    4. Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252
    UNSOLVED Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252
      Jona @Jona last edited by
      Leider muss ich den Thread wiederbeleben. Die Probleme sind weiterhin vorhanden. Zwar ist der Neustart jetzt kein Problem mehr, weil ich jetzt einen USB2 anstatt USB3 Port nutze, aber nachdem mal etwas läuft, kann man sich schon bald wieder auf diese Fehler einstellen.
      2020-09-28 11:06:27.718 - error: zigbee.0 (1740) Error on send command to 0x00158d0002e34b33. Error: Error: Command 0x00158d0002e34b33/2 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":13765,"destendpoint":2,"srcendpoint":1,"clusterid":6,"transid":49,"options":0,"radius":30,"len":3,"data":{"type":"Buffer","data":[1,24,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)'))
      at Znp. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:291:27)
      at Generator.next ()
      at fulfilled (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:24:58)
      2020-09-28 11:06:30.480 - error: zigbee.0 (1740) Error on send command to 0x00158d0002e34b33. Error: Error: Command 0x00158d0002e34b33/2 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":13765,"destendpoint":2,"srcendpoint":1,"clusterid":6,"transid":50,"options":0,"radius":30,"len":3,"data":{"type":"Buffer","data":[1,25,1]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)'))
      2020-09-28 11:06:49.663 - error: zigbee.0 (1740) Error on send command to 0x00158d0002f8d5b4. Error: Error: Command 0x00158d0002f8d5b4/2 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":5944,"destendpoint":2,"srcendpoint":1,"clusterid":6,"transid":51,"options":0,"radius":30,"len":3,"data":{"type":"Buffer","data":[1,26,0]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)'))
      2020-09-28 11:06:59.248 - error: zigbee.0 (1740) Error on send command to 0x00158d0002f8d76c. Error: Error: Command 0x00158d0002f8d76c/2 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (SREQ '--> AF - dataRequest - {"dstaddr":28411,"destendpoint":2,"srcendpoint":1,"clusterid":6,"transid":53,"options":0,"radius":30,"len":3,"data":{"type":"Buffer","data":[1,28,1]}}' failed with status '(0x02: INVALID_PARAM)' (expected '(0x00: SUCCESS)'))
      Es ist wirklich wahnsinnig ärgerlich, da so nichts zuverlässig funktioniert. Meistens passiert nach einem Befehl nichts, manchmal wird der Befehl doch überraschend nach fünf bis zehn Sekunden ausgeführt. Ich habe viel in diesem Forum nach solchen Fehlern gesucht, aber nie einen Thread mit Lösung gefunden. Wenn ich etwas bei diesen tausenden Möglichkeiten übersehen haben sollte, gerne einfach einen Link zum Beitrag setzen. Ohne Hilfe komme ich hier aber nicht weiter.
      Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jona last edited by
        @Jona
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          Jona @Thomas Braun last edited by
          @Thomas-Braun
          /usr/bin/nodejs
          v10.21.0
          /usr/local/bin/node
          v12.13.0
          /usr/local/bin/npm
          6.14.2
          nodejs:
            Installed: 10.21.0~dfsg-1~deb10u1+rpi1
            Candidate: 10.21.0~dfsg-1~deb10u1+rpi1
            Version table:
           *** 10.21.0~dfsg-1~deb10u1+rpi1 500
                  100 /var/lib/dpkg/status
            @Jona
            Node ist falsch installiert.
            Korrigier es:
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/3
              @Thomas-Braun Hab ich nun gemacht, bekomme über meine Quelle aber nur v10.
              /usr/bin/nodejs
              v10.21.0
              /usr/bin/node
              v10.21.0
              /usr/bin/npm
              5.8.0
              nodejs:
                Version table:
                @Jona
                Dann leg die Quellen richtig an. Steht auch in der Anleitung. Im ersten Eintrag.
                • Asgothian
                  Asgothian Developer @Jona last edited by
                  @Jona sagte in Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252:
                  Ich muss leider ein paar Fragen stellen bevor ich da richtig aktiv werden kann:
                  • Was fuer einen Koordinator (zigbee-Stick) setzt du ein - immer noch den cc2531 ?
