfs on /sys/fs/selinux type selinuxfs (rw,relatime)
                      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
                      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
                      tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=102148k,mode=755)
                      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=102144k,mode=700,uid=1000,gid=1000)
                      tmpfs on /run/user/999 type tmpfs (rw,nosuid,nodev,relatime,size=102144k,mode=700,uid=999,gid=996)
                      tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
                      udev on /dev type devtmpfs (rw,nosuid,relatime,size=376616k,nr_inodes=94154,mode=755)
                      pi@Banana-Pi:/opt/iobroker $ dmesg
                      [ 2184.462617] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2189.783982] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2189.784009] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2195.114235] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2195.114262] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2200.474468] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2200.474495] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2205.814694] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2205.814722] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2211.154596] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2211.154621] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2216.515188] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2216.515216] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2221.835124] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2221.835149] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2227.206081] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2227.206110] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2232.575610] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2232.575634] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2237.936231] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2237.936258] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2243.296164] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2243.296189] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2248.656309] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2248.656334] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2254.017136] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2254.017166] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2259.376773] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2259.376798] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2264.717655] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2264.717684] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2270.057269] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2270.057295] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2275.408093] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2275.408122] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2280.737765] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2280.737790] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2286.097218] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2286.097238] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2291.408813] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2291.408843] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2296.758756] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2296.758783] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2302.128976] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2302.129003] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2307.488870] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2307.488894] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2312.859438] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2312.859465] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2318.239642] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2318.239669] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2323.610139] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2323.610170] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2328.940202] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2328.940230] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2334.320662] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2334.320692] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2339.680589] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2339.680616] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2345.021157] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2345.021186] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2350.360647] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2350.360673] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2355.721181] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2355.721209] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2361.081092] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2361.081117] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2366.421621] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2366.421647] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2371.791919] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2371.791946] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2377.132169] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2377.132197] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2382.512631] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2382.512660] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2387.852540] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2387.852568] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2393.223079] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2393.223110] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2398.562624] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2398.562649] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2403.943144] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2403.943171] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2409.323754] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2409.323784] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2414.683250] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2414.683275] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2420.023807] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2420.023834] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2425.373997] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2425.374023] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2430.724542] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2430.724571] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2436.094300] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2436.094324] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2441.454601] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2441.454628] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2446.825090] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2446.825119] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2452.154888] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2452.154913] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2457.515609] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2457.515639] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2462.855528] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2462.855555] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2468.215923] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2468.215952] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2473.565503] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2473.565529] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2478.916403] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2478.916434] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2484.265978] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2484.266004] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2489.636524] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2489.636550] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2494.986355] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2494.986380] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2500.327182] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2500.327211] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2505.696747] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2505.696772] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2511.027293] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2511.027321] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2516.387206] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2516.387232] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2521.727703] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2521.727731] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2527.086863] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2527.086884] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2532.397729] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2532.397754] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2537.748317] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2537.748345] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2543.098469] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2543.098496] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2548.439051] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2548.439080] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2553.819143] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2553.819173] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2559.158788] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2559.158814] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2564.539295] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2564.539323] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2569.919733] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2569.919763] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2575.249634] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2575.249661] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2580.599503] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2580.599528] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2585.940044] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2585.940071] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2591.309903] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2591.309928] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2596.680389] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2596.680417] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2602.030984] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2602.031013] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2607.360501] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2607.360527] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2612.711013] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2612.711041] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2618.081221] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2618.081249] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2623.431371] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2623.431399] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2628.781211] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2628.781236] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2634.122123] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2634.122153] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2639.471897] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2639.471925] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2644.822504] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2644.822533] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2650.171947] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2650.171972] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2655.522732] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2655.522761] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2660.882684] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2660.882712] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2666.242807] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2666.242834] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2671.623320] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2671.623350] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2677.002944] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2677.002969] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2682.333690] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2682.333719] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2687.703264] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2687.703289] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2693.034341] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2693.034372] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2698.373998] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2698.374024] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2703.734385] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2703.734415] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2709.094021] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2709.094046] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2714.434781] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2714.434810] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2719.774698] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2719.774726] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2725.144842] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2725.144869] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2730.494683] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2730.494708] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2735.825560] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2735.825588] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2741.165432] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2741.165460] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2746.545559] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2746.545587] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2751.905472] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2751.905498] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2757.236216] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2757.236246] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2762.595775] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2762.595801] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2767.946278] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2767.946305] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2773.286387] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2773.286414] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2778.646550] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2778.646577] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2784.027160] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2784.027190] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2789.366650] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2789.366675] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2794.736987] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2794.737012] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2800.117034] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2800.117060] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2805.467474] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2805.467502] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2810.828019] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2810.828048] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2816.167882] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2816.167910] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2821.528323] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2821.528353] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2826.898245] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2826.898272] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2832.238332] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2832.238360] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2837.578192] