    4. Test Adapter Rain Bird v0.1.x GitHub
      myssv last edited by
      Ich habe es jetzt so gelöst:
      So kann ich zwar noch nicht die Laufzeit individuell einstellen, aber ich kann alle Zonen auf einen Schlag anstoßen.
        meerkat @myssv last edited by
        sagt mal welche Version habt ihr vom Adapter? Bei mir hagelt es nur Fehler.
        rainbird.0	2020-08-11 18:46:04.822	info	(30264) Terminated (NO_ERROR): Without reason
        rainbird.0	2020-08-11 18:46:04.820	info	(30264) terminating
        rainbird.0	2020-08-11 18:46:04.803	error	at Socket.emit (events.js:198:13)
        rainbird.0	2020-08-11 18:46:04.803	error	at Socket.socketErrorListener (_http_client.js:401:9)
        rainbird.0	2020-08-11 18:46:04.803	error	at ClientRequest.emit (events.js:203:15)
        rainbird.0	2020-08-11 18:46:04.803	error	at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:877:8)
        rainbird.0	2020-08-11 18:46:04.803	error	at Request.emit (events.js:198:13)
        rainbird.0	2020-08-11 18:46:04.803	error	at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
        rainbird.0	2020-08-11 18:46:04.803	error	at Request._callback (/opt/iobroker/node_modules/iobroker.rainbird/lib/rainbird.js:226:17)
        rainbird.0	2020-08-11 18:46:04.803	error	at /opt/iobroker/node_modules/iobroker.rainbird/lib/rainbird.js:403:25
        rainbird.0	2020-08-11 18:46:04.803	error	at /opt/iobroker/node_modules/iobroker.rainbird/lib/rainbird.js:467:27
        rainbird.0	2020-08-11 18:46:04.803	error	at Object.callback (/opt/iobroker/node_modules/iobroker.rainbird/lib/rainbird.js:521:39)
        rainbird.0	2020-08-11 18:46:04.803	error	(30264) TypeError: Cannot read property 'setStations' of undefined
        rainbird.0	2020-08-11 18:46:04.801	error	(30264) uncaught exception: Cannot read property 'setStations' of undefined
        rainbird.0	2020-08-11 18:46:04.799	warn	(30264) Error in request from client for AvailableStations: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80}
        rainbird.0	2020-08-11 18:46:04.798	warn	(30264) Request reply error: [{"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80},null,null]
        rainbird.0	2020-08-11 18:46:04.787	warn	(30264) Error in request from client for CurrentDate: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80}
        rainbird.0	2020-08-11 18:46:04.786	warn	(30264) Request reply error: [{"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80},null,null]
        rainbird.0	2020-08-11 18:46:04.771	warn	(30264) Error in request from client for SerialNumber: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80}
        rainbird.0	2020-08-11 18:46:04.770	warn	(30264) Request reply error: [{"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80},null,null]
        rainbird.0	2020-08-11 18:46:04.754	warn	(30264) Error in request from client for ModelAndVersion: {"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80}
        rainbird.0	2020-08-11 18:46:04.752	warn	(30264) Request reply error: [{"errno":"ECONNREFUSED","code":"ECONNREFUSED","syscall":"connect","address":"192.168.178.189","port":80},null,null]
        rainbird.0	2020-08-11 18:46:04.634	info	(30264) [INFO] Configured polling interval: 10000
        rainbird.0	2020-08-11 18:46:04.614	info	(30264) [START] Starting Rain Bird adapter V0.2.2r39
        • Feuersturm
          Feuersturm @meerkat last edited by
          @meerkat Hi,
          ich hab bei mir die Version 0.2.3 im Einsatz und aktuell keine Probleme. Im Einsatz hab ich als Rainbird der die das ESP-ME
          rainbird.0	2020-08-11 22:09:44.544	info	(9452) [INFO] Configured polling interval: 20000
          rainbird.0	2020-08-11 22:09:44.538	info	(9452) [START] Starting Rain Bird adapter V0.2.3r44
          rainbird.0	2020-08-11 22:09:44.501	info	(9452) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.rainbird, node: v12.18.0, js-controller: 3.1.6
            meerkat @Feuersturm last edited by
            @Feuersturm Hi, danke für die Info. Dann mache ich mich morgen mal auf die Suche nach der .23 Version. Über iobroker bekomme ich nur die .22 Version.