                  • Wie viele Zigbee Geräte hat Dein Netz ?
                  • Welche Geräte sind betroffen ? Aus dem Log kann ich nur erkennen das es sich anscheinend um Geräte eines Herstellers handelt, nicht aber welche
                  • Reagieren die Geräte, sprich ist nur die Antwort nicht wie erwartet, oder reagieren die Geräte nicht (Das Log zeigt eindeutig Schaltversuche - da wird etwas an oder abgeschaltet)
                  • Sollte es sich bei den Geräten um Osram Steckdosen handeln bräuchte ich auch deren Firmware Version. Ich hatte mit meinen mit einer alten Firmware Probleme.
                  A.
                    Jona @Thomas Braun last edited by Jona
                    @Thomas-Braun Nun ist das zwar so, wie Du es in deinem Blog-Post beschrieben hast, jetzt sind aber mein Zigbee und BLE Adapter dauerhaft auf rot. 😕
                    /usr/bin/nodejs
                    v12.18.4
                    /usr/bin/node
                    v12.18.4
                    /usr/bin/npm
                    6.14.6
                    nodejs:
                      Installed: 12.18.4-1nodesource1
                      Candidate: 12.18.4-1nodesource1
                      Version table:
                     *** 12.18.4-1nodesource1 500
                            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                    2020-09-28 12:46:37.967 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                    2020-09-28 12:47:07.996 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 4776
                    2020-09-28 12:47:08.554 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
                    2020-09-28 12:47:08.554 - error: host.raspberrypi Caught by controller[0]: throw e;
                    2020-09-28 12:47:08.554 - error: host.raspberrypi Caught by controller[0]: ^
                    2020-09-28 12:47:08.554 - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.64: cannot open shared object file: No such file or directory
                    2020-09-28 12:47:08.555 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1187:18)
                    2020-09-28 12:47:08.555 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                    2020-09-28 12:47:08.555 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                    2020-09-28 12:47:08.555 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                    2020-09-28 12:47:08.555 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                    2020-09-28 12:47:08.555 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
                    2020-09-28 12:47:08.556 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                    2020-09-28 12:47:08.556 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                    2020-09-28 12:47:08.556 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                    2020-09-28 12:47:08.556 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                    2020-09-28 12:47:08.556 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      @Jona
                      iobroker stop
                      iobroker fix
                      iobroker start
                        @Thomas-Braun Schon gemacht, keine Besserung.
                          Jona @Asgothian last edited by
                          @Asgothian
                          • Genau, ich nutze weiterhin den cc2531.
                          • Ich nutze derzeit 24 Geräte über Zigbee. Auch OSRAM Steckdosen sind betroffen!
                          • Wenn etwas nicht geht, sind alle betroffen (Lichtschalter, Lampen, Steckdosen, etc.)
                          • Die Geräte reagieren nicht. Ich kann nachvollziehen, dass der Befehl im Objekt geändert wird.
                          • Dazu (OSRAM Firmware) höre ich gerne deine Erfahrung!
                            Thomas Braun Most Active @Jona last edited by Thomas Braun
                            @Jona
                            Das ist eine 64bit-Library. Da ist bei dir noch irgendwas anderes krumm. Denn Raspbian OS ist eigentlich 32bit.
                            sudo apt remove node-*
                            apt policy libnode64
                              @Thomas-Braun Hierdurch ist leider mein gesamtes Smarthome lahm gelegt, weil Bluetooth Low Energy und Zigbee meine einzigen beiden Bindestellen nach außen sind. Hast Du eine Idee, wie ich das reparieren kann?
                                @Jona
                                Da scheint mir noch unnötiger Kram drauf zu sein.
                                sudo apt remove libnode*
                                  @Thomas-Braun Komischer Weise sucht er beim ersten noch nach Version 10.