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2837.578218] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2842.938725] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2842.938752] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2848.288508] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2848.288533] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2853.649407] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2853.649436] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2859.019002] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2859.019028] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2864.399123] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2864.399148] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2869.759588] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2869.759616] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2875.109482] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2875.109508] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2880.459950] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2880.459977] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2885.840059] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2885.840086] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2891.179964] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2891.179989] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2896.540418] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2896.540446] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2901.900284] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2901.900310] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2907.241237] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2907.241266] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2912.600917] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2912.600944] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2917.941089] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2917.941117] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2923.280937] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2923.280963] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2928.631777] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2928.631806] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2933.981629] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2933.981656] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2939.342075] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2939.342104] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2944.701975] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2944.702002] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2950.042410] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2950.042439] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2955.382285] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2955.382313] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2960.752364] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2960.752392] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2966.072412] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2966.072437] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2971.442770] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2971.442798] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2976.782576] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2976.782601] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2982.153099] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2982.153127] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2987.533555] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2987.533584] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2992.863441] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2992.863469] _cpu_up: attempt to bring up CPU 3 failed
                      [ 2998.233819] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 2998.233850] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3003.573760] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3003.573788] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3008.944254] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3008.944283] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3014.303701] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3014.303726] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3019.644215] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3019.644243] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3025.004030] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3025.004055] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3030.364594] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3030.364621] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3035.740606] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3035.740637] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3041.104571] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3041.104596] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3046.445332] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3046.445361] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3051.804857] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3051.804882] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3057.145650] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3057.145678] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3062.485183] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3062.485209] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3067.835941] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3067.835970] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3073.205513] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3073.205538] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3078.546328] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3078.546357] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3083.906202] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3083.906229] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3089.246404] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3089.246431] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3094.606152] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3094.606177] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3099.956654] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3099.956682] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3105.316806] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3105.316833] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3110.667055] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3110.667083] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3116.037430] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3116.037459] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3121.367002] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3121.367027] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3126.737712] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3126.737741] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3132.077325] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3132.077350] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3137.417495] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3137.417520] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3142.767938] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3142.767965] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3148.138375] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3148.138405] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3153.507950] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3153.507975] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3158.858439] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3158.858467] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3164.238835] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3164.238864] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3169.588368] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3169.588393] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3174.949163] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3174.949193] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3180.278804] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3180.278830] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3185.639520] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3185.639550] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3190.979309] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3190.979337] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3196.345428] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3196.345458] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3201.679635] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3201.679663] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3207.040137] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3207.040167] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3212.370042] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3212.370069] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3217.740401] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3217.740430] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3223.100321] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3223.100349] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3228.440704] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3228.440733] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3233.790830] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3233.790857] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3239.151075] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3239.151105] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3244.510889] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3244.510917] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3249.841348] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3249.841377] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3255.180966] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3255.180991] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3260.561698] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3260.561728] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3265.911200] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3265.911226] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3271.261751] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3271.261778] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3276.642088] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3276.642117] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3281.991654] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3281.991680] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3287.352451] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3287.352480] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3292.692296] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3292.692323] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3298.052726] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3298.052756] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3303.422654] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3303.422681] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3308.772760] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3308.772787] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3314.143204] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3314.143233] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3319.512770] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3319.512795] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3324.853216] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3324.853244] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3330.223375] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3330.223402] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3335.563500] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3335.563527] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3340.913777] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3340.913804] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3346.202710] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3346.202730] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3351.513706] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3351.513731] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3356.854452] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3356.854481] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3362.213994] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3362.214019] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3367.554686] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3367.554715] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3372.924679] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3372.924706] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3378.274756] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3378.274783] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3383.645302] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3383.645332] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3388.975129] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3388.975156] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3394.355498] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3394.355526] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3399.715014] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3399.715040] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3405.075532] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3405.075559] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3410.446027] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3410.446056] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3415.785780] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3415.785808] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3421.146225] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3421.146255] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3426.516170] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3426.516198] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3431.846576] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3431.846605] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3437.196401] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3437.196429] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3442.566555] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3442.566583] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3447.926703] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3447.926730] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3453.276854] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3453.276881] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3458.657016] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3458.657043] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3463.986998] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3463.987023] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3469.367398] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3469.367425] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3474.747765] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3474.747793] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3480.087438] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3480.087464] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3485.458024] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3485.458053] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3490.746921] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3490.746942] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3496.048441] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3496.048470] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3501.397950] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3501.397975] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3506.748632] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3506.748663] _cpu_up: attempt to bring up CPU 3 failed
                      [ 3512.128594] CPU Budget:reject cpu 3 to up,cluster0 online 3, limit 3
                      [ 3512.128624] _cpu_up: attempt to bring up CPU 3 failed
                        @SG_IoBroker
                        dmesg sieht merkwürdig aus.