            • Feuersturm
              Feuersturm @meerkat last edited by Feuersturm
              @meerkat Ich hab die Version "damals" aus Github über das Symbol mit der Katze installiert. Siehe https://forum.iobroker.net/topic/28924/test-adapter-rain-bird-v0-1-x-github/114
              Wenn sich seitdem im Github am Code nichts verändert hat, solltest du es gefahrlos installieren können. Wenn es danach noch Änderungen gab, sollte man aus Github nur die Versionen installieren, wenn der Entwickler dazu aufruft 😉 ansonsten könnte es unerwartete Nebeneffekte geben.
                @Feuersturm vielen Dank noch mal. Nun läuft es. Jetzt hätte ich nich eine Frage. Ich habe den ESP-RZXE mit LNK, leider kann man nur max 99 Minuten einstellen, wenn ich eine manuelle bewässerung starte. Können die Rainbird Steuergeräte nicht mehr? Oder liegt dies am Adapter?
                • Feuersturm
                  @meerkat Hab ich noch nicht getestet. Meine einzeln Kreise laufen aktuell 20 Minuten einmal in der Nacht. Ich kann morgen mal bei meiner Station schauen was sich maximal einstellen lässt.
                  • Feuersturm
                    Feuersturm last edited by Feuersturm
                    Mittlerweile ist es Herbst und die Bewässerung muss nur noch sehr selten laufen. Ich habe bisher über die App die Bewässerungszeiten festgelegt. Ich möchte jetzt die Bewässerung auf unbestimmte Zeit stoppen, so dass der hinterlegte Zeitplan nicht greift.
                    Die einzige Lösungsmöglichkeit die ich bisher sehe ist, jeden Tag per Skript den Datenpunkt rainbird.0.device.settings.rainDelay z.B. immer wieder auf 2 zu setzen, um den im Rainbird Controller hinterlegten Zeitplan zu verzögern.
                    Wie habt ihr das ganze gelöst?
                    bilberry 1 Reply Last reply Reply Quote 0
                    • bilberry
                      bilberry @Feuersturm last edited by
                      @Feuersturm
                      Hab auch schon überlegt, wie man das komfortabel machen könnte. Bislang blieb mir nur die sinnvolle Lösung, direkt am Controller "Stopp" zu drücken. Dann geht auch der Datenpunkt rainbird.0.device.irrigation.active auf false .
                      Schade, das der nur schreiben kann. Kommt aber vielleicht auf einen Versuch an. Eventuell geht das ja doch?
                      Aber die von Dir beschriebene Lösung via Script scheint mir ein guter Workaround zu sein.
                      • Feuersturm
                        Feuersturm @bilberry last edited by Feuersturm
                        @bilberry Ich hab meinen Workaround mal als kleines Skript zusammengeschrieben:
                        const debug = true;
                        const DP_Bewaesserung_dauerhaft_pausieren = 'javascript.0.rainbird.Bewaesserung_dauerhaft_pausieren';
                        createState(DP_Bewaesserung_dauerhaft_pausieren, false, {name: 'TRUE pausiert die Bewasserung durch regelmaessiges Setzen des Adapterdatenpunktes rainDelay', unit: '', type: 'boolean', role: 'value', def: false});
                        function SetRainDelay(days){
                           if(debug) console.log("RainDelay wird auf " + days + " Tage gesetzt");
                           setState('rainbird.0.device.settings.rainDelay',days);
                        on({id: DP_Bewaesserung_dauerhaft_pausieren, change: "ne"}, function(obj){
                           if(getState(DP_Bewaesserung_dauerhaft_pausieren).val === true){
                               if(debug) console.log("Raindelay wird neu gesetzt weil Bewässerung dauerhaft pausiert werden soll");
                               SetRainDelay(5); //RainDelay wird auf 5 Tage gesetzt
                           } else{
                               if(debug) console.log("Datenpunkt DP_Bewaesserung_dauerhaft_pausieren wurde auf FALSE gesetzt");
                               SetRainDelay(0);    //RainDelay wird auf 0 Tage gesetzt und somit deaktiviert
                        //Ausfuehrung einmal am Tag / Mitternacht
                        schedule("0 1 * * *", function () {
                        Über einen Schalter / Checkbox setze ich dann in meiner Bewässerungsview den Datenpunkt auf true
                        Änderungshistorie:
                        04.10.2020 Schedule im Skript korrigiert
                        Feuersturm 1 Reply Last reply Reply Quote 1
                        • Feuersturm
                          Feuersturm @Feuersturm last edited by
                          Ich hab das Skript korrigiert. Der Schedule war nicht ganz korrekt, jedenfalls hat es bei mir nicht dazu geführt, dass jeden Tag der Wert neu gesetzt wurde.