                                  ~ $ sudo apt remove node-*
                                  Reading package lists... Done
                                  Building dependency tree
                                  E: Unable to locate package node-v10.16.0-linux-armv7l
                                  E: Couldn't find any package by glob 'node-v10.16.0-linux-armv7l'
                                  E: Couldn't find any package by regex 'node-v10.16.0-linux-armv7l'
                                  ~ $ sudo apt remove libnode*
                                  Note, selecting 'libnodeletlib-dev' for glob 'libnode*'
                                  Note, selecting 'libnodeletlib1d' for glob 'libnode*'
                                  Note, selecting 'libnodelet-topic-tools-dev' for glob 'libnode*'
                                  Note, selecting 'libnodeletlib-tools' for glob 'libnode*'
                                  Note, selecting 'libnode64-dev' for glob 'libnode*'
                                  Note, selecting 'libnode-dev' for glob 'libnode*'
                                  Note, selecting 'libnode64' for glob 'libnode*'
                                  Note, selecting 'libnodelet-dev' for glob 'libnode*'
                                  Package 'libnode64-dev' is not installed, so not removed
                                  Package 'libnode-dev' is not installed, so not removed
                                  Package 'libnode64' is not installed, so not removed
                                  Package 'libnodelet-dev' is not installed, so not removed
                                  Package 'libnodelet-topic-tools-dev' is not installed, so not removed
                                  Package 'libnodeletlib-dev' is not installed, so not removed
                                  Package 'libnodeletlib-tools' is not installed, so not removed
                                  Package 'libnodeletlib1d' is not installed, so not removed
                                  The following packages were automatically installed and are no longer required:
                                    gyp libc-ares2 libgfortran3 libgmime-2.6-0 libjs-inherits
                                    libjs-is-typedarray libllvm8 libmicrodns0 libncurses5 libuv1 libuv1-dev
                                    libva-wayland2 node-abbrev node-ajv node-ansi node-ansi-align
                                    node-ansi-regex node-ansi-styles node-ansistyles node-aproba node-archy
                                    node-are-we-there-yet node-asn1 node-assert-plus node-asynckit
                                    node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf node-bluebird
                                    node-boxen node-brace-expansion node-builtin-modules node-builtins
                                    node-cacache node-call-limit node-camelcase node-caseless node-chalk
                                    node-chownr node-cli-boxes node-cliui node-clone node-co node-color-convert
                                    node-color-name node-combined-stream node-concat-map node-concat-stream
                                    node-config-chain node-console-control-strings node-copy-concurrently
                                    node-core-util-is node-cross-spawn node-cyclist node-dashdash
                                    node-decamelize node-decompress-response node-deep-extend node-defaults
                                    node-delayed-stream node-delegates node-detect-indent node-detect-newline
                                    node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding
                                    node-end-of-stream node-errno node-escape-string-regexp node-execa
                                    node-extend node-extsprintf node-find-up node-flush-write-stream
                                    node-forever-agent node-form-data node-from2 node-fs-vacuum
                                    node-fs-write-stream-atomic node-fs.realpath node-gauge node-get-caller-file
                                    node-get-stream node-getpass node-glob node-got node-graceful-fs
                                    node-har-schema node-har-validator node-has-flag node-has-symbol-support-x
                                    node-has-to-string-tag-x node-has-unicode node-hosted-git-info
                                    node-http-signature node-iconv-lite node-iferr node-import-lazy
                                    node-imurmurhash node-inflight node-inherits node-ini node-invert-kv
                                    node-is-builtin-module node-is-npm node-is-object node-is-plain-obj
                                    node-is-retry-allowed node-is-stream node-is-typedarray node-isarray
                                    node-isexe node-isstream node-isurl node-jsbn node-json-parse-better-errors
                                    node-json-schema node-json-stable-stringify node-json-stringify-safe
                                    node-jsonify node-jsonparse node-jsonstream node-jsprim node-latest-version
                                    node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile
                                    node-lowercase-keys node-lru-cache node-mem node-mime-types node-mimic-fn
                                    node-mimic-response node-minimatch node-minimist node-mississippi
                                    node-mkdirp node-move-concurrently node-mute-stream node-node-uuid node-nopt
                                    node-normalize-package-data node-npm-package-arg node-npm-run-path
                                    node-npmlog node-oauth-sign node-object-assign node-once node-opener
                                    node-os-locale node-osenv node-p-cancelable node-p-finally node-p-limit
                                    node-p-locate node-p-timeout node-package-json node-parallel-transform
                                    node-path-exists node-path-is-absolute node-path-is-inside