                        sudo reboot
                        und dann unmittelbar nach dem Bootvorgang nochmal
                        dmesg
                          @Thomas-Braun
                          pi@Banana-Pi:~ $ dmesg
                          [    6.816523] sunxi-mmc sdc2: Failed getting OCR mask: 0
                          [    6.816730] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
                          [    6.816993] sunxi-mmc sdc2: ***set host ocr***
                          [    6.817284] sunxi-mmc sdc2: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.817587] sunxi-mmc sdc0: smc 0 p0 err, cmd 52, RTO !!
                          [    6.817623] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.820068] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.822240] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                          [    6.823072] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                          [    6.823905] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                          [    6.824737] sunxi-mmc sdc0: smc 0 p0 err, cmd 5, RTO !!
                          [    6.825395] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.827831] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.845857] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.865861] sunxi-mmc sdc2: detmode:alway in(non removable)
                          [    6.866372] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v1.15 2017-9-30 11:30)
                          [    6.866411] sunxi-mmc sdc1: Can't get vmmc regulator string
                          [    6.866417] sunxi-mmc sdc1: Can't get vqmmc regulator string
                          [    6.866423] sunxi-mmc sdc1: Can't get vdmmc regulator string
                          [    6.866429] sunxi-mmc sdc1: Failed getting OCR mask: 0
                          [    6.866871] sunxi-mmc sdc1: set host busy
                          [    6.866876] sunxi-mmc sdc1: ***set host ocr***
                          [    6.867148] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.883219] mmc0: host does not support reading read-only switch, assuming write-enable
                          [    6.885066] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                          [    6.885130] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                          [    6.885221] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                          [    6.885258] mmc0: new high speed SDHC card at address b368
                          [    6.886201] mmcblk0: mmc0:b368 CBADS 30.0 GiB
                          [    6.887992]  mmcblk0: p1 p2
                          [    6.890165] sunxi-mmc sdc2: smc 1 p2 err, cmd 52, RTO !!
                          [    6.891008] sunxi-mmc sdc2: smc 1 p2 err, cmd 52, RTO !!
                          [    6.891034] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.893526] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.895398] sunxi-mmc sdc2: smc 1 p2 err, cmd 8, RTO !!
                          [    6.895886] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.896234] sunxi-mmc sdc2: smc 1 p2 err, cmd 5, RTO !!
                          [    6.897073] sunxi-mmc sdc2: smc 1 p2 err, cmd 5, RTO !!
                          [    6.897903] sunxi-mmc sdc2: smc 1 p2 err, cmd 5, RTO !!
                          [    6.898732] sunxi-mmc sdc2: smc 1 p2 err, cmd 5, RTO !!
                          [    6.899565] sunxi-mmc sdc2: smc 1 p2 err, cmd 55, RTO !!
                          [    6.900396] sunxi-mmc sdc2: smc 1 p2 err, cmd 55, RTO !!
                          [    6.901235] sunxi-mmc sdc2: smc 1 p2 err, cmd 55, RTO !!
                          [    6.902065] sunxi-mmc sdc2: smc 1 p2 err, cmd 55, RTO !!
                          [    6.902088] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.902484] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.902541] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.904972] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.915871] sunxi-mmc sdc1: detmode:manually by software
                          [    6.916661] gpio_led_probe start
                          [    6.916696] led1 gpio number is 362
                          [    6.916701] led1_trigger led trigger name is heartbeat
                          [    6.916705] create_gpio_led
                          [    6.917098] ledtrig-cpu: registered to indicate activity on CPUs
                          [    6.917220] hidraw: raw HID events driver (C) Jiri Kosina
                          [    6.921231] usbcore: registered new interface driver usbhid
                          [    6.921235] usbhid: USB HID core driver
                          [    6.923393] ashmem: initialized
                          [    6.925226] usbcore: registered new interface driver snd-usb-audio
                          [    6.926436] sun8iw7p1-pinctrl pio: expect_func as:daudio0, but muxsel(2) is func:pcm0
                          [    6.926453] sun8iw7p1-pinctrl pio: expect_func as:daudio0, but muxsel(2) is func:pcm0
                          [    6.926467] sun8iw7p1-pinctrl pio: expect_func as:daudio0, but muxsel(2) is func:pcm0
                          [    6.926480] sun8iw7p1-pinctrl pio: expect_func as:daudio0, but muxsel(2) is func:pcm0
                          [    6.927865] failed get gpio-spdif gpio from dts,spdif_gpio:-2
                          [    6.931555] sunxi-codec-machine soc@01c00000:sound@0: sun8iw7codec <-> 1c22c00.cpudai0-controller mapping ok
                          [    6.936621] sndhdmi soc@01c00000:sound@3: audiohdmi-dai <-> 1c22800.daudio mapping ok
                          [    6.937172] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    6.941425] sndspdif soc@01c00000:sound@4: spdif-hifi <-> 1c21000.spdif-controller mapping ok
                          [    6.943928] oprofile: using timer interrupt.