                          Ich hab den Schedule jetzt so eingestellt, dass jede Nacht um 1 Uhr die Funktion aufgerufen wird. Bei mir funktioniert es soweit.
                          • bilberry
                            @Feuersturm
                            Hi, hab Dein Skript noch nicht in der Praxis probiert. Bei ersten Überfliegen am Montag schien mir alles plausibel gecoded und mir ist nichts problematisches ausgefallen. Was hat denn nicht funktioniert?
                            • Feuersturm
                              Hallo @bilberry, wenn man nur den Datenpunkt rainbird.0.device.settings.rainDelay auf einen definierten Wert setzt, dann ist dieser Wert einen Tag später um 1 dekrementiert.
                              In der ersten Version vom Skript hatte ich für den schedule folgendes eingetsellt: schedule("0 0 * * *", ...
                              Ich hatte erwartet, dass am nächsten Tag dann der Wert für rainbird.0.device.settings.rainDelay wieder auf 5 steht, dem war aber nicht so, sondern der Wert war inkrementiert. Erst als ich den schedule auf schedule("0 1 * * *", ... gestellt habe sehe ich am nächsten Tag, dass der im Skript definierte Wert 5 korrekt eingetragen ist.
                                PeterSCP @StrathCole last edited by
                                @strathcole
                                Hallo Alle zusammen
                                da ich ein Neuling bin hätte ich ein paar Fragen
                                1. Kann ich den Code auch in Node-red verwenden.
                                2. Wenn ja welche Schritte muss ich machen das ich auf meinen Rain bird zugreifen kann.
                                Danke im Voraus für euere Hilfe
                                liebe Grüsse
                                StrathCole 1 Reply Last reply Reply Quote 0
                                • StrathCole
                                  StrathCole @PeterSCP last edited by
                                  @peterscp Sorry, dazu kann ich nichts sagen, habe node-red nie verwendet.
                                    lucky51179 @StrathCole last edited by
                                    @strathcole Hallo, würde den Adapter auch gerne installieren leider geht das nicht ich kann den Link einfügen finde aber Schluss nichts mit Rainbird im IObroker hatte das Problem jemand anders auch oder gibt es da einen Trick ?
                                    • Feuersturm
                                      Feuersturm @lucky51179 last edited by Feuersturm
                                      @lucky51179 Hi, du findest den Rainbird Adapter in der Liste der Adapter. Eine Installation über den Github Link ist nicht notwendig (und sollte auch nur dann gemacht werden, wenn dies vom Entwickler gesagt wird, ansonsten kann es passieren, dass du dir irgendwelche Entwicklerstände installierst).
                                        lucky51179 @Feuersturm last edited by
                                        @feuersturm wenn ich nach dem Adapter suche wird aber nichts angezeigt. Ich finde ihn nicht
                                        • Feuersturm
                                          @lucky51179 Ah, der Adapter liegt aktuell nur im Beta Repository. Siehe auch https://github.com/StrathCole/ioBroker.rainbird/issues/3
                                          Du kannst in den iobroker Einstellungen das Repository kurzzeitig auf Beta umstellen und die den Rainbird Adapter installieren. Wechsel danach wieder auf das stable, damit dir nur die Versionen zur Aktualisierung angeboten werden, welche schon mehr getestet sind.
                                          Gibt es einen Grund @StrathCole warum der Adapter noch nicht im stable ist?
                                          ioBrokerChecker created this issue in StrathCole/ioBroker.rainbird
                                          closed Please also add your adapter to the stable repository once ready #3
                                          L StrathCole 2 Replies Last reply Reply Quote 0
                                            @feuersturm said in Test Adapter Rain Bird v0.1.x GitHub:
                                            Beta Repository.
                                            wie stellt man das ein das man die sieht ?
                                            79.9k
                                            bewässerung rain bird
                                            21
                                            215
                                            24058