                                    node-performance-now node-prepend-http node-process-nextick-args
                                    node-promise-inflight node-promzard node-proto-list node-prr node-pump
                                    node-pumpify node-punycode node-qs node-qw node-rc node-read
                                    node-read-package-json node-readable-stream node-registry-auth-token
                                    node-registry-url node-request node-require-directory
                                    node-require-main-filename node-resolve-from node-retry node-rimraf
                                    node-run-queue node-safe-buffer node-semver node-semver-diff
                                    node-set-blocking node-sha node-shebang-command node-shebang-regex
                                    node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct
                                    node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
                                    node-stream-each node-stream-iterate node-stream-shift node-string-decoder
                                    node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
                                    node-supports-color node-tar node-term-size node-text-table node-through
                                    node-through2 node-timed-out node-tough-cookie node-tunnel-agent
                                    node-tweetnacl node-typedarray node-uid-number node-unique-filename
                                    node-unpipe node-url-parse-lax node-url-to-options node-util-deprecate
                                    node-uuid node-validate-npm-package-license node-validate-npm-package-name
                                    node-verror node-wcwidth.js node-which node-which-module node-wide-align
                                    node-widest-line node-wrap-ansi node-wrappy node-write-file-atomic
                                    node-xdg-basedir node-xtend node-y18n node-yallist node-yargs
                                    node-yargs-parser nodejs-doc rpi-eeprom-images
                                  Use 'sudo apt autoremove' to remove them.
                                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    @Jona
                                    Das ist alles alter Kram.
                                    sudo apt autoremove
                                    sudo reboot
                                    Dann würde ich nodejs noch mal drüber bügeln:
                                    iobroker stop
                                    sudo apt install nodejs --reinstall
                                    iobroker start
                                      @Thomas-Braun Zwischendurch erst einmal danke für deine Mühe und Hilfe.
                                      Leider sind die beiden Adapter noch immer auf rot.
                                      Der Fehler-Log sieht so aus:
                                      2020-09-28 13:21:00.300 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                                      2020-09-28 13:21:30.328 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2930
                                      2020-09-28 13:21:30.954 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
                                      2020-09-28 13:21:30.954 - error: host.raspberrypi Caught by controller[0]: throw e;
                                      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: ^
                                      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.64: cannot open shared object file: No such file or directory
                                      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1187:18)
                                      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                                      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                                      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                                      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                                      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
                                      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                                      2020-09-28 13:21:30.957 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                                      2020-09-28 13:21:30.957 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                                      2020-09-28 13:21:30.957 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      Thomas Braun F 2 Replies Last reply Reply Quote 0
                                        @Jona
                                        sudo apt update
                                        sudo apt upgrade
                                        apt policy node-*
                                        Gut möglich, dass man dann noch einen npm rebuild hinterherwerfen muss, wenn die Pakete sauber sind.
                                        J Thomas Braun 2 Replies Last reply Reply Quote 0
                                          @Thomas-Braun Keine Updates verfügbar und:
                                          ~ $ apt policy node-*
                                          N: Unable to locate package node-v10.16.0-linux-armv7l
                                          N: Couldn't find any package by glob 'node-v10.16.0-linux-armv7l'
                                          N: Couldn't find any package by regex 'node-v10.16.0-linux-armv7l'
                                            Bitte die komplete Ein- und Ausgabe inkl. Login Prompt von
                                            sudo apt update
                                            Nix kürzen, nix weglöschen.
                                            cc2531 homekit neustart pi 4 raspberry pi 4 yahka zigbee
                                            3136