                          [    6.944317] ipip: IPv4 over IPv4 tunneling driver
                          [    6.945222] ip_tables: (C) 2000-2006 Netfilter Core Team
                          [    6.949843] mmc1: MAN_BKOPS_EN bit is not set
                          [    6.967184] arp_tables: (C) 2002 David S. Miller
                          [    6.988762] Initializing XFRM netlink socket
                          [    7.046582] NET: Registered protocol family 10
                          [    7.060536] NET: Registered protocol family 17
                          [    7.060570] NET: Registered protocol family 15
                          [    7.060725] Bluetooth: RFCOMM TTY layer initialized
                          [    7.060745] Bluetooth: RFCOMM socket layer initialized
                          [    7.060782] Bluetooth: RFCOMM ver 1.11
                          [    7.060805] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                          [    7.060809] Bluetooth: BNEP filters: protocol multicast
                          [    7.060819] Bluetooth: BNEP socket layer initialized
                          [    7.060829] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
                          [    7.060839] Bluetooth: HIDP socket layer initialized
                          [    7.060962] Key type dns_resolver registered
                          [    7.060989] Key type ceph registered
                          [    7.072451] libceph: loaded (mon/osd proto 15/24)
                          [    7.075400] Registering SWP/SWPB emulation handler
                          [    7.076591] registered taskstats version 1
                          [    7.105874] sunxi-mmc sdc2: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
                          [    7.106356] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
                          [    7.106485] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-HS(SDR20) dt B
                          [    7.106646] sunxi-mmc sdc2: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 8 timing MMC-DDR52 dt B
                          [    7.106750] mmc1: new DDR MMC card at address 0001
                          [    7.107638] mmcblk1: mmc1:0001 8WPD3R 7.28 GiB
                          [    7.108074] mmcblk1boot0: mmc1:0001 8WPD3R partition 1 4.00 MiB
                          [    7.118601] mmcblk1boot1: mmc1:0001 8WPD3R partition 2 4.00 MiB
                          [    7.119893]  mmcblk1:
                          [    7.122866] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
                          [    7.123702] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
                          [    7.123729] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    7.126226] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    7.128103] sunxi-mmc sdc1: smc 2 p1 err, cmd 8, RTO !!
                          [    7.128934] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
                          [    7.129760] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
                          [    7.130586] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
                          [    7.131411] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RTO !!
                          [    7.132239] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
                          [    7.133064] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
                          [    7.133889] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
                          [    7.134714] sunxi-mmc sdc1: smc 2 p1 err, cmd 55, RTO !!
                          [    7.134739] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [    7.135613] sunxi-mmc sdc1: smc 2 p1 err, cmd 1, RTO !!
                          [    7.135639] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                          [    7.163181] Btrfs loaded, debug=on, assert=on, integrity-checker=on
                          [    7.163277] BTRFS: selftest: Running btrfs free space cache tests
                          [    7.163305] BTRFS: selftest: Running extent only tests
                          [    7.163336] BTRFS: selftest: Running bitmap only tests
                          [    7.163370] BTRFS: selftest: Running bitmap and extent tests
                          [    7.163418] BTRFS: selftest: Running space stealing from bitmap to extent
                          [    7.164219] BTRFS: selftest: Free space cache tests finished
                          [    7.164226] BTRFS: selftest: Running extent buffer operation tests
                          [    7.164226] BTRFS: selftest: Running btrfs_split_item tests
                          [    7.164292] BTRFS: selftest: Running find delalloc tests
                          [    7.617833] BTRFS: selftest: Running btrfs_get_extent tests
                          [    7.618332] BTRFS: selftest: Running hole first btrfs_get_extent test
                          [    7.618395] BTRFS: selftest: Running outstanding_extents tests
                          [    7.618510] BTRFS: selftest: Running qgroup tests
                          [    7.618513] BTRFS: selftest: Qgroup basic add
                          [    7.618629] BTRFS: selftest: Qgroup multiple refs test
                          [    7.724245] Key type encrypted registered
                          [    7.725013] [DISP] boot_disp:0x0
                          [    7.725094] [HDMI WRN] file:drivers/video/fbdev/sunxi/disp2/hdmi/drv_hdmi.c,line:782:
                          [    7.725095] hdmi_clk_enable
                          [    7.725898] [HDMI] cec support = 0
                          [    8.345878] [DISP] disp_device_attached_and_enable,line:189:
                          [    8.345879] attached ok, mgr0<-->device0, type=4, mode=4
                          [    9.226125] console [netcon0] enabled
                          [    9.233295] netconsole: network logging started
                          [    9.241624] sunxi-rtc rtc: setting system clock to 2020-09-27 18:56:46 UTC (1601233006)
                          [    9.254746] cma_shrinker get the ion misc device
                          [    9.270173] ALSA device list:
                          [    9.276833]   #0: audiocodec
                          [    9.283313]   #1: sndhdmi
                          [    9.289544]   #2: sndspdif
                          [    9.298062] Freeing unused kernel memory: 1024K (c1000000 - c1100000)
                          [    9.379688] random: systemd-udevd: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.385678] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.386105] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.386269] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.386797] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.387302] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.387786] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.389820] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.390426] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [    9.391023] random: udevadm: uninitialized urandom read (16 bytes read, 2 bits of entropy available)
                          [   10.700317] [ARISC ERROR] :message process error
                          [   10.714372] [ARISC ERROR] :message addr   : f004b940
                          [   10.725948] [ARISC ERROR] :message state  : 5
                          [   10.736741] [ARISC ERROR] :message attr   : 0
                          [   10.747401] [ARISC ERROR] :message type   : 30
                          [   10.758056] [ARISC ERROR] :message result : dc
                          [   10.768658] [ARISC WARING] :message [30] error, callback not install
                          [   11.055963] [cpu_freq] ERR: Set cpu frequency to 1008000KHz failed!
