    4. Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252
    UNSOLVED Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252
      Jona @Thomas Braun last edited by
      @Thomas-Braun Zwischendurch erst einmal danke für deine Mühe und Hilfe.
      Leider sind die beiden Adapter noch immer auf rot.
      Der Fehler-Log sieht so aus:
      2020-09-28 13:21:00.300 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2020-09-28 13:21:30.328 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 2930
      2020-09-28 13:21:30.954 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:121
      2020-09-28 13:21:30.954 - error: host.raspberrypi Caught by controller[0]: throw e;
      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: ^
      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: Error: libnode.so.64: cannot open shared object file: No such file or directory
      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1187:18)
      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
      2020-09-28 13:21:30.955 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:112:48)
      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
      2020-09-28 13:21:30.956 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
      2020-09-28 13:21:30.957 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
      2020-09-28 13:21:30.957 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
      2020-09-28 13:21:30.957 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      Thomas Braun F 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jona last edited by
        @Jona
        sudo apt update
        sudo apt upgrade
        apt policy node-*
        Gut möglich, dass man dann noch einen npm rebuild hinterherwerfen muss, wenn die Pakete sauber sind.
        J Thomas Braun 2 Replies Last reply Reply Quote 0
          @Thomas-Braun Keine Updates verfügbar und:
          ~ $ apt policy node-*
          N: Unable to locate package node-v10.16.0-linux-armv7l
          N: Couldn't find any package by glob 'node-v10.16.0-linux-armv7l'
          N: Couldn't find any package by regex 'node-v10.16.0-linux-armv7l'
            @Jona sagte in Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252:
            Bitte die komplete Ein- und Ausgabe inkl. Login Prompt von
            sudo apt update
            Nix kürzen, nix weglöschen.
              @Thomas-Braun
              pi@raspberrypi:~ $ sudo apt update && sudo apt upgrade
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
              Get:3 https://download.docker.com/linux/raspbian buster InRelease [29.7 kB]
              Hit:4 https://deb.nodesource.com/node_12.x buster InRelease
              Hit:6 https://packagecloud.io/headmelted/codebuilds/debian stretch InRelease
              Hit:5 https://dl.ubnt.com/unifi/debian stable InRelease
              Fetched 29.7 kB in 2s (13.7 kB/s)
              Reading package lists... Done
              Building dependency tree
              All packages are up to date.
              Calculating upgrade... Done
              0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              pi@raspberrypi:~ $ apt policy node-*
              pi@raspberrypi:~ $ sudo apt policy node-*
                Thomas Braun Most Active @Jona last edited by Thomas Braun
                Was sind das für Quellen? Brauchst du die? Und warum steht die von packagecloud auf stretch?
                  Jona @Thomas Braun last edited by Jona
                  @Thomas-Braun Mit Docker habe ich mal herumgespielt, kann aber gelöscht werden. Letzteres ist für meinen Unifi Controller - ich glaube nicht, dass das etwas hiermit zu tun hat.
                    @Jona
                    Und packagecloud?
                    Deaktivier die mal alle drei.
                      fabwal @Jona last edited by
                      @Jona
                      Hast du deine Adapter nach dem Update auf node 12 neu installiert?
                      iobroker rebuild apdatername --install
                      Siehe auch hier:
                      https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                      (Ich hatte übrigens auch immer diverse Probleme mit dem CC2531 und habe ihn dann auf Anraten des Forums in die Tonne gekloppt. Das Teil ist für größere Mesh Netze nur bedingt geeignet. Mal klappt es, mal nicht...)
                        Jona @fabwal last edited by
                        @fabwal Super Tipp - das war es! Nun kann ich Zigbee und BLE wieder nutzen. Mal schauen, ob die Fehler nach dem Richten meiner Nodejs Installation weiterhin auftauchen.
                          Thomas Braun Most Active @Thomas Braun last edited by
                          @Thomas-Braun sagte in Probleme mit Zigbee / Generator.next / ZStackAdapter / 2252:
                          Ich zitier mich mal selber...:
                          Wobei deine Paketdatenbank wohl noch nicht konsistent ist, denke ich.
                            @Thomas-Braun Wie kann ich das überprüfen? Ich habe mit den Befehlen gearbeitet, die du im zitierten Beitrag genannt hast.
                              @fabwal Gibt es denn eine Alternative? Ich dachte, das sei der "Golden Standard", meiner hat auch extra eine dedizierte Antenne.
                                @Jona
                                Ich würde ja die drei Quellen mal auf Eis legen. Insbesondere die mit 'stretch' drin.
                                • Asgothian
                                  Asgothian Developer @Jona last edited by
                                  Der CC2531 war mal der einzige der so richtig ging. Inzwischen gibt es reichlich alternativen, siehe
                                  https://www.zigbee2mqtt.io/information/supported_adapters.html
                                  Auch mit Antenne hat der CC2531 das Problem das er sehr wenig Speicher besitzt. Dieser kann insbesondere bei grossen / komplexen Netzen durchaus mal voll laufen, was zu verschiedenen Fehlern bei der Nachrichtenübermittlung führt.
                                  Ich persönlich setze einen Texas Instruments LAUNCHXL-CC26X2R1 ein, da ich den problemlos und ohne externe Geräte selber aktualisieren kann. Es gibt aber auch im Forum Quellen für andere Sticks - wirf mal einen Blick in den Marktplatz.
                                  Vom Conbee / Conbee II mit Zigbee wuerde ich aktuell noch abraten - das ist noch experimentell.
                                  A.
                                    @Thomas-Braun Docker und Packagecloud kann ich entfernen (dazu gerne noch einen kleinen Hinweis dazu, wie das am besten geht). Das Unifi repo brauche ich zwingend für meinen Unifi Controller!
                                      @Jona
                                      Im Verzeichnis /etc/apt/sources.list.d/
                                      dürften mehrere Dateien liegen, die diese Quellen beinhalten.
                                      In den Einträgen die zu deaktivieren sind einfach ein
                                      vor den Eintrag / die Zeile setzen und damit 'auskommentieren'.
                                      Wenn im Verzeichnis nicht alle zu finden sind schau dir die Datei
                                      an. Da könnte sich auch ein Eintrag verstecken.
                                        @Thomas-Braun Das habe ich gemacht und auch schon ein update und upgrade durchgeführt. Aber wozu eigentlich?
                                          @Jona
                                          Weil du da noch irgendwelche Abhängigkeiten zu einem Paket
                                          drin hast. Das sollte eigentlich nicht sein.
                                            @Thomas-Braun Dann wird es wohl an Unifi liegen. Die anderen beiden Quellen habe ich auskommentiert, der Fehler auf den Befehl
                                            apt policy node-*
                                            bleibt der selbe.
                                            Der Unifi Controller ist aber essentiell für mein Heimnetzwerk.
                                            cc2531 homekit neustart pi 4 raspberry pi 4 yahka zigbee
                                            3152