                          [   11.069134] cpufreq: __target_index: Failed to change cpu frequency: -1
                          [   11.184217] [ARISC ERROR] :message process error
                          [   11.193378] [ARISC ERROR] :message addr   : f004b940
                          [   11.202840] [ARISC ERROR] :message state  : 5
                          [   11.211592] [ARISC ERROR] :message attr   : 0
                          [   11.220322] [ARISC ERROR] :message type   : 30
                          [   11.229064] [ARISC ERROR] :message result : dc
                          [   11.237751] [ARISC WARING] :message [30] error, callback not install
                          [   11.910258] [ARISC ERROR] :message process error
                          [   11.919491] [ARISC ERROR] :message addr   : f004b940
                          [   11.929020] [ARISC ERROR] :message state  : 5
                          [   11.937766] [ARISC ERROR] :message attr   : 0
                          [   11.946408] [ARISC ERROR] :message type   : 30
                          [   11.955045] [ARISC ERROR] :message result : dc
                          [   11.963616] [ARISC WARING] :message [30] error, callback not install
                          [   12.255942] [cpu_freq] ERR: Set cpu frequency to 1008000KHz failed!
                          [   12.266719] cpufreq: __target_index: Failed to change cpu frequency: -1
                          [   12.831353] [ARISC ERROR] :message process error
                          [   12.839960] [ARISC ERROR] :message addr   : f004b940
                          [   12.848898] [ARISC ERROR] :message state  : 5
                          [   12.857150] [ARISC ERROR] :message attr   : 0
                          [   12.865288] [ARISC ERROR] :message type   : 30
                          [   12.873320] [ARISC ERROR] :message result : dc
                          [   12.881168] [ARISC WARING] :message [30] error, callback not install
                          [   12.991360] [ARISC ERROR] :message process error
                          [   12.999736] [ARISC ERROR] :message addr   : f004b940
                          [   13.008466] [ARISC ERROR] :message state  : 5
                          [   13.016535] [ARISC ERROR] :message attr   : 0
                          [   13.024626] [ARISC ERROR] :message type   : 30
                          [   13.032832] [ARISC ERROR] :message result : dc
                          [   13.041060] [ARISC WARING] :message [30] error, callback not install
                          [   13.311406] [ARISC ERROR] :message process error
                          [   13.321317] [ARISC ERROR] :message addr   : f004b940
                          [   13.330178] [ARISC ERROR] :message state  : 5
                          [   13.338340] [ARISC ERROR] :message attr   : 0
                          [   13.346499] [ARISC ERROR] :message type   : 30
                          [   13.354758] [ARISC ERROR] :message result : dc
                          [   13.363015] [ARISC WARING] :message [30] error, callback not install
                          [   13.741201] [ARISC ERROR] :message process error
                          [   13.749770] [ARISC ERROR] :message addr   : f004b940
                          [   13.758559] [ARISC ERROR] :message state  : 5
                          [   13.766510] [ARISC ERROR] :message attr   : 0
                          [   13.774422] [ARISC ERROR] :message type   : 30
                          [   13.782420] [ARISC ERROR] :message result : dc
                          [   13.790416] [ARISC WARING] :message [30] error, callback not install
                          [   24.704260] sunxi-mmc sdc0: smc 0 p0 err, cmd 18, RD DTO !!
                          [   24.717626] sunxi-mmc sdc0: data error, sending stop command
                          [   24.731044] sunxi-mmc sdc0: reset:host reset and recover finish
                          [   24.740469] mmcblk0: timed out sending r/w cmd command, card status 0x900
                          [   24.750867] mmcblk0: not retrying timeout
                          [   24.758196] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                          [   24.773528] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   24.805871] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   24.835868] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   24.852063] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   24.929488] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                          [   24.943017] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                          [   24.956782] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                          [   24.970461] mmc0: tried to reset card
                          [   26.370437] [ARISC ERROR] :message process error
                          [   26.380649] [ARISC ERROR] :message addr   : f004b940
                          [   26.391219] [ARISC ERROR] :message state  : 5
                          [   26.401073] [ARISC ERROR] :message attr   : 0
                          [   26.410793] [ARISC ERROR] :message type   : 30
                          [   26.420475] [ARISC ERROR] :message result : dc
                          [   26.430132] [ARISC WARING] :message [30] error, callback not install
                          [   26.715931] [cpu_freq] ERR: Set cpu frequency to 1008000KHz failed!
                          [   26.728126] cpufreq: __target_index: Failed to change cpu frequency: -1
                          [   26.807810] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
                          [   27.572796] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
                          [   27.612570] systemd[1]: Detected architecture arm.
                          [   27.656922] systemd[1]: Set hostname to <Banana-Pi>.
                          [   28.186345] systemd[1]: iobroker.service: Service lacks both ExecStart= and ExecStop= setting. Refusing.
                          [   28.261426] systemd[1]: iobroker.service: Cannot add dependency job, ignoring: Unit iobroker.service is not loaded properly: Invalid argument.
                          [   28.296775] systemd[1]: Listening on Journal Audit Socket.
                          [   28.336815] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
                          [   28.376516] systemd[1]: Listening on fsck to fsckd communication Socket.
                          [   28.418006] systemd[1]: Created slice System Slice.
                          [   28.448592] systemd[1]: Created slice system-serial\x2dgetty.slice.
                          [   28.490141] systemd[1]: Mounting Debug File System...
                          [   28.520440] systemd[1]: Mounting POSIX Message Queue File System...
                          [   28.557270] systemd[1]: Listening on udev Control Socket.
                          [   28.586941] systemd[1]: Listening on Journal Socket.
                          [   28.621487] systemd[1]: Starting Restore / save the current clock...
                          [   28.660431] systemd[1]: Starting Set the console keyboard layout...
                          [   28.706446] systemd[1]: Starting Load Kernel Modules...
                          [   28.728777] systemd[1]: Listening on Journal Socket (/dev/log).
                          [   28.757274] systemd[1]: Created slice User and Session Slice.
                          [   28.786539] systemd[1]: Reached target Slices.
                          [   28.817489] systemd[1]: Created slice system-systemd\x2dfsck.slice.
                          [   28.846596] systemd[1]: Listening on udev Kernel Socket.
                          [   28.876609] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
                          [   28.906479] systemd[1]: Listening on Syslog Socket.
                          [   28.940465] systemd[1]: Starting Journal Service...
                          [   28.966485] systemd[1]: Reached target Swap.
                          [   28.997849] systemd[1]: Created slice system-getty.slice.
                          [   29.030852] systemd[1]: Mounting RPC Pipe File System...
                          [   29.064213] systemd[1]: Starting Create list of required static device nodes for the current kernel...
                          [   29.142451] systemd[1]: Mounted RPC Pipe File System.
                          [   29.176348] systemd[1]: Mounted Debug File System.
                          [   29.206563] systemd[1]: Mounted POSIX Message Queue File System.
                          [   29.236748] systemd[1]: Started Journal Service.
                          [   29.495298] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                          [   29.771337] systemd-journald[1244]: Received request to flush runtime journal from PID 1
                          [   30.100345] cfg80211: World regulatory domain updated:
                          [   30.100368] cfg80211:  DFS Master region: unset
                          [   30.100376] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
                          [   30.100388] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
                          [   30.100399] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
                          [   30.100409] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
                          [   30.100420] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
                          [   30.100431] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
                          [   30.100441] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
                          [   30.100451] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
                          [   30.100461] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
                          [   30.653410] sunxi_ir_startup: get cir supply_vol failed
                          [   30.653447] node ir_addr_code8 get failed!
                          [   30.653491] Registered IR keymap rc_map_sunxi
                          [   30.665024] input: sunxi-ir as /devices/platform/soc/s_cir0/rc/rc0/input0
                          [   30.666601] rc0: sunxi-ir as /devices/platform/soc/s_cir0/rc/rc0
                          [   30.666918] sunxi ir_protocol_judge
                          [   32.677919] IPv6: ADDRCONF(NETDEV_UP): bond0: link is not ready
                          [   32.720139] libphy: gmac0: probed
                          [   32.756253] sunxi-gmac gmac0 eth0: eth0: Type(7) PHY ID 001cc915 at 1 IRQ poll (gmac0-0:01)
                          [   32.781153] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                          [   32.785751] sunxi-bt bt: block state already is 1
                          [   34.256146] random: nonblocking pool is initialized
                          [   34.377956] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:151548k SS
                          [   35.719014] [VFE]cci probe end cci_sel = 0!
                          [   35.719281] [VFE]cci_init end
                          [   35.979561] [VFE]Welcome to Video Front End driver
                          [   35.980074] [VFE]csi0 probe end!
                          [   35.980378] [VFE]csi_init end
                          [   35.980821] [VFE]sunxi_isp_platform_register end
                          [   35.981181] [VFE]mipi_init end
                          [   35.981195] [VFE]flash_init end
                          [   35.982439] [VFE]pdev->id = 0
                          [   35.982457] [VFE]dev->cci_sel = 0
                          [   35.982463] [VFE]dev->csi_sel = 0
                          [   35.982470] [VFE]dev->mipi_sel = 0
                          [   35.982476] [VFE]dev->isp_sel = 0
                          [   35.982504] [VFE_WARN]fetch csi0_dev0_twi_id from device_tree failed
                          [   35.982529] [VFE_WARN]fetch csi0_dev0_iovdd from device_tree failed
                          [   35.982542] [VFE_WARN]fetch csi0_dev0_avdd from device_tree failed
                          [   35.982555] [VFE_WARN]fetch csi0_dev0_dvdd from device_tree failed
                          [   35.982568] [VFE_WARN]fetch csi0_dev0_afvdd from device_tree failed
                          [   35.982636] [VFE_WARN]fetch csi0_dev0_flash_en from device_tree failed
                          [   35.982649] [VFE_WARN]fetch csi0_dev0_flash_mode from device_tree failed
                          [   35.982660] [VFE_WARN]fetch csi0_dev0_flvdd from device_tree failed
                          [   35.982671] [VFE_WARN]fetch csi0_dev0_flvdd_vol from device_tree failed
                          [   35.982682] [VFE_WARN]fetch csi0_dev0_af_pwdn from device_tree failed
                          [   35.983251] [VFE]vfe_init end
                          [   35.986482] [VFE]probe_work_handle start!
                          [   35.993091] [VFE]..........................vfe clk open!.......................
                          [   35.993138] [VFE]v4l2 subdev register input_num = 0
                          [   35.993149] [VFE]vfe sensor detect start! input_num = 0
                          [   35.993161] [VFE]Find sensor name is "ov5640", i2c address is 78, type is "YUV" !
                          [   35.993169] [VFE]Sub device register "ov5640" i2c_addr = 0x78 start!
                          [   35.993181] [VFE]v4l2_device_register_subdev return 0
                          [   35.993188] [VFE]registered sensor subdev is OK!
                          [   35.993194] [VFE]Check sensor!
                          [   35.994486] [VFE]mclk on
                          [   36.062833] sensor_init 0x0
                          [   36.063182] [VFE CCI_0 ERR] Status error at addr_8bit = 78, wr_flag = 1, val = 37c00a30
                          [   36.063486] [VFE CCI_0 ERR] Status error at addr_8bit = 78, wr_flag = 1, val = 37000a30
                          [   36.063777] [VFE CCI_0 ERR] Status error at addr_8bit = 78, wr_flag = 1, val = 37000a30
                          [   36.063794] ov5640 sensor read retry=2
                          [   36.063802] [OV5640]error at sensor_detect
                          [   36.063809] [OV5640]chip found is not an target chip.
                          [   36.063820] [VFE]mclk off
                          [   36.088518] [VFE]vfe sensor subdev unregister!
                          [   36.088544] [VFE]Sub device register "ov5640" failed!
                          [   36.088553] [VFE_ERR]vfe sensor register check error at input_num = 0
                          [   36.088566] [VFE]V4L2 device registered as (null)
                          [   36.088629] [VFE]..........................vfe clk close!.......................
                          [   36.088916] [VFE]probe_work_handle end!
                          [   36.388475] dhd_module_init: in Dongle Host Driver, version 1.363.59.144.11 (r)
                          [   36.388500] ======== dhd_wlan_init_plat_data ========
                          [   36.388509] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
                          [   36.388517] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
                          [   36.388532] dhd_wlan_init_gpio: host_oob_irq: 96
                          [   36.388539] dhd_wlan_init_gpio: host_oob_irq_flags=0x4084
                          [   36.388546] dhd_wifi_platform_load: Enter
                          [   36.388579] Power-up adapter 'DHD generic adapter'
                          [   36.388682] wifi_platform_set_power = 1
                          [   36.388691] ======== PULL WL_REG_ON(-1) HIGH! ========
                          [   36.408441] [DISP] disp_ioctl,line:1865:
                          [   36.408457] para err, cmd = 0x0,screen id = 65536
                          [   36.695924] wifi_platform_bus_enumerate device present 1
                          [   36.695953] sunxi-wlan wlan: bus_index: 1
                          [   36.695960] ======== Card detection to detect SDIO card! ========
                          [   36.696028] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   36.715953] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   36.736739] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
                          [   36.737639] sunxi-mmc sdc1: smc 2 p1 err, cmd 52, RTO !!
                          [   36.737730] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   36.740313] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                          [   36.742231] sunxi-mmc sdc1: smc 2 p1 err, cmd 8, RTO !!
                          [   36.752095] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
                          [   36.753667] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
                          [   36.755232] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
                          [   36.758139] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
                          [   36.761571] mmc2: queuing unknown CIS tuple 0x81 (9 bytes)
                          [   36.847031] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                          [   36.847181] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                          [   36.847298] sunxi-mmc sdc1: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                          [   36.849513] mmc2: new high speed SDIO card at address 0001
                          [   36.866127] bcmsdh_register: register client driver
                          [   36.867921] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
                          [   36.868112] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
                          [   36.868124] bus num (host idx)=2, slot num (rca)=1
                          [   36.868134] found adapter info 'DHD generic adapter'
                          [   36.868248] sdioh_attach: set sd_f2_blocksize 256
                          [   36.868929] dhdsdio_probe : no mutex held. set lock
                          [   36.869115] F1 signature read @0x18000000=0x1541a9a6
                          [   36.872309] F1 signature OK, socitype:0x1 chip:0xa9a6 rev:0x1 pkg:0x4
                          [   36.873307] DHD: dongle ram size is set to 524288(orig 524288) at 0x0
                          [   36.873455] dhd_conf_set_chiprev: chip=0xa9a6, chiprev=1
                          [   36.874601] wl_create_event_handler(): thread:wl_event_handler:763 started
                          [   36.874606] tsk Enter, tsk = 0xe5ea14e8
                          [   36.875800] dhd_attach(): thread:dhd_watchdog_thread:764 started
                          [   36.879646] dhd_attach(): thread:dhd_dpc:765 started
                          [   36.879916] dhd_attach(): thread:dhd_rxf:766 started
                          [   36.879937] dhd_deferred_work_init: work queue initialized
                          [   36.890832] Dongle Host Driver, version 1.363.59.144.11 (r)
                          [   36.891923] Register interface [wlan0]  MAC: b0:f1:ec:0d:07:52
                          [   36.892555] wl_event_handler: was terminated
                          [   36.892604] wl_destroy_event_handler(): thread:wl_event_handler:763 terminated OK
                          [   36.892618] dhd_wl_ioctl: returning as busstate=0
                          [   36.892701] bcmsdh_oob_intr_unregister: Enter
                          [   36.892710] bcmsdh_oob_intr_unregister: irq is not registered
                          [   36.892725] dhd_txglom_enable: enable 0
                          [   36.892735] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
                          [   36.892743] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
                          [   36.892751] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
                          [   36.892759] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=1
                          [   36.892767] sdioh_set_mode: set txglom_mode to multi-desc
                          [   36.892774] dhd_bus_devreset:  WLAN OFF DONE
                          [   36.892828] wifi_platform_set_power = 0
                          [   36.892837] ======== PULL WL_REG_ON(-1) LOW! ========
                          [   36.892856] dhdsdio_probe : the lock is released.
                          [   36.892984] dhd_module_init: Exit err=0
                          [   37.756245] sunxi-gmac gmac0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
                          [   37.756316] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                          [   38.097749] CFG80211-ERROR) wl_cfg80211_add_virtual_iface : device is not ready
                          [   38.105891] cfg80211: Regulatory domain changed to country: DE
                          [   38.106171] cfg80211:  DFS Master region: ETSI
                          [   38.106181] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
                          [   38.106193] cfg80211:   (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
                          [   38.106205] cfg80211:   (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
                          [   38.106216] cfg80211:   (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
                          [   38.106235] cfg80211:   (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
                          [   38.106248] cfg80211:   (5725000 KHz - 5875000 KHz @ 80000 KHz), (N/A, 1397 mBm), (N/A)
                          [   38.106258] cfg80211:   (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
                            Thomas Braun Most Active @SG_IoBroker last edited by Thomas Braun
                            @SG_IoBroker
                            Klarer Fall. Die Karte dürfte tot sein.
                            Ich wunder mich nur über btrfs als Filesystem. Ist etwas exotisch.
                              SG_IoBroker @Thomas Braun last edited by
                              @Thomas-Braun
                              Kann ich das alles so 1 zu 1 kopieren? Damit ich nicht wieder alles neu Einrichten muss?
                                @SG_IoBroker
                                Nein, neue Karte, neue Installation. Beim kopieren/clonen würdest du ja den kaputten Kram mitkopieren.
                                  @Thomas-Braun
                                  OK super. Vielen Dank
                                  iobroker startet nicht mehr xiaomi vacuum
                                  509
